[U-Boot] [PATCH] mmc: rmobile: add a compiler barrier
Building w/ GCC v5.2, the SD card access is broken due to invalid data in the response command reconstructed at the end of sh_sdhci_get_response().
Add a memory barrier between the two main steps of this function to ensure the resp[] table content is consistent before bits reordering.
This fix has been tested Ok on Porter board rev1.0 using v2016.03 release.
Signed-off-by: Yannick Gicquel yannick.gicquel@iot.bzh --- drivers/mmc/sh_sdhi.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/sh_sdhi.c b/drivers/mmc/sh_sdhi.c index 30e538c..dc4c686 100644 --- a/drivers/mmc/sh_sdhi.c +++ b/drivers/mmc/sh_sdhi.c @@ -430,6 +430,9 @@ static void sh_sdhi_get_response(struct sh_sdhi_host *host, struct mmc_cmd *cmd) }
p2 = (unsigned long *)cmd->response; + + barrier(); + #if defined(__BIG_ENDIAN_BITFIELD) for (i = 0; i < cnt; i++) { *p2++ = ((*p1 >> 16) & 0x0000ffff) |
Applied, thanks.
Best regards, Nobuhiro
2016-04-04 18:49 GMT+09:00 Yannick Gicquel yannick.gicquel@iot.bzh:
barrier();
#if defined(__BIG_ENDIAN_BITFIELD) for (i = 0; i < cnt; i++) { *p2++ = ((*p1 >> 16) & 0x0000ffff) | -- 1.9.1
Nobuhiro Iwamatsu
Yannick Gicquel
