[U-Boot] [PATCH 04/25] x86: Clean up asm-offsets
Move GD_BIST from lib/asm-offsets.c to arch/x86/lib/asm-offsets.c as it is x86 arch specific stuff. Also remove GENERATED_GD_RELOC_OFF which is not referenced anymore.
Signed-off-by: Bin Meng bmeng.cn@gmail.com --- arch/x86/cpu/start.S | 3 ++- arch/x86/lib/asm-offsets.c | 2 +- lib/asm-offsets.c | 3 --- 3 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/x86/cpu/start.S b/arch/x86/cpu/start.S index b0d0ac0..f9662fb 100644 --- a/arch/x86/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -1,5 +1,5 @@ /* - * U-boot - x86 Startup Code + * U-Boot - x86 Startup Code * * (C) Copyright 2008-2011 * Graeme Russ, graeme.russ@gmail.com @@ -17,6 +17,7 @@ #include <asm/processor.h> #include <asm/processor-flags.h> #include <generated/generic-asm-offsets.h> +#include <generated/asm-offsets.h>
.section .text .code32 diff --git a/arch/x86/lib/asm-offsets.c b/arch/x86/lib/asm-offsets.c index d65c6ab..50a488f 100644 --- a/arch/x86/lib/asm-offsets.c +++ b/arch/x86/lib/asm-offsets.c @@ -17,6 +17,6 @@
int main(void) { - DEFINE(GENERATED_GD_RELOC_OFF, offsetof(gd_t, reloc_off)); + DEFINE(GD_BIST, offsetof(gd_t, arch.bist)); return 0; } diff --git a/lib/asm-offsets.c b/lib/asm-offsets.c index 580f763..129bc3e 100644 --- a/lib/asm-offsets.c +++ b/lib/asm-offsets.c @@ -31,9 +31,6 @@ int main(void) #ifdef CONFIG_SYS_MALLOC_F_LEN DEFINE(GD_MALLOC_BASE, offsetof(struct global_data, malloc_base)); #endif -#ifdef CONFIG_X86 - DEFINE(GD_BIST, offsetof(struct global_data, arch.bist)); -#endif
#if defined(CONFIG_ARM)
Bin Meng
