[U-Boot-Users] [PATCH] ATSTK1002: Remove default ethernet addresses
Wolfgang is right: It's not a good idea to set up default initial ethernet addresses for a board, even though they belong to the local range.
This will change the failure mode from "IT manager screams at you for using duplicate ethernet addresses" to a nice error message explaining that the ethernet address hasn't been set properly.
Signed-off-by: Haavard Skinnemoen hskinnemoen@atmel.com --- include/configs/atstk1002.h | 11 +++-------- 1 files changed, 3 insertions(+), 8 deletions(-)
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 1809fc5..b33e26f 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -114,15 +114,10 @@ #define CONFIG_AUTOBOOT_STOP_STR " "
/* - * These are "locally administered ethernet addresses" generated by - * ./tools/gen_eth_addr - * - * After booting the board for the first time, new addresses should be - * generated and assigned to the environment variables "ethaddr" and - * "eth1addr". + * After booting the board for the first time, new ethernet addresses + * should be generated and assigned to the environment variables + * "ethaddr" and "eth1addr". This is normally done during production. */ -#define CONFIG_ETHADDR 6a:87:71:14:cd:cb -#define CONFIG_ETH1ADDR ca:f8:15:e6:3e:e6 #define CONFIG_OVERWRITE_ETHADDR_ONCE 1 #define CONFIG_NET_MULTI 1
Haavard Skinnemoen
