[U-Boot] [PATCH] ARM: imx: cm_fx6: Drop ad-hoc SATA binding
Drop the ad-hoc AHCI binding code, this is superseded by CONFIG_DWC_AHSATA_AHCI=y resp. drivers/ata/dwc_ahsata.c
Signed-off-by: Marek Vasut marex@denx.de Cc: Christopher Spinrath christopher.spinrath@rwth-aachen.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Igor Grinberg grinberg@compulab.co.il Cc: Nikita Kiryanov nikita@compulab.co.il Cc: Stefano Babic sbabic@denx.de --- board/compulab/cm_fx6/cm_fx6.c | 63 ---------------------------------- configs/cm_fx6_defconfig | 1 - 2 files changed, 64 deletions(-)
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index d42f57d4b7..b8f15cf3ab 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -724,66 +724,3 @@ U_BOOT_DEVICE(cm_fx6_serial) = { .name = "serial_mxc", .platdata = &cm_fx6_mxc_serial_plat, }; - -#if CONFIG_IS_ENABLED(AHCI) -static int sata_imx_probe(struct udevice *dev) -{ - int i, err; - - /* Make sure this gpio has logical 0 value */ - gpio_direction_output(CM_FX6_SATA_PWLOSS_INT, 0); - udelay(100); - cm_fx6_sata_power(1); - - for (i = 0; i < CM_FX6_SATA_INIT_RETRIES; i++) { - err = setup_sata(); - if (err) { - printf("SATA setup failed: %d\n", err); - return err; - } - - udelay(100); - - err = dwc_ahsata_probe(dev); - if (!err) - break; - - /* There is no device on the SATA port */ - if (sata_dm_port_status(0, 0) == 0) - break; - - /* There's a device, but link not established. Retry */ - device_remove(dev, DM_REMOVE_NORMAL); - } - - return 0; -} - -static int sata_imx_remove(struct udevice *dev) -{ - cm_fx6_sata_power(0); - mdelay(250); - - return 0; -} - -struct ahci_ops sata_imx_ops = { - .port_status = dwc_ahsata_port_status, - .reset = dwc_ahsata_bus_reset, - .scan = dwc_ahsata_scan, -}; - -static const struct udevice_id sata_imx_ids[] = { - { .compatible = "fsl,imx6q-ahci" }, - { } -}; - -U_BOOT_DRIVER(sata_imx) = { - .name = "dwc_ahci", - .id = UCLASS_AHCI, - .of_match = sata_imx_ids, - .ops = &sata_imx_ops, - .probe = sata_imx_probe, - .remove = sata_imx_remove, /* reset bus to stop it */ -}; -#endif /* AHCI */ diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index ce3f9de3f9..e928cbc948 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -52,7 +52,6 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-cm-fx6" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y -# CONFIG_DWC_AHSATA_AHCI is not set CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y
Hi Marek,
- int i, err;
- udelay(100);
cm_fx6_sata_power() is still defined and not used in the board, this raises at least a warning (apart of Christopher's comments).
Stefano
err = setup_sata();
if (err) {
return err;
udelay(100);
if (!err)
break;
break;
- mdelay(250);
On 6/10/19 4:24 PM, Stefano Babic wrote:
Hi Marek,
- int i, err;
- udelay(100);
AFAIR Christopher will be fixing this patch, so drop it.
Stefano Babic
