[U-Boot] "Error reading cluster"
I am using a switch (Dell S4810-ON), which comes with U-Boot preinstalled. When I tried to install a new OS for the switch, I always get the message as below:
Partition Map for MMC device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type 1 16 31280 c3096657-01 83 2 31296 125056 c3096657-02 83 3 156352 15883584 c3096657-03 83 reading switchlight-loader Error reading cluster ** Unable to read file switchlight-loader ** WARNING: adjusting available memory to 30000000 ## Booting kernel from Legacy Image at 10000000 ... Image Name: Image Type: PowerPC Linux Multi-File Image (gzip compressed) Data Size: 6784030 Bytes = 6.5 MiB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 3375086 Bytes = 3.2 MiB Image 1: 3400856 Bytes = 3.2 MiB Image 2: 8070 Bytes = 7.9 KiB Verifying Checksum ... Bad Data CRC ERROR: can't get kernel image!
Since I'm totally new with U-Boot, could anyone give me a clue about this problem?
Thank you very much!
Regards, Hai
Hai, Mr. Dinh Tuan
