[PATCH 1/1] efi_loader: correct comments for efi_status_t
EFI_STATUS is unsigned (UINTN). Hence it cannot be negative. Correct comments for 'Return:'.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_setup.c | 2 +- lib/efi_loader/efi_signature.c | 2 +- lib/efi_loader/efi_variable.c | 6 +++--- 3 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 1b648c8467..65739aca49 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -86,7 +86,7 @@ out: /** * efi_init_secure_boot - initialize secure boot state * - * Return: EFI_SUCCESS on success, status code (negative) on error + * Return: status code */ static efi_status_t efi_init_secure_boot(void) { diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 4ad818d5ee..adcb8c9cca 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -528,7 +528,7 @@ out: * pointed to by @regs. If @nocheck is false, overlapping among entries * will be checked first. * - * Return: 0 on success, status code (negative) on error + * Return: status code */ efi_status_t efi_image_region_add(struct efi_image_regions *regs, const void *start, const void *end, diff --git a/lib/efi_loader/efi_variable.c b/lib/efi_loader/efi_variable.c index b9c2e4ebf6..58f8fae358 100644 --- a/lib/efi_loader/efi_variable.c +++ b/lib/efi_loader/efi_variable.c @@ -230,7 +230,7 @@ err: * Those variables are *read-only* for users, efi_set_variable_common() * is called here. * - * Return: EFI_SUCCESS on success, status code (negative) on error + * Return: status code */ static efi_status_t efi_transfer_secure_state(enum efi_secure_mode mode) { @@ -284,7 +284,7 @@ err: /** * efi_init_secure_state - initialize secure boot state * - * Return: EFI_SUCCESS on success, status code (negative) on error + * Return: status code */ static efi_status_t efi_init_secure_state(void) { @@ -438,7 +438,7 @@ out: * attributes and signed time will also be returned in @env_attr and @time, * respectively. * - * Return: EFI_SUCCESS on success, status code (negative) on error + * Return: status code */ static efi_status_t efi_variable_authenticate(u16 *variable, const efi_guid_t *vendor, -- 2.26.2
