[U-Boot] [PATCH v3] Add support for Bluewater Systems Snapper 9260 and 9G20 modules
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20 single board computer modules. Includes NAND flash and Ethernet support.
Signed-off-by: Ryan Mallon ryan@bluewatersys.com --- Patches apply against the rework101229 branch of git://git.denx.de/u-boot-atmel.git.
Builds and runs. Tested Ethernet and NAND booting.
Changes for v3: - Replaced SZ_ macros with shifts - Remove defined values from CONFIG_ defines - Moved boards.cfg entry to correct place - Added MAINTAINERS entry
Changes for v2: - Updated for recent at91 changes - Use CONFIG_AT91FAMILY in soft_i2c driver - Fixed missing snapper9260.h config file - Add config to boards.cfg not Makefile - Removed config.mk (now in snapper9260.h)
MAINTAINERS | 5 + board/bluewater/snapper9260/Makefile | 53 ++++++++ board/bluewater/snapper9260/snapper9260.c | 169 +++++++++++++++++++++++++ boards.cfg | 2 + include/configs/snapper9260.h | 191 +++++++++++++++++++++++++++++ 5 files changed, 420 insertions(+), 0 deletions(-) create mode 100644 board/bluewater/snapper9260/Makefile create mode 100644 board/bluewater/snapper9260/snapper9260.c create mode 100644 include/configs/snapper9260.h
diff --git a/MAINTAINERS b/MAINTAINERS index a5f0493..f8c1996 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -298,6 +298,11 @@ Dan Malek dan@embeddedalley.com stxssa MPC85xx stxxtc MPC8xx
+Ryan Mallon ryan@bluewatersys.com + + snapper9260 ARM926EJS (AT91SAM9260 SoC) + snapper9g20 ARM926EJS (AT91SAM9G20 SoC) + Eran Man eran@nbase.co.il
EVB64260_750CX MPC750CX diff --git a/board/bluewater/snapper9260/Makefile b/board/bluewater/snapper9260/Makefile new file mode 100644 index 0000000..4fccdaa --- /dev/null +++ b/board/bluewater/snapper9260/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2011 Bluewater Systems +# Ryan Mallon ryan@bluewatersys.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += snapper9260.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c new file mode 100644 index 0000000..6bb2ee0 --- /dev/null +++ b/board/bluewater/snapper9260/snapper9260.c @@ -0,0 +1,169 @@ +/* + * Bluewater Systems Snapper 9260/9G20 modules + * + * (C) Copyright 2011 Bluewater Systems + * Author: Andre Renaud andre@bluewatersys.com + * Author: Ryan Mallon ryan@bluewatersys.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/at91sam9260_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <net.h> +#include <netdev.h> +#include <i2c.h> +#include <pca953x.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* IO Expander pins */ +#define IO_EXP_ETH_RESET (0 << 1) +#define IO_EXP_ETH_POWER (1 << 1) + +static void macb_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; + struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; + unsigned long erstl; + + /* Enable clock */ + writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + + /* Disable pull-ups to prevent PHY going into test mode */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA18), + &pioa->pudr); + + /* Power down ethernet */ + pca953x_set_dir(0x28, IO_EXP_ETH_POWER, PCA953X_DIR_OUT); + pca953x_set_val(0x28, IO_EXP_ETH_POWER, 1); + + /* Hold ethernet in reset */ + pca953x_set_dir(0x28, IO_EXP_ETH_RESET, PCA953X_DIR_OUT); + pca953x_set_val(0x28, IO_EXP_ETH_RESET, 0); + + /* Enable ethernet power */ + pca953x_set_val(0x28, IO_EXP_ETH_POWER, 0); + + /* Need to reset PHY -> 500ms reset */ + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) + ; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + + /* Bring the ethernet out of reset */ + pca953x_set_val(0x28, IO_EXP_ETH_RESET, 1); + + /* The phy internal reset take 21ms */ + udelay(21 * 1000); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA18), + &pioa->puer); + + at91_macb_hw_init(); +} + +static void nand_hw_init(void) +{ + struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; + struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; + unsigned long csa; + + /* Enable CS3 as NAND/SmartMedia */ + csa = readl(&matrix->ebicsa); + csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA; + writel(csa, &matrix->ebicsa); + + /* Configure SMC CS3 for NAND/SmartMedia */ + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} + +int board_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + /* Enable PIO clocks */ + writel((1 << ATMEL_ID_PIOA) | + (1 << ATMEL_ID_PIOB) | + (1 << ATMEL_ID_PIOC), &pmc->pcer); + + /* The mach-type is the same for both Snapper 9260 and 9G20 */ + gd->bd->bi_arch_number = MACH_TYPE_SNAPPER_9260; + + /* Address of boot parameters */ + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + + /* Initialise peripherals */ + at91_seriald_hw_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + nand_hw_init(); + macb_hw_init(); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x1f); +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); + return 0; +} + +void reset_phy(void) +{ +} diff --git a/boards.cfg b/boards.cfg index 9b15026..55b5f67 100644 --- a/boards.cfg +++ b/boards.cfg @@ -81,6 +81,8 @@ at91sam9g20ek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91sam9xeek_nandflash arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_NANDFLASH at91sam9xeek_dataflash_cs0 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS0 at91sam9xeek_dataflash_cs1 arm arm926ejs at91sam9260ek atmel at91 at91sam9260ek:AT91SAM9XE,SYS_USE_DATAFLASH_CS1 +snapper9260 arm arm926ejs - bluewater at91 snapper9260:AT91SAM9260 +snapper9g20 arm arm926ejs snapper9260 bluewater at91 snapper9260:AT91SAM9G20 top9000eval_xe arm arm926ejs top9000 emk at91 top9000:EVAL9000 top9000su_xe arm arm926ejs top9000 emk at91 top9000:SU9000 meesc arm arm926ejs - esd at91 diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h new file mode 100644 index 0000000..98fe293 --- /dev/null +++ b/include/configs/snapper9260.h @@ -0,0 +1,191 @@ +/* + * Bluewater Systems Snapper 9260 and 9G20 modules + * + * (C) Copyright 2011 Bluewater Systems + * Author: Andre Renaud andre@bluewatersys.com + * Author: Ryan Mallon ryan@bluewatersys.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SoC type is defined in boards.cfg */ +#include <asm/hardware.h> +#include <asm/sizes.h> + +#define CONFIG_SYS_TEXT_BASE 0x23f00000 + +/* ARM asynchronous clock */ +#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 /* External Crystal, in Hz */ +#define CONFIG_SYS_AT91_SLOW_CLOCK 32768 +#define CONFIG_SYS_HZ 1000 + +/* CPU */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_FIT + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 +#define CONFIG_SYS_SDRAM_SIZE (64 * 1024 * 1024) /* 64MB */ +#define CONFIG_SYS_INIT_SP_ADDR (ATMEL_BASE_SRAM1 + 0x1000 - \ + GENERATED_GBL_DATA_SIZE) + +/* Mem test settings */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + (1024 * 1024)) + +/* NAND Flash */ +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 +#define CONFIG_SYS_NAND_DBW_8 +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) /* AD21 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) /* AD22 */ +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 + +/* Ethernet */ +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_MULTI +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R +#define CONFIG_TFTP_PORT +#define CONFIG_TFTP_TSIZE + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_UHP_BASE +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE + +/* GPIOs and IO expander */ +#define CONFIG_AT91_LEGACY +#define CONFIG_ATMEL_LEGACY +#define CONFIG_AT91_GPIO +#define CONFIG_AT91_GPIO_PULLUP 1 +#define CONFIG_PCA953X +#define CONFIG_SYS_I2C_PCA953X_ADDR 0x28 +#define CONFIG_SYS_I2C_PCA953X_WIDTH {{0x28, 16}} + +/* UARTs/Serial console */ +#define CONFIG_ATMEL_USART +#define CONFIG_USART_BASE ATMEL_BASE_DBGU +#define CONFIG_USART_ID ATMEL_ID_SYS +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } +#define CONFIG_SYS_PROMPT "Snapper> " + +/* I2C - Bit-bashed */ +#define CONFIG_SOFT_I2C +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SOFT_I2C_READ_REPEATED_START +#define CONFIG_I2C_MULTI_BUS +#define I2C_INIT do { \ + at91_set_gpio_output(AT91_PIN_PA23, 1); \ + at91_set_gpio_output(AT91_PIN_PA24, 1); \ + at91_set_pio_multi_drive(AT91_PIO_PORTA, 23, 1); \ + at91_set_pio_multi_drive(AT91_PIO_PORTA, 24, 1); \ + } while (0) +#define I2C_SOFT_DECLARATIONS +#define I2C_ACTIVE +#define I2C_TRISTATE at91_set_gpio_input(AT91_PIN_PA23, 1); +#define I2C_READ at91_get_gpio_value(AT91_PIN_PA23); +#define I2C_SDA(bit) do { \ + if (bit) { \ + at91_set_gpio_input(AT91_PIN_PA23, 1); \ + } else { \ + at91_set_gpio_output(AT91_PIN_PA23, 1); \ + at91_set_gpio_value(AT91_PIN_PA23, bit); \ + } \ + } while (0) +#define I2C_SCL(bit) at91_set_pio_value(AT91_PIO_PORTA, 24, bit) +#define I2C_DELAY udelay(2) + +/* Boot options */ +#define CONFIG_SYS_LOAD_ADDR 0x23000000 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +/* Environment settings */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET (512 << 10) +#define CONFIG_ENV_SIZE (256 << 10) +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BOOTARGS "console=ttyS0,115200 ip=any" + +/* Console settings */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_EXTBDINFO +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* U-Boot memory settings */ +#define CONFIG_SYS_MALLOC_LEN ( 1 << 20) +#define CONFIG_STACKSIZE (256 << 10) + +/* Command line configuration */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_USB +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_PCA953X +#define CONFIG_CMD_PCA953X_INFO + +#endif /* __CONFIG_H */
Hello Reinhard,
Is this patch okay for inclusion in your tree yet?
Thanks, ~Ryan
Changes for v3:
Changes for v2:
- snapper9260 ARM926EJS (AT91SAM9260 SoC)
- snapper9g20 ARM926EJS (AT91SAM9G20 SoC)
- $(call cmd_link_o_target, $(OBJS) $(SOBJS))
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- Bluewater Systems Snapper 9260/9G20 modules
- (C) Copyright 2011 Bluewater Systems
- Author: Andre Renaud andre@bluewatersys.com
- Author: Ryan Mallon ryan@bluewatersys.com
- MA 02111-1307 USA
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
- struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC;
- unsigned long erstl;
- /* Enable clock */
- writel(1 << ATMEL_ID_EMAC0, &pmc->pcer);
- /* Disable pull-ups to prevent PHY going into test mode */
- writel(pin_to_mask(AT91_PIN_PA14) |
&pioa->pudr);
- /* Power down ethernet */
- pca953x_set_dir(0x28, IO_EXP_ETH_POWER, PCA953X_DIR_OUT);
- pca953x_set_val(0x28, IO_EXP_ETH_POWER, 1);
- /* Hold ethernet in reset */
- pca953x_set_dir(0x28, IO_EXP_ETH_RESET, PCA953X_DIR_OUT);
- pca953x_set_val(0x28, IO_EXP_ETH_RESET, 0);
- /* Enable ethernet power */
- pca953x_set_val(0x28, IO_EXP_ETH_POWER, 0);
- /* Need to reset PHY -> 500ms reset */
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK;
- writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) |
- writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr);
- /* Wait for end hardware reset */
- while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL))
- /* Restore NRST value */
- writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr);
- /* Bring the ethernet out of reset */
- pca953x_set_val(0x28, IO_EXP_ETH_RESET, 1);
- /* The phy internal reset take 21ms */
- udelay(21 * 1000);
- /* Re-enable pull-up */
&pioa->puer);
- at91_macb_hw_init();
- struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC;
- struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX;
- unsigned long csa;
- /* Enable CS3 as NAND/SmartMedia */
- csa = readl(&matrix->ebicsa);
- csa |= AT91_MATRIX_CS3A_SMC_SMARTMEDIA;
- writel(csa, &matrix->ebicsa);
- /* Configure SMC CS3 for NAND/SmartMedia */
- writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) |
&smc->cs[3].setup);
- writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) |
&smc->cs[3].pulse);
- writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7),
&smc->cs[3].cycle);
- writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE |
&smc->cs[3].mode);
- /* Configure RDY/BSY */
- at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1);
- /* Enable NandFlash */
- at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1);
- /* Enable PIO clocks */
- writel((1 << ATMEL_ID_PIOA) |
- /* The mach-type is the same for both Snapper 9260 and 9G20 */
- gd->bd->bi_arch_number = MACH_TYPE_SNAPPER_9260;
- /* Address of boot parameters */
- gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- /* Initialise peripherals */
- at91_seriald_hw_init();
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
- nand_hw_init();
- macb_hw_init();
- return macb_eth_initialize(0, (void *)ATMEL_BASE_EMAC0, 0x1f);
- gd->ram_size = get_ram_size((void *)CONFIG_SYS_SDRAM_BASE,
- Bluewater Systems Snapper 9260 and 9G20 modules
- project.
- MA 02111-1307 USA
- } while (0)
if (bit) { \
} else { \
- } while (0)
Dear Ryan Mallon,
WARNING: Use #include <linux/io.h> instead of <asm/io.h> #154: FILE: board/bluewater/snapper9260/snapper9260.c:25: +#include <asm/io.h> [ignored]
ERROR: trailing whitespace #201: FILE: board/bluewater/snapper9260/snapper9260.c:72: +^Iwritel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | $ [fixed manually]
ERROR: trailing whitespace #320: FILE: include/configs/snapper9260.h:3: + * $ [fixed manually]
WARNING: please, no space before tabs #356: FILE: include/configs/snapper9260.h:39: +#define CONFIG_SYS_HZ ^I^I^I1000$ [fixed manually]
ERROR: space required after that close brace '}' #418: FILE: include/configs/snapper9260.h:101: +#define CONFIG_SYS_I2C_PCA953X_WIDTH {{0x28, 16}} [fixed manually]
ERROR: trailing whitespace #440: FILE: include/configs/snapper9260.h:123: +#define I2C_SOFT_DECLARATIONS $ [fixed manually]
ERROR: space prohibited after that open parenthesis '(' #485: FILE: include/configs/snapper9260.h:168: +#define CONFIG_SYS_MALLOC_LEN ( 1 << 20) [fixed manually]
total: 5 errors, 2 warnings, 432 lines checked
Applied to u-boot-atmel/next after fixing style problems.
Thanks,
Reinhard
Reinhard Meyer
Ryan Mallon
