Re: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support
On Wed, Dec 8, 2021 at 8:33 PM Andre Przywara andre.przywara@arm.com wrote:
On Wed, 8 Dec 2021 19:14:22 +0330 Javad Rahimi javad321javad@gmail.com wrote:
On Wed, Dec 8, 2021 at 6:05 PM Andre Przywara andre.przywara@arm.com wrote:
On Wed, 8 Dec 2021 15:25:54 +0100 Frank Wunderlich frank-w@public-files.de wrote:
you should add maintainer email for your patch
$ scripts/get_maintainer.pl board/sunxi/board.c Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) u-boot@lists.denx.de (open list)
Thanks Frank!
Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr Von: "Javad Rahimi" javad321javad@gmail.com An: u-boot@lists.denx.de Cc: "Javad Rahimi" javad321javad@gmail.com Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support
This feature makes it possible to assign one of LED1(PH20) and LED2(PH21) to BOOT process LED. User should activates the "Enable status LED API" in "Device Drivers -> LED Support"
Please have a look at the current pinephone_defconfig, because that uses the boot LED already in a much easier fashion: https://source.denx.de/u-boot/u-boot/-/commit/0534153fd1
Cheers, Andre
Hi Andre, Thanks for your comments. I studied the pinephone_defconfig. By default, when activating the same options on Cubieboard2_defconfig it shows linker error for `__led_init` and `__led_set`. In other words, they are not defined. So, in this patch, I added the implementation for these functions for this board.
Did you add the: CONFIG_SPL_DRIVERS_MISC=y line as well? And re-ran make Cubieboard2_defconfig? Because that seemed to work for me.
Cheers, Andre
When I add CONFIG_SPL_DRIVERS_MISC=y By flashing SD card and turning on the board, It freezes in this step: ``` U-Boot SPL 2022.01-rc3-00025-gf570594bc9-dirty (Dec 08 2021 - 20:36:51 +0330) ``` ----------------------------------------- The customized defconfig file for Cubieboard: ``` CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" CONFIG_SATAPWR="PB8" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SCSI_AHCI=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y CONFIG_SUN7I_GMAC=y CONFIG_SCSI=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OHCI_HCD=y CONFIG_LED_STATUS=y CONFIG_LED_STATUS_GPIO=y CONFIG_LED_STATUS0=y CONFIG_LED_STATUS_BIT=114 CONFIG_LED_STATUS_STATE=2 ``` Best Regards, Javad
Signed-off-by: Javad Rahimi javad321javad@gmail.com
This is my first contributation in open source world. I'm sorry if I have mistakes in my commits and versioning. I do my best to learn fast.
Changes in v2:
- Missed braces added
- Unnecessary debug removed
- Some typo fixed
board/sunxi/board.c | 49 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 49 insertions(+)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 4f5747c34a..5e2f6ae902 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -1002,3 +1002,52 @@ int board_fit_config_name_match(const char *name) return ret; } #endif
+#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT) && defined(CONFIG_LED_STATUS_BOARD_SPECIFIC)
+#define CUBIE2_LED_BOOT_GPIO "PH20" +static int gpio_boot_led;
+void __led_init(led_id_t mask, int state) +{
- int ret;
- if (mask != CONFIG_LED_STATUS_BOOT)
return;
- ret = gpio_lookup_name(CUBIE2_LED_BOOT_GPIO, NULL, NULL, &gpio_boot_led);
- if (ret)
return;
- ret = gpio_request(gpio_boot_led, "boot_led");
- if (ret == -1) {
debug("[gpio_request] Error:%d\n", ret);
return;
- ret = gpio_direction_output(gpio_boot_led, 1);
- if (ret == -1) {
debug("[gpio_direction_output] Error:%d\n", ret);
return;
- __led_set(mask, state);
+void __led_set(led_id_t mask, int state) +{
return;
- gpio_set_value(gpio_boot_led, state);
+void __led_toggle(led_id_t mask) +{
return;
- gpio_set_value(gpio_boot_led, !gpio_get_value(gpio_boot_led));
2.25.1
On Wed, 8 Dec 2021 20:48:54 +0330 Javad Rahimi javad321javad@gmail.com wrote:
Thanks Frank!
Cheers, Andre
Cheers, Andre
This is the GPIO number, you need to adjust this to point to the pin your LED is connected to. PH20 would be 244, for instance: ('H' - 'A') * 32 + 20
Cheers, Andre
Best Regards, Javad > > > > > > > > > > Signed-off-by: Javad Rahimi <javad321javad@gmail.com> > > > > > --- > > > > > This is my first contributation in open source world. > > > > > I'm sorry if I have mistakes in my commits and versioning. > > > > > I do my best to learn fast. > > > > > > > > > > Changes in v2: > > > > > - Missed braces added > > > > > - Unnecessary debug removed > > > > > - Some typo fixed > > > > > > > > > > board/sunxi/board.c | 49 +++++++++++++++++++++++++++++++++++++++++++++ > > > > > 1 file changed, 49 insertions(+) > > > > > > > > > > diff --git a/board/sunxi/board.c b/board/sunxi/board.c > > > > > index 4f5747c34a..5e2f6ae902 100644 > > > > > --- a/board/sunxi/board.c > > > > > +++ b/board/sunxi/board.c > > > > > @@ -1002,3 +1002,52 @@ int board_fit_config_name_match(const char *name) > > > > > return ret; > > > > > } > > > > > #endif > > > > > + > > > > > +#if defined(CONFIG_LED_STATUS) && defined(CONFIG_LED_STATUS_BOOT) && defined(CONFIG_LED_STATUS_BOARD_SPECIFIC) > > > > > + > > > > > +#define CUBIE2_LED_BOOT_GPIO "PH20" > > > > > +static int gpio_boot_led; > > > > > + > > > > > +void __led_init(led_id_t mask, int state) > > > > > +{ > > > > > + int ret; > > > > > + > > > > > + if (mask != CONFIG_LED_STATUS_BOOT) > > > > > + return; > > > > > + > > > > > + ret = gpio_lookup_name(CUBIE2_LED_BOOT_GPIO, NULL, NULL, &gpio_boot_led); > > > > > + > > > > > + if (ret) > > > > > + return; > > > > > + > > > > > + ret = gpio_request(gpio_boot_led, "boot_led"); > > > > > + if (ret == -1) { > > > > > + debug("[gpio_request] Error:%d\n", ret); > > > > > + return; > > > > > + } > > > > > + > > > > > + ret = gpio_direction_output(gpio_boot_led, 1); > > > > > + if (ret == -1) { > > > > > + debug("[gpio_direction_output] Error:%d\n", ret); > > > > > + return; > > > > > + } > > > > > + __led_set(mask, state); > > > > > +} > > > > > + > > > > > +void __led_set(led_id_t mask, int state) > > > > > +{ > > > > > + if (mask != CONFIG_LED_STATUS_BOOT) > > > > > + return; > > > > > + > > > > > + gpio_set_value(gpio_boot_led, state); > > > > > +} > > > > > + > > > > > +void __led_toggle(led_id_t mask) > > > > > +{ > > > > > + if (mask != CONFIG_LED_STATUS_BOOT) > > > > > + return; > > > > > + > > > > > + gpio_set_value(gpio_boot_led, !gpio_get_value(gpio_boot_led)); > > > > > +} > > > > > + > > > > > +#endif > > > > > -- > > > > > 2.25.1 > > > > > > > > > > > > > >
Thanks Frank!
> Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr > Von: "Javad Rahimi" javad321javad@gmail.com > An: u-boot@lists.denx.de > Cc: "Javad Rahimi" javad321javad@gmail.com > Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support > > This feature makes it possible to assign one of > LED1(PH20) and LED2(PH21) to BOOT process LED. > User should activates the "Enable status LED API" in > "Device Drivers -> LED Support"
Cheers, Andre
Cheers, Andre
Cheers, Andre
Thanks, Now the LED is ON, but the loader still freezes in (SPL, I think) ``` U-Boot SPL 2022.01-rc3-00025-gf570594bc9-dirty (Dec 09 2021 - 06:19:40 +0330) ``` Best Regards, Javad
> you should add maintainer email for your patch > > $ scripts/get_maintainer.pl board/sunxi/board.c > Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) > Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) > u-boot@lists.denx.de (open list)
Thanks Frank!
> > Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr > > Von: "Javad Rahimi" javad321javad@gmail.com > > An: u-boot@lists.denx.de > > Cc: "Javad Rahimi" javad321javad@gmail.com > > Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support > > > > This feature makes it possible to assign one of > > LED1(PH20) and LED2(PH21) to BOOT process LED. > > User should activates the "Enable status LED API" in > > "Device Drivers -> LED Support"
Cheers, Andre
Cheers, Andre
Cheers, Andre
Best Regards, Javad
Hi Andre, The freeze problem solved when I placed `status_led_init` function after gd->ram_size = sunxi_dram_init(); When it is called before sunxi_dram_init(), the bootloader freezes.
Best Regards, Javad
On Thu, 9 Dec 2021 14:38:08 +0330 Javad Rahimi javad321javad@gmail.com wrote:
Hi Javad,
On Wed, Dec 8, 2021 at 6:05 PM Andre Przywara andre.przywara@arm.com wrote: > > On Wed, 8 Dec 2021 15:25:54 +0100 > Frank Wunderlich frank-w@public-files.de wrote: > > Hi, > > > you should add maintainer email for your patch > > > > $ scripts/get_maintainer.pl board/sunxi/board.c > > Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) > > Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) > > u-boot@lists.denx.de (open list) > > Thanks Frank! > > > > Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr > > > Von: "Javad Rahimi" javad321javad@gmail.com > > > An: u-boot@lists.denx.de > > > Cc: "Javad Rahimi" javad321javad@gmail.com > > > Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support > > > > > > This feature makes it possible to assign one of > > > LED1(PH20) and LED2(PH21) to BOOT process LED. > > > User should activates the "Enable status LED API" in > > > "Device Drivers -> LED Support" > > Please have a look at the current pinephone_defconfig, because that uses > the boot LED already in a much easier fashion: > https://source.denx.de/u-boot/u-boot/-/commit/0534153fd1 > > Cheers, > Andre > Hi Andre, Thanks for your comments. I studied the pinephone_defconfig. By default, when activating the same options on Cubieboard2_defconfig it shows linker error for `__led_init` and `__led_set`. In other words, they are not defined. So, in this patch, I added the implementation for these functions for this board.
Cheers, Andre
Cheers, Andre
Best Regards, Javad
That's probably our old friend .bss in SPL again: To save precious SRAM space, we place the BSS section in DRAM, so it's only available after the DRAM init happened. So far the code that runs before DRAM init is not using variables placed in BSS, so everything works. Possible solutions are: 1) see if we can get rid of BSS variables in the LED code (my bet is on "static int status_led_init_done = 0;" as the culprit) 2) move the LED init after the DRAM init. That's probably a bit late, though, depends a bit on what people expect from the boot LED. 3) I guess the A20 can afford BSS in SRAM, but that would not help with other (64-bit) boards. I actually wonder how it works there, though?
I'd prefer 1), but 2) is surely easier.
Cheers, Andre
Best Regards, Javad
On Thu, Dec 9, 2021 at 2:54 PM Andre Przywara andre.przywara@arm.com wrote: Hi Andre,
Hi Javad,
> On Wed, Dec 8, 2021 at 6:05 PM Andre Przywara andre.przywara@arm.com wrote: > > > > On Wed, 8 Dec 2021 15:25:54 +0100 > > Frank Wunderlich frank-w@public-files.de wrote: > > > > Hi, > > > > > you should add maintainer email for your patch > > > > > > $ scripts/get_maintainer.pl board/sunxi/board.c > > > Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) > > > Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) > > > u-boot@lists.denx.de (open list) > > > > Thanks Frank! > > > > > > Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr > > > > Von: "Javad Rahimi" javad321javad@gmail.com > > > > An: u-boot@lists.denx.de > > > > Cc: "Javad Rahimi" javad321javad@gmail.com > > > > Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support > > > > > > > > This feature makes it possible to assign one of > > > > LED1(PH20) and LED2(PH21) to BOOT process LED. > > > > User should activates the "Enable status LED API" in > > > > "Device Drivers -> LED Support" > > > > Please have a look at the current pinephone_defconfig, because that uses > > the boot LED already in a much easier fashion: > > https://source.denx.de/u-boot/u-boot/-/commit/0534153fd1 > > > > Cheers, > > Andre > > > Hi Andre, > Thanks for your comments. I studied the pinephone_defconfig. > By default, when activating the same options on Cubieboard2_defconfig > it shows linker error for `__led_init` and `__led_set`. > In other words, they are not defined. So, in this patch, I added the > implementation for these functions for this board.
Cheers, Andre
Cheers, Andre
Best Regards, Javad
- see if we can get rid of BSS variables in the LED code (my bet is on
Cheers, Andre
Your guess was true. The `status_led_init_done` was the culprit. I removed this variable and added a one-bit variable named "initialized" to the `led_dev_t ` . In this case, when `__led_init` is called, we can set it for every single LED. In this case, we can check `ld->initilized` for each led rather than blindly checking the `status_led_init_done` global variable.
Best Regards, Javad
Best Regards, Javad
On Thu, 9 Dec 2021 15:51:50 +0330 Javad Rahimi javad321javad@gmail.com wrote:
Hi Javad,
On Wed, Dec 8, 2021 at 8:33 PM Andre Przywara andre.przywara@arm.com wrote: > > On Wed, 8 Dec 2021 19:14:22 +0330 > Javad Rahimi javad321javad@gmail.com wrote: > > > On Wed, Dec 8, 2021 at 6:05 PM Andre Przywara andre.przywara@arm.com wrote: > > > > > > On Wed, 8 Dec 2021 15:25:54 +0100 > > > Frank Wunderlich frank-w@public-files.de wrote: > > > > > > Hi, > > > > > > > you should add maintainer email for your patch > > > > > > > > $ scripts/get_maintainer.pl board/sunxi/board.c > > > > Jagan Teki jagan@amarulasolutions.com (maintainer:ARM SUNXI) > > > > Andre Przywara andre.przywara@arm.com (maintainer:ARM SUNXI) > > > > u-boot@lists.denx.de (open list) > > > > > > Thanks Frank! > > > > > > > > Gesendet: Mittwoch, 08. Dezember 2021 um 15:22 Uhr > > > > > Von: "Javad Rahimi" javad321javad@gmail.com > > > > > An: u-boot@lists.denx.de > > > > > Cc: "Javad Rahimi" javad321javad@gmail.com > > > > > Betreff: [PATCH v2] Cubieboard2:SUN7I:Add LED BOOT support > > > > > > > > > > This feature makes it possible to assign one of > > > > > LED1(PH20) and LED2(PH21) to BOOT process LED. > > > > > User should activates the "Enable status LED API" in > > > > > "Device Drivers -> LED Support" > > > > > > Please have a look at the current pinephone_defconfig, because that uses > > > the boot LED already in a much easier fashion: > > > https://source.denx.de/u-boot/u-boot/-/commit/0534153fd1 > > > > > > Cheers, > > > Andre > > > > > Hi Andre, > > Thanks for your comments. I studied the pinephone_defconfig. > > By default, when activating the same options on Cubieboard2_defconfig > > it shows linker error for `__led_init` and `__led_set`. > > In other words, they are not defined. So, in this patch, I added the > > implementation for these functions for this board. > > Did you add the: > CONFIG_SPL_DRIVERS_MISC=y > line as well? And re-ran make Cubieboard2_defconfig? > Because that seemed to work for me. > > Cheers, > Andre > > When I add CONFIG_SPL_DRIVERS_MISC=y By flashing SD card and turning on the board, It freezes in this step:
Cheers, Andre
Best Regards, Javad
Cheers, Andre
Interesting idea, though I don't know too much about this code, and why we had the global variable in the first place. Can you prepare a patch and send it to the mailing list, so that people can have a look and discuss this?
Cheers, Andre
Best Regards, Javad
Best Regards, Javad
Andre Przywara
Javad Rahimi
