[U-Boot] [PATCH] S3C6400/SMDK6400: fix stack_setup in start.S
stack_setup is modified to initialize the stack on the correct address in DRAM accroding to the typical memory configuration described in README and the related CONFIG_* macro definitions. This makes macro CONFIG_MEMORY_UPPER_CODE no longer necessry. This was introduced and used only by this board for some unclear reason. The definition of this macro is removed because it's not referenced elsewhere.
Signed-off-by: Seunghyeon Rhee seunghyeon@lpmtec.com --- cpu/arm1176/start.S | 7 +------ include/configs/smdk6400.h | 2 -- 2 files changed, 1 insertions(+), 8 deletions(-)
diff --git a/cpu/arm1176/start.S b/cpu/arm1176/start.S index cb891df..1ecb3b9 100644 --- a/cpu/arm1176/start.S +++ b/cpu/arm1176/start.S @@ -241,16 +241,11 @@ mmu_enable: skip_hw_init: /* Set up the stack */ stack_setup: -#ifdef CONFIG_MEMORY_UPPER_CODE - ldr sp, =(CONFIG_SYS_UBOOT_BASE + CONFIG_SYS_UBOOT_SIZE - 0xc) -#else - ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot */ + ldr r0, =CONFIG_SYS_UBOOT_BASE /* base of copy in DRAM */ sub r0, r0, #CONFIG_SYS_MALLOC_LEN /* malloc area */ sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE /* bdinfo */ sub sp, r0, #12 /* leave 3 words for abort-stack */
-#endif - clear_bss: ldr r0, _bss_start /* find start of bss segment */ ldr r1, _bss_end /* stop here */ diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index f6e1221..f644cd2 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -49,8 +49,6 @@ #define CONFIG_ENABLE_MMU #endif
-#define CONFIG_MEMORY_UPPER_CODE - #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG
Dear Seunghyeon Rhee
2009/10/31 "Seunghyeon Rhee (이승현)" seunghyeon@lpmtec.com:
-#else
- ldr r0, =CONFIG_SYS_UBOOT_BASE /* base of copy in DRAM */
this change is unnecessary, TEXT_BASE and CONFIG_SYS_UBOOT_BASE must be same. btw, is there need CONFIG_SYS_UBOOT_BASE define?
-#endif
#define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG -- 1.6.2.5
-- Seunghyeon Rhee, Ph.D. / Director LPM Technology Inc. T +82-70-8255-6007 F +82-2-6442-6462 M +82-10-2790-0657 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Thanks for patch :) Minkyu Kang
Minkyu Kang
