[PATCH v3 01/10] ARM: meson: Sync Amlogic DT from Linux 5.14
Import Amlogic DT changes from Linux commit 7d2a07b76933 ("Linux 5.14"), dt-bindings clock changes and new meson-g12b-gsking-x.dts, meson-sm1-bananapi-m5 & odroid-hc4 boards.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/Makefile | 3 + arch/arm/dts/meson-axg-s400.dts | 16 + arch/arm/dts/meson-axg.dtsi | 181 +++++ arch/arm/dts/meson-g12-common.dtsi | 31 +- arch/arm/dts/meson-g12a-sei510.dts | 2 +- arch/arm/dts/meson-g12b-gsking-x.dts | 133 ++++ arch/arm/dts/meson-g12b-gtking-pro.dts | 23 +- arch/arm/dts/meson-g12b-gtking.dts | 22 +- arch/arm/dts/meson-g12b-odroid-n2-plus.dts | 2 +- arch/arm/dts/meson-g12b-odroid-n2.dtsi | 74 +- arch/arm/dts/meson-g12b-w400.dtsi | 2 +- arch/arm/dts/meson-g12b.dtsi | 4 + arch/arm/dts/meson-gx-libretech-pc.dtsi | 2 +- arch/arm/dts/meson-gx-p23x-q20x.dtsi | 2 +- arch/arm/dts/meson-gx.dtsi | 7 + arch/arm/dts/meson-gxbb-nanopi-k2.dts | 42 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 44 +- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 50 +- .../dts/meson-gxl-s905x-libretech-cc-v2.dts | 6 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 2 +- arch/arm/dts/meson-gxm-khadas-vim2.dts | 55 +- arch/arm/dts/meson-gxm-wetek-core2.dts | 2 +- arch/arm/dts/meson-gxm.dtsi | 20 + arch/arm/dts/meson-khadas-vim3.dtsi | 73 +- arch/arm/dts/meson-sm1-bananapi-m5.dts | 646 ++++++++++++++++++ arch/arm/dts/meson-sm1-khadas-vim3l.dts | 20 +- arch/arm/dts/meson-sm1-odroid-c4.dts | 448 +----------- arch/arm/dts/meson-sm1-odroid-hc4.dts | 140 ++++ arch/arm/dts/meson-sm1-odroid.dtsi | 449 ++++++++++++ arch/arm/dts/meson-sm1-sei610.dts | 10 +- arch/arm/dts/meson-sm1.dtsi | 12 +- include/dt-bindings/clock/axg-clkc.h | 26 +- include/dt-bindings/clock/g12a-clkc.h | 2 + 34 files changed, 2030 insertions(+), 523 deletions(-) create mode 100644 arch/arm/dts/meson-g12b-gsking-x.dts create mode 100644 arch/arm/dts/meson-sm1-bananapi-m5.dts create mode 100644 arch/arm/dts/meson-sm1-odroid-hc4.dts create mode 100644 arch/arm/dts/meson-sm1-odroid.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fc16a57e60..f0160d2dc0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -177,11 +177,14 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-g12a-sei510.dtb \ meson-g12b-gtking.dtb \ meson-g12b-gtking-pro.dtb \ + meson-g12b-gsking-x.dtb \ meson-g12b-odroid-n2.dtb \ meson-g12b-odroid-n2-plus.dtb \ meson-g12b-a311d-khadas-vim3.dtb \ + meson-sm1-bananapi-m5.dtb \ meson-sm1-khadas-vim3l.dtb \ meson-sm1-odroid-c4.dtb \ + meson-sm1-odroid-hc4.dtb \ meson-sm1-sei610.dtb dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ diff --git a/arch/arm/dts/meson-axg-s400.dts b/arch/arm/dts/meson-axg-s400.dts index cb1360ae12..359589d1df 100644 --- a/arch/arm/dts/meson-axg-s400.dts +++ b/arch/arm/dts/meson-axg-s400.dts @@ -441,6 +441,16 @@ status = "okay"; };
+&pcieA { + reset-gpios = <&gpio GPIOX_19 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&pcieB { + reset-gpios = <&gpio GPIOZ_10 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; + status = "okay"; +}; + &pwm_ab { status = "okay"; pinctrl-0 = <&pwm_a_x20_pins>; @@ -584,3 +594,9 @@ pinctrl-0 = <&uart_ao_a_pins>; pinctrl-names = "default"; }; + +&usb { + status = "okay"; + dr_mode = "otg"; + vbus-supply = <&usb_pwr>; +}; diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index b9efc84692..3f5254eeb4 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -12,6 +12,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> #include <dt-bindings/reset/amlogic,meson-axg-reset.h> +#include <dt-bindings/power/meson-axg-power.h>
/ { compatible = "amlogic,meson-axg"; @@ -171,6 +172,98 @@ #size-cells = <2>; ranges;
+ pcieA: pcie@f9800000 { + compatible = "amlogic,axg-pcie", "snps,dw-pcie"; + reg = <0x0 0xf9800000 0x0 0x400000>, + <0x0 0xff646000 0x0 0x2000>, + <0x0 0xf9f00000 0x0 0x100000>; + reg-names = "elbi", "cfg", "config"; + interrupts = <GIC_SPI 177 IRQ_TYPE_EDGE_RISING>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 179 IRQ_TYPE_EDGE_RISING>; + bus-range = <0x0 0xff>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x82000000 0 0xf9c00000 0x0 0xf9c00000 0 0x00300000>; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_A>, <&clkc CLKID_PCIE_CML_EN0>; + clock-names = "general", "pclk", "port"; + resets = <&reset RESET_PCIE_A>, <&reset RESET_PCIE_APB>; + reset-names = "port", "apb"; + num-lanes = <1>; + phys = <&pcie_phy>; + phy-names = "pcie"; + status = "disabled"; + }; + + pcieB: pcie@fa000000 { + compatible = "amlogic,axg-pcie", "snps,dw-pcie"; + reg = <0x0 0xfa000000 0x0 0x400000>, + <0x0 0xff648000 0x0 0x2000>, + <0x0 0xfa400000 0x0 0x100000>; + reg-names = "elbi", "cfg", "config"; + interrupts = <GIC_SPI 167 IRQ_TYPE_EDGE_RISING>; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &gic GIC_SPI 169 IRQ_TYPE_EDGE_RISING>; + bus-range = <0x0 0xff>; + #address-cells = <3>; + #size-cells = <2>; + device_type = "pci"; + ranges = <0x82000000 0 0xfa500000 0x0 0xfa500000 0 0x00300000>; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_B>, <&clkc CLKID_PCIE_CML_EN1>; + clock-names = "general", "pclk", "port"; + resets = <&reset RESET_PCIE_B>, <&reset RESET_PCIE_APB>; + reset-names = "port", "apb"; + num-lanes = <1>; + phys = <&pcie_phy>; + phy-names = "pcie"; + status = "disabled"; + }; + + usb: usb@ffe09080 { + compatible = "amlogic,meson-axg-usb-ctrl"; + reg = <0x0 0xffe09080 0x0 0x20>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "usb_ctrl", "ddr"; + resets = <&reset RESET_USB_OTG>; + + dr_mode = "otg"; + + phys = <&usb2_phy1>; + phy-names = "usb2-phy1"; + + dwc2: usb@ff400000 { + compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; + reg = <0x0 0xff400000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1>; + clock-names = "otg"; + phys = <&usb2_phy1>; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + }; + + dwc3: usb@ff500000 { + compatible = "snps,dwc3"; + reg = <0x0 0xff500000 0x0 0x100000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + maximum-speed = "high-speed"; + snps,dis_u2_susphy_quirk; + }; + }; + ethmac: ethernet@ff3f0000 { compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.70a", @@ -187,9 +280,19 @@ "timing-adjustment"; rx-fifo-depth = <4096>; tx-fifo-depth = <2048>; + power-domains = <&pwrc PWRC_AXG_ETHERNET_MEM_ID>; status = "disabled"; };
+ pcie_phy: phy@ff644000 { + compatible = "amlogic,axg-pcie-phy"; + reg = <0x0 0xff644000 0x0 0x1c>; + resets = <&reset RESET_PCIE_PHY>; + phys = <&mipi_pcie_analog_dphy>; + phy-names = "analog"; + #phy-cells = <0>; + }; + pdm: audio-controller@ff632000 { compatible = "amlogic,axg-pdm"; reg = <0x0 0xff632000 0x0 0x34>; @@ -1117,6 +1220,52 @@ clocks = <&xtal>; clock-names = "xtal"; }; + + pwrc: power-controller { + compatible = "amlogic,meson-axg-pwrc"; + #power-domain-cells = <1>; + amlogic,ao-sysctrl = <&sysctrl_AO>; + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + reset-names = "viu", "venc", "vcbus", + "vencl", "vid_lock"; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <250000000>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ + }; + + mipi_pcie_analog_dphy: phy { + compatible = "amlogic,axg-mipi-pcie-analog-phy"; + #phy-cells = <0>; + status = "disabled"; + }; }; };
@@ -1129,6 +1278,19 @@ #mbox-cells = <1>; };
+ mipi_dphy: phy@ff640000 { + compatible = "amlogic,axg-mipi-dphy"; + reg = <0x0 0xff640000 0x0 0x100>; + clocks = <&clkc CLKID_MIPI_DSI_PHY>; + clock-names = "pclk"; + resets = <&reset RESET_MIPI_PHY>; + reset-names = "phy"; + phys = <&mipi_pcie_analog_dphy>; + phy-names = "analog"; + #phy-cells = <0>; + status = "disabled"; + }; + audio: bus@ff642000 { compatible = "simple-bus"; reg = <0x0 0xff642000 0x0 0x2000>; @@ -1563,6 +1725,14 @@ }; };
+ ge2d: ge2d@ff940000 { + compatible = "amlogic,axg-ge2d"; + reg = <0x0 0xff940000 0x0 0x10000>; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc CLKID_VAPB>; + resets = <&reset RESET_GE2D>; + }; + gic: interrupt-controller@ffc01000 { compatible = "arm,gic-400"; reg = <0x0 0xffc01000 0 0x1000>, @@ -1701,6 +1871,7 @@ status = "disabled"; clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; clock-names = "xtal", "pclk", "baud"; + fifo-size = <128>; }; };
@@ -1734,6 +1905,16 @@ clock-names = "core", "clkin0", "clkin1"; resets = <&reset RESET_SD_EMMC_C>; }; + + usb2_phy1: phy@9020 { + compatible = "amlogic,meson-gxl-usb2-phy"; + #phy-cells = <0>; + reg = <0x0 0x9020 0x0 0x20>; + clocks = <&clkc CLKID_USB>; + clock-names = "phy"; + resets = <&reset RESET_USB_OTG>; + reset-names = "phy"; + }; };
sram: sram@fffc0000 { diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi index 1e83ec5b8c..00c6f53290 100644 --- a/arch/arm/dts/meson-g12-common.dtsi +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -17,6 +17,12 @@ #address-cells = <2>; #size-cells = <2>;
+ aliases { + mmc0 = &sd_emmc_b; /* SD card */ + mmc1 = &sd_emmc_c; /* eMMC */ + mmc2 = &sd_emmc_a; /* SDIO */ + }; + chosen { #address-cells = <2>; #size-cells = <2>; @@ -122,9 +128,9 @@
pcie: pcie@fc000000 { compatible = "amlogic,g12a-pcie", "snps,dw-pcie"; - reg = <0x0 0xfc000000 0x0 0x400000 - 0x0 0xff648000 0x0 0x2000 - 0x0 0xfc400000 0x0 0x200000>; + reg = <0x0 0xfc000000 0x0 0x400000>, + <0x0 0xff648000 0x0 0x2000>, + <0x0 0xfc400000 0x0 0x200000>; reg-names = "elbi", "cfg", "config"; interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>; @@ -134,8 +140,8 @@ #address-cells = <3>; #size-cells = <2>; device_type = "pci"; - ranges = <0x81000000 0 0 0x0 0xfc600000 0 0x00100000 - 0x82000000 0 0xfc700000 0x0 0xfc700000 0 0x1900000>; + ranges = <0x81000000 0 0 0x0 0xfc600000 0 0x00100000>, + <0x82000000 0 0xfc700000 0x0 0xfc700000 0 0x1900000>;
clocks = <&clkc CLKID_PCIE_PHY &clkc CLKID_PCIE_COMB @@ -209,7 +215,7 @@ };
ethmac: ethernet@ff3f0000 { - compatible = "amlogic,meson-axg-dwmac", + compatible = "amlogic,meson-g12a-dwmac", "snps,dwmac-3.70a", "snps,dwmac"; reg = <0x0 0xff3f0000 0x0 0x10000>, @@ -282,6 +288,8 @@ hwrng: rng@218 { compatible = "amlogic,meson-rng"; reg = <0x0 0x218 0x0 0x4>; + clocks = <&clkc CLKID_RNG0>; + clock-names = "core"; }; };
@@ -2001,7 +2009,7 @@ }; };
- vrtc: rtc@0a8 { + vrtc: rtc@a8 { compatible = "amlogic,meson-vrtc"; reg = <0x0 0x000a8 0x0 0x4>; }; @@ -2179,6 +2187,12 @@ amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; };
+ watchdog: watchdog@f0d0 { + compatible = "amlogic,meson-gxbb-wdt"; + reg = <0x0 0xf0d0 0x0 0x10>; + clocks = <&xtal>; + }; + spicc0: spi@13000 { compatible = "amlogic,meson-g12a-spicc"; reg = <0x0 0x13000 0x0 0x44>; @@ -2303,6 +2317,7 @@ clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; clock-names = "xtal", "pclk", "baud"; status = "disabled"; + fifo-size = <128>; }; };
@@ -2380,7 +2395,7 @@ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; dr_mode = "host"; snps,dis_u2_susphy_quirk; - snps,quirk-frame-length-adjustment; + snps,quirk-frame-length-adjustment = <0x20>; snps,parkmode-disable-ss-quirk; }; }; diff --git a/arch/arm/dts/meson-g12a-sei510.dts b/arch/arm/dts/meson-g12a-sei510.dts index b00d0468c7..81269ccc24 100644 --- a/arch/arm/dts/meson-g12a-sei510.dts +++ b/arch/arm/dts/meson-g12a-sei510.dts @@ -181,7 +181,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12A-SEI510"; + model = "SEI510"; audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", diff --git a/arch/arm/dts/meson-g12b-gsking-x.dts b/arch/arm/dts/meson-g12b-gsking-x.dts new file mode 100644 index 0000000000..6c7bfacbad --- /dev/null +++ b/arch/arm/dts/meson-g12b-gsking-x.dts @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +/dts-v1/; + +#include "meson-g12b-w400.dtsi" +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + compatible = "azw,gsking-x", "amlogic,s922x", "amlogic,g12b"; + model = "Beelink GS-King X"; + + aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + #address-cells = <1>; + #size-cells = <0>; + poll-interval = <100>; + + power-button { + label = "power"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; + }; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "GSKING-X"; + audio-aux-devs = <&tdmout_a>; + audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 1", + "TDMOUT_A IN 1", "FRDDR_B OUT 1", + "TDMOUT_A IN 2", "FRDDR_C OUT 1", + "TDM_A Playback", "TDMOUT_A OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_a>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_A>; + }; + }; + + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + +&tdmif_a { + status = "okay"; +}; + +&tdmout_a { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; diff --git a/arch/arm/dts/meson-g12b-gtking-pro.dts b/arch/arm/dts/meson-g12b-gtking-pro.dts index f0c56a16af..707daf9278 100644 --- a/arch/arm/dts/meson-g12b-gtking-pro.dts +++ b/arch/arm/dts/meson-g12b-gtking-pro.dts @@ -11,9 +11,14 @@ #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
/ { - compatible = "azw,gtking", "amlogic,g12b"; + compatible = "azw,gtking", "amlogic,s922x", "amlogic,g12b"; model = "Beelink GT-King Pro";
+ aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + gpio-keys-polled { compatible = "gpio-keys-polled"; #address-cells = <1>; @@ -30,7 +35,7 @@ leds { compatible = "gpio-leds";
- white { + led-white { label = "power:white"; gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; default-state = "on"; @@ -39,7 +44,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-GTKING-PRO"; + model = "GTKING-PRO"; audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1", @@ -112,6 +117,18 @@ status = "okay"; };
+&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &tdmif_b { status = "okay"; }; diff --git a/arch/arm/dts/meson-g12b-gtking.dts b/arch/arm/dts/meson-g12b-gtking.dts index eeb7bc5539..5d96c14490 100644 --- a/arch/arm/dts/meson-g12b-gtking.dts +++ b/arch/arm/dts/meson-g12b-gtking.dts @@ -11,9 +11,14 @@ #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
/ { - compatible = "azw,gtking", "amlogic,g12b"; + compatible = "azw,gtking", "amlogic,s922x", "amlogic,g12b"; model = "Beelink GT-King";
+ aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + spdif_dit: audio-codec-1 { #sound-dai-cells = <0>; compatible = "linux,spdif-dit"; @@ -23,7 +28,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-GTKING"; + model = "GTKING"; audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1", @@ -122,6 +127,19 @@ status = "okay"; };
+ +&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &spdifout { pinctrl-0 = <&spdif_out_h_pins>; pinctrl-names = "default"; diff --git a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts index 5de2815ba9..ce1198ad34 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts +++ b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts @@ -19,7 +19,7 @@ regulator-min-microvolt = <680000>; regulator-max-microvolt = <1040000>;
- pwms = <&pwm_AO_cd 1 1500 0>; + pwms = <&pwm_ab 0 1500 0>; };
&vddcpu_b { diff --git a/arch/arm/dts/meson-g12b-odroid-n2.dtsi b/arch/arm/dts/meson-g12b-odroid-n2.dtsi index 6982632ae6..344573e157 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2.dtsi +++ b/arch/arm/dts/meson-g12b-odroid-n2.dtsi @@ -13,6 +13,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac; + rtc0 = &rtc; + rtc1 = &vrtc; };
dioo2133: audio-amplifier-0 { @@ -40,7 +42,7 @@ leds { compatible = "gpio-leds";
- blue { + led-blue { label = "n2:blue"; gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; @@ -211,7 +213,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-ODROID-N2"; + model = "ODROID-N2"; audio-widgets = "Line", "Lineout"; audio-aux-devs = <&tdmout_b>, <&tdmout_c>, <&tdmin_a>, <&tdmin_b>, <&tdmin_c>, <&tdmin_lb>, @@ -408,12 +410,12 @@
&ext_mdio { external_phy: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ + /* Realtek RTL8211F (0x001cc916) */ reg = <0>; max-speed = <1000>;
reset-assert-us = <10000>; - reset-deassert-us = <30000>; + reset-deassert-us = <80000>; reset-gpios = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>;
interrupt-parent = <&gpio_intc>; @@ -444,13 +446,58 @@ };
&gpio { + gpio-line-names = + /* GPIOZ */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOH */ + "", "", "", "", "", "", "", "", + "", + /* BOOT */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOC */ + "", "", "", "", "", "", "", "", + /* GPIOA */ + "PIN_44", /* GPIOA_0 */ + "PIN_46", /* GPIOA_1 */ + "PIN_45", /* GPIOA_2 */ + "PIN_47", /* GPIOA_3 */ + "PIN_26", /* GPIOA_4 */ + "", "", "", "", "", "", + "PIN_42", /* GPIOA_11 */ + "PIN_32", /* GPIOA_12 */ + "PIN_7", /* GPIOA_13 */ + "PIN_27", /* GPIOA_14 */ + "PIN_28", /* GPIOA_15 */ + /* GPIOX */ + "PIN_16", /* GPIOX_0 */ + "PIN_18", /* GPIOX_1 */ + "PIN_22", /* GPIOX_2 */ + "PIN_11", /* GPIOX_3 */ + "PIN_13", /* GPIOX_4 */ + "PIN_33", /* GPIOX_5 */ + "PIN_35", /* GPIOX_6 */ + "PIN_15", /* GPIOX_7 */ + "PIN_19", /* GPIOX_8 */ + "PIN_21", /* GPIOX_9 */ + "PIN_24", /* GPIOX_10 */ + "PIN_23", /* GPIOX_11 */ + "PIN_8", /* GPIOX_12 */ + "PIN_10", /* GPIOX_13 */ + "PIN_29", /* GPIOX_14 */ + "PIN_31", /* GPIOX_15 */ + "PIN_12", /* GPIOX_16 */ + "PIN_3", /* GPIOX_17 */ + "PIN_5", /* GPIOX_18 */ + "PIN_36"; /* GPIOX_19 */ /* * WARNING: The USB Hub on the Odroid-N2 needs a reset signal * to be turned high in order to be detected by the USB Controller * This signal should be handled by a USB specific power sequence * in order to reset the Hub when USB bus is powered down. */ - usb-hub { + hog-0 { gpio-hog; gpios = <GPIOH_4 GPIO_ACTIVE_HIGH>; output-high; @@ -478,6 +525,18 @@ linux,rc-map-name = "rc-odroid"; };
+&i2c3 { + status = "okay"; + pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + &pwm_ab { pinctrl-0 = <&pwm_a_e_pins>; pinctrl-names = "default"; @@ -494,6 +553,11 @@ status = "okay"; };
+&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + /* SD card */ &sd_emmc_b { status = "okay"; diff --git a/arch/arm/dts/meson-g12b-w400.dtsi b/arch/arm/dts/meson-g12b-w400.dtsi index 2802ddbb83..feb0885047 100644 --- a/arch/arm/dts/meson-g12b-w400.dtsi +++ b/arch/arm/dts/meson-g12b-w400.dtsi @@ -264,7 +264,7 @@ max-speed = <1000>;
interrupt-parent = <&gpio_intc>; diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 9b8548e5f6..ee8fcae9f9 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -135,3 +135,7 @@ }; }; }; + +&mali { + dma-coherent; +}; diff --git a/arch/arm/dts/meson-gx-libretech-pc.dtsi b/arch/arm/dts/meson-gx-libretech-pc.dtsi index c2480bab8d..2d7032f41e 100644 --- a/arch/arm/dts/meson-gx-libretech-pc.dtsi +++ b/arch/arm/dts/meson-gx-libretech-pc.dtsi @@ -186,7 +186,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S9XX-PC"; + model = "LIBRETECH-PC"; audio-aux-devs = <&dio2133>; audio-widgets = "Speaker", "7J4-14 LEFT", "Speaker", "7J4-11 RIGHT"; diff --git a/arch/arm/dts/meson-gx-p23x-q20x.dtsi b/arch/arm/dts/meson-gx-p23x-q20x.dtsi index 6b57e15aad..dafc841f7c 100644 --- a/arch/arm/dts/meson-gx-p23x-q20x.dtsi +++ b/arch/arm/dts/meson-gx-p23x-q20x.dtsi @@ -121,7 +121,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GX-P230-Q200"; + model = "P230-Q200"; audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLP", diff --git a/arch/arm/dts/meson-gx.dtsi b/arch/arm/dts/meson-gx.dtsi index 0edd137151..6b457b2c30 100644 --- a/arch/arm/dts/meson-gx.dtsi +++ b/arch/arm/dts/meson-gx.dtsi @@ -20,6 +20,12 @@ #address-cells = <2>; #size-cells = <2>;
+ aliases { + mmc0 = &sd_emmc_b; /* SD card */ + mmc1 = &sd_emmc_c; /* eMMC */ + mmc2 = &sd_emmc_a; /* SDIO */ + }; + reserved-memory { #address-cells = <2>; #size-cells = <2>; @@ -295,6 +301,7 @@ reg = <0x0 0x84c0 0x0 0x18>; interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; status = "disabled"; + fifo-size = <128>; };
uart_B: serial@84dc { diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts index 7be3e35409..7273eed529 100644 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ b/arch/arm/dts/meson-gxbb-nanopi-k2.dts @@ -7,6 +7,7 @@
#include "meson-gxbb.dtsi" #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; @@ -130,6 +131,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "NANOPI-K2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -165,7 +205,7 @@ reg = <0>;
reset-assert-us = <10000>; - reset-deassert-us = <30000>; + reset-deassert-us = <80000>; reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>;
interrupt-parent = <&gpio_intc>; diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index 70fcfb7b06..201596247f 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -9,6 +9,7 @@
/ { compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; @@ -172,6 +173,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "ODROID-C2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -200,7 +240,7 @@ reg = <0>;
interrupt-parent = <&gpio_intc>; @@ -217,7 +257,7 @@ * This signal should be handled by a USB specific power sequence * in order to reset the Hub when USB bus is powered down. */ - usb-hub { + hog-0 { gpio-hog; gpios = <GPIOAO_4 GPIO_ACTIVE_HIGH>; output-high; diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts index 9e43f4dca9..2d769203f6 100644 --- a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts +++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts @@ -118,7 +118,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S805X-AC"; + model = "LIBRETECH-AC"; audio-widgets = "Speaker", "9J5-3 LEFT", "Speaker", "9J5-2 RIGHT"; audio-routing = "9J5-3 LEFT", "ACODEC LOLN", diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts index 8bcdffdf55..60feac0179 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts @@ -5,9 +5,9 @@
/dts-v1/;
-#include <dt-bindings/input/input.h> - #include "meson-gxl-s905x-p212.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim", "amlogic,s905x", "amlogic,meson-gxl"; @@ -42,10 +42,10 @@ }; };
- pwmleds { + led-controller { compatible = "pwm-leds";
- power { + led-1 { label = "vim:red:power"; pwms = <&pwm_AO_ab 1 7812500 0>; max-brightness = <255>; @@ -63,6 +63,45 @@ }; }; }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "KHADAS-VIM"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -97,8 +136,7 @@ pinctrl-names = "default";
rtc: rtc@51 { - /* has to be enabled manually when a battery is connected: */ - status = "disabled"; + status = "okay"; compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts index 675eaa8796..93d8f8aff7 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts @@ -84,7 +84,6 @@ regulator-always-on; };
- vcck: regulator-vcck { compatible = "regulator-fixed"; regulator-name = "VCCK"; @@ -124,7 +123,6 @@ regulator-always-on; };
- vddio_card: regulator-vddio-card { compatible = "regulator-gpio"; regulator-name = "VDDIO_CARD"; @@ -161,7 +159,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S905X-CC-V2"; + model = "LIBRETECH-CC-V2"; assigned-clocks = <&clkc CLKID_MPLL0>, <&clkc CLKID_MPLL1>, <&clkc CLKID_MPLL2>; @@ -195,7 +193,6 @@ }; };
- &aiu { status = "okay"; }; @@ -207,7 +204,6 @@ hdmi-phandle = <&hdmi_tx>; };
- ðmac { status = "okay"; }; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts index 5ae7bb6209..82bfabfbd3 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts @@ -135,7 +135,7 @@
sound { compatible = "amlogic,gx-sound-card"; - model = "GXL-LIBRETECH-S905X-CC"; + model = "LIBRETECH-CC"; audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLN", diff --git a/arch/arm/dts/meson-gxm-khadas-vim2.dts b/arch/arm/dts/meson-gxm-khadas-vim2.dts index bff8ec2c1c..18a4b7a6c5 100644 --- a/arch/arm/dts/meson-gxm-khadas-vim2.dts +++ b/arch/arm/dts/meson-gxm-khadas-vim2.dts @@ -7,9 +7,9 @@
/dts-v1/;
-#include <dt-bindings/input/input.h> - #include "meson-gxm.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim2", "amlogic,s912", "amlogic,meson-gxm"; @@ -81,10 +81,10 @@ }; };
- power { + led-1 { label = "vim:red:power"; pwms = <&pwm_AO_ab 1 7812500 0>; max-brightness = <255>; @@ -145,6 +145,45 @@ clock-frequency = <32768>; pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ }; + + sound { + compatible = "amlogic,gx-sound-card"; + model = "KHADAS-VIM2"; + assigned-clocks = <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>; + }; + + dai-link-1 { + sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>; + dai-format = "i2s"; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&aiu AIU_HDMI CTRL_I2S>; + }; + }; + + dai-link-2 { + sound-dai = <&aiu AIU_HDMI CTRL_OUT>; + + codec-0 { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&aiu { + status = "okay"; };
&cec_AO { @@ -154,7 +193,6 @@ hdmi-phandle = <&hdmi_tx>; };
- &cpu_cooling_maps { map0 { cooling-device = <&gpio_fan THERMAL_NO_LIMIT 1>; @@ -194,7 +232,7 @@ reg = <0>;
interrupt-parent = <&gpio_intc>; @@ -228,8 +266,7 @@ pinctrl-names = "default";
rtc: rtc@51 { - /* has to be enabled manually when a battery is connected: */ - status = "disabled"; + status = "okay"; compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; @@ -341,7 +378,7 @@ #size-cells = <1>; compatible = "winbond,w25q16", "jedec,spi-nor"; reg = <0>; - spi-max-frequency = <3000000>; + spi-max-frequency = <104000000>; }; };
diff --git a/arch/arm/dts/meson-gxm-wetek-core2.dts b/arch/arm/dts/meson-gxm-wetek-core2.dts index ec794c134c..1e7f77f9b5 100644 --- a/arch/arm/dts/meson-gxm-wetek-core2.dts +++ b/arch/arm/dts/meson-gxm-wetek-core2.dts @@ -22,7 +22,7 @@ leds { compatible = "gpio-leds";
- blue { + led-blue { color = <LED_COLOR_ID_BLUE>; function = LED_FUNCTION_STATUS; gpios = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>; diff --git a/arch/arm/dts/meson-gxm.dtsi b/arch/arm/dts/meson-gxm.dtsi index fe41451122..411cc312fc 100644 --- a/arch/arm/dts/meson-gxm.dtsi +++ b/arch/arm/dts/meson-gxm.dtsi @@ -42,11 +42,28 @@ }; };
+ cpu0: cpu@0 { + capacity-dmips-mhz = <1024>; + }; + + cpu1: cpu@1 { + capacity-dmips-mhz = <1024>; + }; + + cpu2: cpu@2 { + capacity-dmips-mhz = <1024>; + }; + + cpu3: cpu@3 { + capacity-dmips-mhz = <1024>; + }; + cpu4: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a53"; reg = <0x0 0x100>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -57,6 +74,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x101>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -67,6 +85,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x102>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; @@ -77,6 +96,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x103>; enable-method = "psci"; + capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>; diff --git a/arch/arm/dts/meson-khadas-vim3.dtsi b/arch/arm/dts/meson-khadas-vim3.dtsi index 7b46555ac5..3cf4ecb6d5 100644 --- a/arch/arm/dts/meson-khadas-vim3.dtsi +++ b/arch/arm/dts/meson-khadas-vim3.dtsi @@ -6,6 +6,7 @@ */
#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/meson-g12a-gpio.h> #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
@@ -13,6 +14,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac; + rtc0 = &rtc; + rtc1 = &vrtc; };
chosen { @@ -41,13 +44,15 @@ compatible = "gpio-leds";
led-white { - label = "vim3:white:sys"; + color = <LED_COLOR_ID_WHITE>; + function = LED_FUNCTION_STATUS; gpios = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; };
led-red { - label = "vim3:red"; + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_STATUS; gpios = <&gpio_expander 5 GPIO_ACTIVE_HIGH>; }; }; @@ -165,12 +170,17 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "G12B-KHADAS-VIM3"; - audio-aux-devs = <&tdmout_a>; + model = "KHADAS-VIM3"; + audio-aux-devs = <&tdmin_a>, <&tdmout_a>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", "TDMOUT_A IN 1", "FRDDR_B OUT 0", "TDMOUT_A IN 2", "FRDDR_C OUT 0", - "TDM_A Playback", "TDMOUT_A OUT"; + "TDM_A Playback", "TDMOUT_A OUT", + "TDMIN_A IN 0", "TDM_A Capture", + "TDMIN_A IN 3", "TDM_A Loopback", + "TODDR_A IN 0", "TDMIN_A OUT", + "TODDR_B IN 0", "TDMIN_A OUT", + "TODDR_C IN 0", "TDMIN_A OUT";
assigned-clocks = <&clkc CLKID_MPLL2>, <&clkc CLKID_MPLL0>, @@ -193,8 +203,20 @@ sound-dai = <&frddr_c>; };
- /* 8ch hdmi interface */ dai-link-3 { + sound-dai = <&toddr_a>; + }; + + dai-link-4 { + sound-dai = <&toddr_b>; + }; + + dai-link-5 { + sound-dai = <&toddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-6 { sound-dai = <&tdmif_a>; dai-format = "i2s"; dai-tdm-slot-tx-mask-0 = <1 1>; @@ -209,7 +231,7 @@ };
/* hdmi glue */ - dai-link-4 { + dai-link-7 { sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>;
codec { @@ -278,12 +300,12 @@ };
ðmac { - pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; - pinctrl-names = "default"; - status = "okay"; - phy-mode = "rgmii"; - phy-handle = <&external_phy>; - amlogic,tx-delay-ns = <2>; + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; };
&frddr_a { @@ -330,7 +352,7 @@ #gpio-cells = <2>; };
- rtc@51 { + rtc: rtc@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>; @@ -349,9 +371,9 @@ };
&pwm_ef { - status = "okay"; - pinctrl-0 = <&pwm_e_pins>; - pinctrl-names = "default"; + status = "okay"; + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; };
&saradc { @@ -445,15 +467,30 @@ }; };
- &tdmif_a { status = "okay"; };
+&tdmin_a { + status = "okay"; +}; + &tdmout_a { status = "okay"; };
+&toddr_a { + status = "okay"; +}; + +&toddr_b { + status = "okay"; +}; + +&toddr_c { + status = "okay"; +}; + &tohdmitx { status = "okay"; }; diff --git a/arch/arm/dts/meson-sm1-bananapi-m5.dts b/arch/arm/dts/meson-sm1-bananapi-m5.dts new file mode 100644 index 0000000000..effaa138b5 --- /dev/null +++ b/arch/arm/dts/meson-sm1-bananapi-m5.dts @@ -0,0 +1,646 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2021 BayLibre SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +/dts-v1/; + +#include "meson-sm1.dtsi" +#include <dt-bindings/leds/common.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/sound/meson-g12a-toacodec.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + compatible = "bananapi,bpi-m5", "amlogic,sm1"; + model = "Banana Pi BPI-M5"; + + adc_keys { + compatible = "adc-keys"; + io-channels = <&saradc 2>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1800000>; + + key { + label = "SW3"; + linux,code = <BTN_3>; + press-threshold-microvolt = <1700000>; + }; + }; + + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + /* TOFIX: handle CVBS_DET on SARADC channel 0 */ + cvbs-connector { + compatible = "composite-video-connector"; + + port { + cvbs_connector_in: endpoint { + remote-endpoint = <&cvbs_vdac_out>; + }; + }; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + gpio-keys { + compatible = "gpio-keys"; + + key { + label = "SW1"; + linux,code = <BTN_1>; + gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_LOW>; + interrupt-parent = <&gpio_intc>; + interrupts = <3 IRQ_TYPE_EDGE_BOTH>; + }; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + green { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>; + }; + + blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_LOW>; + linux,default-trigger = "heartbeat"; + }; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + emmc_1v8: regulator-emmc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "EMMC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + dc_in: regulator-dc_in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vddio_c: regulator-vddio_c { + compatible = "regulator-gpio"; + regulator-name = "VDDIO_C"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + enable-gpio = <&gpio GPIOE_2 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + + gpios = <&gpio_ao GPIOAO_6 GPIO_OPEN_DRAIN>; + gpios-states = <1>; + + states = <1800000 0>, + <3300000 1>; + }; + + tflash_vdd: regulator-tflash_vdd { + compatible = "regulator-fixed"; + regulator-name = "TFLASH_VDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_in>; + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + vddao_3v3: regulator-vddao_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + vddcpu: regulator-vddcpu { + /* + * SY8120B1ABC DC/DC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU"; + regulator-min-microvolt = <690000>; + regulator-max-microvolt = <1050000>; + + vin-supply = <&dc_in>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + /* USB Hub Power Enable */ + vl_pwr_en: regulator-vl_pwr_en { + compatible = "regulator-fixed"; + regulator-name = "VL_PWR_EN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_in>; + + gpio = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "BPI-M5"; + audio-widgets = "Line", "Lineout"; + audio-aux-devs = <&tdmout_b>, <&tdmout_c>, + <&tdmin_a>, <&tdmin_b>, <&tdmin_c>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT", + "TDMOUT_C IN 0", "FRDDR_A OUT 2", + "TDMOUT_C IN 1", "FRDDR_B OUT 2", + "TDMOUT_C IN 2", "FRDDR_C OUT 2", + "TDM_C Playback", "TDMOUT_C OUT", + "TDMIN_A IN 4", "TDM_B Loopback", + "TDMIN_B IN 4", "TDM_B Loopback", + "TDMIN_C IN 4", "TDM_B Loopback", + "TDMIN_A IN 5", "TDM_C Loopback", + "TDMIN_B IN 5", "TDM_C Loopback", + "TDMIN_C IN 5", "TDM_C Loopback", + "TODDR_A IN 0", "TDMIN_A OUT", + "TODDR_B IN 0", "TDMIN_A OUT", + "TODDR_C IN 0", "TDMIN_A OUT", + "TODDR_A IN 1", "TDMIN_B OUT", + "TODDR_B IN 1", "TDMIN_B OUT", + "TODDR_C IN 1", "TDMIN_B OUT", + "TODDR_A IN 2", "TDMIN_C OUT", + "TODDR_B IN 2", "TDMIN_C OUT", + "TODDR_C IN 2", "TDMIN_C OUT", + "Lineout", "ACODEC LOLP", + "Lineout", "ACODEC LORP"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + dai-link-3 { + sound-dai = <&toddr_a>; + }; + + dai-link-4 { + sound-dai = <&toddr_b>; + }; + + dai-link-5 { + sound-dai = <&toddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-6 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + + codec-1 { + sound-dai = <&toacodec TOACODEC_IN_B>; + }; + }; + + /* i2s jack output interface */ + dai-link-7 { + sound-dai = <&tdmif_c>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + mclk-fs = <256>; + + codec-0 { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_C>; + }; + + codec-1 { + sound-dai = <&toacodec TOACODEC_IN_C>; + }; + }; + + /* hdmi glue */ + dai-link-8 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + + /* acodec glue */ + dai-link-9 { + sound-dai = <&toacodec TOACODEC_OUT>; + + codec { + sound-dai = <&acodec>; + }; + }; + }; +}; + +&acodec { + AVDD-supply = <&vddao_1v8>; + status = "okay"; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU1_CLK>; + clock-latency = <50000>; +}; + +&cpu2 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU2_CLK>; + clock-latency = <50000>; +}; + +&cpu3 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU3_CLK>; + clock-latency = <50000>; +}; + +&cvbs_vdac_port { + cvbs_vdac_out: endpoint { + remote-endpoint = <&cvbs_connector_in>; + }; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii-txid"; + phy-handle = <&external_phy>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&gpio { + gpio-line-names = + /* GPIOZ */ + "ETH_MDIO", /* GPIOZ_0 */ + "ETH_MDC", /* GPIOZ_1 */ + "ETH_RXCLK", /* GPIOZ_2 */ + "ETH_RX_DV", /* GPIOZ_3 */ + "ETH_RXD0", /* GPIOZ_4 */ + "ETH_RXD1", /* GPIOZ_5 */ + "ETH_RXD2", /* GPIOZ_6 */ + "ETH_RXD3", /* GPIOZ_7 */ + "ETH_TXCLK", /* GPIOZ_8 */ + "ETH_TXEN", /* GPIOZ_9 */ + "ETH_TXD0", /* GPIOZ_10 */ + "ETH_TXD1", /* GPIOZ_11 */ + "ETH_TXD2", /* GPIOZ_12 */ + "ETH_TXD3", /* GPIOZ_13 */ + "ETH_INTR", /* GPIOZ_14 */ + "ETH_NRST", /* GPIOZ_15 */ + /* GPIOH */ + "HDMI_SDA", /* GPIOH_0 */ + "HDMI_SCL", /* GPIOH_1 */ + "HDMI_HPD", /* GPIOH_2 */ + "HDMI_CEC", /* GPIOH_3 */ + "VL-RST_N", /* GPIOH_4 */ + "CON1-P36", /* GPIOH_5 */ + "VL-PWREN", /* GPIOH_6 */ + "WiFi_3V3_1V8", /* GPIOH_7 */ + "TFLASH_VDD_EN", /* GPIOH_8 */ + /* BOOT */ + "eMMC_D0", /* BOOT_0 */ + "eMMC_D1", /* BOOT_1 */ + "eMMC_D2", /* BOOT_2 */ + "eMMC_D3", /* BOOT_3 */ + "eMMC_D4", /* BOOT_4 */ + "eMMC_D5", /* BOOT_5 */ + "eMMC_D6", /* BOOT_6 */ + "eMMC_D7", /* BOOT_7 */ + "eMMC_CLK", /* BOOT_8 */ + "", + "eMMC_CMD", /* BOOT_10 */ + "", + "eMMC_RST#", /* BOOT_12 */ + "eMMC_DS", /* BOOT_13 */ + /* GPIOC */ + "SD_D0_B", /* GPIOC_0 */ + "SD_D1_B", /* GPIOC_1 */ + "SD_D2_B", /* GPIOC_2 */ + "SD_D3_B", /* GPIOC_3 */ + "SD_CLK_B", /* GPIOC_4 */ + "SD_CMD_B", /* GPIOC_5 */ + "CARD_EN_DET", /* GPIOC_6 */ + "", + /* GPIOA */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", + "CON1-P27", /* GPIOA_14 */ + "CON1-P28", /* GPIOA_15 */ + /* GPIOX */ + "CON1-P16", /* GPIOX_0 */ + "CON1-P18", /* GPIOX_1 */ + "CON1-P22", /* GPIOX_2 */ + "CON1-P11", /* GPIOX_3 */ + "CON1-P13", /* GPIOX_4 */ + "CON1-P07", /* GPIOX_5 */ + "CON1-P33", /* GPIOX_6 */ + "CON1-P15", /* GPIOX_7 */ + "CON1-P19", /* GPIOX_8 */ + "CON1-P21", /* GPIOX_9 */ + "CON1-P24", /* GPIOX_10 */ + "CON1-P23", /* GPIOX_11 */ + "CON1-P08", /* GPIOX_12 */ + "CON1-P10", /* GPIOX_13 */ + "CON1-P29", /* GPIOX_14 */ + "CON1-P31", /* GPIOX_15 */ + "CON1-P26", /* GPIOX_16 */ + "CON1-P03", /* GPIOX_17 */ + "CON1-P05", /* GPIOX_18 */ + "CON1-P32"; /* GPIOX_19 */ + + /* + * WARNING: The USB Hub on the BPI-M5 needs a reset signal + * to be turned high in order to be detected by the USB Controller + * This signal should be handled by a USB specific power sequence + * in order to reset the Hub when USB bus is powered down. + */ + usb-hub { + gpio-hog; + gpios = <GPIOH_4 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "usb-hub-reset"; + }; +}; + +&gpio_ao { + gpio-line-names = + /* GPIOAO */ + "DEBUG TX", /* GPIOAO_0 */ + "DEBUG RX", /* GPIOAO_1 */ + "SYS_LED2", /* GPIOAO_2 */ + "UPDATE_KEY", /* GPIOAO_3 */ + "CON1-P40", /* GPIOAO_4 */ + "IR_IN", /* GPIOAO_5 */ + "TF_3V3N_1V8_EN", /* GPIOAO_6 */ + "CON1-P35", /* GPIOAO_7 */ + "CON1-P12", /* GPIOAO_8 */ + "CON1-P37", /* GPIOAO_9 */ + "CON1-P38", /* GPIOAO_10 */ + "SYS_LED", /* GPIOAO_11 */ + /* GPIOE */ + "VDDEE_PWM", /* GPIOE_0 */ + "VDDCPU_PWM", /* GPIOE_1 */ + "TF_PWR_EN"; /* GPIOE_2 */ +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&dc_in>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + /* TOFIX: SD card is barely usable in SDR modes */ + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&tflash_vdd>; + vqmmc-supply = <&vddio_c>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vddao_3v3>; + vqmmc-supply = <&emmc_1v8>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmif_c { + status = "okay"; +}; + +&tdmin_a { + status = "okay"; +}; + +&tdmin_b { + status = "okay"; +}; + +&tdmin_c { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&tdmout_c { + status = "okay"; +}; + +&toacodec { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +&toddr_a { + status = "okay"; +}; + +&toddr_b { + status = "okay"; +}; + +&toddr_c { + status = "okay"; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb { + status = "okay"; +}; + +&usb2_phy0 { + phy-supply = <&dc_in>; +}; + +&usb2_phy1 { + /* Enable the hub which is connected to this port */ + phy-supply = <&vl_pwr_en>; +}; diff --git a/arch/arm/dts/meson-sm1-khadas-vim3l.dts b/arch/arm/dts/meson-sm1-khadas-vim3l.dts index 4b517ca720..f2c0981435 100644 --- a/arch/arm/dts/meson-sm1-khadas-vim3l.dts +++ b/arch/arm/dts/meson-sm1-khadas-vim3l.dts @@ -32,6 +32,19 @@ regulator-boot-on; regulator-always-on; }; + + sound { + model = "G12B-KHADAS-VIM3L"; + audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", + "TDMOUT_A IN 1", "FRDDR_B OUT 0", + "TDMOUT_A IN 2", "FRDDR_C OUT 0", + "TDM_A Playback", "TDMOUT_A OUT", + "TDMIN_A IN 0", "TDM_A Capture", + "TDMIN_A IN 13", "TDM_A Loopback", + "TODDR_A IN 0", "TDMIN_A OUT", + "TODDR_B IN 0", "TDMIN_A OUT", + "TODDR_C IN 0", "TDMIN_A OUT"; + }; };
&cpu0 { @@ -89,13 +102,12 @@ status = "okay"; };
-&sd_emmc_a { - sd-uhs-sdr50; -}; - &usb { phys = <&usb2_phy0>, <&usb2_phy1>; phy-names = "usb2-phy0", "usb2-phy1"; }; */
+&sd_emmc_a { + sd-uhs-sdr50; +}; diff --git a/arch/arm/dts/meson-sm1-odroid-c4.dts b/arch/arm/dts/meson-sm1-odroid-c4.dts index cf5a98f0e4..8c30ce6368 100644 --- a/arch/arm/dts/meson-sm1-odroid-c4.dts +++ b/arch/arm/dts/meson-sm1-odroid-c4.dts @@ -5,34 +5,12 @@
/dts-v1/;
-#include "meson-sm1.dtsi" -#include <dt-bindings/gpio/meson-g12a-gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/sound/meson-g12a-tohdmitx.h> +#include "meson-sm1-odroid.dtsi"
/ { compatible = "hardkernel,odroid-c4", "amlogic,sm1"; model = "Hardkernel ODROID-C4";
- aliases { - serial0 = &uart_AO; - ethernet0 = ðmac; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x0 0x0 0x40000000>; - }; - - emmc_pwrseq: emmc-pwrseq { - compatible = "mmc-pwrseq-emmc"; - reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; - }; - leds { compatible = "gpio-leds";
@@ -45,324 +23,19 @@ }; };
- tflash_vdd: regulator-tflash_vdd { - compatible = "regulator-fixed"; - - regulator-name = "TFLASH_VDD"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - gpio = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>; - enable-active-high; - regulator-always-on; - }; - - tf_io: gpio-regulator-tf_io { - compatible = "regulator-gpio"; - - regulator-name = "TF_IO"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - gpios = <&gpio_ao GPIOAO_6 GPIO_ACTIVE_HIGH>; - gpios-states = <0>; - - states = <3300000 0>, - <1800000 1>; - }; - - flash_1v8: regulator-flash_1v8 { - compatible = "regulator-fixed"; - regulator-name = "FLASH_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - regulator-always-on; - }; - - main_12v: regulator-main_12v { - compatible = "regulator-fixed"; - regulator-name = "12V"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - }; - - vcc_5v: regulator-vcc_5v { - compatible = "regulator-fixed"; - regulator-name = "5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&main_12v>; - }; - - vcc_1v8: regulator-vcc_1v8 { - compatible = "regulator-fixed"; - regulator-name = "VCC_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3>; - regulator-always-on; - }; - - vcc_3v3: regulator-vcc_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VCC_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vddao_3v3>; - regulator-always-on; - /* FIXME: actually controlled by VDDCPU_B_EN */ - }; - - vddcpu: regulator-vddcpu { - /* - * MP8756GD Regulator. - */ - compatible = "pwm-regulator"; - - regulator-name = "VDDCPU"; - regulator-min-microvolt = <721000>; - regulator-max-microvolt = <1022000>; - - vin-supply = <&main_12v>; - - pwms = <&pwm_AO_cd 1 1250 0>; - pwm-dutycycle-range = <100 0>; - - regulator-boot-on; - regulator-always-on; - }; - - hub_5v: regulator-hub_5v { - compatible = "regulator-fixed"; - regulator-name = "HUB_5V"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_5v>; - - /* Connected to the Hub CHIPENABLE, LOW sets low power state */ - gpio = <&gpio GPIOH_4 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - usb_pwr_en: regulator-usb_pwr_en { - compatible = "regulator-fixed"; - regulator-name = "USB_PWR_EN"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_5v>; - - /* Connected to the microUSB port power enable */ - gpio = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - vddao_1v8: regulator-vddao_1v8 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vddao_3v3>; - regulator-always-on; - }; - - vddao_3v3: regulator-vddao_3v3 { - compatible = "regulator-fixed"; - regulator-name = "VDDAO_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&main_12v>; - regulator-always-on; - }; - - hdmi-connector { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&hdmi_tx_tmds_out>; - }; - }; - }; - sound { - compatible = "amlogic,axg-sound-card"; - model = "SM1-ODROID-C4"; - audio-aux-devs = <&tdmout_b>; - audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", - "TDMOUT_B IN 1", "FRDDR_B OUT 1", - "TDMOUT_B IN 2", "FRDDR_C OUT 1", - "TDM_B Playback", "TDMOUT_B OUT"; - - assigned-clocks = <&clkc CLKID_MPLL2>, - <&clkc CLKID_MPLL0>, - <&clkc CLKID_MPLL1>; - assigned-clock-parents = <0>, <0>, <0>; - assigned-clock-rates = <294912000>, - <270950400>, - <393216000>; - status = "okay"; - - dai-link-0 { - sound-dai = <&frddr_a>; - }; - - dai-link-1 { - sound-dai = <&frddr_b>; - }; - - dai-link-2 { - sound-dai = <&frddr_c>; - }; - - /* 8ch hdmi interface */ - dai-link-3 { - sound-dai = <&tdmif_b>; - dai-format = "i2s"; - dai-tdm-slot-tx-mask-0 = <1 1>; - dai-tdm-slot-tx-mask-1 = <1 1>; - dai-tdm-slot-tx-mask-2 = <1 1>; - dai-tdm-slot-tx-mask-3 = <1 1>; - mclk-fs = <256>; - - codec { - sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; - }; - }; - - /* hdmi glue */ - dai-link-4 { - sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; - - codec { - sound-dai = <&hdmi_tx>; - }; - }; - }; -}; - -&arb { - status = "okay"; -}; - -&clkc_audio { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU_CLK>; - clock-latency = <50000>; -}; - -&cpu1 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU1_CLK>; - clock-latency = <50000>; -}; - -&cpu2 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU2_CLK>; - clock-latency = <50000>; -}; - -&cpu3 { - cpu-supply = <&vddcpu>; - operating-points-v2 = <&cpu_opp_table>; - clocks = <&clkc CLKID_CPU3_CLK>; - clock-latency = <50000>; -}; - -&ext_mdio { - external_phy: ethernet-phy@0 { - /* Realtek RTL8211F (0x001cc916) */ - reg = <0>; - max-speed = <1000>; - - interrupt-parent = <&gpio_intc>; - /* MAC_INTR on GPIOZ_14 */ - interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + model = "ODROID-C4"; }; };
-ðmac { - pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; - pinctrl-names = "default"; - status = "okay"; - phy-mode = "rgmii"; - phy-handle = <&external_phy>; - amlogic,tx-delay-ns = <2>; -}; - -&frddr_a { - status = "okay"; -}; - -&frddr_b { - status = "okay"; -}; - -&frddr_c { - status = "okay"; -}; - &gpio { - gpio-line-names = - /* GPIOZ */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - /* GPIOH */ - "", "", "", "", "", - "PIN_36", /* GPIOH_5 */ - "PIN_26", /* GPIOH_6 */ - "PIN_32", /* GPIOH_7 */ - "", - /* BOOT */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", "", "", - /* GPIOC */ - "", "", "", "", "", "", "", "", - /* GPIOA */ - "", "", "", "", "", "", "", "", - "", "", "", "", "", "", - "PIN_27", /* GPIOA_14 */ - "PIN_28", /* GPIOA_15 */ - /* GPIOX */ - "PIN_16", /* GPIOX_0 */ - "PIN_18", /* GPIOX_1 */ - "PIN_22", /* GPIOX_2 */ - "PIN_11", /* GPIOX_3 */ - "PIN_13", /* GPIOX_4 */ - "PIN_7", /* GPIOX_5 */ - "PIN_33", /* GPIOX_6 */ - "PIN_15", /* GPIOX_7 */ - "PIN_19", /* GPIOX_8 */ - "PIN_21", /* GPIOX_9 */ - "PIN_24", /* GPIOX_10 */ - "PIN_23", /* GPIOX_11 */ - "PIN_8", /* GPIOX_12 */ - "PIN_10", /* GPIOX_13 */ - "PIN_29", /* GPIOX_14 */ - "PIN_31", /* GPIOX_15 */ - "PIN_12", /* GPIOX_16 */ - "PIN_3", /* GPIOX_17 */ - "PIN_5", /* GPIOX_18 */ - "PIN_35"; /* GPIOX_19 */ - /* * WARNING: The USB Hub on the Odroid-C4 needs a reset signal * to be turned high in order to be detected by the USB Controller * This signal should be handled by a USB specific power sequence * in order to reset the Hub when USB bus is powered down. */ - usb-hub { + hog-0 { gpio-hog; gpios = <GPIOH_4 GPIO_ACTIVE_HIGH>; output-high; @@ -370,121 +43,6 @@ }; };
-&gpio_ao { - gpio-line-names = - /* GPIOAO */ - "", "", "", "", - "PIN_47", /* GPIOAO_4 */ - "", "", - "PIN_45", /* GPIOAO_7 */ - "PIN_46", /* GPIOAO_8 */ - "PIN_44", /* GPIOAO_9 */ - "PIN_42", /* GPIOAO_10 */ - "", - /* GPIOE */ - "", "", ""; -}; - -&hdmi_tx { - status = "okay"; - pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; - pinctrl-names = "default"; - hdmi-supply = <&vcc_5v>; -}; - -&hdmi_tx_tmds_port { - hdmi_tx_tmds_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; -}; - &ir { - status = "okay"; - pinctrl-0 = <&remote_input_ao_pins>; - pinctrl-names = "default"; linux,rc-map-name = "rc-odroid"; }; - -&pwm_AO_cd { - pinctrl-0 = <&pwm_ao_d_e_pins>; - pinctrl-names = "default"; - clocks = <&xtal>; - clock-names = "clkin1"; - status = "okay"; -}; - -&saradc { - status = "okay"; -}; - -/* SD card */ -&sd_emmc_b { - status = "okay"; - pinctrl-0 = <&sdcard_c_pins>; - pinctrl-1 = <&sdcard_clk_gate_c_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <4>; - cap-sd-highspeed; - max-frequency = <200000000>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - disable-wp; - - cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; - vmmc-supply = <&tflash_vdd>; - vqmmc-supply = <&tf_io>; -}; - -/* eMMC */ -&sd_emmc_c { - status = "okay"; - pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; - pinctrl-1 = <&emmc_clk_gate_pins>; - pinctrl-names = "default", "clk-gate"; - - bus-width = <8>; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - max-frequency = <200000000>; - disable-wp; - - mmc-pwrseq = <&emmc_pwrseq>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&flash_1v8>; -}; - -&tdmif_b { - status = "okay"; -}; - -&tdmout_b { - status = "okay"; -}; - -&tohdmitx { - status = "okay"; -}; - -&uart_AO { - status = "okay"; - pinctrl-0 = <&uart_ao_a_pins>; - pinctrl-names = "default"; -}; - -&usb { - status = "okay"; - vbus-supply = <&usb_pwr_en>; -}; - -&usb2_phy0 { - phy-supply = <&vcc_5v>; -}; - -&usb2_phy1 { - /* Enable the hub which is connected to this port */ - phy-supply = <&hub_5v>; -}; diff --git a/arch/arm/dts/meson-sm1-odroid-hc4.dts b/arch/arm/dts/meson-sm1-odroid-hc4.dts new file mode 100644 index 0000000000..f3f953225b --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid-hc4.dts @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Dongjin Kim tobetter@gmail.com + */ + +/dts-v1/; + +#include "meson-sm1-odroid.dtsi" + +/ { + compatible = "hardkernel,odroid-hc4", "amlogic,sm1"; + model = "Hardkernel ODROID-HC4"; + + aliases { + rtc0 = &rtc; + rtc1 = &vrtc; + }; + + fan0: pwm-fan { + compatible = "pwm-fan"; + #cooling-cells = <2>; + cooling-min-state = <0>; + cooling-max-state = <3>; + cooling-levels = <0 120 170 220>; + pwms = <&pwm_cd 1 40000 0>; + }; + + leds { + compatible = "gpio-leds"; + + led-blue { + color = <LED_COLOR_ID_BLUE>; + function = LED_FUNCTION_STATUS; + gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + panic-indicator; + }; + + led-red { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_POWER; + gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; + + /* Powers the SATA Disk 0 regulator, which is enabled when a disk load is detected */ + p12v_0: regulator-p12v_0 { + compatible = "regulator-fixed"; + regulator-name = "P12V_0"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <&main_12v>; + + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + }; + + /* Powers the SATA Disk 1 regulator, which is enabled when a disk load is detected */ + p12v_1: regulator-p12v_1 { + compatible = "regulator-fixed"; + regulator-name = "P12V_1"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + vin-supply = <&main_12v>; + + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + }; + + sound { + model = "ODROID-HC4"; + }; +}; + +&cpu_thermal { + cooling-maps { + map { + trip = <&cpu_passive>; + cooling-device = <&fan0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; +}; + +&ir { + linux,rc-map-name = "rc-odroid"; +}; + +&i2c2 { + status = "okay"; + pinctrl-0 = <&i2c2_sda_x_pins>, <&i2c2_sck_x_pins>; + pinctrl-names = "default"; + + rtc: rtc@51 { + status = "okay"; + compatible = "nxp,pcf8563"; + reg = <0x51>; + wakeup-source; + }; +}; + +&pcie { + status = "okay"; + reset-gpios = <&gpio GPIOH_4 GPIO_ACTIVE_LOW>; +}; + +&pwm_cd { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&pwm_d_x6_pins>; +}; + +&sd_emmc_c { + status = "disabled"; +}; + +&spifc { + status = "okay"; + pinctrl-0 = <&nor_pins>; + pinctrl-names = "default"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <104000000>; + }; +}; + +&usb { + phys = <&usb2_phy1>; + phy-names = "usb2-phy1"; +}; + +&usb2_phy0 { + status = "disabled"; +}; diff --git a/arch/arm/dts/meson-sm1-odroid.dtsi b/arch/arm/dts/meson-sm1-odroid.dtsi new file mode 100644 index 0000000000..fd0ad85c16 --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid.dtsi @@ -0,0 +1,449 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Dongjin Kim tobetter@gmail.com + */ + +#include "meson-sm1.dtsi" +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + tflash_vdd: regulator-tflash_vdd { + compatible = "regulator-fixed"; + + regulator-name = "TFLASH_VDD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; + enable-active-high; + regulator-always-on; + }; + + tf_io: gpio-regulator-tf_io { + compatible = "regulator-gpio"; + + regulator-name = "TF_IO"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc_5v>; + + enable-gpio = <&gpio GPIOE_2 GPIO_ACTIVE_HIGH>; + enable-active-high; + regulator-always-on; + + gpios = <&gpio_ao GPIOAO_6 GPIO_OPEN_SOURCE>; + gpios-states = <0>; + + states = <3300000 0>, + <1800000 1>; + }; + + flash_1v8: regulator-flash_1v8 { + compatible = "regulator-fixed"; + regulator-name = "FLASH_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + main_12v: regulator-main_12v { + compatible = "regulator-fixed"; + regulator-name = "12V"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + regulator-always-on; + }; + + vcc_5v: regulator-vcc_5v { + compatible = "regulator-fixed"; + regulator-name = "5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + vin-supply = <&main_12v>; + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + /* FIXME: actually controlled by VDDCPU_B_EN */ + }; + + vddcpu: regulator-vddcpu { + /* + * MP8756GD Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU"; + regulator-min-microvolt = <721000>; + regulator-max-microvolt = <1022000>; + + vin-supply = <&main_12v>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + usb_pwr_en: regulator-usb_pwr_en { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR_EN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + /* Connected to the microUSB port power enable */ + gpio = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vddao_3v3>; + regulator-always-on; + }; + + vddao_3v3: regulator-vddao_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VDDAO_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&main_12v>; + regulator-always-on; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + sound { + compatible = "amlogic,axg-sound-card"; + audio-aux-devs = <&tdmout_b>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* hdmi glue */ + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&clkc_audio { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU1_CLK>; + clock-latency = <50000>; +}; + +&cpu2 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU2_CLK>; + clock-latency = <50000>; +}; + +&cpu3 { + cpu-supply = <&vddcpu>; + operating-points-v2 = <&cpu_opp_table>; + clocks = <&clkc CLKID_CPU3_CLK>; + clock-latency = <50000>; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&gpio { + gpio-line-names = + /* GPIOZ */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOH */ + "", "", "", "", "", + "PIN_36", /* GPIOH_5 */ + "PIN_26", /* GPIOH_6 */ + "PIN_32", /* GPIOH_7 */ + "", + /* BOOT */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + /* GPIOC */ + "", "", "", "", "", "", "", "", + /* GPIOA */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", + "PIN_27", /* GPIOA_14 */ + "PIN_28", /* GPIOA_15 */ + /* GPIOX */ + "PIN_16", /* GPIOX_0 */ + "PIN_18", /* GPIOX_1 */ + "PIN_22", /* GPIOX_2 */ + "PIN_11", /* GPIOX_3 */ + "PIN_13", /* GPIOX_4 */ + "PIN_7", /* GPIOX_5 */ + "PIN_33", /* GPIOX_6 */ + "PIN_15", /* GPIOX_7 */ + "PIN_19", /* GPIOX_8 */ + "PIN_21", /* GPIOX_9 */ + "PIN_24", /* GPIOX_10 */ + "PIN_23", /* GPIOX_11 */ + "PIN_8", /* GPIOX_12 */ + "PIN_10", /* GPIOX_13 */ + "PIN_29", /* GPIOX_14 */ + "PIN_31", /* GPIOX_15 */ + "PIN_12", /* GPIOX_16 */ + "PIN_3", /* GPIOX_17 */ + "PIN_5", /* GPIOX_18 */ + "PIN_35"; /* GPIOX_19 */ +}; + +&gpio_ao { + gpio-line-names = + /* GPIOAO */ + "", "", "", "", + "PIN_47", /* GPIOAO_4 */ + "", "", + "PIN_45", /* GPIOAO_7 */ + "PIN_46", /* GPIOAO_8 */ + "PIN_44", /* GPIOAO_9 */ + "PIN_42", /* GPIOAO_10 */ + "", + /* GPIOE */ + "", "", ""; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc_5v>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + +&saradc { + status = "okay"; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <200000000>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-sdr104; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&tflash_vdd>; + vqmmc-supply = <&tf_io>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&flash_1v8>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb { + status = "okay"; + vbus-supply = <&usb_pwr_en>; +}; + +&usb2_phy0 { + phy-supply = <&vcc_5v>; +}; + diff --git a/arch/arm/dts/meson-sm1-sei610.dts b/arch/arm/dts/meson-sm1-sei610.dts index 5ab139a34c..2194a77897 100644 --- a/arch/arm/dts/meson-sm1-sei610.dts +++ b/arch/arm/dts/meson-sm1-sei610.dts @@ -101,20 +101,20 @@ }; };
- leds { + led-controller-1 { compatible = "gpio-leds";
- led-bluetooth { + led-1 { label = "sei610:blue:bt"; gpios = <&gpio GPIOC_7 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; default-state = "off"; }; };
- pwmleds { + led-controller-2 { compatible = "pwm-leds";
- power { + led-2 { label = "sei610:red:power"; pwms = <&pwm_AO_ab 0 30518 0>; max-brightness = <255>; @@ -220,7 +220,7 @@
sound { compatible = "amlogic,axg-sound-card"; - model = "SM1-SEI610"; + model = "SEI610"; audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", diff --git a/arch/arm/dts/meson-sm1.dtsi b/arch/arm/dts/meson-sm1.dtsi index 71317f5aad..3d8b1f4f20 100644 --- a/arch/arm/dts/meson-sm1.dtsi +++ b/arch/arm/dts/meson-sm1.dtsi @@ -130,7 +130,7 @@ opp-microvolt = <790000>; };
- opp-1512000000 { + opp-1500000000 { opp-hz = /bits/ 64 <1500000000>; opp-microvolt = <800000>; }; @@ -401,6 +401,16 @@ status = "disabled"; };
+ toacodec: audio-controller@740 { + compatible = "amlogic,sm1-toacodec", + "amlogic,g12a-toacodec"; + reg = <0x0 0x740 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOACODEC"; + resets = <&clkc_audio AUD_RESET_TOACODEC>; + status = "disabled"; + }; + tohdmitx: audio-controller@744 { compatible = "amlogic,sm1-tohdmitx", "amlogic,g12a-tohdmitx"; diff --git a/include/dt-bindings/clock/axg-clkc.h b/include/dt-bindings/clock/axg-clkc.h index fd1f938c38..93752ea107 100644 --- a/include/dt-bindings/clock/axg-clkc.h +++ b/include/dt-bindings/clock/axg-clkc.h @@ -70,7 +70,31 @@ #define CLKID_HIFI_PLL 69 #define CLKID_PCIE_CML_EN0 79 #define CLKID_PCIE_CML_EN1 80 -#define CLKID_MIPI_ENABLE 81 #define CLKID_GEN_CLK 84 +#define CLKID_VPU_0_SEL 92 +#define CLKID_VPU_0 93 +#define CLKID_VPU_1_SEL 95 +#define CLKID_VPU_1 96 +#define CLKID_VPU 97 +#define CLKID_VAPB_0_SEL 99 +#define CLKID_VAPB_0 100 +#define CLKID_VAPB_1_SEL 102 +#define CLKID_VAPB_1 103 +#define CLKID_VAPB_SEL 104 +#define CLKID_VAPB 105 +#define CLKID_VCLK 106 +#define CLKID_VCLK2 107 +#define CLKID_VCLK_DIV1 122 +#define CLKID_VCLK_DIV2 123 +#define CLKID_VCLK_DIV4 124 +#define CLKID_VCLK_DIV6 125 +#define CLKID_VCLK_DIV12 126 +#define CLKID_VCLK2_DIV1 127 +#define CLKID_VCLK2_DIV2 128 +#define CLKID_VCLK2_DIV4 129 +#define CLKID_VCLK2_DIV6 130 +#define CLKID_VCLK2_DIV12 131 +#define CLKID_CTS_ENCL 133 +#define CLKID_VDIN_MEAS 136
#endif /* __AXG_CLKC_H */ diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index 40d49940d8..a93b58c5e1 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -147,5 +147,7 @@ #define CLKID_SPICC1_SCLK 261 #define CLKID_NNA_AXI_CLK 264 #define CLKID_NNA_CORE_CLK 267 +#define CLKID_MIPI_DSI_PXCLK_SEL 269 +#define CLKID_MIPI_DSI_PXCLK 270
#endif /* __G12A_CLKC_H */
Upstream Linux uses the "amlogic,meson-axg-usb-ctrl" for AXG SoCs.
This adds it to the compatible list for this driver.
Reported-by: Vyacheslav Bocharov adeep@lexina.in Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/usb/dwc3/dwc3-meson-gxl.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/dwc3/dwc3-meson-gxl.c b/drivers/usb/dwc3/dwc3-meson-gxl.c index 08467d6210..b8f3886173 100644 --- a/drivers/usb/dwc3/dwc3-meson-gxl.c +++ b/drivers/usb/dwc3/dwc3-meson-gxl.c @@ -409,6 +409,7 @@ static int dwc3_meson_gxl_remove(struct udevice *dev) }
static const struct udevice_id dwc3_meson_gxl_ids[] = { + { .compatible = "amlogic,meson-axg-usb-ctrl" }, { .compatible = "amlogic,meson-gxl-usb-ctrl" }, { .compatible = "amlogic,meson-gxm-usb-ctrl" }, { }
Tested-by: Vyacheslav Bocharov adeep@lexina.in
17.09.2021 10:37, Neil Armstrong пишет:
- { .compatible = "amlogic,meson-axg-usb-ctrl" }, { .compatible = "amlogic,meson-gxl-usb-ctrl" }, { .compatible = "amlogic,meson-gxm-usb-ctrl" }, { }
Since Linux commmit [1], the order is fixed with aliases, in order to keep the MMC device order, set it back to HW order in U-Boot dtsi files.
[1] ab547c4fb39f ("arm64: dts: amlogic: Assign a fixed index to mmc devices")
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12-common-u-boot.dtsi | 7 +++++++ arch/arm/dts/meson-gx-u-boot.dtsi | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/arch/arm/dts/meson-g12-common-u-boot.dtsi b/arch/arm/dts/meson-g12-common-u-boot.dtsi index 38fd3d3feb..b1f60b15c9 100644 --- a/arch/arm/dts/meson-g12-common-u-boot.dtsi +++ b/arch/arm/dts/meson-g12-common-u-boot.dtsi @@ -5,6 +5,13 @@ */
/ { + /* Keep HW order from U-boot */ + aliases { + /delete-property/ mmc0; + /delete-property/ mmc1; + /delete-property/ mmc2; + }; + soc { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/meson-gx-u-boot.dtsi b/arch/arm/dts/meson-gx-u-boot.dtsi index 17d2cb95c1..fb6952f1d8 100644 --- a/arch/arm/dts/meson-gx-u-boot.dtsi +++ b/arch/arm/dts/meson-gx-u-boot.dtsi @@ -5,6 +5,13 @@ */
Drop the local USB nodes after Linux 5.14 sync.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-axg-s400-u-boot.dtsi | 8 ---- arch/arm/dts/meson-axg-u-boot.dtsi | 62 ------------------------- 2 files changed, 70 deletions(-) delete mode 100644 arch/arm/dts/meson-axg-u-boot.dtsi
diff --git a/arch/arm/dts/meson-axg-s400-u-boot.dtsi b/arch/arm/dts/meson-axg-s400-u-boot.dtsi index 2c4b06f140..334650d610 100644 --- a/arch/arm/dts/meson-axg-s400-u-boot.dtsi +++ b/arch/arm/dts/meson-axg-s400-u-boot.dtsi @@ -3,8 +3,6 @@ * Copyright (c) 2017 Amlogic, Inc. All rights reserved. */
-#include "meson-axg-u-boot.dtsi" - /* wifi module */ &sd_emmc_b { status = "disabled"; @@ -15,12 +13,6 @@ status = "okay"; };
-&usb { - status = "okay"; - dr_mode = "otg"; - vbus-supply = <&usb_pwr>; -}; - &usb2_phy1 { phy-supply = <&vcc_5v>; }; diff --git a/arch/arm/dts/meson-axg-u-boot.dtsi b/arch/arm/dts/meson-axg-u-boot.dtsi deleted file mode 100644 index cb1c71e78c..0000000000 --- a/arch/arm/dts/meson-axg-u-boot.dtsi +++ /dev/null @@ -1,62 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 BayLibre, SAS. - * Author: Neil Armstrong narmstrong@baylibre.com - */ - -/ { - soc { - usb: usb@ffe09080 { - compatible = "amlogic,meson-gxl-usb-ctrl"; - reg = <0x0 0xffe09080 0x0 0x20>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - clocks = <&clkc CLKID_USB>, <&clkc CLKID_USB1_DDR_BRIDGE>; - clock-names = "usb_ctrl", "ddr"; - resets = <&reset RESET_USB_OTG>; - - dr_mode = "otg"; - - phys = <&usb2_phy1>; - phy-names = "usb2-phy1"; - - dwc2: usb@ff400000 { - compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; - reg = <0x0 0xff400000 0x0 0x40000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clkc CLKID_USB1>; - clock-names = "otg"; - phys = <&usb2_phy1>; - dr_mode = "peripheral"; - g-rx-fifo-size = <192>; - g-np-tx-fifo-size = <128>; - g-tx-fifo-size = <128 128 16 16 16>; - }; - - dwc3: usb@ff500000 { - compatible = "snps,dwc3"; - reg = <0x0 0xff500000 0x0 0x100000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - dr_mode = "host"; - maximum-speed = "high-speed"; - snps,dis_u2_susphy_quirk; - }; - }; - }; -}; - -&apb { - usb2_phy1: phy@9020 { - compatible = "amlogic,meson-gxl-usb2-phy"; - #phy-cells = <0>; - reg = <0x0 0x9020 0x0 0x20>; - clocks = <&clkc CLKID_USB>; - clock-names = "phy"; - resets = <&reset RESET_USB_OTG>; - reset-names = "phy"; - status = "okay"; - }; -};
Add SCSI target to be able to boot from the SATA disks on the Odroid HC4 using an on-board AHCI PCIe controller.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Mark Kettenis kettenis@openbsd.org --- include/configs/meson64.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/meson64.h b/include/configs/meson64.h index f9bb0240d2..08816fff1f 100644 --- a/include/configs/meson64.h +++ b/include/configs/meson64.h @@ -66,6 +66,12 @@ #define BOOT_TARGET_NVME(func) #endif
+#ifdef CONFIG_CMD_SCSI + #define BOOT_TARGET_SCSI(func) func(SCSI, scsi, 0) +#else + #define BOOT_TARGET_SCSI(func) +#endif + #ifndef BOOT_TARGET_DEVICES #define BOOT_TARGET_DEVICES(func) \ func(ROMUSB, romusb, na) \ @@ -74,6 +80,7 @@ func(MMC, mmc, 2) \ BOOT_TARGET_DEVICES_USB(func) \ BOOT_TARGET_NVME(func) \ + BOOT_TARGET_SCSI(func) \ func(PXE, pxe, na) \ func(DHCP, dhcp, na) #endif
The SCSI device can be a PCIe adapter, so run pcie enum if enabled.
Signed-off-by: Mark Kettenis kettenis@openbsd.org Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- include/config_distro_bootcmd.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 750e9e04e8..3f724aa10f 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -226,6 +226,7 @@ "fi\0" \ \ "scsi_boot=" \ + BOOTENV_RUN_PCI_ENUM \ BOOTENV_RUN_SCSI_INIT \ BOOTENV_SHARED_BLKDEV_BODY(scsi) #define BOOTENV_DEV_SCSI BOOTENV_DEV_BLKDEV
The Odroid-HC4 is a variant of the Odroid-C4 board but with a PCIe-SATA bridge instead of the USB3 ports.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi | 23 +++++ board/amlogic/odroid-n2/MAINTAINERS | 1 + configs/odroid-hc4_defconfig | 92 +++++++++++++++++++ 3 files changed, 116 insertions(+) create mode 100644 arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi create mode 100644 configs/odroid-hc4_defconfig
diff --git a/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi b/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi new file mode 100644 index 0000000000..963bf96b25 --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid-hc4-u-boot.dtsi @@ -0,0 +1,23 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-sm1-u-boot.dtsi" + +ðmac { + snps,reset-gpio = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +}; + +/* SARADC is needed for proper board variant detection */ +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + +&tflash_vdd { + gpio = <&gpio_ao GPIOAO_3 GPIO_OPEN_DRAIN>; +}; diff --git a/board/amlogic/odroid-n2/MAINTAINERS b/board/amlogic/odroid-n2/MAINTAINERS index 77f7746346..43724e6fdd 100644 --- a/board/amlogic/odroid-n2/MAINTAINERS +++ b/board/amlogic/odroid-n2/MAINTAINERS @@ -5,5 +5,6 @@ L: u-boot-amlogic@groups.io F: board/amlogic/odroid-n2/ F: configs/odroid-n2_defconfig F: configs/odroid-c4_defconfig +F: configs/odroid-hc4_defconfig F: doc/board/amlogic/odroid-n2.rst F: doc/board/amlogic/odroid-c4.rst diff --git a/configs/odroid-hc4_defconfig b/configs/odroid-hc4_defconfig new file mode 100644 index 0000000000..7671496218 --- /dev/null +++ b/configs/odroid-hc4_defconfig @@ -0,0 +1,92 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="odroid-n2" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="meson-sm1-odroid-hc4" +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" odroid-hc4" +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_SATA=y +CONFIG_SCSI_AHCI=y +CONFIG_AHCI_PCI=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_XTX=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_PCI=y +CONFIG_PCIE_DW_MESON=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_RESET=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MESON_SPIFC=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y
Add documentation bits for the Odroid-HC4.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- doc/board/amlogic/index.rst | 2 +- doc/board/amlogic/odroid-c4.rst | 3 +++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/doc/board/amlogic/index.rst b/doc/board/amlogic/index.rst index 8da7afddb4..af12f94fde 100644 --- a/doc/board/amlogic/index.rst +++ b/doc/board/amlogic/index.rst @@ -18,7 +18,7 @@ This matrix concerns the actual source code version. | Boards | Odroid-C2 | P212 | Khadas VIM2 | S400 | U200 | Odroid-N2 | SEI610 | | | Nanopi-K2 | Khadas-VIM | Libretech-PC | | SEI510 | Khadas-VIM3 | Khadas-VIM3L | | | P200 | LibreTech-CC v1 | WeTek Core2 | | | GT-King/Pro | Odroid-C4 | -| | P201 | LibreTech-AC v2 | | | | | | +| | P201 | LibreTech-AC v2 | | | | | Odroid-HC4 | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ | UART | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ diff --git a/doc/board/amlogic/odroid-c4.rst b/doc/board/amlogic/odroid-c4.rst index 5a5a8688b8..f66d60a54d 100644 --- a/doc/board/amlogic/odroid-c4.rst +++ b/doc/board/amlogic/odroid-c4.rst @@ -17,6 +17,9 @@ Co. Ltd with the following specifications: - UART serial - Infrared receiver
+The ODROID-HC4 is a variant with a PCIe-SATA controller, the same commands +applies for HC4. + Schematics are available on the manufacturer website.
U-Boot compilation
The Beelink GS-King X is a variant of the GS King boards but with an internal USB to SATA bridge and advanced audio features.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi | 7 ++ board/amlogic/beelink-s922x/MAINTAINERS | 1 + configs/beelink-gsking-x_defconfig | 70 ++++++++++++++++++++ doc/board/amlogic/index.rst | 2 +- 4 files changed, 79 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi create mode 100644 configs/beelink-gsking-x_defconfig
diff --git a/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi b/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi new file mode 100644 index 0000000000..236f2468dc --- /dev/null +++ b/arch/arm/dts/meson-g12b-gsking-x-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-g12-common-u-boot.dtsi" diff --git a/board/amlogic/beelink-s922x/MAINTAINERS b/board/amlogic/beelink-s922x/MAINTAINERS index 7f223df4ae..47b622765a 100644 --- a/board/amlogic/beelink-s922x/MAINTAINERS +++ b/board/amlogic/beelink-s922x/MAINTAINERS @@ -5,5 +5,6 @@ L: u-boot-amlogic@groups.io F: board/amlogic/beelink-s922x/ F: configs/beelink-gtking_defconfig F: configs/beelink-gtkingpro_defconfig +F: configs/beelink-gsking-x_defconfig F: doc/board/amlogic/beelink-gtking.rst F: doc/board/amlogic/beelink-gtkingpro.rst diff --git a/configs/beelink-gsking-x_defconfig b/configs/beelink-gsking-x_defconfig new file mode 100644 index 0000000000..8a76e8829a --- /dev/null +++ b/configs/beelink-gsking-x_defconfig @@ -0,0 +1,70 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="beelink-s922x" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-gsking-x" +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" beelink" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_MMC_MESON_GX=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/doc/board/amlogic/index.rst b/doc/board/amlogic/index.rst index af12f94fde..de1a9ce284 100644 --- a/doc/board/amlogic/index.rst +++ b/doc/board/amlogic/index.rst @@ -18,7 +18,7 @@ This matrix concerns the actual source code version. | Boards | Odroid-C2 | P212 | Khadas VIM2 | S400 | U200 | Odroid-N2 | SEI610 | | | Nanopi-K2 | Khadas-VIM | Libretech-PC | | SEI510 | Khadas-VIM3 | Khadas-VIM3L | | | P200 | LibreTech-CC v1 | WeTek Core2 | | | GT-King/Pro | Odroid-C4 | -| | P201 | LibreTech-AC v2 | | | | | Odroid-HC4 | +| | P201 | LibreTech-AC v2 | | | | GSKing-X | Odroid-HC4 | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ | UART | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+
Banana Pi BPI-M5 is a credit card format SBC with the following features: - Amlogic S905X3 quad core Cortex-A55 - Mali-G31 GPU - 4GB LPDDR4 - 16GB eMMC flash - 4 USB 3.0 - 1 GbE ethernet - HDMI output - 2x LEDS - SDCard - 2.5mm Jack with Stereo Audio + CVBS - Infrared Received - ADC Button - GPIO Button - 40 pins header + 3pins debug header
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- .../arm/dts/meson-sm1-bananapi-m5-u-boot.dtsi | 13 ++++ board/amlogic/u200/MAINTAINERS | 1 + configs/bananapi-m5_defconfig | 73 +++++++++++++++++++ doc/board/amlogic/index.rst | 1 + 4 files changed, 88 insertions(+) create mode 100644 arch/arm/dts/meson-sm1-bananapi-m5-u-boot.dtsi create mode 100644 configs/bananapi-m5_defconfig
diff --git a/arch/arm/dts/meson-sm1-bananapi-m5-u-boot.dtsi b/arch/arm/dts/meson-sm1-bananapi-m5-u-boot.dtsi new file mode 100644 index 0000000000..a86fdb5668 --- /dev/null +++ b/arch/arm/dts/meson-sm1-bananapi-m5-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2021 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-sm1-u-boot.dtsi" + +ðmac { + snps,reset-gpio = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; + snps,reset-delays-us = <0 10000 1000000>; + snps,reset-active-low; +}; diff --git a/board/amlogic/u200/MAINTAINERS b/board/amlogic/u200/MAINTAINERS index 8c23f9a7d3..655cf64a3d 100644 --- a/board/amlogic/u200/MAINTAINERS +++ b/board/amlogic/u200/MAINTAINERS @@ -4,4 +4,5 @@ S: Maintained L: u-boot-amlogic@groups.io F: board/amlogic/u200/ F: configs/u200_defconfig +F: configs/bananapi-m5_defconfig F: doc/board/amlogic/u200.rst diff --git a/configs/bananapi-m5_defconfig b/configs/bananapi-m5_defconfig new file mode 100644 index 0000000000..a088761622 --- /dev/null +++ b/configs/bananapi-m5_defconfig @@ -0,0 +1,73 @@ +CONFIG_ARM=y +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="meson-sm1-bananapi-m5" +CONFIG_MESON_G12A=y +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING="bpi-m5" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_MISC_INIT_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_ADC=y +CONFIG_SARADC_MESON=y +CONFIG_MMC_MESON_GX=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_DM_MDIO=y +CONFIG_DM_MDIO_MUX=y +CONFIG_ETH_DESIGNWARE_MESON8B=y +CONFIG_MDIO_MUX_MESON_G12A=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_POWER_DOMAIN=y +CONFIG_MESON_EE_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +# CONFIG_USB_DWC3_GADGET is not set +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_DM_VIDEO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP16 is not set +CONFIG_SYS_WHITE_ON_BLACK=y +CONFIG_VIDEO_MESON=y +CONFIG_VIDEO_DT_SIMPLEFB=y +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/doc/board/amlogic/index.rst b/doc/board/amlogic/index.rst index de1a9ce284..2913ab281a 100644 --- a/doc/board/amlogic/index.rst +++ b/doc/board/amlogic/index.rst @@ -19,6 +19,7 @@ This matrix concerns the actual source code version. | | Nanopi-K2 | Khadas-VIM | Libretech-PC | | SEI510 | Khadas-VIM3 | Khadas-VIM3L | | | P200 | LibreTech-CC v1 | WeTek Core2 | | | GT-King/Pro | Odroid-C4 | | | P201 | LibreTech-AC v2 | | | | GSKing-X | Odroid-HC4 | +| | | | | | | | BananaPi-M5 | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+ | UART | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | **Yes** | +-------------------------------+-----------+-----------------+--------------+------------+------------+-------------+--------------+
On 17/09/2021 09:37, Neil Armstrong wrote:
Import Amlogic DT changes from Linux commit 7d2a07b76933 ("Linux 5.14"), dt-bindings clock changes and new meson-g12b-gsking-x.dts, meson-sm1-bananapi-m5 & odroid-hc4 boards.
arch/arm/dts/Makefile | 3 + arch/arm/dts/meson-axg-s400.dts | 16 + arch/arm/dts/meson-axg.dtsi | 181 +++++ arch/arm/dts/meson-g12-common.dtsi | 31 +- arch/arm/dts/meson-g12a-sei510.dts | 2 +- arch/arm/dts/meson-g12b-gsking-x.dts | 133 ++++ arch/arm/dts/meson-g12b-gtking-pro.dts | 23 +- arch/arm/dts/meson-g12b-gtking.dts | 22 +- arch/arm/dts/meson-g12b-odroid-n2-plus.dts | 2 +- arch/arm/dts/meson-g12b-odroid-n2.dtsi | 74 +- arch/arm/dts/meson-g12b-w400.dtsi | 2 +- arch/arm/dts/meson-g12b.dtsi | 4 + arch/arm/dts/meson-gx-libretech-pc.dtsi | 2 +- arch/arm/dts/meson-gx-p23x-q20x.dtsi | 2 +- arch/arm/dts/meson-gx.dtsi | 7 + arch/arm/dts/meson-gxbb-nanopi-k2.dts | 42 +- arch/arm/dts/meson-gxbb-odroidc2.dts | 44 +- arch/arm/dts/meson-gxl-s805x-libretech-ac.dts | 2 +- arch/arm/dts/meson-gxl-s905x-khadas-vim.dts | 50 +- .../dts/meson-gxl-s905x-libretech-cc-v2.dts | 6 +- arch/arm/dts/meson-gxl-s905x-libretech-cc.dts | 2 +- arch/arm/dts/meson-gxm-khadas-vim2.dts | 55 +- arch/arm/dts/meson-gxm-wetek-core2.dts | 2 +- arch/arm/dts/meson-gxm.dtsi | 20 + arch/arm/dts/meson-khadas-vim3.dtsi | 73 +- arch/arm/dts/meson-sm1-bananapi-m5.dts | 646 ++++++++++++++++++ arch/arm/dts/meson-sm1-khadas-vim3l.dts | 20 +- arch/arm/dts/meson-sm1-odroid-c4.dts | 448 +----------- arch/arm/dts/meson-sm1-odroid-hc4.dts | 140 ++++ arch/arm/dts/meson-sm1-odroid.dtsi | 449 ++++++++++++ arch/arm/dts/meson-sm1-sei610.dts | 10 +- arch/arm/dts/meson-sm1.dtsi | 12 +- include/dt-bindings/clock/axg-clkc.h | 26 +- include/dt-bindings/clock/g12a-clkc.h | 2 + 34 files changed, 2030 insertions(+), 523 deletions(-) create mode 100644 arch/arm/dts/meson-g12b-gsking-x.dts create mode 100644 arch/arm/dts/meson-sm1-bananapi-m5.dts create mode 100644 arch/arm/dts/meson-sm1-odroid-hc4.dts create mode 100644 arch/arm/dts/meson-sm1-odroid.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fc16a57e60..f0160d2dc0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -177,11 +177,14 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-g12a-sei510.dtb \ meson-g12b-gtking.dtb \ meson-g12b-gtking-pro.dtb \
- meson-g12b-gsking-x.dtb \ meson-g12b-odroid-n2.dtb \ meson-g12b-odroid-n2-plus.dtb \ meson-g12b-a311d-khadas-vim3.dtb \
- meson-sm1-bananapi-m5.dtb \ meson-sm1-khadas-vim3l.dtb \ meson-sm1-odroid-c4.dtb \
- meson-sm1-odroid-hc4.dtb \ meson-sm1-sei610.dtb
dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ diff --git a/arch/arm/dts/meson-axg-s400.dts b/arch/arm/dts/meson-axg-s400.dts index cb1360ae12..359589d1df 100644 --- a/arch/arm/dts/meson-axg-s400.dts +++ b/arch/arm/dts/meson-axg-s400.dts @@ -441,6 +441,16 @@ status = "okay"; };
+&pcieA {
- reset-gpios = <&gpio GPIOX_19 GPIO_ACTIVE_LOW>;
- status = "okay";
+&pcieB {
- reset-gpios = <&gpio GPIOZ_10 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>;
- status = "okay";
&pwm_ab { status = "okay"; pinctrl-0 = <&pwm_a_x20_pins>; @@ -584,3 +594,9 @@ pinctrl-0 = <&uart_ao_a_pins>; pinctrl-names = "default"; };
+&usb {
- status = "okay";
- dr_mode = "otg";
+}; diff --git a/arch/arm/dts/meson-axg.dtsi b/arch/arm/dts/meson-axg.dtsi index b9efc84692..3f5254eeb4 100644 --- a/arch/arm/dts/meson-axg.dtsi +++ b/arch/arm/dts/meson-axg.dtsi @@ -12,6 +12,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> #include <dt-bindings/reset/amlogic,meson-axg-reset.h> +#include <dt-bindings/power/meson-axg-power.h>
/ { compatible = "amlogic,meson-axg"; @@ -171,6 +172,98 @@ #size-cells = <2>; ranges;
pcieA: pcie@f9800000 {
compatible = "amlogic,axg-pcie", "snps,dw-pcie";
reg = <0x0 0xf9800000 0x0 0x400000>,
<0x0 0xff646000 0x0 0x2000>,
<0x0 0xf9f00000 0x0 0x100000>;
reg-names = "elbi", "cfg", "config";
interrupts = <GIC_SPI 177 IRQ_TYPE_EDGE_RISING>;
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 179 IRQ_TYPE_EDGE_RISING>;
bus-range = <0x0 0xff>;
#address-cells = <3>;
#size-cells = <2>;
device_type = "pci";
ranges = <0x82000000 0 0xf9c00000 0x0 0xf9c00000 0 0x00300000>;
clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_A>, <&clkc CLKID_PCIE_CML_EN0>;
clock-names = "general", "pclk", "port";
resets = <&reset RESET_PCIE_A>, <&reset RESET_PCIE_APB>;
reset-names = "port", "apb";
num-lanes = <1>;
phys = <&pcie_phy>;
phy-names = "pcie";
pcieB: pcie@fa000000 {
reg = <0x0 0xfa000000 0x0 0x400000>,
<0x0 0xff648000 0x0 0x2000>,
<0x0 0xfa400000 0x0 0x100000>;
interrupts = <GIC_SPI 167 IRQ_TYPE_EDGE_RISING>;
interrupt-map = <0 0 0 0 &gic GIC_SPI 169 IRQ_TYPE_EDGE_RISING>;
#size-cells = <2>;
ranges = <0x82000000 0 0xfa500000 0x0 0xfa500000 0 0x00300000>;
clocks = <&clkc CLKID_USB>, <&clkc CLKID_PCIE_B>, <&clkc CLKID_PCIE_CML_EN1>;
resets = <&reset RESET_PCIE_B>, <&reset RESET_PCIE_APB>;
num-lanes = <1>;
phys = <&pcie_phy>;
phy-names = "pcie";
usb: usb@ffe09080 {
compatible = "amlogic,meson-axg-usb-ctrl";
#size-cells = <2>;
ranges;
dr_mode = "otg";
dr_mode = "host";
- ethmac: ethernet@ff3f0000 { compatible = "amlogic,meson-axg-dwmac", "snps,dwmac-3.70a",
@@ -187,9 +280,19 @@ "timing-adjustment"; rx-fifo-depth = <4096>; tx-fifo-depth = <2048>;
power-domains = <&pwrc PWRC_AXG_ETHERNET_MEM_ID>; status = "disabled";
pcie_phy: phy@ff644000 {
compatible = "amlogic,axg-pcie-phy";
reg = <0x0 0xff644000 0x0 0x1c>;
resets = <&reset RESET_PCIE_PHY>;
phys = <&mipi_pcie_analog_dphy>;
phy-names = "analog";
#phy-cells = <0>;
pdm: audio-controller@ff632000 { compatible = "amlogic,axg-pdm"; reg = <0x0 0xff632000 0x0 0x34>;
@@ -1117,6 +1220,52 @@ clocks = <&xtal>; clock-names = "xtal"; };
pwrc: power-controller {
compatible = "amlogic,meson-axg-pwrc";
#power-domain-cells = <1>;
amlogic,ao-sysctrl = <&sysctrl_AO>;
resets = <&reset RESET_VIU>,
<&reset RESET_VENC>,
<&reset RESET_VCBUS>,
<&reset RESET_VENCL>,
<&reset RESET_VID_LOCK>;
reset-names = "viu", "venc", "vcbus",
"vencl", "vid_lock";
clocks = <&clkc CLKID_VPU>,
<&clkc CLKID_VAPB>;
clock-names = "vpu", "vapb";
* VPU clocking is provided by two identical clock paths
* VPU_0 and VPU_1 muxed to a single clock by a glitch
* free mux to safely change frequency while running.
* Same for VAPB but with a final gate after the glitch free mux.
assigned-clocks = <&clkc CLKID_VPU_0_SEL>,
<&clkc CLKID_VPU_0>,
<&clkc CLKID_VPU>, /* Glitch free mux */
<&clkc CLKID_VAPB_0_SEL>,
<&clkc CLKID_VAPB_0>,
<&clkc CLKID_VAPB_SEL>; /* Glitch free mux */
assigned-clock-parents = <&clkc CLKID_FCLK_DIV4>,
<0>, /* Do Nothing */
<&clkc CLKID_VAPB_0>;
assigned-clock-rates = <0>, /* Do Nothing */
<250000000>,
<250000000>,
<0>; /* Do Nothing */
mipi_pcie_analog_dphy: phy {
compatible = "amlogic,axg-mipi-pcie-analog-phy";
#phy-cells = <0>;
@@ -1129,6 +1278,19 @@ #mbox-cells = <1>; };
mipi_dphy: phy@ff640000 {
compatible = "amlogic,axg-mipi-dphy";
reg = <0x0 0xff640000 0x0 0x100>;
clocks = <&clkc CLKID_MIPI_DSI_PHY>;
clock-names = "pclk";
resets = <&reset RESET_MIPI_PHY>;
#phy-cells = <0>;
- audio: bus@ff642000 { compatible = "simple-bus"; reg = <0x0 0xff642000 0x0 0x2000>;
@@ -1563,6 +1725,14 @@ }; };
ge2d: ge2d@ff940000 {
compatible = "amlogic,axg-ge2d";
reg = <0x0 0xff940000 0x0 0x10000>;
interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>;
clocks = <&clkc CLKID_VAPB>;
resets = <&reset RESET_GE2D>;
- gic: interrupt-controller@ffc01000 { compatible = "arm,gic-400"; reg = <0x0 0xffc01000 0 0x1000>,
@@ -1701,6 +1871,7 @@ status = "disabled"; clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; clock-names = "xtal", "pclk", "baud";
};fifo-size = <128>; };
@@ -1734,6 +1905,16 @@ clock-names = "core", "clkin0", "clkin1"; resets = <&reset RESET_SD_EMMC_C>; };
#phy-cells = <0>;
sram: sram@fffc0000 {
diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi index 1e83ec5b8c..00c6f53290 100644 --- a/arch/arm/dts/meson-g12-common.dtsi +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -17,6 +17,12 @@ #address-cells = <2>; #size-cells = <2>;
- aliases {
mmc0 = &sd_emmc_b; /* SD card */
mmc1 = &sd_emmc_c; /* eMMC */
mmc2 = &sd_emmc_a; /* SDIO */
- chosen { #address-cells = <2>; #size-cells = <2>;
@@ -122,9 +128,9 @@
pcie: pcie@fc000000 { compatible = "amlogic,g12a-pcie", "snps,dw-pcie";
reg = <0x0 0xfc000000 0x0 0x400000
0x0 0xfc400000 0x0 0x200000>;
reg = <0x0 0xfc000000 0x0 0x400000>,
<0x0 0xfc400000 0x0 0x200000>; reg-names = "elbi", "cfg", "config"; interrupts = <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>; #interrupt-cells = <1>;
@@ -134,8 +140,8 @@ #address-cells = <3>; #size-cells = <2>; device_type = "pci";
ranges = <0x81000000 0 0 0x0 0xfc600000 0 0x00100000
0x82000000 0 0xfc700000 0x0 0xfc700000 0 0x1900000>;
ranges = <0x81000000 0 0 0x0 0xfc600000 0 0x00100000>,
<0x82000000 0 0xfc700000 0x0 0xfc700000 0 0x1900000>; clocks = <&clkc CLKID_PCIE_PHY &clkc CLKID_PCIE_COMB
@@ -209,7 +215,7 @@ };
compatible = "amlogic,meson-g12a-dwmac", "snps,dwmac-3.70a", "snps,dwmac"; reg = <0x0 0xff3f0000 0x0 0x10000>,
@@ -282,6 +288,8 @@ hwrng: rng@218 { compatible = "amlogic,meson-rng"; reg = <0x0 0x218 0x0 0x4>;
clocks = <&clkc CLKID_RNG0>;
clock-names = "core"; }; };
@@ -2001,7 +2009,7 @@ }; };
vrtc: rtc@0a8 {
vrtc: rtc@a8 { compatible = "amlogic,meson-vrtc"; reg = <0x0 0x000a8 0x0 0x4>; };
@@ -2179,6 +2187,12 @@ amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; };
watchdog: watchdog@f0d0 {
compatible = "amlogic,meson-gxbb-wdt";
reg = <0x0 0xf0d0 0x0 0x10>;
clocks = <&xtal>;
spicc0: spi@13000 { compatible = "amlogic,meson-g12a-spicc"; reg = <0x0 0x13000 0x0 0x44>;
@@ -2303,6 +2317,7 @@ clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; clock-names = "xtal", "pclk", "baud"; status = "disabled";
@@ -2380,7 +2395,7 @@ interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; dr_mode = "host"; snps,dis_u2_susphy_quirk;
snps,quirk-frame-length-adjustment;
};snps,quirk-frame-length-adjustment = <0x20>; snps,parkmode-disable-ss-quirk; };
diff --git a/arch/arm/dts/meson-g12a-sei510.dts b/arch/arm/dts/meson-g12a-sei510.dts index b00d0468c7..81269ccc24 100644 --- a/arch/arm/dts/meson-g12a-sei510.dts +++ b/arch/arm/dts/meson-g12a-sei510.dts @@ -181,7 +181,7 @@
model = "G12A-SEI510";
audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0",model = "SEI510";
diff --git a/arch/arm/dts/meson-g12b-gsking-x.dts b/arch/arm/dts/meson-g12b-gsking-x.dts new file mode 100644 index 0000000000..6c7bfacbad --- /dev/null +++ b/arch/arm/dts/meson-g12b-gsking-x.dts @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (c) 2019 BayLibre, SAS
- Author: Neil Armstrong narmstrong@baylibre.com
- Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com
+/dts-v1/;
+#include "meson-g12b-w400.dtsi" +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h>
- compatible = "azw,gsking-x", "amlogic,s922x", "amlogic,g12b";
- model = "Beelink GS-King X";
- aliases {
rtc0 = &rtc;
rtc1 = &vrtc;
- gpio-keys-polled {
compatible = "gpio-keys-polled";
#size-cells = <0>;
poll-interval = <100>;
power-button {
label = "power";
linux,code = <KEY_POWER>;
gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>;
- sound {
model = "GSKING-X";
audio-aux-devs = <&tdmout_a>;
audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 1",
"TDMOUT_A IN 1", "FRDDR_B OUT 1",
"TDMOUT_A IN 2", "FRDDR_C OUT 1",
"TDM_A Playback", "TDMOUT_A OUT";
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-link-3 {
sound-dai = <&tdmif_a>;
dai-format = "i2s";
mclk-fs = <256>;
codec {
sound-dai = <&tohdmitx TOHDMITX_I2S_IN_A>;
dai-link-4 {
codec {
+&arb {
- status = "okay";
+&clkc_audio {
- status = "okay";
+&frddr_a {
- status = "okay";
+&frddr_b {
- status = "okay";
+&frddr_c {
- status = "okay";
+&i2c3 {
- status = "okay";
- pinctrl-0 = <&i2c3_sda_a_pins>, <&i2c3_sck_a_pins>;
- rtc: rtc@51 {
reg = <0x51>;
wakeup-source;
+&tdmif_a {
- status = "okay";
+&tdmout_a {
- status = "okay";
+&tohdmitx {
- status = "okay";
+}; diff --git a/arch/arm/dts/meson-g12b-gtking-pro.dts b/arch/arm/dts/meson-g12b-gtking-pro.dts index f0c56a16af..707daf9278 100644 --- a/arch/arm/dts/meson-g12b-gtking-pro.dts +++ b/arch/arm/dts/meson-g12b-gtking-pro.dts @@ -11,9 +11,14 @@ #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
- compatible = "azw,gtking", "amlogic,g12b";
compatible = "azw,gtking", "amlogic,s922x", "amlogic,g12b"; model = "Beelink GT-King Pro";
aliases {
rtc0 = &rtc;
rtc1 = &vrtc;
gpio-keys-polled { compatible = "gpio-keys-polled"; #address-cells = <1>;
@@ -30,7 +35,7 @@ leds { compatible = "gpio-leds";
white {
led-white { label = "power:white"; gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; default-state = "on";
@@ -39,7 +44,7 @@
model = "G12B-GTKING-PRO";
audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1",model = "GTKING-PRO";
@@ -112,6 +117,18 @@ status = "okay"; };
+&i2c3 {
- status = "okay";
- rtc: rtc@51 {
reg = <0x51>;
wakeup-source;
&tdmif_b { status = "okay"; }; diff --git a/arch/arm/dts/meson-g12b-gtking.dts b/arch/arm/dts/meson-g12b-gtking.dts index eeb7bc5539..5d96c14490 100644 --- a/arch/arm/dts/meson-g12b-gtking.dts +++ b/arch/arm/dts/meson-g12b-gtking.dts @@ -11,9 +11,14 @@ #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
compatible = "azw,gtking", "amlogic,s922x", "amlogic,g12b"; model = "Beelink GT-King";
aliases {
rtc0 = &rtc;
rtc1 = &vrtc;
spdif_dit: audio-codec-1 { #sound-dai-cells = <0>; compatible = "linux,spdif-dit";
@@ -23,7 +28,7 @@
model = "G12B-GTKING";
audio-aux-devs = <&tdmout_b>; audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", "TDMOUT_B IN 1", "FRDDR_B OUT 1",model = "GTKING";
@@ -122,6 +127,19 @@ status = "okay"; };
+&i2c3 {
- status = "okay";
- rtc: rtc@51 {
reg = <0x51>;
wakeup-source;
&spdifout { pinctrl-0 = <&spdif_out_h_pins>; pinctrl-names = "default"; diff --git a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts index 5de2815ba9..ce1198ad34 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2-plus.dts +++ b/arch/arm/dts/meson-g12b-odroid-n2-plus.dts @@ -19,7 +19,7 @@ regulator-min-microvolt = <680000>; regulator-max-microvolt = <1040000>;
- pwms = <&pwm_AO_cd 1 1500 0>;
- pwms = <&pwm_ab 0 1500 0>;
&vddcpu_b { diff --git a/arch/arm/dts/meson-g12b-odroid-n2.dtsi b/arch/arm/dts/meson-g12b-odroid-n2.dtsi index 6982632ae6..344573e157 100644 --- a/arch/arm/dts/meson-g12b-odroid-n2.dtsi +++ b/arch/arm/dts/meson-g12b-odroid-n2.dtsi @@ -13,6 +13,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac;
rtc0 = &rtc;
rtc1 = &vrtc;
dioo2133: audio-amplifier-0 {
@@ -40,7 +42,7 @@ leds { compatible = "gpio-leds";
blue {
led-blue { label = "n2:blue"; gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat";
@@ -211,7 +213,7 @@
model = "G12B-ODROID-N2";
audio-widgets = "Line", "Lineout"; audio-aux-devs = <&tdmout_b>, <&tdmout_c>, <&tdmin_a>, <&tdmin_b>, <&tdmin_c>, <&tdmin_lb>,model = "ODROID-N2";
@@ -408,12 +410,12 @@
&ext_mdio { external_phy: ethernet-phy@0 {
reg = <0>; max-speed = <1000>;
reset-assert-us = <10000>;
reset-deassert-us = <30000>;
reset-deassert-us = <80000>;
reset-gpios = <&gpio GPIOZ_15 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>;
@@ -444,13 +446,58 @@ };
&gpio {
- gpio-line-names =
/* GPIOZ */
/* GPIOH */
/* BOOT */
/* GPIOC */
/* GPIOA */
"PIN_44", /* GPIOA_0 */
"PIN_46", /* GPIOA_1 */
"PIN_45", /* GPIOA_2 */
"PIN_47", /* GPIOA_3 */
"PIN_26", /* GPIOA_4 */
"PIN_42", /* GPIOA_11 */
"PIN_32", /* GPIOA_12 */
"PIN_7", /* GPIOA_13 */
/* GPIOX */
"PIN_33", /* GPIOX_5 */
"PIN_35", /* GPIOX_6 */
/*"PIN_36"; /* GPIOX_19 */
- WARNING: The USB Hub on the Odroid-N2 needs a reset signal
- to be turned high in order to be detected by the USB Controller
- This signal should be handled by a USB specific power sequence
- in order to reset the Hub when USB bus is powered down.
- usb-hub {
- hog-0 { gpio-hog; gpios = <GPIOH_4 GPIO_ACTIVE_HIGH>; output-high;
@@ -478,6 +525,18 @@ linux,rc-map-name = "rc-odroid"; };
+&i2c3 {
- status = "okay";
- rtc: rtc@51 {
reg = <0x51>;
wakeup-source;
&pwm_ab { pinctrl-0 = <&pwm_a_e_pins>; pinctrl-names = "default"; @@ -494,6 +553,11 @@ status = "okay"; };
+&saradc {
- status = "okay";
- vref-supply = <&vddao_1v8>;
/* SD card */ &sd_emmc_b { status = "okay"; diff --git a/arch/arm/dts/meson-g12b-w400.dtsi b/arch/arm/dts/meson-g12b-w400.dtsi index 2802ddbb83..feb0885047 100644 --- a/arch/arm/dts/meson-g12b-w400.dtsi +++ b/arch/arm/dts/meson-g12b-w400.dtsi @@ -264,7 +264,7 @@ max-speed = <1000>;
diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 9b8548e5f6..ee8fcae9f9 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -135,3 +135,7 @@ }; }; };
+&mali {
- dma-coherent;
+}; diff --git a/arch/arm/dts/meson-gx-libretech-pc.dtsi b/arch/arm/dts/meson-gx-libretech-pc.dtsi index c2480bab8d..2d7032f41e 100644 --- a/arch/arm/dts/meson-gx-libretech-pc.dtsi +++ b/arch/arm/dts/meson-gx-libretech-pc.dtsi @@ -186,7 +186,7 @@
sound { compatible = "amlogic,gx-sound-card";
model = "GXL-LIBRETECH-S9XX-PC";
audio-aux-devs = <&dio2133>; audio-widgets = "Speaker", "7J4-14 LEFT", "Speaker", "7J4-11 RIGHT";model = "LIBRETECH-PC";
diff --git a/arch/arm/dts/meson-gx-p23x-q20x.dtsi b/arch/arm/dts/meson-gx-p23x-q20x.dtsi index 6b57e15aad..dafc841f7c 100644 --- a/arch/arm/dts/meson-gx-p23x-q20x.dtsi +++ b/arch/arm/dts/meson-gx-p23x-q20x.dtsi @@ -121,7 +121,7 @@
model = "GX-P230-Q200";
audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLP",model = "P230-Q200";
diff --git a/arch/arm/dts/meson-gx.dtsi b/arch/arm/dts/meson-gx.dtsi index 0edd137151..6b457b2c30 100644 --- a/arch/arm/dts/meson-gx.dtsi +++ b/arch/arm/dts/meson-gx.dtsi @@ -20,6 +20,12 @@ #address-cells = <2>; #size-cells = <2>;
- aliases {
- reserved-memory { #address-cells = <2>; #size-cells = <2>;
@@ -295,6 +301,7 @@ reg = <0x0 0x84c0 0x0 0x18>; interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; status = "disabled";
fifo-size = <128>; }; uart_B: serial@84dc {
diff --git a/arch/arm/dts/meson-gxbb-nanopi-k2.dts b/arch/arm/dts/meson-gxbb-nanopi-k2.dts index 7be3e35409..7273eed529 100644 --- a/arch/arm/dts/meson-gxbb-nanopi-k2.dts +++ b/arch/arm/dts/meson-gxbb-nanopi-k2.dts @@ -7,6 +7,7 @@
#include "meson-gxbb.dtsi" #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "friendlyarm,nanopi-k2", "amlogic,meson-gxbb"; @@ -130,6 +131,45 @@ }; }; };
- sound {
model = "NANOPI-K2";
assigned-clocks = <&clkc CLKID_MPLL0>,
<&clkc CLKID_MPLL1>,
<&clkc CLKID_MPLL2>;
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
sound-dai = <&aiu AIU_CPU CPU_I2S_FIFO>;
dai-link-1 {
sound-dai = <&aiu AIU_CPU CPU_I2S_ENCODER>;
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
sound-dai = <&aiu AIU_HDMI CTRL_I2S>;
dai-link-2 {
sound-dai = <&aiu AIU_HDMI CTRL_OUT>;
codec-0 {
+&aiu {
- status = "okay";
&cec_AO { @@ -165,7 +205,7 @@ reg = <0>;
reset-deassert-us = <80000>; reset-gpios = <&gpio GPIOZ_14 GPIO_ACTIVE_LOW>; interrupt-parent = <&gpio_intc>;
diff --git a/arch/arm/dts/meson-gxbb-odroidc2.dts b/arch/arm/dts/meson-gxbb-odroidc2.dts index 70fcfb7b06..201596247f 100644 --- a/arch/arm/dts/meson-gxbb-odroidc2.dts +++ b/arch/arm/dts/meson-gxbb-odroidc2.dts @@ -9,6 +9,7 @@
/ { compatible = "hardkernel,odroid-c2", "amlogic,meson-gxbb"; @@ -172,6 +173,45 @@ }; }; };
- sound {
model = "ODROID-C2";
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
+&aiu {
- status = "okay";
&cec_AO { @@ -200,7 +240,7 @@ reg = <0>;
@@ -217,7 +257,7 @@ * This signal should be handled by a USB specific power sequence * in order to reset the Hub when USB bus is powered down. */
- usb-hub {
- hog-0 { gpio-hog; gpios = <GPIOAO_4 GPIO_ACTIVE_HIGH>; output-high;
diff --git a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts index 9e43f4dca9..2d769203f6 100644 --- a/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts +++ b/arch/arm/dts/meson-gxl-s805x-libretech-ac.dts @@ -118,7 +118,7 @@
model = "GXL-LIBRETECH-S805X-AC";
audio-widgets = "Speaker", "9J5-3 LEFT", "Speaker", "9J5-2 RIGHT"; audio-routing = "9J5-3 LEFT", "ACODEC LOLN",model = "LIBRETECH-AC";
diff --git a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts index 8bcdffdf55..60feac0179 100644 --- a/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts +++ b/arch/arm/dts/meson-gxl-s905x-khadas-vim.dts @@ -5,9 +5,9 @@
/dts-v1/;
-#include <dt-bindings/input/input.h>
#include "meson-gxl-s905x-p212.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim", "amlogic,s905x", "amlogic,meson-gxl"; @@ -42,10 +42,10 @@ }; };
- pwmleds {
- led-controller { compatible = "pwm-leds";
power {
led-1 { label = "vim:red:power"; pwms = <&pwm_AO_ab 1 7812500 0>; max-brightness = <255>;
@@ -63,6 +63,45 @@ }; }; };
- sound {
model = "KHADAS-VIM";
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
+&aiu {
- status = "okay";
&cec_AO { @@ -97,8 +136,7 @@ pinctrl-names = "default";
rtc: rtc@51 {
/* has to be enabled manually when a battery is connected: */
compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>;status = "okay";
diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts index 675eaa8796..93d8f8aff7 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc-v2.dts @@ -84,7 +84,6 @@ regulator-always-on; };
- vcck: regulator-vcck { compatible = "regulator-fixed"; regulator-name = "VCCK";
@@ -124,7 +123,6 @@ regulator-always-on; };
- vddio_card: regulator-vddio-card { compatible = "regulator-gpio"; regulator-name = "VDDIO_CARD";
@@ -161,7 +159,7 @@
model = "GXL-LIBRETECH-S905X-CC-V2";
assigned-clocks = <&clkc CLKID_MPLL0>, <&clkc CLKID_MPLL1>, <&clkc CLKID_MPLL2>;model = "LIBRETECH-CC-V2";
@@ -195,7 +193,6 @@ }; };
&aiu { status = "okay"; }; @@ -207,7 +204,6 @@ hdmi-phandle = <&hdmi_tx>; };
ðmac { status = "okay"; }; diff --git a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts index 5ae7bb6209..82bfabfbd3 100644 --- a/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts +++ b/arch/arm/dts/meson-gxl-s905x-libretech-cc.dts @@ -135,7 +135,7 @@
model = "GXL-LIBRETECH-S905X-CC";
audio-aux-devs = <&dio2133>; audio-widgets = "Line", "Lineout"; audio-routing = "AU2 INL", "ACODEC LOLN",model = "LIBRETECH-CC";
diff --git a/arch/arm/dts/meson-gxm-khadas-vim2.dts b/arch/arm/dts/meson-gxm-khadas-vim2.dts index bff8ec2c1c..18a4b7a6c5 100644 --- a/arch/arm/dts/meson-gxm-khadas-vim2.dts +++ b/arch/arm/dts/meson-gxm-khadas-vim2.dts @@ -7,9 +7,9 @@
/dts-v1/;
#include "meson-gxm.dtsi" +#include <dt-bindings/input/input.h> +#include <dt-bindings/sound/meson-aiu.h>
/ { compatible = "khadas,vim2", "amlogic,s912", "amlogic,meson-gxm"; @@ -81,10 +81,10 @@ }; };
- pwmleds {
power {
@@ -145,6 +145,45 @@ clock-frequency = <32768>; pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ };
- sound {
model = "KHADAS-VIM2";
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
dai-link-2 {
codec-0 {
+&aiu {
- status = "okay";
&cec_AO { @@ -154,7 +193,6 @@ hdmi-phandle = <&hdmi_tx>; };
&cpu_cooling_maps { map0 { cooling-device = <&gpio_fan THERMAL_NO_LIMIT 1>; @@ -194,7 +232,7 @@ reg = <0>;
@@ -228,8 +266,7 @@ pinctrl-names = "default";
rtc: rtc@51 {
@@ -341,7 +378,7 @@ #size-cells = <1>; compatible = "winbond,w25q16", "jedec,spi-nor"; reg = <0>;
spi-max-frequency = <3000000>;
};spi-max-frequency = <104000000>;
diff --git a/arch/arm/dts/meson-gxm-wetek-core2.dts b/arch/arm/dts/meson-gxm-wetek-core2.dts index ec794c134c..1e7f77f9b5 100644 --- a/arch/arm/dts/meson-gxm-wetek-core2.dts +++ b/arch/arm/dts/meson-gxm-wetek-core2.dts @@ -22,7 +22,7 @@ leds { compatible = "gpio-leds";
blue {
led-blue { color = <LED_COLOR_ID_BLUE>; function = LED_FUNCTION_STATUS; gpios = <&gpio GPIODV_24 GPIO_ACTIVE_HIGH>;
diff --git a/arch/arm/dts/meson-gxm.dtsi b/arch/arm/dts/meson-gxm.dtsi index fe41451122..411cc312fc 100644 --- a/arch/arm/dts/meson-gxm.dtsi +++ b/arch/arm/dts/meson-gxm.dtsi @@ -42,11 +42,28 @@ }; };
cpu0: cpu@0 {
capacity-dmips-mhz = <1024>;
cpu1: cpu@1 {
cpu2: cpu@2 {
cpu3: cpu@3 {
- cpu4: cpu@100 { device_type = "cpu"; compatible = "arm,cortex-a53"; reg = <0x0 0x100>; enable-method = "psci";
capacity-dmips-mhz = <1024>; next-level-cache = <&l2>; clocks = <&scpi_dvfs 1>; #cooling-cells = <2>;
@@ -57,6 +74,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x101>; enable-method = "psci";
@@ -67,6 +85,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x102>; enable-method = "psci";
@@ -77,6 +96,7 @@ compatible = "arm,cortex-a53"; reg = <0x0 0x103>; enable-method = "psci";
diff --git a/arch/arm/dts/meson-khadas-vim3.dtsi b/arch/arm/dts/meson-khadas-vim3.dtsi index 7b46555ac5..3cf4ecb6d5 100644 --- a/arch/arm/dts/meson-khadas-vim3.dtsi +++ b/arch/arm/dts/meson-khadas-vim3.dtsi @@ -6,6 +6,7 @@ */
#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> #include <dt-bindings/gpio/meson-g12a-gpio.h> #include <dt-bindings/sound/meson-g12a-tohdmitx.h>
@@ -13,6 +14,8 @@ aliases { serial0 = &uart_AO; ethernet0 = ðmac;
rtc0 = &rtc;
rtc1 = &vrtc;
chosen {
@@ -41,13 +44,15 @@ compatible = "gpio-leds";
led-white {
label = "vim3:white:sys";
color = <LED_COLOR_ID_WHITE>;
function = LED_FUNCTION_STATUS; gpios = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat";
led-red {
label = "vim3:red";
color = <LED_COLOR_ID_RED>;
}; };function = LED_FUNCTION_STATUS; gpios = <&gpio_expander 5 GPIO_ACTIVE_HIGH>;
@@ -165,12 +170,17 @@
model = "G12B-KHADAS-VIM3";
model = "KHADAS-VIM3";
audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0", "TDMOUT_A IN 1", "FRDDR_B OUT 0", "TDMOUT_A IN 2", "FRDDR_C OUT 0",audio-aux-devs = <&tdmin_a>, <&tdmout_a>;
"TDM_A Playback", "TDMOUT_A OUT",
"TDMIN_A IN 0", "TDM_A Capture",
"TDMIN_A IN 3", "TDM_A Loopback",
"TODDR_A IN 0", "TDMIN_A OUT",
"TODDR_B IN 0", "TDMIN_A OUT",
"TODDR_C IN 0", "TDMIN_A OUT";
assigned-clocks = <&clkc CLKID_MPLL2>, <&clkc CLKID_MPLL0>,
@@ -193,8 +203,20 @@ sound-dai = <&frddr_c>; };
dai-link-3 {/* 8ch hdmi interface */
sound-dai = <&toddr_a>;
dai-link-4 {
sound-dai = <&toddr_b>;
dai-link-5 {
sound-dai = <&toddr_c>;
dai-link-6 { sound-dai = <&tdmif_a>; dai-format = "i2s"; dai-tdm-slot-tx-mask-0 = <1 1>;
@@ -209,7 +231,7 @@ };
/* hdmi glue */
dai-link-4 {
dai-link-7 { sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; codec {
@@ -278,12 +300,12 @@ };
ðmac {
status = "okay";
phy-mode = "rgmii";
- pinctrl-0 = <ð_pins>, <ð_rgmii_pins>;
- pinctrl-names = "default";
- status = "okay";
- phy-mode = "rgmii";
- phy-handle = <&external_phy>;
- amlogic,tx-delay-ns = <2>;
&frddr_a { @@ -330,7 +352,7 @@ #gpio-cells = <2>; };
- rtc@51 {
- rtc: rtc@51 { compatible = "haoyu,hym8563"; reg = <0x51>; #clock-cells = <0>;
@@ -349,9 +371,9 @@ };
&pwm_ef {
status = "okay";
pinctrl-0 = <&pwm_e_pins>;
- status = "okay";
- pinctrl-0 = <&pwm_e_pins>;
&saradc { @@ -445,15 +467,30 @@ }; };
&tdmif_a { status = "okay"; };
+&tdmin_a {
- status = "okay";
&tdmout_a { status = "okay"; };
+&toddr_a {
- status = "okay";
+&toddr_b {
- status = "okay";
+&toddr_c {
- status = "okay";
&tohdmitx { status = "okay"; }; diff --git a/arch/arm/dts/meson-sm1-bananapi-m5.dts b/arch/arm/dts/meson-sm1-bananapi-m5.dts new file mode 100644 index 0000000000..effaa138b5 --- /dev/null +++ b/arch/arm/dts/meson-sm1-bananapi-m5.dts @@ -0,0 +1,646 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (c) 2021 BayLibre SAS
+/dts-v1/;
+#include "meson-sm1.dtsi" +#include <dt-bindings/leds/common.h> +#include <dt-bindings/input/linux-event-codes.h> +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/sound/meson-g12a-toacodec.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h>
- compatible = "bananapi,bpi-m5", "amlogic,sm1";
- model = "Banana Pi BPI-M5";
- adc_keys {
compatible = "adc-keys";
io-channels = <&saradc 2>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1800000>;
key {
label = "SW3";
linux,code = <BTN_3>;
press-threshold-microvolt = <1700000>;
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
stdout-path = "serial0:115200n8";
- /* TOFIX: handle CVBS_DET on SARADC channel 0 */
- cvbs-connector {
compatible = "composite-video-connector";
port {
cvbs_connector_in: endpoint {
remote-endpoint = <&cvbs_vdac_out>;
- emmc_pwrseq: emmc-pwrseq {
compatible = "mmc-pwrseq-emmc";
reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>;
- gpio-keys {
compatible = "gpio-keys";
key {
label = "SW1";
linux,code = <BTN_1>;
gpios = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_LOW>;
interrupts = <3 IRQ_TYPE_EDGE_BOTH>;
- hdmi-connector {
type = "a";
port {
- leds {
green {
color = <LED_COLOR_ID_GREEN>;
gpios = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_LOW>;
blue {
gpios = <&gpio_ao GPIOAO_11 GPIO_ACTIVE_LOW>;
- memory@0 {
device_type = "memory";
reg = <0x0 0x0 0x0 0x40000000>;
- emmc_1v8: regulator-emmc_1v8 {
regulator-name = "EMMC_1V8";
- dc_in: regulator-dc_in {
regulator-name = "DC_IN";
- vddio_c: regulator-vddio_c {
regulator-name = "VDDIO_C";
enable-gpio = <&gpio GPIOE_2 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpios = <&gpio_ao GPIOAO_6 GPIO_OPEN_DRAIN>;
gpios-states = <1>;
states = <1800000 0>,
<3300000 1>;
- tflash_vdd: regulator-tflash_vdd {
regulator-name = "TFLASH_VDD";
vin-supply = <&dc_in>;
gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>;
enable-active-high;
- vddao_1v8: regulator-vddao_1v8 {
- vddao_3v3: regulator-vddao_3v3 {
- vddcpu: regulator-vddcpu {
* SY8120B1ABC DC/DC Regulator.
compatible = "pwm-regulator";
regulator-name = "VDDCPU";
regulator-min-microvolt = <690000>;
regulator-max-microvolt = <1050000>;
pwms = <&pwm_AO_cd 1 1250 0>;
pwm-dutycycle-range = <100 0>;
regulator-boot-on;
- /* USB Hub Power Enable */
- vl_pwr_en: regulator-vl_pwr_en {
regulator-name = "VL_PWR_EN";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>;
enable-active-high;
- sound {
model = "BPI-M5";
<&tdmin_a>, <&tdmin_b>, <&tdmin_c>;
"TDM_B Playback", "TDMOUT_B OUT",
"TDMOUT_C IN 0", "FRDDR_A OUT 2",
"TDMOUT_C IN 1", "FRDDR_B OUT 2",
"TDMOUT_C IN 2", "FRDDR_C OUT 2",
"TDM_C Playback", "TDMOUT_C OUT",
"TDMIN_A IN 4", "TDM_B Loopback",
"TDMIN_B IN 4", "TDM_B Loopback",
"TDMIN_C IN 4", "TDM_B Loopback",
"TDMIN_A IN 5", "TDM_C Loopback",
"TDMIN_B IN 5", "TDM_C Loopback",
"TDMIN_C IN 5", "TDM_C Loopback",
"TODDR_C IN 0", "TDMIN_A OUT",
"TODDR_A IN 1", "TDMIN_B OUT",
"TODDR_B IN 1", "TDMIN_B OUT",
"TODDR_C IN 1", "TDMIN_B OUT",
"TODDR_A IN 2", "TDMIN_C OUT",
"TODDR_B IN 2", "TDMIN_C OUT",
"TODDR_C IN 2", "TDMIN_C OUT",
"Lineout", "ACODEC LOLP",
"Lineout", "ACODEC LORP";
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-link-3 {
dai-link-4 {
dai-link-5 {
dai-link-6 {
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
codec-1 {
sound-dai = <&toacodec TOACODEC_IN_B>;
/* i2s jack output interface */
dai-link-7 {
sound-dai = <&tdmif_c>;
dai-format = "i2s";
mclk-fs = <256>;
codec-0 {
sound-dai = <&tohdmitx TOHDMITX_I2S_IN_C>;
codec-1 {
sound-dai = <&toacodec TOACODEC_IN_C>;
/* hdmi glue */
dai-link-8 {
codec {
/* acodec glue */
dai-link-9 {
sound-dai = <&toacodec TOACODEC_OUT>;
codec {
sound-dai = <&acodec>;
+&acodec {
- AVDD-supply = <&vddao_1v8>;
- status = "okay";
+&arb {
- status = "okay";
+&clkc_audio {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vddcpu>;
- operating-points-v2 = <&cpu_opp_table>;
- clocks = <&clkc CLKID_CPU_CLK>;
- clock-latency = <50000>;
+&cpu1 {
- clocks = <&clkc CLKID_CPU1_CLK>;
+&cpu2 {
- clocks = <&clkc CLKID_CPU2_CLK>;
+&cpu3 {
- clocks = <&clkc CLKID_CPU3_CLK>;
+&cvbs_vdac_port {
- cvbs_vdac_out: endpoint {
remote-endpoint = <&cvbs_connector_in>;
+&ext_mdio {
- external_phy: ethernet-phy@0 {
reg = <0>;
max-speed = <1000>;
+ðmac {
- status = "okay";
- phy-mode = "rgmii-txid";
+&frddr_a {
- status = "okay";
+&frddr_b {
- status = "okay";
+&frddr_c {
- status = "okay";
+&gpio {
- gpio-line-names =
/* GPIOZ */
"ETH_MDIO", /* GPIOZ_0 */
"ETH_MDC", /* GPIOZ_1 */
"ETH_RXCLK", /* GPIOZ_2 */
"ETH_RX_DV", /* GPIOZ_3 */
"ETH_RXD0", /* GPIOZ_4 */
"ETH_RXD1", /* GPIOZ_5 */
"ETH_RXD2", /* GPIOZ_6 */
"ETH_RXD3", /* GPIOZ_7 */
"ETH_TXCLK", /* GPIOZ_8 */
"ETH_TXEN", /* GPIOZ_9 */
"ETH_TXD0", /* GPIOZ_10 */
"ETH_TXD1", /* GPIOZ_11 */
"ETH_TXD2", /* GPIOZ_12 */
"ETH_TXD3", /* GPIOZ_13 */
"ETH_INTR", /* GPIOZ_14 */
"ETH_NRST", /* GPIOZ_15 */
/* GPIOH */
"HDMI_SDA", /* GPIOH_0 */
"HDMI_SCL", /* GPIOH_1 */
"HDMI_HPD", /* GPIOH_2 */
"HDMI_CEC", /* GPIOH_3 */
"VL-RST_N", /* GPIOH_4 */
"CON1-P36", /* GPIOH_5 */
"VL-PWREN", /* GPIOH_6 */
"WiFi_3V3_1V8", /* GPIOH_7 */
"TFLASH_VDD_EN", /* GPIOH_8 */
/* BOOT */
"eMMC_D0", /* BOOT_0 */
"eMMC_D1", /* BOOT_1 */
"eMMC_D2", /* BOOT_2 */
"eMMC_D3", /* BOOT_3 */
"eMMC_D4", /* BOOT_4 */
"eMMC_D5", /* BOOT_5 */
"eMMC_D6", /* BOOT_6 */
"eMMC_D7", /* BOOT_7 */
"eMMC_CLK", /* BOOT_8 */
"eMMC_CMD", /* BOOT_10 */
"eMMC_RST#", /* BOOT_12 */
"eMMC_DS", /* BOOT_13 */
/* GPIOC */
"SD_D0_B", /* GPIOC_0 */
"SD_D1_B", /* GPIOC_1 */
"SD_D2_B", /* GPIOC_2 */
"SD_D3_B", /* GPIOC_3 */
"SD_CLK_B", /* GPIOC_4 */
"SD_CMD_B", /* GPIOC_5 */
"CARD_EN_DET", /* GPIOC_6 */
/* GPIOA */
"CON1-P27", /* GPIOA_14 */
"CON1-P28", /* GPIOA_15 */
/* GPIOX */
"CON1-P16", /* GPIOX_0 */
"CON1-P18", /* GPIOX_1 */
"CON1-P22", /* GPIOX_2 */
"CON1-P11", /* GPIOX_3 */
"CON1-P13", /* GPIOX_4 */
"CON1-P07", /* GPIOX_5 */
"CON1-P33", /* GPIOX_6 */
"CON1-P15", /* GPIOX_7 */
"CON1-P19", /* GPIOX_8 */
"CON1-P21", /* GPIOX_9 */
"CON1-P24", /* GPIOX_10 */
"CON1-P23", /* GPIOX_11 */
"CON1-P08", /* GPIOX_12 */
"CON1-P10", /* GPIOX_13 */
"CON1-P29", /* GPIOX_14 */
"CON1-P31", /* GPIOX_15 */
"CON1-P26", /* GPIOX_16 */
"CON1-P03", /* GPIOX_17 */
"CON1-P05", /* GPIOX_18 */
"CON1-P32"; /* GPIOX_19 */
* WARNING: The USB Hub on the BPI-M5 needs a reset signal
* to be turned high in order to be detected by the USB Controller
- usb-hub {
gpio-hog;
output-high;
line-name = "usb-hub-reset";
+&gpio_ao {
- gpio-line-names =
/* GPIOAO */
"DEBUG TX", /* GPIOAO_0 */
"DEBUG RX", /* GPIOAO_1 */
"SYS_LED2", /* GPIOAO_2 */
"UPDATE_KEY", /* GPIOAO_3 */
"CON1-P40", /* GPIOAO_4 */
"IR_IN", /* GPIOAO_5 */
"TF_3V3N_1V8_EN", /* GPIOAO_6 */
"CON1-P35", /* GPIOAO_7 */
"CON1-P12", /* GPIOAO_8 */
"CON1-P37", /* GPIOAO_9 */
"CON1-P38", /* GPIOAO_10 */
"SYS_LED", /* GPIOAO_11 */
/* GPIOE */
"VDDEE_PWM", /* GPIOE_0 */
"VDDCPU_PWM", /* GPIOE_1 */
"TF_PWR_EN"; /* GPIOE_2 */
+&hdmi_tx {
- status = "okay";
- pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>;
- hdmi-supply = <&dc_in>;
+&hdmi_tx_tmds_port {
- hdmi_tx_tmds_out: endpoint {
remote-endpoint = <&hdmi_connector_in>;
+&ir {
- status = "okay";
- pinctrl-0 = <&remote_input_ao_pins>;
+&pwm_AO_cd {
- pinctrl-0 = <&pwm_ao_d_e_pins>;
- clocks = <&xtal>;
- clock-names = "clkin1";
- status = "okay";
+&saradc {
- status = "okay";
+/* SD card */ +&sd_emmc_b {
- status = "okay";
- pinctrl-0 = <&sdcard_c_pins>;
- pinctrl-1 = <&sdcard_clk_gate_c_pins>;
- pinctrl-names = "default", "clk-gate";
- bus-width = <4>;
- cap-sd-highspeed;
- max-frequency = <50000000>;
- disable-wp;
- /* TOFIX: SD card is barely usable in SDR modes */
- cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>;
- vmmc-supply = <&tflash_vdd>;
- vqmmc-supply = <&vddio_c>;
+/* eMMC */ +&sd_emmc_c {
- status = "okay";
- pinctrl-0 = <&emmc_ctrl_pins>, <&emmc_data_8b_pins>, <&emmc_ds_pins>;
- pinctrl-1 = <&emmc_clk_gate_pins>;
- bus-width = <8>;
- cap-mmc-highspeed;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- max-frequency = <200000000>;
- disable-wp;
- mmc-pwrseq = <&emmc_pwrseq>;
- vmmc-supply = <&vddao_3v3>;
- vqmmc-supply = <&emmc_1v8>;
+&tdmif_b {
- status = "okay";
+&tdmif_c {
- status = "okay";
+&tdmin_a {
- status = "okay";
+&tdmin_b {
- status = "okay";
+&tdmin_c {
- status = "okay";
+&tdmout_b {
- status = "okay";
+&tdmout_c {
- status = "okay";
+&toacodec {
- status = "okay";
+&tohdmitx {
- status = "okay";
+&toddr_a {
- status = "okay";
+&toddr_b {
- status = "okay";
+&toddr_c {
- status = "okay";
+&uart_AO {
- status = "okay";
- pinctrl-0 = <&uart_ao_a_pins>;
+&usb {
- status = "okay";
+&usb2_phy0 {
- phy-supply = <&dc_in>;
+&usb2_phy1 {
- /* Enable the hub which is connected to this port */
- phy-supply = <&vl_pwr_en>;
+}; diff --git a/arch/arm/dts/meson-sm1-khadas-vim3l.dts b/arch/arm/dts/meson-sm1-khadas-vim3l.dts index 4b517ca720..f2c0981435 100644 --- a/arch/arm/dts/meson-sm1-khadas-vim3l.dts +++ b/arch/arm/dts/meson-sm1-khadas-vim3l.dts @@ -32,6 +32,19 @@ regulator-boot-on; regulator-always-on; };
- sound {
model = "G12B-KHADAS-VIM3L";
"TDMIN_A IN 13", "TDM_A Loopback",
&cpu0 { @@ -89,13 +102,12 @@ status = "okay"; };
-&sd_emmc_a {
- sd-uhs-sdr50;
&usb { phys = <&usb2_phy0>, <&usb2_phy1>; phy-names = "usb2-phy0", "usb2-phy1"; }; */
+&sd_emmc_a {
- sd-uhs-sdr50;
+}; diff --git a/arch/arm/dts/meson-sm1-odroid-c4.dts b/arch/arm/dts/meson-sm1-odroid-c4.dts index cf5a98f0e4..8c30ce6368 100644 --- a/arch/arm/dts/meson-sm1-odroid-c4.dts +++ b/arch/arm/dts/meson-sm1-odroid-c4.dts @@ -5,34 +5,12 @@
/dts-v1/;
-#include "meson-sm1.dtsi" -#include <dt-bindings/gpio/meson-g12a-gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/sound/meson-g12a-tohdmitx.h> +#include "meson-sm1-odroid.dtsi"
/ { compatible = "hardkernel,odroid-c4", "amlogic,sm1"; model = "Hardkernel ODROID-C4";
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
- leds { compatible = "gpio-leds";
@@ -45,324 +23,19 @@ }; };
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio_ao GPIOAO_3 GPIO_ACTIVE_HIGH>;
enable-active-high;
- tf_io: gpio-regulator-tf_io {
regulator-name = "TF_IO";
regulator-min-microvolt = <1800000>;
gpios = <&gpio_ao GPIOAO_6 GPIO_ACTIVE_HIGH>;
gpios-states = <0>;
states = <3300000 0>,
<1800000 1>;
- flash_1v8: regulator-flash_1v8 {
regulator-name = "FLASH_1V8";
regulator-max-microvolt = <1800000>;
vin-supply = <&vcc_3v3>;
- main_12v: regulator-main_12v {
regulator-name = "12V";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- vcc_5v: regulator-vcc_5v {
regulator-name = "5V";
vin-supply = <&main_12v>;
- vcc_1v8: regulator-vcc_1v8 {
regulator-name = "VCC_1V8";
- vcc_3v3: regulator-vcc_3v3 {
regulator-name = "VCC_3V3";
vin-supply = <&vddao_3v3>;
/* FIXME: actually controlled by VDDCPU_B_EN */
* MP8756GD Regulator.
regulator-min-microvolt = <721000>;
regulator-max-microvolt = <1022000>;
regulator-boot-on;
- hub_5v: regulator-hub_5v {
regulator-name = "HUB_5V";
vin-supply = <&vcc_5v>;
/* Connected to the Hub CHIPENABLE, LOW sets low power state */
gpio = <&gpio GPIOH_4 GPIO_ACTIVE_HIGH>;
enable-active-high;
- usb_pwr_en: regulator-usb_pwr_en {
regulator-name = "USB_PWR_EN";
/* Connected to the microUSB port power enable */
gpio = <&gpio_ao GPIOAO_2 GPIO_ACTIVE_HIGH>;
enable-active-high;
regulator-name = "VDDAO_1V8";
regulator-name = "VDDAO_3V3";
- hdmi-connector {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_connector_in: endpoint {
remote-endpoint = <&hdmi_tx_tmds_out>;
- sound {
compatible = "amlogic,axg-sound-card";
model = "SM1-ODROID-C4";
"TDMOUT_B IN 2", "FRDDR_C OUT 1",
"TDM_B Playback", "TDMOUT_B OUT";
<&clkc CLKID_MPLL1>;
assigned-clock-parents = <0>, <0>, <0>;
assigned-clock-rates = <294912000>,
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
sound-dai = <&frddr_a>;
dai-link-1 {
sound-dai = <&frddr_b>;
dai-link-2 {
dai-link-3 {
sound-dai = <&tdmif_b>;
dai-format = "i2s";
dai-tdm-slot-tx-mask-1 = <1 1>;
dai-tdm-slot-tx-mask-2 = <1 1>;
dai-tdm-slot-tx-mask-3 = <1 1>;
mclk-fs = <256>;
codec {
sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>;
/* hdmi glue */
dai-link-4 {
codec {
sound-dai = <&hdmi_tx>;
-&arb {
- status = "okay";
-&clkc_audio {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&ext_mdio {
/* Realtek RTL8211F (0x001cc916) */
reg = <0>;
max-speed = <1000>;
/* MAC_INTR on GPIOZ_14 */
interrupts = <26 IRQ_TYPE_LEVEL_LOW>;
};model = "ODROID-C4";
-ðmac {
- status = "okay";
-&frddr_a {
- status = "okay";
-&frddr_b {
- status = "okay";
-&frddr_c {
- status = "okay";
&gpio {
- gpio-line-names =
/* GPIOZ */
/* GPIOH */
"PIN_36", /* GPIOH_5 */
"PIN_26", /* GPIOH_6 */
"PIN_32", /* GPIOH_7 */
/* BOOT */
/* GPIOC */
/* GPIOA */
"PIN_27", /* GPIOA_14 */
"PIN_28", /* GPIOA_15 */
/* GPIOX */
"PIN_16", /* GPIOX_0 */
"PIN_18", /* GPIOX_1 */
"PIN_22", /* GPIOX_2 */
"PIN_11", /* GPIOX_3 */
"PIN_13", /* GPIOX_4 */
"PIN_7", /* GPIOX_5 */
"PIN_33", /* GPIOX_6 */
"PIN_15", /* GPIOX_7 */
"PIN_19", /* GPIOX_8 */
"PIN_21", /* GPIOX_9 */
"PIN_24", /* GPIOX_10 */
"PIN_23", /* GPIOX_11 */
"PIN_8", /* GPIOX_12 */
"PIN_10", /* GPIOX_13 */
"PIN_29", /* GPIOX_14 */
"PIN_31", /* GPIOX_15 */
"PIN_12", /* GPIOX_16 */
"PIN_3", /* GPIOX_17 */
"PIN_5", /* GPIOX_18 */
"PIN_35"; /* GPIOX_19 */
- WARNING: The USB Hub on the Odroid-C4 needs a reset signal
- usb-hub {
@@ -370,121 +43,6 @@ }; };
-&gpio_ao {
- gpio-line-names =
/* GPIOAO */
"PIN_47", /* GPIOAO_4 */
"PIN_45", /* GPIOAO_7 */
"PIN_46", /* GPIOAO_8 */
"PIN_44", /* GPIOAO_9 */
"PIN_42", /* GPIOAO_10 */
/* GPIOE */
-&hdmi_tx {
- status = "okay";
- hdmi-supply = <&vcc_5v>;
-&hdmi_tx_tmds_port {
&ir {
- status = "okay";
- pinctrl-names = "default"; linux,rc-map-name = "rc-odroid";
-&pwm_AO_cd {
- clocks = <&xtal>;
- status = "okay";
-&saradc {
- status = "okay";
-/* SD card */ -&sd_emmc_b {
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- disable-wp;
- vqmmc-supply = <&tf_io>;
-/* eMMC */ -&sd_emmc_c {
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- disable-wp;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&flash_1v8>;
-&tdmif_b {
- status = "okay";
-&tdmout_b {
- status = "okay";
-&tohdmitx {
- status = "okay";
-&uart_AO {
- status = "okay";
-&usb {
- status = "okay";
- vbus-supply = <&usb_pwr_en>;
-&usb2_phy0 {
- phy-supply = <&vcc_5v>;
-&usb2_phy1 {
- phy-supply = <&hub_5v>;
-}; diff --git a/arch/arm/dts/meson-sm1-odroid-hc4.dts b/arch/arm/dts/meson-sm1-odroid-hc4.dts new file mode 100644 index 0000000000..f3f953225b --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid-hc4.dts @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
- Copyright (c) 2020 Dongjin Kim tobetter@gmail.com
+/dts-v1/;
- compatible = "hardkernel,odroid-hc4", "amlogic,sm1";
- model = "Hardkernel ODROID-HC4";
- aliases {
rtc0 = &rtc;
rtc1 = &vrtc;
- fan0: pwm-fan {
compatible = "pwm-fan";
cooling-min-state = <0>;
cooling-max-state = <3>;
cooling-levels = <0 120 170 220>;
pwms = <&pwm_cd 1 40000 0>;
- leds {
led-blue {
panic-indicator;
led-red {
function = LED_FUNCTION_POWER;
gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_HIGH>;
- /* Powers the SATA Disk 0 regulator, which is enabled when a disk load is detected */
- p12v_0: regulator-p12v_0 {
regulator-name = "P12V_0";
enable-active-high;
- /* Powers the SATA Disk 1 regulator, which is enabled when a disk load is detected */
- p12v_1: regulator-p12v_1 {
regulator-name = "P12V_1";
enable-active-high;
- sound {
model = "ODROID-HC4";
+&cpu_thermal {
- cooling-maps {
map {
trip = <&cpu_passive>;
cooling-device = <&fan0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
+&ir {
- linux,rc-map-name = "rc-odroid";
+&i2c2 {
- status = "okay";
- pinctrl-0 = <&i2c2_sda_x_pins>, <&i2c2_sck_x_pins>;
- rtc: rtc@51 {
status = "okay";
compatible = "nxp,pcf8563";
reg = <0x51>;
wakeup-source;
+&pcie {
- status = "okay";
- reset-gpios = <&gpio GPIOH_4 GPIO_ACTIVE_LOW>;
+&pwm_cd {
- status = "okay";
- pinctrl-0 = <&pwm_d_x6_pins>;
+&sd_emmc_c {
- status = "disabled";
+&spifc {
- status = "okay";
- pinctrl-0 = <&nor_pins>;
- spi-flash@0 {
#size-cells = <1>;
compatible = "jedec,spi-nor";
reg = <0>;
+&usb {
- phys = <&usb2_phy1>;
- phy-names = "usb2-phy1";
+&usb2_phy0 {
+}; diff --git a/arch/arm/dts/meson-sm1-odroid.dtsi b/arch/arm/dts/meson-sm1-odroid.dtsi new file mode 100644 index 0000000000..fd0ad85c16 --- /dev/null +++ b/arch/arm/dts/meson-sm1-odroid.dtsi @@ -0,0 +1,449 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/*
+#include "meson-sm1.dtsi" +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h>
- aliases {
serial0 = &uart_AO;
ethernet0 = ðmac;
- chosen {
- memory@0 {
enable-active-high;
enable-active-high;
gpios = <&gpio_ao GPIOAO_6 GPIO_OPEN_SOURCE>;
gpios-states = <0>;
<1800000 1>;
enable-active-high;
regulator-boot-on;
enable-active-high;
- hdmi-connector {
type = "a";
port {
- sound {
<270950400>,
<393216000>;
status = "okay";
dai-link-0 {
dai-link-1 {
dai-link-2 {
dai-link-3 {
dai-format = "i2s";
mclk-fs = <256>;
codec {
/* hdmi glue */
dai-link-4 {
codec {
+&arb {
- status = "okay";
+&clkc_audio {
- status = "okay";
+&cpu0 {
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&ext_mdio {
reg = <0>;
max-speed = <1000>;
+ðmac {
- status = "okay";
+&frddr_a {
- status = "okay";
+&frddr_b {
- status = "okay";
+&frddr_c {
- status = "okay";
+&gpio {
- gpio-line-names =
/* GPIOZ */
/* GPIOH */
/* BOOT */
/* GPIOC */
/* GPIOA */
/* GPIOX */
+&gpio_ao {
- gpio-line-names =
/* GPIOAO */
/* GPIOE */
+&hdmi_tx {
- status = "okay";
+&ir {
- status = "okay";
+&pwm_AO_cd {
- clocks = <&xtal>;
- status = "okay";
+&saradc {
- status = "okay";
- status = "okay";
- bus-width = <4>;
- cap-sd-highspeed;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- disable-wp;
- status = "okay";
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- disable-wp;
+&tdmif_b {
- status = "okay";
+&tdmout_b {
- status = "okay";
+&tohdmitx {
- status = "okay";
+&uart_AO {
- status = "okay";
+&usb {
- status = "okay";
+&usb2_phy0 {
diff --git a/arch/arm/dts/meson-sm1-sei610.dts b/arch/arm/dts/meson-sm1-sei610.dts index 5ab139a34c..2194a77897 100644 --- a/arch/arm/dts/meson-sm1-sei610.dts +++ b/arch/arm/dts/meson-sm1-sei610.dts @@ -101,20 +101,20 @@ }; };
- leds {
- led-controller-1 { compatible = "gpio-leds";
led-bluetooth {
}; };led-1 { label = "sei610:blue:bt"; gpios = <&gpio GPIOC_7 (GPIO_ACTIVE_LOW | GPIO_OPEN_DRAIN)>; default-state = "off";
- pwmleds {
- led-controller-2 { compatible = "pwm-leds";
power {
led-2 { label = "sei610:red:power"; pwms = <&pwm_AO_ab 0 30518 0>; max-brightness = <255>;
@@ -220,7 +220,7 @@
sound { compatible = "amlogic,axg-sound-card";
model = "SM1-SEI610";
audio-aux-devs = <&tdmout_a>, <&tdmout_b>, <&tdmin_a>, <&tdmin_b>; audio-routing = "TDMOUT_A IN 0", "FRDDR_A OUT 0",model = "SEI610";
diff --git a/arch/arm/dts/meson-sm1.dtsi b/arch/arm/dts/meson-sm1.dtsi index 71317f5aad..3d8b1f4f20 100644 --- a/arch/arm/dts/meson-sm1.dtsi +++ b/arch/arm/dts/meson-sm1.dtsi @@ -130,7 +130,7 @@ opp-microvolt = <790000>; };
opp-1512000000 {
};opp-1500000000 { opp-hz = /bits/ 64 <1500000000>; opp-microvolt = <800000>;
@@ -401,6 +401,16 @@ status = "disabled"; };
toacodec: audio-controller@740 {
compatible = "amlogic,sm1-toacodec",
"amlogic,g12a-toacodec";
reg = <0x0 0x740 0x0 0x4>;
#sound-dai-cells = <1>;
sound-name-prefix = "TOACODEC";
resets = <&clkc_audio AUD_RESET_TOACODEC>;
- tohdmitx: audio-controller@744 { compatible = "amlogic,sm1-tohdmitx", "amlogic,g12a-tohdmitx";
diff --git a/include/dt-bindings/clock/axg-clkc.h b/include/dt-bindings/clock/axg-clkc.h index fd1f938c38..93752ea107 100644 --- a/include/dt-bindings/clock/axg-clkc.h +++ b/include/dt-bindings/clock/axg-clkc.h @@ -70,7 +70,31 @@ #define CLKID_HIFI_PLL 69 #define CLKID_PCIE_CML_EN0 79 #define CLKID_PCIE_CML_EN1 80 -#define CLKID_MIPI_ENABLE 81 #define CLKID_GEN_CLK 84 +#define CLKID_VPU_0_SEL 92 +#define CLKID_VPU_0 93 +#define CLKID_VPU_1_SEL 95 +#define CLKID_VPU_1 96 +#define CLKID_VPU 97 +#define CLKID_VAPB_0_SEL 99 +#define CLKID_VAPB_0 100 +#define CLKID_VAPB_1_SEL 102 +#define CLKID_VAPB_1 103 +#define CLKID_VAPB_SEL 104 +#define CLKID_VAPB 105 +#define CLKID_VCLK 106 +#define CLKID_VCLK2 107 +#define CLKID_VCLK_DIV1 122 +#define CLKID_VCLK_DIV2 123 +#define CLKID_VCLK_DIV4 124 +#define CLKID_VCLK_DIV6 125 +#define CLKID_VCLK_DIV12 126 +#define CLKID_VCLK2_DIV1 127 +#define CLKID_VCLK2_DIV2 128 +#define CLKID_VCLK2_DIV4 129 +#define CLKID_VCLK2_DIV6 130 +#define CLKID_VCLK2_DIV12 131 +#define CLKID_CTS_ENCL 133 +#define CLKID_VDIN_MEAS 136
#endif /* __AXG_CLKC_H */ diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index 40d49940d8..a93b58c5e1 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -147,5 +147,7 @@ #define CLKID_SPICC1_SCLK 261 #define CLKID_NNA_AXI_CLK 264 #define CLKID_NNA_CORE_CLK 267 +#define CLKID_MIPI_DSI_PXCLK_SEL 269 +#define CLKID_MIPI_DSI_PXCLK 270
#endif /* __G12A_CLKC_H */
Applied to u-boot-amlogic-next
Neil
Neil Armstrong
Vyacheslav
