[U-Boot] [PATCH v1 1/1] net: phy: Add AFE settings to the Broadcom Cygnus phy
Added the AFE (Analog Front End) settings for stability to the Broadcom Cygnus phy. This improves the time take to perform auto negotiation.
Signed-off-by: Arun Parameswaran arun.parameswaran@broadcom.com --- drivers/net/phy/broadcom.c | 64 +++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 63 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c index 9871cc3..e4afa90 100644 --- a/drivers/net/phy/broadcom.c +++ b/drivers/net/phy/broadcom.c @@ -30,6 +30,29 @@ #define MIIM_BCM54XX_EXP_SEL_SSD 0x0e00 /* Secondary SerDes select */ #define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */
+#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC 0x0007 +#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 + +#define MIIM_BCM_CHANNEL_WIDTH 0x2000 + +static void bcm_phy_write_misc(struct phy_device *phydev, + u16 reg, u16 chl, u16 value) +{ + int reg_val; + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, + MIIM_BCM_AUXCNTL_SHDWSEL_MISC); + + reg_val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL); + reg_val |= MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, reg_val); + + reg_val = (chl * MIIM_BCM_CHANNEL_WIDTH) | reg; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_SEL, reg_val); + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_DATA, value); +} + /* Broadcom BCM5461S */ static int bcm5461_config(struct phy_device *phydev) { @@ -152,11 +175,50 @@ static int bcm_cygnus_startup(struct phy_device *phydev) return genphy_parse_link(phydev); }
+static void bcm_cygnus_afe(struct phy_device *phydev) +{ + /* ensures smdspclk is enabled */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, 0x0c30); + + /* AFE_VDAC_ICTRL_0 bit 7:4 Iq=1100 for 1g 10bt, normal modes */ + bcm_phy_write_misc(phydev, 0x39, 0x01, 0xA7C8); + + /* AFE_HPF_TRIM_OTHERS bit11=1, short cascode for all modes*/ + bcm_phy_write_misc(phydev, 0x3A, 0x00, 0x0803); + + /* AFE_TX_CONFIG_1 bit 7:4 Iq=1100 for test modes */ + bcm_phy_write_misc(phydev, 0x3A, 0x01, 0xA740); + + /* AFE TEMPSEN_OTHERS rcal_HT, rcal_LT 10000 */ + bcm_phy_write_misc(phydev, 0x3A, 0x03, 0x8400); + + /* AFE_FUTURE_RSV bit 2:0 rccal <2:0>=100 */ + bcm_phy_write_misc(phydev, 0x3B, 0x00, 0x0004); + + /* Adjust bias current trim to overcome digital offSet */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x02); + + /* make rcal=100, since rdb default is 000 */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x17, 0x00B1); + phy_write(phydev, MDIO_DEVAD_NONE, 0x15, 0x0010); + + /* CORE_EXPB0, Reset R_CAL/RC_CAL Engine */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x17, 0x00B0); + phy_write(phydev, MDIO_DEVAD_NONE, 0x15, 0x0010); + + /* CORE_EXPB0, Disable Reset R_CAL/RC_CAL Engine */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x17, 0x00B0); + phy_write(phydev, MDIO_DEVAD_NONE, 0x15, 0x0000); +} + static int bcm_cygnus_config(struct phy_device *phydev) { genphy_config_aneg(phydev); - phy_reset(phydev); + /* AFE settings for PHY stability */ + bcm_cygnus_afe(phydev); + /* Forcing aneg after applying the AFE settings */ + genphy_restart_aneg(phydev);
return 0; }
On Wed, Jul 19, 2017 at 5:34 PM, Arun Parameswaran arun.parameswaran@broadcom.com wrote:
Reviewed-by: Jiandong Zheng jiandong.zheng@broadcom.com
Arun Parameswaran
JD Zheng
Joe Hershberger
