[U-Boot] [PATCH] mx6: Add initial support for Carrier1 mx6solo board
Solid Run designed the Carrier1 board based on mx6q/dl/solo.
Add the initial support for the mx6 solo variant.
More information about this hardware can be found at: http://cubox-i.com/
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/solidrun/carrier1/800mhz_2x256mx16.cfg | 74 +++++++ board/solidrun/carrier1/Makefile | 26 +++ board/solidrun/carrier1/README | 35 ++++ board/solidrun/carrier1/carrier1.c | 197 ++++++++++++++++++ board/solidrun/carrier1/clocks.cfg | 33 +++ board/solidrun/carrier1/ddr-800mhz-32bit-setup.cfg | 67 ++++++ board/solidrun/carrier1/mx6_c1solo.cfg | 25 +++ boards.cfg | 3 + include/configs/carrier1.h | 227 +++++++++++++++++++++ 9 files changed, 687 insertions(+) create mode 100644 board/solidrun/carrier1/800mhz_2x256mx16.cfg create mode 100644 board/solidrun/carrier1/Makefile create mode 100644 board/solidrun/carrier1/README create mode 100644 board/solidrun/carrier1/carrier1.c create mode 100644 board/solidrun/carrier1/clocks.cfg create mode 100644 board/solidrun/carrier1/ddr-800mhz-32bit-setup.cfg create mode 100644 board/solidrun/carrier1/mx6_c1solo.cfg create mode 100644 include/configs/carrier1.h
diff --git a/board/solidrun/carrier1/800mhz_2x256mx16.cfg b/board/solidrun/carrier1/800mhz_2x256mx16.cfg new file mode 100644 index 0000000..c0398f0 --- /dev/null +++ b/board/solidrun/carrier1/800mhz_2x256mx16.cfg @@ -0,0 +1,74 @@ +/* + * Copyright (C) 2013 Boundary Devices + * Copyright (C) 2013 SolidRun ltd. + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* ZQ Calibrations */ +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xa1390003 +DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xa1390003 +/* write leveling */ +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x000F0011 +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x000E000F +/* + * DQS gating, read delay, write delay calibration values + * based on calibration compare of 0x00ffff00 + */ +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42240229 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x021a0219 +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4e4f5150 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x35363136 +/* read data bit delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +/* Complete calibration by forced measurement */ +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 + +/* + * MMDC init: + * in DDR3, 32-bit mode, only MMDC0 is initiated: + */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002d +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 + +DATA 4, MX6_MMDC_P0_MDCFG0, 0x40445323 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xb68e8c63 + +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01ff00db +DATA 4, MX6_MMDC_P0_MDMISC, 0x00001740 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026d2 +DATA 4, MX6_MMDC_P0_MDOR, 0x00440e21 +/* CS0_END - 0x2fffffff, 512M */ +DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 + +/* MMDC0_MAARCR ADOPT optimized priorities. Dyn jump disabled */ +DATA 4, 0x021b0400, 0x11420000 + +/* MMDC0_MDCTL- row-14bits; col-10bits; burst length 8;32-bit data bus */ +DATA 4, MX6_MMDC_P0_MDCTL, 0x83190000 + +/* + * Initialize 2GB DDR3 - Micron MT41J128M + * MR2 + */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +/* MR3 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +/* MR1 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 +/* MR0 */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x07208030 +/* ZQ calibration */ +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 +/* final DDR setup */ +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000007 +DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556d +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 diff --git a/board/solidrun/carrier1/Makefile b/board/solidrun/carrier1/Makefile new file mode 100644 index 0000000..a18451e --- /dev/null +++ b/board/solidrun/carrier1/Makefile @@ -0,0 +1,26 @@ +# +# Copyright (C) 2013, Jon Nettleton jon.nettleton@gmail.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := carrier1.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/solidrun/carrier1/README b/board/solidrun/carrier1/README new file mode 100644 index 0000000..89d0aa0 --- /dev/null +++ b/board/solidrun/carrier1/README @@ -0,0 +1,35 @@ +U-Boot for Solid Run Carrier1 +----------------------------- + +This file contains information for the port of U-Boot to the Carrier1 board. + +For more details about Carrier1, please refer to: +http://cubox-i.com + +Building U-boot for Carrier1 +---------------------------- + +To build U-Boot for the Carrier1 Solo version: + +$ make carrier1_solo_config +$ make + +Flashing U-boot into the SD card +-------------------------------- + +- After the 'make' command completes, the generated 'u-boot.imx' binary must be +flashed into the SD card: + +$ sudo dd if=u-boot.imx of=/dev/mmcblk0 bs=1k seek=1; sync + +(Note - the SD card node may vary, so adjust this as needed). + +- Insert the micro SD card into the slot located in the bottom of the board + +- Connect a 3.3V USB to serial converter cable to the host PC. The MX6 UART +signals are available in the 26 pin connector as shown at: +http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware +(Check for "26 pin header layout"). + +- Power up the board via USB cable (CON201) and U-boot messages will appear in +the serial console. diff --git a/board/solidrun/carrier1/carrier1.c b/board/solidrun/carrier1/carrier1.c new file mode 100644 index 0000000..9c4ec49 --- /dev/null +++ b/board/solidrun/carrier1/carrier1.c @@ -0,0 +1,197 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * Copyright (C) 2013 SolidRun ltd. + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/io.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <miiphy.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CLK_CTRL (PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | \ + PAD_CTL_HYS) + +#define USDHC_PAD_GPIO_CTRL (PAD_CTL_PUS_22K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_PD (PAD_CTL_PUS_100K_DOWN | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define ENET_PAD_CTRL_CLK ((PAD_CTL_PUS_100K_UP & ~PAD_CTL_PKE) | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ETH_PHY_RESET IMX_GPIO_NR(4, 15) + +int dram_init(void) +{ + gd->ram_size = ((phys_size_t)CONFIG_DDR_MB * 1024 * 1024); + + return 0; +} + +static iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_CSI0_DAT10__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +static iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CLK_CTRL), + MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_GPIO_4__USDHC2_CD | MUX_PAD_CTRL(USDHC_PAD_GPIO_CTRL), +}; + +#ifdef CONFIG_FSL_ESDHC +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + { USDHC2_BASE_ADDR }, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* SD card is the boot medium, so always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +} +#endif + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8035 reset */ + MX6_PAD_KEY_ROW4__GPIO_4_15 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + /* AR8035 interrupt */ + MX6_PAD_DI0_PIN2__GPIO_4_18 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* GPIO16 -> AR8035 25MHz */ + MX6_PAD_GPIO_16__ENET_ANATOP_ETHERNET_REF_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8035 CLK_25M --> ENET_REF_CLK (V22) */ + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL_CLK), + MX6_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + MX6_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), + MX6_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL_PD), +}; + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + /* Reset AR8035 PHY */ + gpio_direction_output(ETH_PHY_RESET, 0); + udelay(1000 * 2); /* Wait 2 ms before reset */ + gpio_set_value(ETH_PHY_RESET, 1); + + udelay(100); +} + +int board_phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret; + struct iomuxc_base_regs *iomuxc_regs = (struct iomuxc_base_regs *) + IOMUXC_BASE_ADDR; + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + s32 timeout = 100000; + + u32 reg = readl(&anatop->pll_enet); + reg |= 0x00002000; + writel(reg, &anatop->pll_enet); + + /* clear gpr1[21] */ + clrsetbits_le32(&iomuxc_regs->gpr[1], (1 << 21), 1); + + while (timeout--) { + if (readl(&anatop->pll_enet) & BM_ANADIG_PLL_ENET_LOCK) + break; + } + + setup_iomux_enet(); + + ret = cpu_eth_init(bis); + if (ret) + printf("FEC MXC: %s:failed: %d\n", __func__, ret); + + return ret; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: MX6 Carrier1\n"); + + return 0; +} diff --git a/board/solidrun/carrier1/clocks.cfg b/board/solidrun/carrier1/clocks.cfg new file mode 100644 index 0000000..1288811 --- /dev/null +++ b/board/solidrun/carrier1/clocks.cfg @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2013 Boundary Devices + * Copyright (C) 2013 SolidRun ltd. + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0x00FFF300 +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F + +/* + * Setup CCM_CCOSR register as follows: + * + * cko1_en = 1 --> CKO1 enabled + * cko1_div = 111 --> divide by 8 + * cko1_sel = 1011 --> ahb_clk_root + * + * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz + */ +DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/solidrun/carrier1/ddr-800mhz-32bit-setup.cfg b/board/solidrun/carrier1/ddr-800mhz-32bit-setup.cfg new file mode 100644 index 0000000..f89a296 --- /dev/null +++ b/board/solidrun/carrier1/ddr-800mhz-32bit-setup.cfg @@ -0,0 +1,67 @@ +/* + * Copyright (C) 2013 Boundary Devices + * Copyright (C) 2013 SolidRun ltd. + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* DDR IO TYPE */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000c0000 +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +/* Clock */ +DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00000030 +/* Address */ +DATA 4, MX6_IOM_DRAM_CAS, 0x00000030 +DATA 4, MX6_IOM_DRAM_RAS, 0x00000030 +DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 +/* Control */ +DATA 4, MX6_IOM_DRAM_RESET, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 +DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 +DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 +DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 + +/* + * Data Strobe: IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL - DDR_INPUT=0, CMOS, + * CMOS mode saves power, but have less timing margin in case of DDR + * timing issue on your board you can try DDR_MODE: [= 0x00020000] + */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00000000 + +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000000 + +/* + * DATA:IOMUXC_SW_PAD_CTL_GRP_DDRMODE - DDR_INPUT=0, CMOS, + * CMOS mode saves power, but have less timing margin in case of DDR + * timing issue on your board you can try DDR_MODE: [= 0x00020000] + */ +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00000000 + +DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 +DATA 4, MX6_IOM_GRP_B4DS, 0x00000000 +DATA 4, MX6_IOM_GRP_B5DS, 0x00000000 +DATA 4, MX6_IOM_GRP_B6DS, 0x00000000 +DATA 4, MX6_IOM_GRP_B7DS, 0x00000000 + +DATA 4, MX6_IOM_DRAM_DQM0, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM1, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM2, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM3, 0x00000030 +DATA 4, MX6_IOM_DRAM_DQM4, 0x00000000 +DATA 4, MX6_IOM_DRAM_DQM5, 0x00000000 +DATA 4, MX6_IOM_DRAM_DQM6, 0x00000000 +DATA 4, MX6_IOM_DRAM_DQM7, 0x00000000 diff --git a/board/solidrun/carrier1/mx6_c1solo.cfg b/board/solidrun/carrier1/mx6_c1solo.cfg new file mode 100644 index 0000000..1acad07 --- /dev/null +++ b/board/solidrun/carrier1/mx6_c1solo.cfg @@ -0,0 +1,25 @@ +/* + * Copyright (C) 2013 Boundary Devices + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd (the board has no nand neither onenand) + */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-800mhz-32bit-setup.cfg" +#include "800mhz_2x256mx16.cfg" +#include "clocks.cfg" diff --git a/boards.cfg b/boards.cfg index cec154b..892973a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -306,6 +306,9 @@ Active arm armv7 mx6 freescale mx6sabresd Active arm armv7 mx6 freescale mx6sabresd mx6qsabresd mx6sabresd:IMX_CONFIG=board/freescale/imx/ddr/mx6q_4x_mt41j128.cfg,MX6Q Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale mx6slevk mx6slevk mx6slevk:IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 freescale titanium titanium titanium:IMX_CONFIG=board/freescale/titanium/imximage.cfg Stefan Roese sr@denx.de + +Active arm armv7 mx6 solidrun carrier1 carrier1_solo carrier1:IMX_CONFIG=board/solidrun/carrier1/mx6_c1solo.cfg,MX6S,DDR_MB=512 Fabio Estevam fabio.estevam@freescale.com + Active arm armv7 omap3 - overo omap3_overo - Steve Sakoman sakoman@gmail.com Active arm armv7 omap3 - pandora omap3_pandora - Grazvydas Ignotas notasas@gmail.com Active arm armv7 omap3 8dtech eco5pk eco5pk - Raphael Assenat raph@8d.com diff --git a/include/configs/carrier1.h b/include/configs/carrier1.h new file mode 100644 index 0000000..969e3ad --- /dev/null +++ b/include/configs/carrier1.h @@ -0,0 +1,227 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * Copyright (C) 2013 SolidRun ltd. + * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com + * + * Configuration settings for the SolidRun Carrier1 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include "mx6_common.h" +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> +#include <asm/sizes.h> + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define MACH_TYPE_CARRIER1 4773 +#define CONFIG_MACH_TYPE MACH_TYPE_CARRIER1 + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (2 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_BASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_I2C + +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +/* MMC Configuration */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* Ethernet Configuration */ +#define CONFIG_FEC_MXC +#ifdef CONFIG_FEC_MXC +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS +#endif + +#if defined(CONFIG_MX6S) +#define CONFIG_DEFAULT_FDT_FILE "imx6dl-carrier1.dtb" +#endif + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc0\0" \ + "splashpos=m,m\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "update_sd_firmware_filename=u-boot.imx\0" \ + "update_sd_firmware=" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if mmc dev ${mmcdev}; then " \ + "if ${get_cmd} ${update_sd_firmware_filename}; then " \ + "setexpr fw_sz ${filesize} / 0x200; " \ + "setexpr fw_sz ${fw_sz} + 1; " \ + "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ + "fi; " \ + "fi\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 1024 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H * */
Hi Stefano,
I would like to send another patch that depends on this one.
Could you please let me know if you think this one looks good?
Thanks,
Fabio Estevam
Hi Stefano,
On Wed, Nov 13, 2013 at 6:12 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Stefano,
Actually please discard this one. Will need to send a v2 soon.
Thanks,
Fabio Estevam
Ok, understood.
Stefano
Fabio Estevam
Stefano Babic
