[U-Boot-Users] [PATCH] Update pci code to use phys_addr_t
Physical addrs need to be represented by phys_addr_t, not unsigned long. Otherwise, systems that use CONFIG_PHYS_64BIT are going to fail mightily.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- drivers/pci/pci.c | 8 ++++---- include/pci.h | 10 +++++----- 2 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 7944b66..f01a75e 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -221,7 +221,7 @@ pci_dev_t pci_find_device(unsigned int vendor, unsigned int device, int index) */
unsigned long pci_hose_phys_to_bus (struct pci_controller *hose, - unsigned long phys_addr, + phys_addr_t phys_addr, unsigned long flags) { struct pci_region *res; @@ -253,9 +253,9 @@ Done: return 0; }
-unsigned long pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long bus_addr, - unsigned long flags) +phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, + unsigned long bus_addr, + unsigned long flags) { struct pci_region *res; int i; diff --git a/include/pci.h b/include/pci.h index 8e5dacc..1c8e216 100644 --- a/include/pci.h +++ b/include/pci.h @@ -314,7 +314,7 @@
struct pci_region { unsigned long bus_start; /* Start on the bus */ - unsigned long phys_start; /* Start in physical address space */ + phys_addr_t phys_start; /* Start in physical address space */ unsigned long size; /* Size */ unsigned long flags; /* Resource flags */
@@ -331,7 +331,7 @@ struct pci_region {
extern __inline__ void pci_set_region(struct pci_region *reg, unsigned long bus_start, - unsigned long phys_start, + phys_addr_t phys_start, unsigned long size, unsigned long flags) { reg->bus_start = bus_start; @@ -432,10 +432,10 @@ extern __inline__ void pci_set_ops(struct pci_controller *hose,
extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data);
-extern unsigned long pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long addr, unsigned long flags); +extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, + unsigned long addr, unsigned long flags); extern unsigned long pci_hose_phys_to_bus(struct pci_controller* hose, - unsigned long addr, unsigned long flags); + phys_addr_t addr, unsigned long flags);
#define pci_phys_to_bus(dev, addr, flags) \ pci_hose_phys_to_bus(pci_bus_to_hose(PCI_BUS(dev)), (addr), (flags))
In message Pine.LNX.4.64.0805071321310.12847@monty.am.freescale.net you wrote:
Applied, thanks.
Becky Bruce
