[PATCH] efi_loader: allow to disable GOP support
Sometimes EFI GOP support may be not wanted (e.g. because the operating system cannot operate well with it) even if video support in U-Boot is needed.
Allow to disable EFI GOP support with a Kconfig option.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- lib/efi_loader/Kconfig | 8 ++++++++ lib/efi_loader/Makefile | 3 +-- lib/efi_loader/efi_setup.c | 11 ++++++----- 3 files changed, 15 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 6242caceb7..5ba0ce6a44 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -282,6 +282,14 @@ config EFI_HAVE_RUNTIME_RESET depends on ARCH_BCM283X || FSL_LAYERSCAPE || PSCI_RESET || \ SANDBOX || SYSRESET_X86
+config EFI_GOP_PROTOCOL + bool "EFI_GOP_PROTOCOL support" + default y + depends on DM_VIDEO || LCD + help + Provide a EFI_GOP_PROTOCOL implementation using the graphics + hardware initialized by U-Boot. + config EFI_GRUB_ARM32_WORKAROUND bool "Workaround for GRUB on 32bit ARM" default n if ARCH_BCM283X || ARCH_SUNXI || ARCH_QEMU diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index fd344cea29..826563d9a7 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -54,8 +54,7 @@ obj-$(CONFIG_EFI_VARIABLES_PRESEED) += efi_var_seed.o endif obj-y += efi_watchdog.o obj-$(CONFIG_EFI_ESRT) += efi_esrt.o -obj-$(CONFIG_LCD) += efi_gop.o -obj-$(CONFIG_DM_VIDEO) += efi_gop.o +obj-$(CONFIG_EFI_GOP_PROTOCOL) += efi_gop.o obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += efi_acpi.o diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 3c5cf9a435..98deb63777 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -254,11 +254,12 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out;
-#if defined(CONFIG_LCD) || defined(CONFIG_DM_VIDEO) - ret = efi_gop_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif + if (IS_ENABLED(CONFIG_EFI_GOP_PROTOCOL)) { + ret = efi_gop_register(); + if (ret != EFI_SUCCESS) + goto out; + } + #ifdef CONFIG_NET ret = efi_net_register(); if (ret != EFI_SUCCESS)
Am 15. Juni 2021 23:10:28 MESZ schrieb Icenowy Zheng icenowy@aosc.io:
Which OS has which problem? Why don't you fix the OS?
Best regards
Heinrich
- bool "EFI_GOP_PROTOCOL support"
- default y
- depends on DM_VIDEO || LCD
- help
goto out;
-#endif
- if (IS_ENABLED(CONFIG_EFI_GOP_PROTOCOL)) {
goto out;
在 2021-06-16星期三的 06:59 +0200,Heinrich Schuchardt写道:
I'm trying RK3399 with Linux. EFIFB never works as intended (maybe it's because IOMMU is reconfigured), and rockchipdrmfb will be fb1 (leave non-working EFIFB as fb0), makes fbcon unusable.
The second problem has a proposed fix, but the first problem is mystery.
Best regards
Heinrich
Am 16. Juni 2021 14:19:41 MESZ schrieb Icenowy Zheng icenowy@aosc.io:
The GOP driver is not available after ExitBootServices. You can't use it after the EFI stub hands over to main Linux.
Shouldn't the Panfrost driver and Mesa be used for RK3399? https://wiki.debian.org/PanfrostLima , https://www.collabora.com/news-and-blog/blog/2019/08/06/rockpi-panfrost-wayl...
Best regards
Heinrich
Best regards
Heinrich
在 2021-06-16星期三的 15:20 +0200,Heinrich Schuchardt写道:
Sometimes EFI GOP support may be not wanted (e.g. because the operating system cannot operate well with it) even if video support in U- Boot is needed.
I think Linux will remember a FB address before ExitBootServices, and continue to use it then.
Shouldn't the Panfrost driver and Mesa be used for RK3399? https://wiki.debian.org/PanfrostLima%C2%A0, https://www.collabora.com/news-and-blog/blog/2019/08/06/rockpi-panfrost-wayl...
Well, you made a common error that thinks on embedded systems GPUs are responsible for display. It's not, for display (not 3D rendering) rockchipdrm is the driver.
Best regards
Heinrich
Best regards
Heinrich
It's due to bugs in Linux, it will be fixed in 5.14 with these patches from our Fedora testing: https://lists.freedesktop.org/archives/dri-devel/2021-May/306803.html
There's also this enhancement, also should land in 5.14, which is dependent on the feature that's in the second link:
https://lists.freedesktop.org/archives/dri-devel/2021-May/306803.html https://lists.freedesktop.org/archives/dri-devel/2021-April/303291.html
With that first patch it mostly works for me, the second two series improves on that some more.
Peter
Best regards
Heinrich
default y
help
graphics
goto out;
-#endif
goto out;
在 2021-06-16星期三的 15:06 +0100,Peter Robinson写道:
I think this patch should get backported.
BTW a point of using EFI boot is to support existing distros, which won't have this patch.
Peter
Best regards
Heinrich
I have no problems with that so feel free to propose it to the stable kernels.
Sure, but UEFI doesn't guarantee there aren't bugs in kernels or firmware though, it certainly makes things more straight forward but it's no silver bullet.
Peter
Best regards
Heinrich
default y
help
graphics
goto out;
-#endif
goto out;
Am 16. Juni 2021 16:18:35 MESZ schrieb Peter Robinson pbrobinson@gmail.com:
U-
Boot is needed.
(maybe
https://passthroughpo.st/explaining-csm-efifboff-setting-boot-gpu-manually/ refers to a Linux command line parameter that could be used:
video=efifb:off
Best regards
Heinrich
Peter
Best regards
Heinrich
PSCI_RESET
default y
help
graphics
goto out;
-#endif
goto out;
I think that figured out the mystery for your second problem too (if I understood what you meant correctly).
The problem is that u-boot initializes the display controller and provides the setup framebuffer memory to the kernel as a GOP. But then the kernel re-initializes the HW again and mess with the resources needed by the display controller that were correctly setup by u-boot. Part of that is the IOMMU as you said, but also the clocks and power domains that Linux will disable because are "unused".
So to have a GOP framebuffer that will be available until the rockchip DRM fb emulation takes over (with the patch mentioned by Peter), you will need the following kernel command line options:
initcall_blacklist=rk_iommu_init clk_ignore_unused pd_ignore_unused
Best regards, Javier
Icenowy Zheng
Javier Martinez Canillas
Peter Robinson
