[PATCH] version: Move version_string[] from version.h to version_string.h
More C files do not use compile time timestamp macros and do not have to be recompiled every time when SOURCE_DATE_EPOCH changes.
This patch moves version_string[] from version.h to version_string.h and updates other C files which only needs version_string[] string to include version_string.h instead of version.h. After applying this patch these files are not recompiled every time when SOURCE_DATE_EPOCH changes.
Signed-off-by: Pali Rohár pali@kernel.org --- board/ge/b1x5v2/b1x5v2.c | 2 +- board/ge/bx50v3/bx50v3.c | 2 +- board/ge/mx53ppd/mx53ppd.c | 2 +- cmd/version.c | 1 + common/main.c | 2 +- drivers/video/cfb_console.c | 3 +-- include/version.h | 3 --- include/version_string.h | 8 ++++++++ lib/display_options.c | 2 +- test/print_ut.c | 2 +- 10 files changed, 16 insertions(+), 11 deletions(-) create mode 100644 include/version_string.h
diff --git a/board/ge/b1x5v2/b1x5v2.c b/board/ge/b1x5v2/b1x5v2.c index 1cb347fd9e..18ba5c9e71 100644 --- a/board/ge/b1x5v2/b1x5v2.c +++ b/board/ge/b1x5v2/b1x5v2.c @@ -29,7 +29,7 @@ #include <panel.h> #include <rtc.h> #include <spi_flash.h> -#include <version.h> +#include <version_string.h>
#include "../common/vpd_reader.h"
diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index 3ea9425fd1..faad9cef72 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -32,7 +32,7 @@ #include <power/da9063_pmic.h> #include <input.h> #include <pwm.h> -#include <version.h> +#include <version_string.h> #include <stdlib.h> #include <dm/root.h> #include "../common/ge_rtc.h" diff --git a/board/ge/mx53ppd/mx53ppd.c b/board/ge/mx53ppd/mx53ppd.c index ef689733c4..9a76cdc388 100644 --- a/board/ge/mx53ppd/mx53ppd.c +++ b/board/ge/mx53ppd/mx53ppd.c @@ -32,7 +32,7 @@ #include <fsl_pmic.h> #include <linux/fb.h> #include <ipu_pixfmt.h> -#include <version.h> +#include <version_string.h> #include <watchdog.h> #include "ppd_gpio.h" #include <stdlib.h> diff --git a/cmd/version.c b/cmd/version.c index 3686b87332..b183cc8b63 100644 --- a/cmd/version.c +++ b/cmd/version.c @@ -7,6 +7,7 @@ #include <common.h> #include <command.h> #include <version.h> +#include <version_string.h> #include <linux/compiler.h> #ifdef CONFIG_SYS_COREBOOT #include <asm/arch/sysinfo.h> diff --git a/common/main.c b/common/main.c index ae5bcdb32f..3f5214fd44 100644 --- a/common/main.c +++ b/common/main.c @@ -15,7 +15,7 @@ #include <env.h> #include <init.h> #include <net.h> -#include <version.h> +#include <version_string.h> #include <efi_loader.h>
static void run_preboot_environment_command(void) diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 3f07f4eb29..1a471ce07b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -71,7 +71,7 @@ #include <fdtdec.h> #include <gzip.h> #include <log.h> -#include <version.h> +#include <version_string.h> #include <malloc.h> #include <video.h> #include <linux/compiler.h> @@ -121,7 +121,6 @@ * Console device */
-#include <version.h> #include <linux/types.h> #include <stdio_dev.h> #include <video_font.h> diff --git a/include/version.h b/include/version.h index 2d24451569..0a3b29adb8 100644 --- a/include/version.h +++ b/include/version.h @@ -16,7 +16,4 @@ #define U_BOOT_VERSION_STRING U_BOOT_VERSION " (" U_BOOT_DATE " - " \ U_BOOT_TIME " " U_BOOT_TZ ")" CONFIG_IDENT_STRING
-#ifndef __ASSEMBLY__ -extern const char version_string[]; -#endif /* __ASSEMBLY__ */ #endif /* __VERSION_H__ */ diff --git a/include/version_string.h b/include/version_string.h new file mode 100644 index 0000000000..a89a6e4370 --- /dev/null +++ b/include/version_string.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __VERSION_STRING_H__ +#define __VERSION_STRING_H__ + +extern const char version_string[]; + +#endif /* __VERSION_STRING_H__ */ diff --git a/lib/display_options.c b/lib/display_options.c index b2025eeb5c..1b069761f8 100644 --- a/lib/display_options.c +++ b/lib/display_options.c @@ -8,7 +8,7 @@ #include <compiler.h> #include <console.h> #include <div64.h> -#include <version.h> +#include <version_string.h> #include <linux/ctype.h> #include <asm/io.h>
diff --git a/test/print_ut.c b/test/print_ut.c index a456a449ef..ae1cf85f1c 100644 --- a/test/print_ut.c +++ b/test/print_ut.c @@ -12,7 +12,7 @@ #endif #include <display_options.h> #include <log.h> -#include <version.h> +#include <version_string.h>
#define FAKE_BUILD_TAG "jenkins-u-boot-denx_uboot_dm-master-build-aarch64" \ "and a lot more text to come"
Thanks, Stefan
- Console device
Viele Grüße, Stefan
Pali Rohár
Stefan Roese
