[PATCH v2 1/2] cmd: Rename CMD_MISC to CMD_SLEEP
The "cmd/Kconfig" has a TODO description for CMD_MISC that it should really be named as CMD_SLEEP. Change it in the whole source tree.
Signed-off-by: Bin Meng bin.meng@windriver.com ---
Changes in v2: - remove the "Misc functions" in the C codes
cmd/Kconfig | 3 +-- cmd/Makefile | 2 +- cmd/{misc.c => sleep.c} | 3 --- configs/MCR3000_defconfig | 2 +- configs/MigoR_defconfig | 2 +- configs/armadillo-800eva_defconfig | 2 +- configs/bcm968380gerg_ram_defconfig | 2 +- configs/comtrend_ar5315u_ram_defconfig | 2 +- configs/comtrend_ar5387un_ram_defconfig | 2 +- configs/comtrend_ct5361_ram_defconfig | 2 +- configs/comtrend_vr3032u_ram_defconfig | 2 +- configs/comtrend_wap5813n_ram_defconfig | 2 +- configs/evb-px30_defconfig | 2 +- configs/evb-rk3308_defconfig | 2 +- configs/firefly-px30_defconfig | 2 +- configs/huawei_hg556a_ram_defconfig | 2 +- configs/ls2080a_emu_defconfig | 2 +- configs/ls2080a_simu_defconfig | 2 +- configs/netgear_cg3100d_ram_defconfig | 2 +- configs/netgear_dgnd3700v2_ram_defconfig | 2 +- configs/odroid-go2_defconfig | 2 +- configs/odroid_defconfig | 2 +- configs/origen_defconfig | 2 +- configs/pumpkin_defconfig | 2 +- configs/r7780mp_defconfig | 2 +- configs/roc-cc-rk3308_defconfig | 2 +- configs/s5p_goni_defconfig | 2 +- configs/s5pc210_universal_defconfig | 2 +- configs/sagem_f@st1704_ram_defconfig | 2 +- configs/sfr_nb4-ser_ram_defconfig | 2 +- configs/sh7752evb_defconfig | 2 +- configs/sh7753evb_defconfig | 2 +- configs/sh7757lcr_defconfig | 2 +- configs/sh7763rdp_defconfig | 2 +- configs/smdkv310_defconfig | 2 +- configs/total_compute_defconfig | 2 +- configs/trats2_defconfig | 2 +- configs/trats_defconfig | 2 +- configs/uniphier_ld4_sld8_defconfig | 2 +- configs/uniphier_v7_defconfig | 2 +- configs/uniphier_v8_defconfig | 2 +- configs/vexpress_aemv8a_juno_defconfig | 2 +- configs/vexpress_aemv8a_semi_defconfig | 2 +- configs/vexpress_ca15_tc2_defconfig | 2 +- configs/vexpress_ca5x2_defconfig | 2 +- configs/vexpress_ca9x4_defconfig | 2 +- configs/xenguest_arm64_defconfig | 2 +- configs/xilinx_versal_mini_defconfig | 2 +- configs/xilinx_zynqmp_mini_defconfig | 2 +- configs/xilinx_zynqmp_mini_qspi_defconfig | 2 +- configs/zynq_cse_nand_defconfig | 2 +- configs/zynq_cse_nor_defconfig | 2 +- configs/zynq_cse_qspi_defconfig | 2 +- 53 files changed, 52 insertions(+), 56 deletions(-) rename cmd/{misc.c => sleep.c} (98%)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4cb1717..d4427a7 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1708,8 +1708,7 @@ config CMD_RNG help Print bytes from the hardware random number generator.
-# TODO: rename to CMD_SLEEP -config CMD_MISC +config CMD_SLEEP bool "sleep" default y help diff --git a/cmd/Makefile b/cmd/Makefile index 015b837..85bce48 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -95,7 +95,7 @@ obj-$(CONFIG_CMD_IO) += io.o obj-$(CONFIG_CMD_MFSL) += mfsl.o obj-$(CONFIG_CMD_MII) += mii.o obj-$(CONFIG_CMD_MDIO) += mdio.o -obj-$(CONFIG_CMD_MISC) += misc.o +obj-$(CONFIG_CMD_SLEEP) += sleep.o obj-$(CONFIG_CMD_MMC) += mmc.o obj-$(CONFIG_MP) += mp.o obj-$(CONFIG_CMD_MTD) += mtd.o diff --git a/cmd/misc.c b/cmd/sleep.c similarity index 98% rename from cmd/misc.c rename to cmd/sleep.c index 20ab943..86986f0 100644 --- a/cmd/misc.c +++ b/cmd/sleep.c @@ -4,9 +4,6 @@ * Wolfgang Denk, DENX Software Engineering, wd@denx.de. */
-/* - * Misc functions - */ #include <common.h> #include <command.h> #include <console.h> diff --git a/configs/MCR3000_defconfig b/configs/MCR3000_defconfig index 8ddda59..924ab16 100644 --- a/configs/MCR3000_defconfig +++ b/configs/MCR3000_defconfig @@ -66,7 +66,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index 5945e1d..f29f1ec 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xA0020000 diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index ab84978..e06ef7d 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_SDRAM=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x40000 diff --git a/configs/bcm968380gerg_ram_defconfig b/configs/bcm968380gerg_ram_defconfig index 8dd507d..b1f8bf5 100644 --- a/configs/bcm968380gerg_ram_defconfig +++ b/configs/bcm968380gerg_ram_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_GPIO=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index e9d1c08..bb9c0b8 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index 8d1de33..80bafb0 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index 9394ce0..36dcf2c 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index 33665e1..1c2eeed 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_NAND=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index 997caf6..fda61ec 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/evb-px30_defconfig b/configs/evb-px30_defconfig index 5b930a5..d2fdfef 100644 --- a/configs/evb-px30_defconfig +++ b/configs/evb-px30_defconfig @@ -46,7 +46,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index 7c7d222..9230983 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 diff --git a/configs/firefly-px30_defconfig b/configs/firefly-px30_defconfig index a8b24cc..6487615 100644 --- a/configs/firefly-px30_defconfig +++ b/configs/firefly-px30_defconfig @@ -47,7 +47,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index 6aba660..0029004 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -30,7 +30,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 4e37781..c42f012 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -24,7 +24,7 @@ CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_MP=y # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 599c250..2aabb77 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_MP=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set diff --git a/configs/netgear_cg3100d_ram_defconfig b/configs/netgear_cg3100d_ram_defconfig index 7a73738..538056c 100644 --- a/configs/netgear_cg3100d_ram_defconfig +++ b/configs/netgear_cg3100d_ram_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_MEMINFO=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_SPI=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 31ab144..333652d 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/odroid-go2_defconfig b/configs/odroid-go2_defconfig index d1f7a0f..8538909 100644 --- a/configs/odroid-go2_defconfig +++ b/configs/odroid-go2_defconfig @@ -52,7 +52,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_ITEST is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 25c7e98..9f2b0b2 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT4_WRITE=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 3f1c7b1..4c4dc1a 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -25,7 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/pumpkin_defconfig b/configs/pumpkin_defconfig index 3d6af03..ab50124 100644 --- a/configs/pumpkin_defconfig +++ b/configs/pumpkin_defconfig @@ -42,7 +42,7 @@ CONFIG_CMD_PART=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_BLOCK_CACHE is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_NET is not set diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 44bf3a7..ed89aa9 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT2=y CONFIG_DOS_PARTITION=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index f40c197..2d02e29 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index a9c1fce..28d8be6 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_ONENAND=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index db1d64c..759034a 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -25,7 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDPARTS_DEFAULT="mtdparts=samsung-onenand:128k(s-boot),896k(bootloader),256k(params),2816k(config),8m(csa),7m(kernel),1m(log),12m(modem),60m(qboot),-(UBI)" CONFIG_OF_CONTROL=y diff --git a/configs/sagem_f@st1704_ram_defconfig b/configs/sagem_f@st1704_ram_defconfig index 13f7775..efd23b4 100644 --- a/configs/sagem_f@st1704_ram_defconfig +++ b/configs/sagem_f@st1704_ram_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_SPI=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index 00a79ee..6cf0740 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 3e35553..bc174f4 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -23,7 +23,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 0b14847..c199660 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index 14e569c..4e5bfea 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -25,7 +25,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index fc07bfd..072202e 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -25,7 +25,7 @@ CONFIG_CMD_SDRAM=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_JFFS2=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index eec30b6..9d4cf35 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -18,7 +18,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index 3b04f94..6348b31 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -34,7 +34,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_AVB=y CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index e8950e3..8439ddc 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -27,7 +27,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 1323e18..931c69b 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NET is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index a35aa85..acc6d7d 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -27,7 +27,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=uniphier-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=uniphier-nand.0:1m(firmware),-(UBI)" diff --git a/configs/uniphier_v7_defconfig b/configs/uniphier_v7_defconfig index a7dbbdc..e989b84 100644 --- a/configs/uniphier_v7_defconfig +++ b/configs/uniphier_v7_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=uniphier-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=uniphier-nand.0:1m(firmware),-(UBI)" diff --git a/configs/uniphier_v8_defconfig b/configs/uniphier_v8_defconfig index c69a07a..3d2a98e 100644 --- a/configs/uniphier_v8_defconfig +++ b/configs/uniphier_v8_defconfig @@ -25,7 +25,7 @@ CONFIG_CMD_USB=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=uniphier-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=uniphier-nand.0:1m(firmware),-(UBI)" diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index c368425..005d3d1 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -29,7 +29,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_OF_BOARD=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 4a17ce0..ee41ec3 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 330b95c..e8e401b 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -19,7 +19,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index 44f40d0..88027b9 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -18,7 +18,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 8772ac3..7b14845 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -19,7 +19,7 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y diff --git a/configs/xenguest_arm64_defconfig b/configs/xenguest_arm64_defconfig index 042ea79..e170761 100644 --- a/configs/xenguest_arm64_defconfig +++ b/configs/xenguest_arm64_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_PVBLOCK=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_OF_BOARD=y diff --git a/configs/xilinx_versal_mini_defconfig b/configs/xilinx_versal_mini_defconfig index 3d1cba3..e72cef9 100644 --- a/configs/xilinx_versal_mini_defconfig +++ b/configs/xilinx_versal_mini_defconfig @@ -47,7 +47,7 @@ CONFIG_SYS_MEMTEST_END=0x00001000 # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_PARTITIONS is not set CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set diff --git a/configs/xilinx_zynqmp_mini_defconfig b/configs/xilinx_zynqmp_mini_defconfig index c029f59..9e63533 100644 --- a/configs/xilinx_zynqmp_mini_defconfig +++ b/configs/xilinx_zynqmp_mini_defconfig @@ -45,7 +45,7 @@ CONFIG_SYS_MEMTEST_END=0x00001000 # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set # CONFIG_PARTITIONS is not set CONFIG_OF_EMBED=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/xilinx_zynqmp_mini_qspi_defconfig b/configs/xilinx_zynqmp_mini_qspi_defconfig index 83458f9..15cba60 100644 --- a/configs/xilinx_zynqmp_mini_qspi_defconfig +++ b/configs/xilinx_zynqmp_mini_qspi_defconfig @@ -44,7 +44,7 @@ CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/zynq_cse_nand_defconfig b/configs/zynq_cse_nand_defconfig index 342a64d..b36fd4a4 100644 --- a/configs/zynq_cse_nand_defconfig +++ b/configs/zynq_cse_nand_defconfig @@ -45,7 +45,7 @@ CONFIG_SPL_STACK_R=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_OF_EMBED=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/zynq_cse_nor_defconfig b/configs/zynq_cse_nor_defconfig index 4e3196b..3e614df 100644 --- a/configs/zynq_cse_nor_defconfig +++ b/configs/zynq_cse_nor_defconfig @@ -44,7 +44,7 @@ CONFIG_SPL_STACK_R=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_OF_EMBED=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/zynq_cse_qspi_defconfig b/configs/zynq_cse_qspi_defconfig index fcef6fb..7cb1d61 100644 --- a/configs/zynq_cse_qspi_defconfig +++ b/configs/zynq_cse_qspi_defconfig @@ -53,7 +53,7 @@ CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_MISC is not set +# CONFIG_CMD_SLEEP is not set CONFIG_OF_EMBED=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y
CONFIG_CMD_TIMER merits a single file instead of co-exist in the sleep command file.
(no changes since v1)
cmd/Makefile | 1 + cmd/sleep.c | 28 ---------------------------- cmd/timer.c | 34 ++++++++++++++++++++++++++++++++++ 3 files changed, 35 insertions(+), 28 deletions(-) create mode 100644 cmd/timer.c
diff --git a/cmd/Makefile b/cmd/Makefile index 85bce48..c536a3e 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -140,6 +140,7 @@ obj-$(CONFIG_CMD_SMC) += smccc.o obj-$(CONFIG_CMD_SYSBOOT) += sysboot.o pxe_utils.o obj-$(CONFIG_CMD_TERMINAL) += terminal.o obj-$(CONFIG_CMD_TIME) += time.o +obj-$(CONFIG_CMD_TIMER) += timer.o obj-$(CONFIG_CMD_TRACE) += trace.o obj-$(CONFIG_HUSH_PARSER) += test.o obj-$(CONFIG_CMD_TPM) += tpm-common.o diff --git a/cmd/sleep.c b/cmd/sleep.c index 86986f0..f0c78a8 100644 --- a/cmd/sleep.c +++ b/cmd/sleep.c @@ -55,31 +55,3 @@ U_BOOT_CMD( " - delay execution for N seconds (N is _decimal_ and can be\n" " fractional)" ); - -#ifdef CONFIG_CMD_TIMER -static int do_timer(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - static ulong start; - - if (argc != 2) - return CMD_RET_USAGE; - - if (!strcmp(argv[1], "start")) - start = get_timer(0); - - if (!strcmp(argv[1], "get")) { - ulong msecs = get_timer(start) * 1000 / CONFIG_SYS_HZ; - printf("%ld.%03d\n", msecs / 1000, (int)(msecs % 1000)); - } - - return 0; -} - -U_BOOT_CMD( - timer, 2, 1, do_timer, - "access the system timer", - "start - Reset the timer reference.\n" - "timer get - Print the time since 'start'." -); -#endif diff --git a/cmd/timer.c b/cmd/timer.c new file mode 100644 index 0000000..551be5d --- /dev/null +++ b/cmd/timer.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2001 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + */ + +#include <common.h> +#include <command.h> + +static int do_timer(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + static ulong start; + + if (argc != 2) + return CMD_RET_USAGE; + + if (!strcmp(argv[1], "start")) + start = get_timer(0); + + if (!strcmp(argv[1], "get")) { + ulong msecs = get_timer(start) * 1000 / CONFIG_SYS_HZ; + printf("%ld.%03d\n", msecs / 1000, (int)(msecs % 1000)); + } + + return 0; +} + +U_BOOT_CMD( + timer, 2, 1, do_timer, + "access the system timer", + "start - Reset the timer reference.\n" + "timer get - Print the time since 'start'." +);
Changes in v2:
ping?
Bin Meng
