[U-Boot] [PATCH] ARM: tegra: remove stale nvidia, bpmp I2C DT property
The nvidia,bpmp property is left over from an old BPMP I2C binding, and shouldn't be present. Remove it from the SoC DT file, and update the I2C driver not to parse it; the value wasn't used for anything any more anyway.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/dts/tegra186.dtsi | 1 - drivers/i2c/tegra186_bpmp_i2c.c | 10 ---------- 2 files changed, 11 deletions(-)
diff --git a/arch/arm/dts/tegra186.dtsi b/arch/arm/dts/tegra186.dtsi index 65ff4246c01e..f878b6532510 100644 --- a/arch/arm/dts/tegra186.dtsi +++ b/arch/arm/dts/tegra186.dtsi @@ -309,7 +309,6 @@
bpmp_i2c: i2c { compatible = "nvidia,tegra186-bpmp-i2c"; - nvidia,bpmp = <&bpmp>; nvidia,bpmp-bus-id = <5>; #address-cells = <1>; #size-cells = <0>; diff --git a/drivers/i2c/tegra186_bpmp_i2c.c b/drivers/i2c/tegra186_bpmp_i2c.c index 88e8413d9e07..513c414ae38a 100644 --- a/drivers/i2c/tegra186_bpmp_i2c.c +++ b/drivers/i2c/tegra186_bpmp_i2c.c @@ -89,16 +89,6 @@ static int tegra186_bpmp_i2c_xfer(struct udevice *dev, struct i2c_msg *msg, static int tegra186_bpmp_i2c_probe(struct udevice *dev) { struct tegra186_bpmp_i2c *priv = dev_get_priv(dev); - int ret; - struct fdtdec_phandle_args args; - - ret = fdtdec_parse_phandle_with_args(gd->fdt_blob, dev->of_offset, - "nvidia,bpmp", NULL, 0, 0, &args); - if (ret < 0) { - debug("%s: fdtdec_parse_phandle_with_args() failed: %d\n", - __func__, ret); - return ret; - }
priv->bpmp_bus_id = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, "nvidia,bpmp-bus-id", U32_MAX);
Stephen Warren
