DTB_RESELECT/MULTI DTB with SPL flow
I am just trying to wrap my head around DTB_RESELECT feature. ZynqMP is using u-boot.itb which is u-boot/atf + a lot of DT files. As of now SPL should pick the right one load it predefined location which U-Boot proper pickup. Others DTBs are not loaded at all. This is working fine and I expect it should work like this even with DTB_RESELECT enabled because you need to have base DTB for being able to do platform detection. I have hookup platform detection in embedded_dtb_select and I know which board revision I am running at and struggling how to tell u-boot what to do.
What should be the right flow for changing DTB at run time? Where they should be stored? I would expect that I need to have FIT image in memory for all board revisions and u-boot should be calling board_fit_config_name_match() which will decide which DT is correct based on board detection done in embedded_dtb_select().
Thanks, Michal
Hi Michal,
Did you intend to cc the author of that?
Does doc/README.multi-dtb-fit help?
Yes you can use a FIT to hold the DTs. You can also use binman I suppose (the 'files' entry type perhaps).
Hi Simon,
On 6/26/21 8:30 PM, Simon Glass wrote:
Hi Michal,
I got it working. Also found one alignment issue which needs to be fixed. And also DT overlays are not supported now.
Thanks, Michal
Michal Simek
