[PATCH 00/27] imx: imx8ulp: misc update from downstream
This patchset is to upstream NXP downstream i.MX8ULP patches - Support Nominal/Low Drive clock settings - Update mem map for TEE - Release CAAM - Support Dual boot - Enable handshake with M33 - Update DDR and PHY settings - Misc clock update
Clark Wang (1): imx: imx8ulp: clock: Add clock support for i3c controller
Clement Faure (2): misc: S400_API: add ahab_release_caam imx: imx8ulp: release CAAM for the Cortex-A35
Ji Luo (1): imx: imx8ulp: reserve tee memory
Peng Fan (10): imx: imx8ulp: include pcc/cgc header in clock header imx: imx8ulp: add CAAM clock entry imx: imx8ulp: add ND/LD clock imx: imx8ulp: enable MU0_B clk by default imx: dynamic setting mmcdev and mmcroot imx: imx8ulp_evk: Enable SD/MMC port auto detect imx: imx8ulp: enable wdog_ad interrupt in CMC1 imx: imx8ulp_evk: enlarge CONFIG_NR_DRAM_BANKS dt-bindings: power: imx8ulp: include power entry header misc: imx8ulp: Update fuse driver
Ye Li (13): imx: imx8ulp: Set COUNTER_FREQUENCY to 1Mhz imx: imx8ulp: Add M33 handshake functions imx: imx8ulp_evk: Remove PMIC Bucks PWM mode settings imx: imx8ulp_evk: Skip init DDR for reboot in dual boot mode imx: imx8ulp: cgc: Switch to NICLPAV to FRO192 before PLL4 init misc: imx8ulp: Add OEM SRK Hash fuse support imx: imx8ulp: Change LPAV assignment for dual boot imx: imx8ulp: Load the lposc fuse for dual boot misc: S400_API: Update S400 API for buffer dump imx: imx8ulp_evk: Update LPDDR4 PHY settings imx: imx8ulp_evk: call the handshake with M33 imx: imx8ulp_evk: Power down the domains may used in u-boot imx: imx8ulp_evk: Enable multiple env storage devices
arch/arm/include/asm/arch-imx8ulp/cgc.h | 8 +- arch/arm/include/asm/arch-imx8ulp/clock.h | 8 +- arch/arm/include/asm/arch-imx8ulp/imx-regs.h | 1 + arch/arm/include/asm/arch-imx8ulp/pcc.h | 1 + arch/arm/include/asm/arch-imx8ulp/s400_api.h | 5 +- arch/arm/include/asm/arch-imx8ulp/sys_proto.h | 2 + arch/arm/include/asm/mach-imx/sys_proto.h | 2 + arch/arm/mach-imx/imx8ulp/Kconfig | 7 + arch/arm/mach-imx/imx8ulp/cgc.c | 106 +- arch/arm/mach-imx/imx8ulp/clock.c | 101 +- arch/arm/mach-imx/imx8ulp/pcc.c | 1 + arch/arm/mach-imx/imx8ulp/soc.c | 197 ++- board/freescale/common/Makefile | 3 + board/freescale/common/mmc.c | 49 + board/freescale/imx8ulp_evk/Makefile | 7 +- board/freescale/imx8ulp_evk/imx8ulp_evk.c | 43 +- board/freescale/imx8ulp_evk/lpddr4_timing.c | 32 +- .../freescale/imx8ulp_evk/lpddr4_timing_266.c | 1109 +++++++++++++++++ board/freescale/imx8ulp_evk/spl.c | 59 +- configs/imx8ulp_evk_defconfig | 2 +- drivers/misc/imx8ulp/fuse.c | 4 +- drivers/misc/imx8ulp/s400_api.c | 63 + include/configs/imx8ulp_evk.h | 2 + include/dt-bindings/power/imx8ulp-power.h | 26 + 24 files changed, 1729 insertions(+), 109 deletions(-) create mode 100644 board/freescale/common/mmc.c create mode 100644 board/freescale/imx8ulp_evk/lpddr4_timing_266.c create mode 100644 include/dt-bindings/power/imx8ulp-power.h
The COUNTER_FREQUENCY is missed in 8ulp configs, it will cause SPL and u-boot not set the cntfrq_el0. For u-boot, this is ok, because ATF has set it. But for SPL, it will lead delay and get_timer not working.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/imx8ulp_evk.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 7da6802aa5..1baebedf00 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -27,6 +27,8 @@
#endif
+#define COUNTER_FREQUENCY 1000000 /* 1MHz */ + /* ENET Config */ #if defined(CONFIG_FEC_MXC) #define CONFIG_ETHPRIME "FEC"
Only including clock.h could simplify header files.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/clock.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8ulp/clock.h b/arch/arm/include/asm/arch-imx8ulp/clock.h index c0f32cc087..d7c92f7058 100644 --- a/arch/arm/include/asm/arch-imx8ulp/clock.h +++ b/arch/arm/include/asm/arch-imx8ulp/clock.h @@ -6,6 +6,9 @@ #ifndef _ASM_ARCH_IMX8ULP_CLOCK_H #define _ASM_ARCH_IMX8ULP_CLOCK_H
+#include <asm/arch/pcc.h> +#include <asm/arch/cgc.h> + /* Mainly for compatible to imx common code. */ enum mxc_clock { MXC_ARM_CLK = 0,
Sorry, I don't understand this commit log.
Please explain why you need to include these two header files.
No need to include pcc/cgc header file both for users, only need include clock.h
Thanks, Peng.
Add functions to check if M33 image is booted and handshake with M33 image via MU. A core notifies M33 to start init by FCR F0, then wait M33 init done signal by checking FSR F0.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Biwen Li biwen.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/imx-regs.h | 1 + arch/arm/include/asm/arch-imx8ulp/sys_proto.h | 2 ++ arch/arm/mach-imx/imx8ulp/soc.c | 36 +++++++++++++++++++ 3 files changed, 39 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8ulp/imx-regs.h b/arch/arm/include/asm/arch-imx8ulp/imx-regs.h index 91adc85525..723bab584c 100644 --- a/arch/arm/include/asm/arch-imx8ulp/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8ulp/imx-regs.h @@ -14,6 +14,7 @@
#define CMC0_RBASE 0x28025000
+#define MU0_B_BASE_ADDR 0x29220000 #define CMC1_BASE_ADDR 0x29240000
#define SIM1_BASE_ADDR 0x29290000 diff --git a/arch/arm/include/asm/arch-imx8ulp/sys_proto.h b/arch/arm/include/asm/arch-imx8ulp/sys_proto.h index 284ccafc98..5f030eaa0a 100644 --- a/arch/arm/include/asm/arch-imx8ulp/sys_proto.h +++ b/arch/arm/include/asm/arch-imx8ulp/sys_proto.h @@ -18,4 +18,6 @@ int xrdc_config_pdac_openacc(u32 bridge, u32 index); enum boot_device get_boot_device(void); void set_lpav_qos(void); void load_lposc_fuse(void); +bool m33_image_booted(void); +int m33_image_handshake(ulong timeout_ms); #endif diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index 934b0ef038..b9c146fc26 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -25,6 +25,7 @@ #include <dm/uclass-internal.h> #include <fuse.h> #include <thermal.h> +#include <linux/iopoll.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -136,6 +137,41 @@ enum bt_mode get_boot_mode(void) return LOW_POWER_BOOT; }
+bool m33_image_booted(void) +{ + u32 gp6; + + /* DGO_GP6 */ + gp6 = readl(SIM_SEC_BASE_ADDR + 0x28); + if (gp6 & BIT(5)) + return true; + + return false; +} + +int m33_image_handshake(ulong timeout_ms) +{ + u32 fsr; + int ret; + ulong timeout_us = timeout_ms * 1000; + + /* enable MU0_MUB clock before access the register of MU0_MUB */ + pcc_clock_enable(3, MU0_B_PCC3_SLOT, true); + + /* Notify m33 that it's ready to do init srtm(enable mu receive interrupt and so on) */ + setbits_le32(MU0_B_BASE_ADDR + 0x100, BIT(0)); /* set FCR F0 flag of MU0_MUB */ + + /* + * Wait m33 to set FCR F0 flag of MU0_MUA + * Clear FCR F0 flag of MU0_MUB after m33 has set FCR F0 flag of MU0_MUA + */ + ret = readl_poll_sleep_timeout(MU0_B_BASE_ADDR + 0x104, fsr, fsr & BIT(0), 10, timeout_us); + if (!ret) + clrbits_le32(MU0_B_BASE_ADDR + 0x100, BIT(0)); + + return ret; +} + #define CMC_SRS_TAMPER BIT(31) #define CMC_SRS_SECURITY BIT(30) #define CMC_SRS_TZWDG BIT(29)
Add i3c controller clock enable/disable function for imx8ulp.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Clark Wang xiaoning.wang@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/clock.c | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index 91580b2c29..6f52ccee34 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -237,6 +237,32 @@ u32 imx_get_i2cclk(u32 i2c_num) } #endif
+#if IS_ENABLED(CONFIG_SYS_I2C_IMX_I3C) +int enable_i3c_clk(unsigned char enable, u32 i3c_num) +{ + if (i3c_num != 8) + return -EINVAL; + + if (enable) { + pcc_clock_enable(3, I3C2_PCC3_SLOT, false); + pcc_clock_sel(3, I3C2_PCC3_SLOT, SOSC_DIV2); + pcc_clock_enable(3, I3C2_PCC3_SLOT, true); + pcc_reset_peripheral(3, I3C2_PCC3_SLOT, false); + } else { + pcc_clock_enable(3, I3C2_PCC3_SLOT, false); + } + return 0; +} + +u32 imx_get_i3cclk(u32 i3c_num) +{ + if (i3c_num != 8) + return 0; + + return pcc_clock_get_rate(3, I3C2_PCC3_SLOT); +} +#endif + void enable_usboh3_clk(unsigned char enable) { if (enable) {
if (i3c_num != 8)
What does this magic 8 mean? Please replace with some more meaningful define.
if (i3c_num != 8)
Same here.
Add CAAM clock entry in PCC3
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/pcc.h | 1 + arch/arm/mach-imx/imx8ulp/pcc.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8ulp/pcc.h b/arch/arm/include/asm/arch-imx8ulp/pcc.h index 46386f1aba..d9b2d7c299 100644 --- a/arch/arm/include/asm/arch-imx8ulp/pcc.h +++ b/arch/arm/include/asm/arch-imx8ulp/pcc.h @@ -52,6 +52,7 @@ enum pcc3_entry { UPOWER_PCC3_SLOT = 40, WDOG3_PCC3_SLOT = 42, WDOG4_PCC3_SLOT = 43, + CAAM_PCC3_SLOT = 46, XRDC_MGR_PCC3_SLOT = 47, SEMA42_1_PCC3_SLOT = 48, ROMCP1_PCC3_SLOT = 49, diff --git a/arch/arm/mach-imx/imx8ulp/pcc.c b/arch/arm/mach-imx/imx8ulp/pcc.c index 7909d770af..e3c6d6760b 100644 --- a/arch/arm/mach-imx/imx8ulp/pcc.c +++ b/arch/arm/mach-imx/imx8ulp/pcc.c @@ -135,6 +135,7 @@ static struct pcc_entry pcc3_arrays[] = { {PCC3_RBASE, UPOWER_PCC3_SLOT, CLKSRC_NO_PCS, PCC_NO_DIV, PCC_NO_RST_B}, {PCC3_RBASE, WDOG3_PCC3_SLOT, CLKSRC_PER_BUS, PCC_HAS_DIV, PCC_HAS_RST_B}, {PCC3_RBASE, WDOG4_PCC3_SLOT, CLKSRC_PER_BUS, PCC_HAS_DIV, PCC_HAS_RST_B}, + {PCC3_RBASE, CAAM_PCC3_SLOT, CLKSRC_NO_PCS, PCC_NO_DIV, PCC_HAS_RST_B}, {PCC3_RBASE, XRDC_MGR_PCC3_SLOT, CLKSRC_NO_PCS, PCC_NO_DIV, PCC_NO_RST_B}, {PCC3_RBASE, SEMA42_1_PCC3_SLOT, CLKSRC_PER_BUS, PCC_NO_DIV, PCC_NO_RST_B}, {PCC3_RBASE, ROMCP1_PCC3_SLOT, CLKSRC_NO_PCS, PCC_NO_DIV, PCC_NO_RST_B},
This workaround is not needed on i.MX8ULP proto-1B EVK as board has fixed the problem. Because we don't support proto-1A any longer, remove the PMIC settings.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/spl.c | 18 ------------------ 1 file changed, 18 deletions(-)
diff --git a/board/freescale/imx8ulp_evk/spl.c b/board/freescale/imx8ulp_evk/spl.c index c17d5eff7d..b314901409 100644 --- a/board/freescale/imx8ulp_evk/spl.c +++ b/board/freescale/imx8ulp_evk/spl.c @@ -35,24 +35,6 @@ u32 spl_boot_device(void)
int power_init_board(void) { - u32 pmic_reg; - - /* PMIC set bucks1-4 to PWM mode */ - upower_pmic_i2c_read(0x10, &pmic_reg); - upower_pmic_i2c_read(0x14, &pmic_reg); - upower_pmic_i2c_read(0x21, &pmic_reg); - upower_pmic_i2c_read(0x2e, &pmic_reg); - - upower_pmic_i2c_write(0x10, 0x3d); - upower_pmic_i2c_write(0x14, 0x7d); - upower_pmic_i2c_write(0x21, 0x7d); - upower_pmic_i2c_write(0x2e, 0x3d); - - upower_pmic_i2c_read(0x10, &pmic_reg); - upower_pmic_i2c_read(0x14, &pmic_reg); - upower_pmic_i2c_read(0x21, &pmic_reg); - upower_pmic_i2c_read(0x2e, &pmic_reg); - /* Set buck3 to 1.1v OD */ upower_pmic_i2c_write(0x22, 0x28); return 0;
Add a new ddr script, defconfig for ND Configure the clock for ND mode changing A35 to 960M for OD mode Update NIC CLK for the various modes Introduce clock_init_early/late, late is used after pmic voltage setting, early is used in the very early stage for upower mu, lpuart and etc.
Note: NIC runs at 324MHz, 442MHz has some random kernel hang issue with cpuidle enabled now.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/cgc.h | 6 +- arch/arm/include/asm/arch-imx8ulp/clock.h | 5 +- arch/arm/mach-imx/imx8ulp/Kconfig | 7 + arch/arm/mach-imx/imx8ulp/cgc.c | 78 +- arch/arm/mach-imx/imx8ulp/clock.c | 70 +- arch/arm/mach-imx/imx8ulp/soc.c | 2 +- board/freescale/imx8ulp_evk/Makefile | 7 +- .../freescale/imx8ulp_evk/lpddr4_timing_266.c | 1109 +++++++++++++++++ board/freescale/imx8ulp_evk/spl.c | 15 +- 9 files changed, 1252 insertions(+), 47 deletions(-) create mode 100644 board/freescale/imx8ulp_evk/lpddr4_timing_266.c
diff --git a/arch/arm/include/asm/arch-imx8ulp/cgc.h b/arch/arm/include/asm/arch-imx8ulp/cgc.h index ad3edc85ad..e45f04624d 100644 --- a/arch/arm/include/asm/arch-imx8ulp/cgc.h +++ b/arch/arm/include/asm/arch-imx8ulp/cgc.h @@ -146,10 +146,10 @@ struct cgc2_regs { };
u32 cgc_clk_get_rate(enum cgc_clk clk); -void cgc1_pll3_init(void); -void cgc1_pll2_init(void); +void cgc1_pll3_init(ulong freq); +void cgc1_pll2_init(ulong freq); void cgc1_soscdiv_init(void); -void cgc1_init_core_clk(void); +void cgc1_init_core_clk(ulong freq); void cgc2_pll4_init(void); void cgc2_ddrclk_config(u32 src, u32 div); void cgc2_ddrclk_wait_unlock(void); diff --git a/arch/arm/include/asm/arch-imx8ulp/clock.h b/arch/arm/include/asm/arch-imx8ulp/clock.h index d7c92f7058..2946cc1911 100644 --- a/arch/arm/include/asm/arch-imx8ulp/clock.h +++ b/arch/arm/include/asm/arch-imx8ulp/clock.h @@ -9,6 +9,8 @@ #include <asm/arch/pcc.h> #include <asm/arch/cgc.h>
+#define MHZ(X) ((X) * 1000000UL) + /* Mainly for compatible to imx common code. */ enum mxc_clock { MXC_ARM_CLK = 0, @@ -39,7 +41,8 @@ void init_clk_usdhc(u32 index); void init_clk_fspi(int index); void init_clk_ddr(void); int set_ddr_clk(u32 phy_freq_mhz); -void clock_init(void); +void clock_init_early(void); +void clock_init_late(void); void cgc1_enet_stamp_sel(u32 clk_src); void mxs_set_lcdclk(u32 base_addr, u32 freq_in_khz); void reset_lcdclk(void); diff --git a/arch/arm/mach-imx/imx8ulp/Kconfig b/arch/arm/mach-imx/imx8ulp/Kconfig index 963fc93d34..efbcaa5adc 100644 --- a/arch/arm/mach-imx/imx8ulp/Kconfig +++ b/arch/arm/mach-imx/imx8ulp/Kconfig @@ -7,6 +7,13 @@ config IMX8ULP config SYS_SOC default "imx8ulp"
+config IMX8ULP_LD_MODE + bool + default n + +config IMX8ULP_ND_MODE + bool "i.MX8ULP Low Driver Mode" + choice prompt "i.MX8ULP board select" optional diff --git a/arch/arm/mach-imx/imx8ulp/cgc.c b/arch/arm/mach-imx/imx8ulp/cgc.c index 38bcbb91e6..494ddb0f32 100644 --- a/arch/arm/mach-imx/imx8ulp/cgc.c +++ b/arch/arm/mach-imx/imx8ulp/cgc.c @@ -9,9 +9,11 @@ #include <errno.h> #include <asm/arch/imx-regs.h> #include <asm/arch/cgc.h> +#include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/global_data.h> #include <linux/delay.h> +#include <hang.h>
@@ -29,7 +31,7 @@ void cgc1_soscdiv_init(void) clrbits_le32(&cgc1_regs->frodiv, BIT(7)); }
-void cgc1_pll2_init(void) +void cgc1_pll2_init(ulong freq) { u32 reg;
@@ -44,8 +46,8 @@ void cgc1_pll2_init(void) while ((readl(&cgc1_regs->pll2csr) & BIT(24))) ;
- /* Select SOSC as source, freq = 31 * 24 =744mhz */ - reg = 31 << 16; + /* Select SOSC as source */ + reg = (freq / MHZ(24)) << 16; writel(reg, &cgc1_regs->pll2cfg);
/* Enable PLL2 */ @@ -74,7 +76,7 @@ static void cgc1_set_a35_clk(u32 clk_src, u32 div_core) ; }
-void cgc1_init_core_clk(void) +void cgc1_init_core_clk(ulong freq) { u32 reg = readl(&cgc1_regs->ca35clk);
@@ -82,8 +84,7 @@ void cgc1_init_core_clk(void) if (((reg >> 28) & 0x3) == 0x1) cgc1_set_a35_clk(0, 1);
- /* Set pll2 to 750Mhz for 1V */ - cgc1_pll2_init(); + cgc1_pll2_init(freq);
/* Set A35 clock to pll2 */ cgc1_set_a35_clk(1, 1); @@ -94,7 +95,7 @@ void cgc1_enet_stamp_sel(u32 clk_src) writel((clk_src & 0x7) << 24, &cgc1_regs->enetstamp); }
-void cgc1_pll3_init(void) +void cgc1_pll3_init(ulong freq) { /* Gate off VCO */ setbits_le32(&cgc1_regs->pll3div_vco, BIT(7)); @@ -115,11 +116,15 @@ void cgc1_pll3_init(void) /* Select SOSC as source */ clrbits_le32(&cgc1_regs->pll3cfg, BIT(0));
- //setbits_le32(&cgc1_regs->pll3cfg, 22 << 16); - writel(22 << 16, &cgc1_regs->pll3cfg); - - writel(578, &cgc1_regs->pll3num); - writel(1000, &cgc1_regs->pll3denom); + switch (freq) { + case 540672000: + writel(0x16 << 16, &cgc1_regs->pll3cfg); + writel(0x16e3600, &cgc1_regs->pll3denom); + writel(0xc15c00, &cgc1_regs->pll3num); + break; + default: + hang(); + }
/* Enable PLL3 */ setbits_le32(&cgc1_regs->pll3csr, BIT(0)); @@ -130,23 +135,30 @@ void cgc1_pll3_init(void) /* Gate on VCO */ clrbits_le32(&cgc1_regs->pll3div_vco, BIT(7));
- /* - * PFD0: 380MHz/396/396/328 - */ clrbits_le32(&cgc1_regs->pll3pfdcfg, 0x3F); - setbits_le32(&cgc1_regs->pll3pfdcfg, 25 << 0); + + if (IS_ENABLED(CONFIG_IMX8ULP_LD_MODE)) { + setbits_le32(&cgc1_regs->pll3pfdcfg, 25 << 0); + clrsetbits_le32(&cgc1_regs->nicclk, GENMASK(26, 21), 3 << 21); /* 195M */ + } else if (IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) { + setbits_le32(&cgc1_regs->pll3pfdcfg, 21 << 0); + clrsetbits_le32(&cgc1_regs->nicclk, GENMASK(26, 21), 1 << 21); /* 231M */ + } else { + setbits_le32(&cgc1_regs->pll3pfdcfg, 30 << 0); /* 324M */ + } + clrbits_le32(&cgc1_regs->pll3pfdcfg, BIT(7)); while (!(readl(&cgc1_regs->pll3pfdcfg) & BIT(6))) ;
clrbits_le32(&cgc1_regs->pll3pfdcfg, 0x3F << 8); - setbits_le32(&cgc1_regs->pll3pfdcfg, 24 << 8); + setbits_le32(&cgc1_regs->pll3pfdcfg, 25 << 8); clrbits_le32(&cgc1_regs->pll3pfdcfg, BIT(15)); while (!(readl(&cgc1_regs->pll3pfdcfg) & BIT(14))) ;
clrbits_le32(&cgc1_regs->pll3pfdcfg, 0x3F << 16); - setbits_le32(&cgc1_regs->pll3pfdcfg, 24 << 16); + setbits_le32(&cgc1_regs->pll3pfdcfg, 25 << 16); clrbits_le32(&cgc1_regs->pll3pfdcfg, BIT(23)); while (!(readl(&cgc1_regs->pll3pfdcfg) & BIT(22))) ; @@ -166,6 +178,13 @@ void cgc1_pll3_init(void) clrbits_le32(&cgc1_regs->pll3div_pfd1, BIT(15)); clrbits_le32(&cgc1_regs->pll3div_pfd1, BIT(23)); clrbits_le32(&cgc1_regs->pll3div_pfd1, BIT(31)); + + if (!IS_ENABLED(CONFIG_IMX8ULP_LD_MODE) && !IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) { + /* nicclk select pll3 pfd0 */ + clrsetbits_le32(&cgc1_regs->nicclk, GENMASK(29, 28), BIT(28)); + while (!(readl(&cgc1_regs->nicclk) & BIT(27))) + ; + } }
void cgc2_pll4_init(void) @@ -189,10 +208,21 @@ void cgc2_pll4_init(void) ;
/* Enable all 4 PFDs */ - setbits_le32(&cgc2_regs->pll4pfdcfg, 18 << 0); - setbits_le32(&cgc2_regs->pll4pfdcfg, 30 << 8); /* 316.8Mhz for NIC_LPAV */ - setbits_le32(&cgc2_regs->pll4pfdcfg, 12 << 16); - setbits_le32(&cgc2_regs->pll4pfdcfg, 24 << 24); + setbits_le32(&cgc2_regs->pll4pfdcfg, 18 << 0); /* 528 */ + if (IS_ENABLED(CONFIG_IMX8ULP_LD_MODE)) { + setbits_le32(&cgc2_regs->pll4pfdcfg, 24 << 8); + /* 99Mhz for NIC_LPAV */ + clrsetbits_le32(&cgc2_regs->niclpavclk, GENMASK(26, 21), 3 << 21); + } else if (IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) { + setbits_le32(&cgc2_regs->pll4pfdcfg, 24 << 8); + /* 198Mhz for NIC_LPAV */ + clrsetbits_le32(&cgc2_regs->niclpavclk, GENMASK(26, 21), 1 << 21); + } else { + setbits_le32(&cgc2_regs->pll4pfdcfg, 30 << 8); /* 316.8Mhz for NIC_LPAV */ + clrbits_le32(&cgc2_regs->niclpavclk, GENMASK(26, 21)); + } + setbits_le32(&cgc2_regs->pll4pfdcfg, 12 << 16); /* 792 */ + setbits_le32(&cgc2_regs->pll4pfdcfg, 24 << 24); /* 396 */
clrbits_le32(&cgc2_regs->pll4pfdcfg, BIT(7) | BIT(15) | BIT(23) | BIT(31));
@@ -203,6 +233,10 @@ void cgc2_pll4_init(void) /* Enable PFD DIV */ clrbits_le32(&cgc2_regs->pll4div_pfd0, BIT(7) | BIT(15) | BIT(23) | BIT(31)); clrbits_le32(&cgc2_regs->pll4div_pfd1, BIT(7) | BIT(15) | BIT(23) | BIT(31)); + + clrsetbits_le32(&cgc2_regs->niclpavclk, GENMASK(29, 28), BIT(28)); + while (!(readl(&cgc2_regs->niclpavclk) & BIT(27))) + ; }
void cgc2_pll4_pfd_config(enum cgc_clk pllpfd, u32 pfd) diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index 6f52ccee34..7c45a717be 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -102,7 +102,7 @@ void init_clk_ddr(void)
/* enable pll4 and ddrclk*/ cgc2_pll4_init(); - cgc2_ddrclk_config(1, 1); + cgc2_ddrclk_config(4, 1);
/* enable ddr pcc */ writel(0xd0000000, PCC5_LPDDR4_ADDR); @@ -153,30 +153,66 @@ int set_ddr_clk(u32 phy_freq_mhz) return 0; }
-void clock_init(void) +void clock_init_early(void) { cgc1_soscdiv_init(); - cgc1_init_core_clk();
init_clk_lpuart();
- pcc_clock_enable(4, SDHC0_PCC4_SLOT, false); - pcc_clock_sel(4, SDHC0_PCC4_SLOT, PLL3_PFD1_DIV2); - pcc_clock_enable(4, SDHC0_PCC4_SLOT, true); - pcc_reset_peripheral(4, SDHC0_PCC4_SLOT, false); + /* Enable upower mu1 clk */ + pcc_clock_enable(3, UPOWER_PCC3_SLOT, true); +}
- pcc_clock_enable(4, SDHC1_PCC4_SLOT, false); - pcc_clock_sel(4, SDHC1_PCC4_SLOT, PLL3_PFD2_DIV1); - pcc_clock_enable(4, SDHC1_PCC4_SLOT, true); - pcc_reset_peripheral(4, SDHC1_PCC4_SLOT, false); +/* This will be invoked after pmic voltage setting */ +void clock_init_late(void) +{
- pcc_clock_enable(4, SDHC2_PCC4_SLOT, false); - pcc_clock_sel(4, SDHC2_PCC4_SLOT, PLL3_PFD2_DIV1); - pcc_clock_enable(4, SDHC2_PCC4_SLOT, true); - pcc_reset_peripheral(4, SDHC2_PCC4_SLOT, false); + if (IS_ENABLED(CONFIG_IMX8ULP_LD_MODE)) + cgc1_init_core_clk(MHZ(500)); + else if (IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) + cgc1_init_core_clk(MHZ(750)); + else + cgc1_init_core_clk(MHZ(960));
- /* Enable upower mu1 clk */ - pcc_clock_enable(3, UPOWER_PCC3_SLOT, true); + /* + * Audio use this frequency in kernel dts, + * however nic use pll3 pfd0, we have to + * make the freqency same as kernel to make nic + * not being disabled + */ + cgc1_pll3_init(540672000); + + if (IS_ENABLED(CONFIG_IMX8ULP_LD_MODE) || IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) { + pcc_clock_enable(4, SDHC0_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC0_PCC4_SLOT, PLL3_PFD2_DIV2); + pcc_clock_enable(4, SDHC0_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC0_PCC4_SLOT, false); + + pcc_clock_enable(4, SDHC1_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC1_PCC4_SLOT, PLL3_PFD2_DIV2); + pcc_clock_enable(4, SDHC1_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC1_PCC4_SLOT, false); + + pcc_clock_enable(4, SDHC2_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC2_PCC4_SLOT, PLL3_PFD2_DIV2); + pcc_clock_enable(4, SDHC2_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC2_PCC4_SLOT, false); + } else { + pcc_clock_enable(4, SDHC0_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC0_PCC4_SLOT, PLL3_PFD1_DIV2); + pcc_clock_enable(4, SDHC0_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC0_PCC4_SLOT, false); + + pcc_clock_enable(4, SDHC1_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC1_PCC4_SLOT, PLL3_PFD2_DIV1); + pcc_clock_enable(4, SDHC1_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC1_PCC4_SLOT, false); + + pcc_clock_enable(4, SDHC2_PCC4_SLOT, false); + pcc_clock_sel(4, SDHC2_PCC4_SLOT, PLL3_PFD2_DIV1); + pcc_clock_enable(4, SDHC2_PCC4_SLOT, true); + pcc_reset_peripheral(4, SDHC2_PCC4_SLOT, false); + }
/* * Enable clock division diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index b9c146fc26..b4f0ca6a2e 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -596,7 +596,7 @@ int arch_cpu_init(void)
xrdc_mrc_region_set_access(2, CONFIG_SPL_TEXT_BASE, 0xE00);
- clock_init(); + clock_init_early(); } else { /* reconfigure core0 reset vector to ROM */ set_core0_reset_vector(0x1000); diff --git a/board/freescale/imx8ulp_evk/Makefile b/board/freescale/imx8ulp_evk/Makefile index b2e72b4e85..b6ca238de5 100644 --- a/board/freescale/imx8ulp_evk/Makefile +++ b/board/freescale/imx8ulp_evk/Makefile @@ -3,5 +3,10 @@ obj-y += imx8ulp_evk.o
ifdef CONFIG_SPL_BUILD -obj-y += spl.o ddr_init.o lpddr4_timing.o +obj-y += spl.o ddr_init.o +ifdef CONFIG_IMX8ULP_ND_MODE +obj-y += lpddr4_timing_264.o +else +obj-y += lpddr4_timing.o +endif endif diff --git a/board/freescale/imx8ulp_evk/lpddr4_timing_266.c b/board/freescale/imx8ulp_evk/lpddr4_timing_266.c new file mode 100644 index 0000000000..e48cb965c1 --- /dev/null +++ b/board/freescale/imx8ulp_evk/lpddr4_timing_266.c @@ -0,0 +1,1109 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright 2021 NXP + * + * Generated code from MX8ULP_DDR_tool + */ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> + +/** CTL settings **/ +struct dram_cfg_param ddr_ctl_cfg[] = { + { 0x2e060000, 0xb00 }, /* 0 */ + { 0x2e060028, 0x258100 }, /* 10 */ + { 0x2e06002c, 0x17702 }, /* 11 */ + { 0x2e060030, 0x5 }, /* 12 */ + { 0x2e060034, 0x61 }, /* 13 */ + { 0x2e060038, 0xce3f }, /* 14 */ + { 0x2e06003c, 0x80e70 }, /* 15 */ + { 0x2e060040, 0x5 }, /* 16 */ + { 0x2e060044, 0x210 }, /* 17 */ + { 0x2e060048, 0x19c7d }, /* 18 */ + { 0x2e06004c, 0x101cdf }, /* 19 */ + { 0x2e060050, 0x5 }, /* 20 */ + { 0x2e060054, 0x420 }, /* 21 */ + { 0x2e060058, 0x1010000 }, /* 22 */ + { 0x2e06005c, 0x1011001 }, /* 23 */ + { 0x2e060060, 0x10000 }, /* 24 */ + { 0x2e060064, 0x102 }, /* 25 */ + { 0x2e060068, 0xa }, /* 26 */ + { 0x2e06006c, 0x19 }, /* 27 */ + { 0x2e060078, 0x2020200 }, /* 30 */ + { 0x2e06007c, 0x160b }, /* 31 */ + { 0x2e060090, 0x10 }, /* 36 */ + { 0x2e0600a4, 0x40c040c }, /* 41 */ + { 0x2e0600a8, 0x8040614 }, /* 42 */ + { 0x2e0600ac, 0x604 }, /* 43 */ + { 0x2e0600b0, 0x3090003 }, /* 44 */ + { 0x2e0600b4, 0x40002 }, /* 45 */ + { 0x2e0600b8, 0xc0011 }, /* 46 */ + { 0x2e0600bc, 0xb0509 }, /* 47 */ + { 0x2e0600c0, 0x2106 }, /* 48 */ + { 0x2e0600c4, 0xa090017 }, /* 49 */ + { 0x2e0600c8, 0x8200016 }, /* 50 */ + { 0x2e0600cc, 0xa0a }, /* 51 */ + { 0x2e0600d0, 0x4000694 }, /* 52 */ + { 0x2e0600d4, 0xa0a0804 }, /* 53 */ + { 0x2e0600d8, 0x4002432 }, /* 54 */ + { 0x2e0600dc, 0xa0a0804 }, /* 55 */ + { 0x2e0600e0, 0x4004864 }, /* 56 */ + { 0x2e0600e4, 0x2030404 }, /* 57 */ + { 0x2e0600e8, 0x5040400 }, /* 58 */ + { 0x2e0600ec, 0x80b0a06 }, /* 59 */ + { 0x2e0600f0, 0x7010100 }, /* 60 */ + { 0x2e0600f4, 0x4150b }, /* 61 */ + { 0x2e0600fc, 0x1010000 }, /* 63 */ + { 0x2e060100, 0x1000000 }, /* 64 */ + { 0x2e060104, 0xe0403 }, /* 65 */ + { 0x2e060108, 0xb3 }, /* 66 */ + { 0x2e06010c, 0x4a }, /* 67 */ + { 0x2e060110, 0x3fd }, /* 68 */ + { 0x2e060114, 0x94 }, /* 69 */ + { 0x2e060118, 0x803 }, /* 70 */ + { 0x2e06011c, 0x5 }, /* 71 */ + { 0x2e060120, 0x70000 }, /* 72 */ + { 0x2e060124, 0x25000f }, /* 73 */ + { 0x2e060128, 0x4a0078 }, /* 74 */ + { 0x2e06012c, 0x4000f9 }, /* 75 */ + { 0x2e060130, 0x120103 }, /* 76 */ + { 0x2e060134, 0x50005 }, /* 77 */ + { 0x2e060138, 0x8070005 }, /* 78 */ + { 0x2e06013c, 0x505010d }, /* 79 */ + { 0x2e060140, 0x101030a }, /* 80 */ + { 0x2e060144, 0x30a0505 }, /* 81 */ + { 0x2e060148, 0x5050101 }, /* 82 */ + { 0x2e06014c, 0x1030a }, /* 83 */ + { 0x2e060150, 0xe000e }, /* 84 */ + { 0x2e060154, 0x4c004c }, /* 85 */ + { 0x2e060158, 0x980098 }, /* 86 */ + { 0x2e06015c, 0x3050505 }, /* 87 */ + { 0x2e060160, 0x3010403 }, /* 88 */ + { 0x2e060164, 0x4050505 }, /* 89 */ + { 0x2e060168, 0x3010403 }, /* 90 */ + { 0x2e06016c, 0x8050505 }, /* 91 */ + { 0x2e060170, 0x3010403 }, /* 92 */ + { 0x2e060174, 0x3010000 }, /* 93 */ + { 0x2e060178, 0x10000 }, /* 94 */ + { 0x2e060180, 0x1000000 }, /* 96 */ + { 0x2e060184, 0x80104002 }, /* 97 */ + { 0x2e060188, 0x40003 }, /* 98 */ + { 0x2e06018c, 0x40005 }, /* 99 */ + { 0x2e060190, 0x30000 }, /* 100 */ + { 0x2e060194, 0x50004 }, /* 101 */ + { 0x2e060198, 0x4 }, /* 102 */ + { 0x2e06019c, 0x40003 }, /* 103 */ + { 0x2e0601a0, 0x40005 }, /* 104 */ + { 0x2e0601a8, 0x2cc0 }, /* 106 */ + { 0x2e0601ac, 0x2cc0 }, /* 107 */ + { 0x2e0601b0, 0x2cc0 }, /* 108 */ + { 0x2e0601b4, 0x2cc0 }, /* 109 */ + { 0x2e0601b8, 0x2cc0 }, /* 110 */ + { 0x2e0601c0, 0x4e5 }, /* 112 */ + { 0x2e0601c4, 0xff40 }, /* 113 */ + { 0x2e0601c8, 0xff40 }, /* 114 */ + { 0x2e0601cc, 0xff40 }, /* 115 */ + { 0x2e0601d0, 0xff40 }, /* 116 */ + { 0x2e0601d4, 0xff40 }, /* 117 */ + { 0x2e0601dc, 0x1beb }, /* 119 */ + { 0x2e0601e0, 0x200c0 }, /* 120 */ + { 0x2e0601e4, 0x200c0 }, /* 121 */ + { 0x2e0601e8, 0x200c0 }, /* 122 */ + { 0x2e0601ec, 0x200c0 }, /* 123 */ + { 0x2e0601f0, 0x200c0 }, /* 124 */ + { 0x2e0601f8, 0x3815 }, /* 126 */ + { 0x2e06021c, 0x5000000 }, /* 135 */ + { 0x2e060220, 0x5030503 }, /* 136 */ + { 0x2e060224, 0x3 }, /* 137 */ + { 0x2e060228, 0x7010a09 }, /* 138 */ + { 0x2e06022c, 0xe0a09 }, /* 139 */ + { 0x2e060230, 0x10a0900 }, /* 140 */ + { 0x2e060234, 0xe0a0907 }, /* 141 */ + { 0x2e060238, 0xa090000 }, /* 142 */ + { 0x2e06023c, 0xa090701 }, /* 143 */ + { 0x2e060240, 0x101000e }, /* 144 */ + { 0x2e060244, 0x40003 }, /* 145 */ + { 0x2e060248, 0x7 }, /* 146 */ + { 0x2e060264, 0x4040100 }, /* 153 */ + { 0x2e060268, 0x1000000 }, /* 154 */ + { 0x2e06026c, 0x100000c0 }, /* 155 */ + { 0x2e060270, 0x100000c0 }, /* 156 */ + { 0x2e060274, 0x100000c0 }, /* 157 */ + { 0x2e06027c, 0x1600 }, /* 159 */ + { 0x2e060284, 0x1 }, /* 161 */ + { 0x2e060288, 0x2 }, /* 162 */ + { 0x2e06028c, 0x100e }, /* 163 */ + { 0x2e0602a4, 0xa0000 }, /* 169 */ + { 0x2e0602a8, 0xd0005 }, /* 170 */ + { 0x2e0602ac, 0x404 }, /* 171 */ + { 0x2e0602b0, 0xd }, /* 172 */ + { 0x2e0602b4, 0x1b0035 }, /* 173 */ + { 0x2e0602b8, 0x4040042 }, /* 174 */ + { 0x2e0602bc, 0x42 }, /* 175 */ + { 0x2e0602c0, 0x35006a }, /* 176 */ + { 0x2e0602c4, 0x4040084 }, /* 177 */ + { 0x2e0602c8, 0x84 }, /* 178 */ + { 0x2e0602d8, 0x40004 }, /* 182 */ + { 0x2e0602dc, 0x30000914 }, /* 183 */ + { 0x2e0602e0, 0x3030 }, /* 184 */ + { 0x2e0602e4, 0x44440000 }, /* 185 */ + { 0x2e0602e8, 0x19191944 }, /* 186 */ + { 0x2e0602ec, 0x19191908 }, /* 187 */ + { 0x2e0602f0, 0x4000000 }, /* 188 */ + { 0x2e0602f4, 0x40404 }, /* 189 */ + { 0x2e0602f8, 0x9140004 }, /* 190 */ + { 0x2e0602fc, 0x30303000 }, /* 191 */ + { 0x2e060304, 0x19444444 }, /* 193 */ + { 0x2e060308, 0x19081919 }, /* 194 */ + { 0x2e06030c, 0x1919 }, /* 195 */ + { 0x2e060310, 0x4040400 }, /* 196 */ + { 0x2e060314, 0x1010120 }, /* 197 */ + { 0x2e060318, 0x1000100 }, /* 198 */ + { 0x2e06031c, 0x1 }, /* 199 */ + { 0x2e060324, 0x1000000 }, /* 201 */ + { 0x2e060328, 0x1 }, /* 202 */ + { 0x2e060354, 0x11000000 }, /* 213 */ + { 0x2e060358, 0x40c1815 }, /* 214 */ + { 0x2e060390, 0x30000 }, /* 228 */ + { 0x2e060394, 0x1000200 }, /* 229 */ + { 0x2e060398, 0x310040 }, /* 230 */ + { 0x2e06039c, 0x20002 }, /* 231 */ + { 0x2e0603a0, 0x400100 }, /* 232 */ + { 0x2e0603a4, 0x80108 }, /* 233 */ + { 0x2e0603a8, 0x1000200 }, /* 234 */ + { 0x2e0603ac, 0x2100040 }, /* 235 */ + { 0x2e0603b0, 0x10 }, /* 236 */ + { 0x2e0603b4, 0xe0003 }, /* 237 */ + { 0x2e0603b8, 0x100001b }, /* 238 */ + { 0x2e0603d8, 0xffff0b00 }, /* 246 */ + { 0x2e0603dc, 0x1010001 }, /* 247 */ + { 0x2e0603e0, 0x1010101 }, /* 248 */ + { 0x2e0603e4, 0x10b0101 }, /* 249 */ + { 0x2e0603e8, 0x10000 }, /* 250 */ + { 0x2e0603ec, 0x4010101 }, /* 251 */ + { 0x2e0603f0, 0x1010000 }, /* 252 */ + { 0x2e0603f4, 0x4 }, /* 253 */ + { 0x2e0603fc, 0x3030101 }, /* 255 */ + { 0x2e060400, 0x103 }, /* 256 */ + { 0x2e0604a4, 0x2020101 }, /* 297 */ + { 0x2e0604a8, 0x10100 }, /* 298 */ + { 0x2e0604ac, 0x1000101 }, /* 299 */ + { 0x2e0604b0, 0x1010101 }, /* 300 */ + { 0x2e0604b4, 0x4030300 }, /* 301 */ + { 0x2e0604b8, 0x8080505 }, /* 302 */ + { 0x2e0604bc, 0x8020808 }, /* 303 */ + { 0x2e0604c0, 0x8020e00 }, /* 304 */ + { 0x2e0604c4, 0xa020e00 }, /* 305 */ + { 0x2e0604c8, 0x8000f00 }, /* 306 */ + { 0x2e0604cc, 0xa08 }, /* 307 */ + { 0x2e0604d0, 0x1010101 }, /* 308 */ + { 0x2e0604d4, 0x102 }, /* 309 */ + { 0x2e0604d8, 0x404 }, /* 310 */ + { 0x2e0604dc, 0x40400 }, /* 311 */ + { 0x2e0604e0, 0x4040000 }, /* 312 */ + { 0x2e0604e4, 0x4000000 }, /* 313 */ + { 0x2e0604e8, 0x10004 }, /* 314 */ + { 0x2e0604f0, 0xfffff }, /* 316 */ + { 0x2e0604f8, 0xfffff }, /* 318 */ + { 0x2e060500, 0xfffff }, /* 320 */ + { 0x2e060508, 0xfffff }, /* 322 */ + { 0x2e060510, 0xfffff }, /* 324 */ + { 0x2e060518, 0xfffff }, /* 326 */ + { 0x2e060520, 0xfffff }, /* 328 */ + { 0x2e060528, 0xfffff }, /* 330 */ + { 0x2e060530, 0xfffff }, /* 332 */ + { 0x2e060538, 0xfffff }, /* 334 */ + { 0x2e060540, 0xfffff }, /* 336 */ + { 0x2e060548, 0xfffff }, /* 338 */ + { 0x2e060550, 0xfffff }, /* 340 */ + { 0x2e060558, 0xfffff }, /* 342 */ + { 0x2e060560, 0xfffff }, /* 344 */ + { 0x2e060568, 0xfffff }, /* 346 */ + { 0x2e060570, 0xfffff }, /* 348 */ + { 0x2e060578, 0xfffff }, /* 350 */ + { 0x2e060580, 0xfffff }, /* 352 */ + { 0x2e060588, 0xfffff }, /* 354 */ + { 0x2e060590, 0xfffff }, /* 356 */ + { 0x2e060598, 0xfffff }, /* 358 */ + { 0x2e0605a0, 0xfffff }, /* 360 */ + { 0x2e0605a8, 0xfffff }, /* 362 */ + { 0x2e0605b0, 0xfffff }, /* 364 */ + { 0x2e0605b8, 0xfffff }, /* 366 */ + { 0x2e0605c0, 0xfffff }, /* 368 */ + { 0x2e0605c8, 0xfffff }, /* 370 */ + { 0x2e0605d0, 0xfffff }, /* 372 */ + { 0x2e0605d8, 0xfffff }, /* 374 */ + { 0x2e0605e0, 0xfffff }, /* 376 */ + { 0x2e0605e8, 0xfffff }, /* 378 */ + { 0x2e0605f0, 0xfffff }, /* 380 */ + { 0x2e0605f8, 0xfffff }, /* 382 */ + { 0x2e060600, 0xfffff }, /* 384 */ + { 0x2e060608, 0xfffff }, /* 386 */ + { 0x2e060610, 0xfffff }, /* 388 */ + { 0x2e060618, 0xfffff }, /* 390 */ + { 0x2e060620, 0xfffff }, /* 392 */ + { 0x2e060628, 0xfffff }, /* 394 */ + { 0x2e060630, 0xfffff }, /* 396 */ + { 0x2e060638, 0xfffff }, /* 398 */ + { 0x2e060640, 0xfffff }, /* 400 */ + { 0x2e060648, 0xfffff }, /* 402 */ + { 0x2e060650, 0xfffff }, /* 404 */ + { 0x2e060658, 0xfffff }, /* 406 */ + { 0x2e060660, 0xfffff }, /* 408 */ + { 0x2e060668, 0xfffff }, /* 410 */ + { 0x2e060670, 0xfffff }, /* 412 */ + { 0x2e060678, 0xfffff }, /* 414 */ + { 0x2e060680, 0xfffff }, /* 416 */ + { 0x2e060688, 0xfffff }, /* 418 */ + { 0x2e060690, 0xfffff }, /* 420 */ + { 0x2e060698, 0xfffff }, /* 422 */ + { 0x2e0606a0, 0xfffff }, /* 424 */ + { 0x2e0606a8, 0xfffff }, /* 426 */ + { 0x2e0606b0, 0xfffff }, /* 428 */ + { 0x2e0606b8, 0xfffff }, /* 430 */ + { 0x2e0606c0, 0xfffff }, /* 432 */ + { 0x2e0606c8, 0xfffff }, /* 434 */ + { 0x2e0606d0, 0xfffff }, /* 436 */ + { 0x2e0606d8, 0xfffff }, /* 438 */ + { 0x2e0606e0, 0xfffff }, /* 440 */ + { 0x2e0606e8, 0x30fffff }, /* 442 */ + { 0x2e0606ec, 0xffffffff }, /* 443 */ + { 0x2e0606f0, 0x30f0f }, /* 444 */ + { 0x2e0606f4, 0xffffffff }, /* 445 */ + { 0x2e0606f8, 0x30f0f }, /* 446 */ + { 0x2e0606fc, 0xffffffff }, /* 447 */ + { 0x2e060700, 0x30f0f }, /* 448 */ + { 0x2e060704, 0xffffffff }, /* 449 */ + { 0x2e060708, 0x30f0f }, /* 450 */ + { 0x2e06070c, 0xffffffff }, /* 451 */ + { 0x2e060710, 0x30f0f }, /* 452 */ + { 0x2e060714, 0xffffffff }, /* 453 */ + { 0x2e060718, 0x30f0f }, /* 454 */ + { 0x2e06071c, 0xffffffff }, /* 455 */ + { 0x2e060720, 0x30f0f }, /* 456 */ + { 0x2e060724, 0xffffffff }, /* 457 */ + { 0x2e060728, 0x30f0f }, /* 458 */ + { 0x2e06072c, 0xffffffff }, /* 459 */ + { 0x2e060730, 0x30f0f }, /* 460 */ + { 0x2e060734, 0xffffffff }, /* 461 */ + { 0x2e060738, 0x30f0f }, /* 462 */ + { 0x2e06073c, 0xffffffff }, /* 463 */ + { 0x2e060740, 0x30f0f }, /* 464 */ + { 0x2e060744, 0xffffffff }, /* 465 */ + { 0x2e060748, 0x30f0f }, /* 466 */ + { 0x2e06074c, 0xffffffff }, /* 467 */ + { 0x2e060750, 0x30f0f }, /* 468 */ + { 0x2e060754, 0xffffffff }, /* 469 */ + { 0x2e060758, 0x30f0f }, /* 470 */ + { 0x2e06075c, 0xffffffff }, /* 471 */ + { 0x2e060760, 0x30f0f }, /* 472 */ + { 0x2e060764, 0xffffffff }, /* 473 */ + { 0x2e060768, 0x30f0f }, /* 474 */ + { 0x2e06076c, 0xffffffff }, /* 475 */ + { 0x2e060770, 0x30f0f }, /* 476 */ + { 0x2e060774, 0xffffffff }, /* 477 */ + { 0x2e060778, 0x30f0f }, /* 478 */ + { 0x2e06077c, 0xffffffff }, /* 479 */ + { 0x2e060780, 0x30f0f }, /* 480 */ + { 0x2e060784, 0xffffffff }, /* 481 */ + { 0x2e060788, 0x30f0f }, /* 482 */ + { 0x2e06078c, 0xffffffff }, /* 483 */ + { 0x2e060790, 0x30f0f }, /* 484 */ + { 0x2e060794, 0xffffffff }, /* 485 */ + { 0x2e060798, 0x30f0f }, /* 486 */ + { 0x2e06079c, 0xffffffff }, /* 487 */ + { 0x2e0607a0, 0x30f0f }, /* 488 */ + { 0x2e0607a4, 0xffffffff }, /* 489 */ + { 0x2e0607a8, 0x30f0f }, /* 490 */ + { 0x2e0607ac, 0xffffffff }, /* 491 */ + { 0x2e0607b0, 0x30f0f }, /* 492 */ + { 0x2e0607b4, 0xffffffff }, /* 493 */ + { 0x2e0607b8, 0x30f0f }, /* 494 */ + { 0x2e0607bc, 0xffffffff }, /* 495 */ + { 0x2e0607c0, 0x30f0f }, /* 496 */ + { 0x2e0607c4, 0xffffffff }, /* 497 */ + { 0x2e0607c8, 0x30f0f }, /* 498 */ + { 0x2e0607cc, 0xffffffff }, /* 499 */ + { 0x2e0607d0, 0x30f0f }, /* 500 */ + { 0x2e0607d4, 0xffffffff }, /* 501 */ + { 0x2e0607d8, 0x30f0f }, /* 502 */ + { 0x2e0607dc, 0xffffffff }, /* 503 */ + { 0x2e0607e0, 0x30f0f }, /* 504 */ + { 0x2e0607e4, 0xffffffff }, /* 505 */ + { 0x2e0607e8, 0x30f0f }, /* 506 */ + { 0x2e0607ec, 0xffffffff }, /* 507 */ + { 0x2e0607f0, 0x30f0f }, /* 508 */ + { 0x2e0607f4, 0xffffffff }, /* 509 */ + { 0x2e0607f8, 0x30f0f }, /* 510 */ + { 0x2e0607fc, 0xffffffff }, /* 511 */ + { 0x2e060800, 0x30f0f }, /* 512 */ + { 0x2e060804, 0xffffffff }, /* 513 */ + { 0x2e060808, 0x30f0f }, /* 514 */ + { 0x2e06080c, 0xffffffff }, /* 515 */ + { 0x2e060810, 0x30f0f }, /* 516 */ + { 0x2e060814, 0xffffffff }, /* 517 */ + { 0x2e060818, 0x30f0f }, /* 518 */ + { 0x2e06081c, 0xffffffff }, /* 519 */ + { 0x2e060820, 0x30f0f }, /* 520 */ + { 0x2e060824, 0xffffffff }, /* 521 */ + { 0x2e060828, 0x30f0f }, /* 522 */ + { 0x2e06082c, 0xffffffff }, /* 523 */ + { 0x2e060830, 0x30f0f }, /* 524 */ + { 0x2e060834, 0xffffffff }, /* 525 */ + { 0x2e060838, 0x30f0f }, /* 526 */ + { 0x2e06083c, 0xffffffff }, /* 527 */ + { 0x2e060840, 0x30f0f }, /* 528 */ + { 0x2e060844, 0xffffffff }, /* 529 */ + { 0x2e060848, 0x30f0f }, /* 530 */ + { 0x2e06084c, 0xffffffff }, /* 531 */ + { 0x2e060850, 0x30f0f }, /* 532 */ + { 0x2e060854, 0xffffffff }, /* 533 */ + { 0x2e060858, 0x30f0f }, /* 534 */ + { 0x2e06085c, 0xffffffff }, /* 535 */ + { 0x2e060860, 0x30f0f }, /* 536 */ + { 0x2e060864, 0xffffffff }, /* 537 */ + { 0x2e060868, 0x30f0f }, /* 538 */ + { 0x2e06086c, 0xffffffff }, /* 539 */ + { 0x2e060870, 0x30f0f }, /* 540 */ + { 0x2e060874, 0xffffffff }, /* 541 */ + { 0x2e060878, 0x30f0f }, /* 542 */ + { 0x2e06087c, 0xffffffff }, /* 543 */ + { 0x2e060880, 0x30f0f }, /* 544 */ + { 0x2e060884, 0xffffffff }, /* 545 */ + { 0x2e060888, 0x30f0f }, /* 546 */ + { 0x2e06088c, 0xffffffff }, /* 547 */ + { 0x2e060890, 0x30f0f }, /* 548 */ + { 0x2e060894, 0xffffffff }, /* 549 */ + { 0x2e060898, 0x30f0f }, /* 550 */ + { 0x2e06089c, 0xffffffff }, /* 551 */ + { 0x2e0608a0, 0x30f0f }, /* 552 */ + { 0x2e0608a4, 0xffffffff }, /* 553 */ + { 0x2e0608a8, 0x30f0f }, /* 554 */ + { 0x2e0608ac, 0xffffffff }, /* 555 */ + { 0x2e0608b0, 0x30f0f }, /* 556 */ + { 0x2e0608b4, 0xffffffff }, /* 557 */ + { 0x2e0608b8, 0x30f0f }, /* 558 */ + { 0x2e0608bc, 0xffffffff }, /* 559 */ + { 0x2e0608c0, 0x30f0f }, /* 560 */ + { 0x2e0608c4, 0xffffffff }, /* 561 */ + { 0x2e0608c8, 0x30f0f }, /* 562 */ + { 0x2e0608cc, 0xffffffff }, /* 563 */ + { 0x2e0608d0, 0x30f0f }, /* 564 */ + { 0x2e0608d4, 0xffffffff }, /* 565 */ + { 0x2e0608d8, 0x30f0f }, /* 566 */ + { 0x2e0608dc, 0xffffffff }, /* 567 */ + { 0x2e0608e0, 0x30f0f }, /* 568 */ + { 0x2e0608e4, 0xffffffff }, /* 569 */ + { 0x2e0608e8, 0x32070f0f }, /* 570 */ + { 0x2e0608ec, 0x1320001 }, /* 571 */ + { 0x2e0608f0, 0x13200 }, /* 572 */ + { 0x2e0608f4, 0x132 }, /* 573 */ + { 0x2e0608fc, 0x1d1b0000 }, /* 575 */ + { 0x2e060900, 0x21 }, /* 576 */ + { 0x2e060904, 0xa }, /* 577 */ + { 0x2e060908, 0x166 }, /* 578 */ + { 0x2e06090c, 0x200 }, /* 579 */ + { 0x2e060910, 0x200 }, /* 580 */ + { 0x2e060914, 0x200 }, /* 581 */ + { 0x2e060918, 0x200 }, /* 582 */ + { 0x2e06091c, 0x432 }, /* 583 */ + { 0x2e060920, 0xdfc }, /* 584 */ + { 0x2e060924, 0x204 }, /* 585 */ + { 0x2e060928, 0x7fa }, /* 586 */ + { 0x2e06092c, 0x200 }, /* 587 */ + { 0x2e060930, 0x200 }, /* 588 */ + { 0x2e060934, 0x200 }, /* 589 */ + { 0x2e060938, 0x200 }, /* 590 */ + { 0x2e06093c, 0x17ee }, /* 591 */ + { 0x2e060940, 0x4fc4 }, /* 592 */ + { 0x2e060944, 0x204 }, /* 593 */ + { 0x2e060948, 0x1006 }, /* 594 */ + { 0x2e06094c, 0x200 }, /* 595 */ + { 0x2e060950, 0x200 }, /* 596 */ + { 0x2e060954, 0x200 }, /* 597 */ + { 0x2e060958, 0x200 }, /* 598 */ + { 0x2e06095c, 0x3012 }, /* 599 */ + { 0x2e060960, 0xa03c }, /* 600 */ + { 0x2e060964, 0x2020406 }, /* 601 */ + { 0x2e060968, 0x2030202 }, /* 602 */ + { 0x2e06096c, 0x1000202 }, /* 603 */ + { 0x2e060970, 0x3040100 }, /* 604 */ + { 0x2e060974, 0x10105 }, /* 605 */ + { 0x2e060978, 0x10101 }, /* 606 */ + { 0x2e06097c, 0x10101 }, /* 607 */ + { 0x2e060980, 0x10001 }, /* 608 */ + { 0x2e060984, 0x101 }, /* 609 */ + { 0x2e060988, 0x2000201 }, /* 610 */ + { 0x2e06098c, 0x2010000 }, /* 611 */ + { 0x2e060990, 0x6000200 }, /* 612 */ + { 0x2e060994, 0x3000a06 }, /* 613 */ + { 0x2e060998, 0x2000c06 }, /* 614 */ +}; + +/** PI settings **/ +struct dram_cfg_param ddr_pi_cfg[] = { + { 0x2e062000, 0xb00 }, /* 0 */ + { 0x2e062004, 0xbeedb66f }, /* 1 */ + { 0x2e062008, 0xabef6bd }, /* 2 */ + { 0x2e06200c, 0x1001387 }, /* 3 */ + { 0x2e062010, 0x1 }, /* 4 */ + { 0x2e062014, 0x10064 }, /* 5 */ + { 0x2e06202c, 0x101 }, /* 11 */ + { 0x2e062030, 0x3 }, /* 12 */ + { 0x2e062034, 0x50001 }, /* 13 */ + { 0x2e062038, 0x3030800 }, /* 14 */ + { 0x2e06203c, 0x1 }, /* 15 */ + { 0x2e062040, 0x5 }, /* 16 */ + { 0x2e062064, 0x1000000 }, /* 25 */ + { 0x2e062068, 0xa000001 }, /* 26 */ + { 0x2e06206c, 0x28 }, /* 27 */ + { 0x2e062070, 0x1 }, /* 28 */ + { 0x2e062074, 0x320005 }, /* 29 */ + { 0x2e062080, 0x10102 }, /* 32 */ + { 0x2e062084, 0x1 }, /* 33 */ + { 0x2e062088, 0xaa }, /* 34 */ + { 0x2e06208c, 0x55 }, /* 35 */ + { 0x2e062090, 0xb5 }, /* 36 */ + { 0x2e062094, 0x4a }, /* 37 */ + { 0x2e062098, 0x56 }, /* 38 */ + { 0x2e06209c, 0xa9 }, /* 39 */ + { 0x2e0620a0, 0xa9 }, /* 40 */ + { 0x2e0620a4, 0xb5 }, /* 41 */ + { 0x2e0620a8, 0x10000 }, /* 42 */ + { 0x2e0620ac, 0x100 }, /* 43 */ + { 0x2e0620b0, 0x5050000 }, /* 44 */ + { 0x2e0620b4, 0x13 }, /* 45 */ + { 0x2e0620b8, 0x7d0 }, /* 46 */ + { 0x2e0620bc, 0x300 }, /* 47 */ + { 0x2e0620c8, 0x1000000 }, /* 50 */ + { 0x2e0620cc, 0x10101 }, /* 51 */ + { 0x2e0620d8, 0x10003 }, /* 54 */ + { 0x2e0620dc, 0x170500 }, /* 55 */ + { 0x2e0620ec, 0xa140a01 }, /* 59 */ + { 0x2e0620f0, 0x204010a }, /* 60 */ + { 0x2e0620f4, 0x21010 }, /* 61 */ + { 0x2e0620f8, 0x40401 }, /* 62 */ + { 0x2e0620fc, 0x10e0005 }, /* 63 */ + { 0x2e062100, 0x5000001 }, /* 64 */ + { 0x2e062104, 0x204 }, /* 65 */ + { 0x2e062108, 0x34 }, /* 66 */ + { 0x2e062114, 0x1000000 }, /* 69 */ + { 0x2e062118, 0x1000000 }, /* 70 */ + { 0x2e06211c, 0x80200 }, /* 71 */ + { 0x2e062120, 0x2000200 }, /* 72 */ + { 0x2e062124, 0x1000100 }, /* 73 */ + { 0x2e062128, 0x1000000 }, /* 74 */ + { 0x2e06212c, 0x2000200 }, /* 75 */ + { 0x2e062130, 0x200 }, /* 76 */ + { 0x2e062164, 0x400 }, /* 89 */ + { 0x2e062168, 0x2010000 }, /* 90 */ + { 0x2e06216c, 0x80103 }, /* 91 */ + { 0x2e062174, 0x10008 }, /* 93 */ + { 0x2e06217c, 0xaa00 }, /* 95 */ + { 0x2e062188, 0x10000 }, /* 98 */ + { 0x2e0621ec, 0x8 }, /* 123 */ + { 0x2e062218, 0xf0000 }, /* 134 */ + { 0x2e06221c, 0xa }, /* 135 */ + { 0x2e062220, 0x19 }, /* 136 */ + { 0x2e062224, 0x100 }, /* 137 */ + { 0x2e062228, 0x100 }, /* 138 */ + { 0x2e062238, 0x1000000 }, /* 142 */ + { 0x2e06223c, 0x10003 }, /* 143 */ + { 0x2e062240, 0x2000101 }, /* 144 */ + { 0x2e062244, 0x1030001 }, /* 145 */ + { 0x2e062248, 0x10400 }, /* 146 */ + { 0x2e06224c, 0x6000105 }, /* 147 */ + { 0x2e062250, 0x1070001 }, /* 148 */ + { 0x2e062260, 0x10001 }, /* 152 */ + { 0x2e062274, 0x401 }, /* 157 */ + { 0x2e06227c, 0x10000 }, /* 159 */ + { 0x2e062284, 0x6010000 }, /* 161 */ + { 0x2e062288, 0xb }, /* 162 */ + { 0x2e06228c, 0x34 }, /* 163 */ + { 0x2e062290, 0x36 }, /* 164 */ + { 0x2e062294, 0x2003c }, /* 165 */ + { 0x2e062298, 0x2000200 }, /* 166 */ + { 0x2e06229c, 0xc040c04 }, /* 167 */ + { 0x2e0622a0, 0xe1406 }, /* 168 */ + { 0x2e0622a4, 0xb3 }, /* 169 */ + { 0x2e0622a8, 0x4a }, /* 170 */ + { 0x2e0622ac, 0x3fd }, /* 171 */ + { 0x2e0622b0, 0x94 }, /* 172 */ + { 0x2e0622b4, 0x4000803 }, /* 173 */ + { 0x2e0622b8, 0x1010404 }, /* 174 */ + { 0x2e0622bc, 0x1501 }, /* 175 */ + { 0x2e0622c0, 0x1a0018 }, /* 176 */ + { 0x2e0622c4, 0x1000100 }, /* 177 */ + { 0x2e0622c8, 0x100 }, /* 178 */ + { 0x2e0622d0, 0x5040303 }, /* 180 */ + { 0x2e0622d4, 0x1010805 }, /* 181 */ + { 0x2e0622d8, 0x1010101 }, /* 182 */ + { 0x2e0622e8, 0x2060404 }, /* 186 */ + { 0x2e0622ec, 0x2020402 }, /* 187 */ + { 0x2e0622f0, 0x3102 }, /* 188 */ + { 0x2e0622f4, 0x340009 }, /* 189 */ + { 0x2e0622f8, 0x36000c }, /* 190 */ + { 0x2e0622fc, 0x101000e }, /* 191 */ + { 0x2e062300, 0xd0101 }, /* 192 */ + { 0x2e062304, 0x1004201 }, /* 193 */ + { 0x2e062308, 0x1000084 }, /* 194 */ + { 0x2e06230c, 0xe000e }, /* 195 */ + { 0x2e062310, 0x430100 }, /* 196 */ + { 0x2e062314, 0x1000043 }, /* 197 */ + { 0x2e062318, 0x850085 }, /* 198 */ + { 0x2e06231c, 0x220f220f }, /* 199 */ + { 0x2e062320, 0x101220f }, /* 200 */ + { 0x2e062324, 0xa070601 }, /* 201 */ + { 0x2e062328, 0xa07060d }, /* 202 */ + { 0x2e06232c, 0xa07070d }, /* 203 */ + { 0x2e062330, 0xc00d }, /* 204 */ + { 0x2e062334, 0xc01000 }, /* 205 */ + { 0x2e062338, 0xc01000 }, /* 206 */ + { 0x2e06233c, 0x21000 }, /* 207 */ + { 0x2e062340, 0x11000d }, /* 208 */ + { 0x2e062344, 0x140042 }, /* 209 */ + { 0x2e062348, 0x190084 }, /* 210 */ + { 0x2e06234c, 0x220f0056 }, /* 211 */ + { 0x2e062350, 0x101 }, /* 212 */ + { 0x2e062354, 0x560019 }, /* 213 */ + { 0x2e062358, 0x101220f }, /* 214 */ + { 0x2e06235c, 0x1b00 }, /* 215 */ + { 0x2e062360, 0x220f0056 }, /* 216 */ + { 0x2e062364, 0x8000101 }, /* 217 */ + { 0x2e062368, 0x4090403 }, /* 218 */ + { 0x2e06236c, 0x5eb }, /* 219 */ + { 0x2e062370, 0x20010003 }, /* 220 */ + { 0x2e062374, 0x80a0a03 }, /* 221 */ + { 0x2e062378, 0x6090506 }, /* 222 */ + { 0x2e06237c, 0x2093 }, /* 223 */ + { 0x2e062380, 0x2001000c }, /* 224 */ + { 0x2e062384, 0x80a0a04 }, /* 225 */ + { 0x2e062388, 0xb090a0c }, /* 226 */ + { 0x2e06238c, 0x4126 }, /* 227 */ + { 0x2e062390, 0x20020017 }, /* 228 */ + { 0x2e062394, 0xa0a08 }, /* 229 */ + { 0x2e062398, 0x166 }, /* 230 */ + { 0x2e06239c, 0xdfc }, /* 231 */ + { 0x2e0623a0, 0x7fa }, /* 232 */ + { 0x2e0623a4, 0x4fc4 }, /* 233 */ + { 0x2e0623a8, 0x1006 }, /* 234 */ + { 0x2e0623ac, 0xa03c }, /* 235 */ + { 0x2e0623b0, 0x4c000e }, /* 236 */ + { 0x2e0623b4, 0x3030098 }, /* 237 */ + { 0x2e0623b8, 0x258103 }, /* 238 */ + { 0x2e0623bc, 0x17702 }, /* 239 */ + { 0x2e0623c0, 0x5 }, /* 240 */ + { 0x2e0623c4, 0x61 }, /* 241 */ + { 0x2e0623c8, 0xe }, /* 242 */ + { 0x2e0623cc, 0xce3f }, /* 243 */ + { 0x2e0623d0, 0x80e70 }, /* 244 */ + { 0x2e0623d4, 0x5 }, /* 245 */ + { 0x2e0623d8, 0x210 }, /* 246 */ + { 0x2e0623dc, 0x4c }, /* 247 */ + { 0x2e0623e0, 0x19c7d }, /* 248 */ + { 0x2e0623e4, 0x101cdf }, /* 249 */ + { 0x2e0623e8, 0x5 }, /* 250 */ + { 0x2e0623ec, 0x420 }, /* 251 */ + { 0x2e0623f0, 0x1000098 }, /* 252 */ + { 0x2e0623f4, 0x310040 }, /* 253 */ + { 0x2e0623f8, 0x10002 }, /* 254 */ + { 0x2e0623fc, 0x1080040 }, /* 255 */ + { 0x2e062400, 0x10008 }, /* 256 */ + { 0x2e062404, 0x2100040 }, /* 257 */ + { 0x2e062408, 0x310 }, /* 258 */ + { 0x2e06240c, 0x1b000e }, /* 259 */ + { 0x2e062410, 0x1010101 }, /* 260 */ + { 0x2e062414, 0x2020101 }, /* 261 */ + { 0x2e062418, 0x8080404 }, /* 262 */ + { 0x2e06241c, 0x5508 }, /* 263 */ + { 0x2e062420, 0x83c5a00 }, /* 264 */ + { 0x2e062424, 0x55 }, /* 265 */ + { 0x2e062428, 0x55083c5a }, /* 266 */ + { 0x2e06242c, 0x5a000000 }, /* 267 */ + { 0x2e062430, 0x55083c }, /* 268 */ + { 0x2e062434, 0x3c5a0000 }, /* 269 */ + { 0x2e062438, 0xf0e0d0c }, /* 270 */ + { 0x2e06243c, 0xb0a0908 }, /* 271 */ + { 0x2e062440, 0x7060504 }, /* 272 */ + { 0x2e062444, 0x3020100 }, /* 273 */ + { 0x2e06244c, 0x2020101 }, /* 275 */ + { 0x2e062450, 0x8080404 }, /* 276 */ + { 0x2e062454, 0x44300004 }, /* 277 */ + { 0x2e062458, 0x4041919 }, /* 278 */ + { 0x2e06245c, 0x19443000 }, /* 279 */ + { 0x2e062460, 0x9140419 }, /* 280 */ + { 0x2e062464, 0x19194430 }, /* 281 */ + { 0x2e062468, 0x30000404 }, /* 282 */ + { 0x2e06246c, 0x4191944 }, /* 283 */ + { 0x2e062470, 0x44300004 }, /* 284 */ + { 0x2e062474, 0x14041919 }, /* 285 */ + { 0x2e062478, 0x19443009 }, /* 286 */ + { 0x2e06247c, 0x40419 }, /* 287 */ + { 0x2e062480, 0x19194430 }, /* 288 */ + { 0x2e062484, 0x30000404 }, /* 289 */ + { 0x2e062488, 0x4191944 }, /* 290 */ + { 0x2e06248c, 0x44300914 }, /* 291 */ + { 0x2e062490, 0x44041919 }, /* 292 */ + { 0x2e062494, 0x19443000 }, /* 293 */ + { 0x2e062498, 0x40419 }, /* 294 */ + { 0x2e06249c, 0x19194430 }, /* 295 */ + { 0x2e0624a0, 0x30091404 }, /* 296 */ + { 0x2e0624a4, 0x4191944 }, /* 297 */ +}; + +/** PHY_F1 settings **/ +struct dram_cfg_param ddr_phy_f1_cfg[] = { + { 0x2e064000, 0x4f0 }, /* 0 */ + { 0x2e064008, 0x1030200 }, /* 2 */ + { 0x2e064014, 0x3000000 }, /* 5 */ + { 0x2e064018, 0x1000001 }, /* 6 */ + { 0x2e06401c, 0x3000400 }, /* 7 */ + { 0x2e064020, 0x1 }, /* 8 */ + { 0x2e064024, 0x1 }, /* 9 */ + { 0x2e064030, 0x10000 }, /* 12 */ + { 0x2e064038, 0xc00004 }, /* 14 */ + { 0x2e06403c, 0xcc0008 }, /* 15 */ + { 0x2e064040, 0x660601 }, /* 16 */ + { 0x2e064044, 0x3 }, /* 17 */ + { 0x2e06404c, 0x1 }, /* 19 */ + { 0x2e064050, 0xaaaa }, /* 20 */ + { 0x2e064054, 0x5555 }, /* 21 */ + { 0x2e064058, 0xb5b5 }, /* 22 */ + { 0x2e06405c, 0x4a4a }, /* 23 */ + { 0x2e064060, 0x5656 }, /* 24 */ + { 0x2e064064, 0xa9a9 }, /* 25 */ + { 0x2e064068, 0xb7b7 }, /* 26 */ + { 0x2e06406c, 0x4848 }, /* 27 */ + { 0x2e064078, 0x8000000 }, /* 30 */ + { 0x2e06407c, 0x4010008 }, /* 31 */ + { 0x2e064080, 0x408 }, /* 32 */ + { 0x2e064084, 0x3102000 }, /* 33 */ + { 0x2e064088, 0xc0020 }, /* 34 */ + { 0x2e06408c, 0x10000 }, /* 35 */ + { 0x2e064090, 0x55555555 }, /* 36 */ + { 0x2e064094, 0xaaaaaaaa }, /* 37 */ + { 0x2e064098, 0x55555555 }, /* 38 */ + { 0x2e06409c, 0xaaaaaaaa }, /* 39 */ + { 0x2e0640a0, 0x5555 }, /* 40 */ + { 0x2e0640a4, 0x1000100 }, /* 41 */ + { 0x2e0640a8, 0x800180 }, /* 42 */ + { 0x2e0640ac, 0x1 }, /* 43 */ + { 0x2e064100, 0x4 }, /* 64 */ + { 0x2e06411c, 0x41f07ff }, /* 71 */ + { 0x2e064120, 0x1 }, /* 72 */ + { 0x2e064124, 0x1cc0800 }, /* 73 */ + { 0x2e064128, 0x3003cc08 }, /* 74 */ + { 0x2e06412c, 0x2000014e }, /* 75 */ + { 0x2e064130, 0x7ff0200 }, /* 76 */ + { 0x2e064134, 0x301 }, /* 77 */ + { 0x2e064140, 0x30000 }, /* 80 */ + { 0x2e064154, 0x2000000 }, /* 85 */ + { 0x2e064158, 0x51515042 }, /* 86 */ + { 0x2e06415c, 0x31c06000 }, /* 87 */ + { 0x2e064160, 0x6bf000a }, /* 88 */ + { 0x2e064164, 0xc0c000 }, /* 89 */ + { 0x2e064168, 0x1000000 }, /* 90 */ + { 0x2e06416c, 0x10001000 }, /* 91 */ + { 0x2e064170, 0xc043242 }, /* 92 */ + { 0x2e064174, 0xf0c1201 }, /* 93 */ + { 0x2e064178, 0x1000140 }, /* 94 */ + { 0x2e06417c, 0xc000120 }, /* 95 */ + { 0x2e064180, 0x143 }, /* 96 */ + { 0x2e064184, 0x1000203 }, /* 97 */ + { 0x2e064188, 0x56417032 }, /* 98 */ + { 0x2e06418c, 0x8 }, /* 99 */ + { 0x2e064190, 0x2c302c3 }, /* 100 */ + { 0x2e064194, 0x2c302c3 }, /* 101 */ + { 0x2e064198, 0x2c302c3 }, /* 102 */ + { 0x2e06419c, 0x2c302c3 }, /* 103 */ + { 0x2e0641a0, 0x2c3 }, /* 104 */ + { 0x2e0641a4, 0x8000 }, /* 105 */ + { 0x2e0641a8, 0x800080 }, /* 106 */ + { 0x2e0641ac, 0x800080 }, /* 107 */ + { 0x2e0641b0, 0x800080 }, /* 108 */ + { 0x2e0641b4, 0x800080 }, /* 109 */ + { 0x2e0641b8, 0x800080 }, /* 110 */ + { 0x2e0641bc, 0x800080 }, /* 111 */ + { 0x2e0641c0, 0x800080 }, /* 112 */ + { 0x2e0641c4, 0x800080 }, /* 113 */ + { 0x2e0641c8, 0x6b0080 }, /* 114 */ + { 0x2e0641cc, 0x1a00001 }, /* 115 */ + { 0x2e0641d4, 0x10000 }, /* 117 */ + { 0x2e0641d8, 0x80200 }, /* 118 */ + { 0x2e064400, 0x4f0 }, /* 256 */ + { 0x2e064408, 0x1030200 }, /* 258 */ + { 0x2e064414, 0x3000000 }, /* 261 */ + { 0x2e064418, 0x1000001 }, /* 262 */ + { 0x2e06441c, 0x3000400 }, /* 263 */ + { 0x2e064420, 0x1 }, /* 264 */ + { 0x2e064424, 0x1 }, /* 265 */ + { 0x2e064430, 0x10000 }, /* 268 */ + { 0x2e064438, 0xc00004 }, /* 270 */ + { 0x2e06443c, 0xcc0008 }, /* 271 */ + { 0x2e064440, 0x660601 }, /* 272 */ + { 0x2e064444, 0x3 }, /* 273 */ + { 0x2e06444c, 0x1 }, /* 275 */ + { 0x2e064450, 0xaaaa }, /* 276 */ + { 0x2e064454, 0x5555 }, /* 277 */ + { 0x2e064458, 0xb5b5 }, /* 278 */ + { 0x2e06445c, 0x4a4a }, /* 279 */ + { 0x2e064460, 0x5656 }, /* 280 */ + { 0x2e064464, 0xa9a9 }, /* 281 */ + { 0x2e064468, 0xb7b7 }, /* 282 */ + { 0x2e06446c, 0x4848 }, /* 283 */ + { 0x2e064478, 0x8000000 }, /* 286 */ + { 0x2e06447c, 0x4010008 }, /* 287 */ + { 0x2e064480, 0x408 }, /* 288 */ + { 0x2e064484, 0x3102000 }, /* 289 */ + { 0x2e064488, 0xc0020 }, /* 290 */ + { 0x2e06448c, 0x10000 }, /* 291 */ + { 0x2e064490, 0x55555555 }, /* 292 */ + { 0x2e064494, 0xaaaaaaaa }, /* 293 */ + { 0x2e064498, 0x55555555 }, /* 294 */ + { 0x2e06449c, 0xaaaaaaaa }, /* 295 */ + { 0x2e0644a0, 0x5555 }, /* 296 */ + { 0x2e0644a4, 0x1000100 }, /* 297 */ + { 0x2e0644a8, 0x800180 }, /* 298 */ + { 0x2e064500, 0x4 }, /* 320 */ + { 0x2e06451c, 0x41f07ff }, /* 327 */ + { 0x2e064520, 0x1 }, /* 328 */ + { 0x2e064524, 0x1cc0800 }, /* 329 */ + { 0x2e064528, 0x3003cc08 }, /* 330 */ + { 0x2e06452c, 0x2000014e }, /* 331 */ + { 0x2e064530, 0x7ff0200 }, /* 332 */ + { 0x2e064534, 0x301 }, /* 333 */ + { 0x2e064540, 0x30000 }, /* 336 */ + { 0x2e064554, 0x2000000 }, /* 341 */ + { 0x2e064558, 0x51515042 }, /* 342 */ + { 0x2e06455c, 0x31c06000 }, /* 343 */ + { 0x2e064560, 0x6bf000a }, /* 344 */ + { 0x2e064564, 0xc0c000 }, /* 345 */ + { 0x2e064568, 0x1000000 }, /* 346 */ + { 0x2e06456c, 0x10001000 }, /* 347 */ + { 0x2e064570, 0xc043242 }, /* 348 */ + { 0x2e064574, 0xf0c1201 }, /* 349 */ + { 0x2e064578, 0x1000140 }, /* 350 */ + { 0x2e06457c, 0xc000120 }, /* 351 */ + { 0x2e064580, 0x143 }, /* 352 */ + { 0x2e064584, 0x1000203 }, /* 353 */ + { 0x2e064588, 0x30217465 }, /* 354 */ + { 0x2e06458c, 0x8 }, /* 355 */ + { 0x2e064590, 0x2c302c3 }, /* 356 */ + { 0x2e064594, 0x2c302c3 }, /* 357 */ + { 0x2e064598, 0x2c302c3 }, /* 358 */ + { 0x2e06459c, 0x2c302c3 }, /* 359 */ + { 0x2e0645a0, 0x2c3 }, /* 360 */ + { 0x2e0645a4, 0x8000 }, /* 361 */ + { 0x2e0645a8, 0x800080 }, /* 362 */ + { 0x2e0645ac, 0x800080 }, /* 363 */ + { 0x2e0645b0, 0x800080 }, /* 364 */ + { 0x2e0645b4, 0x800080 }, /* 365 */ + { 0x2e0645b8, 0x800080 }, /* 366 */ + { 0x2e0645bc, 0x800080 }, /* 367 */ + { 0x2e0645c0, 0x800080 }, /* 368 */ + { 0x2e0645c4, 0x800080 }, /* 369 */ + { 0x2e0645c8, 0x6b0080 }, /* 370 */ + { 0x2e0645cc, 0x1a00001 }, /* 371 */ + { 0x2e0645d4, 0x10000 }, /* 373 */ + { 0x2e0645d8, 0x80200 }, /* 374 */ + { 0x2e064800, 0x4f0 }, /* 512 */ + { 0x2e064808, 0x1030200 }, /* 514 */ + { 0x2e064814, 0x3000000 }, /* 517 */ + { 0x2e064818, 0x1000001 }, /* 518 */ + { 0x2e06481c, 0x3000400 }, /* 519 */ + { 0x2e064820, 0x1 }, /* 520 */ + { 0x2e064824, 0x1 }, /* 521 */ + { 0x2e064830, 0x10000 }, /* 524 */ + { 0x2e064838, 0xc00004 }, /* 526 */ + { 0x2e06483c, 0xcc0008 }, /* 527 */ + { 0x2e064840, 0x660601 }, /* 528 */ + { 0x2e064844, 0x3 }, /* 529 */ + { 0x2e06484c, 0x1 }, /* 531 */ + { 0x2e064850, 0xaaaa }, /* 532 */ + { 0x2e064854, 0x5555 }, /* 533 */ + { 0x2e064858, 0xb5b5 }, /* 534 */ + { 0x2e06485c, 0x4a4a }, /* 535 */ + { 0x2e064860, 0x5656 }, /* 536 */ + { 0x2e064864, 0xa9a9 }, /* 537 */ + { 0x2e064868, 0xb7b7 }, /* 538 */ + { 0x2e06486c, 0x4848 }, /* 539 */ + { 0x2e064878, 0x8000000 }, /* 542 */ + { 0x2e06487c, 0x4010008 }, /* 543 */ + { 0x2e064880, 0x408 }, /* 544 */ + { 0x2e064884, 0x3102000 }, /* 545 */ + { 0x2e064888, 0xc0020 }, /* 546 */ + { 0x2e06488c, 0x10000 }, /* 547 */ + { 0x2e064890, 0x55555555 }, /* 548 */ + { 0x2e064894, 0xaaaaaaaa }, /* 549 */ + { 0x2e064898, 0x55555555 }, /* 550 */ + { 0x2e06489c, 0xaaaaaaaa }, /* 551 */ + { 0x2e0648a0, 0x5555 }, /* 552 */ + { 0x2e0648a4, 0x1000100 }, /* 553 */ + { 0x2e0648a8, 0x800180 }, /* 554 */ + { 0x2e0648ac, 0x1 }, /* 555 */ + { 0x2e064900, 0x4 }, /* 576 */ + { 0x2e06491c, 0x41f07ff }, /* 583 */ + { 0x2e064920, 0x1 }, /* 584 */ + { 0x2e064924, 0x1cc0800 }, /* 585 */ + { 0x2e064928, 0x3003cc08 }, /* 586 */ + { 0x2e06492c, 0x2000014e }, /* 587 */ + { 0x2e064930, 0x7ff0200 }, /* 588 */ + { 0x2e064934, 0x301 }, /* 589 */ + { 0x2e064940, 0x30000 }, /* 592 */ + { 0x2e064954, 0x2000000 }, /* 597 */ + { 0x2e064958, 0x51515042 }, /* 598 */ + { 0x2e06495c, 0x31c06000 }, /* 599 */ + { 0x2e064960, 0x6bf000a }, /* 600 */ + { 0x2e064964, 0xc0c000 }, /* 601 */ + { 0x2e064968, 0x1000000 }, /* 602 */ + { 0x2e06496c, 0x10001000 }, /* 603 */ + { 0x2e064970, 0xc043242 }, /* 604 */ + { 0x2e064974, 0xf0c1201 }, /* 605 */ + { 0x2e064978, 0x1000140 }, /* 606 */ + { 0x2e06497c, 0xc000120 }, /* 607 */ + { 0x2e064980, 0x143 }, /* 608 */ + { 0x2e064984, 0x1000203 }, /* 609 */ + { 0x2e064988, 0x75436012 }, /* 610 */ + { 0x2e06498c, 0x8 }, /* 611 */ + { 0x2e064990, 0x2c302c3 }, /* 612 */ + { 0x2e064994, 0x2c302c3 }, /* 613 */ + { 0x2e064998, 0x2c302c3 }, /* 614 */ + { 0x2e06499c, 0x2c302c3 }, /* 615 */ + { 0x2e0649a0, 0x2c3 }, /* 616 */ + { 0x2e0649a4, 0x8000 }, /* 617 */ + { 0x2e0649a8, 0x800080 }, /* 618 */ + { 0x2e0649ac, 0x800080 }, /* 619 */ + { 0x2e0649b0, 0x800080 }, /* 620 */ + { 0x2e0649b4, 0x800080 }, /* 621 */ + { 0x2e0649b8, 0x800080 }, /* 622 */ + { 0x2e0649bc, 0x800080 }, /* 623 */ + { 0x2e0649c0, 0x800080 }, /* 624 */ + { 0x2e0649c4, 0x800080 }, /* 625 */ + { 0x2e0649c8, 0x6b0080 }, /* 626 */ + { 0x2e0649cc, 0x1a00001 }, /* 627 */ + { 0x2e0649d4, 0x10000 }, /* 629 */ + { 0x2e0649d8, 0x80200 }, /* 630 */ + { 0x2e064c00, 0x4f0 }, /* 768 */ + { 0x2e064c08, 0x1030200 }, /* 770 */ + { 0x2e064c14, 0x3000000 }, /* 773 */ + { 0x2e064c18, 0x1000001 }, /* 774 */ + { 0x2e064c1c, 0x3000400 }, /* 775 */ + { 0x2e064c20, 0x1 }, /* 776 */ + { 0x2e064c24, 0x1 }, /* 777 */ + { 0x2e064c30, 0x10000 }, /* 780 */ + { 0x2e064c38, 0xc00004 }, /* 782 */ + { 0x2e064c3c, 0xcc0008 }, /* 783 */ + { 0x2e064c40, 0x660601 }, /* 784 */ + { 0x2e064c44, 0x3 }, /* 785 */ + { 0x2e064c4c, 0x1 }, /* 787 */ + { 0x2e064c50, 0xaaaa }, /* 788 */ + { 0x2e064c54, 0x5555 }, /* 789 */ + { 0x2e064c58, 0xb5b5 }, /* 790 */ + { 0x2e064c5c, 0x4a4a }, /* 791 */ + { 0x2e064c60, 0x5656 }, /* 792 */ + { 0x2e064c64, 0xa9a9 }, /* 793 */ + { 0x2e064c68, 0xb7b7 }, /* 794 */ + { 0x2e064c6c, 0x4848 }, /* 795 */ + { 0x2e064c78, 0x8000000 }, /* 798 */ + { 0x2e064c7c, 0x4010008 }, /* 799 */ + { 0x2e064c80, 0x408 }, /* 800 */ + { 0x2e064c84, 0x3102000 }, /* 801 */ + { 0x2e064c88, 0xc0020 }, /* 802 */ + { 0x2e064c8c, 0x10000 }, /* 803 */ + { 0x2e064c90, 0x55555555 }, /* 804 */ + { 0x2e064c94, 0xaaaaaaaa }, /* 805 */ + { 0x2e064c98, 0x55555555 }, /* 806 */ + { 0x2e064c9c, 0xaaaaaaaa }, /* 807 */ + { 0x2e064ca0, 0x5555 }, /* 808 */ + { 0x2e064ca4, 0x1000100 }, /* 809 */ + { 0x2e064ca8, 0x800180 }, /* 810 */ + { 0x2e064d00, 0x4 }, /* 832 */ + { 0x2e064d1c, 0x41f07ff }, /* 839 */ + { 0x2e064d20, 0x1 }, /* 840 */ + { 0x2e064d24, 0x1cc0800 }, /* 841 */ + { 0x2e064d28, 0x3003cc08 }, /* 842 */ + { 0x2e064d2c, 0x2000014e }, /* 843 */ + { 0x2e064d30, 0x7ff0200 }, /* 844 */ + { 0x2e064d34, 0x301 }, /* 845 */ + { 0x2e064d40, 0x30000 }, /* 848 */ + { 0x2e064d54, 0x2000000 }, /* 853 */ + { 0x2e064d58, 0x51515042 }, /* 854 */ + { 0x2e064d5c, 0x31c06000 }, /* 855 */ + { 0x2e064d60, 0x6bf000a }, /* 856 */ + { 0x2e064d64, 0xc0c000 }, /* 857 */ + { 0x2e064d68, 0x1000000 }, /* 858 */ + { 0x2e064d6c, 0x10001000 }, /* 859 */ + { 0x2e064d70, 0xc043242 }, /* 860 */ + { 0x2e064d74, 0xf0c1201 }, /* 861 */ + { 0x2e064d78, 0x1000140 }, /* 862 */ + { 0x2e064d7c, 0xc000120 }, /* 863 */ + { 0x2e064d80, 0x143 }, /* 864 */ + { 0x2e064d84, 0x1000203 }, /* 865 */ + { 0x2e064d88, 0x32017465 }, /* 866 */ + { 0x2e064d8c, 0x8 }, /* 867 */ + { 0x2e064d90, 0x2c302c3 }, /* 868 */ + { 0x2e064d94, 0x2c302c3 }, /* 869 */ + { 0x2e064d98, 0x2c302c3 }, /* 870 */ + { 0x2e064d9c, 0x2c302c3 }, /* 871 */ + { 0x2e064da0, 0x2c3 }, /* 872 */ + { 0x2e064da4, 0x8000 }, /* 873 */ + { 0x2e064da8, 0x800080 }, /* 874 */ + { 0x2e064dac, 0x800080 }, /* 875 */ + { 0x2e064db0, 0x800080 }, /* 876 */ + { 0x2e064db4, 0x800080 }, /* 877 */ + { 0x2e064db8, 0x800080 }, /* 878 */ + { 0x2e064dbc, 0x800080 }, /* 879 */ + { 0x2e064dc0, 0x800080 }, /* 880 */ + { 0x2e064dc4, 0x800080 }, /* 881 */ + { 0x2e064dc8, 0x6b0080 }, /* 882 */ + { 0x2e064dcc, 0x1a00001 }, /* 883 */ + { 0x2e064dd4, 0x10000 }, /* 885 */ + { 0x2e064dd8, 0x80200 }, /* 886 */ + { 0x2e065014, 0x100 }, /* 1029 */ + { 0x2e065018, 0x201 }, /* 1030 */ + { 0x2e06502c, 0x400000 }, /* 1035 */ + { 0x2e065030, 0x80 }, /* 1036 */ + { 0x2e065034, 0xdcba98 }, /* 1037 */ + { 0x2e065038, 0x3000000 }, /* 1038 */ + { 0x2e06504c, 0x2a }, /* 1043 */ + { 0x2e065050, 0x15 }, /* 1044 */ + { 0x2e065054, 0x15 }, /* 1045 */ + { 0x2e065058, 0x2a }, /* 1046 */ + { 0x2e06505c, 0x33 }, /* 1047 */ + { 0x2e065060, 0xc }, /* 1048 */ + { 0x2e065064, 0xc }, /* 1049 */ + { 0x2e065068, 0x33 }, /* 1050 */ + { 0x2e06506c, 0x543210 }, /* 1051 */ + { 0x2e065070, 0x3f0000 }, /* 1052 */ + { 0x2e065074, 0xf013f }, /* 1053 */ + { 0x2e065078, 0xf }, /* 1054 */ + { 0x2e06507c, 0x3cc }, /* 1055 */ + { 0x2e065080, 0x30000 }, /* 1056 */ + { 0x2e065084, 0x300 }, /* 1057 */ + { 0x2e065088, 0x300 }, /* 1058 */ + { 0x2e06508c, 0x300 }, /* 1059 */ + { 0x2e065090, 0x300 }, /* 1060 */ + { 0x2e065094, 0x300 }, /* 1061 */ + { 0x2e065098, 0x42080010 }, /* 1062 */ + { 0x2e06509c, 0x332 }, /* 1063 */ + { 0x2e0650a0, 0x2 }, /* 1064 */ + { 0x2e065414, 0x100 }, /* 1285 */ + { 0x2e065418, 0x201 }, /* 1286 */ + { 0x2e06542c, 0x400000 }, /* 1291 */ + { 0x2e065430, 0x80 }, /* 1292 */ + { 0x2e065434, 0xdcba98 }, /* 1293 */ + { 0x2e065438, 0x3000000 }, /* 1294 */ + { 0x2e06544c, 0x2a }, /* 1299 */ + { 0x2e065450, 0x15 }, /* 1300 */ + { 0x2e065454, 0x15 }, /* 1301 */ + { 0x2e065458, 0x2a }, /* 1302 */ + { 0x2e06545c, 0x33 }, /* 1303 */ + { 0x2e065460, 0xc }, /* 1304 */ + { 0x2e065464, 0xc }, /* 1305 */ + { 0x2e065468, 0x33 }, /* 1306 */ + { 0x2e06546c, 0x543210 }, /* 1307 */ + { 0x2e065470, 0x3f0000 }, /* 1308 */ + { 0x2e065474, 0xf013f }, /* 1309 */ + { 0x2e065478, 0xf }, /* 1310 */ + { 0x2e06547c, 0x3cc }, /* 1311 */ + { 0x2e065480, 0x30000 }, /* 1312 */ + { 0x2e065484, 0x300 }, /* 1313 */ + { 0x2e065488, 0x300 }, /* 1314 */ + { 0x2e06548c, 0x300 }, /* 1315 */ + { 0x2e065490, 0x300 }, /* 1316 */ + { 0x2e065494, 0x300 }, /* 1317 */ + { 0x2e065498, 0x42080010 }, /* 1318 */ + { 0x2e06549c, 0x332 }, /* 1319 */ + { 0x2e0654a0, 0x2 }, /* 1320 */ + { 0x2e065804, 0x100 }, /* 1537 */ + { 0x2e065814, 0x50000 }, /* 1541 */ + { 0x2e065818, 0x4000100 }, /* 1542 */ + { 0x2e06581c, 0x55 }, /* 1543 */ + { 0x2e06582c, 0xf0001 }, /* 1547 */ + { 0x2e065830, 0x280040 }, /* 1548 */ + { 0x2e065834, 0x5002 }, /* 1549 */ + { 0x2e065838, 0x10101 }, /* 1550 */ + { 0x2e065840, 0x90e0000 }, /* 1552 */ + { 0x2e065844, 0x101010f }, /* 1553 */ + { 0x2e065848, 0x10f0004 }, /* 1554 */ + { 0x2e065854, 0x64 }, /* 1557 */ + { 0x2e06585c, 0x1000000 }, /* 1559 */ + { 0x2e065860, 0x8040201 }, /* 1560 */ + { 0x2e065864, 0x2010201 }, /* 1561 */ + { 0x2e065868, 0xf0f0f }, /* 1562 */ + { 0x2e06586c, 0x241342 }, /* 1563 */ + { 0x2e065874, 0x1020000 }, /* 1565 */ + { 0x2e065878, 0x701 }, /* 1566 */ + { 0x2e06587c, 0x54 }, /* 1567 */ + { 0x2e065880, 0x4102000 }, /* 1568 */ + { 0x2e065884, 0x24410 }, /* 1569 */ + { 0x2e065888, 0x4410 }, /* 1570 */ + { 0x2e06588c, 0x4410 }, /* 1571 */ + { 0x2e065890, 0x4410 }, /* 1572 */ + { 0x2e065894, 0x4410 }, /* 1573 */ + { 0x2e065898, 0x4410 }, /* 1574 */ + { 0x2e06589c, 0x4410 }, /* 1575 */ + { 0x2e0658a0, 0x4410 }, /* 1576 */ + { 0x2e0658a4, 0x4410 }, /* 1577 */ + { 0x2e0658b0, 0x60000 }, /* 1580 */ + { 0x2e0658b8, 0x66 }, /* 1582 */ + { 0x2e0658bc, 0x10000 }, /* 1583 */ + { 0x2e0658c0, 0x8 }, /* 1584 */ + { 0x2e0658d8, 0x3000000 }, /* 1590 */ + { 0x2e0658e8, 0x4102006 }, /* 1594 */ + { 0x2e0658ec, 0x41020 }, /* 1595 */ + { 0x2e0658f0, 0x1c98c98 }, /* 1596 */ + { 0x2e0658f4, 0x3f400000 }, /* 1597 */ + { 0x2e0658f8, 0x3f3f1f3f }, /* 1598 */ + { 0x2e0658fc, 0x1f }, /* 1599 */ + { 0x2e06590c, 0x1 }, /* 1603 */ + { 0x2e06591c, 0x1 }, /* 1607 */ + { 0x2e065920, 0x76543210 }, /* 1608 */ + { 0x2e065924, 0x10198 }, /* 1609 */ + { 0x2e065934, 0x40700 }, /* 1613 */ + { 0x2e06594c, 0x2 }, /* 1619 */ + { 0x2e065958, 0xf3c3 }, /* 1622 */ + { 0x2e065964, 0x11542 }, /* 1625 */ + { 0x2e065968, 0x30209bf }, /* 1626 */ + { 0x2e06596c, 0x30000 }, /* 1627 */ + { 0x2e065970, 0x3000300 }, /* 1628 */ + { 0x2e065974, 0x3000300 }, /* 1629 */ + { 0x2e065978, 0x3000300 }, /* 1630 */ + { 0x2e06597c, 0x3000300 }, /* 1631 */ + { 0x2e065980, 0x300 }, /* 1632 */ + { 0x2e065984, 0x300 }, /* 1633 */ + { 0x2e065988, 0x300 }, /* 1634 */ + { 0x2e06598c, 0x337cc }, /* 1635 */ + { 0x2e065990, 0x8 }, /* 1636 */ + { 0x2e065994, 0x1b7 }, /* 1637 */ + { 0x2e06599c, 0x1b7 }, /* 1639 */ + { 0x2e0659a4, 0x1b700 }, /* 1641 */ + { 0x2e0659a8, 0x1980000 }, /* 1642 */ + { 0x2e0659ac, 0x1b7cc }, /* 1643 */ + { 0x2e0659b4, 0x1b700 }, /* 1645 */ + { 0x2e0659b8, 0x1980000 }, /* 1646 */ + { 0x2e0659bc, 0x1b700 }, /* 1647 */ + { 0x2e0659c0, 0x1980000 }, /* 1648 */ + { 0x2e0659c4, 0x1b700 }, /* 1649 */ + { 0x2e0659c8, 0x1980000 }, /* 1650 */ + { 0x2e0659cc, 0x1b700 }, /* 1651 */ + { 0x2e0659d0, 0x1980000 }, /* 1652 */ + { 0x2e0659d4, 0x20040003 }, /* 1653 */ +}; + +/** PHY_F2 settings **/ +struct dram_cfg_param ddr_phy_f2_cfg[] = { +}; + +/* ddr timing config params */ +struct dram_timing_info2 dram_timing = { + .ctl_cfg = ddr_ctl_cfg, + .ctl_cfg_num = ARRAY_SIZE(ddr_ctl_cfg), + .pi_cfg = ddr_pi_cfg, + .pi_cfg_num = ARRAY_SIZE(ddr_pi_cfg), + .phy_f1_cfg = ddr_phy_f1_cfg, + .phy_f1_cfg_num = ARRAY_SIZE(ddr_phy_f1_cfg), + .phy_f2_cfg = ddr_phy_f2_cfg, + .phy_f2_cfg_num = ARRAY_SIZE(ddr_phy_f2_cfg), + .fsp_table = { 96, 528 }, +}; diff --git a/board/freescale/imx8ulp_evk/spl.c b/board/freescale/imx8ulp_evk/spl.c index b314901409..d3cdad2d76 100644 --- a/board/freescale/imx8ulp_evk/spl.c +++ b/board/freescale/imx8ulp_evk/spl.c @@ -35,8 +35,17 @@ u32 spl_boot_device(void)
int power_init_board(void) { - /* Set buck3 to 1.1v OD */ - upower_pmic_i2c_write(0x22, 0x28); + if (IS_ENABLED(CONFIG_IMX8ULP_LD_MODE)) { + /* Set buck3 to 0.9v LD */ + upower_pmic_i2c_write(0x22, 0x18); + } else if (IS_ENABLED(CONFIG_IMX8ULP_ND_MODE)) { + /* Set buck3 to 1.0v ND */ + upower_pmic_i2c_write(0x22, 0x20); + } else { + /* Set buck3 to 1.1v OD */ + upower_pmic_i2c_write(0x22, 0x28); + } + return 0; }
@@ -69,6 +78,8 @@ void spl_board_init(void)
power_init_board();
+ clock_init_late(); + /* DDR initialization */ spl_dram_init();
What does ND, LD and OD stand for?
s/960M/960MHz
bool
default n
'default n' is already the default. Just remove it.
When M33 is LPAV owner in dual boot, DDR, PCC5, CGC2 won't be reset during APD reset. So no need to init DDR again after reboot, but need to reconfigure the PLL4 PFD/PFDDIV/LPAV NIC etc, because kernel may change or disable some of them.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/cgc.h | 2 +- arch/arm/mach-imx/imx8ulp/cgc.c | 20 +++++++++++--------- arch/arm/mach-imx/imx8ulp/clock.c | 2 +- board/freescale/imx8ulp_evk/spl.c | 12 ++++++++++-- 4 files changed, 23 insertions(+), 13 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8ulp/cgc.h b/arch/arm/include/asm/arch-imx8ulp/cgc.h index e45f04624d..83a246b15a 100644 --- a/arch/arm/include/asm/arch-imx8ulp/cgc.h +++ b/arch/arm/include/asm/arch-imx8ulp/cgc.h @@ -150,7 +150,7 @@ void cgc1_pll3_init(ulong freq); void cgc1_pll2_init(ulong freq); void cgc1_soscdiv_init(void); void cgc1_init_core_clk(ulong freq); -void cgc2_pll4_init(void); +void cgc2_pll4_init(bool pll4_reset); void cgc2_ddrclk_config(u32 src, u32 div); void cgc2_ddrclk_wait_unlock(void); u32 cgc1_sosc_div(enum cgc_clk clk); diff --git a/arch/arm/mach-imx/imx8ulp/cgc.c b/arch/arm/mach-imx/imx8ulp/cgc.c index 494ddb0f32..ccd977f1a5 100644 --- a/arch/arm/mach-imx/imx8ulp/cgc.c +++ b/arch/arm/mach-imx/imx8ulp/cgc.c @@ -187,7 +187,7 @@ void cgc1_pll3_init(ulong freq) } }
-void cgc2_pll4_init(void) +void cgc2_pll4_init(bool pll4_reset) { /* Disable PFD DIV and clear DIV */ writel(0x80808080, &cgc2_regs->pll4div_pfd0); @@ -196,16 +196,18 @@ void cgc2_pll4_init(void) /* Gate off and clear PFD */ writel(0x80808080, &cgc2_regs->pll4pfdcfg);
- /* Disable PLL4 */ - writel(0x0, &cgc2_regs->pll4csr); + if (pll4_reset) { + /* Disable PLL4 */ + writel(0x0, &cgc2_regs->pll4csr);
- /* Configure PLL4 to 528Mhz and clock source from SOSC */ - writel(22 << 16, &cgc2_regs->pll4cfg); - writel(0x1, &cgc2_regs->pll4csr); + /* Configure PLL4 to 528Mhz and clock source from SOSC */ + writel(22 << 16, &cgc2_regs->pll4cfg); + writel(0x1, &cgc2_regs->pll4csr);
- /* wait for PLL4 output valid */ - while (!(readl(&cgc2_regs->pll4csr) & BIT(24))) - ; + /* wait for PLL4 output valid */ + while (!(readl(&cgc2_regs->pll4csr) & BIT(24))) + ; + }
/* Enable all 4 PFDs */ setbits_le32(&cgc2_regs->pll4pfdcfg, 18 << 0); /* 528 */ diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index 7c45a717be..cc13ccd5ea 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -101,7 +101,7 @@ void init_clk_ddr(void) writel(0xc0000000, PCC5_LPDDR4_ADDR);
/* enable pll4 and ddrclk*/ - cgc2_pll4_init(); + cgc2_pll4_init(true); cgc2_ddrclk_config(4, 1);
/* enable ddr pcc */ diff --git a/board/freescale/imx8ulp_evk/spl.c b/board/freescale/imx8ulp_evk/spl.c index d3cdad2d76..e6949b5e43 100644 --- a/board/freescale/imx8ulp_evk/spl.c +++ b/board/freescale/imx8ulp_evk/spl.c @@ -24,8 +24,16 @@ DECLARE_GLOBAL_DATA_PTR;
void spl_dram_init(void) { - init_clk_ddr(); - ddr_init(&dram_timing); + /* Reboot in dual boot setting no need to init ddr again */ + bool ddr_enable = pcc_clock_is_enable(5, LPDDR4_PCC5_SLOT); + + if (!ddr_enable) { + init_clk_ddr(); + ddr_init(&dram_timing); + } else { + /* reinit pfd/pfddiv and lpavnic except pll4*/ + cgc2_pll4_init(false); + } }
When reset with dual boot mode, the LPAV domain won't power down due to its master is not assigned to APD. So the NICLPAV keeps the last setting to use PLL4PFD1. So before SPL initialize the PLL4, we need to switch NICLPAV to FRO192, otherwise system will hang.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/cgc.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-imx/imx8ulp/cgc.c b/arch/arm/mach-imx/imx8ulp/cgc.c index ccd977f1a5..d240abaee4 100644 --- a/arch/arm/mach-imx/imx8ulp/cgc.c +++ b/arch/arm/mach-imx/imx8ulp/cgc.c @@ -189,6 +189,14 @@ void cgc1_pll3_init(ulong freq)
void cgc2_pll4_init(bool pll4_reset) { + /* Check the NICLPAV first to ensure not from PLL4 PFD1 clock */ + if ((readl(&cgc2_regs->niclpavclk) & GENMASK(29, 28)) == BIT(28)) { + /* switch to FRO 192 first */ + clrbits_le32(&cgc2_regs->niclpavclk, GENMASK(29, 28)); + while (!(readl(&cgc2_regs->niclpavclk) & BIT(27))) + ; + } + /* Disable PFD DIV and clear DIV */ writel(0x80808080, &cgc2_regs->pll4div_pfd0); writel(0x80808080, &cgc2_regs->pll4div_pfd1);
Enable MU0_B clk by default. When M33 image is loaded by Jlink, the previous method not enable MU0_B clk and not able to communicate with M33, so let's enable it by default.
And we not put it under kernel dts, because it conflicts with i.MX8QM suspend/resume logic which requires large change.
Reviewed-by: Ye Li ye.li@nxp.com Reviewed-by: Jacky Bai ping.bai@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/clock.c | 3 +++ arch/arm/mach-imx/imx8ulp/soc.c | 3 --- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/imx8ulp/clock.c b/arch/arm/mach-imx/imx8ulp/clock.c index cc13ccd5ea..398d8c849f 100644 --- a/arch/arm/mach-imx/imx8ulp/clock.c +++ b/arch/arm/mach-imx/imx8ulp/clock.c @@ -214,6 +214,9 @@ void clock_init_late(void) pcc_reset_peripheral(4, SDHC2_PCC4_SLOT, false); }
+ /* enable MU0_MUB clock before access the register of MU0_MUB */ + pcc_clock_enable(3, MU0_B_PCC3_SLOT, true); + /* * Enable clock division * TODO: may not needed after ROM ready. diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index b4f0ca6a2e..e95a159147 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -155,9 +155,6 @@ int m33_image_handshake(ulong timeout_ms) int ret; ulong timeout_us = timeout_ms * 1000;
- /* enable MU0_MUB clock before access the register of MU0_MUB */ - pcc_clock_enable(3, MU0_B_PCC3_SLOT, true); - /* Notify m33 that it's ready to do init srtm(enable mu receive interrupt and so on) */ setbits_le32(MU0_B_BASE_ADDR + 0x100, BIT(0)); /* set FCR F0 flag of MU0_MUB */
Since latest S400 firmware has supported to read OEM SRK Hash, add it to the driver's table
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/misc/imx8ulp/fuse.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/misc/imx8ulp/fuse.c b/drivers/misc/imx8ulp/fuse.c index d1feb62ab5..01db470e8f 100644 --- a/drivers/misc/imx8ulp/fuse.c +++ b/drivers/misc/imx8ulp/fuse.c @@ -61,6 +61,7 @@ struct s400_map_entry s400_api_mapping_table[] = { { 1, 8 }, /* LOCK */ { 2, 8 }, /* ECID */ { 7, 4, 0, 1 }, /* OTP_UNIQ_ID */ + { 15, 8 }, /* OEM SRK HASH */ { 23, 1, 4, 2 }, /* OTFAD */ };
Assign the LPAV owner to RTD, and assign LPAV masters and peripherals to APD. So except the masters and peripherals, other resources (like DDR, cgc2, pcc5) in LPAV won't be reset during reboot and suspend.
No needs to initialize DDR again after reboot.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/soc.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index e95a159147..b0ddaef222 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -523,10 +523,10 @@ static int trdc_set_access(void) return 0; }
-void lpav_configure(void) +void lpav_configure(bool lpav_to_m33) { - /* LPAV to APD */ - setbits_le32(SIM_SEC_BASE_ADDR + 0x44, BIT(7)); + if (!lpav_to_m33) + setbits_le32(SIM_SEC_BASE_ADDR + 0x44, BIT(7)); /* LPAV to APD */
/* PXP/GPU 2D/3D/DCNANO/MIPI_DSI/EPDC/HIFI4 to APD */ setbits_le32(SIM_SEC_BASE_ADDR + 0x4c, 0x7F); @@ -583,8 +583,9 @@ int arch_cpu_init(void) release_rdc(RDC_TRDC);
trdc_set_access(); - - lpav_configure(); + lpav_configure(false); + } else { + lpav_configure(true); }
/* Release xrdc, then allow A35 to write SRAM2 */
Found the lposc fuse loading having impact to cpu idle in kernel. Without the loading in dual boot mode, kernel will hang after idle for a while.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/spl.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/freescale/imx8ulp_evk/spl.c b/board/freescale/imx8ulp_evk/spl.c index e6949b5e43..9bc9081617 100644 --- a/board/freescale/imx8ulp_evk/spl.c +++ b/board/freescale/imx8ulp_evk/spl.c @@ -76,10 +76,8 @@ void spl_board_init(void)
/* After AP set iomuxc0, the i2c can't work, Need M33 to set it now */
- /* Load the lposc fuse for single boot to work around ROM issue, - * The fuse depends on S400 to read. - */ - if (is_soc_rev(CHIP_REV_1_0) && get_boot_mode() == SINGLE_BOOT) + /* Load the lposc fuse to work around ROM issue. The fuse depends on S400 to read. */ + if (is_soc_rev(CHIP_REV_1_0)) load_lposc_fuse();
upower_init();
Add ahab_release_caam() function to the S400 API.
Signed-off-by: Clement Faure clement.faure@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/s400_api.h | 2 ++ drivers/misc/imx8ulp/s400_api.c | 29 ++++++++++++++++++++ 2 files changed, 31 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8ulp/s400_api.h b/arch/arm/include/asm/arch-imx8ulp/s400_api.h index c848f0dfb8..b788661b09 100644 --- a/arch/arm/include/asm/arch-imx8ulp/s400_api.h +++ b/arch/arm/include/asm/arch-imx8ulp/s400_api.h @@ -19,6 +19,7 @@ #define AHAB_READ_FUSE_REQ_CID 0x97 #define AHAB_RELEASE_RDC_REQ_CID 0xC4 #define AHAB_WRITE_FUSE_REQ_CID 0xD6 +#define AHAB_CAAM_RELEASE_CID 0xD7
#define S400_MAX_MSG 8U
@@ -37,5 +38,6 @@ int ahab_verify_image(u32 img_id, u32 *response); int ahab_forward_lifecycle(u16 life_cycle, u32 *response); int ahab_write_fuse(u16 fuse_id, u32 fuse_val, bool lock, u32 *response); int ahab_read_common_fuse(u16 fuse_id, u32 *fuse_words, u32 fuse_num, u32 *response); +int ahab_release_caam(u32 core_did, u32 *response);
#endif diff --git a/drivers/misc/imx8ulp/s400_api.c b/drivers/misc/imx8ulp/s400_api.c index d76a95febe..dd5f9f25da 100644 --- a/drivers/misc/imx8ulp/s400_api.c +++ b/drivers/misc/imx8ulp/s400_api.c @@ -242,3 +242,32 @@ int ahab_write_fuse(u16 fuse_id, u32 fuse_val, bool lock, u32 *response)
return ret; } + +int ahab_release_caam(u32 core_did, u32 *response) +{ + struct udevice *dev = gd->arch.s400_dev; + int size = sizeof(struct imx8ulp_s400_msg); + struct imx8ulp_s400_msg msg; + int ret; + + if (!dev) { + printf("s400 dev is not initialized\n"); + return -ENODEV; + } + + msg.version = AHAB_VERSION; + msg.tag = AHAB_CMD_TAG; + msg.size = 2; + msg.command = AHAB_CAAM_RELEASE_CID; + msg.data[0] = core_did; + + ret = misc_call(dev, false, &msg, size, &msg, size); + if (ret) + printf("Error: %s: ret %d, response 0x%x\n", + __func__, ret, msg.data[0]); + + if (response) + *response = msg.data[0]; + + return ret; +}
Add ahab_dump_buffer API to dump AHAB buffer for debug purpose
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8ulp/s400_api.h | 3 +- drivers/misc/imx8ulp/s400_api.c | 34 ++++++++++++++++++++ 2 files changed, 36 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-imx8ulp/s400_api.h b/arch/arm/include/asm/arch-imx8ulp/s400_api.h index b788661b09..1856659877 100644 --- a/arch/arm/include/asm/arch-imx8ulp/s400_api.h +++ b/arch/arm/include/asm/arch-imx8ulp/s400_api.h @@ -21,7 +21,7 @@ #define AHAB_WRITE_FUSE_REQ_CID 0xD6 #define AHAB_CAAM_RELEASE_CID 0xD7
-#define S400_MAX_MSG 8U +#define S400_MAX_MSG 255U
struct imx8ulp_s400_msg { u8 version; @@ -39,5 +39,6 @@ int ahab_forward_lifecycle(u16 life_cycle, u32 *response); int ahab_write_fuse(u16 fuse_id, u32 fuse_val, bool lock, u32 *response); int ahab_read_common_fuse(u16 fuse_id, u32 *fuse_words, u32 fuse_num, u32 *response); int ahab_release_caam(u32 core_did, u32 *response); +int ahab_dump_buffer(u32 *buffer, u32 buffer_length);
#endif diff --git a/drivers/misc/imx8ulp/s400_api.c b/drivers/misc/imx8ulp/s400_api.c index dd5f9f25da..3ffdeb2ad2 100644 --- a/drivers/misc/imx8ulp/s400_api.c +++ b/drivers/misc/imx8ulp/s400_api.c @@ -271,3 +271,37 @@ int ahab_release_caam(u32 core_did, u32 *response)
return ret; } + +int ahab_dump_buffer(u32 *buffer, u32 buffer_length) +{ + struct udevice *dev = gd->arch.s400_dev; + int size = sizeof(struct imx8ulp_s400_msg); + struct imx8ulp_s400_msg msg; + int ret, i = 0; + + if (!dev) { + printf("s400 dev is not initialized\n"); + return -ENODEV; + } + + msg.version = AHAB_VERSION; + msg.tag = AHAB_CMD_TAG; + msg.size = 1; + msg.command = AHAB_LOG_CID; + + ret = misc_call(dev, false, &msg, size, &msg, size); + if (ret) { + printf("Error: %s: ret %d, response 0x%x\n", + __func__, ret, msg.data[0]); + + return ret; + } + + if (buffer) { + buffer[i++] = *(u32 *)&msg; /* Need dump the response header */ + for (; i < buffer_length && i < msg.size; i++) + buffer[i] = msg.data[i - 1]; + } + + return i; +}
Release the CAAM for the A35 from the SPL.
Signed-off-by: Clement Faure clement.faure@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/spl.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/freescale/imx8ulp_evk/spl.c b/board/freescale/imx8ulp_evk/spl.c index 9bc9081617..66bfc2bd0c 100644 --- a/board/freescale/imx8ulp_evk/spl.c +++ b/board/freescale/imx8ulp_evk/spl.c @@ -19,6 +19,7 @@ #include <asm/arch/ddr.h> #include <asm/arch/rdc.h> #include <asm/arch/upower.h> +#include <asm/arch/s400_api.h>
@@ -60,6 +61,8 @@ int power_init_board(void) void spl_board_init(void) { struct udevice *dev; + u32 res; + int ret;
uclass_find_first_device(UCLASS_MISC, &dev);
@@ -98,6 +101,11 @@ void spl_board_init(void)
/* Call it after PS16 power up */ set_lpav_qos(); + + /* Enable A35 access to the CAAM */ + ret = ahab_release_caam(0x7, &res); + if (ret) + printf("ahab release caam failed %d, 0x%x\n", ret, res); }
void board_init_f(ulong dummy)
Update DDR PHY settings to support LPDDR4 mode only by adjusting DQ VREF ctrl, ODT and pads drive strength.
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/lpddr4_timing.c | 32 ++++++++++----------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/board/freescale/imx8ulp_evk/lpddr4_timing.c b/board/freescale/imx8ulp_evk/lpddr4_timing.c index 4546e92b01..09240999ce 100644 --- a/board/freescale/imx8ulp_evk/lpddr4_timing.c +++ b/board/freescale/imx8ulp_evk/lpddr4_timing.c @@ -701,7 +701,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e064154, 0x2000000 }, /* 85 */ { 0x2e064158, 0x51515042 }, /* 86 */ { 0x2e06415c, 0x31c06000 }, /* 87 */ - { 0x2e064160, 0x9bf000a }, /* 88 */ + { 0x2e064160, 0x6bf000a }, /* 88 */ { 0x2e064164, 0xc0c000 }, /* 89 */ { 0x2e064168, 0x1000000 }, /* 90 */ { 0x2e06416c, 0x10001000 }, /* 91 */ @@ -777,7 +777,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e064554, 0x2000000 }, /* 341 */ { 0x2e064558, 0x51515042 }, /* 342 */ { 0x2e06455c, 0x31c06000 }, /* 343 */ - { 0x2e064560, 0x9bf000a }, /* 344 */ + { 0x2e064560, 0x6bf000a }, /* 344 */ { 0x2e064564, 0xc0c000 }, /* 345 */ { 0x2e064568, 0x1000000 }, /* 346 */ { 0x2e06456c, 0x10001000 }, /* 347 */ @@ -854,7 +854,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e064954, 0x2000000 }, /* 597 */ { 0x2e064958, 0x51515042 }, /* 598 */ { 0x2e06495c, 0x31c06000 }, /* 599 */ - { 0x2e064960, 0x9bf000a }, /* 600 */ + { 0x2e064960, 0x6bf000a }, /* 600 */ { 0x2e064964, 0xc0c000 }, /* 601 */ { 0x2e064968, 0x1000000 }, /* 602 */ { 0x2e06496c, 0x10001000 }, /* 603 */ @@ -930,7 +930,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e064d54, 0x2000000 }, /* 853 */ { 0x2e064d58, 0x51515042 }, /* 854 */ { 0x2e064d5c, 0x31c06000 }, /* 855 */ - { 0x2e064d60, 0x9bf000a }, /* 856 */ + { 0x2e064d60, 0x6bf000a }, /* 856 */ { 0x2e064d64, 0xc0c000 }, /* 857 */ { 0x2e064d68, 0x1000000 }, /* 858 */ { 0x2e064d6c, 0x10001000 }, /* 859 */ @@ -1032,7 +1032,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e065860, 0x8040201 }, /* 1560 */ { 0x2e065864, 0x2010201 }, /* 1561 */ { 0x2e065868, 0xf0f0f }, /* 1562 */ - { 0x2e06586c, 0x241b42 }, /* 1563 */ + { 0x2e06586c, 0x241342 }, /* 1563 */ { 0x2e065874, 0x1020000 }, /* 1565 */ { 0x2e065878, 0x701 }, /* 1566 */ { 0x2e06587c, 0x54 }, /* 1567 */ @@ -1047,7 +1047,7 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e0658a0, 0x4410 }, /* 1576 */ { 0x2e0658a4, 0x4410 }, /* 1577 */ { 0x2e0658b0, 0x60000 }, /* 1580 */ - { 0x2e0658b8, 0x96 }, /* 1582 */ + { 0x2e0658b8, 0x66 }, /* 1582 */ { 0x2e0658bc, 0x10000 }, /* 1583 */ { 0x2e0658c0, 0x8 }, /* 1584 */ { 0x2e0658d8, 0x3000000 }, /* 1590 */ @@ -1074,20 +1074,20 @@ struct dram_cfg_param ddr_phy_f1_cfg[] = { { 0x2e065980, 0x300 }, /* 1632 */ { 0x2e065984, 0x300 }, /* 1633 */ { 0x2e065988, 0x300 }, /* 1634 */ - { 0x2e06598c, 0x4bf77 }, /* 1635 */ - { 0x2e065990, 0x77 }, /* 1636 */ - { 0x2e065994, 0x27f }, /* 1637 */ - { 0x2e06599c, 0x27f }, /* 1639 */ - { 0x2e0659a4, 0x27f00 }, /* 1641 */ + { 0x2e06598c, 0x337cc }, /* 1635 */ + { 0x2e065990, 0x8 }, /* 1636 */ + { 0x2e065994, 0x1b7 }, /* 1637 */ + { 0x2e06599c, 0x1b7 }, /* 1639 */ + { 0x2e0659a4, 0x1b700 }, /* 1641 */ { 0x2e0659a8, 0x1980000 }, /* 1642 */ - { 0x2e0659ac, 0x27fcc }, /* 1643 */ - { 0x2e0659b4, 0x27f00 }, /* 1645 */ + { 0x2e0659ac, 0x1b7cc }, /* 1643 */ + { 0x2e0659b4, 0x1b700 }, /* 1645 */ { 0x2e0659b8, 0x1980000 }, /* 1646 */ - { 0x2e0659bc, 0x27f00 }, /* 1647 */ + { 0x2e0659bc, 0x1b700 }, /* 1647 */ { 0x2e0659c0, 0x1980000 }, /* 1648 */ - { 0x2e0659c4, 0x27f00 }, /* 1649 */ + { 0x2e0659c4, 0x1b700 }, /* 1649 */ { 0x2e0659c8, 0x1980000 }, /* 1650 */ - { 0x2e0659cc, 0x27f00 }, /* 1651 */ + { 0x2e0659cc, 0x1b700 }, /* 1651 */ { 0x2e0659d0, 0x1980000 }, /* 1652 */ { 0x2e0659d4, 0x20040003 }, /* 1653 */ };
If M33 handshake is successful, TPM and DSI panel MUX setting is done by M33, no need to set them. If handshake is failed or M33 is not booted, continue the TPM and DSI panel MUX setting
Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Biwen Li biwen.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/imx8ulp_evk.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/freescale/imx8ulp_evk/imx8ulp_evk.c b/board/freescale/imx8ulp_evk/imx8ulp_evk.c index 1502e4dbb6..b61a4cfbe8 100644 --- a/board/freescale/imx8ulp_evk/imx8ulp_evk.c +++ b/board/freescale/imx8ulp_evk/imx8ulp_evk.c @@ -101,10 +101,18 @@ void mipi_dsi_panel_backlight(void)
int board_init(void) { + int sync = -ENODEV; + if (IS_ENABLED(CONFIG_FEC_MXC)) setup_fec();
- if (IS_ENABLED(CONFIG_DM_VIDEO)) { + if (m33_image_booted()) { + sync = m33_image_handshake(1000); + printf("M33 Sync: %s\n", sync ? "Timeout" : "OK"); + } + + /* When sync with M33 is failed, use local driver to set for video */ + if (sync != 0 && IS_ENABLED(CONFIG_DM_VIDEO)) { mipi_dsi_mux_panel(); mipi_dsi_panel_backlight(); }
Since ATF power domain will hold the enable counter for each power domain, We need to power off them before entering kernel to avoid this power domain can't be really powered off.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/imx8ulp_evk.c | 30 +++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/board/freescale/imx8ulp_evk/imx8ulp_evk.c b/board/freescale/imx8ulp_evk/imx8ulp_evk.c index b61a4cfbe8..1bd308148f 100644 --- a/board/freescale/imx8ulp_evk/imx8ulp_evk.c +++ b/board/freescale/imx8ulp_evk/imx8ulp_evk.c @@ -13,6 +13,8 @@ #include <miiphy.h> #include <netdev.h> #include <asm/gpio.h> +#include <power-domain.h> +#include <dt-bindings/power/imx8ulp-power.h>
@@ -129,3 +131,31 @@ int board_late_init(void) { return 0; } + +void board_quiesce_devices(void) +{ + /* Disable the power domains may used in u-boot before entering kernel */ +#if CONFIG_IS_ENABLED(POWER_DOMAIN) + struct udevice *scmi_devpd; + int ret, i; + struct power_domain pd; + ulong ids[] = { IMX8ULP_PD_FLEXSPI2, IMX8ULP_PD_USB0, IMX8ULP_PD_USDHC0, + IMX8ULP_PD_USDHC1, IMX8ULP_PD_USDHC2_USB1, IMX8ULP_PD_DCNANO, + IMX8ULP_PD_MIPI_DSI }; + + ret = uclass_get_device(UCLASS_POWER_DOMAIN, 0, &scmi_devpd); + if (ret) { + printf("Cannot get scmi devpd: err=%d\n", ret); + return; + } + + pd.dev = scmi_devpd; + + for (i = 0; i < ARRAY_SIZE(ids); i++) { + pd.id = ids[i]; + ret = power_domain_off(&pd); + if (ret) + printf("power_domain_off %lu failed: err=%d\n", ids[i], ret); + } +#endif +}
Dynamic setting mmcdev and mmcroot. Then when boot linux, we can have correct "root=/dev/mmcblk[x]p2"
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/mach-imx/sys_proto.h | 2 + board/freescale/common/Makefile | 3 ++ board/freescale/common/mmc.c | 49 +++++++++++++++++++++++ 3 files changed, 54 insertions(+) create mode 100644 board/freescale/common/mmc.c
diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index 88216af7eb..8be3a721cd 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -229,6 +229,8 @@ int mxs_reset_block(struct mxs_register_32 *reg); int mxs_wait_mask_set(struct mxs_register_32 *reg, u32 mask, u32 timeout); int mxs_wait_mask_clr(struct mxs_register_32 *reg, u32 mask, u32 timeout);
+void board_late_mmc_env_init(void); + unsigned long call_imx_sip(unsigned long id, unsigned long reg0, unsigned long reg1, unsigned long reg2, unsigned long reg3); diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 0ddfb59d7d..81d97cd436 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -67,6 +67,9 @@ obj-$(CONFIG_ZM7300) += zm7300.o obj-$(CONFIG_POWER_PFUZE100) += pfuze.o obj-$(CONFIG_DM_PMIC_PFUZE100) += pfuze.o obj-$(CONFIG_POWER_MC34VR500) += mc34vr500.o +ifneq (,$(filter $(SOC), imx8ulp)) +obj-y += mmc.o +endif
obj-$(CONFIG_LS102XA_STREAM_ID) += ls102xa_stream_id.o
diff --git a/board/freescale/common/mmc.c b/board/freescale/common/mmc.c new file mode 100644 index 0000000000..8cd5079f96 --- /dev/null +++ b/board/freescale/common/mmc.c @@ -0,0 +1,49 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2018-2022 NXP + */ + +#include <common.h> +#include <command.h> +#include <asm/arch/sys_proto.h> +#include <linux/errno.h> +#include <asm/io.h> +#include <stdbool.h> +#include <mmc.h> +#include <env.h> + +static int check_mmc_autodetect(void) +{ + char *autodetect_str = env_get("mmcautodetect"); + + if (autodetect_str && !strcmp(autodetect_str, "yes")) + return 1; + + return 0; +} + +/* This should be defined for each board */ +__weak int mmc_map_to_kernel_blk(int dev_no) +{ + return dev_no; +} + +void board_late_mmc_env_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_dev(); + + if (!check_mmc_autodetect()) + return; + + env_set_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", mmc_map_to_kernel_blk(dev_no)); + env_set("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +}
Enable the SD/MMC port auto detect. The mmc relevant env can be reset when auto detect is enabled.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8ulp_evk/imx8ulp_evk.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/freescale/imx8ulp_evk/imx8ulp_evk.c b/board/freescale/imx8ulp_evk/imx8ulp_evk.c index 1bd308148f..5ca72e171c 100644 --- a/board/freescale/imx8ulp_evk/imx8ulp_evk.c +++ b/board/freescale/imx8ulp_evk/imx8ulp_evk.c @@ -129,6 +129,9 @@ int board_early_init_f(void)
int board_late_init(void) { +#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) + board_late_mmc_env_init(); +#endif return 0; }
Enable wdog_ad interrupt being triggered by CMC1 to CM33 to let CM33 know A35 reset and reinitialize rpmsg. Clear wdog_ad and AD_PERIPH reset interrupt after A35 up, otherwise M33 will always receive interrupt.
Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/soc.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index b0ddaef222..86ca4ffad9 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -570,6 +570,19 @@ int arch_cpu_init(void) int ret; bool rdc_en = true; /* Default assume DBD_EN is set */
+ /* Enable System Reset Interrupt using WDOG_AD */ + setbits_le32(CMC1_BASE_ADDR + 0x8C, BIT(13)); + /* Clear AD_PERIPH Power switch domain out of reset interrupt flag */ + setbits_le32(CMC1_BASE_ADDR + 0x70, BIT(4)); + + if (readl(CMC1_BASE_ADDR + 0x90) & BIT(13)) { + /* Clear System Reset Interrupt Flag Register of WDOG_AD */ + setbits_le32(CMC1_BASE_ADDR + 0x90, BIT(13)); + /* Reset WDOG to clear reset request */ + pcc_reset_peripheral(3, WDOG3_PCC3_SLOT, true); + pcc_reset_peripheral(3, WDOG3_PCC3_SLOT, false); + } + /* Disable wdog */ init_wdog();
The TEE memory should be reserved when TEE is present, so need to runtime update dram bank and memory information according to tee present or not.
Signed-off-by: Ji Luo ji.luo@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/soc.c | 102 +++++++++++++++++++++++++++++++- 1 file changed, 100 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index 86ca4ffad9..7aa89aefe8 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -412,6 +412,17 @@ static struct mm_region imx8ulp_arm64_mem_map[] = {
struct mm_region *mem_map = imx8ulp_arm64_mem_map;
+static unsigned int imx8ulp_find_dram_entry_in_mem_map(void) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(imx8ulp_arm64_mem_map); i++) + if (imx8ulp_arm64_mem_map[i].phys == CONFIG_SYS_SDRAM_BASE) + return i; + + hang(); /* Entry not found, this must never happen. */ +} + /* simplify the page table size to enhance boot speed */ #define MAX_PTE_ENTRIES 512 #define MAX_MEM_MAP_REGIONS 16 @@ -443,19 +454,106 @@ u64 get_page_table_size(void)
void enable_caches(void) { - /* TODO: add TEE memmap region */ + /* If OPTEE runs, remove OPTEE memory from MMU table to avoid speculative prefetch */ + if (rom_pointer[1]) { + /* + * TEE are loaded, So the ddr bank structures + * have been modified update mmu table accordingly + */ + int i = 0; + int entry = imx8ulp_find_dram_entry_in_mem_map(); + u64 attrs = imx8ulp_arm64_mem_map[entry].attrs; + + while (i < CONFIG_NR_DRAM_BANKS && + entry < ARRAY_SIZE(imx8ulp_arm64_mem_map)) { + if (gd->bd->bi_dram[i].start == 0) + break; + imx8ulp_arm64_mem_map[entry].phys = gd->bd->bi_dram[i].start; + imx8ulp_arm64_mem_map[entry].virt = gd->bd->bi_dram[i].start; + imx8ulp_arm64_mem_map[entry].size = gd->bd->bi_dram[i].size; + imx8ulp_arm64_mem_map[entry].attrs = attrs; + debug("Added memory mapping (%d): %llx %llx\n", entry, + imx8ulp_arm64_mem_map[entry].phys, imx8ulp_arm64_mem_map[entry].size); + i++; entry++; + } + }
icache_enable(); dcache_enable(); }
+__weak int board_phys_sdram_size(phys_size_t *size) +{ + if (!size) + return -EINVAL; + + *size = PHYS_SDRAM_SIZE; + return 0; +} + int dram_init(void) { - gd->ram_size = PHYS_SDRAM_SIZE; + unsigned int entry = imx8ulp_find_dram_entry_in_mem_map(); + phys_size_t sdram_size; + int ret; + + ret = board_phys_sdram_size(&sdram_size); + if (ret) + return ret; + + /* rom_pointer[1] contains the size of TEE occupies */ + if (rom_pointer[1]) + gd->ram_size = sdram_size - rom_pointer[1]; + else + gd->ram_size = sdram_size; + + /* also update the SDRAM size in the mem_map used externally */ + imx8ulp_arm64_mem_map[entry].size = sdram_size; + return 0; +} + +int dram_init_banksize(void) +{ + int bank = 0; + int ret; + phys_size_t sdram_size; + + ret = board_phys_sdram_size(&sdram_size); + if (ret) + return ret; + + gd->bd->bi_dram[bank].start = PHYS_SDRAM; + if (rom_pointer[1]) { + phys_addr_t optee_start = (phys_addr_t)rom_pointer[0]; + phys_size_t optee_size = (size_t)rom_pointer[1]; + + gd->bd->bi_dram[bank].size = optee_start - gd->bd->bi_dram[bank].start; + if ((optee_start + optee_size) < (PHYS_SDRAM + sdram_size)) { + if (++bank >= CONFIG_NR_DRAM_BANKS) { + puts("CONFIG_NR_DRAM_BANKS is not enough\n"); + return -1; + } + + gd->bd->bi_dram[bank].start = optee_start + optee_size; + gd->bd->bi_dram[bank].size = PHYS_SDRAM + + sdram_size - gd->bd->bi_dram[bank].start; + } + } else { + gd->bd->bi_dram[bank].size = sdram_size; + }
return 0; }
+phys_size_t get_effective_memsize(void) +{ + /* return the first bank as effective memory */ + if (rom_pointer[1]) + return ((phys_addr_t)rom_pointer[0] - PHYS_SDRAM); + + return gd->ram_size; +} + #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG void get_board_serial(struct tag_serialnr *serialnr) {
When TEE is present, the DRAM maybe split to two parts, so enlarge CONFIG_NR_DRAM_BANKS
Signed-off-by: Peng Fan peng.fan@nxp.com --- configs/imx8ulp_evk_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/imx8ulp_evk_defconfig b/configs/imx8ulp_evk_defconfig index 0e2a646ebf..4eaf3085b2 100644 --- a/configs/imx8ulp_evk_defconfig +++ b/configs/imx8ulp_evk_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_LEN=0x1002000 CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 +CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG=""
Hi Peng,
I think this description is confusing.
CONFIG_NR_DRAM_BANKS should be set according to how many DDR chips are connected.
The usage of TEE is not relevant to CONFIG_NR_DRAM_BANKS.
On 2022/2/26 21:28, Fabio Estevam wrote:
Hi Peng,
TEE locates in the middle of DRAM memory space, it will split the DRAM. I not have other idea how to support this without enlarge CONFIG_NR_DRAM_BANKS.
Thanks, Peng.
Introdue i.MX8ULP power entry header
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/dt-bindings/power/imx8ulp-power.h | 26 +++++++++++++++++++++++ 1 file changed, 26 insertions(+) create mode 100644 include/dt-bindings/power/imx8ulp-power.h
diff --git a/include/dt-bindings/power/imx8ulp-power.h b/include/dt-bindings/power/imx8ulp-power.h new file mode 100644 index 0000000000..a556b2e96d --- /dev/null +++ b/include/dt-bindings/power/imx8ulp-power.h @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: (GPL-2.0 OR MIT) */ +/* + * Copyright 2021 NXP + */ + +#ifndef __DT_BINDINGS_IMX8ULP_POWER_H__ +#define __DT_BINDINGS_IMX8ULP_POWER_H__ + +#define IMX8ULP_PD_DMA1 0 +#define IMX8ULP_PD_FLEXSPI2 1 +#define IMX8ULP_PD_USB0 2 +#define IMX8ULP_PD_USDHC0 3 +#define IMX8ULP_PD_USDHC1 4 +#define IMX8ULP_PD_USDHC2_USB1 5 +#define IMX8ULP_PD_DCNANO 6 +#define IMX8ULP_PD_EPDC 7 +#define IMX8ULP_PD_DMA2 8 +#define IMX8ULP_PD_GPU2D 9 +#define IMX8ULP_PD_GPU3D 10 +#define IMX8ULP_PD_HIFI4 11 +#define IMX8ULP_PD_ISI 12 +#define IMX8ULP_PD_MIPI_CSI 13 +#define IMX8ULP_PD_MIPI_DSI 14 +#define IMX8ULP_PD_PXP 15 + +#endif
Hi Peng,
s/Introdue/Introduce
Please explain why this header file is needed.
You introduce this header file on 25/27, but I don't see any usage of it on 26/27 and 27/27.
Enable multiple storages for u-boot env: MMC or SPI flash or NOWHERE for usb so u-boot can runtime select the storage flash according to boot device.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8ulp/soc.c | 36 +++++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/arch/arm/mach-imx/imx8ulp/soc.c b/arch/arm/mach-imx/imx8ulp/soc.c index 7aa89aefe8..e40df1e290 100644 --- a/arch/arm/mach-imx/imx8ulp/soc.c +++ b/arch/arm/mach-imx/imx8ulp/soc.c @@ -26,6 +26,8 @@ #include <fuse.h> #include <thermal.h> #include <linux/iopoll.h> +#include <env.h> +#include <env_internal.h>
@@ -785,3 +787,37 @@ u32 spl_arch_boot_image_offset(u32 image_offset, u32 rom_bt_dev)
return image_offset; } + +enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + switch (dev) { +#ifdef CONFIG_ENV_IS_IN_SPI_FLASH + case QSPI_BOOT: + env_loc = ENVL_SPI_FLASH; + break; +#endif +#ifdef CONFIG_ENV_IS_IN_MMC + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; +#endif + default: +#if defined(CONFIG_ENV_IS_NOWHERE) + env_loc = ENVL_NOWHERE; +#endif + break; + } + + return env_loc; +}
- According to S400 API, the fuse bank 25 (Testconfig2) is able to access. Add it into driver's mapping table. - According to FSB words list, the reserved 48 words are ahead of the bank 5 and bank 6. Fix the wrong position.
Signed-off-by: Ye Li ye.li@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/misc/imx8ulp/fuse.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/imx8ulp/fuse.c b/drivers/misc/imx8ulp/fuse.c index 01db470e8f..090e702d9f 100644 --- a/drivers/misc/imx8ulp/fuse.c +++ b/drivers/misc/imx8ulp/fuse.c @@ -34,9 +34,9 @@ struct s400_map_entry { struct fsb_map_entry fsb_mapping_table[] = { { 3, 8 }, { 4, 8 }, + { -1, 48 }, /* Reserve 48 words */ { 5, 8 }, { 6, 8 }, - { -1, 48 }, /* Reserve 48 words */ { 8, 4, true }, { 24, 4, true }, { 26, 4, true }, @@ -63,6 +63,7 @@ struct s400_map_entry s400_api_mapping_table[] = { { 7, 4, 0, 1 }, /* OTP_UNIQ_ID */ { 15, 8 }, /* OEM SRK HASH */ { 23, 1, 4, 2 }, /* OTFAD */ + { 25, 8 }, /* Test config2 */ };
static s32 map_fsb_fuse_index(u32 bank, u32 word, bool *redundancy)
Fabio Estevam
Peng Fan (OSS)
