[U-Boot] UEFI on u-boot
Hi Alex, Hope you are doing great,
Could you help on UEFI over the u-boot. 1- I couldn't locate EFI_DXE_SERVICES in u-boot, do you have plan to add those 2- If I load a driver (with bootefi) which install few protocols, is this ok to do with u-boot 3- if you say, 2 is ok then I hope these protocols are kept in some data base, and this new protocol can be opened by an application 4- if there is some known limitation, like we cannot run DXE_driver etc
Thanks Udit
Hi Udit,
Right now the model is that all device drivers are implemented by U-Boot and that only exposes their interfaces to EFI applications. Implementing DXE in U-Boot would open quite a big can of worms, as it would really only be useful in compilation with PI which is a terrible interface :).
It depends on how much the driver does, but in general yes. Heinrich is currently working on making the iPXE iSCSI driver work, so his EFI payload would expose an EFI block device to yet another payload running after his.
Yes, the protocol database is now global and persistent across bootefi invocations.
What exactly are you trying to do? With the U-Boot UEFI implementation we're trying to find a sweet spot between implementing as much as makes sense, but not the whole UEFI world, as that would just bloat the code needlessly.
Alex
Hi Alex
-----Original Message----- From: Alexander Graf [mailto:agraf@suse.de] Sent: Monday, January 15, 2018 2:45 PM To: Udit Kumar udit.kumar@nxp.com
Hi Udit,
Ok,
Thanks for this, Heinrich, in this driver, are you accessing underneath hardware register by UEFI-Driver and managing UEFI protocols or you are relying on some h/w access exposed by u-boot driver
Thanks
I am trying to add a driver (DXE by definition) which a) Access the hardware registers. (I said DXE could due to hardware registers) b) Update memory map as well (AddMemorySpace call) c) Finally it export a protocol, which could be used by its test application.
For b) I am not able to find function call, For a), if I say driver is UEFI and accessing hardware register, will this be acceptable ?
Alex
On 15.01.18 10:32, Udit Kumar wrote:
Hi Alex
Hi Udit,
Ok,
Thanks
What exactly beyond efi_allocate_pages() do you need? The EFI memory map is really only used as data source for EFI applications. The actual 1:1 U-Boot map is not influenced by it.
Yes, definitely. All you'd need to do is set the efi application type to application, then register your protocols and access hardware registers using direct MMIO access to their respective regions.
Alex
Hi Alex,
-----Original Message----- From: Alexander Graf [mailto:agraf@suse.de] Sent: Monday, January 15, 2018 5:02 PM To: Udit Kumar udit.kumar@nxp.com Cc: u-boot@lists.denx.de; Heinrich Schuchardt xypron.glpk@gmx.de Subject: Re: UEFI on u-boot
Hi Alex
Hi Udit,
interface :).
Ok,
after his.
Thanks
What exactly beyond efi_allocate_pages() do you need? The EFI memory map is really only used as data source for EFI applications. The actual 1:1 U- Boot map is not influenced by it.
I am exploring possibility, If a driver discover memory and want to add this in system. For example, at build time 1Gb is reserved for a given driver but at run-time driver is told to use little less memory say 512Mb and this driver can return back 512Mb to system (In UEFI call is being AddMemorySpace under DXE services)
acceptable ?
Thanks
Alex
On 01/16/2018 06:28 AM, Udit Kumar wrote:
Hi Alex,
Hi Alex
Hi Udit,
interface :).
Ok,
after his.
Thanks
The UEFI specification defines different memory types which can be used when allocating memory. Whether a memory type can be used by an UEFI OS loader or an OS determines on the boottime exit event. Many classes of memory become generally available after exiting the boottime. This is decribed in chapter "7.2 Memory Allocation Services" of UEFI spec 2.7.
Regards
Heinrich
acceptable ?
Thanks
Alex
-----Original Message----- From: Heinrich Schuchardt [mailto:xypron.glpk@gmx.de] Sent: Tuesday, January 16, 2018 12:39 PM To: Udit Kumar udit.kumar@nxp.com; Alexander Graf agraf@suse.de Cc: u-boot@lists.denx.de Subject: Re: UEFI on u-boot
Hi Alex,
Hi Alex
Hi Udit,
interface :).
Ok,
after his.
Thanks
application.
this in system.
For allocation this is perfectly fine. How a driver can update the memory map. Let me ask this in other way, when we create UEFI memory map in u-boot How we are creating this ? using memory node of device tree or some other way.
Thanks Udit
Regards
Heinrich
acceptable ?
Thanks
Alex
Hi Alex,
Hi Alex
Hi Udit,
On 15.01.18 10:09, Udit Kumar wrote: > Hi Alex, > Hope you are doing great, > > Could you help on UEFI over the u-boot. > 1- I couldn't locate EFI_DXE_SERVICES in u-boot, do you have plan > to add those
interface :).
Ok,
> 2- If I load a driver (with bootefi) which install few protocols, > is this ok to do with u-boot
after his.
> 3- if you say, 2 is ok then I hope these protocols are kept in > some data base, and this new protocol can be opened by an > application
Thanks
> 4- if there is some known limitation, like we cannot run > DXE_driver etc
application.
this in system.
Any allocation simply overrides the memory map, so if you explicitly allocate CONVENTIONAL_MEMORY at an address that was declared as MMIO space before, the efi memory map will get updated accordingly.
It uses board specific knowledge of memory ranges.
Alex
Hi Alex
-----Original Message----- From: Alexander Graf [mailto:agraf@suse.de] Sent: Tuesday, January 16, 2018 7:52 PM To: Udit Kumar udit.kumar@nxp.com; Heinrich Schuchardt xypron.glpk@gmx.de Cc: u-boot@lists.denx.de Subject: Re: UEFI on u-boot
Hi Alex,
Hi Alex
> -----Original Message----- > From: Alexander Graf [mailto:agraf@suse.de] > Sent: Monday, January 15, 2018 2:45 PM > To: Udit Kumar udit.kumar@nxp.com > > Hi Udit, > > On 15.01.18 10:09, Udit Kumar wrote: >> Hi Alex, >> Hope you are doing great, >> >> Could you help on UEFI over the u-boot. >> 1- I couldn't locate EFI_DXE_SERVICES in u-boot, do you have >> plan to add those > > Right now the model is that all device drivers are implemented by > U-Boot and that only exposes their interfaces to EFI applications. > Implementing DXE in U-Boot would open quite a big can of worms, > as it would really only be useful in compilation with PI which is > a terrible
interface :).
Ok,
>> 2- If I load a driver (with bootefi) which install few >> protocols, is this ok to do with u-boot > > It depends on how much the driver does, but in general yes. > Heinrich is currently working on making the iPXE iSCSI driver > work, so his EFI payload would expose an EFI block device to yet > another payload running
after his.
>> 3- if you say, 2 is ok then I hope these protocols are kept in >> some data base, and this new protocol can be opened by an >> application > > Yes, the protocol database is now global and persistent across > bootefi invocations.
Thanks
>> 4- if there is some known limitation, like we cannot run >> DXE_driver etc > > What exactly are you trying to do? With the U-Boot UEFI > implementation we're trying to find a sweet spot between > implementing as much as makes sense, but not the whole UEFI > world, as that would just bloat the code needlessly.
application.
this in system.
an
UEFI spec 2.7.
Once UEFI memory map is created, then is this possible to add new memory in this map , for the moment I am fine if using UEFI driver adding this memory into board specific ranges and this is reflected back to UEFI map.
Thanks Alex and Heinrich
I guess function efi_add_memory_map will do, what I was looking for
Regards Udit
-----Original Message----- From: Udit Kumar Sent: Sunday, January 21, 2018 4:13 PM To: 'Alexander Graf' agraf@suse.de; Heinrich Schuchardt xypron.glpk@gmx.de Cc: u-boot@lists.denx.de Subject: RE: UEFI on u-boot
Hi Alex
Hi Alex,
On 15.01.18 10:32, Udit Kumar wrote: > Hi Alex > >> -----Original Message----- >> From: Alexander Graf [mailto:agraf@suse.de] >> Sent: Monday, January 15, 2018 2:45 PM >> To: Udit Kumar udit.kumar@nxp.com >> >> Hi Udit, >> >> On 15.01.18 10:09, Udit Kumar wrote: >>> Hi Alex, >>> Hope you are doing great, >>> >>> Could you help on UEFI over the u-boot. >>> 1- I couldn't locate EFI_DXE_SERVICES in u-boot, do you have >>> plan to add those >> >> Right now the model is that all device drivers are implemented >> by U-Boot and that only exposes their interfaces to EFI
applications.
>> Implementing DXE in U-Boot would open quite a big can of worms, >> as it would really only be useful in compilation with PI which >> is a terrible interface :). > > Ok, > >>> 2- If I load a driver (with bootefi) which install few >>> protocols, is this ok to do with u-boot >> >> It depends on how much the driver does, but in general yes. >> Heinrich is currently working on making the iPXE iSCSI driver >> work, so his EFI payload would expose an EFI block device to >> yet another payload running after his. > > Thanks for this, > Heinrich, in this driver, are you accessing underneath > hardware register by UEFI-Driver and managing UEFI protocols or > you are relying on some h/w access exposed by u-boot driver > > > >>> 3- if you say, 2 is ok then I hope these protocols are kept in >>> some data base, and this new protocol can be opened by an >>> application >> >> Yes, the protocol database is now global and persistent across >> bootefi invocations. > > Thanks > >>> 4- if there is some known limitation, like we cannot run >>> DXE_driver etc >> >> What exactly are you trying to do? With the U-Boot UEFI >> implementation we're trying to find a sweet spot between >> implementing as much as makes sense, but not the whole UEFI >> world, as that would just bloat the code needlessly. > > I am trying to add a driver (DXE by definition) which > a) Access the hardware registers. (I said DXE could due to > hardware > registers) > b) Update memory map as well (AddMemorySpace call) > c) Finally it export a protocol, which could be used by its test
application.
this in system.
an
UEFI spec 2.7.
MMIO
On 01/15/2018 10:32 AM, Udit Kumar wrote:
Hi Alex
Hi Udit,
Ok,
With the command bootefi you can load an executable that adds boottime or runtime services.
Unfortunatly there are some missing points:
When loading the image the memory category reserved for the image is not chosen in dependence of the image type. This will cause major trouble for runtime drivers.
The exit() service does not call the unload function of the driver/application.
U-Boot exposes the network interface as EFI simple network protocol. iPXE provides TCP and iSCSI on top of the SNP. It creates a handle and install the a block IO protocol on it. When ConnectController is called the U-Boot EFI block driver creates the partitions as children of aforementioned handle and installs the simple file protocol on the child handles.
See patch https://lists.denx.de/pipermail/u-boot/2018-January/316708.html
Regards
Heinrich
Thanks
Alex
Thanks Heinrich
-----Original Message----- From: Heinrich Schuchardt [mailto:xypron.glpk@gmx.de] Sent: Tuesday, January 16, 2018 2:55 AM To: Udit Kumar udit.kumar@nxp.com; Alexander Graf agraf@suse.de Cc: u-boot@lists.denx.de Subject: Re: UEFI on u-boot
Hi Alex
Hi Udit,
interface :).
Ok,
When loading the image the memory category reserved for the image is not chosen in dependence of the image type. This will cause major trouble for runtime drivers. The exit() service does not call the unload function of the driver/application.
Thanks for warning, for the moment I am ok with simple driver
after his.
See patch https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists. denx.de%2Fpipermail%2Fu-boot%2F2018- January%2F316708.html&data=02%7C01%7Cudit.kumar%40nxp.com%7Cc19b 8ec63abb4ee7ff1908d55c5e7be8%7C686ea1d3bc2b4c6fa92cd99c5c301635%7 C0%7C0%7C636516483235326220&sdata=wUx1fErZM2G6xjB7Aq89ntqs5bRGt TXZKKcfLgWef4M%3D&reserved=0
Thanks, you rely on u-boot exports. Alex answered in previous post as in UEFI driver MMIO read/write is allowed
Regards
Heinrich
Thanks
Alex
Alexander Graf
Udit Kumar
