Re: [U-Boot] [PATCH 4/8] serial: add serial driver for BCM6345
Am 13.04.2017 um 17:52 schrieb Álvaro Fernández Rojas:
It is based on linux/drivers/tty/serial/bcm63xx_uart.c
Signed-off-by: Álvaro Fernández Rojas noltari@gmail.com
drivers/serial/Kconfig | 14 ++ drivers/serial/Makefile | 1 + drivers/serial/serial_bcm6345.c | 341 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 356 insertions(+) create mode 100644 drivers/serial/serial_bcm6345.c
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index c0ec2ec..ca776d8 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -134,6 +134,14 @@ config DEBUG_UART_ATMEL will need to provide parameters to make this work. The driver will be available until the real driver-model serial is running.
+config DEBUG_UART_BCM6345
- bool "BCM6345 UART"
- depends on BCM6345_SERIAL
- help
Select this to enable a debug UART on BCM6345 SoCs. You
be available until the real driver model serial is running.
config DEBUG_UART_NS16550 bool "ns16550" help @@ -339,6 +347,12 @@ config ATMEL_USART configured in the device tree, and input clock frequency can be got from the clk node.
+config BCM6345_SERIAL
- bool "Support for BCM6345 UART"
- depends on DM_SERIAL
- help
Select this to enable UART on BCM6345 SoCs.
config FSL_LPUART bool "Freescale LPUART support" help diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 4382cf9..dca31b2 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -20,6 +20,7 @@ obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o obj-$(CONFIG_AR933X_UART) += serial_ar933x.o obj-$(CONFIG_ARM_DCC) += arm_dcc.o obj-$(CONFIG_ATMEL_USART) += atmel_usart.o +obj-$(CONFIG_BCM6345_SERIAL) += serial_bcm6345.o obj-$(CONFIG_EFI_APP) += serial_efi.o obj-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o obj-$(CONFIG_MCFUART) += mcfuart.o diff --git a/drivers/serial/serial_bcm6345.c b/drivers/serial/serial_bcm6345.c new file mode 100644 index 0000000..8754e76 --- /dev/null +++ b/drivers/serial/serial_bcm6345.c @@ -0,0 +1,341 @@ +/*
- Copyright (C) 2017 Álvaro Fernández Rojas noltari@gmail.com
- Derived from linux/drivers/tty/serial/bcm63xx_uart.c:
- Copyright (C) 2008 Maxime Bizon mbizon@freebox.fr
+#include <serial.h> +#include <errno.h> +#include <clk.h> +#include <debug_uart.h> +#include <asm/io.h> +#include <asm/types.h> +#include <dm/device.h>
+/* UART Control Register */ +#define UART_CTL_REG 0x0 +#define UART_CTL_RXTMOUTCNT_SHIFT 0 +#define UART_CTL_RXTMOUTCNT_MASK (0x1f << UART_CTL_RXTMOUTCNT_SHIFT) +#define UART_CTL_RSTTXDN_SHIFT 5 +#define UART_CTL_RSTTXDN_MASK (1 << UART_CTL_RSTTXDN_SHIFT) +#define UART_CTL_RSTRXFIFO_SHIFT 6 +#define UART_CTL_RSTRXFIFO_MASK (1 << UART_CTL_RSTRXFIFO_SHIFT) +#define UART_CTL_RSTTXFIFO_SHIFT 7 +#define UART_CTL_RSTTXFIFO_MASK (1 << UART_CTL_RSTTXFIFO_SHIFT) +#define UART_CTL_STOPBITS_SHIFT 8 +#define UART_CTL_STOPBITS_MASK (0xf << UART_CTL_STOPBITS_SHIFT) +#define UART_CTL_STOPBITS_1 (0x7 << UART_CTL_STOPBITS_SHIFT) +#define UART_CTL_STOPBITS_2 (0xf << UART_CTL_STOPBITS_SHIFT) +#define UART_CTL_BITSPERSYM_SHIFT 12 +#define UART_CTL_BITSPERSYM_MASK (0x3 << UART_CTL_BITSPERSYM_SHIFT) +#define UART_CTL_XMITBRK_SHIFT 14 +#define UART_CTL_XMITBRK_MASK (1 << UART_CTL_XMITBRK_SHIFT) +#define UART_CTL_RSVD_SHIFT 15 +#define UART_CTL_RSVD_MASK (1 << UART_CTL_RSVD_SHIFT) +#define UART_CTL_RXPAREVEN_SHIFT 16 +#define UART_CTL_RXPAREVEN_MASK (1 << UART_CTL_RXPAREVEN_SHIFT) +#define UART_CTL_RXPAREN_SHIFT 17 +#define UART_CTL_RXPAREN_MASK (1 << UART_CTL_RXPAREN_SHIFT) +#define UART_CTL_TXPAREVEN_SHIFT 18 +#define UART_CTL_TXPAREVEN_MASK (1 << UART_CTL_TXPAREVEN_SHIFT) +#define UART_CTL_TXPAREN_SHIFT 18 +#define UART_CTL_TXPAREN_MASK (1 << UART_CTL_TXPAREN_SHIFT) +#define UART_CTL_LOOPBACK_SHIFT 20 +#define UART_CTL_LOOPBACK_MASK (1 << UART_CTL_LOOPBACK_SHIFT) +#define UART_CTL_RXEN_SHIFT 21 +#define UART_CTL_RXEN_MASK (1 << UART_CTL_RXEN_SHIFT) +#define UART_CTL_TXEN_SHIFT 22 +#define UART_CTL_TXEN_MASK (1 << UART_CTL_TXEN_SHIFT) +#define UART_CTL_BRGEN_SHIFT 23 +#define UART_CTL_BRGEN_MASK (1 << UART_CTL_BRGEN_SHIFT)
+/* UART Baudword register */ +#define UART_BAUD_REG 0x4
+/* UART Misc Control register */ +#define UART_MCTL_REG 0x8 +#define UART_MCTL_DTR_SHIFT 0 +#define UART_MCTL_DTR_MASK (1 << UART_MCTL_DTR_SHIFT) +#define UART_MCTL_RTS_SHIFT 1 +#define UART_MCTL_RTS_MASK (1 << UART_MCTL_RTS_SHIFT) +#define UART_MCTL_RXFIFOTHRESH_SHIFT 8 +#define UART_MCTL_RXFIFOTHRESH_MASK (0xf << UART_MCTL_RXFIFOTHRESH_SHIFT) +#define UART_MCTL_TXFIFOTHRESH_SHIFT 12 +#define UART_MCTL_TXFIFOTHRESH_MASK (0xf << UART_MCTL_TXFIFOTHRESH_SHIFT) +#define UART_MCTL_RXFIFOFILL_SHIFT 16 +#define UART_MCTL_RXFIFOFILL_MASK (0x1f << UART_MCTL_RXFIFOFILL_SHIFT) +#define UART_MCTL_TXFIFOFILL_SHIFT 24 +#define UART_MCTL_TXFIFOFILL_MASK (0x1f << UART_MCTL_TXFIFOFILL_SHIFT)
+/* UART External Input Configuration register */ +#define UART_EXTINP_REG 0xc +#define UART_EXTINP_RI_SHIFT 0 +#define UART_EXTINP_RI_MASK (1 << UART_EXTINP_RI_SHIFT) +#define UART_EXTINP_CTS_SHIFT 1 +#define UART_EXTINP_CTS_MASK (1 << UART_EXTINP_CTS_SHIFT) +#define UART_EXTINP_DCD_SHIFT 2 +#define UART_EXTINP_DCD_MASK (1 << UART_EXTINP_DCD_SHIFT) +#define UART_EXTINP_DSR_SHIFT 3 +#define UART_EXTINP_DSR_MASK (1 << UART_EXTINP_DSR_SHIFT) +#define UART_EXTINP_IRSTAT(x) (1 << (x + 4)) +#define UART_EXTINP_IRMASK(x) (1 << (x + 8)) +#define UART_EXTINP_IR_RI 0 +#define UART_EXTINP_IR_CTS 1 +#define UART_EXTINP_IR_DCD 2 +#define UART_EXTINP_IR_DSR 3 +#define UART_EXTINP_RI_NOSENSE_SHIFT 16 +#define UART_EXTINP_RI_NOSENSE_MASK (1 << UART_EXTINP_RI_NOSENSE_SHIFT) +#define UART_EXTINP_CTS_NOSENSE_SHIFT 17 +#define UART_EXTINP_CTS_NOSENSE_MASK (1 << UART_EXTINP_CTS_NOSENSE_SHIFT) +#define UART_EXTINP_DCD_NOSENSE_SHIFT 18 +#define UART_EXTINP_DCD_NOSENSE_MASK (1 << UART_EXTINP_DCD_NOSENSE_SHIFT) +#define UART_EXTINP_DSR_NOSENSE_SHIFT 19 +#define UART_EXTINP_DSR_NOSENSE_MASK (1 << UART_EXTINP_DSR_NOSENSE_SHIFT)
+/* UART Interrupt register */ +#define UART_IR_REG 0x10 +#define UART_IR_MASK(x) (1 << (x + 16)) +#define UART_IR_STAT(x) (1 << (x)) +#define UART_IR_EXTIP 0 +#define UART_IR_TXUNDER 1 +#define UART_IR_TXOVER 2 +#define UART_IR_TXTRESH 3 +#define UART_IR_TXRDLATCH 4 +#define UART_IR_TXEMPTY 5 +#define UART_IR_RXUNDER 6 +#define UART_IR_RXOVER 7 +#define UART_IR_RXTIMEOUT 8 +#define UART_IR_RXFULL 9 +#define UART_IR_RXTHRESH 10 +#define UART_IR_RXNOTEMPTY 11 +#define UART_IR_RXFRAMEERR 12 +#define UART_IR_RXPARERR 13 +#define UART_IR_RXBRK 14 +#define UART_IR_TXDONE 15
+/* UART Fifo register */ +#define UART_FIFO_REG 0x14 +#define UART_FIFO_VALID_SHIFT 0 +#define UART_FIFO_VALID_MASK 0xff +#define UART_FIFO_FRAMEERR_SHIFT 8 +#define UART_FIFO_FRAMEERR_MASK (1 << UART_FIFO_FRAMEERR_SHIFT) +#define UART_FIFO_PARERR_SHIFT 9 +#define UART_FIFO_PARERR_MASK (1 << UART_FIFO_PARERR_SHIFT) +#define UART_FIFO_BRKDET_SHIFT 10 +#define UART_FIFO_BRKDET_MASK (1 << UART_FIFO_BRKDET_SHIFT) +#define UART_FIFO_ANYERR_MASK (UART_FIFO_FRAMEERR_MASK | \
UART_FIFO_PARERR_MASK | \
UART_FIFO_BRKDET_MASK)
you should remove all defines you don't need in your driver code
+struct bcm6345_serial_priv {
- void __iomem *base;
- ulong uartclk;
- enable rx & tx operation on uart
+static void bcm6345_serial_enable(void __iomem *base) +{
- u32 val;
- val = __raw_readl(base + UART_CTL_REG);
- val |= (UART_CTL_BRGEN_MASK | UART_CTL_TXEN_MASK | UART_CTL_RXEN_MASK);
- __raw_writel(val, base + UART_CTL_REG);
in general you should try to use readl/writel as well as setbits_32/clrbits_32/clrsetbit_32. But because you have CONFIG_SWAP_IO_SPACE enabled in all your defconfigs, you have to switch to readl_be32/writel_be32 and setbits_be32/clrbits_be32/clrsetbits_be32
- disable rx & tx operation on uart
+static void bcm6345_serial_disable(void __iomem *base) +{
- u32 val;
- val &= ~(UART_CTL_BRGEN_MASK | UART_CTL_TXEN_MASK |
- clear all unread data in rx fifo and unsent data in tx fifo
+static void bcm6345_serial_flush(void __iomem *base) +{
- u32 val;
- /* empty rx and tx fifo */
- val |= UART_CTL_RSTRXFIFO_MASK | UART_CTL_RSTTXFIFO_MASK;
- /* read any pending char to make sure all irq status are
* cleared */
incorrect multi-line comment
- __raw_readl(base + UART_FIFO_REG);
+static int bcm6345_serial_init(void __iomem *base, ulong clk, u32 baudrate) +{
- u32 val;
- /* mask all irq and flush port */
- bcm6345_serial_disable(base);
- bcm6345_serial_flush(base);
- /* set bits per sym and stop bits */
- val &= ~UART_CTL_BITSPERSYM_MASK;
- val |= (3 << UART_CTL_BITSPERSYM_SHIFT);
- val |= UART_CTL_STOPBITS_1;
- /* set baud rate */
- val = (clk / baudrate) / 16;
- if (val & 0x1)
val = val;
- else
val = val / 2 - 1;
- __raw_writel(val, base + UART_BAUD_REG);
- /* clear interrupts */
- __raw_writel(0, base + UART_IR_REG);
- /* enable uart */
- bcm6345_serial_enable(base);
+static int bcm6345_serial_pending(struct udevice *dev, bool input) +{
- struct bcm6345_serial_priv *priv = dev_get_priv(dev);
- u32 val = __raw_readl(priv->base + UART_IR_REG);
- if (input)
return (val & UART_IR_STAT(UART_IR_RXNOTEMPTY)) ? 1 : 0;
- else
return (val & UART_IR_STAT(UART_IR_TXEMPTY)) ? 0 : 1;
+static int bcm6345_serial_setbrg(struct udevice *dev, int baudrate) +{
- return bcm6345_serial_init(priv->base, priv->uartclk, baudrate);
+static int bcm6345_serial_putc(struct udevice *dev, const char ch) +{
- u32 val;
- val = __raw_readl(priv->base + UART_IR_REG);
- if (!(val & UART_IR_STAT(UART_IR_TXEMPTY)))
return -EAGAIN;
- __raw_writel(ch, priv->base + UART_FIFO_REG);
+static int bcm6345_serial_getc(struct udevice *dev) +{
- u32 val;
- if (val & UART_IR_STAT(UART_IR_RXOVER)) {
/* fifo reset is required to clear interrupt */
val = __raw_readl(priv->base + UART_CTL_REG);
val |= UART_CTL_RSTRXFIFO_MASK;
__raw_writel(val, priv->base + UART_CTL_REG);
- if (!(val & UART_IR_STAT(UART_IR_RXNOTEMPTY)))
return -EAGAIN;
- val = __raw_readl(priv->base + UART_FIFO_REG);
- if (val & UART_FIFO_ANYERR_MASK)
return -EAGAIN;
- return (val & UART_FIFO_VALID_MASK);
+static int bcm6345_serial_probe(struct udevice *dev) +{
- struct clk clk;
- fdt_addr_t addr;
- fdt_size_t size;
- int ret;
- /* get address */
- addr = dev_get_addr_size_index(dev, 0, &size);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->base = ioremap(addr, size);
- /* get clock rate */
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0)
return ret;
- priv->uartclk = clk_get_rate(&clk) / 2;
- clk_free(&clk);
- /* initialize serial */
- return bcm6345_serial_init(priv->base, priv->uartclk, CONFIG_BAUDRATE);
+static const struct dm_serial_ops bcm6345_serial_ops = {
- .putc = bcm6345_serial_putc,
- .pending = bcm6345_serial_pending,
- .getc = bcm6345_serial_getc,
- .setbrg = bcm6345_serial_setbrg,
+static const struct udevice_id bcm6345_serial_of_match[] = {
- { .compatible = "brcm,bcm6345-uart" },
- { /* sentinel */ }
+U_BOOT_DRIVER(bcm6345_serial) = {
- .name = "bcm6345-uart",
- .id = UCLASS_SERIAL,
- .of_match = bcm6345_serial_of_match,
- .probe = bcm6345_serial_probe,
- .priv_auto_alloc_size = sizeof(struct bcm6345_serial_priv),
- .ops = &bcm6345_serial_ops,
- .flags = DM_FLAG_PRE_RELOC,
+#ifdef CONFIG_DEBUG_UART_BCM6345 +static inline void _debug_uart_init(void) +{
- void __iomem *base = (void __iomem *)CONFIG_DEBUG_UART_BASE;
- bcm6345_serial_init(base, CONFIG_DEBUG_UART_CLOCK, CONFIG_BAUDRATE);
+static inline void wait_xfered(void __iomem *base) +{
- do {
u32 val = __raw_readl(base + UART_IR_REG);
if (val & UART_IR_STAT(UART_IR_TXEMPTY))
break;
- } while (1);
+static inline void _debug_uart_putc(int ch) +{
- wait_xfered(base);
- __raw_writel(ch, base + UART_FIFO_REG);
+DEBUG_UART_FUNCS +#endif
Hi Daniel,
- help
- help
Ok, I will remove them.
- ulong uartclk;
- u32 val;
Is this really needed? I want to be as close as posible to linux driver...
- u32 val;
- u32 val;
* cleared */
Yup, inherited from linux driver, I will fix it.
- u32 val;
- if (val & 0x1)
val = val;
- else
val = val / 2 - 1;
- /* enable uart */
- if (input)
- else
- u32 val;
return -EAGAIN;
- u32 val;
return -EAGAIN;
return -EAGAIN;
- struct clk clk;
- fdt_addr_t addr;
- fdt_size_t size;
- int ret;
- /* get address */
return -EINVAL;
- if (ret < 0)
return ret;
- clk_free(&clk);
- do {
break;
- } while (1);
Daniel Schwierzeck
