[U-Boot] [PATCH] Please pull u-boot-mmc
Dear Tom,
Sorry for confusing..Could you pull these patches on u-boot/master? If there are other problems, let me know, plz.
Rebased on latest u-boot/master. (Wenyou's patches was applied on u-boot-atmel.) Sorry for late..
Best Regards, Jaehoon Chung
The following changes since commit 4cc9699be7ffc6072482240f5ba208488abe1090:
common: env_nand: Ensure that we have nand_info[0] prior to use (2016-08-15 18:46:41 -0400)
http://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 177381a9f9e956353deaa56d86bec47e02995ff3:
mmc: mmc_legacy: fix the compiler error with disabled CONFIG_DM_MMC_OPS (2016-08-16 10:27:24 +0900)
---------------------------------------------------------------- Jaehoon Chung (1): mmc: mmc_legacy: fix the compiler error with disabled CONFIG_DM_MMC_OPS
Sekhar Nori (4): drivers: mmc: omap_hsmmc: fix build breakage ARM: dts: K2G: Add support for MMC controller ARM: dts: k2g-evm: enable mmc/sd suppport defconfig: k2g_evm_defconfig: Enable mmc driver model
Yangbo Lu (1): mmc: send CMD0 before CMD1 for some MMC cards
arch/arm/dts/k2g-evm.dts | 8 ++++++++ arch/arm/dts/k2g.dtsi | 23 +++++++++++++++++++++++ configs/k2g_evm_defconfig | 1 + drivers/mmc/mmc.c | 3 +++ drivers/mmc/mmc_legacy.c | 9 +++++++-- drivers/mmc/omap_hsmmc.c | 2 ++ 6 files changed, 44 insertions(+), 2 deletions(-)
On Tue, Aug 16, 2016 at 10:39:12AM +0900, Jaehoon Chung wrote:
Dear Tom,
Jaehoon Chung
