Re: Strange construct in binman description
Hi Simon
On Jul 23, 2023 05:48, Simon Glass sjg@chromium.org wrote: Hi Marcel,
I just noticed this in an imx8 description:
binman_configuration: @config-SEQ {
I remember having stumbled over this before but I do not remember any exact details, sorry.
Since this is a generator node, binman blindly generates a phandle for each not it generates. This means that if there is more than one config node, then they will have duplicate phandles.
I have sent a series to correct this, but it fails the build on: imx8mm_venice imx8mn_venice imx8mp_venice
Ah, now I get it. You mixed up venice (Gate works) with verdin (Toradex).
I am a bit unsure about what this is supposed to do. Could you please take a look?
I'm more than happy to do that but you are probably much better off enquiring Tim Harvey from Gateworks about this. I put him on CC.
Cheers
Marcel
On Sun, 23 Jul 2023 at 03:00, Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Simon
Hi Marcel,
Tim, any thoughts on this please?
Hi Tim,
Hi Simon
Hi Marcel,
Can you please weigh in on this one?
On Wed, Jul 26, 2023, 5:55 PM Simon Glass sjg@chromium.org wrote:
Hi Tim,
Hi Simon
Hi Marcel,
(Toradex).
Simon,
I'm away from a computer until next week.
Can you point me to the series in reference here?
The -seq is for configs that support multiple dtbs which the Venice configs use.
Tim
Hi Tim,
Hi Tim,
Hi Simon
Hi Marcel,
Simon,
This is referring to code in mainline. it seems to have a phandle in a FIT template node, which means that Binman will generate multiple nodes with duplicate phandles.
On Sun, Jul 30, 2023 at 7:50 PM Simon Glass sjg@chromium.org wrote:
Hi Tim,
Hi Tim,
Hi Simon
Hi Marcel,
Simon,
Simon,
I don't know where the original discussion on this thread is from but what I found is that your commit d4d97661d255: ("binman: Support templates containing phandles") broke imx8mm_venice_defconfig, imx8mn_venice_defconfig, and imx8mp_venice_defconfig. I see that you merged commit 288ae53cb736: ("binman: Add a temporary hack for duplicate phandles") while I was away as a temporary workaround for these three boards instead of reverting the patch so I suppose we need to figure out how to address it then remove your workaround.
The imx8mm-u-boot.dtsi contains a configurations node in the FIT image to build configs for each dtb from CONFIG_OF_LIST.
configurations { default = "@config-DEFAULT-SEQ";
binman_configuration: @config-SEQ { description = "NAME"; fdt = "fdt-SEQ"; firmware = "uboot"; #ifndef CONFIG_ARMV8_PSCI loadables = "atf"; #endif }; };
These three boards are the only imx8m* boards that support multiple dtb's. If I look at the fit image (dtc -I dtb -O dts itb.fit.fit -f) I see the following for imx8mm_venice_defconfig:
configurations { default = "config-1";
config-1 { description = "imx8mm-venice"; fdt = "fdt-1"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-2 { description = "imx8mm-venice-gw71xx-0x"; fdt = "fdt-2"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-3 { description = "imx8mm-venice-gw72xx-0x"; fdt = "fdt-3"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-4 { description = "imx8mm-venice-gw73xx-0x"; fdt = "fdt-4"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-5 { description = "imx8mm-venice-gw7901"; fdt = "fdt-5"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-6 { description = "imx8mm-venice-gw7902"; fdt = "fdt-6"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; };
config-7 { description = "imx8mm-venice-gw7903"; fdt = "fdt-7"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; }; };
So yeah... it doesn't make sense that each config has the same phandle value but this tells me that U-Boot must not use these phandles as this has never presented a problem before. The venice board_fit_config_name_match() function gets called with each dtb to choose which dtb and that works fine. Does U-Boot even use the configurations node? Perhaps it uses the configurations node but doesn't use the phandles?
Best Regards,
Tim
Hi Tim,
Hi Tim,
Hi Tim,
Hi Simon
Hi Marcel,
Simon,
Simon,
configurations { default = "config-1"; config-1 { description = "imx8mm-venice"; fdt = "fdt-1"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-2 { description = "imx8mm-venice-gw71xx-0x"; fdt = "fdt-2"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-3 { description = "imx8mm-venice-gw72xx-0x"; fdt = "fdt-3"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-4 { description = "imx8mm-venice-gw73xx-0x"; fdt = "fdt-4"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-5 { description = "imx8mm-venice-gw7901"; fdt = "fdt-5"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-6 { description = "imx8mm-venice-gw7902"; fdt = "fdt-6"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; config-7 { description = "imx8mm-venice-gw7903"; fdt = "fdt-7"; firmware = "uboot"; loadables = "atf"; phandle = <0x7f>; }; };
U-Boot doesn't use them. I think it is best to remove the phandle from node. Could you please send a patch to do that and a revert of my work-around?
On Tue, Aug 8, 2023 at 10:54 AM Simon Glass sjg@chromium.org wrote:
Hi Tim,
Hi Tim,
Hi Tim,
On Sun, 23 Jul 2023 at 03:00, Marcel Ziswiler marcel.ziswiler@toradex.com wrote: > > Hi Simon > > On Jul 23, 2023 05:48, Simon Glass sjg@chromium.org wrote: > > Hi Marcel, > > I just noticed this in an imx8 description: > > binman_configuration: @config-SEQ { > > > I remember having stumbled over this before but I do not remember any exact details, sorry. > > Since this is a generator node, binman blindly generates a phandle for > each not it generates. This means that if there is more than one > config node, then they will have duplicate phandles. > > I have sent a series to correct this, but it fails the build on: > imx8mm_venice imx8mn_venice imx8mp_venice > > > Ah, now I get it. You mixed up venice (Gate works) with verdin (Toradex). > > I am a bit unsure about what this is supposed to do. Could you please > take a look? > > > I'm more than happy to do that but you are probably much better off enquiring Tim Harvey from Gateworks about this. I put him on CC.
Simon,
Simon,
Simon,
The phandle is not specified in the configurations node in imx8mm-u-boot.dtsi so it gets added automatically somewhere by binman. Where does it get automatically added and why is it only getting added for nodes under configurations?
Tim
Hi Tim,
Hi Tim,
Hi Tim,
Hi Tim,
On Mon, 24 Jul 2023 at 08:53, Simon Glass sjg@chromium.org wrote: > > Hi, > > On Sun, 23 Jul 2023 at 03:00, Marcel Ziswiler > marcel.ziswiler@toradex.com wrote: > > > > Hi Simon > > > > On Jul 23, 2023 05:48, Simon Glass sjg@chromium.org wrote: > > > > Hi Marcel, > > > > I just noticed this in an imx8 description: > > > > binman_configuration: @config-SEQ { > > > > > > I remember having stumbled over this before but I do not remember any exact details, sorry. > > > > Since this is a generator node, binman blindly generates a phandle for > > each not it generates. This means that if there is more than one > > config node, then they will have duplicate phandles. > > > > I have sent a series to correct this, but it fails the build on: > > imx8mm_venice imx8mn_venice imx8mp_venice > > > > > > Ah, now I get it. You mixed up venice (Gate works) with verdin (Toradex). > > > > I am a bit unsure about what this is supposed to do. Could you please > > take a look? > > > > > > I'm more than happy to do that but you are probably much better off enquiring Tim Harvey from Gateworks about this. I put him on CC. > > Tim, any thoughts on this please?
Simon,
Simon,
Simon,
Scotch mist?
arch/arm/dts/imx8mp-u-boot.dtsi:
@fdt-SEQ { description = "NAME"; type = "flat_dt"; compression = "none";
uboot_fdt_blob: blob-ext {
^^ phandle
filename = "u-boot.dtb"; }; };
If there is no mysterious need for this then I think it should be removed.
Marcel Ziswiler
Tim Harvey
