Re: [U-Boot] [RESEND PATCH v2 15/15] riscv: Move do_reset() to a common place
From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Tuesday, September 11, 2018 12:55 PM To: Rick Jian-Zhi Chen(陳建志); U-Boot Mailing List Cc: Lukas Auer Subject: [RESEND PATCH v2 15/15] riscv: Move do_reset() to a common place
We don't have a reset method on any RISC-V board yet. Instead of adding the same 'unsupported' message for each CPU variant it might make more sense to add a generic do_reset function for all CPU variants to lib/,
similar to the one for
ARM (arch/arm/lib/reset.c).
Suggested-by: Lukas Auer lukas.auer@aisec.fraunhofer.de Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2:
- new patch to move do_reset() to a common place
arch/riscv/cpu/ax25/cpu.c | 9 ---------
arch/riscv/cpu/qemu/cpu.c | 8 --------
arch/riscv/lib/Makefile | 1 + arch/riscv/lib/reset.c | 14 ++++++++++++++ 4 files changed, 15 insertions(+), 17 deletions(-) create mode 100644 arch/riscv/lib/reset.c
diff --git a/arch/riscv/cpu/ax25/cpu.c b/arch/riscv/cpu/ax25/cpu.c index ab05b57..fddcc15 100644 --- a/arch/riscv/cpu/ax25/cpu.c +++ b/arch/riscv/cpu/ax25/cpu.c @@ -6,9 +6,6 @@
/* CPU specific code */ #include <common.h> -#include <command.h> -#include <watchdog.h> -#include <asm/cache.h>
- cleanup_before_linux() is called just before we call linux @@ -24,9 +21,3
@@ int cleanup_before_linux(void)
-int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{
disable_interrupts();
panic("ax25-ae350 wdt not support yet.\n");
-} diff --git a/arch/riscv/cpu/qemu/cpu.c b/arch/riscv/cpu/qemu/cpu.c index a064639..6c7a327 100644 --- a/arch/riscv/cpu/qemu/cpu.c +++ b/arch/riscv/cpu/qemu/cpu.c @@ -4,7 +4,6 @@ */
-20,10 +19,3
printf("reset unsupported yet\n");
-} diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index cc562f9..b58db89 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -10,6 +10,7 @@ obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o obj-y += interrupts.o +obj-y += reset.o obj-y += setjmp.o
# For building EFI apps diff --git a/arch/riscv/lib/reset.c b/arch/riscv/lib/reset.c new
file mode 100644
index 0000000..5d9b99c --- /dev/null +++ b/arch/riscv/lib/reset.c @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2018, Bin Meng bmeng.cn@gmail.com */
+#include <common.h> +#include <command.h>
+int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{
Reviewed-by: Rick Chen rick@andestech.com
-- 2.7.4
Rick Chen
