[U-Boot] [PATCH v2] env: Add CONFIG_ENV_SUPPORT
Add a new flag CONFIG_ENV_SUPPORT to compile all the environment features in U-Boot (attributes, callbacks and flags); it is the supplement of the 2 existing flags for SPL/TPL. To have ENV support, enable the flag: - CONFIG_ENV_SUPPORT for U-Boot proper - CONFIG_SPL_ENV_SUPPORT for SPL - CONFIG_TPL_ENV_SUPPORT for TPL
This new configuration allows to use the macro CONFIG_IS_ENABLED(ENV_SUPPORT) in the code without issue and solves the regression introduced by commit 7d4776545b0f ("env: solve compilation error in SPL"); change_ok was always NULL in U-Boot.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
Changes in v2: - Update commit message after Lukasz Majewki review
cmd/Kconfig | 2 ++ env/Kconfig | 7 +++++++ env/Makefile | 11 ++++------- include/env_callback.h | 4 ++++ include/env_flags.h | 4 ++++ 5 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 05872fa0d7..f7a1b1faf5 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -465,6 +465,7 @@ config CMD_ENV_EXISTS
config CMD_ENV_CALLBACK bool "env callbacks - print callbacks and their associated variables" + depends on ENV_SUPPORT help Some environment variable have callbacks defined by U_BOOT_ENV_CALLBACK. These are called when the variable changes. @@ -473,6 +474,7 @@ config CMD_ENV_CALLBACK
config CMD_ENV_FLAGS bool "env flags -print variables that have non-default flags" + depends on ENV_SUPPORT help Some environment variables have special flags that control their behaviour. For example, serial# can only be written once and cannot diff --git a/env/Kconfig b/env/Kconfig index 74db2f38cc..f0c5a7a39c 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -1,5 +1,12 @@ menu "Environment"
+config ENV_SUPPORT + bool "Support all environment features" + default y + help + Enable full environment support in U-Boot, + including attributes, callbacks and flags. + config ENV_IS_NOWHERE bool "Environment is not stored" default y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ diff --git a/env/Makefile b/env/Makefile index 90144d6caf..2a468ac16b 100644 --- a/env/Makefile +++ b/env/Makefile @@ -5,10 +5,11 @@
obj-y += common.o env.o
+obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o +obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o +obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += callback.o + ifndef CONFIG_SPL_BUILD -obj-y += attr.o -obj-y += callback.o -obj-y += flags.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += eeprom.o extra-$(CONFIG_ENV_IS_EMBEDDED) += embedded.o obj-$(CONFIG_ENV_IS_IN_EEPROM) += embedded.o @@ -19,10 +20,6 @@ obj-$(CONFIG_ENV_IS_IN_ONENAND) += onenand.o obj-$(CONFIG_ENV_IS_IN_SATA) += sata.o obj-$(CONFIG_ENV_IS_IN_REMOTE) += remote.o obj-$(CONFIG_ENV_IS_IN_UBI) += ubi.o -else -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += attr.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += flags.o -obj-$(CONFIG_$(SPL_TPL_)ENV_SUPPORT) += callback.o endif
obj-$(CONFIG_$(SPL_TPL_)ENV_IS_NOWHERE) += nowhere.o diff --git a/include/env_callback.h b/include/env_callback.h index 982c07854d..a757fe6b5f 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -72,6 +72,10 @@ "serial#:serialno," \ CONFIG_ENV_CALLBACK_LIST_STATIC
+#if CONFIG_IS_ENABLED(ENV_SUPPORT) void env_callback_init(struct env_entry *var_entry); +#else +static inline void env_callback_init(struct env_entry *var_entry) { } +#endif
#endif /* __ENV_CALLBACK_H__ */ diff --git a/include/env_flags.h b/include/env_flags.h index e5380f2948..ec480e3ed7 100644 --- a/include/env_flags.h +++ b/include/env_flags.h @@ -153,7 +153,11 @@ int env_flags_validate_env_set_params(char *name, char *const val[], int count); * When adding a variable to the environment, initialize the flags for that * variable. */ +#if CONFIG_IS_ENABLED(ENV_SUPPORT) void env_flags_init(struct env_entry *var_entry); +#else +static inline void env_flags_init(struct env_entry *var_entry) { } +#endif
/* * Validate the newval for to conform with the requirements defined by its flags
Changes in v2:
Patrick Delaunay
