[U-Boot] [PATCH v1 0/4] Add SHA256 encrypted stop string for autobooting
The main task for this patch series is to add the new feature to abort autobooting via a SHA256 encrypted password. For this, some of the old autobooting related config macros have been moved to Kconfig. This was a bit more complicated, since Kconfig currently apparently doesn't support using escape characters '' as used in printf format strings like "foo %s bar\n". And this is needed for some of these new Kconfig options. So I needed to make some changes to the Kconfig sources as well. If nobody complains about these Kconfig stuff, I'll try to push this into the Linux Kconfig source as well.
There should be no functional change introduced. Please let me know if you find any problems.
Thanks, Stefan
Stefan Roese (4): Kconfig: Enable usage of escape char '' in string values autoboot.c: Remove CONFIG_AUTOBOOT_STOP_STR2 and CONFIG_AUTOBOOT_DELAY_STR2 autoboot.c: Move config options to Kconfig autoboot.c: Add feature to stop autobooting via SHA256 encrypted password
README | 2 - common/Kconfig | 78 ++++++++++++++++++++++++++ common/autoboot.c | 94 ++++++++++++++++++++++++++------ configs/CPCI4052_defconfig | 3 + configs/O2DNT2_RAMBOOT_defconfig | 3 + configs/O2DNT2_defconfig | 3 + configs/PLU405_defconfig | 3 + configs/PMC405DE_defconfig | 3 + configs/PMC440_defconfig | 3 + configs/UCP1020_SPIFLASH_defconfig | 3 + configs/UCP1020_defconfig | 3 + configs/a4m072_defconfig | 3 + configs/atngw100_defconfig | 4 ++ configs/atngw100mkii_defconfig | 4 ++ configs/atstk1002_defconfig | 4 ++ configs/atstk1003_defconfig | 4 ++ configs/atstk1004_defconfig | 4 ++ configs/atstk1006_defconfig | 4 ++ configs/calimain_defconfig | 2 + configs/cpuat91_defconfig | 4 ++ configs/cpuat91_ram_defconfig | 3 + configs/digsy_mtc_RAMBOOT_defconfig | 3 + configs/digsy_mtc_defconfig | 3 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 3 + configs/digsy_mtc_rev5_defconfig | 3 + configs/dlvision-10g_defconfig | 2 + configs/draco_defconfig | 3 + configs/dxr2_defconfig | 3 + configs/favr-32-ezkit_defconfig | 4 ++ configs/gdppc440etx_defconfig | 2 + configs/grasshopper_defconfig | 4 ++ configs/hammerhead_defconfig | 4 ++ configs/highbank_defconfig | 3 + configs/hrcon_defconfig | 2 + configs/ids8313_defconfig | 3 + configs/intip_defconfig | 2 + configs/io64_defconfig | 2 + configs/io_defconfig | 2 + configs/iocon_defconfig | 2 + configs/ip04_defconfig | 1 + configs/motionpro_defconfig | 3 + configs/nokia_rx51_defconfig | 1 + configs/omap3_mvblx_defconfig | 2 + configs/ph1_ld4_defconfig | 4 ++ configs/ph1_pro4_defconfig | 4 ++ configs/ph1_sld8_defconfig | 4 ++ configs/pm9263_defconfig | 1 + configs/pxm2_defconfig | 3 + configs/rut_defconfig | 3 + configs/spear600_defconfig | 3 + configs/stv0991_defconfig | 3 + configs/x600_defconfig | 3 + configs/zmx25_defconfig | 4 ++ doc/README.autoboot | 10 ---- include/configs/CPCI4052.h | 6 -- include/configs/PLU405.h | 9 --- include/configs/PMC405DE.h | 6 -- include/configs/PMC440.h | 6 -- include/configs/UCP1020.h | 11 ---- include/configs/a4m072.h | 4 -- include/configs/atngw100.h | 10 ---- include/configs/atngw100mkii.h | 10 ---- include/configs/atstk1002.h | 10 ---- include/configs/atstk1003.h | 10 ---- include/configs/atstk1004.h | 10 ---- include/configs/atstk1006.h | 10 ---- include/configs/bf537-stamp.h | 4 -- include/configs/calimain.h | 2 - include/configs/cpuat91.h | 6 -- include/configs/digsy_mtc.h | 4 -- include/configs/dlvision-10g.h | 2 - include/configs/favr-32-ezkit.h | 10 ---- include/configs/gdppc440etx.h | 2 - include/configs/grasshopper.h | 10 ---- include/configs/hammerhead.h | 10 ---- include/configs/highbank.h | 4 +- include/configs/hrcon.h | 2 - include/configs/ids8313.h | 4 -- include/configs/intip.h | 2 - include/configs/io.h | 2 - include/configs/io64.h | 2 - include/configs/iocon.h | 2 - include/configs/ip04.h | 1 - include/configs/motionpro.h | 6 -- include/configs/nokia_rx51.h | 1 - include/configs/o2dnt-common.h | 12 ---- include/configs/omap3_mvblx.h | 2 - include/configs/pm9263.h | 1 - include/configs/siemens-am33x-common.h | 6 -- include/configs/spear-common.h | 4 -- include/configs/stv0991.h | 4 -- include/configs/uniphier.h | 5 -- include/configs/x600.h | 4 -- include/configs/zmx25.h | 4 -- scripts/kconfig/confdata.c | 20 +++---- scripts/kconfig/symbol.c | 43 --------------- 96 files changed, 315 insertions(+), 301 deletions(-)
I might have missed something, but I failed to use the escape char '' in strings. To pass a printf format string like "foo %d bar\n" via Kconfig to the code.
Right now its not possible to use the escape character '' in Kconfig string values correctly to e.g. set this string value "test output\n". The '\n' will be converted to 'n'.
The current implementation removes some of the '' chars from the input string in conf_set_sym_val(). Examples:
And then doubles the backslash chars in the output string in sym_escape_string_value(). Example:
As you see in these examples, its impossible to generate a single '' charater in the output string as its needed for something like '\n'.
This patch now changes this behavior to not drop some backslashes in conf_set_sym_val() and to not add new backslashes in the resulting output string. Removing the function sym_escape_string_value() completely as its not needed anymore.
Signed-off-by: Stefan Roese sr@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org ---
scripts/kconfig/confdata.c | 20 +++++++++----------- scripts/kconfig/symbol.c | 43 ------------------------------------------- 2 files changed, 9 insertions(+), 54 deletions(-)
diff --git a/scripts/kconfig/confdata.c b/scripts/kconfig/confdata.c index f88d90f..4482192 100644 --- a/scripts/kconfig/confdata.c +++ b/scripts/kconfig/confdata.c @@ -155,18 +155,14 @@ static int conf_set_sym_val(struct symbol *sym, int def, int def_flags, char *p) case S_STRING: if (*p++ != '"') break; - for (p2 = p; (p2 = strpbrk(p2, ""\")); p2++) { - if (*p2 == '"') { - *p2 = 0; - break; - } - memmove(p2, p2 + 1, strlen(p2)); - } - if (!p2) { + /* Last char has to be a '"' */ + if (p[strlen(p) - 1] != '"') { if (def != S_DEF_AUTO) conf_warning("invalid string found"); return 1; } + /* Overwrite '"' with \0 for string termination */ + p[strlen(p) - 1] = 0; /* fall through */ case S_INT: case S_HEX: @@ -624,6 +620,7 @@ static void conf_write_symbol(FILE *fp, struct symbol *sym, struct conf_printer *printer, void *printer_arg) { const char *str; + char *str2;
switch (sym->type) { case S_OTHER: @@ -631,9 +628,10 @@ static void conf_write_symbol(FILE *fp, struct symbol *sym, break; case S_STRING: str = sym_get_string_value(sym); - str = sym_escape_string_value(str); - printer->print_symbol(fp, sym, str, printer_arg); - free((void *)str); + str2 = xmalloc(strlen(str) + 2); + sprintf(str2, ""%s"", str); + printer->print_symbol(fp, sym, str2, printer_arg); + free((void *)str2); break; default: str = sym_get_string_value(sym); diff --git a/scripts/kconfig/symbol.c b/scripts/kconfig/symbol.c index 7caabdb..ab339eb 100644 --- a/scripts/kconfig/symbol.c +++ b/scripts/kconfig/symbol.c @@ -912,49 +912,6 @@ const char *sym_expand_string_value(const char *in) return res; }
-const char *sym_escape_string_value(const char *in) -{ - const char *p; - size_t reslen; - char *res; - size_t l; - - reslen = strlen(in) + strlen("""") + 1; - - p = in; - for (;;) { - l = strcspn(p, ""\"); - p += l; - - if (p[0] == '\0') - break; - - reslen++; - p++; - } - - res = xmalloc(reslen); - res[0] = '\0'; - - strcat(res, """); - - p = in; - for (;;) { - l = strcspn(p, ""\"); - strncat(res, p, l); - p += l; - - if (p[0] == '\0') - break; - - strcat(res, "\"); - strncat(res, p++, 1); - } - - strcat(res, """); - return res; -} - struct sym_match { struct symbol *sym; off_t so, eo;
Hi Stefan,
2015-05-07 21:13 GMT+09:00 Stefan Roese sr@denx.de:
Interesting. I did not know this behavior of strings in Kconfig.
I want to see the reaction from linux-kconfig ML.
Hi Masahiro,
Then I'm not the only one. ;)
Okay. It makes sense then to send this patch to this list right away. A quick search didn't reveal any results though. Where is this list hosted?
Thanks, Stefan
Hi Stefan,
2015-05-07 21:46 GMT+09:00 Stefan Roese sr@denx.de:
Hi Masahiro,
Sorry, there is no decicated ML for Kconfig.
Kconfig patches should go to linux-kbuild ML (linux-kbuild@vger.kernel.org).
If you want to subscribe to the list, please visit http://vger.kernel.org/vger-lists.html#linux-kbuild
Yann E. MORIN is not active these days, so I think Michal Marek is the maintainer.
Hi Stefan,
This looks right to me. But I do see one problem - the default string for CONFIG_AUTOBOOT_PROMPT appears as:
"Autoboot in %d secondsn"
so something is still removing the \ in the Kconfig default;
[snip]
Hi Simon,
Right. Thanks for spotting. I'll fix this in v3.
Thanks, Stefan
Hi Simon, Hi Masahiro,
I could easily change the default string in the Kconfig file to "Autoboot in %d seconds\n". This works. But its a different syntax regarding using the escape character backslash compared to editing the .config file or editing the string in "make menuconfig etc...". So I hesitate to "fix" it this way.
Unfortunately fixing this issue in the code is not that easy. At least not for me. As the default values of the "string values" are set in the conf_parse() function (in scripts/kconfig/zconf.y). And I really have absolutely no experience with yacc / bison. Perhaps one of you guys has a quick fix to make this default value of strings compatible again so that this additional '' is not needed in the Kconfig file?
Thanks, Stefan
Hi Stefan,
Well I am familiar with those tools but I think Masahiro probably knows a lot more here.
Hi, Simon, Stefan,
2015-05-12 7:41 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Stefan,
I am not so familiar with Bison, and I am getting a bit busy these days. So, I cannot find time to take a close look. Sorry.
If Simon (or someone else) could follow it up, that'd be nice.
BTW, if you have already figured out that conf_parse() is the cause of the problem, you do not have to invoke Bison.
Bison does not touch the C part. conf_parse() is just copied verbatim from zconf.y to zconf.tab.c_shipped.
You can modify conf_parse() exactly in the same way in both of them.
Hi Masahiro,
On 13.05.2015 03:34, Masahiro Yamada wrote:
Hi, Simon, Stefan,
Hi Stefan,
Thanks. Did it and found that zconfparse() is responsible for this default value configuration / parsing. I must be missing something, but I fail to see where this function is really implemented:
$ git grep zconfparse scripts/kconfig/lkc.h:int zconfparse(void); scripts/kconfig/zconf.tab.c_shipped:#define yyparse zconfparse scripts/kconfig/zconf.tab.c_shipped: zconfparse(); scripts/kconfig/zconf.y: zconfparse();
I'm inclined to just add this additional backslash to the default value in Kconfig.
Thanks, Stefan
Hi Stefan,
2015-05-15 16:13 GMT+09:00 Stefan Roese sr@denx.de:
Hi Masahiro,
Hi, Simon, Stefan,
Hi Stefan,
On 7 May 2015 at 06:13, Stefan Roese sr@denx.de wrote: > > > I might have missed something, but I failed to use the escape char > '' > in strings. To pass a printf format string like "foo %d bar\n" via > Kconfig to the code. > > Right now its not possible to use the escape character '' in Kconfig > string values correctly to e.g. set this string value "test > output\n". > The '\n' will be converted to 'n'. > > The current implementation removes some of the '' chars from the > input > string in conf_set_sym_val(). Examples: > > '' -> '' > '\' -> '' > '\' -> '' > '\\' -> '\' > ... > > And then doubles the backslash chars in the output string in > sym_escape_string_value(). Example: > > '' -> '' -> '' > '\' -> '' -> '\' > '\' -> '' -> '\' > '\\' -> '\' -> '\\' > ... > > As you see in these examples, its impossible to generate a single '' > charater in the output string as its needed for something like '\n'. > > This patch now changes this behavior to not drop some backslashes in > conf_set_sym_val() and to not add new backslashes in the resulting > output string. Removing the function sym_escape_string_value() > completely as its not needed anymore. > > Signed-off-by: Stefan Roese sr@denx.de > Cc: Masahiro Yamada yamada.masahiro@socionext.com > Cc: Simon Glass sjg@chromium.org > --- > > scripts/kconfig/confdata.c | 20 +++++++++----------- > scripts/kconfig/symbol.c | 43 > ------------------------------------------- > 2 files changed, 9 insertions(+), 54 deletions(-)
Bison converts zconf.y into zconf.tab.c_shipped
You will notice the following part.
/* Substitute the variable and function names. */ #define yyparse zconfparse #define yylex zconflex
I think zconfparse was taken from the basename of zconf.y
And then, you will also notice the following part:
/*----------. | yyparse. | `----------*/
#ifdef YYPARSE_PARAM #if (defined __STDC__ || defined __C99__FUNC__ \ || defined __cplusplus || defined _MSC_VER) int yyparse (void *YYPARSE_PARAM) #else int yyparse (YYPARSE_PARAM) void *YYPARSE_PARAM; #endif #else /* ! YYPARSE_PARAM */ #if (defined __STDC__ || defined __C99__FUNC__ \ || defined __cplusplus || defined _MSC_VER) int yyparse (void) #else int yyparse ()
#endif #endif { int yystate; /* Number of tokens to shift before error messages enabled. */
"yyparse" is replaced with "zconfparse" by the prepreocessor, so this is the implementation of zconfparse(), and it is the parser generated by Bison.
I think it is almost impossible to read the generated parser directly. Instead, you should read zconf.y, but you need to understand Bison grammer for that...
These defines for a 2nd autoboot stop and delay string are nearly unused. Only sc3 defines CONFIG_AUTOBOOT_DELAY_STR2. And a patch to remove this most likely unmaintained board is also posted to the list.
By removing these defines the code will become cleaner and moving the remaining compile options to Kconfig will get easier.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Wolfgang Denk wd@denx.de Cc: Heiko Schocher hs@denx.de ---
README | 2 -- common/autoboot.c | 14 ++------------ doc/README.autoboot | 10 ---------- 3 files changed, 2 insertions(+), 24 deletions(-)
diff --git a/README b/README index 7958921..5956035 100644 --- a/README +++ b/README @@ -974,8 +974,6 @@ The following options need to be configured: CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR - CONFIG_AUTOBOOT_DELAY_STR2 - CONFIG_AUTOBOOT_STOP_STR2 CONFIG_ZERO_BOOTDELAY_CHECK CONFIG_RESET_TO_RETRY
diff --git a/common/autoboot.c b/common/autoboot.c index c27cc2c..7c92f3e 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -42,9 +42,7 @@ static int abortboot_keyed(int bootdelay) } delaykey[] = { { .str = getenv("bootdelaykey"), .retry = 1 }, - { .str = getenv("bootdelaykey2"), .retry = 1 }, { .str = getenv("bootstopkey"), .retry = 0 }, - { .str = getenv("bootstopkey2"), .retry = 0 }, };
char presskey[MAX_DELAY_STOP_STR]; @@ -65,17 +63,9 @@ static int abortboot_keyed(int bootdelay) if (delaykey[0].str == NULL) delaykey[0].str = CONFIG_AUTOBOOT_DELAY_STR; # endif -# ifdef CONFIG_AUTOBOOT_DELAY_STR2 - if (delaykey[1].str == NULL) - delaykey[1].str = CONFIG_AUTOBOOT_DELAY_STR2; -# endif # ifdef CONFIG_AUTOBOOT_STOP_STR - if (delaykey[2].str == NULL) - delaykey[2].str = CONFIG_AUTOBOOT_STOP_STR; -# endif -# ifdef CONFIG_AUTOBOOT_STOP_STR2 - if (delaykey[3].str == NULL) - delaykey[3].str = CONFIG_AUTOBOOT_STOP_STR2; + if (delaykey[1].str == NULL) + delaykey[1].str = CONFIG_AUTOBOOT_STOP_STR; # endif
for (i = 0; i < sizeof(delaykey) / sizeof(delaykey[0]); i++) { diff --git a/doc/README.autoboot b/doc/README.autoboot index 14e3660..227e3b5 100644 --- a/doc/README.autoboot +++ b/doc/README.autoboot @@ -78,13 +78,9 @@ What they do CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR - CONFIG_AUTOBOOT_DELAY_STR2 - CONFIG_AUTOBOOT_STOP_STR2
"bootdelaykey" environment variable "bootstopkey" environment variable - "bootdelaykey2" environment variable - "bootstopkey2" environment variable
These options give more control over stopping autoboot. When they are used a specific character or string is required to @@ -130,12 +126,6 @@ What they do character of a key string does not appear in the rest of the string.
- Using the CONFIG_AUTOBOOT_DELAY_STR2 #define or the - "bootdelaykey2" environment variable and/or the - CONFIG_AUTOBOOT_STOP_STR2 #define or the "bootstopkey" - environment variable you can specify a second, alternate - string (which allows you to have two "password" strings). - The CONFIG_AUTOBOOT_KEYED_CTRLC #define allows for the boot sequence to be interrupted by ctrl-c, in addition to the "bootdelaykey" and "bootstopkey". Setting this variable
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC
common/Kconfig | 64 ++++++++++++++++++++++++++++++++ common/autoboot.c | 6 ++- configs/CPCI4052_defconfig | 3 ++ configs/O2DNT2_RAMBOOT_defconfig | 3 ++ configs/O2DNT2_defconfig | 3 ++ configs/PLU405_defconfig | 3 ++ configs/PMC405DE_defconfig | 3 ++ configs/PMC440_defconfig | 3 ++ configs/UCP1020_SPIFLASH_defconfig | 3 ++ configs/UCP1020_defconfig | 3 ++ configs/a4m072_defconfig | 3 ++ configs/atngw100_defconfig | 4 ++ configs/atngw100mkii_defconfig | 4 ++ configs/atstk1002_defconfig | 4 ++ configs/atstk1003_defconfig | 4 ++ configs/atstk1004_defconfig | 4 ++ configs/atstk1006_defconfig | 4 ++ configs/calimain_defconfig | 2 + configs/cpuat91_defconfig | 4 ++ configs/cpuat91_ram_defconfig | 3 ++ configs/digsy_mtc_RAMBOOT_defconfig | 3 ++ configs/digsy_mtc_defconfig | 3 ++ configs/digsy_mtc_rev5_RAMBOOT_defconfig | 3 ++ configs/digsy_mtc_rev5_defconfig | 3 ++ configs/dlvision-10g_defconfig | 2 + configs/draco_defconfig | 3 ++ configs/dxr2_defconfig | 3 ++ configs/favr-32-ezkit_defconfig | 4 ++ configs/gdppc440etx_defconfig | 2 + configs/grasshopper_defconfig | 4 ++ configs/hammerhead_defconfig | 4 ++ configs/highbank_defconfig | 3 ++ configs/hrcon_defconfig | 2 + configs/ids8313_defconfig | 3 ++ configs/intip_defconfig | 2 + configs/io64_defconfig | 2 + configs/io_defconfig | 2 + configs/iocon_defconfig | 2 + configs/ip04_defconfig | 1 + configs/motionpro_defconfig | 3 ++ configs/nokia_rx51_defconfig | 1 + configs/omap3_mvblx_defconfig | 2 + configs/ph1_ld4_defconfig | 4 ++ configs/ph1_pro4_defconfig | 4 ++ configs/ph1_sld8_defconfig | 4 ++ configs/pm9263_defconfig | 1 + configs/pxm2_defconfig | 3 ++ configs/rut_defconfig | 3 ++ configs/spear600_defconfig | 3 ++ configs/stv0991_defconfig | 3 ++ configs/x600_defconfig | 3 ++ configs/zmx25_defconfig | 4 ++ include/configs/CPCI4052.h | 6 --- include/configs/PLU405.h | 9 ----- include/configs/PMC405DE.h | 6 --- include/configs/PMC440.h | 6 --- include/configs/UCP1020.h | 11 ------ include/configs/a4m072.h | 4 -- include/configs/atngw100.h | 10 ----- include/configs/atngw100mkii.h | 10 ----- include/configs/atstk1002.h | 10 ----- include/configs/atstk1003.h | 10 ----- include/configs/atstk1004.h | 10 ----- include/configs/atstk1006.h | 10 ----- include/configs/bf537-stamp.h | 4 -- include/configs/calimain.h | 2 - include/configs/cpuat91.h | 6 --- include/configs/digsy_mtc.h | 4 -- include/configs/dlvision-10g.h | 2 - include/configs/favr-32-ezkit.h | 10 ----- include/configs/gdppc440etx.h | 2 - include/configs/grasshopper.h | 10 ----- include/configs/hammerhead.h | 10 ----- include/configs/highbank.h | 4 +- include/configs/hrcon.h | 2 - include/configs/ids8313.h | 4 -- include/configs/intip.h | 2 - include/configs/io.h | 2 - include/configs/io64.h | 2 - include/configs/iocon.h | 2 - include/configs/ip04.h | 1 - include/configs/motionpro.h | 6 --- include/configs/nokia_rx51.h | 1 - include/configs/o2dnt-common.h | 12 ------ include/configs/omap3_mvblx.h | 2 - include/configs/pm9263.h | 1 - include/configs/siemens-am33x-common.h | 6 --- include/configs/spear-common.h | 4 -- include/configs/stv0991.h | 4 -- include/configs/uniphier.h | 5 --- include/configs/x600.h | 4 -- include/configs/zmx25.h | 4 -- 92 files changed, 219 insertions(+), 220 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 15759f7..ff150f0 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -17,6 +17,70 @@ config SYS_HUSH_PARSER help Backward compatibility.
+menu "Autoboot options" + +config AUTOBOOT_KEYED + bool "Stop autobooting via specific input key / string" + default n + help + This option enables stopping (aborting) of the automatic + boot feature only by issuing a specific input key or + string. If not enabled, any input key will abort the + U-Boot automatic booting process and bring the device + to the U-Boot prompt for user input. + +config AUTOBOOT_PROMPT + string "Autoboot stop prompt" + depends on AUTOBOOT_KEYED + default "Autoboot in %d seconds\n" + help + This string is displayed before the boot delay selected by + CONFIG_BOOTDELAY starts. If it is not defined there is no + output indicating that autoboot is in progress. + + Note that this define is used as the (only) argument to a + printf() call, so it may contain '%' format specifications, + provided that it also includes, sepearated by commas exactly + like in a printf statement, the required arguments. It is + the responsibility of the user to select only such arguments + that are valid in the given context. + +config AUTOBOOT_DELAY_STR + string "Delay autobooting via specific input key / string" + depends on AUTOBOOT_KEYED + help + This option delays the automatic boot feature by issuing + a specific input key or string. If CONFIG_AUTOBOOT_DELAY_STR + or the environment variable "bootdelaykey" is specified + and this string is received from console input before + autoboot starts booting, U-Boot gives a command prompt. The + U-Boot prompt will time out if CONFIG_BOOT_RETRY_TIME is + used, otherwise it never times out. + +config AUTOBOOT_STOP_STR + string "Stop autobooting via specific input key / string" + depends on AUTOBOOT_KEYED + help + This option enables stopping (aborting) of the automatic + boot feature only by issuing a specific input key or + string. If CONFIG_AUTOBOOT_STOP_STR or the environment + variable "bootstopkey" is specified and this string is + received from console input before autoboot starts booting, + U-Boot gives a command prompt. The U-Boot prompt never + times out, even if CONFIG_BOOT_RETRY_TIME is used. + +config AUTOBOOT_KEYED_CTRLC + bool "Enable Ctrl-C autoboot interruption" + depends on AUTOBOOT_KEYED + default n + help + This option allows for the boot sequence to be interrupted + by ctrl-c, in addition to the "bootdelaykey" and "bootstopkey". + Setting this variable provides an escape sequence from the + limited "password" strings. + +endmenu + comment "Commands"
menu "Info commands" diff --git a/common/autoboot.c b/common/autoboot.c index 7c92f3e..f72eb18 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -56,7 +56,11 @@ static int abortboot_keyed(int bootdelay) #endif
# ifdef CONFIG_AUTOBOOT_PROMPT - printf(CONFIG_AUTOBOOT_PROMPT); + /* + * CONFIG_AUTOBOOT_PROMPT includes the %d for all boards. + * To print the bootdelay value upon bootup. + */ + printf(CONFIG_AUTOBOOT_PROMPT, bootdelay); # endif
# ifdef CONFIG_AUTOBOOT_DELAY_STR diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index 5d30b79..8c7369d 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_CPCI4052=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index 49e60ab..87d4b74 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="++++++++++" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 9df3b88..f729895 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="++++++++++" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index 15477c4..337962f 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_PLU405=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index 78c5d39..e26a90f 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_PMC405DE=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index 27869ac..7dd69bd 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_PMC440=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index 2ffb8da..7d045e6 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -4,3 +4,6 @@ CONFIG_TARGET_UCP1020=y CONFIG_TARGET_UCP1020_SPIFLASH=y CONFIG_SPI_FLASH=y CONFIG_UCP1020=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" +CONFIG_AUTOBOOT_STOP_STR="\x1b" diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 61de360..421a2e4 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -3,3 +3,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_UCP1020=y CONFIG_SPI_FLASH=y CONFIG_UCP1020=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" +CONFIG_AUTOBOOT_STOP_STR="\x1b" diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index ddc8d3f..e01eb44 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_A4M072=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="asdfg" +CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index cd79990..c28186e 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATNGW100=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index 88b1de2..05a8f39 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATNGW100MKII=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index d6e9a77..5db0ba6 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATSTK1002=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atstk1003_defconfig b/configs/atstk1003_defconfig index b704532..3f97f07 100644 --- a/configs/atstk1003_defconfig +++ b/configs/atstk1003_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATSTK1003=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atstk1004_defconfig b/configs/atstk1004_defconfig index 7650254..2016b8c 100644 --- a/configs/atstk1004_defconfig +++ b/configs/atstk1004_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATSTK1004=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/atstk1006_defconfig b/configs/atstk1006_defconfig index 54beb0b..0bfa84c 100644 --- a/configs/atstk1006_defconfig +++ b/configs/atstk1006_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_ATSTK1006=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 02d3912..553820f 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -1,3 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_CALIMAIN=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x0b" diff --git a/configs/cpuat91_defconfig b/configs/cpuat91_defconfig index 5a1ef3a..5c25efa 100644 --- a/configs/cpuat91_defconfig +++ b/configs/cpuat91_defconfig @@ -1,3 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_CPUAT91=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/cpuat91_ram_defconfig b/configs/cpuat91_ram_defconfig index 2759192..b0b94d4 100644 --- a/configs/cpuat91_ram_defconfig +++ b/configs/cpuat91_ram_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_CPUAT91=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index a1e765b..19ba197 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot\n" diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index 666c5c8..cefaa45 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR=" " +CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index d356174..818efda 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000,DIGSY_REV5" CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot\n" diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index f66f86f..cdf021a 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -2,3 +2,6 @@ CONFIG_SYS_EXTRA_OPTIONS="DIGSY_REV5" CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot\n" diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index 1d2a571..2f11eed 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_DLVISION_10G=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/draco_defconfig b/configs/draco_defconfig index fba7bf1..a09dcf5 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -1,3 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y CONFIG_TARGET_DRACO=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/dxr2_defconfig b/configs/dxr2_defconfig index e0f577f..c5095e9 100644 --- a/configs/dxr2_defconfig +++ b/configs/dxr2_defconfig @@ -1,3 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y CONFIG_TARGET_DXR2=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/favr-32-ezkit_defconfig b/configs/favr-32-ezkit_defconfig index 941e028..415a11e 100644 --- a/configs/favr-32-ezkit_defconfig +++ b/configs/favr-32-ezkit_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_FAVR_32_EZKIT=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 1097b9c..2dfebbb 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_GDPPC440ETX=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 72013e7..287bbd8 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_GRASSHOPPER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/hammerhead_defconfig b/configs/hammerhead_defconfig index 0d69cc6..deed8e2 100644 --- a/configs/hammerhead_defconfig +++ b/configs/hammerhead_defconfig @@ -1,2 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_HAMMERHEAD=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds" diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 88efbdf..d56ae77 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -1,2 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_HIGHBANK=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_KEYED_CTRLC=y +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds...\nPress <s> to stop or <d> to delay\n" diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 69c65ba..b73c41f 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_MPC83xx=y CONFIG_TARGET_HRCON=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 8479cd4..939361e 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -4,3 +4,6 @@ CONFIG_MPC83xx=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_TARGET_IDS8313=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_DELAY_STR="ids" +CONFIG_AUTOBOOT_PROMPT="Enter password - autoboot in %d seconds...\n" diff --git a/configs/intip_defconfig b/configs/intip_defconfig index d6af774..a9cfe84 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -2,3 +2,5 @@ CONFIG_SYS_EXTRA_OPTIONS="INTIB" CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_INTIP=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 1111e54..52829da 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_IO64=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/io_defconfig b/configs/io_defconfig index 959af75..bf76ad3 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_IO=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index 6dc8887..bfe718e 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -1,3 +1,5 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_IOCON=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index ba737ae..d82e2d6 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -1,3 +1,4 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IP04=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y +CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index 535cb84..e1bacb4 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -1,3 +1,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_MOTIONPRO=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index e03f586..3aff2e6 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y +CONFIG_AUTOBOOT_KEYED=y diff --git a/configs/omap3_mvblx_defconfig b/configs/omap3_mvblx_defconfig index fb6edc2..33d63de 100644 --- a/configs/omap3_mvblx_defconfig +++ b/configs/omap3_mvblx_defconfig @@ -1,3 +1,5 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_MVBLX=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="S" diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig index 036e2d1..328e1dc 100644 --- a/configs/ph1_ld4_defconfig +++ b/configs/ph1_ld4_defconfig @@ -38,3 +38,7 @@ CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig index 9a010ee..cc77a0a 100644 --- a/configs/ph1_pro4_defconfig +++ b/configs/ph1_pro4_defconfig @@ -38,3 +38,7 @@ CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig index 29fe0e8..1294c93 100644 --- a/configs/ph1_sld8_defconfig +++ b/configs/ph1_sld8_defconfig @@ -38,3 +38,7 @@ CONFIG_UNIPHIER_SERIAL=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" +CONFIG_AUTOBOOT_DELAY_STR="d" +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 6e88046..db19bc3 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -2,3 +2,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9263=y +CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index f9e594f..70c0623 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -1,3 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y CONFIG_TARGET_PXM2=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/rut_defconfig b/configs/rut_defconfig index b7161ba..0fc8150 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -1,3 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y CONFIG_TARGET_RUT=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index dae0d59..7a9ba59 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -4,3 +4,6 @@ CONFIG_TARGET_SPEAR600=y CONFIG_ETH_DESIGNWARE=y CONFIG_NETDEVICES=y CONFIG_NET=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index 76ba41b..89308c6 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -5,3 +5,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ETH_DESIGNWARE=y CONFIG_NETDEVICES=y CONFIG_NET=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 7cd239b..d27fa51 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -4,3 +4,6 @@ CONFIG_TARGET_X600=y CONFIG_ETH_DESIGNWARE=y CONFIG_NETDEVICES=y CONFIG_NET=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 80a66d0..b0f882d 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -1,2 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_ZMX25=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="boot in %d s\n" +CONFIG_AUTOBOOT_DELAY_STR="delaygs" +CONFIG_AUTOBOOT_STOP_STR="stopgs" diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index ceddd7a..c20ecbd 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -141,12 +141,6 @@
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - #define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */
/*----------------------------------------------------------------------- diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index a236e11..80f4276 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -138,15 +138,6 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_BOOTDELAY 3 /* autoboot after 3 seconds */
-/* Only interrupt boot if space is pressed */ -/* If a long serial cable is connected but */ -/* other end is dead, garbage will be read */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
#define CONFIG_SYS_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */ diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index f7d28e3..a64c82a 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -110,12 +110,6 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - /* * PCI stuff */ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index c29429d..c09f656 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -332,12 +332,6 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
-#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#undef CONFIG_AUTOBOOT_DELAY_STR -#define CONFIG_AUTOBOOT_STOP_STR " " - /*----------------------------------------------------------------------- * PCI stuff *----------------------------------------------------------------------*/ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 57e0c6c..6593093 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -628,17 +628,6 @@ /* default location for tftp and bootm */ #define CONFIG_LOADADDR 1000000
-/* - * Autobooting - */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR "\x1b" -#define DEBUG_BOOTKEYS 0 -#undef CONFIG_AUTOBOOT_DELAY_STR -#undef CONFIG_BOOTARGS -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press "<Esc>" to stop\n", bootdelay - #define CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index 3c67655..deedfb9 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -123,10 +123,6 @@
#define CONFIG_SYS_AUTOLOAD "n"
-#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR "asdfg" - #undef CONFIG_BOOTARGS #define CONFIG_PREBOOT "run try_update"
diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 540e86a..1202ec2 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -59,17 +59,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload; bootm"
-/* - * Only interrupt autoboot if <space> is pressed. Otherwise, garbage - * data on the serial line may interrupt the boot sequence. - */ #define CONFIG_BOOTDELAY 1 -#define CONFIG_AUTOBOOT -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR "d" -#define CONFIG_AUTOBOOT_STOP_STR " "
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index eaed7ea..fcaabb4 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -82,17 +82,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload 0x10400000 /uImage; bootm"
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index a9c064a..64b5519 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -79,17 +79,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload; bootm $(fileaddr)"
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/atstk1003.h b/include/configs/atstk1003.h index 63704b1..786713f 100644 --- a/include/configs/atstk1003.h +++ b/include/configs/atstk1003.h @@ -79,17 +79,7 @@ #define CONFIG_BOOTCOMMAND \ "mmc rescan; ext2load mmc 0:1 0x10400000 /boot/uImage; bootm"
/* * Command line configuration. diff --git a/include/configs/atstk1004.h b/include/configs/atstk1004.h index 331a60d..0b2a9ff 100644 --- a/include/configs/atstk1004.h +++ b/include/configs/atstk1004.h @@ -79,17 +79,7 @@ #define CONFIG_BOOTCOMMAND \ "mmc rescan; ext2load mmc 0:1 0x10200000 /boot/uImage; bootm"
/* * Command line configuration. diff --git a/include/configs/atstk1006.h b/include/configs/atstk1006.h index 25090a6..cbf17db 100644 --- a/include/configs/atstk1006.h +++ b/include/configs/atstk1006.h @@ -80,17 +80,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload; bootm $(fileaddr)"
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 7b5a5a7..b3e13c1 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -272,10 +272,6 @@ /* These are for board tests */ #if 0 #define CONFIG_BOOTCOMMAND "bootldr 0x203f0100" -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "autoboot in %d seconds: press space to stop\n", bootdelay -#define CONFIG_AUTOBOOT_STOP_STR " " #endif
diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 44c947f..0eeaf8b 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -221,8 +221,6 @@ #define CONFIG_BOOTDELAY 0 #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_BOOT_RETRY_TIME 60 /* continue boot after 60 s inactivity */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_DELAY_STR "\x0d" /* press ENTER to interrupt BOOT */ #define CONFIG_RESET_TO_RETRY
/* diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 8c7d97a..77d3ab8 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -195,12 +195,6 @@ #define CONFIG_DEVICE_NULLDEV #define CONFIG_SILENT_CONSOLE
-#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot\n" -#define CONFIG_AUTOBOOT_STOP_STR " " -#define CONFIG_AUTOBOOT_DELAY_STR "d" - #define CONFIG_VERSION_VARIABLE
#define MTDIDS_DEFAULT "nor0=physmap-flash.0" diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 76ec168..06da3c3 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -396,10 +396,6 @@ #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_SYS_HUSH_PARSER
-#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR " " - #define CONFIG_LOOPW 1 #define CONFIG_MX_CYCLIC 1 #define CONFIG_ZERO_BOOTDELAY_CHECK diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index d9bd564..0f67595 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -29,8 +29,6 @@ #define CONFIG_SYS_CLK_FREQ 33333333 /* external frequency to pll */
#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ -#define CONFIG_AUTOBOOT_KEYED /* use key strings to stop autoboot */ -#define CONFIG_AUTOBOOT_STOP_STR " "
/* * Configure PLL diff --git a/include/configs/favr-32-ezkit.h b/include/configs/favr-32-ezkit.h index 75bff4c..04f4124 100644 --- a/include/configs/favr-32-ezkit.h +++ b/include/configs/favr-32-ezkit.h @@ -80,17 +80,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload; bootm $(fileaddr)"
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/gdppc440etx.h b/include/configs/gdppc440etx.h index 12fd75d..bfaba42 100644 --- a/include/configs/gdppc440etx.h +++ b/include/configs/gdppc440etx.h @@ -35,8 +35,6 @@ #define CONFIG_SYS_GENERIC_BOARD
/* * Base addresses -- Note these are effective addresses where the diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 54eb977..99d2389 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -75,17 +75,7 @@
-/* - * Only interrupt autoboot if <space> is pressed. Otherwise, garbage - * data on the serial line may interrupt the boot sequence. - */ #define CONFIG_BOOTDELAY 1 -#define CONFIG_AUTOBOOT -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Press SPACE to abort autoboot in %d" \ - " seconds\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR "d" -#define CONFIG_AUTOBOOT_STOP_STR " "
/* * After booting the board for the first time, new ethernet addresses diff --git a/include/configs/hammerhead.h b/include/configs/hammerhead.h index 0bc42f1..274f2a8 100644 --- a/include/configs/hammerhead.h +++ b/include/configs/hammerhead.h @@ -60,17 +60,7 @@ #define CONFIG_BOOTCOMMAND \ "fsload; bootm"
/* * After booting the board for the first time, new ethernet address diff --git a/include/configs/highbank.h b/include/configs/highbank.h index da1c837..08dcdf8 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -63,9 +63,7 @@
#define CONFIG_BOOT_RETRY_TIME -1 #define CONFIG_RESET_TO_RETRY -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds...\nPress <s> to stop or <d> to delay\n", bootdelay -#define CONFIG_AUTOBOOT_KEYED_CTRLC + /* * Miscellaneous configurable options */ diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index e7df9ad..608e7d0 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -491,8 +491,6 @@ int fpga_gpio_get(unsigned int bus, int pin); #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index c1ca56c..7730f63 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -25,10 +25,6 @@
#define CONFIG_MISC_INIT_R
-#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "\nEnter password - autoboot in %d seconds...\n", CONFIG_BOOTDELAY -#define CONFIG_AUTOBOOT_DELAY_STR "ids" #define CONFIG_BOOT_RETRY_TIME 900 #define CONFIG_BOOT_RETRY_MIN 30 #define CONFIG_BOOTDELAY 1 diff --git a/include/configs/intip.h b/include/configs/intip.h index 928eb5b..18d3140 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -51,8 +51,6 @@ #define CFG_ALT_MEMTEST
/* * Base addresses -- Note these are effective addresses where the diff --git a/include/configs/io.h b/include/configs/io.h index d4ae0ad..8101933 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -35,8 +35,6 @@ #define PLLMR1_DEFAULT PLLMR1_266_133_66
/* new uImage format support */ #define CONFIG_FIT diff --git a/include/configs/io64.h b/include/configs/io64.h index 2a9ff37..94ccb6b 100644 --- a/include/configs/io64.h +++ b/include/configs/io64.h @@ -46,8 +46,6 @@ #define CONFIG_SYS_GENERIC_BOARD
/* new uImage format support */ #define CONFIG_FIT diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 38d473d..9d9dabf 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -34,8 +34,6 @@ #define PLLMR1_DEFAULT PLLMR1_266_133_66
/* new uImage format support */ #define CONFIG_FIT diff --git a/include/configs/ip04.h b/include/configs/ip04.h index 2ee215f..8081a05 100644 --- a/include/configs/ip04.h +++ b/include/configs/ip04.h @@ -138,7 +138,6 @@ /* Enable this if bootretry required; currently it's disabled */ #define CONFIG_BOOT_RETRY_TIME -1 #define CONFIG_BOOTCOMMAND "run nandboot" -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n"
/* diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index e8b0593..8d29d95 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -73,13 +73,7 @@ * Autobooting */ #define CONFIG_BOOTDELAY 2 /* autoboot after 2 seconds */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR "\x1b\x1b" -#define DEBUG_BOOTKEYS 0 -#undef CONFIG_AUTOBOOT_DELAY_STR #undef CONFIG_BOOTARGS -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press "<Esc><Esc>" to stop\n", bootdelay
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 152a6e5..58b6f6f 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -397,7 +397,6 @@ int rx51_kp_getc(struct stdio_dev *sdev); "echo"
#define CONFIG_BOOTDELAY 30 -#define CONFIG_AUTOBOOT_KEYED #define CONFIG_MENU #define CONFIG_MENU_SHOW
diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 18388d1..3248429 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -98,18 +98,6 @@ #error "CONFIG_SYS_TEXT_BASE value is invalid" #endif
-/* - * Autobooting - * Be selective on what keys can delay or stop the autoboot process - * To stop use: "++++++++++" - */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press password to stop\n", bootdelay -#define CONFIG_AUTOBOOT_STOP_STR "++++++++++" -#undef CONFIG_AUTOBOOT_DELAY_STR -#define DEBUG_BOOTKEYS 0 - #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */
#define CONFIG_PREBOOT "run master" diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index b61297f..41908a9 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -145,8 +145,6 @@ #undef CONFIG_ENV_OVERWRITE /* disallow overwriting serial# and ethaddr */ #define CONFIG_BOOTDELAY 0 #define CONFIG_ZERO_BOOTDELAY_CHECK -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR "S"
#define CONFIG_EXTRA_ENV_SETTINGS \ "silent=true\0" \ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index f6aebf4..9bdbf53 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -339,7 +339,6 @@
#define CONFIG_BOOTCOMMAND "run flashboot" #define CONFIG_ROOTPATH "/ronetix/rootfs" -#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay
#define CONFIG_CON_ROT "fbcon=rotate:3 " #define CONFIG_BOOTARGS "root=/dev/mtdblock4 rootfstype=jffs2 "\ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index c7affd6..50efdc8 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -478,12 +478,6 @@ /* Watchdog */ #define CONFIG_HW_WATCHDOG
-/* Stop autoboot with ESC ESC key detected */ -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR "\x1b\x1b" -#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ - "press "<Esc><Esc>" to stop\n", bootdelay - /* Reboot after 60 sec if bootcmd fails */ #define CONFIG_RESET_TO_RETRY #define CONFIG_BOOT_RETRY_TIME 60 diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 409cf54..ac308d5 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -202,10 +202,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_MISC_INIT_R #define CONFIG_ZERO_BOOTDELAY_CHECK -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR " " -#define CONFIG_AUTOBOOT_PROMPT \ - "Hit SPACE in %d seconds to stop autoboot.\n", bootdelay
#define CONFIG_SYS_MEMTEST_START 0x00800000 #define CONFIG_SYS_MEMTEST_END 0x04000000 diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index ab1e61c..89fce9b 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -75,9 +75,5 @@
#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTCOMMAND "go 0x40040000" -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR " " -#define CONFIG_AUTOBOOT_PROMPT \ - "Hit SPACE in %d seconds to stop autoboot.\n", bootdelay
#endif /* __CONFIG_H */ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index d4688c5..75eba7d 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -200,11 +200,6 @@
#define CONFIG_BOOTDELAY 3 #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ -#define CONFIG_AUTOBOOT_KEYED 1 -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR "d" -#define CONFIG_AUTOBOOT_STOP_STR " "
/* * Network Configuration diff --git a/include/configs/x600.h b/include/configs/x600.h index 27a66a5..2b608bf 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -153,10 +153,6 @@ #define CONFIG_LOOPW /* enable loopw command */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_STOP_STR " " -#define CONFIG_AUTOBOOT_PROMPT \ - "Hit SPACE in %d seconds to stop autoboot.\n", bootdelay
#define CONFIG_SYS_MEMTEST_START 0x00800000 #define CONFIG_SYS_MEMTEST_END 0x04000000 diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 342fa2c..23e1026 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -151,10 +151,6 @@ #define CONFIG_PREBOOT ""
#define CONFIG_BOOTDELAY 5 -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "boot in %d s\n", bootdelay -#define CONFIG_AUTOBOOT_DELAY_STR "delaygs" -#define CONFIG_AUTOBOOT_STOP_STR "stopgs"
/* * Size of malloc() pool
Hi Stefan,
default n
help
Doesn't this mean that the autoboot message will always be printed? I wonder if we need a separate 'AUTOBOOT' to enable the feature?
[snip]
Hi Stefan,
2015-05-08 8:51 GMT+09:00 Simon Glass sjg@chromium.org:
Hi Stefan,
Thanks for working on a task requiring much effort.
I am just wondering if we need not move the prompt messages verbatim to Kconfig.
I know CONFIG_AUTOBOOT_PROMPT provides us the best flexibility, but the messages are most likely "autoboot in %d seconds" or "Press ...".
Can we put the message directly into common/autoboot.c like this?
#ifdef CONFIG_SHOW_AUTOBOOT_PROMPT printf("Autoboot in %d seconds\n", CONFIG_BOOTDELAY); printf("Press %c to abort in %d seconds\n", CONFIG_AUTOBOOT_STOP_STR); #endif
I think I am missing some things here: - Those boards that require a password do not want to show it - We need to convert " " to user-visible "<SPACE>" if CONFIG_AUTOBOOT_STOP_STP == " "
Any ideas?
Hi Masahiro,
Hi Stefan,
Yes. I really admire you for all your hard work on this. Now that I've done a tiny bit here as well. ;)
Any ideas?
Unfortunately not all boards print such a message. There is quite a range of alternatives, I'm afraid. Some boards use CONFIG_AUTOBOOT_STOP_STR, some CONFIG_AUTOBOOT_DELAY_STR. Some print this string / char, some don't. So we can't really convert them all into such a generic implementation. Without breaking backward (user) compatibility. At least I don't see such a way.
Thanks, Stefan
Hi Simon,
<snip>
default n
help
AUTOBOOT_PROMPT is enabled now via AUTOBOOT_KEYED. Most boards don't enable this option, so nothing is changed for those boards.
Thanks, Stefan
On 7 May 2015 at 23:55, Stefan Roese sr@denx.de wrote:
Hi Simon,
<snip>
default n
help
Thanks.
This patch adds the feature to only stop the autobooting, and therefor boot into the U-Boot prompt, when the input string / password matches a values that is encypted via a SHA256 hash and saved in the environment.
This feature is enabled by defined these config options: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_STOP_STR_SHA256
common/Kconfig | 20 ++++++++-- common/autoboot.c | 112 +++++++++++++++++++++++++++++++++++++++++++----------- 2 files changed, 107 insertions(+), 25 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index ff150f0..5d06558 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -45,9 +45,14 @@ config AUTOBOOT_PROMPT the responsibility of the user to select only such arguments that are valid in the given context.
+config AUTOBOOT_ENCRYPTION + bool "Enable encryption in autoboot stopping" + depends on AUTOBOOT_KEYED + default n + config AUTOBOOT_DELAY_STR string "Delay autobooting via specific input key / string" - depends on AUTOBOOT_KEYED + depends on AUTOBOOT_KEYED && !AUTOBOOT_ENCRYPTION help This option delays the automatic boot feature by issuing a specific input key or string. If CONFIG_AUTOBOOT_DELAY_STR @@ -59,7 +64,7 @@ config AUTOBOOT_DELAY_STR
config AUTOBOOT_STOP_STR string "Stop autobooting via specific input key / string" - depends on AUTOBOOT_KEYED + depends on AUTOBOOT_KEYED && !AUTOBOOT_ENCRYPTION help This option enables stopping (aborting) of the automatic boot feature only by issuing a specific input key or @@ -71,7 +76,7 @@ config AUTOBOOT_STOP_STR
config AUTOBOOT_KEYED_CTRLC bool "Enable Ctrl-C autoboot interruption" - depends on AUTOBOOT_KEYED + depends on AUTOBOOT_KEYED && !AUTOBOOT_ENCRYPTION default n help This option allows for the boot sequence to be interrupted @@ -79,6 +84,15 @@ config AUTOBOOT_KEYED_CTRLC Setting this variable provides an escape sequence from the limited "password" strings.
+config AUTOBOOT_STOP_STR_SHA256 + bool "Stop autobooting via SHA256 encrypted password" + depends on AUTOBOOT_KEYED && AUTOBOOT_ENCRYPTION + help + This option adds the feature to only stop the autobooting, + and therefore boot into the U-Boot prompt, when the input + string / password matches a values that is encypted via + a SHA256 hash and saved in the environment. + endmenu
comment "Commands" diff --git a/common/autoboot.c b/common/autoboot.c index f72eb18..0fca6af 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <menu.h> #include <post.h> +#include <u-boot/sha256.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -26,15 +27,58 @@ DECLARE_GLOBAL_DATA_PTR; /* Stored value of bootdelay, used by autoboot_command() */ static int stored_bootdelay;
-/*************************************************************************** - * Watch for 'delay' seconds for autoboot stop or autoboot delay string. - * returns: 0 - no key string, allow autoboot 1 - got key string, abort - */ -# if defined(CONFIG_AUTOBOOT_KEYED) -static int abortboot_keyed(int bootdelay) +#if defined(CONFIG_AUTOBOOT_KEYED) +#if defined(CONFIG_AUTOBOOT_STOP_STR_SHA256) +static int passwd_abort(uint64_t etime) +{ + const char *sha_env_str = getenv("bootstopkeysha256"); + u8 sha_env[SHA256_SUM_LEN]; + u8 sha[SHA256_SUM_LEN]; + char presskey[MAX_DELAY_STOP_STR]; + u_int presskey_len = 0; + int i; + int abort = 0; + + if (sha_env_str == NULL) + sha_env_str = CONFIG_AUTOBOOT_STOP_STR_SHA256; + + /* + * Generate the binary value from the environment hash value + * so that we can compare this value with the computed hash + * from the user input + */ + for (i = 0; i < SHA256_SUM_LEN; i++) { + char chr[3]; + + strncpy(chr, &sha_env_str[i * 2], 2); + sha_env[i] = simple_strtoul(chr, NULL, 16); + } + + /* + * We don't know how long the stop-string is, so we need to + * generate the sha256 hash upon each input character and + * compare the value with the one saved in the environment + */ + do { + if (tstc()) { + presskey[presskey_len++] = getc(); + + /* Calculate sha256 upon each new char */ + sha256_csum_wd((unsigned char *)presskey, presskey_len, + sha, CHUNKSZ_SHA256); + + /* And check if sha matches saved value in env */ + if (memcmp(sha, sha_env, SHA256_SUM_LEN) == 0) + abort = 1; + } + } while (!abort && get_ticks() <= etime); + + return abort; +} +#else +static int passwd_abort(uint64_t etime) { int abort = 0; - uint64_t etime = endtick(bootdelay); struct { char *str; u_int len; @@ -42,7 +86,9 @@ static int abortboot_keyed(int bootdelay) } delaykey[] = { { .str = getenv("bootdelaykey"), .retry = 1 }, + { .str = getenv("bootdelaykey2"), .retry = 1 }, { .str = getenv("bootstopkey"), .retry = 0 }, + { .str = getenv("bootstopkey2"), .retry = 0 }, };
char presskey[MAX_DELAY_STOP_STR]; @@ -50,26 +96,21 @@ static int abortboot_keyed(int bootdelay) u_int presskey_max = 0; u_int i;
-#ifndef CONFIG_ZERO_BOOTDELAY_CHECK - if (bootdelay == 0) - return 0; -#endif - -# ifdef CONFIG_AUTOBOOT_PROMPT - /* - * CONFIG_AUTOBOOT_PROMPT includes the %d for all boards. - * To print the bootdelay value upon bootup. - */ - printf(CONFIG_AUTOBOOT_PROMPT, bootdelay); -# endif - # ifdef CONFIG_AUTOBOOT_DELAY_STR if (delaykey[0].str == NULL) delaykey[0].str = CONFIG_AUTOBOOT_DELAY_STR; # endif -# ifdef CONFIG_AUTOBOOT_STOP_STR +# ifdef CONFIG_AUTOBOOT_DELAY_STR2 if (delaykey[1].str == NULL) - delaykey[1].str = CONFIG_AUTOBOOT_STOP_STR; + delaykey[1].str = CONFIG_AUTOBOOT_DELAY_STR2; +# endif +# ifdef CONFIG_AUTOBOOT_STOP_STR + if (delaykey[2].str == NULL) + delaykey[2].str = CONFIG_AUTOBOOT_STOP_STR; +# endif +# ifdef CONFIG_AUTOBOOT_STOP_STR2 + if (delaykey[3].str == NULL) + delaykey[3].str = CONFIG_AUTOBOOT_STOP_STR2; # endif
for (i = 0; i < sizeof(delaykey) / sizeof(delaykey[0]); i++) { @@ -119,6 +160,33 @@ static int abortboot_keyed(int bootdelay) } } while (!abort && get_ticks() <= etime);
+ return abort; +} +#endif + +/*************************************************************************** + * Watch for 'delay' seconds for autoboot stop or autoboot delay string. + * returns: 0 - no key string, allow autoboot 1 - got key string, abort + */ +static int abortboot_keyed(int bootdelay) +{ + int abort; + uint64_t etime = endtick(bootdelay); + +#ifndef CONFIG_ZERO_BOOTDELAY_CHECK + if (bootdelay == 0) + return 0; +#endif + +# ifdef CONFIG_AUTOBOOT_PROMPT + /* + * CONFIG_AUTOBOOT_PROMPT includes the %d for all boards. + * To print the bootdelay value upon bootup. + */ + printf(CONFIG_AUTOBOOT_PROMPT, bootdelay); +# endif + + abort = passwd_abort(etime); if (!abort) debug_bootkeys("key timeout\n");
Hi Stefan
char chr[3];
do {
if (tstc()) {
abort = 1;
I don't know what the security requirements are for this feature, i.e. what strength the mechanism should have but:
1. Simply hashing the password is not recommended, a long salt (generated by a good random number generator) should be pre-pended to the passphrase before hashing. See [1]
2. Using memcmp() is not recommended for the above comparison. See [1] (SlowEqual example).
3. I haven't looked closely at the code above but it looks to me that there is no check that the stop-string entered by the user/attacker fits the presskey buffer. I.e. a buffer overflow attack might be possible.
[1] https://crackstation.net/hashing-security.htm
Regards, Magnus
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org Cc: Magnus Lilja lilja.magnus@gmail.com --- v2: - AUTOBOOT_STOP_STR_SHA256 is a string and not bool - Add input key length check as suggested by Magnus - Add "constant-length" time compare function as suggested by Magnus
common/Kconfig | 20 +++++++-- common/autoboot.c | 132 +++++++++++++++++++++++++++++++++++++++++++++--------- 2 files changed, 128 insertions(+), 24 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index ff150f0..71c5c10 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -45,9 +45,14 @@ config AUTOBOOT_PROMPT the responsibility of the user to select only such arguments that are valid in the given context.
+config AUTOBOOT_STOP_STR_SHA256 + string "Stop autobooting via SHA256 encrypted password" + depends on AUTOBOOT_KEYED && AUTOBOOT_ENCRYPTION + help + This option adds the feature to only stop the autobooting, + and therefore boot into the U-Boot prompt, when the input + string / password matches a values that is encypted via + a SHA256 hash and saved in the environment. + endmenu
comment "Commands" diff --git a/common/autoboot.c b/common/autoboot.c index f72eb18..dde3d04 100644 --- a/common/autoboot.c +++ b/common/autoboot.c @@ -12,6 +12,7 @@ #include <fdtdec.h> #include <menu.h> #include <post.h> +#include <u-boot/sha256.h>
@@ -26,15 +27,80 @@ DECLARE_GLOBAL_DATA_PTR; /* Stored value of bootdelay, used by autoboot_command() */ static int stored_bootdelay;
-/*************************************************************************** - * Watch for 'delay' seconds for autoboot stop or autoboot delay string. - * returns: 0 - no key string, allow autoboot 1 - got key string, abort +#if defined(CONFIG_AUTOBOOT_KEYED) +#if defined(CONFIG_AUTOBOOT_STOP_STR_SHA256) + +/* + * Use a "constant-length" time compare function for this + * hash compare: + * + * https://crackstation.net/hashing-security.htm */ -# if defined(CONFIG_AUTOBOOT_KEYED) -static int abortboot_keyed(int bootdelay) +static int slow_equals(u8 *a, u8 *b, int len) +{ + int diff = 0; + int i; + + for (i = 0; i < len; i++) + diff |= a[i] ^ b[i]; + + return diff == 0; +} + +static int passwd_abort(uint64_t etime) +{ + const char *sha_env_str = getenv("bootstopkeysha256"); + u8 sha_env[SHA256_SUM_LEN]; + u8 sha[SHA256_SUM_LEN]; + char presskey[MAX_DELAY_STOP_STR]; + u_int presskey_len = 0; + int i; + int abort = 0; + + if (sha_env_str == NULL) + sha_env_str = CONFIG_AUTOBOOT_STOP_STR_SHA256; + + /* + * Generate the binary value from the environment hash value + * so that we can compare this value with the computed hash + * from the user input + */ + for (i = 0; i < SHA256_SUM_LEN; i++) { + char chr[3]; + + strncpy(chr, &sha_env_str[i * 2], 2); + sha_env[i] = simple_strtoul(chr, NULL, 16); + } + + /* + * We don't know how long the stop-string is, so we need to + * generate the sha256 hash upon each input character and + * compare the value with the one saved in the environment + */ + do { + if (tstc()) { + /* Check for input string overflow */ + if (presskey_len >= MAX_DELAY_STOP_STR) + return 0; + + presskey[presskey_len++] = getc(); + + /* Calculate sha256 upon each new char */ + sha256_csum_wd((unsigned char *)presskey, presskey_len, + sha, CHUNKSZ_SHA256); + + /* And check if sha matches saved value in env */ + if (slow_equals(sha, sha_env, SHA256_SUM_LEN)) + abort = 1; + } + } while (!abort && get_ticks() <= etime); + + return abort; +} +#else +static int passwd_abort(uint64_t etime) { int abort = 0; - uint64_t etime = endtick(bootdelay); struct { char *str; u_int len; @@ -42,7 +108,9 @@ static int abortboot_keyed(int bootdelay) } delaykey[] = { { .str = getenv("bootdelaykey"), .retry = 1 }, + { .str = getenv("bootdelaykey2"), .retry = 1 }, { .str = getenv("bootstopkey"), .retry = 0 }, + { .str = getenv("bootstopkey2"), .retry = 0 }, };
char presskey[MAX_DELAY_STOP_STR]; @@ -50,26 +118,21 @@ static int abortboot_keyed(int bootdelay) u_int presskey_max = 0; u_int i;
for (i = 0; i < sizeof(delaykey) / sizeof(delaykey[0]); i++) { @@ -119,6 +182,33 @@ static int abortboot_keyed(int bootdelay) } } while (!abort && get_ticks() <= etime);
Hi Stefan,
v2:
A few optional ideas below.
default n
help
endmenu
- Watch for 'delay' seconds for autoboot stop or autoboot delay string.
- returns: 0 - no key string, allow autoboot 1 - got key string, abort
- Use a "constant-length" time compare function for this
- hash compare:
int diff = 0;
int i;
return diff == 0;
int i;
int abort = 0;
char chr[3];
There is similar code in parse_verify_sum() in hash.c. Not sure if it is worth putting it in a function, like:
hash_parse_string(const char *algo_name, cost char *str, u8 *result)
It could support other algorithms for autoboot in the future if that became useful.
do {
if (tstc()) {
Could use hash_block()
abort = 1;
return abort;
{ .str = getenv("bootstopkey2"), .retry = 0 }, }; char presskey[MAX_DELAY_STOP_STR];
if (bootdelay == 0)
-#endif
-# endif
# endif
return abort;
+} +#endif
int abort;
if (bootdelay == 0)
+# endif
-- 2.4.0
Hi Stefan,
v2:
[snip]
-#endif
-# endif
# endif
isn't this part removed before in 2/4 'autoboot.c: Remove CONFIG_AUTOBOOT_STOP_STR2 and CONFIG_AUTOBOOT_DELAY_STR2'?
Andreas
Hi Andreas,
# endif
Right. I messed up while rebasing. v3 will follow hopefully today.
Thanks, Stefan
Hi Stefan,
v2:
May I ask why you don't go all the way and use the salt mechanism instead of just hashing the password?
Regards; Magnus
Hi Magnus,
v2:
Because its a customer requirement to implement it in this "simple" way. Even though cracking will be easier than by using this salt mechanism. If someone needs this stronger encryption support at some time, I suggest to add it as an additional feature / option then.
Thanks, Stefan
participants (7)
Andreas Bießmann
Magnus Lilja
Masahiro Yamada
Stefan Roese
Stefan Roese
