[PATCH] arm64: zynqmp: Add missing ZYNQMP_FIRMWARE dependencies
From: Algapally Santosh Sagar santoshsagar.algapally@amd.com
There are missing Kconfig dependencies in the code which is using firmware interface. The commit 71efd45a5fc7 ("arm64: zynqmp: Change firmware dependency") add option to also disable ZYNQMP_FIRMWARE. But not all Kconfig dependencies were properly described and also sdhci and gem drivers didn't protect the code properly. So, add the missing ZYNQMP_FIRMWARE dependencies.
Signed-off-by: Algapally Santosh Sagar santoshsagar.algapally@amd.com Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@amd.com ---
board/xilinx/zynqmp/Kconfig | 1 + drivers/clk/Kconfig | 4 ++-- drivers/fpga/Kconfig | 2 +- drivers/mmc/zynq_sdhci.c | 4 ++-- drivers/net/zynq_gem.c | 2 +- 5 files changed, 7 insertions(+), 6 deletions(-)
diff --git a/board/xilinx/zynqmp/Kconfig b/board/xilinx/zynqmp/Kconfig index 7d1f7398c3..ffa2f0215d 100644 --- a/board/xilinx/zynqmp/Kconfig +++ b/board/xilinx/zynqmp/Kconfig @@ -6,6 +6,7 @@ if ARCH_ZYNQMP
config CMD_ZYNQMP bool "Enable ZynqMP specific commands" + depends on ZYNQMP_FIRMWARE default y help Enable ZynqMP specific commands like "zynqmp secure" diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 09aa97ee8c..42280cbf83 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -185,7 +185,7 @@ config CLK_VERSACLOCK config CLK_VERSAL bool "Enable clock driver support for Versal" depends on (ARCH_VERSAL || ARCH_VERSAL_NET) - select ZYNQMP_FIRMWARE + imply ZYNQMP_FIRMWARE help This clock driver adds support for clock realted settings for Versal platform. @@ -219,7 +219,7 @@ config CLK_ZYNQ config CLK_ZYNQMP bool "Enable clock driver support for ZynqMP" depends on ARCH_ZYNQMP - select ZYNQMP_FIRMWARE + imply ZYNQMP_FIRMWARE help This clock driver adds support for clock realted settings for ZynqMP platform. diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index 4113de230c..f8b0aeb3ee 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -63,7 +63,7 @@ config FPGA_XILINX
config FPGA_ZYNQMPPL bool "Enable Xilinx FPGA driver for ZynqMP" - depends on FPGA_XILINX + depends on FPGA_XILINX && ZYNQMP_FIRMWARE help Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq UltraScale+ (ZynqMP) device. diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 91e309d275..8b559d8a7a 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -988,7 +988,7 @@ static const struct sdhci_ops arasan_ops = { }; #endif
-#if defined(CONFIG_ARCH_ZYNQMP) +#if defined(CONFIG_ARCH_ZYNQMP) && defined(CONFIG_ZYNQMP_FIRMWARE) static int sdhci_zynqmp_set_dynamic_config(struct arasan_sdhci_priv *priv, struct udevice *dev) { @@ -1090,7 +1090,7 @@ static int arasan_sdhci_probe(struct udevice *dev)
host = priv->host;
-#if defined(CONFIG_ARCH_ZYNQMP) +#if defined(CONFIG_ARCH_ZYNQMP) && defined(CONFIG_ZYNQMP_FIRMWARE) if (device_is_compatible(dev, "xlnx,zynqmp-8.9a")) { ret = zynqmp_pm_is_function_supported(PM_IOCTL, IOCTL_SET_SD_CONFIG); diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index cc49788012..211b2c6e55 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -738,7 +738,7 @@ static int gem_zynqmp_set_dynamic_config(struct udevice *dev) u32 pm_info[2]; int ret;
- if (IS_ENABLED(CONFIG_ARCH_ZYNQMP)) { + if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) && IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { if (!zynqmp_pm_is_function_supported(PM_IOCTL, IOCTL_SET_GEM_CONFIG)) { ret = ofnode_read_u32_array(dev_ofnode(dev),
- depends on ZYNQMP_FIRMWARE default y help Enable ZynqMP specific commands like "zynqmp secure"
- imply ZYNQMP_FIRMWARE help This clock driver adds support for clock realted settings for Versal platform.
- imply ZYNQMP_FIRMWARE help This clock driver adds support for clock realted settings for ZynqMP platform.
- depends on FPGA_XILINX && ZYNQMP_FIRMWARE help Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq UltraScale+ (ZynqMP) device.
host = priv->host;
- if (IS_ENABLED(CONFIG_ARCH_ZYNQMP) && IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { if (!zynqmp_pm_is_function_supported(PM_IOCTL, IOCTL_SET_GEM_CONFIG)) { ret = ofnode_read_u32_array(dev_ofnode(dev),
Applied. M
Ashok Reddy Soma
Michal Simek
