[PATCH v3] wdt: nuvoton: Add support for Nuvoton
Add watchdog controller driver for NPCM7xx/npcm8xx
Signed-off-by: jimliu2 JJLIU0@nuvoton.com --- Changes for v2: - coding Style cleanup - change register type from struct npcm_wdt to iomem
Changes for v3: - remove common.h
drivers/watchdog/Kconfig | 6 ++ drivers/watchdog/Makefile | 1 + drivers/watchdog/npcm_wdt.c | 118 ++++++++++++++++++++++++++++++++++++ 3 files changed, 125 insertions(+) create mode 100644 drivers/watchdog/npcm_wdt.c
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index f90f0ca02b..15edcf570f 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -196,6 +196,12 @@ config WDT_MTK The watchdog timer is stopped when initialized. It performs full SoC reset.
+config WDT_NPCM + bool "Nuvoton watchdog timer support" + depends on WDT && ARCH_NPCM + help + Nuvoton npcm7xx/npcm8xx watchdog. + config WDT_OCTEONTX bool "OcteonTX core watchdog support" depends on WDT && (ARCH_OCTEONTX || ARCH_OCTEONTX2) diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index a35bd559f5..1089cd21f5 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -31,6 +31,7 @@ obj-$(CONFIG_WDT_MPC8xx) += mpc8xx_wdt.o obj-$(CONFIG_WDT_MT7620) += mt7620_wdt.o obj-$(CONFIG_WDT_MT7621) += mt7621_wdt.o obj-$(CONFIG_WDT_MTK) += mtk_wdt.o +obj-$(CONFIG_WDT_NPCM) += npcm_wdt.o obj-$(CONFIG_WDT_OCTEONTX) += octeontx_wdt.o obj-$(CONFIG_WDT_OMAP3) += omap_wdt.o obj-$(CONFIG_WDT_SBSA) += sbsa_gwdt.o diff --git a/drivers/watchdog/npcm_wdt.c b/drivers/watchdog/npcm_wdt.c new file mode 100644 index 0000000000..333c06a4e7 --- /dev/null +++ b/drivers/watchdog/npcm_wdt.c @@ -0,0 +1,118 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Nuvoton Technology, Inc + */ + +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <wdt.h> +#include <asm/io.h> +#include <linux/delay.h> +#include <linux/err.h> + +#define NPCM_WTCLK (BIT(10) | BIT(11)) /* Clock divider */ +#define NPCM_WTE BIT(7) /* Enable */ +#define NPCM_WTIE BIT(6) /* Enable irq */ +#define NPCM_WTIS (BIT(4) | BIT(5)) /* Interval selection */ +#define NPCM_WTIF BIT(3) /* Interrupt flag*/ +#define NPCM_WTRF BIT(2) /* Reset flag */ +#define NPCM_WTRE BIT(1) /* Reset enable */ +#define NPCM_WTR BIT(0) /* Reset counter */ + +struct npcm_wdt_priv { + void __iomem *regs; +}; + +static int npcm_wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) +{ + struct npcm_wdt_priv *priv = dev_get_priv(dev); + u32 time_out, val; + + time_out = (u32)(timeout_ms) / 1000; + if (time_out < 2) + val = 0x800; + else if (time_out < 3) + val = 0x420; + else if (time_out < 6) + val = 0x810; + else if (time_out < 11) + val = 0x430; + else if (time_out < 22) + val = 0x820; + else if (time_out < 44) + val = 0xC00; + else if (time_out < 87) + val = 0x830; + else if (time_out < 173) + val = 0xC10; + else if (time_out < 688) + val = 0xC20; + else + val = 0xC30; + + val |= NPCM_WTRE | NPCM_WTE | NPCM_WTR | NPCM_WTIE; + writel(val, priv->regs); + + return 0; +} + +static int npcm_wdt_stop(struct udevice *dev) +{ + struct npcm_wdt_priv *priv = dev_get_priv(dev); + + writel(0, priv->regs); + + return 0; +} + +static int npcm_wdt_reset(struct udevice *dev) +{ + struct npcm_wdt_priv *priv = dev_get_priv(dev); + + writel(NPCM_WTR | NPCM_WTRE | NPCM_WTE, priv->regs); + udelay(1000); + + return 0; +} + +static int npcm_wdt_of_to_plat(struct udevice *dev) +{ + struct npcm_wdt_priv *priv = dev_get_priv(dev); + + priv->regs = dev_read_addr_ptr(dev); + if (!priv->regs) + return -EINVAL; + + return 0; +} + +static const struct wdt_ops npcm_wdt_ops = { + .start = npcm_wdt_start, + .reset = npcm_wdt_reset, + .stop = npcm_wdt_stop, +}; + +static const struct udevice_id npcm_wdt_ids[] = { + { .compatible = "nuvoton,npcm750-wdt" }, + { .compatible = "nuvoton,npcm845-wdt" }, + { } +}; + +static int npcm_wdt_probe(struct udevice *dev) +{ + debug("%s() wdt%u\n", __func__, dev_seq(dev)); + npcm_wdt_stop(dev); + + return 0; +} + +U_BOOT_DRIVER(npcm_wdt) = { + .name = "npcm_wdt", + .id = UCLASS_WDT, + .of_match = npcm_wdt_ids, + .probe = npcm_wdt_probe, + .priv_auto = sizeof(struct npcm_wdt_priv), + .of_to_plat = npcm_wdt_of_to_plat, + .ops = &npcm_wdt_ops, +};
Thanks, Stefan
+config WDT_NPCM
- bool "Nuvoton watchdog timer support"
- depends on WDT && ARCH_NPCM
- help
- config WDT_OCTEONTX bool "OcteonTX core watchdog support" depends on WDT && (ARCH_OCTEONTX || ARCH_OCTEONTX2)
- Copyright (c) 2022 Nuvoton Technology, Inc
- void __iomem *regs;
- struct npcm_wdt_priv *priv = dev_get_priv(dev);
- u32 time_out, val;
- time_out = (u32)(timeout_ms) / 1000;
- if (time_out < 2)
val = 0x800;
- else if (time_out < 3)
val = 0x420;
- else if (time_out < 6)
val = 0x810;
- else if (time_out < 11)
val = 0x430;
- else if (time_out < 22)
val = 0x820;
- else if (time_out < 44)
val = 0xC00;
- else if (time_out < 87)
val = 0x830;
- else if (time_out < 173)
val = 0xC10;
- else if (time_out < 688)
val = 0xC20;
- else
val = 0xC30;
- val |= NPCM_WTRE | NPCM_WTE | NPCM_WTR | NPCM_WTIE;
- writel(val, priv->regs);
- writel(0, priv->regs);
- writel(NPCM_WTR | NPCM_WTRE | NPCM_WTE, priv->regs);
- udelay(1000);
- priv->regs = dev_read_addr_ptr(dev);
- if (!priv->regs)
return -EINVAL;
- .start = npcm_wdt_start,
- .reset = npcm_wdt_reset,
- .stop = npcm_wdt_stop,
- { .compatible = "nuvoton,npcm750-wdt" },
- { .compatible = "nuvoton,npcm845-wdt" },
- debug("%s() wdt%u\n", __func__, dev_seq(dev));
- npcm_wdt_stop(dev);
- .name = "npcm_wdt",
- .id = UCLASS_WDT,
- .of_match = npcm_wdt_ids,
- .probe = npcm_wdt_probe,
- .priv_auto = sizeof(struct npcm_wdt_priv),
- .of_to_plat = npcm_wdt_of_to_plat,
- .ops = &npcm_wdt_ops,
Viele Grüße, Stefan Roese
jimliu2
Stefan Roese
