[PATCH] mxs: power: Change sequence of enabling DCDC switches
The imx28 uses following voltage supplies hierarchy:
VDD_5V (VDD_BAT) -> VDDIO -> VDDA -> VDDMEM -----> VDDD
One shall first enable DCDC on the parent source (VDDIO) and then follow with its children.
Signed-off-by: Lukasz Majewski lukma@denx.de --- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c index 35ea71a5ba8..c33170f06d3 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -627,11 +627,11 @@ static void mxs_power_enable_4p2(void)
mxs_power_init_dcdc_4p2_source();
- writel(vdddctrl, &power_regs->hw_power_vdddctrl); + writel(vddioctrl, &power_regs->hw_power_vddioctrl); early_delay(20); writel(vddactrl, &power_regs->hw_power_vddactrl); early_delay(20); - writel(vddioctrl, &power_regs->hw_power_vddioctrl); + writel(vdddctrl, &power_regs->hw_power_vdddctrl);
/* * Check if FET is enabled on either powerout and if so,
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- writel(vddioctrl, &power_regs->hw_power_vddioctrl); early_delay(20); writel(vddactrl, &power_regs->hw_power_vddactrl); early_delay(20);
- Check if FET is enabled on either powerout and if so,
Reviewed-by: Fabio Estevam festevam@gmail.com
The imx28 uses following voltage supplies hierarchy: VDD_5V (VDD_BAT) -> VDDIO -> VDDA -> VDDMEM -----> VDDD One shall first enable DCDC on the parent source (VDDIO) and then follow with its children. Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Jaehoon Chung
Lukasz Majewski
sbabic@denx.de
