[RFC PATCH 0/2] Move FSP configuration to devicetree
This patch series moves the configuration of FPS-S and FSP-M for Apollo Lake based SoCs from the code to the devicetree.
In order to make the FSP configuration easy to extend and maintain new binding structs for FSP-M and FSP-S are introduced. These structs contain the information of which devicetree settings need to be copied to which offset in the FSP config structure. The actual code handling these structs is rather small, and generic for both FSP-S and FSP-M.
This patch series replaces the previous sent patches: "arch: x86: apl: Read FSP-M configuration from device-tree" [1] "Move FSP-S configuration to device-tree" [2]
Changes to [1] and [2]: - No default settings within U-Boot, the default settings in FSP are used directly - The code for copying the data was simplified, and the information of what needs to be copied was moved to newly introduced structures
[1]: https://lists.denx.de/pipermail/u-boot/2020-April/405852.html [2]: https://lists.denx.de/pipermail/u-boot/2020-April/406590.html
Bernhard Messerklinger (2): arch: x86: apl: Only load VBT if CONFIG_HAVE_VBT is enabled arch: x86: apl: Use devicetree for FSP configuration
arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/fsp_bindings.c | 2096 +++++++++++++++++ arch/x86/cpu/apollolake/fsp_m.c | 164 +- arch/x86/cpu/apollolake/fsp_s.c | 404 +--- arch/x86/dts/chromebook_coral.dts | 72 +- .../asm/arch-apollolake/fsp/fsp_m_upd.h | 168 ++ .../asm/arch-apollolake/fsp/fsp_s_upd.h | 202 ++ .../asm/arch-apollolake/fsp_bindings.h | 74 + .../fsp/fsp2/apollolake/fsp-m.txt | 320 +++ .../fsp/fsp2/apollolake/fsp-s.txt | 483 ++++ 10 files changed, 3432 insertions(+), 552 deletions(-) create mode 100644 arch/x86/cpu/apollolake/fsp_bindings.c create mode 100644 arch/x86/include/asm/arch-apollolake/fsp_bindings.h create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt
Only load VBT if it's present in the u-boot.rom.
Signed-off-by: Bernhard Messerklinger bernhard.messerklinger@br-automation.com ---
arch/x86/cpu/apollolake/fsp_s.c | 18 ++++++++---------- 1 file changed, 8 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 17cf1682ad..8f1d6f3008 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -327,16 +327,17 @@ int fsps_update_config(struct udevice *dev, ulong rom_offset, { struct fsp_s_config *cfg = &upd->config; struct apl_config *apl; +#ifdef CONFIG_HAVE_VBT struct binman_entry vbt; - void *buf; + void *vbt_buf; int ret;
ret = binman_entry_find("intel-vbt", &vbt); if (ret) return log_msg_ret("Cannot find VBT", ret); vbt.image_pos += rom_offset; - buf = malloc(vbt.size); - if (!buf) + vbt_buf = malloc(vbt.size); + if (!vbt_buf) return log_msg_ret("Alloc VBT", -ENOMEM);
/* @@ -344,16 +345,13 @@ int fsps_update_config(struct udevice *dev, ulong rom_offset, * memory-mapped SPI at present. */ bootstage_start(BOOTSTAGE_ID_ACCUM_MMAP_SPI, "mmap_spi"); - memcpy(buf, (void *)vbt.image_pos, vbt.size); + memcpy(vbt_buf, (void *)vbt.image_pos, vbt.size); bootstage_accum(BOOTSTAGE_ID_ACCUM_MMAP_SPI); - if (*(u32 *)buf != VBT_SIGNATURE) + if (*(u32 *)vbt_buf != VBT_SIGNATURE) return log_msg_ret("VBT signature", -EINVAL); - cfg->graphics_config_ptr = (ulong)buf;
- apl = malloc(sizeof(*apl)); - if (!apl) - return log_msg_ret("config", -ENOMEM); - get_config(dev, apl); + cfg->graphics_config_ptr = (ulong)vbt_buf; +#endif
cfg->ish_enable = 0; cfg->enable_sata = 0;
Hi Bernhard,
On Thu, 30 Apr 2020 at 03:16, Bernhard Messerklinger bernhard.messerklinger@br-automation.com wrote:
I think you can drop the RFC from this series. The approach seems good to me.
Also, what APL boards have you tested with?
Please use if (IS_ENABLED(CONFIG_HAVE_VBT))
We should try to avoid #ifdef unless needed as it adds different build paths.
void *buf;
void *vbt_buf; int ret; ret = binman_entry_find("intel-vbt", &vbt); if (ret) return log_msg_ret("Cannot find VBT", ret); vbt.image_pos += rom_offset;
if (!buf)
if (!vbt_buf) return log_msg_ret("Alloc VBT", -ENOMEM); /*
if (!apl)
Should not drop the above code.
-- 2.26.0
Hi Simon,
Hi Bernhard,
I tested our custom APL smarc board. I also have a Oxbow Hill CRB but can't test it there at the moment (currently I am working from home).
ulong rom_offset,
void *buf;
if (!buf)
ulong rom_offset,
if (!apl)
-- 2.26.0
Regards, Bernhard
A the moment the FSP configuration is a mix of hard coded values and devicetree properties. This patch makes FSP-M and FSP-S full configurable from devicetree by adding binding properties for all FSP parameters.
Co-developed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Bernhard Messerklinger bernhard.messerklinger@br-automation.com
arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/fsp_bindings.c | 2096 +++++++++++++++++ arch/x86/cpu/apollolake/fsp_m.c | 164 +- arch/x86/cpu/apollolake/fsp_s.c | 382 +-- arch/x86/dts/chromebook_coral.dts | 72 +- .../asm/arch-apollolake/fsp/fsp_m_upd.h | 168 ++ .../asm/arch-apollolake/fsp/fsp_s_upd.h | 202 ++ .../asm/arch-apollolake/fsp_bindings.h | 74 + .../fsp/fsp2/apollolake/fsp-m.txt | 320 +++ .../fsp/fsp2/apollolake/fsp-s.txt | 483 ++++ 10 files changed, 3422 insertions(+), 540 deletions(-) create mode 100644 arch/x86/cpu/apollolake/fsp_bindings.c create mode 100644 arch/x86/include/asm/arch-apollolake/fsp_bindings.h create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt
diff --git a/arch/x86/cpu/apollolake/Makefile b/arch/x86/cpu/apollolake/Makefile index 578e15c4bf..3aa2a55676 100644 --- a/arch/x86/cpu/apollolake/Makefile +++ b/arch/x86/cpu/apollolake/Makefile @@ -10,6 +10,7 @@ obj-y += cpu_common.o ifndef CONFIG_TPL_BUILD obj-y += cpu.o obj-y += punit.o +obj-y += fsp_bindings.o ifdef CONFIG_SPL_BUILD obj-y += fsp_m.o endif diff --git a/arch/x86/cpu/apollolake/fsp_bindings.c b/arch/x86/cpu/apollolake/fsp_bindings.c new file mode 100644 index 0000000000..9c10e7328a --- /dev/null +++ b/arch/x86/cpu/apollolake/fsp_bindings.c @@ -0,0 +1,2096 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2020 B&R Industrial Automation GmbH - http://www.br-automation.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/arch/fsp_bindings.h> + +static void read_u8_prop(ofnode node, u8 *dst, char *name, size_t count) +{ + u32 tmp; + const u8 *buf; + int ret; + + if (count == 0) { + ret = ofnode_read_u32(node, name, &tmp); + if (ret == 0) + *dst = tmp; + } else { + buf = ofnode_read_u8_array_ptr(node, name, count); + if (buf) + memcpy(dst, buf, count); + } +} + +static void read_u16_prop(ofnode node, u16 *dst, char *name, size_t count) +{ + u32 tmp; + u32 buf[32]; + int ret; + + if (ARRAY_SIZE(buf) < count) { + printf("ERROR: %s buffer to small!\n", __func__); + return; + } + + if (count == 0) { + ret = ofnode_read_u32(node, name, &tmp); + if (ret == 0) + *dst = tmp; + } else { + ret = ofnode_read_u32_array(node, name, buf, count); + if (ret == 0) + for (int i = 0; i < count; i++) + dst[i] = buf[i]; + } +} + +static void read_u32_prop(ofnode node, u32 *dst, char *name, size_t count) +{ + if (count == 0) + ofnode_read_u32(node, name, dst); + else + ofnode_read_u32_array(node, name, dst, count); +} + +static void read_string_prop(ofnode node, char *dst, char *name, int count) +{ + const char *string_buf; + + if (count > 0) { + string_buf = ofnode_read_string(node, name); + if (string_buf) { + strncpy(dst, string_buf, count); + dst[count - 1] = '\0'; + } + } +} + +static void read_swizzle_prop(ofnode node, u8 *dst, char *name, int count) +{ + const struct lpddr4_chan_swizzle_cfg *sch; + /* Number of bytes to copy per DQS */ + const size_t sz = DQ_BITS_PER_DQS; + const struct lpddr4_swizzle_cfg *swizzle_cfg; + + swizzle_cfg = (const struct lpddr4_swizzle_cfg *) + ofnode_read_u8_array_ptr(node, name, count); + + if (!swizzle_cfg) + return; + /* + * CH0_DQB byte lanes in the bit swizzle configuration field are + * not 1:1. The mapping within the swizzling field is: + * indices [0:7] - byte lane 1 (DQS1) DQ[8:15] + * indices [8:15] - byte lane 0 (DQS0) DQ[0:7] + * indices [16:23] - byte lane 3 (DQS3) DQ[24:31] + * indices [24:31] - byte lane 2 (DQS2) DQ[16:23] + */ + sch = &swizzle_cfg->phys[LP4_PHYS_CH0B]; + memcpy(&dst[0 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz); + memcpy(&dst[1 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz); + memcpy(&dst[2 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz); + memcpy(&dst[3 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz); + + /* + * CH0_DQA byte lanes in the bit swizzle configuration field are 1:1. + */ + sch = &swizzle_cfg->phys[LP4_PHYS_CH0A]; + memcpy(&dst[4 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz); + memcpy(&dst[5 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz); + memcpy(&dst[6 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz); + memcpy(&dst[7 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz); + + sch = &swizzle_cfg->phys[LP4_PHYS_CH1B]; + memcpy(&dst[8 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz); + memcpy(&dst[9 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz); + memcpy(&dst[10 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz); + memcpy(&dst[11 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz); + + /* + * CH0_DQA byte lanes in the bit swizzle configuration field are 1:1. + */ + sch = &swizzle_cfg->phys[LP4_PHYS_CH1A]; + memcpy(&dst[12 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz); + memcpy(&dst[13 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz); + memcpy(&dst[14 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz); + memcpy(&dst[15 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz); +} + +static void fsp_update_config_from_dtb(ofnode node, u8 *cfg, + const struct fsp_binding *fsp_bindings) +{ + for (int i = 0; fsp_bindings[i].propname; i++) { + switch (fsp_bindings[i].type) { + case FSP_UINT8: + read_u8_prop(node, &cfg[fsp_bindings[i].offset], + fsp_bindings[i].propname, + fsp_bindings[i].count); + break; + case FSP_UINT16: + read_u16_prop(node, + (u16 *)&cfg[fsp_bindings[i].offset], + fsp_bindings[i].propname, + fsp_bindings[i].count); + break; + case FSP_UINT32: + read_u32_prop(node, + (u32 *)&cfg[fsp_bindings[i].offset], + fsp_bindings[i].propname, + fsp_bindings[i].count); + break; + case FSP_STRING: + read_string_prop(node, (char *) + &cfg[fsp_bindings[i].offset], + fsp_bindings[i].propname, + fsp_bindings[i].count); + break; + case FSP_LPDDR4_SWIZZLE: + read_swizzle_prop(node, + &cfg[fsp_bindings[i].offset], + fsp_bindings[i].propname, + fsp_bindings[i].count); + break; + } + } +} + +#if defined(CONFIG_SPL_BUILD) +const struct fsp_binding fsp_m_bindings[] = { + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, serial_debug_port_address), + .propname = "fspm,serial-debug-port-address", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, serial_debug_port_type), + .propname = "fspm,serial-debug-port-type", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, serial_debug_port_device), + .propname = "fspm,serial-debug-port-device", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, serial_debug_port_stride_size), + .propname = "fspm,serial-debug-port-stride-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, mrc_fast_boot), + .propname = "fspm,mrc-fast-boot", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, igd), + .propname = "fspm,igd", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, igd_dvmt50_pre_alloc), + .propname = "fspm,igd-dvmt50-pre-alloc", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, igd_aperture_size), + .propname = "fspm,igd-aperture-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, gtt_size), + .propname = "fspm,gtt-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, primary_video_adaptor), + .propname = "fspm,primary-video-adaptor", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, package), + .propname = "fspm,package", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, profile), + .propname = "fspm,profile", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, memory_down), + .propname = "fspm,memory-down", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, ddr3_l_page_size), + .propname = "fspm,ddr3-l-page-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, ddr3_lasr), + .propname = "fspm,ddr3-lasr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, scrambler_support), + .propname = "fspm,scrambler-support", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, interleaved_mode), + .propname = "fspm,interleaved-mode", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, channel_hash_mask), + .propname = "fspm,channel-hash-mask", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, slice_hash_mask), + .propname = "fspm,slice-hash-mask", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, channels_slices_enable), + .propname = "fspm,channels-slices-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, min_ref_rate2x_enable), + .propname = "fspm,min-ref-rate2x-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, dual_rank_support_enable), + .propname = "fspm,dual-rank-support-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, rmt_mode), + .propname = "fspm,rmt-mode", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, memory_size_limit), + .propname = "fspm,memory-size-limit", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, low_memory_max_value), + .propname = "fspm,low-memory-max-value", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, high_memory_max_value), + .propname = "fspm,high-memory-max-value", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, disable_fast_boot), + .propname = "fspm,disable-fast-boot", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, dimm0_spd_address), + .propname = "fspm,dimm0-spd-address", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, dimm1_spd_address), + .propname = "fspm,dimm1-spd-address", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].rank_enable), + .propname = "fspm,ch0-rank-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].device_width), + .propname = "fspm,ch0-device-width", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].dram_density), + .propname = "fspm,ch0-dram-density", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].option), + .propname = "fspm,ch0-option", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].odt_config), + .propname = "fspm,ch0-odt-config", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].tristate_clk1), + .propname = "fspm,ch0-tristate-clk1", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].mode2_n), + .propname = "fspm,ch0-mode2-n", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[0].odt_levels), + .propname = "fspm,ch0-odt-levels", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].rank_enable), + .propname = "fspm,ch1-rank-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].device_width), + .propname = "fspm,ch1-device-width", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].dram_density), + .propname = "fspm,ch1-dram-density", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].option), + .propname = "fspm,ch1-option", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].odt_config), + .propname = "fspm,ch1-odt-config", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].tristate_clk1), + .propname = "fspm,ch1-tristate-clk1", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].mode2_n), + .propname = "fspm,ch1-mode2-n", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[1].odt_levels), + .propname = "fspm,ch1-odt-levels", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].rank_enable), + .propname = "fspm,ch2-rank-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].device_width), + .propname = "fspm,ch2-device-width", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].dram_density), + .propname = "fspm,ch2-dram-density", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].option), + .propname = "fspm,ch2-option", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].odt_config), + .propname = "fspm,ch2-odt-config", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].tristate_clk1), + .propname = "fspm,ch2-tristate-clk1", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].mode2_n), + .propname = "fspm,ch2-mode2-n", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[2].odt_levels), + .propname = "fspm,ch2-odt-levels", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].rank_enable), + .propname = "fspm,ch3-rank-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].device_width), + .propname = "fspm,ch3-device-width", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].dram_density), + .propname = "fspm,ch3-dram-density", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].option), + .propname = "fspm,ch3-option", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].odt_config), + .propname = "fspm,ch3-odt-config", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].tristate_clk1), + .propname = "fspm,ch3-tristate-clk1", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].mode2_n), + .propname = "fspm,ch3-mode2-n", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, chan[3].odt_levels), + .propname = "fspm,ch3-odt-levels", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, rmt_check_run), + .propname = "fspm,rmt-check-run", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_m_config, + rmt_margin_check_scale_high_threshold), + .propname = "fspm,rmt-margin-check-scale-high-threshold", + }, + { + .type = FSP_LPDDR4_SWIZZLE, + .offset = offsetof(struct fsp_m_config, ch_bit_swizzling), + .propname = "fspm,ch-bit-swizzling", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_m_config, ch_bit_swizzling), + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, msg_level_mask), + .propname = "fspm,msg-level-mask", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pre_mem_gpio_table_pin_num), + .propname = "fspm,pre-mem-gpio-table-pin-num", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_m_config, + pre_mem_gpio_table_pin_num), + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, pre_mem_gpio_table_ptr), + .propname = "fspm,pre-mem-gpio-table-ptr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pre_mem_gpio_table_entry_num), + .propname = "fspm,pre-mem-gpio-table-entry-num", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, enhance_port8xh_decoding), + .propname = "fspm,enhance-port8xh-decoding", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, spd_write_enable), + .propname = "fspm,spd-write-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, mrc_data_saving), + .propname = "fspm,mrc-data-saving", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, oem_loading_base), + .propname = "fspm,oem-loading-base", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, oem_file_name), + .propname = "fspm,oem-file-name", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_m_config, oem_file_name), + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, mrc_boot_data_ptr), + .propname = "fspm,mrc-boot-data-ptr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, e_mmc_trace_len), + .propname = "fspm,e-mmc-trace-len", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, skip_cse_rbp), + .propname = "fspm,skip-cse-rbp", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, npk_en), + .propname = "fspm,npk-en", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, fw_trace_en), + .propname = "fspm,fw-trace-en", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, fw_trace_destination), + .propname = "fspm,fw-trace-destination", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, recover_dump), + .propname = "fspm,recover-dump", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, msc0_wrap), + .propname = "fspm,msc0-wrap", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, msc1_wrap), + .propname = "fspm,msc1-wrap", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, msc0_size), + .propname = "fspm,msc0-size", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, msc1_size), + .propname = "fspm,msc1-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pti_mode), + .propname = "fspm,pti-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pti_training), + .propname = "fspm,pti-training", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pti_speed), + .propname = "fspm,pti-speed", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, punit_mlvl), + .propname = "fspm,punit-mlvl", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, pmc_mlvl), + .propname = "fspm,pmc-mlvl", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, sw_trace_en), + .propname = "fspm,sw-trace-en", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, periodic_retraining_disable), + .propname = "fspm,periodic-retraining-disable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, enable_reset_system), + .propname = "fspm,enable-reset-system", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_m_config, enable_s3_heci2), + .propname = "fspm,enable-s3-heci2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_m_config, variable_nvs_buffer_ptr), + .propname = "fspm,variable-nvs-buffer-ptr", + }, + { + .propname = NULL + } +}; + +void fsp_m_update_config_from_dtb(ofnode node, struct fsp_m_config *cfg) +{ + fsp_update_config_from_dtb(node, (u8 *)cfg, fsp_m_bindings); +} +#endif + +#if !defined(CONFIG_SPL_BUILD) || !defined(CONFIG_TPL_BUILD) +const struct fsp_binding fsp_s_bindings[] = { + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, active_processor_cores), + .propname = "fsps,active-processor-cores", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, disable_core1), + .propname = "fsps,disable-core1", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, disable_core2), + .propname = "fsps,disable-core2", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, disable_core3), + .propname = "fsps,disable-core3", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, vmx_enable), + .propname = "fsps,vmx-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, proc_trace_mem_size), + .propname = "fsps,proc-trace-mem-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, proc_trace_enable), + .propname = "fsps,proc-trace-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, eist), + .propname = "fsps,eist", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, boot_p_state), + .propname = "fsps,boot-p-state", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, enable_cx), + .propname = "fsps,enable-cx", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, c1e), + .propname = "fsps,c1e", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, bi_proc_hot), + .propname = "fsps,bi-proc-hot", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pkg_c_state_limit), + .propname = "fsps,pkg-c-state-limit", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, c_state_auto_demotion), + .propname = "fsps,c-state-auto-demotion", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, c_state_un_demotion), + .propname = "fsps,c-state-un-demotion", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, max_core_c_state), + .propname = "fsps,max-core-c-state", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pkg_c_state_demotion), + .propname = "fsps,pkg-c-state-demotion", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pkg_c_state_un_demotion), + .propname = "fsps,pkg-c-state-un-demotion", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, turbo_mode), + .propname = "fsps,turbo-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hda_verb_table_entry_num), + .propname = "fsps,hda-verb-table-entry-num", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, hda_verb_table_ptr), + .propname = "fsps,hda-verb-table-ptr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, p2sb_unhide), + .propname = "fsps,p2sb-unhide", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ipu_en), + .propname = "fsps,ipu-en", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ipu_acpi_mode), + .propname = "fsps,ipu-acpi-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, force_wake), + .propname = "fsps,force-wake", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, gtt_mm_adr), + .propname = "fsps,gtt-mm-adr", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, gm_adr), + .propname = "fsps,gm-adr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pavp_lock), + .propname = "fsps,pavp-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, graphics_freq_modify), + .propname = "fsps,graphics-freq-modify", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, graphics_freq_req), + .propname = "fsps,graphics-freq-req", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, graphics_video_freq), + .propname = "fsps,graphics-video-freq", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pm_lock), + .propname = "fsps,pm-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dop_clock_gating), + .propname = "fsps,dop-clock-gating", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, unsolicited_attack_override), + .propname = "fsps,unsolicited-attack-override", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, wopcm_support), + .propname = "fsps,wopcm-support", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, wopcm_size), + .propname = "fsps,wopcm-size", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, power_gating), + .propname = "fsps,power-gating", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, unit_level_clock_gating), + .propname = "fsps,unit-level-clock-gating", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, fast_boot), + .propname = "fsps,fast-boot", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dyn_sr), + .propname = "fsps,dyn-sr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sa_ipu_enable), + .propname = "fsps,sa-ipu-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pm_support), + .propname = "fsps,pm-support", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, enable_render_standby), + .propname = "fsps,enable-render-standby", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, logo_size), + .propname = "fsps,logo-size", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, logo_ptr), + .propname = "fsps,logo-ptr", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, graphics_config_ptr), + .propname = "fsps,graphics-config-ptr", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pavp_enable), + .propname = "fsps,pavp-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pavp_pr3), + .propname = "fsps,pavp-pr3", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, cd_clock), + .propname = "fsps,cd-clock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pei_graphics_peim_init), + .propname = "fsps,pei-graphics-peim-init", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, write_protection_enable), + .propname = "fsps,write-protection-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + write_protection_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, read_protection_enable), + .propname = "fsps,read-protection-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + read_protection_enable), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, protected_range_limit), + .propname = "fsps,protected-range-limit", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + protected_range_limit), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, protected_range_base), + .propname = "fsps,protected-range-base", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + protected_range_base), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, gmm), + .propname = "fsps,gmm", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_pgcb_clk_trunk), + .propname = "fsps,clk-gating-pgcb-clk-trunk", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_sb), + .propname = "fsps,clk-gating-sb", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_sb_clk_trunk), + .propname = "fsps,clk-gating-sb-clk-trunk", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_sb_clk_partition), + .propname = "fsps,clk-gating-sb-clk-partition", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_core), + .propname = "fsps,clk-gating-core", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_dma), + .propname = "fsps,clk-gating-dma", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_reg_access), + .propname = "fsps,clk-gating-reg-access", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_host), + .propname = "fsps,clk-gating-host", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_partition), + .propname = "fsps,clk-gating-partition", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, clk_gating_trunk), + .propname = "fsps,clk-gating-trunk", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hda_enable), + .propname = "fsps,hda-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dsp_enable), + .propname = "fsps,dsp-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pme), + .propname = "fsps,pme", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_io_buffer_ownership), + .propname = "fsps,hd-audio-io-buffer-ownership", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_io_buffer_voltage), + .propname = "fsps,hd-audio-io-buffer-voltage", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_vc_type), + .propname = "fsps,hd-audio-vc-type", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_link_frequency), + .propname = "fsps,hd-audio-link-frequency", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_i_disp_link_frequency), + .propname = "fsps,hd-audio-i-disp-link-frequency", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_i_disp_link_tmode), + .propname = "fsps,hd-audio-i-disp-link-tmode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dsp_endpoint_dmic), + .propname = "fsps,dsp-endpoint-dmic", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dsp_endpoint_bluetooth), + .propname = "fsps,dsp-endpoint-bluetooth", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dsp_endpoint_i2s_skp), + .propname = "fsps,dsp-endpoint-i2s-skp", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dsp_endpoint_i2s_hp), + .propname = "fsps,dsp-endpoint-i2s-hp", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, audio_ctl_pwr_gate), + .propname = "fsps,audio-ctl-pwr-gate", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, audio_dsp_pwr_gate), + .propname = "fsps,audio-dsp-pwr-gate", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, mmt), + .propname = "fsps,mmt", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hmt), + .propname = "fsps,hmt", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_pwr_gate), + .propname = "fsps,hd-audio-pwr-gate", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_clk_gate), + .propname = "fsps,hd-audio-clk-gate", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, dsp_feature_mask), + .propname = "fsps,dsp-feature-mask", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, dsp_pp_module_mask), + .propname = "fsps,dsp-pp-module-mask", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, bios_cfg_lock_down), + .propname = "fsps,bios-cfg-lock-down", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hpet), + .propname = "fsps,hpet", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hpet_bdf_valid), + .propname = "fsps,hpet-bdf-valid", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hpet_bus_number), + .propname = "fsps,hpet-bus-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hpet_device_number), + .propname = "fsps,hpet-device-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hpet_function_number), + .propname = "fsps,hpet-function-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_bdf_valid), + .propname = "fsps,io-apic-bdf-valid", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_bus_number), + .propname = "fsps,io-apic-bus-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_device_number), + .propname = "fsps,io-apic-device-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_function_number), + .propname = "fsps,io-apic-function-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_entry24_119), + .propname = "fsps,io-apic-entry24-119", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_id), + .propname = "fsps,io-apic-id", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, io_apic_range_select), + .propname = "fsps,io-apic-range-select", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ish_enable), + .propname = "fsps,ish-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, bios_interface), + .propname = "fsps,bios-interface", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, bios_lock), + .propname = "fsps,bios-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, spi_eiss), + .propname = "fsps,spi-eiss", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, bios_lock_sw_smi_number), + .propname = "fsps,bios-lock-sw-smi-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, lpss_s0ix_enable), + .propname = "fsps,lpss-s0ix-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c_clk_gate_cfg), + .propname = "fsps,i2c-clk-gate-cfg", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, i2c_clk_gate_cfg), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsuart_clk_gate_cfg), + .propname = "fsps,hsuart-clk-gate-cfg", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, hsuart_clk_gate_cfg), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, spi_clk_gate_cfg), + .propname = "fsps,spi-clk-gate-cfg", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, spi_clk_gate_cfg), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c0_enable), + .propname = "fsps,i2c0-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c1_enable), + .propname = "fsps,i2c1-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c2_enable), + .propname = "fsps,i2c2-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c3_enable), + .propname = "fsps,i2c3-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c4_enable), + .propname = "fsps,i2c4-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c5_enable), + .propname = "fsps,i2c5-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c6_enable), + .propname = "fsps,i2c6-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, i2c7_enable), + .propname = "fsps,i2c7-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsuart0_enable), + .propname = "fsps,hsuart0-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsuart1_enable), + .propname = "fsps,hsuart1-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsuart2_enable), + .propname = "fsps,hsuart2-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsuart3_enable), + .propname = "fsps,hsuart3-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, spi0_enable), + .propname = "fsps,spi0-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, spi1_enable), + .propname = "fsps,spi1-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, spi2_enable), + .propname = "fsps,spi2-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, os_dbg_enable), + .propname = "fsps,os-dbg-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dci_en), + .propname = "fsps,dci-en", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, + uart2_kernel_debug_base_address), + .propname = "fsps,uart2-kernel-debug-base-address", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_clock_gating_disabled), + .propname = "fsps,pcie-clock-gating-disabled", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_root_port8xh_decode), + .propname = "fsps,pcie-root-port8xh-decode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie8xh_decode_port_index), + .propname = "fsps,pcie8xh-decode-port-index", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_root_port_peer_memory_write_enable), + .propname = "fsps,pcie-root-port-peer-memory-write-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_aspm_sw_smi_number), + .propname = "fsps,pcie-aspm-sw-smi-number", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_root_port_en), + .propname = "fsps,pcie-root-port-en", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_root_port_en), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_hide), + .propname = "fsps,pcie-rp-hide", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_hide), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_slot_implemented), + .propname = "fsps,pcie-rp-slot-implemented", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_slot_implemented), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_hot_plug), + .propname = "fsps,pcie-rp-hot-plug", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_hot_plug), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_pm_sci), + .propname = "fsps,pcie-rp-pm-sci", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_pm_sci), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_ext_sync), + .propname = "fsps,pcie-rp-ext-sync", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_ext_sync), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_rp_transmitter_half_swing), + .propname = "fsps,pcie-rp-transmitter-half-swing", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_transmitter_half_swing), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_acs_enabled), + .propname = "fsps,pcie-rp-acs-enabled", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_acs_enabled), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_clk_req_supported), + .propname = "fsps,pcie-rp-clk-req-supported", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_clk_req_supported), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_clk_req_number), + .propname = "fsps,pcie-rp-clk-req-number", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_clk_req_number), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_clk_req_detect), + .propname = "fsps,pcie-rp-clk-req-detect", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_clk_req_detect), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, advanced_error_reporting), + .propname = "fsps,advanced-error-reporting", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + advanced_error_reporting), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pme_interrupt), + .propname = "fsps,pme-interrupt", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pme_interrupt), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, unsupported_request_report), + .propname = "fsps,unsupported-request-report", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + unsupported_request_report), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, fatal_error_report), + .propname = "fsps,fatal-error-report", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, fatal_error_report), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, no_fatal_error_report), + .propname = "fsps,no-fatal-error-report", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + no_fatal_error_report), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, correctable_error_report), + .propname = "fsps,correctable-error-report", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + correctable_error_report), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + system_error_on_fatal_error), + .propname = "fsps,system-error-on-fatal-error", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + system_error_on_fatal_error), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + system_error_on_non_fatal_error), + .propname = "fsps,system-error-on-non-fatal-error", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + system_error_on_non_fatal_error), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + system_error_on_correctable_error), + .propname = "fsps,system-error-on-correctable-error", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + system_error_on_correctable_error), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_speed), + .propname = "fsps,pcie-rp-speed", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_speed), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, physical_slot_number), + .propname = "fsps,physical-slot-number", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + physical_slot_number), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_completion_timeout), + .propname = "fsps,pcie-rp-completion-timeout", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_completion_timeout), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ptm_enable), + .propname = "fsps,ptm-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, ptm_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_aspm), + .propname = "fsps,pcie-rp-aspm", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_aspm), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_l1_substates), + .propname = "fsps,pcie-rp-l1-substates", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_l1_substates), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_ltr_enable), + .propname = "fsps,pcie-rp-ltr-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, pcie_rp_ltr_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_ltr_config_lock), + .propname = "fsps,pcie-rp-ltr-config-lock", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_ltr_config_lock), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pme_b0_s5_dis), + .propname = "fsps,pme-b0-s5-dis", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pci_clock_run), + .propname = "fsps,pci-clock-run", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, timer8254_clk_setting), + .propname = "fsps,timer8254-clk-setting", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, enable_sata), + .propname = "fsps,enable-sata", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_mode), + .propname = "fsps,sata-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_salp_support), + .propname = "fsps,sata-salp-support", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_pwr_opt_enable), + .propname = "fsps,sata-pwr-opt-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, e_sata_speed_limit), + .propname = "fsps,e-sata-speed-limit", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, speed_limit), + .propname = "fsps,speed-limit", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_enable), + .propname = "fsps,sata-ports-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_dev_slp), + .propname = "fsps,sata-ports-dev-slp", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_dev_slp), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_hot_plug), + .propname = "fsps,sata-ports-hot-plug", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_hot_plug), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_interlock_sw), + .propname = "fsps,sata-ports-interlock-sw", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + sata_ports_interlock_sw), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_external), + .propname = "fsps,sata-ports-external", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_external), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_spin_up), + .propname = "fsps,sata-ports-spin-up", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_spin_up), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_solid_state_drive), + .propname = "fsps,sata-ports-solid-state-drive", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + sata_ports_solid_state_drive), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_enable_dito_config), + .propname = "fsps,sata-ports-enable-dito-config", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + sata_ports_enable_dito_config), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_dm_val), + .propname = "fsps,sata-ports-dm-val", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_dm_val), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, sata_ports_dito_val), + .propname = "fsps,sata-ports-dito-val", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, sata_ports_dito_val), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, sub_system_vendor_id), + .propname = "fsps,sub-system-vendor-id", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, sub_system_id), + .propname = "fsps,sub-system-id", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, crid_settings), + .propname = "fsps,crid-settings", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, reset_select), + .propname = "fsps,reset-select", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sdcard_enabled), + .propname = "fsps,sdcard-enabled", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, e_mmc_enabled), + .propname = "fsps,e-mmc-enabled", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, e_mmc_host_max_speed), + .propname = "fsps,e-mmc-host-max-speed", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ufs_enabled), + .propname = "fsps,ufs-enabled", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sdio_enabled), + .propname = "fsps,sdio-enabled", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, gpp_lock), + .propname = "fsps,gpp-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sirq_enable), + .propname = "fsps,sirq-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sirq_mode), + .propname = "fsps,sirq-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, start_frame_pulse), + .propname = "fsps,start-frame-pulse", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, smbus_enable), + .propname = "fsps,smbus-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, arp_enable), + .propname = "fsps,arp-enable", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, num_rsvd_smbus_addresses), + .propname = "fsps,num-rsvd-smbus-addresses", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, rsvd_smbus_address_table), + .propname = "fsps,rsvd-smbus-address-table", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + rsvd_smbus_address_table), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, disable_compliance_mode), + .propname = "fsps,disable-compliance-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, usb_per_port_ctl), + .propname = "fsps,usb-per-port-ctl", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, usb30_mode), + .propname = "fsps,usb30-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_enable), + .propname = "fsps,port-usb20-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, port_usb20_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_us20b_over_current_pin), + .propname = "fsps,port-us20b-over-current-pin", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_us20b_over_current_pin), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, usb_otg), + .propname = "fsps,usb-otg", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hsic_support_enable), + .propname = "fsps,hsic-support-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb30_enable), + .propname = "fsps,port-usb30-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, port_usb30_enable), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_us30b_over_current_pin), + .propname = "fsps,port-us30b-over-current-pin", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_us30b_over_current_pin), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ssic_port_enable), + .propname = "fsps,ssic-port-enable", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, ssic_port_enable), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, dlane_pwr_gating), + .propname = "fsps,dlane-pwr-gating", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, vtd_enable), + .propname = "fsps,vtd-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, lock_down_global_smi), + .propname = "fsps,lock-down-global-smi", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, reset_wait_timer), + .propname = "fsps,reset-wait-timer", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, rtc_lock), + .propname = "fsps,rtc-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_test_mode), + .propname = "fsps,sata-test-mode", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, ssic_rate), + .propname = "fsps,ssic-rate", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, ssic_rate), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, dynamic_power_gating), + .propname = "fsps,dynamic-power-gating", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, pcie_rp_ltr_max_snoop_latency), + .propname = "fsps,pcie-rp-ltr-max-snoop-latency", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_ltr_max_snoop_latency), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_rp_snoop_latency_override_mode), + .propname = "fsps,pcie-rp-snoop-latency-override-mode", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_snoop_latency_override_mode), + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, + pcie_rp_snoop_latency_override_value), + .propname = "fsps,pcie-rp-snoop-latency-override-value", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_snoop_latency_override_value), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_rp_snoop_latency_override_multiplier), + .propname = "fsps,pcie-rp-snoop-latency-override-multiplier", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_snoop_latency_override_multiplier), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, skip_mp_init), + .propname = "fsps,skip-mp-init", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, dci_auto_detect), + .propname = "fsps,dci-auto-detect", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, + pcie_rp_ltr_max_non_snoop_latency), + .propname = "fsps,pcie-rp-ltr-max-non-snoop-latency", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_ltr_max_non_snoop_latency), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_mode), + .propname = "fsps,pcie-rp-non-snoop-latency-override-mode", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_mode), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, tco_timer_halt_lock), + .propname = "fsps,tco-timer-halt-lock", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pwr_btn_override_period), + .propname = "fsps,pwr-btn-override-period", + }, + { + .type = FSP_UINT16, + .offset = offsetof(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_value), + .propname = "fsps,pcie-rp-non-snoop-latency-override-value", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_value), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_multiplier), + .propname = "fsps,pcie-rp-non-snoop-latency-override-multiplier", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_non_snoop_latency_override_multiplier), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_slot_power_limit_scale), + .propname = "fsps,pcie-rp-slot-power-limit-scale", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_slot_power_limit_scale), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_slot_power_limit_value), + .propname = "fsps,pcie-rp-slot-power-limit-value", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_slot_power_limit_value), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, disable_native_power_button), + .propname = "fsps,disable-native-power-button", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, power_butter_debounce_mode), + .propname = "fsps,power-butter-debounce-mode", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdio_tx_cmd_cntl), + .propname = "fsps,sdio-tx-cmd-cntl", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdio_tx_data_cntl1), + .propname = "fsps,sdio-tx-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdio_tx_data_cntl2), + .propname = "fsps,sdio-tx-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdio_rx_cmd_data_cntl1), + .propname = "fsps,sdio-rx-cmd-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdio_rx_cmd_data_cntl2), + .propname = "fsps,sdio-rx-cmd-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_tx_cmd_cntl), + .propname = "fsps,sdcard-tx-cmd-cntl", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_tx_data_cntl1), + .propname = "fsps,sdcard-tx-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_tx_data_cntl2), + .propname = "fsps,sdcard-tx-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_rx_cmd_data_cntl1), + .propname = "fsps,sdcard-rx-cmd-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_rx_strobe_cntl), + .propname = "fsps,sdcard-rx-strobe-cntl", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, sdcard_rx_cmd_data_cntl2), + .propname = "fsps,sdcard-rx-cmd-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_tx_cmd_cntl), + .propname = "fsps,emmc-tx-cmd-cntl", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_tx_data_cntl1), + .propname = "fsps,emmc-tx-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_tx_data_cntl2), + .propname = "fsps,emmc-tx-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_rx_cmd_data_cntl1), + .propname = "fsps,emmc-rx-cmd-data-cntl1", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_rx_strobe_cntl), + .propname = "fsps,emmc-rx-strobe-cntl", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_rx_cmd_data_cntl2), + .propname = "fsps,emmc-rx-cmd-data-cntl2", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, emmc_master_sw_cntl), + .propname = "fsps,emmc-master-sw-cntl", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, pcie_rp_selectable_deemphasis), + .propname = "fsps,pcie-rp-selectable-deemphasis", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + pcie_rp_selectable_deemphasis), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, monitor_mwait_enable), + .propname = "fsps,monitor-mwait-enable", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, hd_audio_dsp_uaa_compliance), + .propname = "fsps,hd-audio-dsp-uaa-compliance", + }, + { + .type = FSP_UINT32, + .offset = offsetof(struct fsp_s_config, ipc), + .propname = "fsps,ipc", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, ipc), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, sata_ports_disable_dynamic_pg), + .propname = "fsps,sata-ports-disable-dynamic-pg", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + sata_ports_disable_dynamic_pg), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, init_s3_cpu), + .propname = "fsps,init-s3-cpu", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, skip_punit_init), + .propname = "fsps,skip-punit-init", + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_per_port_tx_pe_half), + .propname = "fsps,port-usb20-per-port-tx-pe-half", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_per_port_tx_pe_half), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_per_port_pe_txi_set), + .propname = "fsps,port-usb20-per-port-pe-txi-set", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_per_port_pe_txi_set), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_per_port_txi_set), + .propname = "fsps,port-usb20-per-port-txi-set", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_per_port_txi_set), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_hs_skew_sel), + .propname = "fsps,port-usb20-hs-skew-sel", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_hs_skew_sel), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + port_usb20_i_usb_tx_emphasis_en), + .propname = "fsps,port-usb20-i-usb-tx-emphasis-en", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_i_usb_tx_emphasis_en), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, + port_usb20_per_port_rxi_set), + .propname = "fsps,port-usb20-per-port-rxi-set", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_per_port_rxi_set), + }, + { + .type = FSP_UINT8, + .offset = offsetof(struct fsp_s_config, port_usb20_hs_npre_drv_sel), + .propname = "fsps,port-usb20-hs-npre-drv-sel", + .count = ARRAY_SIZE_OF_MEMBER(struct fsp_s_config, + port_usb20_hs_npre_drv_sel), + }, + { + .propname = NULL + } +}; + +void fsp_s_update_config_from_dtb(ofnode node, struct fsp_s_config *cfg) +{ + fsp_update_config_from_dtb(node, (u8 *)cfg, fsp_s_bindings); +} +#endif diff --git a/arch/x86/cpu/apollolake/fsp_m.c b/arch/x86/cpu/apollolake/fsp_m.c index 5308af8ed4..2e63062102 100644 --- a/arch/x86/cpu/apollolake/fsp_m.c +++ b/arch/x86/cpu/apollolake/fsp_m.c @@ -9,180 +9,28 @@ #include <asm/arch/iomap.h> #include <asm/arch/fsp/fsp_configs.h> #include <asm/arch/fsp/fsp_m_upd.h> +#include <asm/arch/fsp_bindings.h> #include <asm/fsp2/fsp_internal.h> #include <dm/uclass-internal.h>
-/* - * ODT settings: - * If ODT PIN to LP4 DRAM is pulled HIGH for ODT_A and HIGH for ODT_B, - * choose ODT_A_B_HIGH_HIGH. If ODT PIN to LP4 DRAM is pulled HIGH for ODT_A - * and LOW for ODT_B, choose ODT_A_B_HIGH_LOW. - * - * Note that the enum values correspond to the interpreted UPD fields - * within Ch[3:0]_OdtConfig parameters. - */ -enum { - ODT_A_B_HIGH_LOW = 0 << 1, - ODT_A_B_HIGH_HIGH = 1 << 1, - N_WR_24 = 1 << 5, -}; - -/* - * LPDDR4 helper routines for configuring the memory UPD for LPDDR4 operation. - * There are four physical LPDDR4 channels, each 32-bits wide. There are two - * logical channels using two physical channels together to form a 64-bit - * interface to memory for each logical channel. - */ - -enum { - LP4_PHYS_CH0A, - LP4_PHYS_CH0B, - LP4_PHYS_CH1A, - LP4_PHYS_CH1B, - - LP4_NUM_PHYS_CHANNELS, -}; - -/* - * The DQs within a physical channel can be bit-swizzled within each byte. - * Within a channel the bytes can be swapped, but the DQs need to be routed - * with the corresponding DQS (strobe). - */ -enum { - LP4_DQS0, - LP4_DQS1, - LP4_DQS2, - LP4_DQS3, - - LP4_NUM_BYTE_LANES, - DQ_BITS_PER_DQS = 8, -}; - -/* Provide bit swizzling per DQS and byte swapping within a channel */ -struct lpddr4_chan_swizzle_cfg { - u8 dqs[LP4_NUM_BYTE_LANES][DQ_BITS_PER_DQS]; -}; - -struct lpddr4_swizzle_cfg { - struct lpddr4_chan_swizzle_cfg phys[LP4_NUM_PHYS_CHANNELS]; -}; - -static void setup_sdram(struct fsp_m_config *cfg, - const struct lpddr4_swizzle_cfg *swizzle_cfg) -{ - const struct lpddr4_chan_swizzle_cfg *sch; - /* Number of bytes to copy per DQS */ - const size_t sz = DQ_BITS_PER_DQS; - int chan; - - cfg->memory_down = 1; - cfg->scrambler_support = 1; - cfg->channel_hash_mask = 0x36; - cfg->slice_hash_mask = 9; - cfg->interleaved_mode = 2; - cfg->channels_slices_enable = 0; - cfg->min_ref_rate2x_enable = 0; - cfg->dual_rank_support_enable = 1; - - /* LPDDR4 is memory down so no SPD addresses */ - cfg->dimm0_spd_address = 0; - cfg->dimm1_spd_address = 0; - - for (chan = 0; chan < 4; chan++) { - struct fsp_ram_channel *ch = &cfg->chan[chan]; - - ch->rank_enable = 1; - ch->device_width = 1; - ch->dram_density = 2; - ch->option = 3; - ch->odt_config = ODT_A_B_HIGH_HIGH; - } - - /* - * CH0_DQB byte lanes in the bit swizzle configuration field are - * not 1:1. The mapping within the swizzling field is: - * indices [0:7] - byte lane 1 (DQS1) DQ[8:15] - * indices [8:15] - byte lane 0 (DQS0) DQ[0:7] - * indices [16:23] - byte lane 3 (DQS3) DQ[24:31] - * indices [24:31] - byte lane 2 (DQS2) DQ[16:23] - */ - sch = &swizzle_cfg->phys[LP4_PHYS_CH0B]; - memcpy(&cfg->ch_bit_swizzling[0][0], &sch->dqs[LP4_DQS1], sz); - memcpy(&cfg->ch_bit_swizzling[0][8], &sch->dqs[LP4_DQS0], sz); - memcpy(&cfg->ch_bit_swizzling[0][16], &sch->dqs[LP4_DQS3], sz); - memcpy(&cfg->ch_bit_swizzling[0][24], &sch->dqs[LP4_DQS2], sz); - - /* - * CH0_DQA byte lanes in the bit swizzle configuration field are 1:1. - */ - sch = &swizzle_cfg->phys[LP4_PHYS_CH0A]; - memcpy(&cfg->ch_bit_swizzling[1][0], &sch->dqs[LP4_DQS0], sz); - memcpy(&cfg->ch_bit_swizzling[1][8], &sch->dqs[LP4_DQS1], sz); - memcpy(&cfg->ch_bit_swizzling[1][16], &sch->dqs[LP4_DQS2], sz); - memcpy(&cfg->ch_bit_swizzling[1][24], &sch->dqs[LP4_DQS3], sz); - - sch = &swizzle_cfg->phys[LP4_PHYS_CH1B]; - memcpy(&cfg->ch_bit_swizzling[2][0], &sch->dqs[LP4_DQS1], sz); - memcpy(&cfg->ch_bit_swizzling[2][8], &sch->dqs[LP4_DQS0], sz); - memcpy(&cfg->ch_bit_swizzling[2][16], &sch->dqs[LP4_DQS3], sz); - memcpy(&cfg->ch_bit_swizzling[2][24], &sch->dqs[LP4_DQS2], sz); - - /* - * CH0_DQA byte lanes in the bit swizzle configuration field are 1:1. - */ - sch = &swizzle_cfg->phys[LP4_PHYS_CH1A]; - memcpy(&cfg->ch_bit_swizzling[3][0], &sch->dqs[LP4_DQS0], sz); - memcpy(&cfg->ch_bit_swizzling[3][8], &sch->dqs[LP4_DQS1], sz); - memcpy(&cfg->ch_bit_swizzling[3][16], &sch->dqs[LP4_DQS2], sz); - memcpy(&cfg->ch_bit_swizzling[3][24], &sch->dqs[LP4_DQS3], sz); -}
int fspm_update_config(struct udevice *dev, struct fspm_upd *upd) { struct fsp_m_config *cfg = &upd->config; struct fspm_arch_upd *arch = &upd->arch; + ofnode node;
arch->nvs_buffer_ptr = NULL; prepare_mrc_cache(upd); arch->stack_base = (void *)0xfef96000; arch->boot_loader_tolum_size = 0; - arch->boot_mode = FSP_BOOT_WITH_FULL_CONFIGURATION; - cfg->serial_debug_port_type = 2; - cfg->serial_debug_port_device = 2; - cfg->serial_debug_port_stride_size = 2; - cfg->serial_debug_port_address = 0; - - cfg->package = 1; - /* Don't enforce a memory size limit */ - cfg->memory_size_limit = 0; - cfg->low_memory_max_value = 2048; /* 2 GB */ - /* No restrictions on memory above 4GiB */ - cfg->high_memory_max_value = 0; - - /* Always default to attempt to use saved training data */ - cfg->disable_fast_boot = 0; - - const u8 *swizzle_data; - - swizzle_data = dev_read_u8_array_ptr(dev, "lpddr4-swizzle", - LP4_NUM_BYTE_LANES * - DQ_BITS_PER_DQS * - LP4_NUM_PHYS_CHANNELS); - if (!swizzle_data) - return log_msg_ret("Cannot read swizzel data", -EINVAL); - - setup_sdram(cfg, (struct lpddr4_swizzle_cfg *)swizzle_data); - - cfg->pre_mem_gpio_table_ptr = 0;
- cfg->profile = 0xb; - cfg->msg_level_mask = 0; + node = dev_ofnode(dev); + if (!ofnode_valid(node)) + return log_msg_ret("fsp-m settings", -ENOENT);
- /* other */ - cfg->skip_cse_rbp = 1; - cfg->periodic_retraining_disable = 0; - cfg->enable_s3_heci2 = 0; + fsp_m_update_config_from_dtb(node, cfg);
return 0; } diff --git a/arch/x86/cpu/apollolake/fsp_s.c b/arch/x86/cpu/apollolake/fsp_s.c index 8f1d6f3008..b17d7c6abe 100644 --- a/arch/x86/cpu/apollolake/fsp_s.c +++ b/arch/x86/cpu/apollolake/fsp_s.c @@ -20,313 +20,17 @@ #include <asm/arch/systemagent.h> #include <asm/arch/fsp/fsp_configs.h> #include <asm/arch/fsp/fsp_s_upd.h> +#include <asm/arch/fsp_bindings.h>
#define PCH_P2SB_E0 0xe0 #define HIDE_BIT BIT(0)
-#define INTEL_GSPI_MAX 3 -#define MAX_USB2_PORTS 8 - -enum { - CHIPSET_LOCKDOWN_FSP = 0, /* FSP handles locking per UPDs */ - CHIPSET_LOCKDOWN_COREBOOT, /* coreboot handles locking */ -}; - -/* Serial IRQ control. SERIRQ_QUIET is the default (0) */ -enum serirq_mode { - SERIRQ_QUIET, - SERIRQ_CONTINUOUS, - SERIRQ_OFF, -}; - -struct gspi_cfg { - /* Bus speed in MHz */ - u32 speed_mhz; - /* Bus should be enabled prior to ramstage with temporary base */ - u8 early_init; -}; - -/* - * This structure will hold data required by common blocks. - * These are soc specific configurations which will be filled by soc. - * We'll fill this structure once during init and use the data in common block. - */ -struct soc_intel_common_config { - int chipset_lockdown; - struct gspi_cfg gspi[INTEL_GSPI_MAX]; -}; - -enum pnp_settings { - PNP_PERF, - PNP_POWER, - PNP_PERF_POWER, -}; - -struct usb2_eye_per_port { - u8 per_port_tx_pe_half; - u8 per_port_pe_txi_set; - u8 per_port_txi_set; - u8 hs_skew_sel; - u8 usb_tx_emphasis_en; - u8 per_port_rxi_set; - u8 hs_npre_drv_sel; - u8 override_en; -}; - -struct apl_config { - /* Common structure containing soc config data required by common code*/ - struct soc_intel_common_config common_soc_config; - - /* - * Mapping from PCIe root port to CLKREQ input on the SOC. The SOC has - * four CLKREQ inputs, but six root ports. Root ports without an - * associated CLKREQ signal must be marked with "CLKREQ_DISABLED" - */ - u8 pcie_rp_clkreq_pin[MAX_PCIE_PORTS]; - - /* Enable/disable hot-plug for root ports (0 = disable, 1 = enable) */ - u8 pcie_rp_hotplug_enable[MAX_PCIE_PORTS]; - - /* De-emphasis enable configuration for each PCIe root port */ - u8 pcie_rp_deemphasis_enable[MAX_PCIE_PORTS]; - - /* - * [14:8] DDR mode Number of dealy elements.Each = 125pSec. - * [6:0] SDR mode Number of dealy elements.Each = 125pSec. - */ - u32 emmc_tx_cmd_cntl; - - /* - * [14:8] HS400 mode Number of dealy elements.Each = 125pSec. - * [6:0] SDR104/HS200 mode Number of dealy elements.Each = 125pSec. - */ - u32 emmc_tx_data_cntl1; - - /* - * [30:24] SDR50 mode Number of dealy elements.Each = 125pSec. - * [22:16] DDR50 mode Number of dealy elements.Each = 125pSec. - * [14:8] SDR25/HS50 mode Number of dealy elements.Each = 125pSec. - * [6:0] SDR12/Compatibility mode Number of dealy elements. - * Each = 125pSec. - */ - u32 emmc_tx_data_cntl2; - - /* - * [30:24] SDR50 mode Number of dealy elements.Each = 125pSec. - * [22:16] DDR50 mode Number of dealy elements.Each = 125pSec. - * [14:8] SDR25/HS50 mode Number of dealy elements.Each = 125pSec. - * [6:0] SDR12/Compatibility mode Number of dealy elements. - * Each = 125pSec. - */ - u32 emmc_rx_cmd_data_cntl1; - - /* - * [14:8] HS400 mode 1 Number of dealy elements.Each = 125pSec. - * [6:0] HS400 mode 2 Number of dealy elements.Each = 125pSec. - */ - u32 emmc_rx_strobe_cntl; - - /* - * [13:8] Auto Tuning mode Number of dealy elements.Each = 125pSec. - * [6:0] SDR104/HS200 Number of dealy elements.Each = 125pSec. - */ - u32 emmc_rx_cmd_data_cntl2; - - /* Select the eMMC max speed allowed */ - u32 emmc_host_max_speed; - - /* Specifies on which IRQ the SCI will internally appear */ - u32 sci_irq; - - /* Configure serial IRQ (SERIRQ) line */ - enum serirq_mode serirq_mode; - - /* Configure LPSS S0ix Enable */ - bool lpss_s0ix_enable; - - /* Enable DPTF support */ - bool dptf_enable; - - /* TCC activation offset value in degrees Celsius */ - int tcc_offset; - - /* - * Configure Audio clk gate and power gate - * IOSF-SB port ID 92 offset 0x530 [5] and [3] - */ - bool hdaudio_clk_gate_enable; - bool hdaudio_pwr_gate_enable; - bool hdaudio_bios_config_lockdown; - - /* SLP S3 minimum assertion width */ - int slp_s3_assertion_width_usecs; - - /* GPIO pin for PERST_0 */ - u32 prt0_gpio; - - /* USB2 eye diagram settings per port */ - struct usb2_eye_per_port usb2eye[MAX_USB2_PORTS]; - - /* GPIO SD card detect pin */ - unsigned int sdcard_cd_gpio; - - /* - * PRMRR size setting with three options - * 0x02000000 - 32MiB - * 0x04000000 - 64MiB - * 0x08000000 - 128MiB - */ - u32 PrmrrSize; - - /* - * Enable SGX feature. - * Enabling SGX feature is 2 step process, - * (1) set sgx_enable = 1 - * (2) set PrmrrSize to supported size - */ - bool sgx_enable; - - /* - * Select PNP Settings. - * (0) Performance, - * (1) Power - * (2) Power & Performance - */ - enum pnp_settings pnp_settings; - - /* - * PMIC PCH_PWROK delay configuration - IPC Configuration - * Upd for changing PCH_PWROK delay configuration : I2C_Slave_Address - * (31:24) + Register_Offset (23:16) + OR Value (15:8) + AND Value (7:0) - */ - u32 pmic_pmc_ipc_ctrl; - - /* - * Options to disable XHCI Link Compliance Mode. Default is FALSE to not - * disable Compliance Mode. Set TRUE to disable Compliance Mode. - * 0:FALSE(Default), 1:True. - */ - bool disable_compliance_mode; - - /* - * Options to change USB3 ModPhy setting for the Integrated Filter (IF) - * value. Default is 0 to not changing default IF value (0x12). Set - * value with the range from 0x01 to 0xff to change IF value. - */ - u32 mod_phy_if_value; - - /* - * Options to bump USB3 LDO voltage. Default is FALSE to not increasing - * LDO voltage. Set TRUE to increase LDO voltage with 40mV. - * 0:FALSE (default), 1:True. - */ - bool mod_phy_voltage_bump; - - /* - * Options to adjust PMIC Vdd2 voltage. Default is 0 to not adjusting - * the PMIC Vdd2 default voltage 1.20v. Upd for changing Vdd2 Voltage - * configuration: I2C_Slave_Address (31:23) + Register_Offset (23:16) - * + OR Value (15:8) + AND Value (7:0) through BUCK5_VID[3:2]: - * 00=1.10v, 01=1.15v, 10=1.24v, 11=1.20v (default). - */ - u32 pmic_vdd2_voltage; - - /* Option to enable VTD feature */ - bool enable_vtd; -}; - -static int get_config(struct udevice *dev, struct apl_config *apl) -{ - const u8 *ptr; - ofnode node; - u32 emmc[4]; - int ret; - - memset(apl, '\0', sizeof(*apl)); - - node = dev_read_subnode(dev, "fsp-s"); - if (!ofnode_valid(node)) - return log_msg_ret("fsp-s settings", -ENOENT); - - ptr = ofnode_read_u8_array_ptr(node, "pcie-rp-clkreq-pin", - MAX_PCIE_PORTS); - if (!ptr) - return log_msg_ret("pcie-rp-clkreq-pin", -EINVAL); - memcpy(apl->pcie_rp_clkreq_pin, ptr, MAX_PCIE_PORTS); - - ret = ofnode_read_u32(node, "prt0-gpio", &apl->prt0_gpio); - if (ret) - return log_msg_ret("prt0-gpio", ret); - ret = ofnode_read_u32(node, "sdcard-cd-gpio", &apl->sdcard_cd_gpio); - if (ret) - return log_msg_ret("sdcard-cd-gpio", ret); - - ret = ofnode_read_u32_array(node, "emmc", emmc, ARRAY_SIZE(emmc)); - if (ret) - return log_msg_ret("emmc", ret); - apl->emmc_tx_data_cntl1 = emmc[0]; - apl->emmc_tx_data_cntl2 = emmc[1]; - apl->emmc_rx_cmd_data_cntl1 = emmc[2]; - apl->emmc_rx_cmd_data_cntl2 = emmc[3]; - - apl->dptf_enable = ofnode_read_bool(node, "dptf-enable"); - - apl->hdaudio_clk_gate_enable = ofnode_read_bool(node, - "hdaudio-clk-gate-enable"); - apl->hdaudio_pwr_gate_enable = ofnode_read_bool(node, - "hdaudio-pwr-gate-enable"); - apl->hdaudio_bios_config_lockdown = ofnode_read_bool(node, - "hdaudio-bios-config-lockdown"); - apl->lpss_s0ix_enable = ofnode_read_bool(node, "lpss-s0ix-enable"); - - /* Santa */ - apl->usb2eye[1].per_port_pe_txi_set = 7; - apl->usb2eye[1].per_port_txi_set = 2; - - return 0; -} - -static void apl_fsp_silicon_init_params_cb(struct apl_config *apl, - struct fsp_s_config *cfg) -{ - u8 port; - - for (port = 0; port < MAX_USB2_PORTS; port++) { - if (apl->usb2eye[port].per_port_tx_pe_half) - cfg->port_usb20_per_port_tx_pe_half[port] = - apl->usb2eye[port].per_port_tx_pe_half; - - if (apl->usb2eye[port].per_port_pe_txi_set) - cfg->port_usb20_per_port_pe_txi_set[port] = - apl->usb2eye[port].per_port_pe_txi_set; - - if (apl->usb2eye[port].per_port_txi_set) - cfg->port_usb20_per_port_txi_set[port] = - apl->usb2eye[port].per_port_txi_set; - - if (apl->usb2eye[port].hs_skew_sel) - cfg->port_usb20_hs_skew_sel[port] = - apl->usb2eye[port].hs_skew_sel; - - if (apl->usb2eye[port].usb_tx_emphasis_en) - cfg->port_usb20_i_usb_tx_emphasis_en[port] = - apl->usb2eye[port].usb_tx_emphasis_en; - - if (apl->usb2eye[port].per_port_rxi_set) - cfg->port_usb20_per_port_rxi_set[port] = - apl->usb2eye[port].per_port_rxi_set; - - if (apl->usb2eye[port].hs_npre_drv_sel) - cfg->port_usb20_hs_npre_drv_sel[port] = - apl->usb2eye[port].hs_npre_drv_sel; - } -} - int fsps_update_config(struct udevice *dev, ulong rom_offset, struct fsps_upd *upd) { struct fsp_s_config *cfg = &upd->config; - struct apl_config *apl; + ofnode node; + #ifdef CONFIG_HAVE_VBT struct binman_entry vbt; void *vbt_buf; @@ -353,81 +57,11 @@ int fsps_update_config(struct udevice *dev, ulong rom_offset, cfg->graphics_config_ptr = (ulong)vbt_buf; #endif
- cfg->ish_enable = 0; - cfg->enable_sata = 0; - cfg->pcie_root_port_en[2] = 0; - cfg->pcie_rp_hot_plug[2] = 0; - cfg->pcie_root_port_en[3] = 0; - cfg->pcie_rp_hot_plug[3] = 0; - cfg->pcie_root_port_en[4] = 0; - cfg->pcie_rp_hot_plug[4] = 0; - cfg->pcie_root_port_en[5] = 0; - cfg->pcie_rp_hot_plug[5] = 0; - cfg->pcie_root_port_en[1] = 0; - cfg->pcie_rp_hot_plug[1] = 0; - cfg->usb_otg = 0; - cfg->i2c6_enable = 0; - cfg->i2c7_enable = 0; - cfg->hsuart3_enable = 0; - cfg->spi1_enable = 0; - cfg->spi2_enable = 0; - cfg->sdio_enabled = 0; - - memcpy(cfg->pcie_rp_clk_req_number, apl->pcie_rp_clkreq_pin, - sizeof(cfg->pcie_rp_clk_req_number)); - - memcpy(cfg->pcie_rp_hot_plug, apl->pcie_rp_hotplug_enable, - sizeof(cfg->pcie_rp_hot_plug)); - - switch (apl->serirq_mode) { - case SERIRQ_QUIET: - cfg->sirq_enable = 1; - cfg->sirq_mode = 0; - break; - case SERIRQ_CONTINUOUS: - cfg->sirq_enable = 1; - cfg->sirq_mode = 1; - break; - case SERIRQ_OFF: - default: - cfg->sirq_enable = 0; - break; - } - - if (apl->emmc_tx_cmd_cntl) - cfg->emmc_tx_cmd_cntl = apl->emmc_tx_cmd_cntl; - if (apl->emmc_tx_data_cntl1) - cfg->emmc_tx_data_cntl1 = apl->emmc_tx_data_cntl1; - if (apl->emmc_tx_data_cntl2) - cfg->emmc_tx_data_cntl2 = apl->emmc_tx_data_cntl2; - if (apl->emmc_rx_cmd_data_cntl1) - cfg->emmc_rx_cmd_data_cntl1 = apl->emmc_rx_cmd_data_cntl1; - if (apl->emmc_rx_strobe_cntl) - cfg->emmc_rx_strobe_cntl = apl->emmc_rx_strobe_cntl; - if (apl->emmc_rx_cmd_data_cntl2) - cfg->emmc_rx_cmd_data_cntl2 = apl->emmc_rx_cmd_data_cntl2; - if (apl->emmc_host_max_speed) - cfg->e_mmc_host_max_speed = apl->emmc_host_max_speed; - - cfg->lpss_s0ix_enable = apl->lpss_s0ix_enable; - - cfg->skip_mp_init = true; - - /* Disable setting of EISS bit in FSP */ - cfg->spi_eiss = 0; - - /* Disable FSP from locking access to the RTC NVRAM */ - cfg->rtc_lock = 0; - - /* Enable Audio clk gate and power gate */ - cfg->hd_audio_clk_gate = apl->hdaudio_clk_gate_enable; - cfg->hd_audio_pwr_gate = apl->hdaudio_pwr_gate_enable; - /* Bios config lockdown Audio clk and power gate */ - cfg->bios_cfg_lock_down = apl->hdaudio_bios_config_lockdown; - apl_fsp_silicon_init_params_cb(apl, cfg); - - cfg->usb_otg = true; - cfg->vtd_enable = apl->enable_vtd; + node = dev_read_subnode(dev, "fsp-s"); + if (!ofnode_valid(node)) + return log_msg_ret("fsp-s settings", -ENOENT); + + fsp_s_update_config_from_dtb(node, cfg);
return 0; } diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index d48ef3573e..2eb76a4c4e 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -21,6 +21,8 @@ #include <asm/arch-apollolake/iomap.h> #include <asm/arch-apollolake/pm.h> #include <dt-bindings/clock/intel-clock.h> +#include <asm/arch-apollolake/fsp/fsp_m_upd.h> +#include <asm/arch-apollolake/fsp/fsp_s_upd.h>
/ { model = "Google Coral"; @@ -436,7 +438,41 @@ PAD_CFG_NF(LPC_FRAMEB, NATIVE, DEEP, NF1) /* LPC_FRAME_N */ >;
- lpddr4-swizzle = /bits/ 8 < + fspm,package = <PACKAGE_BGA>; + fspm,profile = <PROFILE_LPDDR4_2400_24_22_22>; + fspm,memory-down = <MEMORY_DOWN_YES>; + fspm,scrambler-support = <1>; + fspm,interleaved-mode = <INTERLEAVED_MODE_ENABLE>; + fspm,channel-hash-mask = <0x36>; + fspm,slice-hash-mask = <0x9>; + fspm,low-memory-max-value = <2048>; + fspm,ch0-rank-enable = <1>; + fspm,ch0-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch0-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch0-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch0-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch1-rank-enable = <1>; + fspm,ch1-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch1-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch1-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch1-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch2-rank-enable = <1>; + fspm,ch2-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch2-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch2-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch2-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch3-rank-enable = <1>; + fspm,ch3-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch3-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch3-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch3-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,fspm,skip-cse-rbp = <1>; + + fspm,ch-bit-swizzling = /bits/ 8 < /* LP4_PHYS_CH0A */
/* DQA[0:7] pins of LPDDR4 module */ @@ -484,8 +520,19 @@ &fsp_s { u-boot,dm-pre-proper;
+ fsps,ish-enable = <0>; + fsps,enable-sata = <0>; + fsps,pcie-root-port-en = [00 00 00 00 00 01]; + fsps,pcie-rp-hot-plug = [00 00 00 00 00 01]; + fsps,i2c6-enable = <I2CX_ENABLE_DISABLED>; + fsps,i2c7-enable = <I2CX_ENABLE_DISABLED>; + fsps,hsuart3-enable = <HSUARTX_ENABLE_DISABLED>; + fsps,spi1-enable = <SPIX_ENABLE_DISABLED>; + fsps,spi2-enable = <SPIX_ENABLE_DISABLED>; + fsps,sdio-enabled = <0>; + /* Disable unused clkreq of PCIe root ports */ - pcie-rp-clkreq-pin = /bits/ 8 <0 /* wifi/bt */ + fsps,pcie-rp-clk-req-number = /bits/ 8 <0 /* wifi/bt */ CLKREQ_DISABLED CLKREQ_DISABLED CLKREQ_DISABLED @@ -539,18 +586,27 @@ * [14:8] steps of delay for Auto Tuning Mode, each 125ps * [6:0] steps of delay for HS200, each 125ps */ - emmc = <0x0c16 0x28162828 0x00181717 0x10008>; - /* Enable DPTF */ dptf-enable; + fsps,emmc-tx-data-cntl1 = <0x0c16>; + fsps,emmc-tx-data-cntl2 = <0x28162828>; + fsps,emmc-rx-cmd-data-cntl1 = <0x00181717>; + fsps,emmc-rx-cmd-data-cntl2 = <0x10008>;
/* Enable Audio Clock and Power gating */ - hdaudio-clk-gate-enable; - hdaudio-pwr-gate-enable; - hdaudio-bios-config-lockdown; + fsps,hd-audio-clk-gate = <1>; + fsps,hd-audio-pwr-gate = <1>; + fsps,bios-cfg-lock-down = <1>;
/* Enable lpss s0ix */ - lpss-s0ix-enable; + fsps,lpss-s0ix-enable = <1>; + + fsps,skip-mp-init = <1>; + fsps,spi-eiss = <0>; + fsps,rtc-lock = <0>; + + fsps,port-usb20-per-port-pe-txi-set = [07 07 06 06 07 07 07 01]; + fsps,port-usb20-per-port-txi-set = [00 02 00 00 00 00 00 03];
/* * TODO(sjg@chromium.org): Move this to the I2C nodes diff --git a/arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h b/arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h index 93bee5b2d1..a77964f30c 100644 --- a/arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h +++ b/arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h @@ -7,6 +7,7 @@ #ifndef __ASM_ARCH_FSP_M_UDP_H #define __ASM_ARCH_FSP_M_UDP_H
+#ifndef __ASSEMBLY__ #include <asm/fsp2/fsp_api.h>
#define FSP_DRAM_CHANNELS 4 @@ -119,5 +120,172 @@ struct __packed fspm_upd { u8 unused_upd_space2[158]; u16 upd_terminator; }; +#endif + +#define SERIAL_DEBUG_PORT_TYPE_NONE 0 +#define SERIAL_DEBUG_PORT_TYPE_IO 1 +#define SERIAL_DEBUG_PORT_TYPE_MMIO 2 + +#define SERIAL_DEBUG_PORT_DEVICE_UART0 0 +#define SERIAL_DEBUG_PORT_DEVICE_UART1 1 +#define SERIAL_DEBUG_PORT_DEVICE_UART2 2 +#define SERIAL_DEBUG_PORT_DEVICE_EXTERNAL 3 + +#define SERIAL_DEBUG_PORT_STRIDE_SIZE_1 0 +#define SERIAL_DEBUG_PORT_STRIDE_SIZE_4 2 + +#define IGD_DVMT_50_PRE_ALLOC_64M 0x02 +#define IGD_DVMT_50_PRE_ALLOC_96M 0x03 +#define IGD_DVMT_50_PRE_ALLOC_128M 0x04 +#define IGD_DVMT_50_PRE_ALLOC_160M 0x05 +#define IGD_DVMT_50_PRE_ALLOC_192M 0x06 +#define IGD_DVMT_50_PRE_ALLOC_224M 0x07 +#define IGD_DVMT_50_PRE_ALLOC_256M 0x08 +#define IGD_DVMT_50_PRE_ALLOC_288M 0x09 +#define IGD_DVMT_50_PRE_ALLOC_320M 0x0a +#define IGD_DVMT_50_PRE_ALLOC_352M 0x0b +#define IGD_DVMT_50_PRE_ALLOC_384M 0x0c +#define IGD_DVMT_50_PRE_ALLOC_416M 0x0d +#define IGD_DVMT_50_PRE_ALLOC_448M 0x0e +#define IGD_DVMT_50_PRE_ALLOC_480M 0x0f +#define IGD_DVMT_50_PRE_ALLOC_512M 0x10 + +#define IGD_APERTURE_SIZE_128M 0x1 +#define IGD_APERTURE_SIZE_256M 0x2 +#define IGD_APERTURE_SIZE_512M 0x3 + +#define GTT_SIZE_2M 1 +#define GTT_SIZE_4M 2 +#define GTT_SIZE_8M 3 + +#define PRIMARY_VIDEO_ADAPTER_AUTO 0 +#define PRIMARY_VIDEO_ADAPTER_IGD 2 +#define PRIMARY_VIDEO_ADAPTER_PCI 3 + +#define PACKAGE_SODIMM 0 +#define PACKAGE_BGA 1 +#define PACKAGE_BGA_MIRRORED 2 +#define PACKAGE_SODIMM_UDIMM_RANK_MIRRORED 3 + +#define PROFILE_WIO2_800_7_8_8 0x1 +#define PROFILE_WIO2_1066_9_10_10 0x2 +#define PROFILE_LPDDR3_1066_8_10_10 0x3 +#define PROFILE_LPDDR3_1333_10_12_12 0x4 +#define PROFILE_LPDDR3_1600_12_15_15 0x5 +#define PROFILE_LPDDR3_1866_14_17_17 0x6 +#define PROFILE_LPDDR3_2133_16_20_20 0x7 +#define PROFILE_LPDDR4_1066_10_10_10 0x8 +#define PROFILE_LPDDR4_1600_14_15_15 0x9 +#define PROFILE_LPDDR4_2133_20_20_20 0xa +#define PROFILE_LPDDR4_2400_24_22_22 0xb +#define PROFILE_LPDDR4_2666_24_24_24 0xc +#define PROFILE_LPDDR4_2933_28_27_27 0xd +#define PROFILE_LPDDR4_3200_28_29_29 0xe +#define PROFILE_DDR3_1066_6_6_6 0xf +#define PROFILE_DDR3_1066_7_7_7 0x10 +#define PROFILE_DDR3_1066_8_8_8 0x11 +#define PROFILE_DDR3_1333_7_7_7 0x12 +#define PROFILE_DDR3_1333_8_8_8 0x13 +#define PROFILE_DDR3_1333_9_9_9 0x14 +#define PROFILE_DDR3_1333_10_10_10 0x15 +#define PROFILE_DDR3_1600_8_8_8 0x16 +#define PROFILE_DDR3_1600_9_9_9 0x17 +#define PROFILE_DDR3_1600_10_10_10 0x18 +#define PROFILE_DDR3_1600_11_11_11 0x19 +#define PROFILE_DDR3_1866_10_10_10 0x1a +#define PROFILE_DDR3_1866_11_11_11 0x1b +#define PROFILE_DDR3_1866_12_12_12 0x1c +#define PROFILE_DDR3_1866_13_13_13 0x1d +#define PROFILE_DDR3_2133_11_11_11 0x1e +#define PROFILE_DDR3_2133_12_12_12 0x1f +#define PROFILE_DDR3_2133_13_13_13 0x20 +#define PROFILE_DDR3_2133_14_14_14 0x21 +#define PROFILE_DDR4_1333_10_10_10 0x22 +#define PROFILE_DDR4_1600_10_10_10 0x23 +#define PROFILE_DDR4_1600_11_11_11 0x24 +#define PROFILE_DDR4_1600_12_12_12 0x25 +#define PROFILE_DDR4_1866_12_12_12 0x26 +#define PROFILE_DDR4_1866_13_13_13 0x27 +#define PROFILE_DDR4_1866_14_14_14 0x28 +#define PROFILE_DDR4_2133_14_14_14 0x29 +#define PROFILE_DDR4_2133_15_15_15 0x2a +#define PROFILE_DDR4_2133_16_16_16 0x2b +#define PROFILE_DDR4_2400_15_15_15 0x2c +#define PROFILE_DDR4_2400_16_16_16 0x2d +#define PROFILE_DDR4_2400_17_17_17 0x2e +#define PROFILE_DDR4_2400_18_18_18 0x2f + +#define MEMORY_DOWN_NO 0 +#define MEMORY_DOWN_YES 1 +#define MEMORY_DOWN_MD_SODIMM 2 +#define MEMORY_DOWN_LPDDR4 3 + +#define DDR3L_PAGE_SIZE_1KB 1 +#define DDR3L_PAGE_SIZE_2KB 2 + +#define INTERLEAVED_MODE_DISABLE 0 +#define INTERLEAVED_MODE_ENABLE 2 + +#define RMT_MODE_DISABLE 0 +#define RMT_MODE_ENABLE 3 + +#define CHX_DEVICE_WIDTH_X8 0 +#define CHX_DEVICE_WIDTH_X16 1 +#define CHX_DEVICE_WIDTH_X32 2 +#define CHX_DEVICE_WIDTH_X64 3 + +#define CHX_DEVICE_DENSITY_4GB 0 +#define CHX_DEVICE_DENSITY_6GB 1 +#define CHX_DEVICE_DENSITY_8GB 2 +#define CHX_DEVICE_DENSITY_12GB 3 +#define CHX_DEVICE_DENSITY_16GB 4 +#define CHX_DEVICE_DENSITY_2GB 5 + +#define CHX_OPTION_RANK_INTERLEAVING 0x1 +#define CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE 0x2 +#define CHX_OPTION_CH1_CLK_DISABLE 0x4 +#define CHX_OPTION_ADDRESS_MAP_2KB 0x10 + +#define CHX_ODT_CONFIG_DDR3_RX_ODT 0x1 +#define CHX_ODT_CONFIG_DDR4_CA_ODT 0x2 +#define CHX_ODT_CONFIG_DDR3L_TX_ODT 0x10 + +#define CHX_MODE2N_AUTO 0 +#define CHX_MODE2N_FORCE 1 + +#define CHX_ODT_LEVELS_CONNECTED_TO_SOC 0x0 +#define CHX_ODT_LEVELS_HELD_HIGH 0x1 + +#define NPK_EN_DISABLE 0 +#define NPK_EN_ENABLE 1 +#define NPK_EN_DEBUGGER 2 +#define NPK_EN_AUTO 3 + +#define FW_TRACE_DESTINATION_NPK_TRACE_TO_MEMORY 1 +#define FW_TRACE_DESTINATION_NPK_TRACE_TO_DCI 2 +#define FW_TRACE_DESTINATION_NPK_NPK_TRACE_TO_BSSB 3 +#define FW_TRACE_DESTINATION_NPK_TRACE_TO_PTI 4 + +#define MSC_X_WRAP_0 0 +#define MSC_X_WRAP_1 1 + +#define MSC_X_SIZE_0M 0 +#define MSC_X_SIZE_1M 1 +#define MSC_X_SIZE_8M 2 +#define MSC_X_SIZE_64M 3 +#define MSC_X_SIZE_128M 4 +#define MSC_X_SIZE_256M 5 +#define MSC_X_SIZE_512M 6 +#define MSC_X_SIZE_1GB 7 + +#define PTI_MODE_0 0 +#define PTI_MODE_x4 1 +#define PTI_MODE_x8 2 +#define PTI_MODE_x12 3 +#define PTI_MODE_x16 4 + +#define PTI_SPEED_FULL 0 +#define PTI_SPEED_HALF 1 +#define PTI_SPEED_QUARTER 2
#endif diff --git a/arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h b/arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h index 4a868e80ba..87596ffd9d 100644 --- a/arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h +++ b/arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h @@ -6,6 +6,7 @@ #ifndef __ASM_ARCH_FSP_S_UDP_H #define __ASM_ARCH_FSP_S_UDP_H
struct __packed fsp_s_config { @@ -288,5 +289,206 @@ struct __packed fsps_upd { u8 unused_upd_space2[46]; u16 upd_terminator; }; +#endif + +#define PROC_TRACE_MEM_SIZE_DISABLE 0xff + +#define BOOT_P_STATE_HFM 0 +#define BOOT_P_STATE_LFM 1 + +#define PKG_C_STATE_LIMIT_C0_C1 0 +#define PKG_C_STATE_LIMIT_C2 1 +#define PKG_C_STATE_LIMIT_C3 2 +#define PKG_C_STATE_LIMIT_C6 3 +#define PKG_C_STATE_LIMIT_C7 4 +#define PKG_C_STATE_LIMIT_C7S 5 +#define PKG_C_STATE_LIMIT_C8 6 +#define PKG_C_STATE_LIMIT_C9 7 +#define PKG_C_STATE_LIMIT_C10 8 +#define PKG_C_STATE_LIMIT_CMAX 9 +#define PKG_C_STATE_LIMIT_CPU_DEFAULT 254 +#define PKG_C_STATE_LIMIT_AUTO 255 + +#define C_STATE_AUTO_DEMOTION_DISABLE_C1_C3 0 +#define C_STATE_AUTO_DEMOTION_ENABLE_C3_C6_C7_TO_C1 1 +#define C_STATE_AUTO_DEMOTION_ENABLE_C6_C7_TO_C3 2 +#define C_STATE_AUTO_DEMOTION_ENABLE_C6_C7_TO_C1_C3 3 + +#define C_STATE_UN_DEMOTION_DISABLE_C1_C3 0 +#define C_STATE_UN_DEMOTION_ENABLE_C1 1 +#define C_STATE_UN_DEMOTION_ENABLE_C3 2 +#define C_STATE_UN_DEMOTION_ENABLE_C1_C3 3 + +#define MAX_CORE_C_STATE_UNLIMITED 0 +#define MAX_CORE_C_STATE_C1 1 +#define MAX_CORE_C_STATE_C3 2 +#define MAX_CORE_C_STATE_C6 3 +#define MAX_CORE_C_STATE_C7 4 +#define MAX_CORE_C_STATE_C8 5 +#define MAX_CORE_C_STATE_C9 6 +#define MAX_CORE_C_STATE_C10 7 +#define MAX_CORE_C_STATE_CCX 8 + +#define IPU_ACPI_MODE_DISABLE 0 +#define IPU_ACPI_MODE_IGFX_CHILD_DEVICE 1 +#define IPU_ACPI_MODE_ACPI_DEVICE 1 + +#define CD_CLOCK_FREQ_144MHZ 0 +#define CD_CLOCK_FREQ_288MHZ 1 +#define CD_CLOCK_FREQ_384MHZ 2 +#define CD_CLOCK_FREQ_576MHZ 3 +#define CD_CLOCK_FREQ_624MHZ 4 + +#define HDA_IO_BUFFER_OWNERSHIP_HDA_ALL_IO 0 +#define HDA_IO_BUFFER_OWNERSHIP_HDA_I2S_SPLIT 1 +#define HDA_IO_BUFFER_OWNERSHIP_I2S_ALL_IO 2 + +#define HDA_IO_BUFFER_VOLTAGE_3V3 0 +#define HDA_IO_BUFFER_VOLTAGE_1V8 1 + +#define HDA_VC_TYPE_VC0 0 +#define HDA_VC_TYPE_VC1 1 + +#define HDA_LINK_FREQ_6MHZ 0 +#define HDA_LINK_FREQ_12MHZ 1 +#define HDA_LINK_FREQ_24MHZ 2 +#define HDA_LINK_FREQ_48MHZ 3 +#define HDA_LINK_FREQ_96MHZ 4 +#define HDA_LINK_FREQ_INVALID 5 + +#define HDA_I_DISP_LINK_FREQ_6MHZ 0 +#define HDA_I_DISP_LINK_FREQ_12MHZ 1 +#define HDA_I_DISP_LINK_FREQ_24MHZ 2 +#define HDA_I_DISP_LINK_FREQ_48MHZ 3 +#define HDA_I_DISP_LINK_FREQ_96MHZ 4 +#define HDA_I_DISP_LINK_FREQ_INVALID 5 + +#define HDA_I_DISP_LINK_T_MODE_2T 0 +#define HDA_I_DISP_LINK_T_MODE_1T 1 + +#define HDA_DISP_DMIC_DISABLE 0 +#define HDA_DISP_DMIC_2CH_ARRAY 1 +#define HDA_DISP_DMIC_4CH_ARRAY 2 + +#define HDA_CSE_MEM_TRANSFERS_VC0 0 +#define HDA_CSE_MEM_TRANSFERS_VC2 1 + +#define HDA_HOST_MEM_TRANSFERS_VC0 0 +#define HDA_HOST_MEM_TRANSFERS_VC2 1 + +#define HDA_DSP_FEATURE_MASK_WOV 0x1 +#define HDA_DSP_FEATURE_MASK_BT_SIDEBAND 0x2 +#define HDA_DSP_FEATURE_MASK_CODEC_VAD 0x4 +#define HDA_DSP_FEATURE_MASK_BT_INTEL_HFP 0x20 +#define HDA_DSP_FEATURE_MASK_BT_INTEL_A2DP 0x40 +#define HDA_DSP_FEATURE_MASK_DSP_BASED_PRE_PROC_DISABLE 0x80 + +#define HDA_DSP_PP_MODULE_MASK_WOV 0x1 +#define HDA_DSP_PP_MODULE_MASK_BT_SIDEBAND 0x2 +#define HDA_DSP_PP_MODULE_MASK_CODEC_VAD 0x4 +#define HDA_DSP_PP_MODULE_MASK_BT_INTEL_HFP 0x20 +#define HDA_DSP_PP_MODULE_MASK_BT_INTEL_A2DP 0x40 +#define HDA_DSP_PP_MODULE_MASK_DSP_BASED_PRE_PROC_DISABLE 0x80 + +#define I2CX_ENABLE_DISABLED 0 +#define I2CX_ENABLE_PCI_MODE 1 +#define I2CX_ENABLE_ACPI_MODE 2 + +#define HSUARTX_ENABLE_DISABLED 0 +#define HSUARTX_ENABLE_PCI_MODE 1 +#define HSUARTX_ENABLE_ACPI_MODE 2 + +#define SPIX_ENABLE_DISABLED 0 +#define SPIX_ENABLE_PCI_MODE 1 +#define SPIX_ENABLE_ACPI_MODE 2 + +#define PCIE_RP_SPEED_AUTO 0 +#define PCIE_RP_SPEED_GEN1 1 +#define PCIE_RP_SPEED_GEN2 2 +#define PCIE_RP_SPEED_GEN3 3 + +#define PCIE_RP_ASPM_DISABLE 0 +#define PCIE_RP_ASPM_L0S 1 +#define PCIE_RP_ASPM_L1 2 +#define PCIE_RP_ASPM_L0S_L1 3 +#define PCIE_RP_ASPM_AUTO 4 + +#define PCIE_RP_L1_SUBSTATES_DISABLE 0 +#define PCIE_RP_L1_SUBSTATES_L1_1 1 +#define PCIE_RP_L1_SUBSTATES_L1_2 2 +#define PCIE_RP_L1_SUBSTATES_L1_1_L1_2 3 + +#define SATA_MODE_AHCI 0 +#define SATA_MODE_RAID 1 + +#define SATA_SPEED_LIMIT_SC_SATA_SPEED 0 +#define SATA_SPEED_LIMIT_1_5GBS 1 +#define SATA_SPEED_LIMIT_3GBS 2 +#define SATA_SPEED_LIMIT_6GBS 3 + +#define SATA_PORT_SOLID_STATE_DRIVE_HARD_DISK_DRIVE 0 +#define SATA_PORT_SOLID_STATE_DRIVE_SOLID_STATE_DRIVE 1 + +#define CRID_SETTING_DISABLE 0 +#define CRID_SETTING_CRID_1 1 +#define CRID_SETTING_CRID_2 2 +#define CRID_SETTING_CRID_3 3 + +#define RESET_SELECT_WARM_RESET 0x6 +#define RESET_SELECT_COLD_RESET 0xe + +#define EMMC_HOST_SPEED_MAX_HS400 0 +#define EMMC_HOST_SPEED_MAX_HS200 1 +#define EMMC_HOST_SPEED_MAX_DDR50 2 + +#define SERIAL_IRQ_MODE_QUIET_MODE 0 +#define SERIAL_IRQ_MODE_CONTINUOUS_MODE 1 + +#define START_FRAME_PULSE_WIDTH_SCSFPW4CLK 0 +#define START_FRAME_PULSE_WIDTH_SCSFPW6CLK 1 +#define START_FRAME_PULSE_WIDTH_SCSFPW8CLK 1 + +#define USB30_MODE_DISABLE 0 +#define USB30_MODE_ENABLE 1 +#define USB30_MODE_AUTO 2 + +#define USB_OTG_DISABLE 0 +#define USB_OTG_PCI_MODE 1 +#define USB_OTG_ACPI_MODE 2 + +#define SSIC_RATE_A_SERIES 1 +#define SSIC_RATE_B_SERIES 2 + +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MODE_DISABLE 0 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MODE_ENABLE 1 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MODE_AUTO 2 + +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1NS 0 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_32NS 1 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1024NS 2 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_32768NS 3 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1048576NS 4 +#define PCIE_RP_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_33554432NS 5 + +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MODE_DISABLE 0 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MODE_ENABLE 1 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MODE_AUTO 2 + +#define PWR_BTN_OVERRIDE_PERIOD_4S 0 +#define PWR_BTN_OVERRIDE_PERIOD_6S 1 +#define PWR_BTN_OVERRIDE_PERIOD_8S 2 +#define PWR_BTN_OVERRIDE_PERIOD_10S 3 +#define PWR_BTN_OVERRIDE_PERIOD_12S 4 +#define PWR_BTN_OVERRIDE_PERIOD_14S 5 + +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1NS 0 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_32NS 1 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1024NS 2 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_32768NS 3 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_1048576NS 4 +#define PCIE_RP_NON_SNOOP_LATENCY_OVERRIDE_MULTIPLIER_33554432NS 5 + +#define PCIE_RP_SELECTABLE_DEEMPHASIS_6_DB 0 +#define PCIE_RP_SELECTABLE_DEEMPHASIS_3_5_DB 1
#endif diff --git a/arch/x86/include/asm/arch-apollolake/fsp_bindings.h b/arch/x86/include/asm/arch-apollolake/fsp_bindings.h new file mode 100644 index 0000000000..c4c0028c06 --- /dev/null +++ b/arch/x86/include/asm/arch-apollolake/fsp_bindings.h @@ -0,0 +1,74 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright 2019 Google LLC + * Copyright 2020 B&R Industrial Automation GmbH - http://www.br-automation.com + */ + +#ifndef __ASM_ARCH_FSP_BINDINGS_H +#define __ASM_ARCH_FSP_BINDINGS_H + +#include <asm/arch/fsp/fsp_m_upd.h> +#include <asm/arch/fsp/fsp_s_upd.h> + +#define ARRAY_SIZE_OF_MEMBER(s, m) (ARRAY_SIZE((((s *)0)->m))) + +enum conf_type { + FSP_UINT8, + FSP_UINT16, + FSP_UINT32, + FSP_STRING, + FSP_LPDDR4_SWIZZLE, +}; + +struct fsp_binding { + size_t offset; + char *propname; + enum conf_type type; + size_t count; +}; + +/* + * LPDDR4 helper routines for configuring the memory UPD for LPDDR4 operation. + * There are four physical LPDDR4 channels, each 32-bits wide. There are two + * logical channels using two physical channels together to form a 64-bit + * interface to memory for each logical channel. + */ + +enum { + LP4_PHYS_CH0A, + LP4_PHYS_CH0B, + LP4_PHYS_CH1A, + LP4_PHYS_CH1B, + + LP4_NUM_PHYS_CHANNELS, +}; + +/* + * The DQs within a physical channel can be bit-swizzled within each byte. + * Within a channel the bytes can be swapped, but the DQs need to be routed + * with the corresponding DQS (strobe). + */ +enum { + LP4_DQS0, + LP4_DQS1, + LP4_DQS2, + LP4_DQS3, + + LP4_NUM_BYTE_LANES, + DQ_BITS_PER_DQS = 8, +}; + +/* Provide bit swizzling per DQS and byte swapping within a channel */ +struct lpddr4_chan_swizzle_cfg { + u8 dqs[LP4_NUM_BYTE_LANES][DQ_BITS_PER_DQS]; +}; + +struct lpddr4_swizzle_cfg { + struct lpddr4_chan_swizzle_cfg phys[LP4_NUM_PHYS_CHANNELS]; +}; + +void fsp_m_update_config_from_dtb(ofnode node, struct fsp_m_config *cfg); + +void fsp_s_update_config_from_dtb(ofnode node, struct fsp_s_config *cfg); + +#endif diff --git a/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt b/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt new file mode 100644 index 0000000000..647a0862d4 --- /dev/null +++ b/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt @@ -0,0 +1,320 @@ +* Intel FSP-M configuration + +Several Intel platforms require the execution of the Intel FSP (Firmware +Support Package) for initialization. The FSP consists of multiple parts, one +of which is the FSP-M (Memory initialization phase). + +This binding applies to the FSP-M for the Intel Apollo Lake SoC. + +The FSP-M is available on Github [1]. +For detailed information on the FSP-M parameters see the documentation in +FSP/ApolloLakeFspBinPkg/Docs [2]. + +The properties of this binding are all optional. If no properties are set the +values of the FSP-M are used. + +[1] https://github.com/IntelFsp/FSP +[2] https://github.com/IntelFsp/FSP/tree/master/ApolloLakeFspBinPkg/Docs + +Optional properties: +- fspm,serial-debug-port-address: Debug Serial Port Base address +- fspm,serial-debug-port-type: Debug Serial Port Type + 0: NONE + 1: I/O + 2: MMIO (default) +- fspm,serial-debug-port-device: Serial Port Debug Device + 0: SOC UART0 + 1: SOC UART1 + 2: SOC UART2 (default) + 3: External Device +- fspm,serial-debug-port-stride-size: Debug Serial Port Stride Size + 0: 1 + 2: 4 (default) +- fspm,mrc-fast-boot: Memory Fast Boot +- fspm,igd: Integrated Graphics Device +- fspm,igd-dvmt50-pre-alloc: DVMT Pre-Allocated + 0x02: 64 MB (default) + 0x03: 96 MB + 0x04: 128 MB + 0x05: 160 MB + 0x06: 192 MB + 0x07: 224 MB + 0x08: 256 MB + 0x09: 288 MB + 0x0A: 320 MB + 0x0B: 352 MB + 0x0C: 384 MB + 0x0D: 416 MB + 0x0E: 448 MB + 0x0F: 480 MB + 0x10: 512 MB +- fspm,aperture-size: Aperture Size + 0x1: 128 MB (default) + 0x2: 256 MB + 0x3: 512 MB +- fspm,gtt-size: GTT Size + 0x1: 2 MB + 0x2: 4 MB + 0x3: 8 MB (default) +- fspm,primary-video-adaptor: Primary Display + 0x0: AUTO (default) + 0x2: IGD + 0x3: PCI +- fspm,package: Package + 0x0: SODIMM (default) + 0x1: BGA + 0x2: BGA mirrored (LPDDR3 only) + 0x3: SODIMM/UDIMM with Rank 1 Mirrored (DDR3L) +- fspm,profile: Profile + 0x01: WIO2_800_7_8_8 + 0x02: WIO2_1066_9_10_10 + 0x03: LPDDR3_1066_8_10_10 + 0x04: LPDDR3_1333_10_12_12 + 0x05: LPDDR3_1600_12_15_15 + 0x06: LPDDR3_1866_14_17_17 + 0x07: LPDDR3_2133_16_20_20 + 0x08: LPDDR4_1066_10_10_10 + 0x09: LPDDR4_1600_14_15_15 + 0x0A: LPDDR4_2133_20_20_20 + 0x0B: LPDDR4_2400_24_22_22 + 0x0C: LPDDR4_2666_24_24_24 + 0x0D: LPDDR4_2933_28_27_27 + 0x0E: LPDDR4_3200_28_29_29 + 0x0F: DDR3_1066_6_6_6 + 0x10: DDR3_1066_7_7_7 + 0x11: DDR3_1066_8_8_8 + 0x12: DDR3_1333_7_7_7 + 0x13: DDR3_1333_8_8_8 + 0x14: DDR3_1333_9_9_9 + 0x15: DDR3_1333_10_10_10 + 0x16: DDR3_1600_8_8_8 + 0x17: DDR3_1600_9_9_9 + 0x18: DDR3_1600_10_10_10 + 0x19: DDR3_1600_11_11_11 (default) + 0x1A: DDR3_1866_10_10_10 + 0x1B: DDR3_1866_11_11_11 + 0x1C: DDR3_1866_12_12_12 + 0x1D: DDR3_1866_13_13_13 + 0x1E: DDR3_2133_11_11_11 + 0x1F: DDR3_2133_12_12_12 + 0x20: DDR3_2133_13_13_13 + 0x21: DDR3_2133_14_14_14 + 0x22: DDR4_1333_10_10_10 + 0x23: DDR4_1600_10_10_10 + 0x24: DDR4_1600_11_11_11 + 0x25: DDR4_1600_12_12_12 + 0x26: DDR4_1866_12_12_12 + 0x27: DDR4_1866_13_13_13 + 0x28: DDR4_1866_14_14_14 + 0x29: DDR4_2133_14_14_14 + 0x2A: DDR4_2133_15_15_15 + 0x2B: DDR4_2133_16_16_16 + 0x2C: DDR4_2400_15_15_15 + 0x2D: DDR4_2400_16_16_16 + 0x2E: DDR4_2400_17_17_17 + 0x2F: DDR4_2400_18_18_18 +- fspm,memory-down: Memory Down + 0x0: No (default) + 0x1: Yes + 0x2: 1MD+SODIMM (for DDR3L only) ACRD + 0x3: 1x32 LPDDR4 +- fspm,ddr3l-page-size: DDR3LPageSize + 0x1: 1KB (default) + 0x2: 2KB +- fspm,ddr3-lasr: DDR3LASR +- fspm,scrambler-support: ScramblerSupport +- fspm,interleaved-mode: InterleavedMode +- fspm,channel-hash-mask: ChannelHashMask +- fspm,fspm,slice-hash-mask: SliceHashMask +- fspm,channels-slices-enable: ChannelsSlices +- fspm,min-ref-rate2x-enable: MinRefRate2x +- fspm,dual-rank-support-enable: DualRankSupport +- fspm,rmt-mode: RmtMode +- fspm,memory-size-limit: MemorySizeLimit +- fspm,low-memory-max-value: LowMemoryMaxValue +- fspm,high-memory-max-value: HighMemoryMaxValue +- fspm,disable-fast-boot: FastBoot +- fspm,dimm0-spd-address: DIMM0 SPD Address +- fspm,dimm1-spd-address: DIMM1 SPD Address +- fspm,chX-rank-enable: Must be set to enable rank (X = 0-3) +- fspm,chX-device-width: DRAM device width per DRAM channel (X = 0-3) + 0: x8 + 1: x16 + 2: x32 + 3: x64 +- fspm,chX-dram-density: Must specify the DRAM device density (X = 0-3) + 0: 4Gb + 1: 6Gb + 2: 8Gb + 3: 12Gb + 4: 16Gb + 5: 2Gb +- fspm,chX-option: Channel options (X = 0-3) +- fspm,chX-odt-config: Channel Odt Config (X = 0-3) +- fspm,chX-mode2-n: Force 2N Mode (X = 0-3) + 0x0: Auto + 0x1: Force 2N CMD Timing Mode +- fspm,chX-odt-levels: Channel Odt Levels (X = 0-3) + 0: ODT Connected to SoC + 1: ODT held high +- fspm,rmt-check-run: RmtCheckRun +- fspm,rmt-margin-check-scale-high-threshold: RmtMarginCheckScaleHighThreshold +- fspm,ch-bit-swizzling: Bit_swizzling +- fspm,msg-level-mask: MsgLevelMask +- fspm,pre-mem-gpio-table-pin-num: PreMem GPIO Pin Number for each table +- fspm,pre-mem-gpio-table-ptr: PreMem GPIO Table Pointer +- fspm,pre-mem-gpio-table-entry-num: PreMem GPIO Table Entry Number +- fspm,enhance-port8xh-decoding: Enhance the port 8xh decoding +- fspm,spd-write-enable: SPD Data Write +- fspm,mrc-data-saving: MRC Training Data Saving +- fspm,oem-loading-base: OEM File Loading Address +- fspm,oem-file-name: OEM File Name to Load +- fspm,mrc-boot-data-ptr: +- fspm,e-mmc-trace-len: eMMC Trace Length + 0x0: Long + 0x1: Short +- fspm,skip-cse-rbp: Skip CSE RBP to support zero sized IBB +- fspm,npk-en: Npk Enable + 0: Disable + 1: Enable + 2: Debugger + 3: Auto (default) +- fspm,fw-trace-en: FW Trace Enable +- fspm,fw-trace-destination: FW Trace Destination + 1: NPK_TRACE_TO_MEMORY + 2: NPK_TRACE_TO_DCI + 3: NPK_TRACE_TO_BSSB + 4: NPK_TRACE_TO_PTI (default) +- fspm,recover-dump: NPK Recovery Dump +- fspm,msc0-wrap: Memory Region 0 Buffer WrapAround + 0: n0-warp + 1: n1-warp (default) +- fspm,msc1-wrap: Memory Region 1 Buffer WrapAround + 0: n0-warp + 1: n1-warp (default) +- fspm,msc0-size: Memory Region 0 Buffer Size + 0: 0MB (default) + 1: 1MB + 2: 8MB + 3: 64MB + 4: 128MB + 5: 256MB + 6: 512MB + 7: 1GB +- fspm,msc1-size: Memory Region 1 Buffer Size + 0: 0MB (default) + 1: 1MB + 2: 8MB + 3: 64MB + 4: 128MB + 5: 256MB + 6: 512MB + 7: 1GB +- fspm,pti-mode: PTI Mode + 0: 0ff + 1: x4 (default) + 2: x8 + 3: x12 + 4: x16 +- fspm,pti-training: PTI Training + 0: off (default) + 1-6: 1-6 +- fspm,pti-speed: + 0: full + 1: half + 2: quarter (default) +- fspm,punit-mlvl: Punit Message Level + 0: + 1: (default) + 2-4: 2-4 +- fspm,pmc-mlvl: PMC Message Level + 0: + 1: (default) + 2-4: 2-4 +- fspm,sw-trace-en: SW Trace Enable +- fspm,periodic-retraining-disable: Periodic Retraining Disable +- fspm,enable-reset-system: Enable Reset System +- fspm,enable-s3-heci2: Enable HECI2 in S3 resume path +- fspm,variable-nvs-buffer-ptr: + +Example: + +&host_bridge { + fspm,package = <PACKAGE_BGA>; + fspm,profile = <PROFILE_LPDDR4_2400_24_22_22>; + fspm,memory-down = <MEMORY_DOWN_YES>; + fspm,scrambler-support = <1>; + fspm,interleaved-mode = <INTERLEAVED_MODE_ENABLE>; + fspm,channel-hash-mask = <0x36>; + fspm,slice-hash-mask = <0x9>; + fspm,low-memory-max-value = <2048>; + fspm,ch0-rank-enable = <1>; + fspm,ch0-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch0-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch0-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch0-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch1-rank-enable = <1>; + fspm,ch1-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch1-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch1-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch1-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch2-rank-enable = <1>; + fspm,ch2-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch2-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch2-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch2-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,ch3-rank-enable = <1>; + fspm,ch3-device-width = <CHX_DEVICE_WIDTH_X16>; + fspm,ch3-dram-density = <CHX_DEVICE_DENSITY_8GB>; + fspm,ch3-option = <(CHX_OPTION_RANK_INTERLEAVING | + CHX_OPTION_BANK_ADDRESS_HASHING_ENABLE)>; + fspm,ch3-odt-config = <CHX_ODT_CONFIG_DDR4_CA_ODT>; + fspm,fspm,skip-cse-rbp = <1>; + + fspm,ch-bit-swizzling = /bits/ 8 < + /* LP4_PHYS_CH0A */ + + /* DQA[0:7] pins of LPDDR4 module */ + 6 7 5 4 3 1 0 2 + /* DQA[8:15] pins of LPDDR4 module */ + 12 10 11 13 14 8 9 15 + /* DQB[0:7] pins of LPDDR4 module with offset of 16 */ + 16 22 23 20 18 17 19 21 + /* DQB[7:15] pins of LPDDR4 module with offset of 16 */ + 30 28 29 25 24 26 27 31 + + /* LP4_PHYS_CH0B */ + /* DQA[0:7] pins of LPDDR4 module */ + 7 3 5 2 6 0 1 4 + /* DQA[8:15] pins of LPDDR4 module */ + 9 14 12 13 10 11 8 15 + /* DQB[0:7] pins of LPDDR4 module with offset of 16 */ + 20 22 23 16 19 17 18 21 + /* DQB[7:15] pins of LPDDR4 module with offset of 16 */ + 28 24 26 27 29 30 31 25 + + /* LP4_PHYS_CH1A */ + + /* DQA[0:7] pins of LPDDR4 module */ + 2 1 6 7 5 4 3 0 + /* DQA[8:15] pins of LPDDR4 module */ + 11 10 8 9 12 15 13 14 + /* DQB[0:7] pins of LPDDR4 module with offset of 16 */ + 17 23 19 16 21 22 20 18 + /* DQB[7:15] pins of LPDDR4 module with offset of 16 */ + 31 29 26 25 28 27 24 30 + + /* LP4_PHYS_CH1B */ + + /* DQA[0:7] pins of LPDDR4 module */ + 4 3 7 5 6 1 0 2 + /* DQA[8:15] pins of LPDDR4 module */ + 15 9 8 11 14 13 12 10 + /* DQB[0:7] pins of LPDDR4 module with offset of 16 */ + 20 23 22 21 18 19 16 17 + /* DQB[7:15] pins of LPDDR4 module with offset of 16 */ + 25 28 30 31 26 27 24 29>; +}; diff --git a/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt b/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt new file mode 100644 index 0000000000..973d253ada --- /dev/null +++ b/doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt @@ -0,0 +1,483 @@ +* Intel FSP-S configuration + +Several Intel platforms require the execution of the Intel FSP (Firmware +Support Package) for initialization. The FSP consists of multiple parts, one +of which is the FSP-S (Silicon initialization phase). + +This binding applies to the FSP-S for the Intel Apollo Lake SoC. + +The FSP-S is available on Github [1]. +For detailed information on the FSP-S parameters see the documentation in +FSP/ApolloLakeFspBinPkg/Docs [2]. + +The properties of this binding are all optional. If no properties are set the +values of the FSP-S are used. + +[1] https://github.com/IntelFsp/FSP +[2] https://github.com/IntelFsp/FSP/tree/master/ApolloLakeFspBinPkg/Docs + +Optional properties: +- fsps,active-processor-cores: ActiveProcessorCores +- fsps,disable-core1: Disable Core1 +- fsps,disable-core2: Disable Core2 +- fsps,disable-core2: Disable Core3 +- fsps,vmx-enable: VMX Enable +- fsps,proc-trace-mem-size: Memory region allocation for Processor Trace + 0xFF: Disable (default) +- fsps,proc-trace-enable: Enable Processor Trace +- fsps,eist: Eist +- fsps,boot-p-state: Boot PState + 0: HFM (default) + 1: LFM +- fsps,enable-cx: CPU power states (C-states) +- fsps,c1e: Enhanced C-states +- fsps,bi-proc-hot: Bi-Directional PROCHOT# +- fsps,pkg-c-state-limit: Max Pkg Cstate + 0: PkgC0C1 + 1: PkgC2 + 2: PkgC3 (default) + 3: PkgC6 + 4: PkgC7 + 5: PkgC7s + 6: PkgC8 + 7: PkgC9 + 8: PkgC10 + 9: PkgCMax + 254: PkgCpuDefault + 255: PkgAuto +- fsps,c-state-auto-demotion: C-State auto-demotion + 0: Disable C1 and C3 Auto-demotion (default) + 1: Enable C3/C6/C7 Auto-demotion to C1 + 2: Enable C6/C7 Auto-demotion to C3 + 3: Enable C6/C7 Auto-demotion to C1 and C3 +- fsps,c-state-un-demotion: C-State un-demotion + 0: Disable C1 and C3 Un-demotion (default) + 1: Enable C1 Un-demotion + 2: Enable C3 Un-demotion + 3: Enable C1 and C3 Un-demotion +- fsps,max-core-c-state: Max Core C-State + 0: Unlimited + 1: C1 + 2: C3 + 3: C6 + 4: C7 + 5: C8 + 6: C9 + 7: C10 + 8: CCx (default) +- fsps,pkg-c-state-demotion: Package C-State Demotion +- fsps,pkg-c-state-un-demotion: Package C-State Un-demotion +- fsps,turbo-mode: Turbo Mode +- fsps,hda-verb-table-entry-num: SC HDA Verb Table Entry Number + 0: (default) +- fsps,hda-verb-table-ptr: SC HDA Verb Table Pointer + 0x00000000: (default) +- fsps,p2sb-unhide: Enable/Disable P2SB device hidden +- fsps,ipu-en: IPU Enable/Disable +- fsps,ipu-acpi-mode: IMGU ACPI mode selection + 0: Auto + 1: IGFX Child device (default) + 2: ACPI device +- fsps,force-wake: Enable ForceWake +- fsps,gtt-mm-adr: GttMmAdr + 0xbf000000: (default) +- fsps,gm-adr: GmAdr + 0xa0000000: (default) +- fsps,pavp-lock: Enable PavpLock +- fsps,graphics-freq-modify: Enable GraphicsFreqModify +- fsps,graphics-freq-req: Enable GraphicsFreqReq +- fsps,graphics-video-freq: Enable GraphicsVideoFreq +- fsps,pm-lock: Enable PmLock +- fsps,dop-clock-gating: Enable DopClockGating +- fsps,unsolicited-attack-override: Enable UnsolicitedAttackOverride +- fsps,wopcm-support: Enable WOPCMSupport +- fsps,wopcm-size: Enable WOPCMSize +- fsps,power-gating: Enable PowerGating +- fsps,unit-level-clock-gating: Enable UnitLevelClockGating +- fsps,fast-boot: Enable FastBoot +- fsps,dyn-sr: Enable DynSR +- fsps,sa-ipu-enable: Enable SaIpuEnable +- fsps,pm-support: GT PM Support +- fsps,enable-render-standby: RC6(Render Standby) +- fsps,logo-size: BMP Logo Data Size +- fsps,logo-ptr: BMP Logo Data Pointer +- fsps,graphics-config-ptr: Graphics Configuration Data Pointer +- fsps,pavp-enable: PAVP Enable +- fsps,pavp-pr3: PAVP PR3 +- fsps,cd-clock: CdClock Frequency selection + 0: 144MHz + 1: 288MHz + 2: 384MHz + 3: 576MHz + 4: 624MHz (default) +- fsps,pei-graphics-peim-init: Enable/Disable PeiGraphicsPeimInit +- fsps,write-protection-enable: Write Protection Support +- fsps,read-protection-enable: Read Protection Support +- fsps,protected-range-limit: Protected Range Limitation + 0x0FFF: (default) +- fsps,protected-range-base: Protected Range Base + 0x0000: (default) +- fsps,gmm: Enable SC Gaussian Mixture Models +- fsps,clk-gating-pgcb-clk-trunk: GMM Clock Gating - PGCB Clock Trunk +- fsps,clk-gating-sb: GMM Clock Gating - Sideband +- fsps,clk-gating-sb-clk-trunk: GMM Clock Gating - Sideband +- fsps,clk-gating-sb-clk-partition: GMM Clock Gating - Sideband Clock + Partition +- fsps,clk-gating-core: GMM Clock Gating - Core +- fsps,clk-gating-dma: GMM Clock Gating - DMA +- fsps,clk-gating-reg-access: GMM Clock Gating - Register Access +- fsps,clk-gating-host: GMM Clock Gating - Host +- fsps,clk-gating-partition: GMM Clock Gating - Partition +- fsps,clk-gating-trunk: Clock Gating - Trunk +- fsps,hda-enable: HD Audio Support +- fsps,dsp-enable: HD Audio DSP Support +- fsps,pme: Azalia wake-on-ring +- fsps,hd-audio-io-buffer-ownership: HD-Audio I/O Buffer Ownership + 0: HD-Audio link owns all the I/O buffers (default) + 1: HD-Audio link owns 4 I/O buffers and I2S port owns 4 I/O buffers + 3: I2S port owns all the I/O buffers +- fsps,hd-audio-io-buffer-voltage: HD-Audio I/O Buffer Voltage + 0: 3.3V (default) + 1: 1.8V +- fsps,hd-audio-vc-type: HD-Audio Virtual Channel Type + 0: VC0 (default) + 1: VC1 +- fsps,hd-audio-link-frequency: HD-Audio Link Frequency + 0: 6MHz (default) + 1: 12MHz + 2: 24MHz + 3: 48MHz + 4: 96MHz + 5: Invalid +- fsps,hd-audio-i-disp-link-frequency: HD-Audio iDisp-Link Frequency + 0: 6MHz (default) + 1: 12MHz + 2: 24MHz + 3: 48MHz + 4: 96MHz + 5: Invalid +- fsps,hd-audio-i-disp-link-tmode: HD-Audio iDisp-Link T-Mode + 0: 2T (default) + 1: 1T +- fsps,dsp-endpoint-dmic: HD-Audio Disp DMIC + 0: disable, + 1: 2ch array (default) + 2: 4ch array +- fsps,dsp-endpoint-bluetooth: HD-Audio Bluetooth +- fsps,dsp-endpoint-i2s-skp: HD-Audio I2S SHK +- fsps,dsp-endpoint-i2s-hp: HD-Audio I2S HP +- fsps,audio-ctl-pwr-gate: HD-Audio Controller Power Gating (deprecated) +- fsps,audio-dsp-pwr-gate: HD-Audio ADSP Power Gating (deprecated) +- fsps,mmt: HD-Audio CSME Memory Transfers + 0: VC0 (default) + 1: VC2 +- fsps,hmt: HD-Audio Host Memory Transfers + 0: VC0 (default) + 1: VC2 +- fsps,hd-audio-pwr-gate: HD-Audio Power Gating +- fsps,hd-audio-clk-gate: HD-Audio Clock Gating +- fsps,dsp-feature-mask: Bitmask of DSP Feature + 0x01: WoV + 0x02: BT Sideband + 0x04: Codec VAD + 0x20: BT Intel HFP + 0x40: BT Intel A2DP + 0x80: DSP based speech pre-processing disabled +- fsps,dsp-pp-module-mask: Bitmask of supported DSP Post-Processing Modules + 0x01: WoV + 0x02: BT Sideband + 0x04: Codec VAD + 0x20: BT Intel HFP + 0x40: BT Intel A2DP + 0x80: DSP based speech pre-processing disabled +- fsps,bios-cfg-lock-down: HD-Audio BIOS Configuration Lock Down +- fsps,hpet: Enable High Precision Timer +- fsps,hpet-bdf-valid: Hpet Valid BDF Value +- fsps,hpet-bus-number: Bus Number of Hpet + 0xFA: (default) +- fsps,hpet-device-number: Device Number of Hpet + 0x1F: (default) +- fsps,hpet-function-number: Function Number of Hpet + 0x00: (default) +- fsps,io-apic-bdf-valid: IoApic Valid BDF Value +- fsps,io-apic-bus-number: Bus Number of IoApic + 0xFA: (default) +- fsps,io-apic-device-number: Device Number of IoApic + 0x0F: (default) +- fsps,io-apic-function-number: Function Number of IoApic + 0x00: (default) +- fsps,io-apic-entry24-119: IOAPIC Entry 24-119 +- fsps,io-apic-id: IO APIC ID + 0x01: (default) +- fsps,io-apic-range-select: IoApic Range + 0x00: (default) +- fsps,ish-enable: ISH Controller +- fsps,bios-interface: BIOS Interface Lock Down +- fsps,bios-lock: Bios LockDown Enable +- fsps,spi-eiss: SPI EISS Status +- fsps,bios-lock-sw-smi-number: BiosLock SWSMI Number + 0xA9: (default) +- fsps,lpss-s0ix-enable: LPSS IOSF PMCTL S0ix Enable +- fsps,i2c-clk-gate-cfg: LPSS I2C Clock Gating Configuration +- fsps,hsuart-clk-gate-cfg: LPSS HSUART Clock Gating Configuration +- fsps,spi-clk-gate-cfg: LPSS SPI Clock Gating Configuration +- fsps,i2cX-enable: 2C Device X + 0: Disabled + 1: PCI Mode (default) + 2: ACPI Mode +- fsps,hsuartX-enable: UART Device X + 0: Disabled + 1: PCI Mode (default) + 2: ACPI Mode +- fsps,spiX-enable: SPI UART Device X + 0: Disabled + 1: PCI Mode (default) + 2: ACPI Mode +- fsps,os-dbg-enable: OS Debug Feature +- fsps,dci-en: DCI Feature +- fsps,uart2-kernel-debug-base-address: UART Debug Base Address + 0x00000000: (default) +- fsps,pcie-clock-gating-disabled: Enable PCIE Clock Gating +- fsps,pcie-root-port8xh-decode: Enable PCIE Root Port 8xh Decode +- fsps,pcie8xh-decode-port-index: PCIE 8xh Decode Port Index + 0x00: (default) +- fsps,pcie-root-port-peer-memory-write-enable: Enable PCIE Root Port Peer + Memory Write +- fsps,pcie-aspm-sw-smi-number: PCIE SWSMI Number + 0xAA: (default) +- fsps,pcie-root-port-en: PCI Express Root Port +- fsps,pcie-rp-hide: Hide PCIE Root Port Configuration Space +- fsps,pcie-rp-slot-implemented: PCIE Root Port Slot Implement +- fsps,pcie-rp-hot-plug: Hot Plug +- fsps,pcie-rp-pm-sci: PCIE PM SCI +- fsps,pcie-rp-ext-sync: PCIE Root Port Extended Sync +- fsps,pcie-rp-transmitter-half-swing: Transmitter Half Swing +- fsps,pcie-rp-acs: ACS +- fsps,pcie-rp-clk-req-supported: Clock Request Support +- fsps,pcie-rp-clk-req-number: Configure CLKREQ Number +- fsps,pcie-rp-clk-req-detect: CLKREQ# Detection +- fsps,advanced-error-reportingt: Advanced Error Reporting +- fsps,pme-interrupt: PME Interrupt +- fsps,fatal-error-report: URR +- fsps,no-fatal-error-report: FER +- fsps,correctable-error-report: NFER +- fsps,system-error-on-fatal-error: CER +- fsps,system-error-on-non-fatal-error: SEFE +- fsps,system-error-on-correctable-error: SENFE +- fsps,pcie-rp-speed: SECE +- fsps,physical-slot-number: PCIe Speed + 0: Auto (default) + 1: Gen1 + 2: Gen2 + 3: Gen3 +- fsps,pcie-rp-completion-timeout: Physical Slot Number + 0x00, 0x01, 0x02, 0x03, 0x04, 0x05 (default) +- fsps,enable-ptm: PTM Support +- fsps,pcie-rp-aspm: ASPM +- fsps,pcie-rp-l1-substates: L1 Substates +- fsps,pcie-rp-ltr-enable: PCH PCIe LTR +- fsps,pcie-rp-ltr-config-lock: PCIE LTR Lock +- fsps,pme-b0-s5-di: PME_B0_S5 Disable bit +- fsps,pci-clock-run: PCI Clock Run +- fsps,timer8254-clk-setting: Enable/Disable Timer 8254 Clock Setting +- fsps,enable-sata: Chipset SATA +- fsps,sata-mode: SATA Mode Selection + 0: AHCI (default) + 1: RAID +- fsps,sata-salp-support: Aggressive LPM Support +- fsps,sata-pwr-opt-enable: SATA Power Optimization +- fsps,e-sata-speed-limit: eSATA Speed Limit +- fsps,speed-limit: SATA Speed Limit + 0x1: 1.5Gb/s(Gen 1) + 0x2: 3Gb/s(Gen 2) + 0x3: 6Gb/s(Gen 3) +- fsps,sata-ports-enable: SATA Port +- fsps,sata-ports-dev-slp: SATA Port DevSlp +- fsps,sata-ports-hot-plug: SATA Port HotPlug +- fsps,sata-ports-interlock-sw: Mechanical Presence Switch +- fsps,sata-ports-external: External SATA Ports +- fsps,sata-ports-spin-up: Spin Up Device +- fsps,sata-ports-solid-state-drive: SATA Solid State + 0: Hard Disk Drive (default) + 1: Solid State Drive +- fsps,sata-ports-enable-dito-config: DITO Configuration +- fsps,sata-ports-dm-val: DM Value + 0x0F: Maximum (default) +- fsps,sata-ports-dito-val: DITO Value + 0x0271 (default) +- fsps,sub-system-vendor-id: Subsystem Vendor ID + 0x8086: (default) +- fsps,sub-system-id: Subsystem ID + 0x7270: (default) +- fsps,crid-setting: CRIDSettings + 0: Disable (default) + 1: CRID_1 + 2: CRID_2 + 3: CRID_3 +- fsps,reset-select: ResetSelect + 0x6: warm reset (default) + 0xE: cold reset +- fsps,sdcard-enabled: SD Card Support (D27:F0) +- fsps,e-mmc-enabled: SeMMC Support (D28:F0) +- fsps,emmc-host-max-speed: eMMC Max Speed + 0: HS400(default) + 1: HS200 + 2: DDR50 +- fsps,ufs-enabled: UFS Support (D29:F0) +- fsps,sdio-enabled: SDIO Support (D30:F0) +- fsps,gpp-lock: GPP Lock Feature +- fsps,sirq-enable: Serial IRQ +- fsps,sirq-mode: Serial IRQ Mode + 0: Quiet mode (default) + 1: Continuous mode +- fsps,start-frame-pulse: Start Frame Pulse Width + 0: ScSfpw4Clk (default) + 1: ScSfpw6Clk + 2: ScSfpw8Clk +- fsps,smbus-enable: SMBus +- fsps,arp-enable: SMBus ARP Support +- fsps,num-rsvd-smbus-addresses: SMBus Table Elements + 0x0080: (default) +- fsps,rsvd-smbus-address-table: Reserved SMBus Address Table + 0x00: (default) +- fsps,disable-compliance-mode: XHCI Disable Compliance Mode +- fsps,usb-per-port-ctl: USB Per-Port Control +- fsps,usb30-mode: xHCI Mode + 0: Disable + 1: Enable + 2: Auto (default) +- fsps,port-usb20-enable: Enable USB2 ports +- fsps,port-usb20-over-current-pin: USB20 Over Current Pin +- fsps,usb-otg: XDCI Support + 0: Disable + 1: PCI_Mode (default) + 2: ACPI_mode +- fsps,hsic-support-enable: Enable XHCI HSIC Support +- fsps,port-usb30-enable: Enable USB3 ports +- fsps,port-usb30-over-current-pin: USB30 Over Current Pin +- fsps,ssic-port-enable: Enable XHCI SSIC Support +- fsps,dlane-pwr-gating: SSIC Dlane PowerGating +- fsps,vtd-enable: VT-d +- fsps,lock-down-global-smi: SMI Lock bit +- fsps,reset-wait-timer: HDAudio Delay Timer + 0x012C: (default) +- fsps,rtc-lock: RTC Lock Bits +- fsps,sata-test-mode: SATA Test Mode Selection +- fsps,ssic-rate: XHCI SSIC RATE + 1: A Series (default) + 2: B Series +- fsps,dynamic-power-gating: SMBus Dynamic Power Gating +- fsps,pcie-rp-ltr-max-snoop-latency: Max Snoop Latency + 0x0000: (default) +- fsps,pcie-rp-snoop-latency-override-mode: Snoop Latency Override + 0: Disable + 1: Enable + 2: Auto (default) +- fsps,pcie-rp-snoop-latency-override-value: Snoop Latency Value + 0x003C (default) +- fsps,pcie-rp-snoop-latency-override-multiplier: Snoop Latency Multiplier + 0: 1ns + 1: 32ns + 2: 1024ns (default) + 3: 32768ns + 4: 1048576ns + 5: 33554432ns +- fsps,skip-mp-init: Skip Multi-Processor Initialization +- fsps,dci-auto-detect: DCI Auto Detect +- fsps,pcie-rp-ltr-max-non-snoop-latency: Max Non-Snoop Latency + 0x0000: (default) +- fsps,pcie-rp-non-snoop-latency-override-mode: Non Snoop Latency Override +- fsps,tco-timer-halt-lock: Halt and Lock TCO Timer +- fsps,pwr-btn-override-period: Power Button Override Period + 000: 4s (default) + 001: 6s + 010: 8s + 011: 10s + 100: 12s + 101: 14s +- fsps,pcie-rp-non-snoop-latency-override-value: + 0x003C: (default) +- fsps,pcie-rp-non-snoop-latency-override-multiplier: Non Snoop Latency Value + 0: 1ns + 1: 32ns + 2: 1024ns (default) + 3: 32768ns + 4: 1048576ns + 5: 33554432ns +- fsps,pcie-rp-slot-power-limit-scale: PCIE Root Port Slot Power Limit Scale + 0x00: (default) +- fsps,pcie-rp-slot-power-limit-value: + 0x00: (default) +- fsps,disable-native-power-button: Power Button Native Mode Disable +- fsps,power-butter-debounce-mode: Power Button Debounce Mode +- fsps,sdio-tx-cmd-cntl: SDIO_TX_CMD_DLL_CNTL + 0x505: (default) +- fsps,sdio-tx-data-cntl1: SDIO_TX_DATA_DLL_CNTL1 + 0xE: (default) +- fsps,sdio-tx-data-cntl2: SDIO_TX_DATA_DLL_CNTL2 + 0x22272828: (default) +- fsps,sdio-rx-cmd-data-cntl1: SDIO_RX_CMD_DATA_DLL_CNTL1 + 0x16161616: (default) +- fsps,sdio-rx-cmd-data-cntl2: SDIO_RX_CMD_DATA_DLL_CNTL2 + 0x10000: (default) +- fsps,sdcard-tx-cmd-cntl: SDCARD_TX_CMD_DLL_CNTL + 0x505 (default) +- fsps,sdcard-tx-data-cntl1: SDCARD_TX_DATA_DLL_CNTL1 + 0xA13: (default) +- fsps,sdcard-tx-data-cntl2: SDCARD_TX_DATA_DLL_CNTL2 + 0x24242828: (default) +- fsps,sdcard-rx-cmd-data-cntl1: SDCARD_RX_CMD_DATA_DLL_CNTL1 + 0x73A3637 (default) +- fsps,sdcard-rx-strobe-cntl: SDCARD_RX_STROBE_DLL_CNTL + 0x0: (default) +- fsps,sdcard-rx-cmd-data-cntl2: SDCARD_RX_CMD_DATA_DLL_CNTL2 + 0x10000: (default) +- fsps,emmc-tx-cmd-cntl: EMMC_TX_CMD_DLL_CNTL + 0x505: (default) +- fsps,emmc-tx-data-cntl1: EMMC_TX_DATA_DLL_CNTL1 + 0xC11: (default) +- fsps,emmc-tx-data-cntl2: EMMC_TX_DATA_DLL_CNTL2 + 0x1C2A2927: (default) +- fsps,emmc-rx-cmd-data-cntl1: EMMC_RX_CMD_DATA_DLL_CNTL1 + 0x000D162F: (default) +- fsps,emmc-rx-strobe-cntl: EMMC_RX_STROBE_DLL_CNTL + 0x0a0a: (default) +- fsps,emmc-rx-cmd-data-cntl2: EMMC_RX_CMD_DATA_DLL_CNTL2 + 0x1003b: (default) +- fsps,emmc-master-sw-cntl: EMMC_MASTER_DLL_CNTL + 0x001: (default) +- fsps,pcie-rp-selectable-deemphasis: PCIe Selectable De-emphasis + 1: -3.5 dB (default) + 0: -6 dB +- fsps,monitor-mwait-enable: Monitor Mwait Enable +- fsps,hd-audio-dsp-uaa-compliance: Universal Audio Architecture + compliance for DSP enabled system +- fsps,ipc: IRQ Interrupt Polarity Control +- fsps,sata-ports-disable-dynamic-pg: Disable ModPHY dynamic power gate +- fsps,init-s3-cpu: Init CPU during S3 resume +- fsps,skip-punit-init: Skip P-unit Initialization +- fsps,port-usb20-per-port-tx-pe-half: PerPort Half Bit Pre-emphasis +- fsps,port-usb20-per-port-pe-txi-set: PerPort HS Pre-emphasis Bias +- fsps,port-usb20-per-port-txi-set: PerPort HS Transmitter Bias +- fsps,port-usb20-hs-skew-sel: Select the skew direction for HS transition +- fsps,port-usb20-i-usb-tx-emphasis-en: PerPort HS Transmitter Emphasis +- fsps,port-usb20-per-port-rxi-set: PerPort HS Receiver Bias +- fsps,port-usb20-hs-npre-drv-sel: Delay/skew's strength control for HS driver + +Example: + +&fsp_s { + u-boot,dm-pre-proper; + + fsps,ish-enable = <0>; + fsps,enable-sata = <0>; + fsps,pcie-root-port-en = [00 00 00 00 00 01]; + fsps,pcie-rp-hot-plug = [00 00 00 00 00 01]; + fsps,i2c6-enable = <I2CX_ENABLE_DISABLED>; + fsps,i2c7-enable = <I2CX_ENABLE_DISABLED>; + fsps,hsuart3-enable = <HSUARTX_ENABLE_DISABLED>; + fsps,spi1-enable = <SPIX_ENABLE_DISABLED>; + fsps,spi2-enable = <SPIX_ENABLE_DISABLED>; + fsps,sdio-enabled = <0>; + ... +};
Hi Bernhard,
On Thu, 30 Apr 2020 at 03:16, Bernhard Messerklinger bernhard.messerklinger@br-automation.com wrote:
A the moment the FSP configuration is a mix of hard coded values and devicetree properties. This patch makes FSP-M and FSP-S full configurable from devicetree by adding binding properties for all FSP parameters.
Co-developed-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com Signed-off-by: Bernhard Messerklinger bernhard.messerklinger@br-automation.com
arch/x86/cpu/apollolake/Makefile | 1 + arch/x86/cpu/apollolake/fsp_bindings.c | 2096 +++++++++++++++++ arch/x86/cpu/apollolake/fsp_m.c | 164 +- arch/x86/cpu/apollolake/fsp_s.c | 382 +-- arch/x86/dts/chromebook_coral.dts | 72 +- .../asm/arch-apollolake/fsp/fsp_m_upd.h | 168 ++ .../asm/arch-apollolake/fsp/fsp_s_upd.h | 202 ++ .../asm/arch-apollolake/fsp_bindings.h | 74 + .../fsp/fsp2/apollolake/fsp-m.txt | 320 +++ .../fsp/fsp2/apollolake/fsp-s.txt | 483 ++++ 10 files changed, 3422 insertions(+), 540 deletions(-) create mode 100644 arch/x86/cpu/apollolake/fsp_bindings.c create mode 100644 arch/x86/include/asm/arch-apollolake/fsp_bindings.h create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-m.txt create mode 100644 doc/device-tree-bindings/fsp/fsp2/apollolake/fsp-s.txt
Tested on coral: Tested-by: Simon Glass sjg@chromium.org
This looks good to me. I wonder if one day the binding table could be created from the binding .txt file, or compared with it programmatically?
diff --git a/arch/x86/cpu/apollolake/Makefile b/arch/x86/cpu/apollolake/Makefile index 578e15c4bf..3aa2a55676 100644 --- a/arch/x86/cpu/apollolake/Makefile +++ b/arch/x86/cpu/apollolake/Makefile @@ -10,6 +10,7 @@ obj-y += cpu_common.o ifndef CONFIG_TPL_BUILD obj-y += cpu.o obj-y += punit.o +obj-y += fsp_bindings.o ifdef CONFIG_SPL_BUILD obj-y += fsp_m.o endif diff --git a/arch/x86/cpu/apollolake/fsp_bindings.c b/arch/x86/cpu/apollolake/fsp_bindings.c new file mode 100644 index 0000000000..9c10e7328a --- /dev/null +++ b/arch/x86/cpu/apollolake/fsp_bindings.c @@ -0,0 +1,2096 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright 2020 B&R Industrial Automation GmbH - http://www.br-automation.com
+#include <common.h> +#include <dm.h> +#include <asm/arch/fsp_bindings.h>
Please add comments to these functions
+static void read_u8_prop(ofnode node, u8 *dst, char *name, size_t count) +{
u32 tmp;
const u8 *buf;
int ret;
if (count == 0) {
ret = ofnode_read_u32(node, name, &tmp);
if (ret == 0)
*dst = tmp;
} else {
buf = ofnode_read_u8_array_ptr(node, name, count);
if (buf)
memcpy(dst, buf, count);
+static void read_u16_prop(ofnode node, u16 *dst, char *name, size_t count) +{
u32 tmp;
u32 buf[32];
int ret;
if (ARRAY_SIZE(buf) < count) {
printf("ERROR: %s buffer to small!\n", __func__);
too Can this be debug?
return;
Needs a return value to report the error, perhaps -ENOSPC?
if (count == 0) {
if (ret == 0)
*dst = tmp;
} else {
ret = ofnode_read_u32_array(node, name, buf, count);
if (ret == 0)
for (int i = 0; i < count; i++)
dst[i] = buf[i];
+static void read_u32_prop(ofnode node, u32 *dst, char *name, size_t count) +{
if (count == 0)
ofnode_read_u32(node, name, dst);
else
ofnode_read_u32_array(node, name, dst, count);
+static void read_string_prop(ofnode node, char *dst, char *name, int count) +{
const char *string_buf;
if (count > 0) {
string_buf = ofnode_read_string(node, name);
if (string_buf) {
strncpy(dst, string_buf, count);
strlcpy does these two lines
dst[count - 1] = '\0';
+static void read_swizzle_prop(ofnode node, u8 *dst, char *name, int count) +{
const struct lpddr4_chan_swizzle_cfg *sch;
/* Number of bytes to copy per DQS */
const size_t sz = DQ_BITS_PER_DQS;
const struct lpddr4_swizzle_cfg *swizzle_cfg;
swizzle_cfg = (const struct lpddr4_swizzle_cfg *)
if (!swizzle_cfg)
return;
* CH0_DQB byte lanes in the bit swizzle configuration field are
* not 1:1. The mapping within the swizzling field is:
* indices [0:7] - byte lane 1 (DQS1) DQ[8:15]
* indices [8:15] - byte lane 0 (DQS0) DQ[0:7]
* indices [16:23] - byte lane 3 (DQS3) DQ[24:31]
* indices [24:31] - byte lane 2 (DQS2) DQ[16:23]
sch = &swizzle_cfg->phys[LP4_PHYS_CH0B];
memcpy(&dst[0 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz);
memcpy(&dst[1 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz);
memcpy(&dst[2 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz);
memcpy(&dst[3 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz);
* CH0_DQA byte lanes in the bit swizzle configuration field are 1:1.
sch = &swizzle_cfg->phys[LP4_PHYS_CH0A];
memcpy(&dst[4 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz);
memcpy(&dst[5 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz);
memcpy(&dst[6 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz);
memcpy(&dst[7 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz);
sch = &swizzle_cfg->phys[LP4_PHYS_CH1B];
memcpy(&dst[8 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz);
memcpy(&dst[9 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz);
memcpy(&dst[10 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz);
memcpy(&dst[11 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz);
sch = &swizzle_cfg->phys[LP4_PHYS_CH1A];
memcpy(&dst[12 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS0], sz);
memcpy(&dst[13 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS1], sz);
memcpy(&dst[14 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS2], sz);
memcpy(&dst[15 * DQ_BITS_PER_DQS], &sch->dqs[LP4_DQS3], sz);
+static void fsp_update_config_from_dtb(ofnode node, u8 *cfg,
const struct fsp_binding *fsp_bindings)
Needs a return value as it can fail with read_u16_prop
How about having a local var here, e.g.
for (int i = 0; fsp_bindings[i].propname; i++) {
struct fsp_binding *fspb = fsp_bindings;
so you can use fspb instead of fsp_bindings[i] everywhere in this function
switch (fsp_bindings[i].type) {
case FSP_UINT8:
read_u8_prop(node, &cfg[fsp_bindings[i].offset],
fsp_bindings[i].propname,
fsp_bindings[i].count);
break;
case FSP_UINT16:
read_u16_prop(node,
(u16 *)&cfg[fsp_bindings[i].offset],
break;
case FSP_UINT32:
read_u32_prop(node,
(u32 *)&cfg[fsp_bindings[i].offset],
break;
case FSP_STRING:
read_string_prop(node, (char *)
break;
case FSP_LPDDR4_SWIZZLE:
read_swizzle_prop(node,
break;
+#if defined(CONFIG_SPL_BUILD)
Do you need these #ifs? I would hope the compiler would only include them if needed.
+const struct fsp_binding fsp_m_bindings[] = {
.type = FSP_UINT32,
.offset = offsetof(struct fsp_m_config, serial_debug_port_address),
.propname = "fspm,serial-debug-port-address",
Put } on previous line, so }, {
.type = FSP_UINT8,
.offset = offsetof(struct fsp_m_config, serial_debug_port_type),
.propname = "fspm,serial-debug-port-type",
.type = FSP_UINT8,
diff --git a/arch/x86/cpu/apollolake/fsp_m.c b/arch/x86/cpu/apollolake/fsp_m.c index 5308af8ed4..2e63062102 100644 --- a/arch/x86/cpu/apollolake/fsp_m.c +++ b/arch/x86/cpu/apollolake/fsp_m.c @@ -9,180 +9,28 @@ #include <asm/arch/iomap.h> #include <asm/arch/fsp/fsp_configs.h> #include <asm/arch/fsp/fsp_m_upd.h>
Looks like those two headers can dropped?
+#include <asm/arch/fsp_bindings.h> #include <asm/fsp2/fsp_internal.h> #include <dm/uclass-internal.h>
Drop extra blank line
int fspm_update_config(struct udevice *dev, struct fspm_upd *upd) { struct fsp_m_config *cfg = &upd->config; struct fspm_arch_upd *arch = &upd->arch;
ofnode node; arch->nvs_buffer_ptr = NULL; prepare_mrc_cache(upd); arch->stack_base = (void *)0xfef96000; arch->boot_loader_tolum_size = 0;
- Copyright 2019 Google LLC
+enum conf_type {
FSP_UINT8,
FSP_UINT16,
FSP_UINT32,
FSP_STRING,
FSP_LPDDR4_SWIZZLE,
struct comment
size_t offset;
char *propname;
size_t count;
- LPDDR4 helper routines for configuring the memory UPD for LPDDR4 operation.
- There are four physical LPDDR4 channels, each 32-bits wide. There are two
- logical channels using two physical channels together to form a 64-bit
- interface to memory for each logical channel.
+enum {
LP4_PHYS_CH0A,
LP4_PHYS_CH0B,
LP4_PHYS_CH1A,
LP4_PHYS_CH1B,
- The DQs within a physical channel can be bit-swizzled within each byte.
- Within a channel the bytes can be swapped, but the DQs need to be routed
- with the corresponding DQS (strobe).
+enum {
LP4_DQS0,
LP4_DQS1,
LP4_DQS2,
LP4_DQS3,
LP4_NUM_BYTE_LANES,
function comments
Hi Simon,
Hi Bernhard,
and
by
create mode 100644
create mode 100644
Yes that's true. But at the moment its just copy paste. I generated the binding table from the fsp_s and fsp_m config struct with a python script. But this script is also far from being finished.
Without the #ifs the SPL size stays the same but the u-boot proper size increases by about 2 kb.
*cfg);
function comments
Regards, Bernhard
Hi Bernhard,
On Thu, 7 May 2020 at 01:53, Bernhard Messerklinger bernhard.messerklinger@br-automation.com wrote:
Hi Simon,
Hi Bernhard,
and
by
create mode 100644
create mode 100644
OK thanks.
OK, well then we need the #ifs.
BTW next time you send this you could take off the RFC as I think we should apply this.
