[U-Boot] [PATCH] ARM: OMAP4+: Move external phy initialisations to arch specific place.
The external phy is present in the case OMAP5 soc is currently configured in emif-common.c. This results in having dummy structures for those Socs which do not have a external phy. So by having a weak function in emif-common and overriding it in OMAP5, avoids the use of dummy structures.
Signed-off-by: R Sricharan r.sricharan@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 32 +++++--------------------- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 3 -- arch/arm/cpu/armv7/omap5/sdram.c | 31 +++++++++++++++++++++++++ arch/arm/include/asm/emif.h | 2 + 4 files changed, 39 insertions(+), 29 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index db509c9..278162d 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -31,6 +31,7 @@ #include <asm/arch/sys_proto.h> #include <asm/omap_common.h> #include <asm/utils.h> +#include <linux/compiler.h>
inline u32 emif_num(u32 base) { @@ -114,9 +115,6 @@ static void do_lpddr2_init(u32 base, u32 cs) static void lpddr2_init(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; - u32 *ext_phy_ctrl_base = 0; - u32 *emif_ext_phy_ctrl_base = 0; - u32 i = 0;
/* Not NVM */ clrbits_le32(&emif->emif_lpddr2_nvm_config, EMIF_REG_CS1NVMEN_MASK); @@ -134,29 +132,7 @@ static void lpddr2_init(u32 base, const struct emif_regs *regs) writel(regs->sdram_config_init, &emif->emif_sdram_config); writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1);
- ext_phy_ctrl_base = (u32 *) &(regs->emif_ddr_ext_phy_ctrl_1); - emif_ext_phy_ctrl_base = (u32 *) &(emif->emif_ddr_ext_phy_ctrl_1); - - if (omap_revision() >= OMAP5430_ES1_0) { - /* Configure external phy control timing registers */ - for (i = 0; i < EMIF_EXT_PHY_CTRL_TIMING_REG; i++) { - writel(*ext_phy_ctrl_base, emif_ext_phy_ctrl_base++); - /* Update shadow registers */ - writel(*ext_phy_ctrl_base++, emif_ext_phy_ctrl_base++); - } - - /* - * external phy 6-24 registers do not change with - * ddr frequency - */ - for (i = 0; i < EMIF_EXT_PHY_CTRL_CONST_REG; i++) { - writel(ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); - /* Update shadow registers */ - writel(ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); - } - } + do_ext_phy_settings(base, regs);
do_lpddr2_init(base, CS0); if (regs->sdram_config & EMIF_REG_EBANK_MASK) @@ -168,6 +144,10 @@ static void lpddr2_init(u32 base, const struct emif_regs *regs) /* Enable refresh now */ clrbits_le32(&emif->emif_sdram_ref_ctrl, EMIF_REG_INITREF_DIS_MASK);
+ } + +__weak void do_ext_phy_settings(u32 base, const struct emif_regs *regs) +{ }
void emif_update_timings(u32 base, const struct emif_regs *regs) diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index b538960..8761bc2 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -90,9 +90,6 @@ const struct emif_regs emif_regs_elpida_400_mhz_2cs = { .emif_ddr_phy_ctlr_1 = 0x049ff418 };
-/* Dummy registers for OMAP44xx */ -const u32 ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG]; - const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { .dmm_lisa_map_0 = 0xFF020100, .dmm_lisa_map_1 = 0, diff --git a/arch/arm/cpu/armv7/omap5/sdram.c b/arch/arm/cpu/armv7/omap5/sdram.c index b2b5753..c1cf6f1 100644 --- a/arch/arm/cpu/armv7/omap5/sdram.c +++ b/arch/arm/cpu/armv7/omap5/sdram.c @@ -156,6 +156,37 @@ void emif_get_device_details(u32 emif_nr,
#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
+void do_ext_phy_settings(u32 base, const struct emif_regs *regs) +{ + u32 *ext_phy_ctrl_base = 0; + u32 *emif_ext_phy_ctrl_base = 0; + u32 i = 0; + + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + ext_phy_ctrl_base = (u32 *) &(regs->emif_ddr_ext_phy_ctrl_1); + emif_ext_phy_ctrl_base = (u32 *) &(emif->emif_ddr_ext_phy_ctrl_1); + + /* Configure external phy control timing registers */ + for (i = 0; i < EMIF_EXT_PHY_CTRL_TIMING_REG; i++) { + writel(*ext_phy_ctrl_base, emif_ext_phy_ctrl_base++); + /* Update shadow registers */ + writel(*ext_phy_ctrl_base++, emif_ext_phy_ctrl_base++); + } + + /* + * external phy 6-24 registers do not change with + * ddr frequency + */ + for (i = 0; i < EMIF_EXT_PHY_CTRL_CONST_REG; i++) { + writel(ext_phy_ctrl_const_base[i], + emif_ext_phy_ctrl_base++); + /* Update shadow registers */ + writel(ext_phy_ctrl_const_base[i], + emif_ext_phy_ctrl_base++); + } +} + #ifndef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS static const struct lpddr2_ac_timings timings_jedec_532_mhz = { .max_freq = 532000000, diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index f1e3ad2..e6ef6ea 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -1093,6 +1093,8 @@ void emif_get_device_timings(u32 emif_nr, const struct lpddr2_device_timings **cs1_device_timings); #endif
+void do_ext_phy_settings(u32 base, const struct emif_regs *regs); + #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS extern u32 *const T_num; extern u32 *const T_den;
Queued up for u-boot-ti/master, thanks!
R Sricharan
