[PATCH v3 5/5] arm: dts: rockchip: rk3128: fix clocks, compatible and phys
Fix rk3128 clocks, compatible and phys, so that they match the bindings.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- arch/arm/dts/rk3128.dtsi | 46 +++++++++++++++++----------------------- 1 file changed, 19 insertions(+), 27 deletions(-)
diff --git a/arch/arm/dts/rk3128.dtsi b/arch/arm/dts/rk3128.dtsi index 48833bff..3253c640 100644 --- a/arch/arm/dts/rk3128.dtsi +++ b/arch/arm/dts/rk3128.dtsi @@ -180,7 +180,6 @@
xin12m: xin12m { compatible = "fixed-clock"; - clocks = <&xin24m>; clock-frequency = <12000000>; clock-output-names = "xin12m"; #clock-cells = <0>; @@ -202,9 +201,9 @@ };
watchdog: watchdog@2004c000 { - compatible = "rockchip,watch dog"; + compatible = "rockchip,rk3128-wdt", "snps,dw-wdt"; reg = <0x2004c000 0x100>; - clock-names = "pclk_wdt"; + clocks = <&cru PCLK_WDT>; interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; rockchip,irq = <1>; rockchip,timeout = <60>; @@ -219,21 +218,20 @@ };
nandc: nand-controller@10500000 { - compatible = "rockchip,rk-nandc"; + compatible = "rockchip,rk3128-nfc", "rockchip,rk2928-nfc"; reg = <0x10500000 0x4000>; interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&nandc_ale &nandc_cle &nandc_wrn &nandc_rdn &nandc_rdy &nandc_cs0 &nandc_data>; - nandc_id = <0>; - clocks = <&cru SCLK_NANDC>, - <&cru HCLK_NANDC>, - <&cru SRST_NANDC>; - clock-names = "clk_nandc", "g_clk_nandc", "hclk_nandc"; + clocks = <&cru HCLK_NANDC>, <&cru SCLK_NANDC>; + clock-names = "ahb", "nfc"; };
cru: clock-controller@20000000 { compatible = "rockchip,rk3128-cru"; reg = <0x20000000 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; rockchip,grf = <&grf>; #clock-cells = <1>; #reset-cells = <1>; @@ -305,7 +303,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm0_pin>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; };
pwm1: pwm@20050010 { @@ -315,7 +312,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm1_pin>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; };
pwm2: pwm@20050020 { @@ -325,7 +321,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm2_pin>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; };
pwm3: pwm@20050030 { @@ -335,7 +330,6 @@ pinctrl-names = "default"; pinctrl-0 = <&pwm3_pin>; clocks = <&cru PCLK_PWM>; - clock-names = "pwm"; };
sram: sram@10080400 { @@ -364,7 +358,7 @@ interrupts = <GIC_PPI 9 0xf04>; };
- u2phy: usb2-phy { + u2phy: usb2phy { compatible = "rockchip,rk3128-usb2phy"; reg = <0x017c 0x0c>; rockchip,grf = <&grf>; @@ -372,7 +366,6 @@ clock-names = "phyclk"; #clock-cells = <0>; clock-output-names = "usb480m_phy"; - #phy-cells = <1>; status = "disabled";
u2phy_otg: otg-port { @@ -394,15 +387,14 @@ };
usb_otg: usb@10180000 { - compatible = "rockchip,rk3128-usb", "rockchip,rk3288-usb", - "snps,dwc2"; + compatible = "rockchip,rk3128-usb", "rockchip,rk3066-usb", "snps,dwc2"; reg = <0x10180000 0x40000>; interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_OTG>; + clock-names = "otg"; dr_mode = "otg"; - g-use-dma; - hnp-srp-disable; - phys = <&u2phy 0>; - phy-names = "usb"; + phys = <&u2phy_otg>; + phy-names = "usb2-phy"; status = "disabled"; };
@@ -410,7 +402,7 @@ compatible = "generic-ehci"; reg = <0x101c0000 0x20000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - phys = <&u2phy 1>; + phys = <&u2phy_host>; phy-names = "usb"; status = "disabled"; }; @@ -419,19 +411,19 @@ compatible = "generic-ohci"; reg = <0x101e0000 0x20000>; interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - phys = <&u2phy 1>; + phys = <&u2phy_host>; phy-names = "usb"; status = "disabled"; };
sdmmc: mmc@10214000 { - compatible = "rockchip,rk312x-dw-mshc", "rockchip,rk3288-dw-mshc"; + compatible = "rockchip,rk3128-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x10214000 0x4000>; max-frequency = <150000000>; interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; fifo-depth = <0x100>; pinctrl-names = "default"; pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; @@ -446,7 +438,7 @@ interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu_drv", "ciu_sample"; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; bus-width = <8>; default-sample-phase = <158>; num-slots = <1>; @@ -507,7 +499,7 @@ };
spi0: spi@20074000 { - compatible = "rockchip,rk3128-spi", "rockchip,rk3288-spi"; + compatible = "rockchip,rk3128-spi", "rockchip,rk3066-spi"; reg = <0x20074000 0x1000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; #address-cells = <1>;
Johan Jonker
