[PATCH] arm: mvebu: Espressobin: Instructions for more MAC addresses in README.marvell
Some Espressobin boards got assigned more than one MAC address. Update instructions how to correctly store and preserve all MAC addresses.
Signed-off-by: Pali Rohár pali@kernel.org --- doc/README.marvell | 23 +++++++++++++++++------ 1 file changed, 17 insertions(+), 6 deletions(-)
diff --git a/doc/README.marvell b/doc/README.marvell index 5416bc3035..6fc5ac8a40 100644 --- a/doc/README.marvell +++ b/doc/README.marvell @@ -27,7 +27,7 @@ Build Procedure - For the Armada-70x0/80x0 DB board use "mvebu_db_armada8k_defconfig" - For the Armada-80x0 MacchiatoBin use "make mvebu_mcbin-88f8040_defconfig" - For the Armada-3700 DB board use "make mvebu_db-88f3720_defconfig" - - For the Armada-3700 EsspressoBin use "make mvebu_espressobin-88f3720_defconfig" + - For the Armada-3700 EspressoBin use "make mvebu_espressobin-88f3720_defconfig"
5. Configure the device-tree and build the U-Boot image:
@@ -62,11 +62,15 @@ Configuration update Permanent ethernet MAC address ------------------------------- Prior flashing new U-Boot version (as part of ATF image) it is suggested to backup - permanent ethernet MAC address as it is stored only in U-Boot env storage (SPI or eMMC). - Some boards like EspressoBin have MAC address printed on sticker. To print current MAC - address run: + permanent ethernet MAC addresses as they are stored only in U-Boot env storage (SPI or eMMC). + Some boards like EspressoBin have MAC addresses printed on sticker. Some boards got assigned + only one address other may also more than one. To print current MAC addresses run:
# echo $ethaddr + # echo $eth1addr + # echo $eth2addr + # echo $eth3addr + # ...
MAC addresses 00:51:82:11:22:00, 00:51:82:11:22:01, 00:51:82:11:22:02, 00:51:82:11:22:03 and F0:AD:4E:03:64:7F are default hardcoded values found in Marvell's and Armbian U-Boot @@ -75,13 +79,20 @@ Permanent ethernet MAC address suggested to generate new random one.
After flashing new U-Boot version it is suggested to reset U-Boot env variables to default - and then set correct permanent ethernet MAC address. + and then set correct permanent ethernet MAC addresses.
# env default -a # setenv ethaddr XX:XX:XX:XX:XX:XX + # setenv eth1addr XX:XX:XX:XX:XX:XX + # setenv eth2addr YY:YY:YY:YY:YY:YY + # setenv eth3addr ZZ:ZZ:ZZ:ZZ:ZZ:ZZ + # ... # saveenv
- Where XX:XX:XX:XX:XX:XX is permanent ethernet MAC address. + Where value for ethaddr is required permanent ethernet MAC address and values for ethNaddr + are optional per-port MAC addresses. When optional ethNaddr variables are not defined then + they are inherited from required ethaddr variable. eth1addr contains MAC address for the + wan port, other for particular lan ports.
Recent Linux kernel versions use correct permanent ethernet MAC address from U-Boot env as U-Boot will inject it into kernel's device-tree.
- Configure the device-tree and build the U-Boot image:
- address run:
# echo $ethaddr
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
# saveenv
- Where value for ethaddr is required permanent ethernet MAC address and values for ethNaddr
- are optional per-port MAC addresses. When optional ethNaddr variables are not defined then
- they are inherited from required ethaddr variable. eth1addr contains MAC address for the
- wan port, other for particular lan ports.
I never tried, what does "inherit" mean? eth1addr=$ethaddr+1 and so on?
And would port1=wan be correct for v7?
- address run:
- permanent ethernet MAC addresses as they are stored only in U-Boot env storage (SPI or eMMC).
- Some boards like EspressoBin have MAC addresses printed on sticker. Some boards got assigned
- only one address other may also more than one. To print current MAC addresses run: # echo $ethaddr
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
MAC addresses 00:51:82:11:22:00, 00:51:82:11:22:01, 00:51:82:11:22:02, 00:51:82:11:22:03 and F0:AD:4E:03:64:7F are default hardcoded values found in Marvell's and Armbian U-Boot# ...
@@ -75,13 +79,20 @@ Permanent ethernet MAC address suggested to generate new random one. After flashing new U-Boot version it is suggested to reset U-Boot env variables to default
- and then set correct permanent ethernet MAC addresses. # env default -a # setenv ethaddr XX:XX:XX:XX:XX:XX
# saveenv# ...
It means that address for DSA port is same as address for main ethernet adapter (ethaddr). So ethNaddr = $ethaddr
Yes.
https://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu.git/diff/arch...
eth1addr is set to ethernet1 and ethernet1 is alias for &switch0port3 for V7. And switch0port3 is wan on V7.
- address run:
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
# ... # saveenv
Okay, nice.
Yes.
For Linux, yes. But I meant u-boot, we don't have a v7 dts there. Doesn't that matter?
- address run:
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
# ... # saveenv
Okay, nice.
Yes.
No, it does not matter. U-Boot loads DTB file supplied by user/boot script and inserts MAC address into it. So if user boots this U-Boot on V7 board and supply kernel's V7 DTB file then U-Boot inserts WAN mac address into ethernet1 alias which is linked to switch0port3 (wan).
So I think it is correct.
We do not need any V7 DTS file in U-Boot.
Reviewed-by: Andre Heider a.heider@gmail.com
- address run:
# echo $ethaddr
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
# saveenv
Applied to u-boot-marvell/master
Thanks, Stefan
- address run:
# echo $ethaddr
# echo $eth1addr
# echo $eth2addr
# echo $eth3addr
# saveenv
Viele Grüße, Stefan
Andre Heider
Pali Rohár
Stefan Roese
