[PATCH 1/2] powerpc: dts: p2020: Sort DT nodes by their addresses
No functional change.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 89 ++++++++++++++++---------------- 1 file changed, 45 insertions(+), 44 deletions(-)
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index 0d0cd2273cd4..3351874b5389 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -13,49 +13,6 @@ compatible = "fsl,p2020-immr", "simple-bus"; bus-frequency = <0x0>;
- usb@22000 { - compatible = "fsl-usb2-dr-v1.6", "fsl-usb2-dr"; - reg = <0x22000 0x1000>; - #address-cells = <1>; - #size-cells = <0>; - interrupts = <28 0x2 0 0>; - phy_type = "ulpi"; - }; - - mpic: pic@40000 { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <4>; - reg = <0x40000 0x40000>; - compatible = "fsl,mpic"; - device_type = "open-pic"; - big-endian; - single-cpu-affinity; - last-interrupt-source = <255>; - }; - - esdhc: sdhc@2e000 { - compatible = "fsl,p2020-esdhc", "fsl,esdhc"; - reg = <0x2e000 0x1000>; - interrupts = <72 0x2 0 0>; - /* Filled in by U-Boot */ - clock-frequency = <0>; - }; - - espi0: spi@7000 { - compatible = "fsl,mpc8536-espi"; - #address-cells = <1>; - #size-cells = <0>; - reg = <0x7000 0x1000>; - interrupts = < 0x3b 0x02 0x00 0x00 >; - fsl,espi-num-chipselects = <4>; - }; - -/include/ "pq3-i2c-0.dtsi" -/include/ "pq3-i2c-1.dtsi" -/include/ "pq3-duart-0.dtsi" -/include/ "pq3-gpio-0.dtsi" - ecm-law@0 { compatible = "fsl,ecm-law"; reg = <0x0 0x1000>; @@ -74,6 +31,22 @@ interrupts = <18 2 0 0>; };
+/include/ "pq3-i2c-0.dtsi" +/include/ "pq3-i2c-1.dtsi" +/include/ "pq3-duart-0.dtsi" + + espi0: spi@7000 { + compatible = "fsl,mpc8536-espi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x7000 0x1000>; + interrupts = < 0x3b 0x02 0x00 0x00 >; + fsl,espi-num-chipselects = <4>; + }; + +/include/ "pq3-dma-1.dtsi" +/include/ "pq3-gpio-0.dtsi" + L2: l2-cache-controller@20000 { compatible = "fsl,p2020-l2-cache-controller"; reg = <0x20000 0x1000>; @@ -83,7 +56,15 @@ };
/include/ "pq3-dma-0.dtsi" -/include/ "pq3-dma-1.dtsi" + + usb@22000 { + compatible = "fsl-usb2-dr-v1.6", "fsl-usb2-dr"; + reg = <0x22000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <28 0x2 0 0>; + phy_type = "ulpi"; + };
/include/ "pq3-etsec1-0.dtsi" /include/ "pq3-etsec1-timer-0.dtsi" @@ -95,10 +76,30 @@ /include/ "pq3-etsec1-1.dtsi" /include/ "pq3-etsec1-2.dtsi"
+ esdhc: sdhc@2e000 { + compatible = "fsl,p2020-esdhc", "fsl,esdhc"; + reg = <0x2e000 0x1000>; + interrupts = <72 0x2 0 0>; + /* Filled in by U-Boot */ + clock-frequency = <0>; + }; + /include/ "pq3-sec3.1-0.dtsi" /include/ "pq3-mpic.dtsi" /include/ "pq3-mpic-timer-B.dtsi"
+ mpic: pic@40000 { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <4>; + reg = <0x40000 0x40000>; + compatible = "fsl,mpic"; + device_type = "open-pic"; + big-endian; + single-cpu-affinity; + last-interrupt-source = <255>; + }; + global-utilities@e0000 { compatible = "fsl,p2020-guts"; reg = <0xe0000 0x1000>;
DT node pic@40000 is defined explicitly in p2020-post.dtsi file and also transitionally via include file pq3-mpic.dtsi. Remove duplicate definition from p2020-post.dtsi.
No change in final DTB file.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/powerpc/dts/p2020-post.dtsi | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/arch/powerpc/dts/p2020-post.dtsi b/arch/powerpc/dts/p2020-post.dtsi index 3351874b5389..ea215ab075fe 100644 --- a/arch/powerpc/dts/p2020-post.dtsi +++ b/arch/powerpc/dts/p2020-post.dtsi @@ -88,18 +88,6 @@ /include/ "pq3-mpic.dtsi" /include/ "pq3-mpic-timer-B.dtsi"
- mpic: pic@40000 { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <4>; - reg = <0x40000 0x40000>; - compatible = "fsl,mpic"; - device_type = "open-pic"; - big-endian; - single-cpu-affinity; - last-interrupt-source = <255>; - }; - global-utilities@e0000 { compatible = "fsl,p2020-guts"; reg = <0xe0000 0x1000>;
Pali Rohár
