[PATCH] JFFS2: fix jffs2 summary datacrc status uninitialized
The function jffs2_1pass_read_inode() was discarding the summary inodes and dirent because the value in datacrc flag wasn't initialized in function jffs2_sum_process_sum_data().
This fix initializes the status of all summary records to indicate that the CRC needs to be verified when they are loaded.
Before this fix, the behaviors produced by the undefined value of datacrc was: - Summary's registries were discarded when 'b->datacrc' is equal as 'CRC_BAD'. - Summary's registries were not checked when b->datacrc differs of 'CRC_BAD' and 'CRC_UNKNOWN'
So, almost all of the time the crc just isn't checked, and in some cases the registries are discarded.
Signed-off-by: Wagner Popov dos Santos wpopov@gmail.com --- fs/jffs2/jffs2_1pass.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/fs/jffs2/jffs2_1pass.c b/fs/jffs2/jffs2_1pass.c index a98745c50e..c9eda54cdb 100644 --- a/fs/jffs2/jffs2_1pass.c +++ b/fs/jffs2/jffs2_1pass.c @@ -1276,6 +1276,7 @@ static int jffs2_sum_process_sum_data(struct part_info *part, uint32_t offset, &spi->version); b->ino = sum_get_unaligned32( &spi->inode); + b->datacrc = CRC_UNKNOWN; }
sp += JFFS2_SUMMARY_INODE_SIZE; @@ -1297,6 +1298,7 @@ static int jffs2_sum_process_sum_data(struct part_info *part, uint32_t offset, &spd->version); b->pino = sum_get_unaligned32( &spd->pino); + b->datacrc = CRC_UNKNOWN; }
sp += JFFS2_SUMMARY_DIRENT_SIZE(
Forgot to Cc the maintainer, doing it now, sorry for the spam.
b->datacrc = CRC_UNKNOWN; } sp += JFFS2_SUMMARY_INODE_SIZE;
b->datacrc = CRC_UNKNOWN; } sp += JFFS2_SUMMARY_DIRENT_SIZE(
