[U-Boot] [PATCH 0/5] ARM: uniphier: UniPhier updates (round 3) for v2016.11-rc1
- Add PLL init code for LD11 SoC - Cleanup clk driver - Sync Device Trees
Masahiro Yamada (5): ARM: uniphier: add PLL init code for LD11 SoC clk: uniphier: constify clock data arrays/structures clk: uniphier: move U_BOOT_DRIVER entry to core code clk: uniphier: allow to have clock node under syscon node ARM: dts: uniphier: sync clock/reset controller nodes with Linux
arch/arm/dts/uniphier-common32.dtsi | 56 ++++++++++++----- arch/arm/dts/uniphier-ph1-ld11.dtsi | 80 ++++++++++++++++------- arch/arm/dts/uniphier-ph1-ld20.dtsi | 75 ++++++++++++++++------ arch/arm/dts/uniphier-ph1-ld4.dtsi | 44 ++++++------- arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 2 +- arch/arm/dts/uniphier-ph1-pro4.dtsi | 38 ++++++----- arch/arm/dts/uniphier-ph1-pro5.dtsi | 38 +++++------ arch/arm/dts/uniphier-ph1-sld3-ref.dts | 4 -- arch/arm/dts/uniphier-ph1-sld3.dtsi | 59 +++++++++-------- arch/arm/dts/uniphier-ph1-sld8.dtsi | 44 ++++++------- arch/arm/dts/uniphier-proxstream2-gentil.dts | 2 +- arch/arm/dts/uniphier-proxstream2-vodka.dts | 2 +- arch/arm/dts/uniphier-proxstream2.dtsi | 38 +++++------ arch/arm/mach-uniphier/board_init.c | 1 + arch/arm/mach-uniphier/clk/Makefile | 5 +- arch/arm/mach-uniphier/clk/dpll-ld11.c | 16 +++++ arch/arm/mach-uniphier/clk/pll-ld11.c | 32 ++++++++++ arch/arm/mach-uniphier/init.h | 2 + arch/arm/mach-uniphier/init/init-ld11.c | 6 +- arch/arm/mach-uniphier/sc64-regs.h | 16 ++++- drivers/clk/uniphier/clk-uniphier-core.c | 94 ++++++++++++++++++++++------ drivers/clk/uniphier/clk-uniphier-mio.c | 51 +-------------- drivers/clk/uniphier/clk-uniphier.h | 18 +----- 23 files changed, 453 insertions(+), 270 deletions(-) create mode 100644 arch/arm/mach-uniphier/clk/dpll-ld11.c create mode 100644 arch/arm/mach-uniphier/clk/pll-ld11.c
- Initialize PLLs (SPL initializes only DPLL to save the precious SPL memory footprint) - Adjust CPLL/MPLL to the final tape-out frequency - Accelerate the Cortex-A53 clock to the maximum frequency since it is running at 500MHz (SPLL/4) on startup
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/board_init.c | 1 + arch/arm/mach-uniphier/clk/Makefile | 5 +++-- arch/arm/mach-uniphier/clk/dpll-ld11.c | 16 ++++++++++++++++ arch/arm/mach-uniphier/clk/pll-ld11.c | 32 ++++++++++++++++++++++++++++++++ arch/arm/mach-uniphier/init.h | 2 ++ arch/arm/mach-uniphier/init/init-ld11.c | 6 ++++-- arch/arm/mach-uniphier/sc64-regs.h | 16 +++++++++++++--- 7 files changed, 71 insertions(+), 7 deletions(-) create mode 100644 arch/arm/mach-uniphier/clk/dpll-ld11.c create mode 100644 arch/arm/mach-uniphier/clk/pll-ld11.c
diff --git a/arch/arm/mach-uniphier/board_init.c b/arch/arm/mach-uniphier/board_init.c index b57a33f..b9be52f 100644 --- a/arch/arm/mach-uniphier/board_init.c +++ b/arch/arm/mach-uniphier/board_init.c @@ -128,6 +128,7 @@ int board_init(void) sg_set_pinsel(153, 14, 8, 4); /* XIRQ4 -> XIRQ4 */ sg_set_iectrl(153); led_puts("U1"); + uniphier_ld11_pll_init(); uniphier_ld11_clk_init(); break; #endif diff --git a/arch/arm/mach-uniphier/clk/Makefile b/arch/arm/mach-uniphier/clk/Makefile index c8d59ea..95f433e 100644 --- a/arch/arm/mach-uniphier/clk/Makefile +++ b/arch/arm/mach-uniphier/clk/Makefile @@ -11,7 +11,7 @@ obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += early-clk-ld4.o dpll-sld8.o obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += early-clk-pro5.o obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += early-clk-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += early-clk-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += early-clk-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_LD11) += early-clk-ld11.o dpll-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += early-clk-ld20.o dpll-ld20.o
else @@ -23,9 +23,10 @@ obj-$(CONFIG_ARCH_UNIPHIER_SLD8) += clk-ld4.o pll-ld4.o dpll-tail.o obj-$(CONFIG_ARCH_UNIPHIER_PRO5) += clk-pro5.o obj-$(CONFIG_ARCH_UNIPHIER_PXS2) += clk-pxs2.o obj-$(CONFIG_ARCH_UNIPHIER_LD6B) += clk-pxs2.o -obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-ld11.o +obj-$(CONFIG_ARCH_UNIPHIER_LD11) += clk-ld11.o pll-ld11.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += clk-ld20.o pll-ld20.o
endif
+obj-$(CONFIG_ARCH_UNIPHIER_LD11) += pll-base-ld20.o obj-$(CONFIG_ARCH_UNIPHIER_LD20) += pll-base-ld20.o diff --git a/arch/arm/mach-uniphier/clk/dpll-ld11.c b/arch/arm/mach-uniphier/clk/dpll-ld11.c new file mode 100644 index 0000000..7f0677c --- /dev/null +++ b/arch/arm/mach-uniphier/clk/dpll-ld11.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "../init.h" +#include "../sc64-regs.h" +#include "pll.h" + +int uniphier_ld11_dpll_init(const struct uniphier_board_data *bd) +{ + uniphier_ld20_sscpll_init(SC_DPLLCTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 2); + + return 0; +} diff --git a/arch/arm/mach-uniphier/clk/pll-ld11.c b/arch/arm/mach-uniphier/clk/pll-ld11.c new file mode 100644 index 0000000..8a4a748 --- /dev/null +++ b/arch/arm/mach-uniphier/clk/pll-ld11.c @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/io.h> + +#include "../init.h" +#include "../sc64-regs.h" +#include "pll.h" + +void uniphier_ld11_pll_init(void) +{ + uniphier_ld20_sscpll_init(SC_CPLLCTRL, 1960, 1, 2); /* 2000MHz -> 1960MHz */ + /* do nothing for SPLL */ + uniphier_ld20_sscpll_init(SC_MPLLCTRL, 1600, 1, 2); /* 1500MHz -> 1600MHz */ + uniphier_ld20_sscpll_init(SC_VSPLLCTRL, UNIPHIER_PLL_FREQ_DEFAULT, 0, 2); + + mdelay(1); + + uniphier_ld20_sscpll_ssc_en(SC_CPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_MPLLCTRL); + uniphier_ld20_sscpll_ssc_en(SC_VSPLLCTRL); + + uniphier_ld20_vpll27_init(SC_VPLL27FCTRL); + uniphier_ld20_vpll27_init(SC_VPLL27ACTRL); + + writel(0, SC_CA53_GEARSET); /* Gear0: CPLL/2 */ + writel(SC_CA_GEARUPD, SC_CA53_GEARUPD); +} diff --git a/arch/arm/mach-uniphier/init.h b/arch/arm/mach-uniphier/init.h index 5c7cd6b..4e3bee1 100644 --- a/arch/arm/mach-uniphier/init.h +++ b/arch/arm/mach-uniphier/init.h @@ -87,6 +87,7 @@ int uniphier_sld3_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld4_dpll_init(const struct uniphier_board_data *bd); int uniphier_pro4_dpll_init(const struct uniphier_board_data *bd); int uniphier_sld8_dpll_init(const struct uniphier_board_data *bd); +int uniphier_ld11_dpll_init(const struct uniphier_board_data *bd); int uniphier_ld20_dpll_init(const struct uniphier_board_data *bd);
int uniphier_ld4_early_clk_init(const struct uniphier_board_data *bd); @@ -105,6 +106,7 @@ int uniphier_ld11_umc_init(const struct uniphier_board_data *bd); void uniphier_sld3_pll_init(void); void uniphier_ld4_pll_init(void); void uniphier_pro4_pll_init(void); +void uniphier_ld11_pll_init(void); int uniphier_ld20_pll_init(const struct uniphier_board_data *bd);
void uniphier_ld4_clk_init(void); diff --git a/arch/arm/mach-uniphier/init/init-ld11.c b/arch/arm/mach-uniphier/init/init-ld11.c index 758df8d..e324c94 100644 --- a/arch/arm/mach-uniphier/init/init-ld11.c +++ b/arch/arm/mach-uniphier/init/init-ld11.c @@ -31,12 +31,14 @@ int uniphier_ld11_init(const struct uniphier_board_data *bd)
led_puts("L2");
- led_puts("L3"); - #ifdef CONFIG_SPL_SERIAL_SUPPORT preloader_console_init(); #endif
+ led_puts("L3"); + + uniphier_ld11_dpll_init(bd); + led_puts("L4");
{ diff --git a/arch/arm/mach-uniphier/sc64-regs.h b/arch/arm/mach-uniphier/sc64-regs.h index 1e52bb1..780fdd1 100644 --- a/arch/arm/mach-uniphier/sc64-regs.h +++ b/arch/arm/mach-uniphier/sc64-regs.h @@ -13,12 +13,14 @@ #define SC_BASE_ADDR 0x61840000
/* PLL type: SSC */ -#define SC_CPLLCTRL (SC_BASE_ADDR | 0x1400) /* LD20: CPU/ARM */ -#define SC_SPLLCTRL (SC_BASE_ADDR | 0x1410) /* LD20: misc */ +#define SC_CPLLCTRL (SC_BASE_ADDR | 0x1400) /* LD11/20: CPU/ARM */ +#define SC_SPLLCTRL (SC_BASE_ADDR | 0x1410) /* LD11/20: misc */ #define SC_SPLL2CTRL (SC_BASE_ADDR | 0x1420) /* LD20: IPP */ -#define SC_MPLLCTRL (SC_BASE_ADDR | 0x1430) /* LD20: Video codec */ +#define SC_MPLLCTRL (SC_BASE_ADDR | 0x1430) /* LD11/20: Video codec */ +#define SC_VSPLLCTRL (SC_BASE_ADDR | 0x1440) /* LD11 */ #define SC_VPPLLCTRL (SC_BASE_ADDR | 0x1440) /* LD20: VPE etc. */ #define SC_GPPLLCTRL (SC_BASE_ADDR | 0x1450) /* LD20: GPU/Mali */ +#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1460) /* LD11: DDR memory */ #define SC_DPLL0CTRL (SC_BASE_ADDR | 0x1460) /* LD20: DDR memory 0 */ #define SC_DPLL1CTRL (SC_BASE_ADDR | 0x1470) /* LD20: DDR memory 1 */ #define SC_DPLL2CTRL (SC_BASE_ADDR | 0x1480) /* LD20: DDR memory 2 */ @@ -61,4 +63,12 @@ #define SC_CLKCTRL7_UMC31 (1 << 1) #define SC_CLKCTRL7_UMC30 (1 << 0)
+#define SC_CA72_GEARST (SC_BASE_ADDR | 0x8080) +#define SC_CA72_GEARSET (SC_BASE_ADDR | 0x8084) +#define SC_CA72_GEARUPD (SC_BASE_ADDR | 0x8088) +#define SC_CA53_GEARST (SC_BASE_ADDR | 0x8080) +#define SC_CA53_GEARSET (SC_BASE_ADDR | 0x8084) +#define SC_CA53_GEARUPD (SC_BASE_ADDR | 0x8088) +#define SC_CA_GEARUPD (1 << 0) + #endif /* SC64_REGS_H */
Clarify these clock data are constant.
drivers/clk/uniphier/clk-uniphier-core.c | 6 +++--- drivers/clk/uniphier/clk-uniphier-mio.c | 6 +++--- drivers/clk/uniphier/clk-uniphier.h | 6 +++--- 3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/uniphier/clk-uniphier-core.c b/drivers/clk/uniphier/clk-uniphier-core.c index a91924e..721e59e 100644 --- a/drivers/clk/uniphier/clk-uniphier-core.c +++ b/drivers/clk/uniphier/clk-uniphier-core.c @@ -17,7 +17,7 @@ static int uniphier_clk_enable(struct clk *clk) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - struct uniphier_clk_gate_data *gate = priv->socdata->gate; + const struct uniphier_clk_gate_data *gate = priv->socdata->gate; unsigned int nr_gate = priv->socdata->nr_gate; void __iomem *reg; u32 mask, data, tmp; @@ -44,7 +44,7 @@ static int uniphier_clk_enable(struct clk *clk) static ulong uniphier_clk_get_rate(struct clk *clk) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - struct uniphier_clk_rate_data *rdata = priv->socdata->rate; + const struct uniphier_clk_rate_data *rdata = priv->socdata->rate; unsigned int nr_rdata = priv->socdata->nr_rate; void __iomem *reg; u32 mask, data; @@ -78,7 +78,7 @@ static ulong uniphier_clk_get_rate(struct clk *clk) static ulong uniphier_clk_set_rate(struct clk *clk, ulong rate) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); - struct uniphier_clk_rate_data *rdata = priv->socdata->rate; + const struct uniphier_clk_rate_data *rdata = priv->socdata->rate; unsigned int nr_rdata = priv->socdata->nr_rate; void __iomem *reg; u32 mask, data, tmp; diff --git a/drivers/clk/uniphier/clk-uniphier-mio.c b/drivers/clk/uniphier/clk-uniphier-mio.c index 2eea5eb..40c1b78 100644 --- a/drivers/clk/uniphier/clk-uniphier-mio.c +++ b/drivers/clk/uniphier/clk-uniphier-mio.c @@ -115,7 +115,7 @@ .data = 0x00020000, \ }
-static struct uniphier_clk_gate_data uniphier_mio_clk_gate[] = { +static const struct uniphier_clk_gate_data uniphier_mio_clk_gate[] = { UNIPHIER_MIO_CLK_GATE_SD(0, 0), UNIPHIER_MIO_CLK_GATE_SD(1, 1), UNIPHIER_MIO_CLK_GATE_SD(2, 2), /* for PH1-Pro4 only */ @@ -126,13 +126,13 @@ static struct uniphier_clk_gate_data uniphier_mio_clk_gate[] = { UNIPHIER_MIO_CLK_GATE_USB(3, 7), /* for PH1-sLD3 only */ };
-static struct uniphier_clk_rate_data uniphier_mio_clk_rate[] = { +static const struct uniphier_clk_rate_data uniphier_mio_clk_rate[] = { UNIPHIER_MIO_CLK_RATE_SD(0, 0), UNIPHIER_MIO_CLK_RATE_SD(1, 1), UNIPHIER_MIO_CLK_RATE_SD(2, 2), /* for PH1-Pro4 only */ };
-static struct uniphier_clk_soc_data uniphier_mio_clk_data = { +static const struct uniphier_clk_soc_data uniphier_mio_clk_data = { .gate = uniphier_mio_clk_gate, .nr_gate = ARRAY_SIZE(uniphier_mio_clk_gate), .rate = uniphier_mio_clk_rate, diff --git a/drivers/clk/uniphier/clk-uniphier.h b/drivers/clk/uniphier/clk-uniphier.h index 18aa888..4e9f7dc 100644 --- a/drivers/clk/uniphier/clk-uniphier.h +++ b/drivers/clk/uniphier/clk-uniphier.h @@ -27,9 +27,9 @@ struct uniphier_clk_rate_data { };
struct uniphier_clk_soc_data { - struct uniphier_clk_gate_data *gate; + const struct uniphier_clk_gate_data *gate; unsigned int nr_gate; - struct uniphier_clk_rate_data *rate; + const struct uniphier_clk_rate_data *rate; unsigned int nr_rate; };
@@ -48,7 +48,7 @@ struct uniphier_clk_soc_data { */ struct uniphier_clk_priv { void __iomem *base; - struct uniphier_clk_soc_data *socdata; + const struct uniphier_clk_soc_data *socdata; };
extern const struct clk_ops uniphier_clk_ops;
Move U_BOOT_DRIVER() entry from the data file (clk-uniphier-mio.c) to the core support file (clk-uniphier-core.c) because I do not want to repeat the driver boilerplate when I add more clock data.
drivers/clk/uniphier/clk-uniphier-core.c | 88 ++++++++++++++++++++++++++------ drivers/clk/uniphier/clk-uniphier-mio.c | 47 +---------------- drivers/clk/uniphier/clk-uniphier.h | 14 +---- 3 files changed, 74 insertions(+), 75 deletions(-)
diff --git a/drivers/clk/uniphier/clk-uniphier-core.c b/drivers/clk/uniphier/clk-uniphier-core.c index 721e59e..2db4a7c 100644 --- a/drivers/clk/uniphier/clk-uniphier-core.c +++ b/drivers/clk/uniphier/clk-uniphier-core.c @@ -14,6 +14,35 @@
#include "clk-uniphier.h"
+/** + * struct uniphier_clk_priv - private data for UniPhier clock driver + * + * @base: base address of the clock provider + * @socdata: SoC specific data + */ +struct uniphier_clk_priv { + void __iomem *base; + const struct uniphier_clk_soc_data *socdata; +}; + +int uniphier_clk_probe(struct udevice *dev) +{ + struct uniphier_clk_priv *priv = dev_get_priv(dev); + fdt_addr_t addr; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = devm_ioremap(dev, addr, SZ_4K); + if (!priv->base) + return -ENOMEM; + + priv->socdata = (void *)dev_get_driver_data(dev); + + return 0; +} + static int uniphier_clk_enable(struct clk *clk) { struct uniphier_clk_priv *priv = dev_get_priv(clk->dev); @@ -128,20 +157,47 @@ const struct clk_ops uniphier_clk_ops = { .set_rate = uniphier_clk_set_rate, };
-int uniphier_clk_probe(struct udevice *dev) -{ - struct uniphier_clk_priv *priv = dev_get_priv(dev); - fdt_addr_t addr; - - addr = dev_get_addr(dev); - if (addr == FDT_ADDR_T_NONE) - return -EINVAL; - - priv->base = devm_ioremap(dev, addr, SZ_4K); - if (!priv->base) - return -ENOMEM; - - priv->socdata = (void *)dev_get_driver_data(dev); +static const struct udevice_id uniphier_clk_match[] = { + { + .compatible = "socionext,ph1-sld3-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-ld4-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-pro4-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-sld8-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-pro5-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,proxstream2-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-ld11-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { + .compatible = "socionext,ph1-ld20-mioctrl", + .data = (ulong)&uniphier_mio_clk_data, + }, + { /* sentinel */ } +};
- return 0; -} +U_BOOT_DRIVER(uniphier_clk) = { + .name = "uniphier-clk", + .id = UCLASS_CLK, + .of_match = uniphier_clk_match, + .probe = uniphier_clk_probe, + .priv_auto_alloc_size = sizeof(struct uniphier_clk_priv), + .ops = &uniphier_clk_ops, +}; diff --git a/drivers/clk/uniphier/clk-uniphier-mio.c b/drivers/clk/uniphier/clk-uniphier-mio.c index 40c1b78..c1e7197 100644 --- a/drivers/clk/uniphier/clk-uniphier-mio.c +++ b/drivers/clk/uniphier/clk-uniphier-mio.c @@ -132,54 +132,9 @@ static const struct uniphier_clk_rate_data uniphier_mio_clk_rate[] = { UNIPHIER_MIO_CLK_RATE_SD(2, 2), /* for PH1-Pro4 only */ };
-static const struct uniphier_clk_soc_data uniphier_mio_clk_data = { +const struct uniphier_clk_soc_data uniphier_mio_clk_data = { .gate = uniphier_mio_clk_gate, .nr_gate = ARRAY_SIZE(uniphier_mio_clk_gate), .rate = uniphier_mio_clk_rate, .nr_rate = ARRAY_SIZE(uniphier_mio_clk_rate), }; - -static const struct udevice_id uniphier_mio_clk_match[] = { - { - .compatible = "socionext,ph1-sld3-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-ld4-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-pro4-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-sld8-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-pro5-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,proxstream2-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-ld11-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { - .compatible = "socionext,ph1-ld20-mioctrl", - .data = (ulong)&uniphier_mio_clk_data, - }, - { /* sentinel */ } -}; - -U_BOOT_DRIVER(uniphier_mio_clk) = { - .name = "uniphier-mio-clk", - .id = UCLASS_CLK, - .of_match = uniphier_mio_clk_match, - .probe = uniphier_clk_probe, - .priv_auto_alloc_size = sizeof(struct uniphier_clk_priv), - .ops = &uniphier_clk_ops, -}; diff --git a/drivers/clk/uniphier/clk-uniphier.h b/drivers/clk/uniphier/clk-uniphier.h index 4e9f7dc..0b60337 100644 --- a/drivers/clk/uniphier/clk-uniphier.h +++ b/drivers/clk/uniphier/clk-uniphier.h @@ -40,18 +40,6 @@ struct uniphier_clk_soc_data { .rate = f, \ }
-/** - * struct uniphier_clk_priv - private data for UniPhier clock driver - * - * @base: base address of the clock provider - * @socdata: SoC specific data - */ -struct uniphier_clk_priv { - void __iomem *base; - const struct uniphier_clk_soc_data *socdata; -}; - -extern const struct clk_ops uniphier_clk_ops; -int uniphier_clk_probe(struct udevice *dev); +extern const struct uniphier_clk_soc_data uniphier_mio_clk_data;
#endif /* __CLK_UNIPHIER_H__ */
To sync the DT binding with Linux, the register base must be taken from the parent syscon node.
drivers/clk/uniphier/clk-uniphier-core.c | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/clk/uniphier/clk-uniphier-core.c b/drivers/clk/uniphier/clk-uniphier-core.c index 2db4a7c..3948326 100644 --- a/drivers/clk/uniphier/clk-uniphier-core.c +++ b/drivers/clk/uniphier/clk-uniphier-core.c @@ -30,7 +30,7 @@ int uniphier_clk_probe(struct udevice *dev) struct uniphier_clk_priv *priv = dev_get_priv(dev); fdt_addr_t addr;
- addr = dev_get_addr(dev); + addr = dev_get_addr(dev->parent); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
@@ -159,35 +159,35 @@ const struct clk_ops uniphier_clk_ops = {
static const struct udevice_id uniphier_clk_match[] = { { - .compatible = "socionext,ph1-sld3-mioctrl", + .compatible = "socionext,uniphier-sld3-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-ld4-mioctrl", + .compatible = "socionext,uniphier-ld4-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-pro4-mioctrl", + .compatible = "socionext,uniphier-pro4-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-sld8-mioctrl", + .compatible = "socionext,uniphier-sld8-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-pro5-mioctrl", + .compatible = "socionext,uniphier-pro5-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,proxstream2-mioctrl", + .compatible = "socionext,uniphier-pxs2-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-ld11-mioctrl", + .compatible = "socionext,uniphier-ld11-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { - .compatible = "socionext,ph1-ld20-mioctrl", + .compatible = "socionext,uniphier-ld20-mio-clock", .data = (ulong)&uniphier_mio_clk_data, }, { /* sentinel */ }
Sync device trees with Linux for easier DT life.
arch/arm/dts/uniphier-common32.dtsi | 56 +++++++++++++------ arch/arm/dts/uniphier-ph1-ld11.dtsi | 80 ++++++++++++++++++++-------- arch/arm/dts/uniphier-ph1-ld20.dtsi | 75 +++++++++++++++++++------- arch/arm/dts/uniphier-ph1-ld4.dtsi | 44 +++++++-------- arch/arm/dts/uniphier-ph1-pro4-sanji.dts | 2 +- arch/arm/dts/uniphier-ph1-pro4.dtsi | 38 +++++++------ arch/arm/dts/uniphier-ph1-pro5.dtsi | 38 ++++++------- arch/arm/dts/uniphier-ph1-sld3-ref.dts | 4 -- arch/arm/dts/uniphier-ph1-sld3.dtsi | 59 +++++++++++--------- arch/arm/dts/uniphier-ph1-sld8.dtsi | 44 +++++++-------- arch/arm/dts/uniphier-proxstream2-gentil.dts | 2 +- arch/arm/dts/uniphier-proxstream2-vodka.dts | 2 +- arch/arm/dts/uniphier-proxstream2.dtsi | 38 ++++++------- 13 files changed, 301 insertions(+), 181 deletions(-)
diff --git a/arch/arm/dts/uniphier-common32.dtsi b/arch/arm/dts/uniphier-common32.dtsi index b0b2b57..e441033 100644 --- a/arch/arm/dts/uniphier-common32.dtsi +++ b/arch/arm/dts/uniphier-common32.dtsi @@ -31,7 +31,7 @@ interrupts = <0 33 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; - clocks = <&uart_clk>; + clocks = <&peri_clk 0>; };
serial1: serial@54006900 { @@ -41,7 +41,7 @@ interrupts = <0 35 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; - clocks = <&uart_clk>; + clocks = <&peri_clk 1>; };
serial2: serial@54006a00 { @@ -51,7 +51,7 @@ interrupts = <0 37 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; - clocks = <&uart_clk>; + clocks = <&peri_clk 2>; };
serial3: serial@54006b00 { @@ -61,7 +61,7 @@ interrupts = <0 177 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; - clocks = <&uart_clk>; + clocks = <&peri_clk 3>; };
system_bus: system-bus@58c00000 { @@ -79,16 +79,33 @@ reg = <0x59801000 0x400>; };
- mio: mioctrl@59810000 { - /* specify compatible in each SoC DTSI */ + mioctrl@59810000 { + compatible = "socionext,uniphier-mioctrl", + "simple-mfd", "syscon"; reg = <0x59810000 0x800>; - #clock-cells = <1>; + u-boot,dm-pre-reloc; + + mio_clk: clock { + #clock-cells = <1>; + }; + + mio_rst: reset { + #reset-cells = <1>; + }; };
- peri: perictrl@59820000 { - /* specify compatible in each SoC DTSI */ + perictrl@59820000 { + compatible = "socionext,uniphier-perictrl", + "simple-mfd", "syscon"; reg = <0x59820000 0x200>; - #clock-cells = <1>; + + peri_clk: clock { + #clock-cells = <1>; + }; + + peri_rst: reset { + #reset-cells = <1>; + }; };
timer@60000200 { @@ -114,7 +131,8 @@ };
soc-glue@5f800000 { - compatible = "simple-mfd", "syscon"; + compatible = "socionext,uniphier-soc-glue", + "simple-mfd", "syscon"; reg = <0x5f800000 0x2000>; u-boot,dm-pre-reloc;
@@ -124,12 +142,18 @@ }; };
- sysctrl: sysctrl@61840000 { - /* specify compatible in each SoC DTSI */ + sysctrl@61840000 { + compatible = "socionext,uniphier-sysctrl", + "simple-mfd", "syscon"; reg = <0x61840000 0x4000>; - #clock-cells = <1>; - clock-names = "ref"; - clocks = <&refclk>; + + sys_clk: clock { + #clock-cells = <1>; + }; + + sys_rst: reset { + #reset-cells = <1>; + }; };
nand: nand@68000000 { diff --git a/arch/arm/dts/uniphier-ph1-ld11.dtsi b/arch/arm/dts/uniphier-ph1-ld11.dtsi index ffe04f5..0bdbbdd 100644 --- a/arch/arm/dts/uniphier-ph1-ld11.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld11.dtsi @@ -54,12 +54,6 @@ clock-frequency = <25000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <58820000>; - }; - i2c_clk: i2c_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -69,10 +63,10 @@
timer { compatible = "arm,armv8-timer"; - interrupts = <1 13 0xf01>, - <1 14 0xf01>, - <1 11 0xf01>, - <1 10 0xf01>; + interrupts = <1 13 4>, + <1 14 4>, + <1 11 4>, + <1 10 4>; };
soc { @@ -89,7 +83,7 @@ interrupts = <0 33 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; - clocks = <&uart_clk>; + clocks = <&peri_clk 0>; clock-frequency = <58820000>; };
@@ -100,7 +94,7 @@ interrupts = <0 35 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; - clocks = <&uart_clk>; + clocks = <&peri_clk 1>; clock-frequency = <58820000>; };
@@ -111,7 +105,7 @@ interrupts = <0 37 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; - clocks = <&uart_clk>; + clocks = <&peri_clk 2>; clock-frequency = <58820000>; };
@@ -122,7 +116,7 @@ interrupts = <0 177 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; - clocks = <&uart_clk>; + clocks = <&peri_clk 3>; clock-frequency = <58820000>; };
@@ -213,6 +207,22 @@ reg = <0x59801000 0x400>; };
+ perictrl@59820000 { + compatible = "socionext,uniphier-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>; + + peri_clk: clock { + compatible = "socionext,uniphier-ld11-peri-clock"; + #clock-cells = <1>; + }; + + peri_rst: reset { + compatible = "socionext,uniphier-ld11-peri-reset"; + #reset-cells = <1>; + }; + }; + usb0: usb@5a800100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; @@ -220,7 +230,7 @@ interrupts = <0 243 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; - clocks = <&mio 3>, <&mio 6>; + clocks = <&mio_clk 3>, <&mio_clk 6>; };
usb1: usb@5a810100 { @@ -230,7 +240,7 @@ interrupts = <0 244 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; - clocks = <&mio 4>, <&mio 6>; + clocks = <&mio_clk 4>, <&mio_clk 6>; };
usb2: usb@5a820100 { @@ -240,17 +250,29 @@ interrupts = <0 245 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio 5>, <&mio 6>; + clocks = <&mio_clk 5>, <&mio_clk 6>; };
- mio: mioctrl@5b3e0000 { - compatible = "socionext,ph1-ld11-mioctrl"; + mioctrl@5b3e0000 { + compatible = "socionext,uniphier-mioctrl", + "simple-mfd", "syscon"; reg = <0x5b3e0000 0x800>; - #clock-cells = <1>; + + mio_clk: clock { + compatible = "socionext,uniphier-ld11-mio-clock"; + #clock-cells = <1>; + }; + + mio_rst: reset { + compatible = "socionext,uniphier-ld11-mio-reset"; + #reset-cells = <1>; + resets = <&sys_rst 7>; + }; };
@@ -273,6 +295,22 @@ #interrupt-cells = <3>; interrupts = <1 9 4>; }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-ld11-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x4000>; + + sys_clk: clock { + compatible = "socionext,uniphier-ld11-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-ld11-reset"; + #reset-cells = <1>; + }; + }; }; };
diff --git a/arch/arm/dts/uniphier-ph1-ld20.dtsi b/arch/arm/dts/uniphier-ph1-ld20.dtsi index 7497539..7f97f88 100644 --- a/arch/arm/dts/uniphier-ph1-ld20.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld20.dtsi @@ -78,12 +78,6 @@ clock-frequency = <25000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <58820000>; - }; - i2c_clk: i2c_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -93,10 +87,10 @@
soc { @@ -113,7 +107,7 @@ interrupts = <0 33 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; - clocks = <&uart_clk>; + clocks = <&peri_clk 0>; clock-frequency = <58820000>; };
@@ -124,7 +118,7 @@ interrupts = <0 35 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; - clocks = <&uart_clk>; + clocks = <&peri_clk 1>; clock-frequency = <58820000>; };
@@ -135,7 +129,7 @@ interrupts = <0 37 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; - clocks = <&uart_clk>; + clocks = <&peri_clk 2>; clock-frequency = <58820000>; };
@@ -146,7 +140,7 @@ interrupts = <0 177 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart3>; - clocks = <&uart_clk>; + clocks = <&peri_clk 3>; clock-frequency = <58820000>; };
@@ -237,10 +231,36 @@ reg = <0x59801000 0x400>; };
- mio: mioctrl@59810000 { - compatible = "socionext,ph1-ld20-mioctrl"; + mioctrl@59810000 { + compatible = "socionext,uniphier-mioctrl", + "simple-mfd", "syscon"; reg = <0x59810000 0x800>; - #clock-cells = <1>; + + mio_clk: clock { + compatible = "socionext,uniphier-ld20-mio-clock"; + #clock-cells = <1>; + }; + + mio_rst: reset { + compatible = "socionext,uniphier-ld20-mio-reset"; + #reset-cells = <1>; + }; + }; + + perictrl@59820000 { + compatible = "socionext,uniphier-perictrl", + "simple-mfd", "syscon"; + reg = <0x59820000 0x200>; + + peri_clk: clock { + compatible = "socionext,uniphier-ld20-peri-clock"; + #clock-cells = <1>; + }; + + peri_rst: reset { + compatible = "socionext,uniphier-ld20-peri-reset"; + #reset-cells = <1>; + }; };
sd: sdhc@5a400000 { @@ -250,12 +270,13 @@ interrupts = <0 76 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_sd>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -278,6 +299,22 @@ #interrupt-cells = <3>; interrupts = <1 9 4>; }; + + sysctrl@61840000 { + compatible = "socionext,uniphier-sysctrl", + "simple-mfd", "syscon"; + reg = <0x61840000 0x4000>; + + sys_clk: clock { + compatible = "socionext,uniphier-ld20-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-ld20-reset"; + #reset-cells = <1>; + }; + }; }; };
diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 07f315a..e4884b9 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -30,12 +30,6 @@ clock-frequency = <50000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <36864000>; - }; - iobus_clk: iobus_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -228,7 +222,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -240,7 +234,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_emmc>; pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio 1>; + clocks = <&mio_clk 1>; bus-width = <8>; non-removable; }; @@ -252,7 +246,7 @@ interrupts = <0 80 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; - clocks = <&mio 3>, <&mio 6>; + clocks = <&mio_clk 3>, <&mio_clk 6>; };
usb1: usb@5a810100 { @@ -262,7 +256,7 @@ interrupts = <0 81 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; - clocks = <&mio 4>, <&mio 6>; + clocks = <&mio_clk 4>, <&mio_clk 6>; };
usb2: usb@5a820100 { @@ -272,7 +266,7 @@ interrupts = <0 82 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio 5>, <&mio 6>; + clocks = <&mio_clk 5>, <&mio_clk 6>; };
aidet@61830000 { @@ -302,22 +296,30 @@ clock-frequency = <36864000>; };
-&mio { - compatible = "socionext,ph1-ld4-mioctrl"; - clock-names = "stdmac", "ehci"; - clocks = <&sysctrl 10>, <&sysctrl 18>; +&mio_clk { + compatible = "socionext,uniphier-ld4-mio-clock"; +}; + +&mio_rst { + compatible = "socionext,uniphier-ld4-mio-reset"; +}; + +&peri_clk { + compatible = "socionext,uniphier-ld4-peri-clock"; };
-&peri { - compatible = "socionext,ph1-ld4-perictrl"; - clock-names = "uart", "i2c"; - clocks = <&sysctrl 3>, <&sysctrl 4>; +&peri_rst { + compatible = "socionext,uniphier-ld4-peri-reset"; };
&pinctrl { compatible = "socionext,uniphier-ld4-pinctrl"; };
-&sysctrl { - compatible = "socionext,ph1-ld4-sysctrl"; +&sys_clk { + compatible = "socionext,uniphier-ld4-clock"; +}; + +&sys_rst { + compatible = "socionext,uniphier-ld4-reset"; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts index 965fe08..3f178d2 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-sanji.dts @@ -89,7 +89,7 @@ u-boot,dm-pre-reloc; };
-&mio { +&mio_clk { u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index e0b28b8..192ce84 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -351,7 +351,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -363,7 +363,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_emmc>; pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio 1>; + clocks = <&mio_clk 1>; bus-width = <8>; non-removable; }; @@ -376,7 +376,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd1>; pinctrl-1 = <&pinctrl_sd1_1v8>; - clocks = <&mio 2>; + clocks = <&mio_clk 2>; bus-width = <4>; };
@@ -387,7 +387,7 @@ interrupts = <0 80 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio 3>, <&mio 6>; + clocks = <&mio_clk 3>, <&mio_clk 6>; };
usb3: usb@5a810100 { @@ -397,7 +397,7 @@ interrupts = <0 81 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb3>; - clocks = <&mio 4>, <&mio 6>; + clocks = <&mio_clk 4>, <&mio_clk 6>; };
aidet@5fc20000 { @@ -444,22 +444,30 @@ clock-frequency = <73728000>; };
-&mio { - compatible = "socionext,ph1-pro4-mioctrl"; - clock-names = "stdmac", "ehci"; - clocks = <&sysctrl 10>, <&sysctrl 18>; +&mio_clk { + compatible = "socionext,uniphier-pro4-mio-clock"; };
-&peri { - compatible = "socionext,ph1-pro4-perictrl"; - clock-names = "uart", "fi2c"; - clocks = <&sysctrl 3>, <&sysctrl 4>; +&mio_rst { + compatible = "socionext,uniphier-pro4-mio-reset"; +}; + +&peri_clk { + compatible = "socionext,uniphier-pro4-peri-clock"; +}; + +&peri_rst { + compatible = "socionext,uniphier-pro4-peri-reset"; };
&pinctrl { compatible = "socionext,uniphier-pro4-pinctrl"; };
-&sysctrl { - compatible = "socionext,ph1-pro4-sysctrl"; +&sys_clk { + compatible = "socionext,uniphier-pro4-clock"; +}; + +&sys_rst { + compatible = "socionext,uniphier-pro4-reset"; }; diff --git a/arch/arm/dts/uniphier-ph1-pro5.dtsi b/arch/arm/dts/uniphier-ph1-pro5.dtsi index 05f961f..22a70b1 100644 --- a/arch/arm/dts/uniphier-ph1-pro5.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro5.dtsi @@ -38,12 +38,6 @@ clock-frequency = <50000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <73728000>; - }; - i2c_clk: i2c_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -367,7 +361,7 @@ interrupts = <0 78 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; - clocks = <&mio 1>; + clocks = <&mio_clk 1>; bus-width = <8>; non-removable; }; @@ -380,7 +374,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -423,22 +417,30 @@ clock-frequency = <73728000>; };
-&mio { - compatible = "socionext,ph1-pro5-mioctrl"; - clock-names = "stdmac"; - clocks = <&sysctrl 10>; +&mio_clk { + compatible = "socionext,uniphier-pro5-mio-clock"; +}; + +&mio_rst { + compatible = "socionext,uniphier-pro5-mio-reset"; +}; + +&peri_clk { + compatible = "socionext,uniphier-pro5-peri-clock"; };
-&peri { - compatible = "socionext,ph1-pro5-perictrl"; - clock-names = "uart", "fi2c"; - clocks = <&sysctrl 3>, <&sysctrl 4>; +&peri_rst { + compatible = "socionext,uniphier-pro5-peri-reset"; };
&pinctrl { compatible = "socionext,uniphier-pro5-pinctrl"; };
-&sysctrl { - compatible = "socionext,ph1-pro5-sysctrl"; +&sys_clk { + compatible = "socionext,uniphier-pro5-clock"; +}; + +&sys_rst { + compatible = "socionext,uniphier-pro5-reset"; }; diff --git a/arch/arm/dts/uniphier-ph1-sld3-ref.dts b/arch/arm/dts/uniphier-ph1-sld3-ref.dts index f3e76b3..116e571 100644 --- a/arch/arm/dts/uniphier-ph1-sld3-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld3-ref.dts @@ -86,10 +86,6 @@ u-boot,dm-pre-reloc; };
-&mio { - u-boot,dm-pre-reloc; -}; - &emmc { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index d8c44b7..a554b08 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -42,12 +42,6 @@ clock-frequency = <50000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <36864000>; - }; - iobus_clk: iobus_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -92,7 +86,6 @@ interrupts = <0 33 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart0>; - clocks = <&uart_clk>; clock-frequency = <36864000>; };
@@ -103,7 +96,6 @@ interrupts = <0 35 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart1>; - clocks = <&uart_clk>; clock-frequency = <36864000>; };
@@ -114,7 +106,6 @@ interrupts = <0 37 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_uart2>; - clocks = <&uart_clk>; clock-frequency = <36864000>; };
@@ -299,12 +290,22 @@ reg = <0x59801000 0x400>; };
- mio: mioctrl@59810000 { - compatible = "socionext,ph1-sld3-mioctrl"; + mioctrl@59810000 { + compatible = "socionext,uniphier-mioctrl", + "simple-mfd", "syscon"; reg = <0x59810000 0x800>; - #clock-cells = <1>; - clock-names = "stdmac", "ehci"; - clocks = <&sysctrl 10>, <&sysctrl 18>; + u-boot,dm-pre-reloc; + + mio_clk: clock { + compatible = "socionext,uniphier-sld3-mio-clock"; + #clock-cells = <1>; + u-boot,dm-pre-reloc; + }; + + mio_rst: reset { + compatible = "socionext,uniphier-sld3-mio-reset"; + #reset-cells = <1>; + }; };
emmc: sdhc@5a400000 { @@ -315,7 +316,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_emmc>; pinctrl-1 = <&pinctrl_emmc_1v8>; - clocks = <&mio 1>; + clocks = <&mio_clk 1>; bus-width = <8>; non-removable; }; @@ -328,7 +329,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -339,7 +340,7 @@ interrupts = <0 80 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb0>; - clocks = <&mio 3>, <&mio 6>; + clocks = <&mio_clk 3>, <&mio_clk 6>; };
usb1: usb@5a810100 { @@ -349,7 +350,7 @@ interrupts = <0 81 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb1>; - clocks = <&mio 4>, <&mio 6>; + clocks = <&mio_clk 4>, <&mio_clk 6>; };
usb2: usb@5a820100 { @@ -359,7 +360,7 @@ interrupts = <0 82 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb2>; - clocks = <&mio 5>, <&mio 6>; + clocks = <&mio_clk 5>, <&mio_clk 6>; };
usb3: usb@5a830100 { @@ -369,7 +370,7 @@ interrupts = <0 83 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_usb3>; - clocks = <&mio 7>, <&mio 6>; + clocks = <&mio_clk 7>, <&mio_clk 6>; };
soc-glue@5f800000 { @@ -388,12 +389,20 @@ reg = <0xf1830000 0x200>; };
- sysctrl: sysctrl@f1840000 { - compatible = "socionext,ph1-sld3-sysctrl"; + sysctrl@f1840000 { + compatible = "socionext,uniphier-sysctrl", + "simple-mfd", "syscon"; reg = <0xf1840000 0x4000>; - #clock-cells = <1>; - clock-names = "ref"; - clocks = <&refclk>; + + sys_clk: clock { + compatible = "socionext,uniphier-sld3-clock"; + #clock-cells = <1>; + }; + + sys_rst: reset { + compatible = "socionext,uniphier-sld3-reset"; + #reset-cells = <1>; + }; };
nand: nand@f8000000 { diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index e0376a1..1ecce50 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -30,12 +30,6 @@ clock-frequency = <50000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <80000000>; - }; - iobus_clk: iobus_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -228,7 +222,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
aidet@61830000 { @@ -302,22 +296,30 @@ clock-frequency = <80000000>; };
-&mio { - compatible = "socionext,ph1-sld8-mioctrl"; - clock-names = "stdmac", "ehci"; - clocks = <&sysctrl 10>, <&sysctrl 18>; +&mio_clk { + compatible = "socionext,uniphier-sld8-mio-clock"; +}; + +&mio_rst { + compatible = "socionext,uniphier-sld8-mio-reset"; +}; + +&peri_clk { + compatible = "socionext,uniphier-sld8-peri-clock"; };
-&peri { - compatible = "socionext,ph1-sld8-perictrl"; - clock-names = "uart", "i2c"; - clocks = <&sysctrl 3>, <&sysctrl 4>; +&peri_rst { + compatible = "socionext,uniphier-sld8-peri-reset"; };
&pinctrl { compatible = "socionext,uniphier-sld8-pinctrl"; };
-&sysctrl { - compatible = "socionext,ph1-sld8-sysctrl"; +&sys_clk { + compatible = "socionext,uniphier-sld8-clock"; +}; + +&sys_rst { + compatible = "socionext,uniphier-sld8-reset"; }; diff --git a/arch/arm/dts/uniphier-proxstream2-gentil.dts b/arch/arm/dts/uniphier-proxstream2-gentil.dts index 1175703..7233dc6 100644 --- a/arch/arm/dts/uniphier-proxstream2-gentil.dts +++ b/arch/arm/dts/uniphier-proxstream2-gentil.dts @@ -69,7 +69,7 @@ u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/uniphier-proxstream2-vodka.dts b/arch/arm/dts/uniphier-proxstream2-vodka.dts index 928a092..30ea270 100644 --- a/arch/arm/dts/uniphier-proxstream2-vodka.dts +++ b/arch/arm/dts/uniphier-proxstream2-vodka.dts @@ -54,7 +54,7 @@ u-boot,dm-pre-reloc; };
diff --git a/arch/arm/dts/uniphier-proxstream2.dtsi b/arch/arm/dts/uniphier-proxstream2.dtsi index 23a6bfa..609cbaa 100644 --- a/arch/arm/dts/uniphier-proxstream2.dtsi +++ b/arch/arm/dts/uniphier-proxstream2.dtsi @@ -52,12 +52,6 @@ clock-frequency = <50000000>; };
- uart_clk: uart_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <88900000>; - }; - i2c_clk: i2c_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -366,7 +360,7 @@ interrupts = <0 78 4>; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_emmc>; - clocks = <&mio 1>; + clocks = <&mio_clk 1>; bus-width = <8>; non-removable; }; @@ -379,7 +373,7 @@ pinctrl-names = "default", "1.8v"; pinctrl-0 = <&pinctrl_sd>; pinctrl-1 = <&pinctrl_sd_1v8>; - clocks = <&mio 0>; + clocks = <&mio_clk 0>; bus-width = <4>; };
@@ -427,22 +421,30 @@ clock-frequency = <88900000>; };
-&mio { - compatible = "socionext,proxstream2-mioctrl"; - clock-names = "stdmac"; - clocks = <&sysctrl 10>; +&mio_clk { + compatible = "socionext,uniphier-pxs2-mio-clock"; +}; + +&mio_rst { + compatible = "socionext,uniphier-pxs2-mio-reset"; +}; + +&peri_clk { + compatible = "socionext,uniphier-pxs2-peri-clock"; };
-&peri { - compatible = "socionext,proxstream2-perictrl"; - clock-names = "uart", "fi2c"; - clocks = <&sysctrl 3>, <&sysctrl 4>; +&peri_rst { + compatible = "socionext,uniphier-pxs2-peri-reset"; };
&pinctrl { compatible = "socionext,uniphier-pxs2-pinctrl"; };
-&sysctrl { - compatible = "socionext,proxstream2-sysctrl"; +&sys_clk { + compatible = "socionext,uniphier-pxs2-clock"; +}; + +&sys_rst { + compatible = "socionext,uniphier-pxs2-reset"; };
2016-09-22 7:42 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
- Sync Device Trees
Series, applied to u-boot-uniphier/master.
Masahiro Yamada
