[U-Boot] [PATCH v2 0/4] usb: host: dwc2: use driver model for PHY and CLOCK
In this serie I update the DWC2 host driver to use the device tree information and the associated PHY and CLOCK drivers when they are available.
I test this serie on stm32mp157c-ev1 board, with PHY and CLK support
The U-CLASS are provided by: - PHY by USBPHYC driver = ./drivers/phy/phy-stm32-usbphyc.c - CLOCK by RCC clock driver = drivers/clk/clk_stm32mp1.c - RESET by RCC reset driver = drivers/reset/stm32-reset.c
And I activate the configuration +CONFIG_USB_DWC2=y
PS: it is not the default configuration to avoid conflict with gadget driver
To solve a binding issue, I also deactivate the gadget support: by default only one driver is bound to theusbotg_hs node with "snps,dwc2" compatible, and today it is the device one (the first in the driver list).
I also need to deactivate hnp-srp support with:
&usbotg_hs { /* need to disable ONLY for HOST support */ hnp-srp-disable; };
WARNING: OTG with device or host support is not correctly handle by DWC2 driver (see example for dynamic OTG role in DWC3 driver).
The tests executed on the stm32mp157c-ev1 target:
STM32MP> usb start starting USB... Bus usb-otg@49000000: USB DWC2 Bus usbh-ehci@5800d000: USB EHCI 1.00 scanning bus usb-otg@49000000 for devices... 2 USB Device(s) found scanning bus usbh-ehci@5800d000 for devices... 3 USB Device(s) found scanning usb for storage devices... 2 Storage Device(s) found STM32MP> usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) | U-Boot Root Hub | +-2 Mass Storage (480 Mb/s, 300mA) Verbatim STORE N GO 070731C8ACD7EE97
1 Hub (480 Mb/s, 0mA) | u-boot EHCI Host Controller | +-2 Hub (480 Mb/s, 2mA) | +-3 Mass Storage (480 Mb/s, 500mA) Generic USB Storage
STM32MP> ls usb 0 <DIR> 4096 . <DIR> 4096 .. <DIR> 16384 lost+found <DIR> 4096 record 1490212 xipImage 21058006 vmlinux
STM32MP> load usb 0 0xC0000000 vmlinux 21058006 bytes read in 10851 ms (1.9 MiB/s)
Changes in v2: - update dev_err - update commit message - change dev_err to dev_dbg for PHY function call - treat dwc2_shutdown_phy error - add clk_disable_bulk in dwc2_usb_remove
Patrick Delaunay (4): usb: host: dwc2: add phy support usb: host: dwc2: add clk support usb: host: dwc2: force reset assert usb: host: dwc2: add trace to have clean usb start
drivers/usb/host/dwc2.c | 100 +++++++++++++++++++++++++++++++++++++++- 1 file changed, 99 insertions(+), 1 deletion(-)
Use generic phy to initialize the PHY associated to the DWC2 device and available in the device tree.
This patch don't added dependency because when CONFIG_PHY is not activated, the generic PHY function are stubbed.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/usb/host/dwc2.c | 66 +++++++++++++++++++++++++++++++++++++++++ 1 file changed, 66 insertions(+)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 350d820a6e..cb2b381eb6 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -7,6 +7,7 @@ #include <common.h> #include <dm.h> #include <errno.h> +#include <generic-phy.h> #include <usb.h> #include <malloc.h> #include <memalign.h> @@ -35,6 +36,7 @@ struct dwc2_priv { #ifdef CONFIG_DM_REGULATOR struct udevice *vbus_supply; #endif + struct phy phy; #else uint8_t *aligned_buffer; uint8_t *status_buffer; @@ -1320,13 +1322,71 @@ static int dwc2_usb_ofdata_to_platdata(struct udevice *dev) return 0; }
+static int dwc2_setup_phy(struct udevice *dev) +{ + struct dwc2_priv *priv = dev_get_priv(dev); + int ret; + + ret = generic_phy_get_by_index(dev, 0, &priv->phy); + if (ret) { + if (ret != -ENOENT) { + dev_err(dev, "Failed to get USB PHY: %d.\n", ret); + return ret; + } + return 0; + } + + ret = generic_phy_init(&priv->phy); + if (ret) { + dev_dbg(dev, "Failed to init USB PHY: %d.\n", ret); + return ret; + } + + ret = generic_phy_power_on(&priv->phy); + if (ret) { + dev_dbg(dev, "Failed to power on USB PHY: %d.\n", ret); + generic_phy_exit(&priv->phy); + return ret; + } + + return 0; +} + +static int dwc2_shutdown_phy(struct udevice *dev) +{ + struct dwc2_priv *priv = dev_get_priv(dev); + int ret; + + if (!generic_phy_valid(&priv->phy)) + return 0; + + ret = generic_phy_power_off(&priv->phy); + if (ret) { + dev_dbg(dev, "Failed to power off USB PHY: %d.\n", ret); + return ret; + } + + ret = generic_phy_exit(&priv->phy); + if (ret) { + dev_dbg(dev, "Failed to power off USB PHY: %d.\n", ret); + return ret; + } + + return 0; +} + static int dwc2_usb_probe(struct udevice *dev) { struct dwc2_priv *priv = dev_get_priv(dev); struct usb_bus_priv *bus_priv = dev_get_uclass_priv(dev); + int ret;
bus_priv->desc_before_addr = true;
+ ret = dwc2_setup_phy(dev); + if (ret) + return ret; + return dwc2_init_common(dev, priv); }
@@ -1339,6 +1399,12 @@ static int dwc2_usb_remove(struct udevice *dev) if (ret) return ret;
+ ret = dwc2_shutdown_phy(dev); + if (ret) { + dev_dbg(dev, "Failed to shutdown USB PHY: %d.\n", ret); + return ret; + } + dwc2_uninit_common(priv->regs);
reset_release_bulk(&priv->resets);
Add support for clock with driver model.
This patch don't added dependency because when CONFIG_CLK is not activated the clk function are stubbed.
Changes in v2: None
drivers/usb/host/dwc2.c | 30 +++++++++++++++++++++++++++++- 1 file changed, 29 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index cb2b381eb6..9a00bea24f 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -5,13 +5,14 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <errno.h> #include <generic-phy.h> -#include <usb.h> #include <malloc.h> #include <memalign.h> #include <phys2bus.h> +#include <usb.h> #include <usbroothubdes.h> #include <wait_bit.h> #include <asm/io.h> @@ -37,6 +38,7 @@ struct dwc2_priv { struct udevice *vbus_supply; #endif struct phy phy; + struct clk_bulk clks; #else uint8_t *aligned_buffer; uint8_t *status_buffer; @@ -1375,6 +1377,26 @@ static int dwc2_shutdown_phy(struct udevice *dev) return 0; }
+static int dwc2_clk_init(struct udevice *dev) +{ + struct dwc2_priv *priv = dev_get_priv(dev); + int ret; + + ret = clk_get_bulk(dev, &priv->clks); + if (ret == -ENOSYS || ret == -ENOENT) + return 0; + if (ret) + return ret; + + ret = clk_enable_bulk(&priv->clks); + if (ret) { + clk_release_bulk(&priv->clks); + return ret; + } + + return 0; +} + static int dwc2_usb_probe(struct udevice *dev) { struct dwc2_priv *priv = dev_get_priv(dev); @@ -1383,6 +1405,10 @@ static int dwc2_usb_probe(struct udevice *dev)
+ ret = dwc2_clk_init(dev); + if (ret) + return ret; + ret = dwc2_setup_phy(dev); if (ret) return ret; @@ -1408,6 +1434,8 @@ static int dwc2_usb_remove(struct udevice *dev) dwc2_uninit_common(priv->regs);
reset_release_bulk(&priv->resets); + clk_disable_bulk(&priv->clks); + clk_release_bulk(&priv->clks);
return 0; }
Assert reset before deassert in dwc2_reset; this patch solve issues when the DWC2 registers are already initialized with value incompatible with host mode.
Force a hardware reset of the IP reset all the DWC2 registers at default value, the host driver start with a clean state (Core Soft reset doen in dwc_otg_core_reset is not enought to reset all register).
The error can occurs in U-Boot when DWC2 device gadget driver force device mode (called by ums or dfu command, before to execute the usb start command).
Changes in v2: - add clk_disable_bulk in dwc2_usb_remove
drivers/usb/host/dwc2.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 9a00bea24f..870b06459e 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -1149,6 +1149,8 @@ static int dwc2_reset(struct udevice *dev) return ret; }
+ /* force reset to clear all IP register */ + reset_assert_bulk(&priv->resets); ret = reset_deassert_bulk(&priv->resets); if (ret) { reset_release_bulk(&priv->resets);
Solve issue for the display of "usb start" command on stm32mp1 because one carriage return is missing in DWC2 probe.
STM32MP> usb start starting USB... Bus usb-otg@49000000: Bus usbh-ehci@5800d000: USB EHCI 1.00
after the patch:
Changes in v2: None
diff --git a/drivers/usb/host/dwc2.c b/drivers/usb/host/dwc2.c index 870b06459e..2450dff9ac 100644 --- a/drivers/usb/host/dwc2.c +++ b/drivers/usb/host/dwc2.c @@ -1217,6 +1217,8 @@ static int dwc2_init_common(struct udevice *dev, struct dwc2_priv *priv) if (readl(®s->gintsts) & DWC2_GINTSTS_CURMODE_HOST) mdelay(1000);
+ printf("USB DWC2\n"); + return 0; }
I'm kinda on the fence whether to add it into current release or not. The patches look generally OK to me.
Ley, Simon, can you check this on SoCFPGA ? Bin, can you give it a once-over ?
If this looks OK to you, I will add it.
Marek Vasut marex@denx.de schrieb am Fr., 8. Nov. 2019, 16:46:
Gmm, so can try, but I don't have a working setup with USB peripherals attached... I do have USB on the socrates, but currently no cable to connect anything...
I could test it to see if I can get the same result saying no attached devices are found, that would mean probing still works correctly...
Hi Marek,
My ci travis build is failing after the last updates (raspberry pi). I am testing a update with sub for clk disable bulk function:
https://github.com/patrickdelaunay/u-boot/commit/1d053dd96e6623d02b846543986...
Now buikd is ok: https://travis-ci.org/patrickdelaunay/u-boot/builds/609496187
I will push it after the Week end (tuesday).
Sorry.
Patrick.
Le ven. 8 nov. 2019 à 16:55, Simon Goldschmidt < simon.k.r.goldschmidt@gmail.com> a écrit :
On Sat, Nov 9, 2019 at 4:46 PM Patrick Delaunay patrick.delaunay73@gmail.com wrote:
Hi Marek,
With that additional change, it seems to build and work for me (same error message saying USB "Port not available" than without this patch).
Sorry.
Patrick.
Le ven. 8 nov. 2019 à 16:55, Simon Goldschmidt simon.k.r.goldschmidt@gmail.com a écrit :
-----Original Message----- From: Marek Vasut marex@denx.de Sent: Friday, November 8, 2019 11:43 PM To: Patrick Delaunay patrick.delaunay@st.com; u-boot@lists.denx.de Cc: simon.k.r.goldschmidt@gmail.com; b.galvani@gmail.com; Michal Suchanek msuchanek@suse.de; Sven Schwermer sven@svenschwermer.de; U-Boot STM32 <uboot-stm32@st-md- mailman.stormreply.com>; Bin Meng bmeng.cn@gmail.com; Tan, Ley Foon ley.foon.tan@intel.com Subject: Re: [PATCH v2 0/4] usb: host: dwc2: use driver model for PHY and CLOCK
There is compilation error for Stratix10. Stratix10 doesn't support clock DM framework yet. So, this patch needs check for CONFIG_CLK when call to all clock DM functions.
drivers/usb/host/built-in.o: In function `dwc2_usb_remove': drivers/usb/host/dwc2.c:1441: undefined reference to `clk_disable_bulk'
Tested on Agilex, USB is working fine with this patch.
Regards Ley Foon
participants (5)
Patrick Delaunay
Patrick Delaunay
Simon Goldschmidt
Tan, Ley Foon
