[U-Boot] [PATCH] Fixed two typos in arch/powerpc/cpu/mpc83xx/start.S.
Signed-off-by: Horst Kronstorfer hkronsto@frequentis.com --- arch/powerpc/cpu/mpc83xx/start.S | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/start.S b/arch/powerpc/cpu/mpc83xx/start.S index a7c8079..aa263e3 100644 --- a/arch/powerpc/cpu/mpc83xx/start.S +++ b/arch/powerpc/cpu/mpc83xx/start.S @@ -507,7 +507,7 @@ init_e300_core: /* time t 10 */
lis r3, CONFIG_SYS_IMMR@h #if defined(CONFIG_WATCHDOG) - /* Initialise the Wathcdog values and reset it (if req) */ + /* Initialise the Watchdog values and reset it (if req) */ /*------------------------------------------------------*/ lis r4, CONFIG_SYS_WATCHDOG_VALUE ori r4, r4, (SWCRR_SWEN | SWCRR_SWRI | SWCRR_SWPR) @@ -520,7 +520,7 @@ init_e300_core: /* time t 10 */ li r4, -0x55C7 sth r4, SWSRR@l(r3) #else - /* Disable Wathcdog */ + /* Disable Watchdog */ /*-------------------*/ lwz r4, SWCRR(r3) /* Check to see if its enabled for disabling
On Tue, 18 May 2010 10:37:05 +0200 Horst Kronstorfer hkronsto@frequentis.com wrote:
applied.
Thanks,
Kim
Horst Kronstorfer
Kim Phillips
