[U-Boot] [RFC][PATCH 00/21] [x86] 'Comming of Age'
Hello Everyone
It has been a while since I posted to the U-Boot list, but I have not been idle. This patch series represents a 'comming of age' for the x86 U-Boot port. I can now boot a Linux 2.6.33 kernel *very happy hacker*
I've spent a lot of effort organising and cleaning up this patch series for community comment. This is an RFC patchset only - Over the next few days/weeks I plan to rebuild from scratch at each patch and apply a few little tidy-ups but the content and numbering of this series should not change.
This patch series can be examined as several distinct functional changes - Patches 1-3 are x86 specific build and core fixups - Patches 4-11 are x86 specific functional improvements - Patches 12-13 switch the x86 port to CONFIG_SERIAL_MULTI - Patches 14-15 provide Linux boot support - Patch 16 is an sc520 specific patch (this one can be delayed) - Patches 17-21 are various eNET specific patches
I will draw your attentions to patches 12,13 and 19. These are the only patches which touch files outside the x86 tree. In particular patch 19 - I had to tweak how the eNET accessed the PCI Address Space (don't know if this is really the correct terminology)
Once this patchset is applied I believe the x86 port of U-Boot will be ready for more mainstream use
Wolfgang - If there is any other renewed interest in the x86 port, I would be more than happy to be an official custodian
--- include/asm-i386/unaligned.h | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-) create mode 100644 include/asm-i386/unaligned.h
diff --git a/include/asm-i386/unaligned.h b/include/asm-i386/unaligned.h new file mode 100644 index 0000000..1e16b7d --- /dev/null +++ b/include/asm-i386/unaligned.h @@ -0,0 +1,14 @@ +#ifndef _ASM_ARM_UNALIGNED_H +#define _ASM_ARM_UNALIGNED_H + +/* + * The x86 can do unaligned accesses itself. + */ + +#include <linux/unaligned/access_ok.h> +#include <linux/unaligned/generic.h> + +#define get_unaligned __get_unaligned_le +#define put_unaligned __put_unaligned_le + +#endif /* _ASM_ARM_UNALIGNED_H */
why dont you just use asm-generic/unaligned.h ? see asm-blackfin/ ... -mike
--- I cannot recall exactly why this is needed but it is
lib_i386/board.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/lib_i386/board.c b/lib_i386/board.c index f3b6348..af81cd5 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -280,8 +280,10 @@ void board_init_r(gd_t *id, ulong ram_start) show_boot_progress(0x26);
+#ifdef CONFIG_CMD_NET /* IP Address */ bd_data.bi_ip_addr = getenv_IPaddr ("ipaddr"); +#endif
#if defined(CONFIG_PCI) /*
Some boards do not support CMD_NET interface. getenvIPaddr is not defined in that case. that's why
#if defined(CONFIG_PCI) /* -- 1.7.0.2.182.ge007
Change sc520 MMCR Access to use memory accessor functions ---
board/eNET/eNET.c | 86 +++++++++++++++++++++--------------------- cpu/i386/sc520/sc520.c | 33 +++++++++------- cpu/i386/sc520/sc520_pci.c | 24 +++++++---- cpu/i386/sc520/sc520_ssi.c | 27 +++++++------ cpu/i386/sc520/sc520_timer.c | 31 ++++++++------- 5 files changed, 106 insertions(+), 95 deletions(-)
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index 6d0b15a..f794beb 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -46,7 +46,7 @@ unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN; void init_sc520_enet (void) { /* Set CPU Speed to 100MHz */ - sc520_mmcr->cpuctl = 0x01; + writeb(0x01, &sc520_mmcr->cpuctl);
/* wait at least one millisecond */ asm("movl $0x2000,%%ecx\n" @@ -55,7 +55,7 @@ void init_sc520_enet (void) "loop 0b\n": : : "ecx");
/* turn on the SDRAM write buffer */ - sc520_mmcr->dbctl = 0x11; + writeb(0x11, &sc520_mmcr->dbctl);
/* turn on the cache and disable write through */ asm("movl %%cr0, %%eax\n" @@ -70,51 +70,51 @@ int board_early_init_f(void) { init_sc520_enet();
- sc520_mmcr->gpcsrt = 0x01; /* GP Chip Select Recovery Time */ - sc520_mmcr->gpcspw = 0x07; /* GP Chip Select Pulse Width */ - sc520_mmcr->gpcsoff = 0x00; /* GP Chip Select Offset */ - sc520_mmcr->gprdw = 0x05; /* GP Read pulse width */ - sc520_mmcr->gprdoff = 0x01; /* GP Read offset */ - sc520_mmcr->gpwrw = 0x05; /* GP Write pulse width */ - sc520_mmcr->gpwroff = 0x01; /* GP Write offset */ - - sc520_mmcr->piodata15_0 = 0x0630; /* PIO15_PIO0 Data */ - sc520_mmcr->piodata31_16 = 0x2000; /* PIO31_PIO16 Data */ - sc520_mmcr->piodir31_16 = 0x2000; /* GPIO Direction */ - sc520_mmcr->piodir15_0 = 0x87b5; /* GPIO Direction */ - sc520_mmcr->piopfs31_16 = 0x0dfe; /* GPIO pin function 31-16 reg */ - sc520_mmcr->piopfs15_0 = 0x200a; /* GPIO pin function 15-0 reg */ - sc520_mmcr->cspfs = 0x00f8; /* Chip Select Pin Function Select */ - - sc520_mmcr->par[2] = 0x200713f8; /* Uart A (GPCS0, 0x013f8, 8 Bytes) */ - sc520_mmcr->par[3] = 0x2c0712f8; /* Uart B (GPCS3, 0x012f8, 8 Bytes) */ - sc520_mmcr->par[4] = 0x300711f8; /* Uart C (GPCS4, 0x011f8, 8 Bytes) */ - sc520_mmcr->par[5] = 0x340710f8; /* Uart D (GPCS5, 0x010f8, 8 Bytes) */ - sc520_mmcr->par[6] = 0xe3ffc000; /* SDRAM (0x00000000, 128MB) */ - sc520_mmcr->par[7] = 0xaa3fd000; /* StrataFlash (ROMCS1, 0x10000000, 16MB) */ - sc520_mmcr->par[8] = 0xca3fd100; /* StrataFlash (ROMCS2, 0x11000000, 16MB) */ - sc520_mmcr->par[9] = 0x4203d900; /* SRAM (GPCS0, 0x19000000, 1MB) */ - sc520_mmcr->par[10] = 0x4e03d910; /* SRAM (GPCS3, 0x19100000, 1MB) */ - sc520_mmcr->par[11] = 0x50018100; /* DP-RAM (GPCS4, 0x18100000, 4kB) */ - sc520_mmcr->par[12] = 0x54020000; /* CFLASH1 (0x200000000, 4kB) */ - sc520_mmcr->par[13] = 0x5c020001; /* CFLASH2 (0x200010000, 4kB) */ -/* sc520_mmcr->par14 = 0x8bfff800; */ /* BOOTCS at 0x18000000 */ -/* sc520_mmcr->par15 = 0x38201000; */ /* LEDs etc (GPCS6, 0x1000, 20 Bytes */ + writeb(0x01, &sc520_mmcr->gpcsrt); /* GP Chip Select Recovery Time */ + writeb(0x07, &sc520_mmcr->gpcspw); /* GP Chip Select Pulse Width */ + writeb(0x00, &sc520_mmcr->gpcsoff); /* GP Chip Select Offset */ + writeb(0x05, &sc520_mmcr->gprdw); /* GP Read pulse width */ + writeb(0x01, &sc520_mmcr->gprdoff); /* GP Read offset */ + writeb(0x05, &sc520_mmcr->gpwrw); /* GP Write pulse width */ + writeb(0x01, &sc520_mmcr->gpwroff); /* GP Write offset */ + + writew(0x0630, &sc520_mmcr->piodata15_0); /* PIO15_PIO0 Data */ + writew(0x2000, &sc520_mmcr->piodata31_16); /* PIO31_PIO16 Data */ + writew(0x2000, &sc520_mmcr->piodir31_16); /* GPIO Direction */ + writew(0x87b5, &sc520_mmcr->piodir15_0); /* GPIO Direction */ + writew(0x0dfe, &sc520_mmcr->piopfs31_16); /* GPIO pin function 31-16 reg */ + writew(0x200a, &sc520_mmcr->piopfs15_0); /* GPIO pin function 15-0 reg */ + writeb(0xf8, &sc520_mmcr->cspfs); /* Chip Select Pin Function Select */ + + writel(0x200713f8, &sc520_mmcr->par[2]); /* Uart A (GPCS0, 0x013f8, 8 Bytes) */ + writel(0x2c0712f8, &sc520_mmcr->par[3]); /* Uart B (GPCS3, 0x012f8, 8 Bytes) */ + writel(0x300711f8, &sc520_mmcr->par[4]); /* Uart C (GPCS4, 0x011f8, 8 Bytes) */ + writel(0x340710f8, &sc520_mmcr->par[5]); /* Uart D (GPCS5, 0x010f8, 8 Bytes) */ + writel(0xe3ffc000, &sc520_mmcr->par[6]); /* SDRAM (0x00000000, 128MB) */ + writel(0xaa3fd000, &sc520_mmcr->par[7]); /* StrataFlash (ROMCS1, 0x10000000, 16MB) */ + writel(0xca3fd100, &sc520_mmcr->par[8]); /* StrataFlash (ROMCS2, 0x11000000, 16MB) */ + writel(0x4203d900, &sc520_mmcr->par[9]); /* SRAM (GPCS0, 0x19000000, 1MB) */ + writel(0x4e03d910, &sc520_mmcr->par[10]); /* SRAM (GPCS3, 0x19100000, 1MB) */ + writel(0x50018100, &sc520_mmcr->par[11]); /* DP-RAM (GPCS4, 0x18100000, 4kB) */ + writel(0x54020000, &sc520_mmcr->par[12]); /* CFLASH1 (0x200000000, 4kB) */ + writel(0x5c020001, &sc520_mmcr->par[13]); /* CFLASH2 (0x200010000, 4kB) */ +/* writel(0x8bfff800, &sc520_mmcr->par14); */ /* BOOTCS at 0x18000000 */ +/* writel(0x38201000, &sc520_mmcr->par15); */ /* LEDs etc (GPCS6, 0x1000, 20 Bytes */
/* Disable Watchdog */ - sc520_mmcr->wdtmrctl = 0x3333; - sc520_mmcr->wdtmrctl = 0xcccc; - sc520_mmcr->wdtmrctl = 0x0000; + writew(0x3333, &sc520_mmcr->wdtmrctl); + writew(0xcccc, &sc520_mmcr->wdtmrctl); + writew(0x0000, &sc520_mmcr->wdtmrctl);
/* Chip Select Configuration */ - sc520_mmcr->bootcsctl = 0x0033; - sc520_mmcr->romcs1ctl = 0x0615; - sc520_mmcr->romcs2ctl = 0x0615; - - sc520_mmcr->adddecctl = 0x02; - sc520_mmcr->uart1ctl = 0x07; - sc520_mmcr->sysarbctl = 0x06; - sc520_mmcr->sysarbmenb = 0x0003; + writew(0x0033, &sc520_mmcr->bootcsctl); + writew(0x0615, &sc520_mmcr->romcs1ctl); + writew(0x0615, &sc520_mmcr->romcs2ctl); + + writeb(0x02, &sc520_mmcr->adddecctl); + writeb(0x07, &sc520_mmcr->uart1ctl); + writeb(0x06, &sc520_mmcr->sysarbctl); + writew(0x0003, &sc520_mmcr->sysarbmenb);
return 0; } diff --git a/cpu/i386/sc520/sc520.c b/cpu/i386/sc520/sc520.c index 4b566a7..519bfd8 100644 --- a/cpu/i386/sc520/sc520.c +++ b/cpu/i386/sc520/sc520.c @@ -44,24 +44,24 @@ void init_sc520(void) /* Set the UARTxCTL register at it's slower, * baud clock giving us a 1.8432 MHz reference */ - sc520_mmcr->uart1ctl = 0x07; - sc520_mmcr->uart2ctl = 0x07; + writeb(0x07, &sc520_mmcr->uart1ctl); + writeb(0x07, &sc520_mmcr->uart2ctl);
/* first set the timer pin mapping */ - sc520_mmcr->clksel = 0x72; /* no clock frequency selected, use 1.1892MHz */ + writeb(0x72, &sc520_mmcr->clksel); /* no clock frequency selected, use 1.1892MHz */
/* enable PCI bus arbitrer */ - sc520_mmcr->sysarbctl = 0x02; /* enable concurrent mode */ + writeb(0x02, &sc520_mmcr->sysarbctl); /* enable concurrent mode */
- sc520_mmcr->sysarbmenb = 0x1f; /* enable external grants */ - sc520_mmcr->hbctl = 0x04; /* enable posted-writes */ + writeb(0x1f, &sc520_mmcr->sysarbmenb); /* enable external grants */ + writeb(0x04, &sc520_mmcr->hbctl); /* enable posted-writes */
if (CONFIG_SYS_SC520_HIGH_SPEED) { - sc520_mmcr->cpuctl = 0x02; /* set it to 133 MHz and write back */ + writeb(0x02, &sc520_mmcr->cpuctl); /* set it to 133 MHz and write back */ gd->cpu_clk = 133000000; printf("## CPU Speed set to 133MHz\n"); } else { - sc520_mmcr->cpuctl = 0x01; /* set it to 100 MHz and write back */ + writeb(0x01, &sc520_mmcr->cpuctl); /* set it to 100 MHz and write back */ printf("## CPU Speed set to 100MHz\n"); gd->cpu_clk = 100000000; } @@ -74,7 +74,7 @@ void init_sc520(void) "loop 0b\n": : : "ecx");
/* turn on the cache and disable write through */ asm("movl %%cr0, %%eax\n" @@ -88,6 +88,7 @@ unsigned long init_sc520_dram(void)
u32 dram_present=0; u32 dram_ctrl; + #ifdef CONFIG_SYS_SDRAM_DRCTMCTL /* these memory control registers are set up in the assember part, * in sc520_asm.S, during 'mem_init'. If we muck with them here, @@ -97,7 +98,8 @@ unsigned long init_sc520_dram(void) * simply dictates it. */ #else - int val; + u8 tmp; + u8 val;
int cas_precharge_delay = CONFIG_SYS_SDRAM_PRECHARGE_DELAY; int refresh_rate = CONFIG_SYS_SDRAM_REFRESH_RATE; @@ -116,9 +118,10 @@ unsigned long init_sc520_dram(void) val = 3; /* 62.4us */ }
- sc520_mmcr->drcctl = (sc520_mmcr->drcctl & 0xcf) | (val<<4); + tmp = (readb(&sc520_mmcr->drcctl) & 0xcf) | (val<<4); + writeb(tmp, &sc520_mmcr->drcctl);
- val = sc520_mmcr->drctmctl & 0xf0; + val = readb(&sc520_mmcr->drctmctl) & 0xf0;
if (cas_precharge_delay==3) { val |= 0x04; /* 3T */ @@ -133,12 +136,12 @@ unsigned long init_sc520_dram(void) } else { val |= 1; } - sc520_mmcr->drctmctl = val; + writeb(val, &c520_mmcr->drctmctl); #endif
/* We read-back the configuration of the dram * controller that the assembly code wrote */ - dram_ctrl = sc520_mmcr->drcbendadr; + dram_ctrl = readl(&sc520_mmcr->drcbendadr);
bd->bi_dram[0].start = 0; if (dram_ctrl & 0x80) { @@ -191,7 +194,7 @@ void reset_cpu(ulong addr) { printf("Resetting using SC520 MMCR\n"); /* Write a '1' to the SYS_RST of the RESCFG MMCR */ - sc520_mmcr->rescfg = 0x01; + writeb(0x01, &sc520_mmcr->rescfg);
/* NOTREACHED */ } diff --git a/cpu/i386/sc520/sc520_pci.c b/cpu/i386/sc520/sc520_pci.c index f446c6d..ee7e720 100644 --- a/cpu/i386/sc520/sc520_pci.c +++ b/cpu/i386/sc520/sc520_pci.c @@ -25,6 +25,7 @@
#include <common.h> #include <pci.h> +#include <asm/io.h> #include <asm/pci.h> #include <asm/ic/sc520.h>
@@ -63,6 +64,8 @@ int sc520_pci_ints[15] = { int pci_sc520_set_irq(int pci_pin, int irq) { int i; + u8 tmpb; + u16 tmpw;
# if 1 printf("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); @@ -80,31 +83,34 @@ int pci_sc520_set_irq(int pci_pin, int irq)
/* PCI interrupt mapping (A through D)*/ for (i=0; i<=3 ;i++) { - if (sc520_mmcr->pci_int_map[i] == sc520_irq[irq].priority) - sc520_mmcr->pci_int_map[i] = SC520_IRQ_DISABLED; + if (readb(&sc520_mmcr->pci_int_map[i]) == sc520_irq[irq].priority) + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[i]); }
/* GP IRQ interrupt mapping */ for (i=0; i<=10 ;i++) { - if (sc520_mmcr->gp_int_map[i] == sc520_irq[irq].priority) - sc520_mmcr->gp_int_map[i] = SC520_IRQ_DISABLED; + if (readb(&sc520_mmcr->gp_int_map[i]) == sc520_irq[irq].priority) + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_int_map[i]); }
/* Set the trigger to level */ - sc520_mmcr->pic_mode[sc520_irq[irq].level_reg] = - sc520_mmcr->pic_mode[sc520_irq[irq].level_reg] | sc520_irq[irq].level_bit; + tmpb = readb(&sc520_mmcr->pic_mode[sc520_irq[irq].level_reg]); + tmpb |= sc520_irq[irq].level_bit; + writeb(tmpb, &sc520_mmcr->pic_mode[sc520_irq[irq].level_reg]);
if (pci_pin < 4) { /* PCI INTA-INTD */ /* route the interrupt */ - sc520_mmcr->pci_int_map[pci_pin] = sc520_irq[irq].priority; + writeb(sc520_irq[irq].priority, &sc520_mmcr->pci_int_map[pci_pin]); } else { /* GPIRQ0-GPIRQ10 used for additional PCI INTS */ - sc520_mmcr->gp_int_map[pci_pin - 4] = sc520_irq[irq].priority; + writeb(sc520_irq[irq].priority, &sc520_mmcr->gp_int_map[pci_pin - 4]);
/* also set the polarity in this case */ - sc520_mmcr->intpinpol = sc520_mmcr->intpinpol | (1 << (pci_pin-4)); + tmpw = readw(&sc520_mmcr->intpinpol); + tmpw |= (1 << (pci_pin-4)); + writew(tmpw, &sc520_mmcr->intpinpol); }
/* register the pin */ diff --git a/cpu/i386/sc520/sc520_ssi.c b/cpu/i386/sc520/sc520_ssi.c index 8dbe17a..6e5e346 100644 --- a/cpu/i386/sc520/sc520_ssi.c +++ b/cpu/i386/sc520/sc520_ssi.c @@ -24,6 +24,7 @@ /* stuff specific for the sc520, but independent of implementation */
#include <common.h> +#include <asm/io.h> #include <asm/ic/ssi.h> #include <asm/ic/sc520.h>
@@ -61,34 +62,34 @@ int ssi_set_interface(int freq, int lsb_first, int inv_clock, int inv_phase) temp |= PHS_INV_ENB; }
- sc520_mmcr->ssictl = temp; + writeb(temp, &sc520_mmcr->ssictl);
return 0; }
u8 ssi_txrx_byte(u8 data) { - sc520_mmcr->ssixmit = data; - while (sc520_mmcr->ssista & SSISTA_BSY); - sc520_mmcr->ssicmd = SSICMD_CMD_SEL_XMITRCV; - while (sc520_mmcr->ssista & SSISTA_BSY); + writeb(data, &sc520_mmcr->ssixmit); + while (readb(&sc520_mmcr->ssista) & SSISTA_BSY); + writeb(SSICMD_CMD_SEL_XMITRCV, &sc520_mmcr->ssicmd); + while (readb(&sc520_mmcr->ssista) & SSISTA_BSY);
- return sc520_mmcr->ssircv; + return readb(&sc520_mmcr->ssircv); }
void ssi_tx_byte(u8 data) { - sc520_mmcr->ssixmit = data; - while (sc520_mmcr->ssista & SSISTA_BSY); - sc520_mmcr->ssicmd = SSICMD_CMD_SEL_XMIT; + writeb(data, &sc520_mmcr->ssixmit); + while (readb(&sc520_mmcr->ssista) & SSISTA_BSY); + writeb(SSICMD_CMD_SEL_XMIT, &sc520_mmcr->ssicmd); }
u8 ssi_rx_byte(void) { - while (sc520_mmcr->ssista & SSISTA_BSY); - sc520_mmcr->ssicmd = SSICMD_CMD_SEL_RCV; - while (sc520_mmcr->ssista & SSISTA_BSY); + while (readb(&sc520_mmcr->ssista) & SSISTA_BSY); + writeb(SSICMD_CMD_SEL_RCV, &sc520_mmcr->ssicmd); + while (readb(&sc520_mmcr->ssista) & SSISTA_BSY);
- return sc520_mmcr->ssircv; + return readb(&sc520_mmcr->ssircv); } diff --git a/cpu/i386/sc520/sc520_timer.c b/cpu/i386/sc520/sc520_timer.c index 93b5b55..eca48e0 100644 --- a/cpu/i386/sc520/sc520_timer.c +++ b/cpu/i386/sc520/sc520_timer.c @@ -24,13 +24,14 @@ /* stuff specific for the sc520, but independent of implementation */
#include <common.h> +#include <asm/io.h> #include <asm/interrupt.h> #include <asm/ic/sc520.h>
void sc520_timer_isr(void) { /* Ack the GP Timer Interrupt */ - sc520_mmcr->gptmrsta = 0x02; + writeb(0x02, &sc520_mmcr->gptmrsta); }
int timer_init(void) @@ -42,28 +43,28 @@ int timer_init(void) irq_install_handler (0, timer_isr, NULL);
/* Map GP Timer 1 to Master PIC IR0 */ - sc520_mmcr->gp_tmr_int_map[1] = 0x01; + writeb(0x01, &sc520_mmcr->gp_tmr_int_map[1]);
/* Disable GP Timers 1 & 2 - Allow configuration writes */ - sc520_mmcr->gptmr1ctl = 0x4000; - sc520_mmcr->gptmr2ctl = 0x4000; + writew(0x4000, &sc520_mmcr->gptmr1ctl); + writew(0x4000, &sc520_mmcr->gptmr2ctl);
/* Reset GP Timers 1 & 2 */ - sc520_mmcr->gptmr1cnt = 0x0000; - sc520_mmcr->gptmr2cnt = 0x0000; + writew(0x0000, &sc520_mmcr->gptmr1cnt); + writew(0x0000, &sc520_mmcr->gptmr2cnt);
/* Setup GP Timer 2 as a 100kHz (10us) prescaler */ - sc520_mmcr->gptmr2maxcmpa = 83; - sc520_mmcr->gptmr2ctl = 0xc001; + writew(83, &sc520_mmcr->gptmr2maxcmpa); + writew(0xc001, &sc520_mmcr->gptmr2ctl);
/* Setup GP Timer 1 as a 1000 Hz (1ms) interrupt generator */ - sc520_mmcr->gptmr1maxcmpa = 100; - sc520_mmcr->gptmr1ctl = 0xe009; + writew(100, &sc520_mmcr->gptmr1maxcmpa); + writew(0xe009, &sc520_mmcr->gptmr1ctl);
unmask_irq (0);
/* Clear the GP Timer 1 status register to get the show rolling*/ - sc520_mmcr->gptmrsta = 0x02; + writeb(0x02, &sc520_mmcr->gptmrsta);
return 0; } @@ -74,11 +75,11 @@ void __udelay(unsigned long usec) long u; long temp;
- temp = sc520_mmcr->swtmrmilli; - temp = sc520_mmcr->swtmrmicro; + temp = readw(&sc520_mmcr->swtmrmilli); + temp = readw(&sc520_mmcr->swtmrmicro);
do { - m += sc520_mmcr->swtmrmilli; - u = sc520_mmcr->swtmrmicro + (m * 1000); + m += readw(&sc520_mmcr->swtmrmilli); + u = readw(&sc520_mmcr->swtmrmicro) + (m * 1000); } while (u < usec); }
Shamelessly steal the Linux x86 crash handling code and shove it into U-Boot (cool - it fits). Be sure to include suitable attribution to Linus --- This patch also fixed the annoyance of adding an extra 3 bytes per IRQ handler. I _really_ like this patch - It has probably been the single most useful patch as it adds the ability to use int3 to help debugging
cpu/i386/interrupts.c | 310 ++++++++++++++++++++++++++++++++++++------------- 1 files changed, 228 insertions(+), 82 deletions(-)
diff --git a/cpu/i386/interrupts.c b/cpu/i386/interrupts.c index 4b57437..2eae5be 100644 --- a/cpu/i386/interrupts.c +++ b/cpu/i386/interrupts.c @@ -5,6 +5,9 @@ * (C) Copyright 2002 * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. * + * Portions of this file are derived from the Linux kernel source + * Copyright (C) 1991, 1992 Linus Torvalds + * * See file CREDITS for list of people who contributed to this * project. * @@ -32,12 +35,112 @@ ".hidden irq_"#x"\n" \ ".type irq_"#x", @function\n" \ "irq_"#x":\n" \ - "pushl %ebp\n" \ - "movl %esp,%ebp\n" \ - "pusha\n" \ "pushl $"#x"\n" \ "jmp irq_common_entry\n"
+/* + * Volatile isn't enough to prevent the compiler from reordering the + * read/write functions for the control registers and messing everything up. + * A memory clobber would solve the problem, but would prevent reordering of + * all loads stores around it, which can hurt performance. Solution is to + * use a variable and mimic reads and writes to it to enforce serialization + */ +static unsigned long __force_order; + +static inline unsigned long read_cr0(void) +{ + unsigned long val; + asm volatile("mov %%cr0,%0\n\t" : "=r" (val), "=m" (__force_order)); + return val; +} + +static inline unsigned long read_cr2(void) +{ + unsigned long val; + asm volatile("mov %%cr2,%0\n\t" : "=r" (val), "=m" (__force_order)); + return val; +} + +static inline unsigned long read_cr3(void) +{ + unsigned long val; + asm volatile("mov %%cr3,%0\n\t" : "=r" (val), "=m" (__force_order)); + return val; +} + +static inline unsigned long read_cr4(void) +{ + unsigned long val; + asm volatile("mov %%cr4,%0\n\t" : "=r" (val), "=m" (__force_order)); + return val; +} + +static inline unsigned long get_debugreg(int regno) +{ + unsigned long val = 0; /* Damn you, gcc! */ + + switch (regno) { + case 0: + asm("mov %%db0, %0" :"=r" (val)); + break; + case 1: + asm("mov %%db1, %0" :"=r" (val)); + break; + case 2: + asm("mov %%db2, %0" :"=r" (val)); + break; + case 3: + asm("mov %%db3, %0" :"=r" (val)); + break; + case 6: + asm("mov %%db6, %0" :"=r" (val)); + break; + case 7: + asm("mov %%db7, %0" :"=r" (val)); + break; + default: + val = 0; + } + return val; +} + +void dump_regs(struct pt_regs *regs) +{ + unsigned long cr0 = 0L, cr2 = 0L, cr3 = 0L, cr4 = 0L; + unsigned long d0, d1, d2, d3, d6, d7; + + printf("EIP: %04x:[<%08lx>] EFLAGS: %08lx\n", + (u16)regs->xcs, regs->eip, regs->eflags); + + printf("EAX: %08lx EBX: %08lx ECX: %08lx EDX: %08lx\n", + regs->eax, regs->ebx, regs->ecx, regs->edx); + printf("ESI: %08lx EDI: %08lx EBP: %08lx ESP: %08lx\n", + regs->esi, regs->edi, regs->ebp, regs->esp); + printf(" DS: %04x ES: %04x FS: %04x GS: %04x SS: %04x\n", + (u16)regs->xds, (u16)regs->xes, (u16)regs->xfs, (u16)regs->xgs, (u16)regs->xss); + + cr0 = read_cr0(); + cr2 = read_cr2(); + cr3 = read_cr3(); + cr4 = read_cr4(); + + printf("CR0: %08lx CR2: %08lx CR3: %08lx CR4: %08lx\n", + cr0, cr2, cr3, cr4); + + d0 = get_debugreg(0); + d1 = get_debugreg(1); + d2 = get_debugreg(2); + d3 = get_debugreg(3); + + printf("DR0: %08lx DR1: %08lx DR2: %08lx DR3: %08lx\n", + d0, d1, d2, d3); + + d6 = get_debugreg(6); + d7 = get_debugreg(7); + printf("DR6: %08lx DR7: %08lx\n", + d6, d7); +} + struct idt_entry { u16 base_low; u16 selector; @@ -122,7 +225,7 @@ int disable_interrupts(void) }
/* IRQ Low-Level Service Routine */ -__isr__ irq_llsr(int ip, int seg, int irq) +__isr__ irq_llsr(struct pt_regs *regs) { /* * For detailed description of each exception, refer to: @@ -131,74 +234,93 @@ __isr__ irq_llsr(int ip, int seg, int irq) * Order Number: 253665-029US, November 2008 * Table 6-1. Exceptions and Interrupts */ - switch (irq) { - case 0x00: - printf("Divide Error (Division by zero) at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x01: - printf("Debug Interrupt (Single step) at %04x:%08x\n", seg, ip); - break; - case 0x02: - printf("NMI Interrupt at %04x:%08x\n", seg, ip); - break; - case 0x03: - printf("Breakpoint at %04x:%08x\n", seg, ip); - break; - case 0x04: - printf("Overflow at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x05: - printf("BOUND Range Exceeded at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x06: - printf("Invalid Opcode (UnDefined Opcode) at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x07: - printf("Device Not Available (No Math Coprocessor) at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x08: - printf("Double fault at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x09: - printf("Co-processor segment overrun at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x0a: - printf("Invalid TSS at %04x:%08x\n", seg, ip); - break; - case 0x0b: - printf("Segment Not Present at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x0c: - printf("Stack Segment Fault at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x0d: - printf("General Protection at %04x:%08x\n", seg, ip); - break; - case 0x0e: - printf("Page fault at %04x:%08x\n", seg, ip); - while(1); - break; - case 0x0f: - printf("Floating-Point Error (Math Fault) at %04x:%08x\n", seg, ip); - break; - case 0x10: - printf("Alignment check at %04x:%08x\n", seg, ip); - break; - case 0x11: - printf("Machine Check at %04x:%08x\n", seg, ip); - break; - case 0x12: - printf("SIMD Floating-Point Exception at %04x:%08x\n", seg, ip); - break; + switch (regs->orig_eax) { + case 0x00: + printf("Divide Error (Division by zero)\n"); + dump_regs(regs); + while(1); + break; + case 0x01: + printf("Debug Interrupt (Single step)\n"); + dump_regs(regs); + break; + case 0x02: + printf("NMI Interrupt\n"); + dump_regs(regs); + break; + case 0x03: + printf("Breakpoint\n"); + dump_regs(regs); + break; + case 0x04: + printf("Overflow\n"); + dump_regs(regs); + while(1); + break; + case 0x05: + printf("BOUND Range Exceeded\n"); + dump_regs(regs); + while(1); + break; + case 0x06: + printf("Invalid Opcode (UnDefined Opcode)\n"); + dump_regs(regs); + while(1); + break; + case 0x07: + printf("Device Not Available (No Math Coprocessor)\n"); + dump_regs(regs); + while(1); + break; + case 0x08: + printf("Double fault\n"); + dump_regs(regs); + while(1); + break; + case 0x09: + printf("Co-processor segment overrun\n"); + dump_regs(regs); + while(1); + break; + case 0x0a: + printf("Invalid TSS\n"); + dump_regs(regs); + break; + case 0x0b: + printf("Segment Not Present\n"); + dump_regs(regs); + while(1); + break; + case 0x0c: + printf("Stack Segment Fault\n"); + dump_regs(regs); + while(1); + break; + case 0x0d: + printf("General Protection\n"); + dump_regs(regs); + break; + case 0x0e: + printf("Page fault\n"); + dump_regs(regs); + while(1); + break; + case 0x0f: + printf("Floating-Point Error (Math Fault)\n"); + dump_regs(regs); + break; + case 0x10: + printf("Alignment check\n"); + dump_regs(regs); + break; + case 0x11: + printf("Machine Check\n"); + dump_regs(regs); + break; + case 0x12: + printf("SIMD Floating-Point Exception\n"); + dump_regs(regs); + break; case 0x13: case 0x14: case 0x15: @@ -212,12 +334,13 @@ __isr__ irq_llsr(int ip, int seg, int irq) case 0x1d: case 0x1e: case 0x1f: - printf("Reserved Exception %d at %04x:%08x\n", irq, seg, ip); + printf("Reserved Exception\n"); + dump_regs(regs); break;
default: /* Hardware or User IRQ */ - do_irq(irq); + do_irq(regs->orig_eax); } }
@@ -226,22 +349,45 @@ __isr__ irq_llsr(int ip, int seg, int irq) * fully relocatable code. * - The call to irq_llsr will be a relative jump * - The IRQ entries will be guaranteed to be in order - * It's a bit annoying that we need to waste 3 bytes per interrupt entry - * (total of 768 code bytes), but we MUST create a Stack Frame and this is - * the easiest way I could do it. Maybe it can be made better later. + * Interrupt entries are now very small (a push and a jump) but they are + * now slower (all registers pushed on stack which provides complete + * crash dumps in the low level handlers */ asm(".globl irq_common_entry\n" \ ".hidden irq_common_entry\n" \ ".type irq_common_entry, @function\n" \ "irq_common_entry:\n" \ - "pushl $0\n" \ - "pushl $0\n" \ + "cld\n" \ + "pushl %gs\n" \ + "pushl %fs\n" \ + "pushl %es\n" \ + "pushl %ds\n" \ + "pushl %eax\n" \ + "pushl %ebp\n" \ + "pushl %edi\n" \ + "pushl %esi\n" \ + "pushl %edx\n" \ + "pushl %ecx\n" \ + "pushl %ebx\n" \ + "mov %esp, %eax\n" \ + "pushl %ebp\n" \ + "movl %esp,%ebp\n" \ + "pushl %eax\n" \ "call irq_llsr\n" \ "popl %eax\n" \ - "popl %eax\n" \ - "popl %eax\n" \ - "popa\n" \ "leave\n"\ + "popl %ebx\n" \ + "popl %ecx\n" \ + "popl %edx\n" \ + "popl %esi\n" \ + "popl %edi\n" \ + "popl %ebp\n" \ + "popl %eax\n" \ + "popl %ds\n" \ + "popl %es\n" \ + "popl %fs\n" \ + "popl %gs\n" \ + "add $4, %esp\n" \ "iret\n" \ DECLARE_INTERRUPT(0) \ DECLARE_INTERRUPT(1) \
This was broken a long time ago by a49864593e083a5d0779fb9ca98e5a0f2053183d which munged the NIOS and x86 do_go_exec() --- PS - I think NIOS is still broken (can someone please check)
lib_i386/board.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/lib_i386/board.c b/lib_i386/board.c index af81cd5..5e28c6f 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -422,10 +422,10 @@ void hang (void) unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[]) { /* - * TODO: Test this function - changed to fix compiler error. - * Original code was: - * return (entry >> 1) (argc, argv); - * with a comment about Nios function pointers are address >> 1 + * x86 does not use a dedicated register to pass the pointer + * to the global_data */ + argv[-1] = (char *)gd; + return (entry) (argc, argv); }
There is an error in how the assembler version of the sc520 memory size reporting code works. As a result, it will only ever report at most the size of one bank of RAM --- cpu/i386/sc520/sc520_asm.S | 35 +++++++++++++++++------------------ 1 files changed, 17 insertions(+), 18 deletions(-)
diff --git a/cpu/i386/sc520/sc520_asm.S b/cpu/i386/sc520/sc520_asm.S index 2042d9b..135f7b4 100644 --- a/cpu/i386/sc520/sc520_asm.S +++ b/cpu/i386/sc520/sc520_asm.S @@ -503,38 +503,37 @@ dram_done:
movl $DRCBENDADR, %edi /* DRAM ending address register */
- movl (%edi), %eax - movl %eax, %ecx - andl $0x80000000, %ecx - jz bank2 - andl $0x7f000000, %eax - shrl $2, %eax - movl %eax, %ebx - -bank2: movl (%edi), %eax +bank0: movl (%edi), %eax movl %eax, %ecx - andl $0x00800000, %ecx + andl $0x00000080, %ecx jz bank1 - andl $0x007f0000, %eax - shll $6, %eax + andl $0x0000007f, %eax + shll $22, %eax movl %eax, %ebx
bank1: movl (%edi), %eax movl %eax, %ecx andl $0x00008000, %ecx - jz bank0 + jz bank2 andl $0x00007f00, %eax shll $14, %eax movl %eax, %ebx
-bank0: movl (%edi), %eax +bank2: movl (%edi), %eax movl %eax, %ecx - andl $0x00000080, %ecx - jz done - andl $0x0000007f, %eax - shll $22, %eax + andl $0x00800000, %ecx + jz bank3 + andl $0x007f0000, %eax + shll $6, %eax movl %eax, %ebx
+bank3: movl (%edi), %eax + movl %eax, %ecx + andl $0x80000000, %ecx + jz done + andl $0x7f000000, %eax + shrl $2, %eax + movl %eax, %ebx
done: movl %ebx, %eax
This patch allows the low-level assembler boot-strap to obtain the RAM size without calling the destructive 'sizer' routine. This allows boot-strapping from a U-Boot image loaded in RAM --- cpu/i386/sc520/sc520_asm.S | 95 ++++++++++++++++++++++++++----------------- cpu/i386/start.S | 5 ++ 2 files changed, 62 insertions(+), 38 deletions(-)
diff --git a/cpu/i386/sc520/sc520_asm.S b/cpu/i386/sc520/sc520_asm.S index 135f7b4..c745454 100644 --- a/cpu/i386/sc520/sc520_asm.S +++ b/cpu/i386/sc520/sc520_asm.S @@ -498,47 +498,21 @@ bad_ram:
dram_done:
- /* readback DRCBENDADR and return the number - * of available ram bytes in %eax */ - - movl $DRCBENDADR, %edi /* DRAM ending address register */ - -bank0: movl (%edi), %eax - movl %eax, %ecx - andl $0x00000080, %ecx - jz bank1 - andl $0x0000007f, %eax - shll $22, %eax - movl %eax, %ebx - -bank1: movl (%edi), %eax - movl %eax, %ecx - andl $0x00008000, %ecx - jz bank2 - andl $0x00007f00, %eax - shll $14, %eax - movl %eax, %ebx - -bank2: movl (%edi), %eax - movl %eax, %ecx - andl $0x00800000, %ecx - jz bank3 - andl $0x007f0000, %eax - shll $6, %eax - movl %eax, %ebx +#if CONFIG_SYS_SDRAM_ECC_ENABLE + /* + * We are in the middle of an existing 'call' - Need to store the + * existing return address before making another 'call' + */ + movl %ebp, %ebx
-bank3: movl (%edi), %eax - movl %eax, %ecx - andl $0x80000000, %ecx - jz done - andl $0x7f000000, %eax - shrl $2, %eax - movl %eax, %ebx + /* Get the memory size */ + movl $init_ecc, %ebp + jmpl get_mem_size
-done: - movl %ebx, %eax +init_ecc: + /* Restore the orignal return address */ + movl %ebx, %ebp
-#if CONFIG_SYS_SDRAM_ECC_ENABLE /* A nominal memory test: just a byte at each address line */ movl %eax, %ecx shrl $0x1, %ecx @@ -575,6 +549,51 @@ set_ecc: mov $0x05, %al movb %al, (%edi) #endif + out: + jmp *%ebp + +/* + * Read and decode the sc520 DRCBENDADR MMCR and return the number of + * available ram bytes in %eax + */ +.globl get_mem_size +get_mem_size: + movl $DRCBENDADR, %edi /* DRAM ending address register */ + +bank0: movl (%edi), %eax + movl %eax, %ecx + andl $0x00000080, %ecx + jz bank1 + andl $0x0000007f, %eax + shll $22, %eax + movl %eax, %ebx + +bank1: movl (%edi), %eax + movl %eax, %ecx + andl $0x00008000, %ecx + jz bank2 + andl $0x00007f00, %eax + shll $14, %eax + movl %eax, %ebx + +bank2: movl (%edi), %eax + movl %eax, %ecx + andl $0x00800000, %ecx + jz bank3 + andl $0x007f0000, %eax + shll $6, %eax + movl %eax, %ebx + +bank3: movl (%edi), %eax + movl %eax, %ecx + andl $0x80000000, %ecx + jz done + andl $0x7f000000, %eax + shrl $2, %eax + movl %eax, %ebx + +done: movl %ebx, %eax jmp *%ebp + diff --git a/cpu/i386/start.S b/cpu/i386/start.S index 25d32e6..1980f1a 100644 --- a/cpu/i386/start.S +++ b/cpu/i386/start.S @@ -63,6 +63,11 @@ early_board_init_ret: jmp mem_init mem_init_ret:
+ /* fetch memory size (into %eax) */ + mov $get_mem_size_ret, %ebp + jmp get_mem_size +get_mem_size_ret: + /* Check we have enough memory for stack */ movl $CONFIG_SYS_STACK_SIZE, %ecx cmpl %ecx, %eax
Add a parameter to the 32-bit entry to indicate if entry is from Real Mode or not. If entry is from Real Mode, execute the destructive 'sizer' routine to determine memory size as we are booting cold and running in Flash. If not entering from Real Mode, we are executing a U-Boot image from RAM and therefore the memory size is already known (and running 'sizer' will destroy the running image)
There are now two 32-bit entry points. The first is the 'in RAM' entry point which exists at the start of the U-Boot binary image. As such, you can load u-boot.bin in RAM and jump directly to the load address without needing to calculate any offsets. The second entry point is used by the real-to-protected mode switch
This patch also changes TEXT_BASE to 0x6000000 (in RAM). You can load the resulting image at 0x6000000 and simple go 0x6000000 from the u-boot prompt
Hopefully a later patch will completely elliminate any dependency on TEXT_BASE like a relocatable linux kernel (perfect world) --- board/eNET/config.mk | 2 +- board/eNET/u-boot.lds | 9 ++++----- cpu/i386/start.S | 34 ++++++++++++++++++++++++++++++++++ cpu/i386/start16.S | 7 +++++-- 4 files changed, 44 insertions(+), 8 deletions(-)
diff --git a/board/eNET/config.mk b/board/eNET/config.mk index 5c64804..cb2e24d 100644 --- a/board/eNET/config.mk +++ b/board/eNET/config.mk @@ -21,7 +21,7 @@ # MA 02111-1307 USA #
-TEXT_BASE = 0x38040000 +TEXT_BASE = 0x06000000 CFLAGS_dlmalloc.o += -Wa,--no-warn -fno-strict-aliasing PLATFORM_RELFLAGS += -fvisibility=hidden PLATFORM_CPPFLAGS += -fno-dwarf2-cfi-asm diff --git a/board/eNET/u-boot.lds b/board/eNET/u-boot.lds index 0d74021..7b0ffaa 100644 --- a/board/eNET/u-boot.lds +++ b/board/eNET/u-boot.lds @@ -27,7 +27,7 @@ ENTRY(_start)
SECTIONS { - . = 0x38040000; /* Location of bootcode in flash */ + . = 0x06000000; /* Location of bootcode in flash */ _i386boot_text_start = .; .text : { *(.text); }
@@ -97,14 +97,13 @@ SECTIONS * at reset and the code have to fit. * The fff0 offset of resetvec is important, however. */ - . = 0xfffffe00; - .start32 : AT (0x3807fe00) { *(.start32); } + .start32 : AT (0x0603fe00) { *(.start32); }
. = 0xf800; - .start16 : AT (0x3807f800) { *(.start16); } + .start16 : AT (0x0603f800) { *(.start16); }
. = 0xfff0; - .resetvec : AT (0x3807fff0) { *(.resetvec); } + .resetvec : AT (0x0603fff0) { *(.resetvec); } _i386boot_end = (LOADADDR(.resetvec) + SIZEOF(.resetvec) ); } diff --git a/cpu/i386/start.S b/cpu/i386/start.S index 1980f1a..e1d4492 100644 --- a/cpu/i386/start.S +++ b/cpu/i386/start.S @@ -33,7 +33,32 @@ .type _start, @function .globl _i386boot_start _i386boot_start: + /* + * This is the fail safe 32-bit bootstrap entry point. The + * following code is not executed from a cold-reset (actually, a + * lot of it is, but from real-mode after cold reset. It is + * repeated here to put the board into a state as close to cold + * reset as necessary) + */ + cli + cld + + /* Turn of cache (this might require a 486-class CPU) */ + movl %cr0, %eax + orl $0x60000000,%eax + movl %eax, %cr0 + wbinvd + + lidt blank_idt_ptr + + /* Tell 32-bit code it is being entered from */ + movw $0x0000, %bx + + /* Flush the prefetch queue */ + jmp _start _start: + /* This is the 32-bit cold-reset entry point */ + movl $0x18,%eax /* Load our segement registes, the * gdt have already been loaded by start16.S */ movw %ax,%fs @@ -42,6 +67,15 @@ _start: movw %ax,%es movw %ax,%ss
+ /* + * Skip low-level board and memory initialization if not starting + * from cold-reset. This allows us to do a fail safe boot-strap + * into a new build of U-Boot from a known-good boot flash + */ + movw $0x0001, %ax + cmpw %ax, %bx + jne mem_init_ret + /* We call a few functions in the board support package * since we have no stack yet we'll have to use %ebp * to store the return address */ diff --git a/cpu/i386/start16.S b/cpu/i386/start16.S index 1ebb6bc..1caa686 100644 --- a/cpu/i386/start16.S +++ b/cpu/i386/start16.S @@ -45,7 +45,7 @@ board_init16_ret: wbinvd
/* load the descriptor tables */ -o32 cs lidt idt_ptr +o32 cs lidt blank_idt_ptr o32 cs lgdt gdt_ptr
@@ -57,6 +57,8 @@ o32 cs lgdt gdt_ptr /* Flush the prefetch queue */ jmp ff ff: + /* Tell 32-bit code it is being entered from hard-reset */ + movw $0x0001, %bx
/* Finally jump to the 32bit initialization code */ movw $code32start, %ax @@ -68,7 +70,8 @@ code32start: .long _start /* offset */ .word 0x10 /* segment */
-idt_ptr: +.global blank_idt_ptr +blank_idt_ptr: .word 0 /* limit */ .long 0 /* base */
Currently, the GDT is either located in FLASH or in the non-relocated U-Boot image in RAM. Both of these locations are unsafe as those locations can be erased during a U-Boot update. Move the GDT into the highest available memory location and relocate U-Boot to just below it --- cpu/i386/start.S | 110 +++++++++++++++++++++++++++++++++++++++++++++++++--- cpu/i386/start16.S | 28 +++---------- 2 files changed, 111 insertions(+), 27 deletions(-)
diff --git a/cpu/i386/start.S b/cpu/i386/start.S index e1d4492..8874470 100644 --- a/cpu/i386/start.S +++ b/cpu/i386/start.S @@ -49,13 +49,8 @@ _i386boot_start: movl %eax, %cr0 wbinvd
- lidt blank_idt_ptr - - /* Tell 32-bit code it is being entered from */ + /* Tell 32-bit code it is being entered from an in-RAM copy */ movw $0x0000, %bx - - /* Flush the prefetch queue */ - jmp _start _start: /* This is the 32-bit cold-reset entry point */
@@ -67,6 +62,9 @@ _start: movw %ax,%es movw %ax,%ss
+ /* Clear the interupt vectors */ + lidt blank_idt_ptr + /* * Skip low-level board and memory initialization if not starting * from cold-reset. This allows us to do a fail safe boot-strap @@ -102,6 +100,53 @@ mem_init_ret: jmp get_mem_size get_mem_size_ret:
+ /* + * We are now in 'Flat Protected Mode' and we know how much memory + * the board has. The (temporary) Global Descriptor Table is not + * in a 'Safe' place (it is either in Flash which can be erased or + * reprogrammed or in a fail-safe boot-strap image which could be + * over-ridden). + * + * Move the final gdt to a safe place (top of RAM) and load it. + * This is not a trivial excercise - the lgdt instruction does not + * have a register operand (memory only) and we may well be + * running from Flash, so self modifying code will not work here. + * To overcome this, we copy a stub into upper memory along with + * the GDT. + */ + + /* Reduce upper memory limit by (Stub + GDT Pointer + GDT) */ + subl $(end_gdt_setup - start_gdt_setup), %eax + + /* Copy the GDT and Stub */ + movl $start_gdt_setup, %esi + movl %eax, %edi + movl $(end_gdt_setup - start_gdt_setup), %ecx + shrl $2, %ecx + cld + rep movsl + + /* write the lgdt 'parameter' */ + subl $(jmp_instr - start_gdt_setup - 4), %ebp + addl %eax, %ebp + movl $(gdt_ptr - start_gdt_setup), %ebx + addl %eax, %ebx + movl %ebx, (%ebp) + + /* write the gdt address into the pointer */ + movl $(gdt_addr - start_gdt_setup), %ebp + addl %eax, %ebp + movl $(gdt - start_gdt_setup), %ebx + addl %eax, %ebx + movl %ebx, (%ebp) + + /* Save the return address */ + movl $load_gdt_ret, %ebp + + /* Load the new (safe) Global Descriptor Table */ + jmp *%eax + +load_gdt_ret: /* Check we have enough memory for stack */ movl $CONFIG_SYS_STACK_SIZE, %ecx cmpl %ecx, %eax @@ -172,3 +217,56 @@ stack_ok: die: hlt jmp die hlt + +blank_idt_ptr: + .word 0 /* limit */ + .long 0 /* base */ + +.align 4 +start_gdt_setup: + lgdt gdt_ptr +jmp_instr: + jmp *%ebp + +.align 4 +gdt_ptr: + .word 0x30 /* limit (48 bytes = 6 GDT entries) */ +gdt_addr: + .long gdt /* base */ + + /* The GDT table ... + * + * Selector Type + * 0x00 NULL + * 0x08 Unused + * 0x10 32bit code + * 0x18 32bit data/stack + * 0x20 16bit code + * 0x28 16bit data/stack + */ + +.align 4 +gdt: + .word 0, 0, 0, 0 /* NULL */ + .word 0, 0, 0, 0 /* unused */ + + .word 0xFFFF /* 4Gb - (0x100000*0x1000 = 4Gb) */ + .word 0 /* base address = 0 */ + .word 0x9B00 /* code read/exec */ + .word 0x00CF /* granularity = 4096, 386 (+5th nibble of limit) */ + + .word 0xFFFF /* 4Gb - (0x100000*0x1000 = 4Gb) */ + .word 0x0 /* base address = 0 */ + .word 0x9300 /* data read/write */ + .word 0x00CF /* granularity = 4096, 386 (+5th nibble of limit) */ + + .word 0xFFFF /* 64kb */ + .word 0 /* base address = 0 */ + .word 0x9b00 /* data read/write */ + .word 0x0010 /* granularity = 1 (+5th nibble of limit) */ + + .word 0xFFFF /* 64kb */ + .word 0 /* base address = 0 */ + .word 0x9300 /* data read/write */ + .word 0x0010 /* granularity = 1 (+5th nibble of limit) */ +end_gdt_setup: diff --git a/cpu/i386/start16.S b/cpu/i386/start16.S index 1caa686..3e8b2cc 100644 --- a/cpu/i386/start16.S +++ b/cpu/i386/start16.S @@ -44,11 +44,9 @@ board_init16_ret: movl %eax, %cr0 wbinvd
- /* load the descriptor tables */ -o32 cs lidt blank_idt_ptr + /* load the temporary Global Descriptor Table */ o32 cs lgdt gdt_ptr
- /* Now, we enter protected mode */ movl %cr0, %eax orl $1,%eax @@ -70,13 +68,13 @@ code32start: .long _start /* offset */ .word 0x10 /* segment */
-.global blank_idt_ptr -blank_idt_ptr: - .word 0 /* limit */ - .long 0 /* base */ - +/* + * The following Global Descriptor Table is just enough to get us into + * 'Flat Protected Mode' - It will be discarded as soon as the final + * GDT is setup in a safe location in RAM + */ gdt_ptr: - .word 0x30 /* limit (48 bytes = 6 GDT entries) */ + .word 0x20 /* limit (32 bytes = 4 GDT entries) */ .long BOOT_SEG + gdt /* base */
/* The GDT table ... @@ -86,8 +84,6 @@ gdt_ptr: * 0x08 Unused * 0x10 32bit code * 0x18 32bit data/stack - * 0x20 16bit code - * 0x28 16bit data/stack */
gdt: @@ -103,13 +99,3 @@ gdt: .word 0x0 /* base address = 0 */ .word 0x9300 /* data read/write */ .word 0x00CF /* granularity = 4096, 386 (+5th nibble of limit) */ - - .word 0xFFFF /* 64kb */ - .word 0 /* base address = 0 */ - .word 0x9b00 /* data read/write */ - .word 0x0010 /* granularity = 1 (+5th nibble of limit) */ - - .word 0xFFFF /* 64kb */ - .word 0 /* base address = 0 */ - .word 0x9300 /* data read/write */ - .word 0x0010 /* granularity = 1 (+5th nibble of limit) */
In order to locate the 16-bit BIOS code, we need to know the reloaction offset.
--- This was a lot tricker than it should have been --- lib_i386/board.c | 63 ++++++++++++++++++++++++++++++----------------------- 1 files changed, 36 insertions(+), 27 deletions(-)
diff --git a/lib_i386/board.c b/lib_i386/board.c index 5e28c6f..947a8ec 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -52,7 +52,9 @@ extern ulong _i386boot_rel_dyn_start; extern ulong _i386boot_rel_dyn_end; extern ulong _i386boot_bss_start; extern ulong _i386boot_bss_size; -void ram_bootstrap (void *); + +void ram_bootstrap (void *, ulong); + const char version_string[] = U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ")";
@@ -162,6 +164,7 @@ init_fnc_t *init_sequence[] = { NULL, };
+static gd_t gd_data; gd_t *gd;
/* @@ -174,21 +177,18 @@ void board_init_f (ulong stack_limit) Elf32_Rel *rel_dyn_start = (Elf32_Rel *)&_i386boot_rel_dyn_start; Elf32_Rel *rel_dyn_end = (Elf32_Rel *)&_i386boot_rel_dyn_end; void *bss_start = &_i386boot_bss_start; - void *bss_size = &_i386boot_bss_size; + ulong bss_size = (ulong)&_i386boot_bss_size;
- size_t uboot_size; - void *ram_start; + ulong uboot_size; + void *dest_addr; ulong rel_offset; Elf32_Rel *re;
- void (*start_func)(void *); - - /* compiler optimization barrier needed for GCC >= 3.4 */ - __asm__ __volatile__("": : :"memory"); + void (*start_func)(void *, ulong);
- uboot_size = (size_t)u_boot_cmd_end - (size_t)text_start; - ram_start = (void *)stack_limit - (uboot_size + (ulong)bss_size); - rel_offset = text_start - ram_start; + uboot_size = (ulong)u_boot_cmd_end - (ulong)text_start; + dest_addr = (void *)stack_limit - (uboot_size + (ulong)bss_size); + rel_offset = text_start - dest_addr; start_func = ram_bootstrap - rel_offset;
/* First stage CPU initialization */ @@ -200,10 +200,10 @@ void board_init_f (ulong stack_limit) hang();
/* Copy U-Boot into RAM */ - memcpy(ram_start, text_start, (size_t)uboot_size); + memcpy(dest_addr, text_start, uboot_size);
/* Clear BSS */ - memset(bss_start - rel_offset, 0, (size_t)bss_size); + memset(bss_start - rel_offset, 0, bss_size);
/* Perform relocation adjustments */ for (re = rel_dyn_start; re < rel_dyn_end; re++) @@ -213,27 +213,39 @@ void board_init_f (ulong stack_limit) *(ulong *)(re->r_offset - rel_offset) -= (Elf32_Addr)rel_offset; }
- start_func(ram_start); - - /* NOTREACHED - relocate_code() does not return */ + /* Enter the relocated U-Boot! */ + start_func(dest_addr, rel_offset); + /* NOTREACHED - board_init_f() does not return */ while(1); }
/* - * All attempts to jump straight from board_init_f() to board_init_r() - * have failed, hence this special 'bootstrap' function. + * We cannot initialize gd_data in board_init_f() because we would be + * attempting to write to flash (I have even tried using manual relocation + * adjustments on pointers but it just won't work) and board_init_r() does + * not have enough arguments to allow us to pass the relocation offset + * straight up. This bootstrap function (which runs in RAM) is used to + * setup gd_data in order to pass the relocation offset to the rest of + * U-Boot. + * + * TODO: The compiler optimization barrier is intended to stop GCC from + * optimizing this function into board_init_f(). It seems to work without + * it, but I've left it in to be sure. I think also that the barrier in + * board_init_r() is no longer needed, but left it in 'just in case' */ -void ram_bootstrap (void *ram_start) +void ram_bootstrap (void *dest_addr, ulong rel_offset) { - static gd_t gd_data; - /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
- board_init_r(&gd_data, (ulong)ram_start); + /* tell others: relocation done */ + gd_data.reloc_off = rel_offset; + gd_data.flags |= GD_FLG_RELOC; + + board_init_r(&gd_data, (ulong)dest_addr); }
-void board_init_r(gd_t *id, ulong ram_start) +void board_init_r(gd_t *id, ulong dest_addr) { char *s; int i; @@ -247,16 +259,13 @@ void board_init_r(gd_t *id, ulong ram_start) /* compiler optimization barrier needed for GCC >= 3.4 */ __asm__ __volatile__("": : :"memory");
- memset (gd, 0, sizeof (gd_t)); gd->bd = &bd_data; memset (gd->bd, 0, sizeof (bd_t)); show_boot_progress(0x22);
gd->baudrate = CONFIG_BAUDRATE;
- gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */ - - mem_malloc_init((((ulong)ram_start - CONFIG_SYS_MALLOC_LEN)+3)&~3, + mem_malloc_init((((ulong)dest_addr - CONFIG_SYS_MALLOC_LEN)+3)&~3, CONFIG_SYS_MALLOC_LEN);
for (init_fnc_ptr = init_sequence, i=0; *init_fnc_ptr; ++init_fnc_ptr, i++) {
Now that the relocation offset is in Global Data, we can locate the BIOS code in the U-Boot image --- lib_i386/bios_setup.c | 2 +- lib_i386/realmode.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib_i386/bios_setup.c b/lib_i386/bios_setup.c index 6491e52..a92b77e 100644 --- a/lib_i386/bios_setup.c +++ b/lib_i386/bios_setup.c @@ -141,7 +141,7 @@ static void setvector(int vector, u16 segment, void *handler)
int bios_setup(void) { - ulong i386boot_bios = (ulong)&_i386boot_bios; + ulong i386boot_bios = (ulong)&_i386boot_bios + gd->reloc_off; ulong i386boot_bios_size = (ulong)&_i386boot_bios_size;
static int done=0; diff --git a/lib_i386/realmode.c b/lib_i386/realmode.c index 3c3c1fc..b3f5123 100644 --- a/lib_i386/realmode.c +++ b/lib_i386/realmode.c @@ -37,7 +37,7 @@ extern char realmode_enter;
int realmode_setup(void) { - ulong i386boot_realmode = (ulong)&_i386boot_realmode; + ulong i386boot_realmode = (ulong)&_i386boot_realmode + gd->reloc_off; ulong i386boot_realmode_size = (ulong)&_i386boot_realmode_size;
/* copy the realmode switch code */
The x86 architecture exclusively uses Port-Mapped I/O (inb/outb) to access the 16550 UARTs. This patch mimics how Linux selects between Memory-Mapped and Port-Mapped I/O. This allows x86 boards to use CONFIG_SERIAL_MUTLI and drop the custom serial port driver --- drivers/serial/ns16550.c | 69 ++++++++++++++++++++++++++-------------------- 1 files changed, 39 insertions(+), 30 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index b3bf10b..0e9beb7 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -7,6 +7,8 @@ #include <config.h> #include <ns16550.h> #include <watchdog.h> +#include <linux/types.h> +#include <asm/io.h>
#define UART_LCRVAL UART_LCR_8N1 /* 8 data, 1 stop, no parity */ #define UART_MCRVAL (UART_MCR_DTR | \ @@ -14,28 +16,35 @@ #define UART_FCRVAL (UART_FCR_FIFO_EN | \ UART_FCR_RXSR | \ UART_FCR_TXSR) /* Clear & enable FIFOs */ +#ifdef CONFIG_X86 +#define serial_out(x,y) outb(x,(ulong)y) +#define serial_in(y) inb((ulong)y) +#else +#define serial_out(x,y) writeb(x,y) +#define serial_in(y) readb(y) +#endif
void NS16550_init (NS16550_t com_port, int baud_divisor) { - com_port->ier = 0x00; + serial_out(0x00, &com_port->ier); #if defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2) - com_port->mdr1 = 0x7; /* mode select reset TL16C750*/ + serial_out(0x7, &com_port->mdr1); /* mode select reset TL16C750*/ #endif - com_port->lcr = UART_LCR_BKSE | UART_LCRVAL; - com_port->dll = 0; - com_port->dlm = 0; - com_port->lcr = UART_LCRVAL; - com_port->mcr = UART_MCRVAL; - com_port->fcr = UART_FCRVAL; - com_port->lcr = UART_LCR_BKSE | UART_LCRVAL; - com_port->dll = baud_divisor & 0xff; - com_port->dlm = (baud_divisor >> 8) & 0xff; - com_port->lcr = UART_LCRVAL; + serial_out(UART_LCR_BKSE | UART_LCRVAL, (ulong)&com_port->lcr); + serial_out(0, &com_port->dll); + serial_out(0, &com_port->dlm); + serial_out(UART_LCRVAL, &com_port->lcr); + serial_out(UART_MCRVAL, &com_port->mcr); + serial_out(UART_FCRVAL, &com_port->fcr); + serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); + serial_out(baud_divisor & 0xff, &com_port->dll); + serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); + serial_out(UART_LCRVAL, &com_port->lcr); #if defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2) #if defined(CONFIG_APTIX) - com_port->mdr1 = 3; /* /13 mode so Aptix 6MHz can hit 115200 */ + serial_out(3, &com_port->mdr1); /* /13 mode so Aptix 6MHz can hit 115200 */ #else - com_port->mdr1 = 0; /* /16 is proper to hit 115200 with 48MHz */ + serial_out(0, &com_port->mdr1); /* /16 is proper to hit 115200 with 48MHz */ #endif #endif /* CONFIG_OMAP */ } @@ -43,42 +52,42 @@ void NS16550_init (NS16550_t com_port, int baud_divisor) #ifndef CONFIG_NS16550_MIN_FUNCTIONS void NS16550_reinit (NS16550_t com_port, int baud_divisor) { - com_port->ier = 0x00; - com_port->lcr = UART_LCR_BKSE | UART_LCRVAL; - com_port->dll = 0; - com_port->dlm = 0; - com_port->lcr = UART_LCRVAL; - com_port->mcr = UART_MCRVAL; - com_port->fcr = UART_FCRVAL; - com_port->lcr = UART_LCR_BKSE; - com_port->dll = baud_divisor & 0xff; - com_port->dlm = (baud_divisor >> 8) & 0xff; - com_port->lcr = UART_LCRVAL; + serial_out(0x00, &com_port->ier); + serial_out(UART_LCR_BKSE | UART_LCRVAL, &com_port->lcr); + serial_out(0, &com_port->dll); + serial_out(0, &com_port->dlm); + serial_out(UART_LCRVAL, &com_port->lcr); + serial_out(UART_MCRVAL, &com_port->mcr); + serial_out(UART_FCRVAL, &com_port->fcr); + serial_out(UART_LCR_BKSE, &com_port->lcr); + serial_out(baud_divisor & 0xff, &com_port->dll); + serial_out((baud_divisor >> 8) & 0xff, &com_port->dlm); + serial_out(UART_LCRVAL, &com_port->lcr); } #endif /* CONFIG_NS16550_MIN_FUNCTIONS */
void NS16550_putc (NS16550_t com_port, char c) { - while ((com_port->lsr & UART_LSR_THRE) == 0); - com_port->thr = c; + while ((serial_in(&com_port->lsr) & UART_LSR_THRE) == 0); + serial_out(c, &com_port->thr); }
#ifndef CONFIG_NS16550_MIN_FUNCTIONS char NS16550_getc (NS16550_t com_port) { - while ((com_port->lsr & UART_LSR_DR) == 0) { + while ((serial_in(&com_port->lsr) & UART_LSR_DR) == 0) { #ifdef CONFIG_USB_TTY extern void usbtty_poll(void); usbtty_poll(); #endif WATCHDOG_RESET(); } - return (com_port->rbr); + return serial_in(&com_port->rbr); }
int NS16550_tstc (NS16550_t com_port) { - return ((com_port->lsr & UART_LSR_DR) != 0); + return ((serial_in(&com_port->lsr) & UART_LSR_DR) != 0); }
--- board/eNET/eNET.c | 3 +- common/serial.c | 3 +- cpu/i386/Makefile | 2 +- cpu/i386/serial.c | 506 ------------------------------------------------ include/configs/eNET.h | 25 ++- include/serial.h | 3 +- lib_i386/board.c | 5 +- 7 files changed, 31 insertions(+), 516 deletions(-) delete mode 100644 cpu/i386/serial.c
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index f794beb..52ea140 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -111,8 +111,9 @@ int board_early_init_f(void) writew(0x0615, &sc520_mmcr->romcs1ctl); writew(0x0615, &sc520_mmcr->romcs2ctl);
- writeb(0x02, &sc520_mmcr->adddecctl); + writeb(0x00, &sc520_mmcr->adddecctl); writeb(0x07, &sc520_mmcr->uart1ctl); + writeb(0x07, &sc520_mmcr->uart2ctl); writeb(0x06, &sc520_mmcr->sysarbctl); writew(0x0003, &sc520_mmcr->sysarbmenb);
diff --git a/common/serial.c b/common/serial.c index 5f9ffd7..d4a632b 100644 --- a/common/serial.c +++ b/common/serial.c @@ -41,7 +41,8 @@ struct serial_device *__default_serial_console (void) #elif defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) \ || defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) \ || defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) \ - || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) \ + || defined(CONFIG_SYS_SC520) #if defined(CONFIG_CONS_INDEX) && defined(CONFIG_SYS_NS16550_SERIAL) #if (CONFIG_CONS_INDEX==1) return &eserial1_device; diff --git a/cpu/i386/Makefile b/cpu/i386/Makefile index c658c6e..bb0a48f 100644 --- a/cpu/i386/Makefile +++ b/cpu/i386/Makefile @@ -29,7 +29,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o start16.o resetvec.o -COBJS = serial.o interrupts.o cpu.o +COBJS = interrupts.o cpu.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/i386/serial.c b/cpu/i386/serial.c deleted file mode 100644 index e7025a3..0000000 --- a/cpu/i386/serial.c +++ /dev/null @@ -1,506 +0,0 @@ -/* - * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se - * - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -/*------------------------------------------------------------------------------+ */ - -/* - * This source code is dual-licensed. You may use it under the terms of the - * GNU General Public License version 2, or under the license below. - * - * This source code has been made available to you by IBM on an AS-IS - * basis. Anyone receiving this source is licensed under IBM - * copyrights to use it in any way he or she deems fit, including - * copying it, modifying it, compiling it, and redistributing it either - * with or without modifications. No license under IBM patents or - * patent applications is to be implied by the copyright license. - * - * Any user of this software should understand that IBM cannot provide - * technical support for this software and will not be responsible for - * any consequences resulting from the use of this software. - * - * Any person who transfers this source code or any derivative work - * must include the IBM copyright notice, this paragraph, and the - * preceding two paragraphs in the transferred software. - * - * COPYRIGHT I B M CORPORATION 1995 - * LICENSED MATERIAL - PROGRAM PROPERTY OF I B M - */ -/*------------------------------------------------------------------------------- */ - -#include <common.h> -#include <watchdog.h> -#include <asm/io.h> -#include <asm/ibmpc.h> - -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO -#include <malloc.h> -#endif - -DECLARE_GLOBAL_DATA_PTR; - -#define UART_RBR 0x00 -#define UART_THR 0x00 -#define UART_IER 0x01 -#define UART_IIR 0x02 -#define UART_FCR 0x02 -#define UART_LCR 0x03 -#define UART_MCR 0x04 -#define UART_LSR 0x05 -#define UART_MSR 0x06 -#define UART_SCR 0x07 -#define UART_DLL 0x00 -#define UART_DLM 0x01 - -/*-----------------------------------------------------------------------------+ - | Line Status Register. - +-----------------------------------------------------------------------------*/ -#define asyncLSRDataReady1 0x01 -#define asyncLSROverrunError1 0x02 -#define asyncLSRParityError1 0x04 -#define asyncLSRFramingError1 0x08 -#define asyncLSRBreakInterrupt1 0x10 -#define asyncLSRTxHoldEmpty1 0x20 -#define asyncLSRTxShiftEmpty1 0x40 -#define asyncLSRRxFifoError1 0x80 - - -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO -/*-----------------------------------------------------------------------------+ - | Fifo - +-----------------------------------------------------------------------------*/ -typedef struct { - char *rx_buffer; - ulong rx_put; - ulong rx_get; - int cts; -} serial_buffer_t; - -volatile serial_buffer_t buf_info; -static int serial_buffer_active=0; -#endif - - -static int serial_div(int baudrate) -{ - - switch (baudrate) { - case 1200: - return 96; - case 9600: - return 12; - case 19200: - return 6; - case 38400: - return 3; - case 57600: - return 2; - case 115200: - return 1; - } - - return 12; -} - - -/* - * Minimal serial functions needed to use one of the SMC ports - * as serial console interface. - */ - -int serial_init(void) -{ - volatile char val; - int bdiv = serial_div(gd->baudrate); - - outb(0x80, UART0_BASE + UART_LCR); /* set DLAB bit */ - outb(bdiv, UART0_BASE + UART_DLL); /* set baudrate divisor */ - outb(bdiv >> 8, UART0_BASE + UART_DLM);/* set baudrate divisor */ - outb(0x03, UART0_BASE + UART_LCR); /* clear DLAB; set 8 bits, no parity */ - outb(0x01, UART0_BASE + UART_FCR); /* enable FIFO */ - outb(0x0b, UART0_BASE + UART_MCR); /* Set DTR and RTS active */ - val = inb(UART0_BASE + UART_LSR); /* clear line status */ - val = inb(UART0_BASE + UART_RBR); /* read receive buffer */ - outb(0x00, UART0_BASE + UART_SCR); /* set scratchpad */ - outb(0x00, UART0_BASE + UART_IER); /* set interrupt enable reg */ - - return 0; -} - - -void serial_setbrg(void) -{ - unsigned short bdiv; - - bdiv = serial_div(gd->baudrate); - - outb(0x80, UART0_BASE + UART_LCR); /* set DLAB bit */ - outb(bdiv&0xff, UART0_BASE + UART_DLL); /* set baudrate divisor */ - outb(bdiv >> 8, UART0_BASE + UART_DLM);/* set baudrate divisor */ - outb(0x03, UART0_BASE + UART_LCR); /* clear DLAB; set 8 bits, no parity */ -} - - -void serial_putc(const char c) -{ - int i; - - if (c == '\n') - serial_putc ('\r'); - - /* check THRE bit, wait for transmiter available */ - for (i = 1; i < 3500; i++) { - if ((inb (UART0_BASE + UART_LSR) & 0x20) == 0x20) { - break; - } - udelay(100); - } - outb(c, UART0_BASE + UART_THR); /* put character out */ -} - - -void serial_puts(const char *s) -{ - while (*s) { - serial_putc(*s++); - } -} - - -int serial_getc(void) -{ - unsigned char status = 0; - -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - if (serial_buffer_active) { - return serial_buffered_getc(); - } -#endif - - while (1) { -#if defined(CONFIG_HW_WATCHDOG) - WATCHDOG_RESET(); /* Reset HW Watchdog, if needed */ -#endif /* CONFIG_HW_WATCHDOG */ - status = inb(UART0_BASE + UART_LSR); - if ((status & asyncLSRDataReady1) != 0x0) { - break; - } - if ((status & ( asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1 )) != 0) { - outb(asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1, UART0_BASE + UART_LSR); - } - } - return (0x000000ff & (int) inb (UART0_BASE)); -} - - -int serial_tstc(void) -{ - unsigned char status; - -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - if (serial_buffer_active) { - return serial_buffered_tstc(); - } -#endif - - status = inb(UART0_BASE + UART_LSR); - if ((status & asyncLSRDataReady1) != 0x0) { - return (1); - } - if ((status & ( asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1 )) != 0) { - outb(asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1, UART0_BASE + UART_LSR); - } - return 0; -} - - -#ifdef CONFIG_SERIAL_SOFTWARE_FIFO - -void serial_isr(void *arg) -{ - int space; - int c; - int rx_put = buf_info.rx_put; - - if (buf_info.rx_get <= rx_put) { - space = CONFIG_SERIAL_SOFTWARE_FIFO - (rx_put - buf_info.rx_get); - } else { - space = buf_info.rx_get - rx_put; - } - - while (inb(UART0_BASE + UART_LSR) & 1) { - c = inb(UART0_BASE); - if (space) { - buf_info.rx_buffer[rx_put++] = c; - space--; - - if (rx_put == buf_info.rx_get) { - buf_info.rx_get++; - if (rx_put == CONFIG_SERIAL_SOFTWARE_FIFO) { - buf_info.rx_get = 0; - } - } - - if (rx_put == CONFIG_SERIAL_SOFTWARE_FIFO) { - rx_put = 0; - if (0 == buf_info.rx_get) { - buf_info.rx_get = 1; - } - - } - - } - if (space < CONFIG_SERIAL_SOFTWARE_FIFO / 4) { - /* Stop flow by setting RTS inactive */ - outb(inb(UART0_BASE + UART_MCR) & (0xFF ^ 0x02), - UART0_BASE + UART_MCR); - } - } - buf_info.rx_put = rx_put; -} - -void serial_buffered_init(void) -{ - serial_puts ("Switching to interrupt driven serial input mode.\n"); - buf_info.rx_buffer = malloc (CONFIG_SERIAL_SOFTWARE_FIFO); - buf_info.rx_put = 0; - buf_info.rx_get = 0; - - if (inb (UART0_BASE + UART_MSR) & 0x10) { - serial_puts ("Check CTS signal present on serial port: OK.\n"); - buf_info.cts = 1; - } else { - serial_puts ("WARNING: CTS signal not present on serial port.\n"); - buf_info.cts = 0; - } - - irq_install_handler ( VECNUM_U0 /*UART0 */ /*int vec */ , - serial_isr /*interrupt_handler_t *handler */ , - (void *) &buf_info /*void *arg */ ); - - /* Enable "RX Data Available" Interrupt on UART */ - /* outb(inb(UART0_BASE + UART_IER) |0x01, UART0_BASE + UART_IER); */ - outb(0x01, UART0_BASE + UART_IER); - - /* Set DTR and RTS active, enable interrupts */ - outb(inb (UART0_BASE + UART_MCR) | 0x0b, UART0_BASE + UART_MCR); - - /* Setup UART FIFO: RX trigger level: 1 byte, Enable FIFO */ - outb( /*(1 << 6) |*/ 1, UART0_BASE + UART_FCR); - - serial_buffer_active = 1; -} - -void serial_buffered_putc (const char c) -{ - int i; - /* Wait for CTS */ -#if defined(CONFIG_HW_WATCHDOG) - while (!(inb (UART0_BASE + UART_MSR) & 0x10)) - WATCHDOG_RESET (); -#else - if (buf_info.cts) { - for (i=0;i<1000;i++) { - if ((inb (UART0_BASE + UART_MSR) & 0x10)) { - break; - } - } - if (i!=1000) { - buf_info.cts = 0; - } - } else { - if ((inb (UART0_BASE + UART_MSR) & 0x10)) { - buf_info.cts = 1; - } - } - -#endif - serial_putc (c); -} - -void serial_buffered_puts(const char *s) -{ - serial_puts (s); -} - -int serial_buffered_getc(void) -{ - int space; - int c; - int rx_get = buf_info.rx_get; - int rx_put; - -#if defined(CONFIG_HW_WATCHDOG) - while (rx_get == buf_info.rx_put) - WATCHDOG_RESET (); -#else - while (rx_get == buf_info.rx_put); -#endif - c = buf_info.rx_buffer[rx_get++]; - if (rx_get == CONFIG_SERIAL_SOFTWARE_FIFO) { - rx_get = 0; - } - buf_info.rx_get = rx_get; - - rx_put = buf_info.rx_put; - if (rx_get <= rx_put) { - space = CONFIG_SERIAL_SOFTWARE_FIFO - (rx_put - rx_get); - } else { - space = rx_get - rx_put; - } - if (space > CONFIG_SERIAL_SOFTWARE_FIFO / 2) { - /* Start flow by setting RTS active */ - outb(inb (UART0_BASE + UART_MCR) | 0x02, UART0_BASE + UART_MCR); - } - - return c; -} - -int serial_buffered_tstc(void) -{ - return (buf_info.rx_get != buf_info.rx_put) ? 1 : 0; -} - -#endif /* CONFIG_SERIAL_SOFTWARE_FIFO */ - - -#if defined(CONFIG_CMD_KGDB) -/* - AS HARNOIS : according to CONFIG_KGDB_SER_INDEX kgdb uses serial port - number 0 or number 1 - - if CONFIG_KGDB_SER_INDEX = 1 => serial port number 0 : - configuration has been already done - - if CONFIG_KGDB_SER_INDEX = 2 => serial port number 1 : - configure port 1 for serial I/O with rate = CONFIG_KGDB_BAUDRATE -*/ -#if (CONFIG_KGDB_SER_INDEX & 2) -void kgdb_serial_init(void) -{ - volatile char val; - bdiv = serial_div (CONFIG_KGDB_BAUDRATE); - - /* - * Init onboard 16550 UART - */ - outb(0x80, UART1_BASE + UART_LCR); /* set DLAB bit */ - outb((bdiv & 0xff), UART1_BASE + UART_DLL); /* set divisor for 9600 baud */ - outb((bdiv >> 8 ), UART1_BASE + UART_DLM); /* set divisor for 9600 baud */ - outb(0x03, UART1_BASE + UART_LCR); /* line control 8 bits no parity */ - outb(0x00, UART1_BASE + UART_FCR); /* disable FIFO */ - outb(0x00, UART1_BASE + UART_MCR); /* no modem control DTR RTS */ - val = inb(UART1_BASE + UART_LSR); /* clear line status */ - val = inb(UART1_BASE + UART_RBR); /* read receive buffer */ - outb(0x00, UART1_BASE + UART_SCR); /* set scratchpad */ - outb(0x00, UART1_BASE + UART_IER); /* set interrupt enable reg */ -} - - -void putDebugChar(const char c) -{ - if (c == '\n') - serial_putc ('\r'); - - outb(c, UART1_BASE + UART_THR); /* put character out */ - - /* check THRE bit, wait for transfer done */ - while ((inb(UART1_BASE + UART_LSR) & 0x20) != 0x20); -} - - -void putDebugStr(const char *s) -{ - while (*s) { - serial_putc(*s++); - } -} - - -int getDebugChar(void) -{ - unsigned char status = 0; - - while (1) { - status = inb(UART1_BASE + UART_LSR); - if ((status & asyncLSRDataReady1) != 0x0) { - break; - } - if ((status & ( asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1 )) != 0) { - outb(asyncLSRFramingError1 | - asyncLSROverrunError1 | - asyncLSRParityError1 | - asyncLSRBreakInterrupt1, UART1_BASE + UART_LSR); - } - } - return (0x000000ff & (int) inb(UART1_BASE)); -} - - -void kgdb_interruptible(int yes) -{ - return; -} - -#else /* ! (CONFIG_KGDB_SER_INDEX & 2) */ - -void kgdb_serial_init(void) -{ - serial_printf ("[on serial] "); -} - -void putDebugChar(int c) -{ - serial_putc (c); -} - -void putDebugStr(const char *str) -{ - serial_puts (str); -} - -int getDebugChar(void) -{ - return serial_getc (); -} - -void kgdb_interruptible(int yes) -{ - return; -} -#endif /* (CONFIG_KGDB_SER_INDEX & 2) */ -#endif diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 6a68bf4..971840f 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <asm/ibmpc.h> /* * board/config.h - configuration options, board specific */ @@ -55,6 +56,25 @@ #undef CONFIG_HW_WATCHDOG
/*----------------------------------------------------------------------- + * Serial Configuration + */ +#define CONFIG_SERIAL_MULTI +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK 1843200 +#define CONFIG_BAUDRATE 9600 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + +#define CONFIG_SYS_NS16550_COM1 UART0_BASE +#define CONFIG_SYS_NS16550_COM2 UART1_BASE +#define CONFIG_SYS_NS16550_COM3 (0x1000 + UART0_BASE) +#define CONFIG_SYS_NS16550_COM4 (0x1000 + UART1_BASE) + + /*----------------------------------------------------------------------- * Video Configuration */ #undef CONFIG_VIDEO /* No Video Hardware */ @@ -65,8 +85,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024)
-#define CONFIG_BAUDRATE 9600 - /*----------------------------------------------------------------------- * Command line configuration. */ @@ -123,9 +141,6 @@
#define CONFIG_SYS_HZ 1024 /* incrementer freq: 1kHz */
- /* valid baudrates */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - /*----------------------------------------------------------------------- * SDRAM Configuration */ diff --git a/include/serial.h b/include/serial.h index f2638ec..aa87a93 100644 --- a/include/serial.h +++ b/include/serial.h @@ -25,7 +25,8 @@ extern struct serial_device * default_serial_console (void); #if defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) || \ defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) || \ - defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) || \ + defined(CONFIG_SYS_SC520) extern struct serial_device serial0_device; extern struct serial_device serial1_device; #if defined(CONFIG_SYS_NS16550_SERIAL) diff --git a/lib_i386/board.c b/lib_i386/board.c index 947a8ec..7115a2f 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -37,6 +37,7 @@ #include <malloc.h> #include <net.h> #include <ide.h> +#include <serial.h> #include <asm/u-boot-i386.h> #include <elf.h>
@@ -149,7 +150,6 @@ static void display_flash_config (ulong size) typedef int (init_fnc_t) (void);
init_fnc_t *init_sequence[] = { - serial_init, cpu_init_r, /* basic cpu dependent setup */ board_early_init_r, /* basic board dependent setup */ dram_init, /* configure available RAM banks */ @@ -277,6 +277,9 @@ void board_init_r(gd_t *id, ulong dest_addr) } show_boot_progress(0x23);
+#ifdef CONFIG_SERIAL_MULTI + serial_initialize(); +#endif /* configure available FLASH banks */ size = flash_init(); display_flash_config(size);
It is possibly to setup x86 boards to use non-PC/AT configurations. For example, the sc520 is an x86 CPU with PC/AT and non-PC/AT peripherals. This function allows the board to set itself up for maximum PC/AT compatibility just before booting the Linux kernel (the Linux kernel 'just works' if everything is PC/AT compliant) --- include/asm-i386/u-boot-i386.h | 2 ++ lib_i386/board.c | 8 ++++++++ 2 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/include/asm-i386/u-boot-i386.h b/include/asm-i386/u-boot-i386.h index 7c99c8c..2bce82e 100644 --- a/include/asm-i386/u-boot-i386.h +++ b/include/asm-i386/u-boot-i386.h @@ -43,6 +43,8 @@ int cpu_init_interrupts(void); int board_init(void); int dram_init(void);
+void setup_pcat_compatibility(void); + void isa_unmap_rom(u32 addr); u32 isa_map_rom(u32 bus_addr, int size);
diff --git a/lib_i386/board.c b/lib_i386/board.c index 7115a2f..b852ed1 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -441,3 +441,11 @@ unsigned long do_go_exec (ulong (*entry)(int, char *[]), int argc, char *argv[])
return (entry) (argc, argv); } + +void setup_pcat_compatibility(void) + __attribute__((weak, alias("__setup_pcat_compatibility"))); + +void __setup_pcat_compatibility(void) +{ +} +
Add support for newer (up to 2.6.33) kernels
Add zboot command which takes the address of a bzImage as its first argument and (optionally) the size of the bzImage as the second argument (the second argument is needed for older kernels which do not include the bzImage size in the header) --- include/asm-generic/ioctl.h | 105 ++++++++++++++ include/asm-i386/bootparam.h | 123 +++++++++++++++++ include/asm-i386/e820.h | 155 +++++++++++++++++++++ include/asm-i386/ioctl.h | 1 + include/asm-i386/ist.h | 34 +++++ include/linux/apm_bios.h | 220 ++++++++++++++++++++++++++++++ include/linux/compiler-gcc.h | 87 ++++++++++++ include/linux/compiler-gcc4.h | 61 ++++++++ include/linux/compiler.h | 303 +++++++++++++++++++++++++++++++++++++++++ include/linux/edd.h | 194 ++++++++++++++++++++++++++ include/linux/ioctl.h | 7 + include/linux/ioport.h | 192 ++++++++++++++++++++++++++ include/linux/screen_info.h | 84 +++++++++++ lib_i386/zimage.c | 127 +++++++++++++----- 14 files changed, 1661 insertions(+), 32 deletions(-) create mode 100644 include/asm-generic/ioctl.h create mode 100644 include/asm-i386/bootparam.h create mode 100644 include/asm-i386/e820.h create mode 100644 include/asm-i386/ioctl.h create mode 100644 include/asm-i386/ist.h create mode 100644 include/linux/apm_bios.h create mode 100644 include/linux/compiler-gcc.h create mode 100644 include/linux/compiler-gcc4.h create mode 100644 include/linux/compiler.h create mode 100644 include/linux/edd.h create mode 100644 include/linux/ioctl.h create mode 100644 include/linux/ioport.h create mode 100644 include/linux/screen_info.h
diff --git a/include/asm-generic/ioctl.h b/include/asm-generic/ioctl.h new file mode 100644 index 0000000..15828b2 --- /dev/null +++ b/include/asm-generic/ioctl.h @@ -0,0 +1,105 @@ +#ifndef _ASM_GENERIC_IOCTL_H +#define _ASM_GENERIC_IOCTL_H + +/* ioctl command encoding: 32 bits total, command in lower 16 bits, + * size of the parameter structure in the lower 14 bits of the + * upper 16 bits. + * Encoding the size of the parameter structure in the ioctl request + * is useful for catching programs compiled with old versions + * and to avoid overwriting user space outside the user buffer area. + * The highest 2 bits are reserved for indicating the ``access mode''. + * NOTE: This limits the max parameter size to 16kB -1 ! + */ + +/* + * The following is for compatibility across the various Linux + * platforms. The generic ioctl numbering scheme doesn't really enforce + * a type field. De facto, however, the top 8 bits of the lower 16 + * bits are indeed used as a type field, so we might just as well make + * this explicit here. Please be sure to use the decoding macros + * below from now on. + */ +#define _IOC_NRBITS 8 +#define _IOC_TYPEBITS 8 + +/* + * Let any architecture override either of the following before + * including this file. + */ + +#ifndef _IOC_SIZEBITS +# define _IOC_SIZEBITS 14 +#endif + +#ifndef _IOC_DIRBITS +# define _IOC_DIRBITS 2 +#endif + +#define _IOC_NRMASK ((1 << _IOC_NRBITS)-1) +#define _IOC_TYPEMASK ((1 << _IOC_TYPEBITS)-1) +#define _IOC_SIZEMASK ((1 << _IOC_SIZEBITS)-1) +#define _IOC_DIRMASK ((1 << _IOC_DIRBITS)-1) + +#define _IOC_NRSHIFT 0 +#define _IOC_TYPESHIFT (_IOC_NRSHIFT+_IOC_NRBITS) +#define _IOC_SIZESHIFT (_IOC_TYPESHIFT+_IOC_TYPEBITS) +#define _IOC_DIRSHIFT (_IOC_SIZESHIFT+_IOC_SIZEBITS) + +/* + * Direction bits, which any architecture can choose to override + * before including this file. + */ + +#ifndef _IOC_NONE +# define _IOC_NONE 0U +#endif + +#ifndef _IOC_WRITE +# define _IOC_WRITE 1U +#endif + +#ifndef _IOC_READ +# define _IOC_READ 2U +#endif + +#define _IOC(dir,type,nr,size) \ + (((dir) << _IOC_DIRSHIFT) | \ + ((type) << _IOC_TYPESHIFT) | \ + ((nr) << _IOC_NRSHIFT) | \ + ((size) << _IOC_SIZESHIFT)) + +#ifdef __KERNEL__ +/* provoke compile error for invalid uses of size argument */ +extern unsigned int __invalid_size_argument_for_IOC; +#define _IOC_TYPECHECK(t) \ + ((sizeof(t) == sizeof(t[1]) && \ + sizeof(t) < (1 << _IOC_SIZEBITS)) ? \ + sizeof(t) : __invalid_size_argument_for_IOC) +#else +#define _IOC_TYPECHECK(t) (sizeof(t)) +#endif + +/* used to create numbers */ +#define _IO(type,nr) _IOC(_IOC_NONE,(type),(nr),0) +#define _IOR(type,nr,size) _IOC(_IOC_READ,(type),(nr),(_IOC_TYPECHECK(size))) +#define _IOW(type,nr,size) _IOC(_IOC_WRITE,(type),(nr),(_IOC_TYPECHECK(size))) +#define _IOWR(type,nr,size) _IOC(_IOC_READ|_IOC_WRITE,(type),(nr),(_IOC_TYPECHECK(size))) +#define _IOR_BAD(type,nr,size) _IOC(_IOC_READ,(type),(nr),sizeof(size)) +#define _IOW_BAD(type,nr,size) _IOC(_IOC_WRITE,(type),(nr),sizeof(size)) +#define _IOWR_BAD(type,nr,size) _IOC(_IOC_READ|_IOC_WRITE,(type),(nr),sizeof(size)) + +/* used to decode ioctl numbers.. */ +#define _IOC_DIR(nr) (((nr) >> _IOC_DIRSHIFT) & _IOC_DIRMASK) +#define _IOC_TYPE(nr) (((nr) >> _IOC_TYPESHIFT) & _IOC_TYPEMASK) +#define _IOC_NR(nr) (((nr) >> _IOC_NRSHIFT) & _IOC_NRMASK) +#define _IOC_SIZE(nr) (((nr) >> _IOC_SIZESHIFT) & _IOC_SIZEMASK) + +/* ...and for the drivers/sound files... */ + +#define IOC_IN (_IOC_WRITE << _IOC_DIRSHIFT) +#define IOC_OUT (_IOC_READ << _IOC_DIRSHIFT) +#define IOC_INOUT ((_IOC_WRITE|_IOC_READ) << _IOC_DIRSHIFT) +#define IOCSIZE_MASK (_IOC_SIZEMASK << _IOC_SIZESHIFT) +#define IOCSIZE_SHIFT (_IOC_SIZESHIFT) + +#endif /* _ASM_GENERIC_IOCTL_H */ diff --git a/include/asm-i386/bootparam.h b/include/asm-i386/bootparam.h new file mode 100644 index 0000000..6be33d8 --- /dev/null +++ b/include/asm-i386/bootparam.h @@ -0,0 +1,123 @@ +#ifndef _ASM_X86_BOOTPARAM_H +#define _ASM_X86_BOOTPARAM_H + +#include <linux/types.h> +#include <linux/screen_info.h> +#include <linux/apm_bios.h> +#include <linux/edd.h> +#include <asm/e820.h> +#include <asm/ist.h> +#include <video/edid.h> + +/* setup data types */ +#define SETUP_NONE 0 +#define SETUP_E820_EXT 1 + +/* extensible setup data list node */ +struct setup_data { + __u64 next; + __u32 type; + __u32 len; + __u8 data[0]; +}; + +struct setup_header { + __u8 setup_sects; + __u16 root_flags; + __u32 syssize; + __u16 ram_size; +#define RAMDISK_IMAGE_START_MASK 0x07FF +#define RAMDISK_PROMPT_FLAG 0x8000 +#define RAMDISK_LOAD_FLAG 0x4000 + __u16 vid_mode; + __u16 root_dev; + __u16 boot_flag; + __u16 jump; + __u32 header; + __u16 version; + __u32 realmode_swtch; + __u16 start_sys; + __u16 kernel_version; + __u8 type_of_loader; + __u8 loadflags; +#define LOADED_HIGH (1<<0) +#define QUIET_FLAG (1<<5) +#define KEEP_SEGMENTS (1<<6) +#define CAN_USE_HEAP (1<<7) + __u16 setup_move_size; + __u32 code32_start; + __u32 ramdisk_image; + __u32 ramdisk_size; + __u32 bootsect_kludge; + __u16 heap_end_ptr; + __u8 ext_loader_ver; + __u8 ext_loader_type; + __u32 cmd_line_ptr; + __u32 initrd_addr_max; + __u32 kernel_alignment; + __u8 relocatable_kernel; + __u8 _pad2[3]; + __u32 cmdline_size; + __u32 hardware_subarch; + __u64 hardware_subarch_data; + __u32 payload_offset; + __u32 payload_length; + __u64 setup_data; +} __attribute__((packed)); + +struct sys_desc_table { + __u16 length; + __u8 table[14]; +}; + +struct efi_info { + __u32 efi_loader_signature; + __u32 efi_systab; + __u32 efi_memdesc_size; + __u32 efi_memdesc_version; + __u32 efi_memmap; + __u32 efi_memmap_size; + __u32 efi_systab_hi; + __u32 efi_memmap_hi; +}; + +/* The so-called "zeropage" */ +struct boot_params { + struct screen_info screen_info; /* 0x000 */ + struct apm_bios_info apm_bios_info; /* 0x040 */ + __u8 _pad2[4]; /* 0x054 */ + __u64 tboot_addr; /* 0x058 */ + struct ist_info ist_info; /* 0x060 */ + __u8 _pad3[16]; /* 0x070 */ + __u8 hd0_info[16]; /* obsolete! */ /* 0x080 */ + __u8 hd1_info[16]; /* obsolete! */ /* 0x090 */ + struct sys_desc_table sys_desc_table; /* 0x0a0 */ + __u8 _pad4[144]; /* 0x0b0 */ + struct edid_info edid_info; /* 0x140 */ + struct efi_info efi_info; /* 0x1c0 */ + __u32 alt_mem_k; /* 0x1e0 */ + __u32 scratch; /* Scratch field! */ /* 0x1e4 */ + __u8 e820_entries; /* 0x1e8 */ + __u8 eddbuf_entries; /* 0x1e9 */ + __u8 edd_mbr_sig_buf_entries; /* 0x1ea */ + __u8 _pad6[6]; /* 0x1eb */ + struct setup_header hdr; /* setup header */ /* 0x1f1 */ + __u8 _pad7[0x290-0x1f1-sizeof(struct setup_header)]; + __u32 edd_mbr_sig_buffer[EDD_MBR_SIG_MAX]; /* 0x290 */ + struct e820entry e820_map[E820MAX]; /* 0x2d0 */ + __u8 _pad8[48]; /* 0xcd0 */ + struct edd_info eddbuf[EDDMAXNR]; /* 0xd00 */ + __u8 _pad9[276]; /* 0xeec */ +} __attribute__((packed)); + +enum { + X86_SUBARCH_PC = 0, + X86_SUBARCH_LGUEST, + X86_SUBARCH_XEN, + X86_SUBARCH_MRST, + X86_NR_SUBARCHS, +}; + + + +#endif /* _ASM_X86_BOOTPARAM_H */ diff --git a/include/asm-i386/e820.h b/include/asm-i386/e820.h new file mode 100644 index 0000000..d155ce9 --- /dev/null +++ b/include/asm-i386/e820.h @@ -0,0 +1,155 @@ +#ifndef _ASM_X86_E820_H +#define _ASM_X86_E820_H +#define E820MAP 0x2d0 /* our map */ +#define E820MAX 128 /* number of entries in E820MAP */ + +/* + * Legacy E820 BIOS limits us to 128 (E820MAX) nodes due to the + * constrained space in the zeropage. If we have more nodes than + * that, and if we've booted off EFI firmware, then the EFI tables + * passed us from the EFI firmware can list more nodes. Size our + * internal memory map tables to have room for these additional + * nodes, based on up to three entries per node for which the + * kernel was built: MAX_NUMNODES == (1 << CONFIG_NODES_SHIFT), + * plus E820MAX, allowing space for the possible duplicate E820 + * entries that might need room in the same arrays, prior to the + * call to sanitize_e820_map() to remove duplicates. The allowance + * of three memory map entries per node is "enough" entries for + * the initial hardware platform motivating this mechanism to make + * use of additional EFI map entries. Future platforms may want + * to allow more than three entries per node or otherwise refine + * this size. + */ + +/* + * Odd: 'make headers_check' complains about numa.h if I try + * to collapse the next two #ifdef lines to a single line: + * #if defined(__KERNEL__) && defined(CONFIG_EFI) + */ +#ifdef __KERNEL__ +#ifdef CONFIG_EFI +#include <linux/numa.h> +#define E820_X_MAX (E820MAX + 3 * MAX_NUMNODES) +#else /* ! CONFIG_EFI */ +#define E820_X_MAX E820MAX +#endif +#else /* ! __KERNEL__ */ +#define E820_X_MAX E820MAX +#endif + +#define E820NR 0x1e8 /* # entries in E820MAP */ + +#define E820_RAM 1 +#define E820_RESERVED 2 +#define E820_ACPI 3 +#define E820_NVS 4 +#define E820_UNUSABLE 5 + +/* reserved RAM used by kernel itself */ +#define E820_RESERVED_KERN 128 + +#ifndef __ASSEMBLY__ +#include <linux/types.h> +struct e820entry { + __u64 addr; /* start of memory segment */ + __u64 size; /* size of memory segment */ + __u32 type; /* type of memory segment */ +} __attribute__((packed)); + +struct e820map { + __u32 nr_map; + struct e820entry map[E820_X_MAX]; +}; + +#define ISA_START_ADDRESS 0xa0000 +#define ISA_END_ADDRESS 0x100000 + +#define BIOS_BEGIN 0x000a0000 +#define BIOS_END 0x00100000 + +#ifdef __KERNEL__ +/* see comment in arch/x86/kernel/e820.c */ +extern struct e820map e820; +extern struct e820map e820_saved; + +extern unsigned long pci_mem_start; +extern int e820_any_mapped(u64 start, u64 end, unsigned type); +extern int e820_all_mapped(u64 start, u64 end, unsigned type); +extern void e820_add_region(u64 start, u64 size, int type); +extern void e820_print_map(char *who); +extern int +sanitize_e820_map(struct e820entry *biosmap, int max_nr_map, u32 *pnr_map); +extern u64 e820_update_range(u64 start, u64 size, unsigned old_type, + unsigned new_type); +extern u64 e820_remove_range(u64 start, u64 size, unsigned old_type, + int checktype); +extern void update_e820(void); +extern void e820_setup_gap(void); +extern int e820_search_gap(unsigned long *gapstart, unsigned long *gapsize, + unsigned long start_addr, unsigned long long end_addr); +struct setup_data; +extern void parse_e820_ext(struct setup_data *data, unsigned long pa_data); + +#if defined(CONFIG_X86_64) || \ + (defined(CONFIG_X86_32) && defined(CONFIG_HIBERNATION)) +extern void e820_mark_nosave_regions(unsigned long limit_pfn); +#else +static inline void e820_mark_nosave_regions(unsigned long limit_pfn) +{ +} +#endif + +#ifdef CONFIG_MEMTEST +extern void early_memtest(unsigned long start, unsigned long end); +#else +static inline void early_memtest(unsigned long start, unsigned long end) +{ +} +#endif + +extern unsigned long end_user_pfn; + +extern u64 find_e820_area(u64 start, u64 end, u64 size, u64 align); +extern u64 find_e820_area_size(u64 start, u64 *sizep, u64 align); +extern void reserve_early(u64 start, u64 end, char *name); +extern void reserve_early_overlap_ok(u64 start, u64 end, char *name); +extern void free_early(u64 start, u64 end); +extern void early_res_to_bootmem(u64 start, u64 end); +extern u64 early_reserve_e820(u64 startt, u64 sizet, u64 align); + +extern unsigned long e820_end_of_ram_pfn(void); +extern unsigned long e820_end_of_low_ram_pfn(void); +extern int e820_find_active_region(const struct e820entry *ei, + unsigned long start_pfn, + unsigned long last_pfn, + unsigned long *ei_startpfn, + unsigned long *ei_endpfn); +extern void e820_register_active_regions(int nid, unsigned long start_pfn, + unsigned long end_pfn); +extern u64 e820_hole_size(u64 start, u64 end); +extern void finish_e820_parsing(void); +extern void e820_reserve_resources(void); +extern void e820_reserve_resources_late(void); +extern void setup_memory_map(void); +extern char *default_machine_specific_memory_setup(void); + +/* + * Returns true iff the specified range [s,e) is completely contained inside + * the ISA region. + */ +/* +static inline bool is_ISA_range(u64 s, u64 e) +{ + return s >= ISA_START_ADDRESS && e <= ISA_END_ADDRESS; +} +*/ +#endif /* __KERNEL__ */ +#endif /* __ASSEMBLY__ */ + +#ifdef __KERNEL__ +/* #include <linux/ioport.h> */ + +#define HIGH_MEMORY (1024*1024) +#endif /* __KERNEL__ */ + +#endif /* _ASM_X86_E820_H */ diff --git a/include/asm-i386/ioctl.h b/include/asm-i386/ioctl.h new file mode 100644 index 0000000..b279fe0 --- /dev/null +++ b/include/asm-i386/ioctl.h @@ -0,0 +1 @@ +#include <asm-generic/ioctl.h> diff --git a/include/asm-i386/ist.h b/include/asm-i386/ist.h new file mode 100644 index 0000000..7e5dff1 --- /dev/null +++ b/include/asm-i386/ist.h @@ -0,0 +1,34 @@ +#ifndef _ASM_X86_IST_H +#define _ASM_X86_IST_H + +/* + * Include file for the interface to IST BIOS + * Copyright 2002 Andy Grover andrew.grover@intel.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2, or (at your option) any + * later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + */ + + +#include <linux/types.h> + +struct ist_info { + __u32 signature; + __u32 command; + __u32 event; + __u32 perf_level; +}; + +#ifdef __KERNEL__ + +extern struct ist_info ist_info; + +#endif /* __KERNEL__ */ +#endif /* _ASM_X86_IST_H */ diff --git a/include/linux/apm_bios.h b/include/linux/apm_bios.h new file mode 100644 index 0000000..01a6244 --- /dev/null +++ b/include/linux/apm_bios.h @@ -0,0 +1,220 @@ +#ifndef _LINUX_APM_H +#define _LINUX_APM_H + +/* + * Include file for the interface to an APM BIOS + * Copyright 1994-2001 Stephen Rothwell (sfr@canb.auug.org.au) + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation; either version 2, or (at your option) any + * later version. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU + * General Public License for more details. + */ + +#include <linux/types.h> + +typedef unsigned short apm_event_t; +typedef unsigned short apm_eventinfo_t; + +struct apm_bios_info { + __u16 version; + __u16 cseg; + __u32 offset; + __u16 cseg_16; + __u16 dseg; + __u16 flags; + __u16 cseg_len; + __u16 cseg_16_len; + __u16 dseg_len; +}; + +#ifdef __KERNEL__ + +#define APM_CS (GDT_ENTRY_APMBIOS_BASE * 8) +#define APM_CS_16 (APM_CS + 8) +#define APM_DS (APM_CS_16 + 8) + +/* Results of APM Installation Check */ +#define APM_16_BIT_SUPPORT 0x0001 +#define APM_32_BIT_SUPPORT 0x0002 +#define APM_IDLE_SLOWS_CLOCK 0x0004 +#define APM_BIOS_DISABLED 0x0008 +#define APM_BIOS_DISENGAGED 0x0010 + +/* + * Data for APM that is persistent across module unload/load + */ +struct apm_info { + struct apm_bios_info bios; + unsigned short connection_version; + int get_power_status_broken; + int get_power_status_swabinminutes; + int allow_ints; + int forbid_idle; + int realmode_power_off; + int disabled; +}; + +/* + * The APM function codes + */ +#define APM_FUNC_INST_CHECK 0x5300 +#define APM_FUNC_REAL_CONN 0x5301 +#define APM_FUNC_16BIT_CONN 0x5302 +#define APM_FUNC_32BIT_CONN 0x5303 +#define APM_FUNC_DISCONN 0x5304 +#define APM_FUNC_IDLE 0x5305 +#define APM_FUNC_BUSY 0x5306 +#define APM_FUNC_SET_STATE 0x5307 +#define APM_FUNC_ENABLE_PM 0x5308 +#define APM_FUNC_RESTORE_BIOS 0x5309 +#define APM_FUNC_GET_STATUS 0x530a +#define APM_FUNC_GET_EVENT 0x530b +#define APM_FUNC_GET_STATE 0x530c +#define APM_FUNC_ENABLE_DEV_PM 0x530d +#define APM_FUNC_VERSION 0x530e +#define APM_FUNC_ENGAGE_PM 0x530f +#define APM_FUNC_GET_CAP 0x5310 +#define APM_FUNC_RESUME_TIMER 0x5311 +#define APM_FUNC_RESUME_ON_RING 0x5312 +#define APM_FUNC_TIMER 0x5313 + +/* + * Function code for APM_FUNC_RESUME_TIMER + */ +#define APM_FUNC_DISABLE_TIMER 0 +#define APM_FUNC_GET_TIMER 1 +#define APM_FUNC_SET_TIMER 2 + +/* + * Function code for APM_FUNC_RESUME_ON_RING + */ +#define APM_FUNC_DISABLE_RING 0 +#define APM_FUNC_ENABLE_RING 1 +#define APM_FUNC_GET_RING 2 + +/* + * Function code for APM_FUNC_TIMER_STATUS + */ +#define APM_FUNC_TIMER_DISABLE 0 +#define APM_FUNC_TIMER_ENABLE 1 +#define APM_FUNC_TIMER_GET 2 + +/* + * in arch/i386/kernel/setup.c + */ +extern struct apm_info apm_info; + +#endif /* __KERNEL__ */ + +/* + * Power states + */ +#define APM_STATE_READY 0x0000 +#define APM_STATE_STANDBY 0x0001 +#define APM_STATE_SUSPEND 0x0002 +#define APM_STATE_OFF 0x0003 +#define APM_STATE_BUSY 0x0004 +#define APM_STATE_REJECT 0x0005 +#define APM_STATE_OEM_SYS 0x0020 +#define APM_STATE_OEM_DEV 0x0040 + +#define APM_STATE_DISABLE 0x0000 +#define APM_STATE_ENABLE 0x0001 + +#define APM_STATE_DISENGAGE 0x0000 +#define APM_STATE_ENGAGE 0x0001 + +/* + * Events (results of Get PM Event) + */ +#define APM_SYS_STANDBY 0x0001 +#define APM_SYS_SUSPEND 0x0002 +#define APM_NORMAL_RESUME 0x0003 +#define APM_CRITICAL_RESUME 0x0004 +#define APM_LOW_BATTERY 0x0005 +#define APM_POWER_STATUS_CHANGE 0x0006 +#define APM_UPDATE_TIME 0x0007 +#define APM_CRITICAL_SUSPEND 0x0008 +#define APM_USER_STANDBY 0x0009 +#define APM_USER_SUSPEND 0x000a +#define APM_STANDBY_RESUME 0x000b +#define APM_CAPABILITY_CHANGE 0x000c + +/* + * Error codes + */ +#define APM_SUCCESS 0x00 +#define APM_DISABLED 0x01 +#define APM_CONNECTED 0x02 +#define APM_NOT_CONNECTED 0x03 +#define APM_16_CONNECTED 0x05 +#define APM_16_UNSUPPORTED 0x06 +#define APM_32_CONNECTED 0x07 +#define APM_32_UNSUPPORTED 0x08 +#define APM_BAD_DEVICE 0x09 +#define APM_BAD_PARAM 0x0a +#define APM_NOT_ENGAGED 0x0b +#define APM_BAD_FUNCTION 0x0c +#define APM_RESUME_DISABLED 0x0d +#define APM_NO_ERROR 0x53 +#define APM_BAD_STATE 0x60 +#define APM_NO_EVENTS 0x80 +#define APM_NOT_PRESENT 0x86 + +/* + * APM Device IDs + */ +#define APM_DEVICE_BIOS 0x0000 +#define APM_DEVICE_ALL 0x0001 +#define APM_DEVICE_DISPLAY 0x0100 +#define APM_DEVICE_STORAGE 0x0200 +#define APM_DEVICE_PARALLEL 0x0300 +#define APM_DEVICE_SERIAL 0x0400 +#define APM_DEVICE_NETWORK 0x0500 +#define APM_DEVICE_PCMCIA 0x0600 +#define APM_DEVICE_BATTERY 0x8000 +#define APM_DEVICE_OEM 0xe000 +#define APM_DEVICE_OLD_ALL 0xffff +#define APM_DEVICE_CLASS 0x00ff +#define APM_DEVICE_MASK 0xff00 + +#ifdef __KERNEL__ +/* + * This is the "All Devices" ID communicated to the BIOS + */ +#define APM_DEVICE_BALL ((apm_info.connection_version > 0x0100) ? \ + APM_DEVICE_ALL : APM_DEVICE_OLD_ALL) +#endif + +/* + * Battery status + */ +#define APM_MAX_BATTERIES 2 + +/* + * APM defined capability bit flags + */ +#define APM_CAP_GLOBAL_STANDBY 0x0001 +#define APM_CAP_GLOBAL_SUSPEND 0x0002 +#define APM_CAP_RESUME_STANDBY_TIMER 0x0004 /* Timer resume from standby */ +#define APM_CAP_RESUME_SUSPEND_TIMER 0x0008 /* Timer resume from suspend */ +#define APM_CAP_RESUME_STANDBY_RING 0x0010 /* Resume on Ring fr standby */ +#define APM_CAP_RESUME_SUSPEND_RING 0x0020 /* Resume on Ring fr suspend */ +#define APM_CAP_RESUME_STANDBY_PCMCIA 0x0040 /* Resume on PCMCIA Ring */ +#define APM_CAP_RESUME_SUSPEND_PCMCIA 0x0080 /* Resume on PCMCIA Ring */ + +/* + * ioctl operations + */ +#include <linux/ioctl.h> + +#define APM_IOC_STANDBY _IO('A', 1) +#define APM_IOC_SUSPEND _IO('A', 2) + +#endif /* LINUX_APM_H */ diff --git a/include/linux/compiler-gcc.h b/include/linux/compiler-gcc.h new file mode 100644 index 0000000..73dcf80 --- /dev/null +++ b/include/linux/compiler-gcc.h @@ -0,0 +1,87 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-gcc.h> directly, include <linux/compiler.h> instead." +#endif + +/* + * Common definitions for all gcc versions go here. + */ + + +/* Optimization barrier */ +/* The "volatile" is due to gcc bugs */ +#define barrier() __asm__ __volatile__("": : :"memory") + +/* + * This macro obfuscates arithmetic on a variable address so that gcc + * shouldn't recognize the original var, and make assumptions about it. + * + * This is needed because the C standard makes it undefined to do + * pointer arithmetic on "objects" outside their boundaries and the + * gcc optimizers assume this is the case. In particular they + * assume such arithmetic does not wrap. + * + * A miscompilation has been observed because of this on PPC. + * To work around it we hide the relationship of the pointer and the object + * using this macro. + * + * Versions of the ppc64 compiler before 4.1 had a bug where use of + * RELOC_HIDE could trash r30. The bug can be worked around by changing + * the inline assembly constraint from =g to =r, in this particular + * case either is valid. + */ +#define RELOC_HIDE(ptr, off) \ + ({ unsigned long __ptr; \ + __asm__ ("" : "=r"(__ptr) : "0"(ptr)); \ + (typeof(ptr)) (__ptr + (off)); }) + +/* &a[0] degrades to a pointer: a different type from an array */ +#define __must_be_array(a) \ + BUILD_BUG_ON_ZERO(__builtin_types_compatible_p(typeof(a), typeof(&a[0]))) + +/* + * Force always-inline if the user requests it so via the .config, + * or if gcc is too old: + */ +#if !defined(CONFIG_ARCH_SUPPORTS_OPTIMIZED_INLINING) || \ + !defined(CONFIG_OPTIMIZE_INLINING) || (__GNUC__ < 4) +# define inline inline __attribute__((always_inline)) +# define __inline__ __inline__ __attribute__((always_inline)) +# define __inline __inline __attribute__((always_inline)) +#endif + +#define __deprecated __attribute__((deprecated)) +#define __packed __attribute__((packed)) +#define __weak __attribute__((weak)) + +/* + * it doesn't make sense on ARM (currently the only user of __naked) to trace + * naked functions because then mcount is called without stack and frame pointer + * being set up and there is no chance to restore the lr register to the value + * before mcount was called. + */ +#define __naked __attribute__((naked)) notrace + +#define __noreturn __attribute__((noreturn)) + +/* + * From the GCC manual: + * + * Many functions have no effects except the return value and their + * return value depends only on the parameters and/or global + * variables. Such a function can be subject to common subexpression + * elimination and loop optimization just as an arithmetic operator + * would be. + * [...] + */ +#define __pure __attribute__((pure)) +#define __aligned(x) __attribute__((aligned(x))) +#define __printf(a,b) __attribute__((format(printf,a,b))) +#define noinline __attribute__((noinline)) +#define __attribute_const__ __attribute__((__const__)) +#define __maybe_unused __attribute__((unused)) +#define __always_unused __attribute__((unused)) + +#define __gcc_header(x) #x +#define _gcc_header(x) __gcc_header(linux/compiler-gcc##x.h) +#define gcc_header(x) _gcc_header(x) +#include gcc_header(__GNUC__) diff --git a/include/linux/compiler-gcc4.h b/include/linux/compiler-gcc4.h new file mode 100644 index 0000000..94dea3f --- /dev/null +++ b/include/linux/compiler-gcc4.h @@ -0,0 +1,61 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-gcc4.h> directly, include <linux/compiler.h> instead." +#endif + +/* GCC 4.1.[01] miscompiles __weak */ +#ifdef __KERNEL__ +# if __GNUC_MINOR__ == 1 && __GNUC_PATCHLEVEL__ <= 1 +# error Your version of gcc miscompiles the __weak directive +# endif +#endif + +#define __used __attribute__((__used__)) +#define __must_check __attribute__((warn_unused_result)) +#define __compiler_offsetof(a,b) __builtin_offsetof(a,b) +#define __always_inline inline __attribute__((always_inline)) + +/* + * A trick to suppress uninitialized variable warning without generating any + * code + */ +#define uninitialized_var(x) x = x + +#if __GNUC_MINOR__ >= 3 +/* Mark functions as cold. gcc will assume any path leading to a call + to them will be unlikely. This means a lot of manual unlikely()s + are unnecessary now for any paths leading to the usual suspects + like BUG(), printk(), panic() etc. [but let's keep them for now for + older compilers] + + Early snapshots of gcc 4.3 don't support this and we can't detect this + in the preprocessor, but we can live with this because they're unreleased. + Maketime probing would be overkill here. + + gcc also has a __attribute__((__hot__)) to move hot functions into + a special section, but I don't see any sense in this right now in + the kernel context */ +#define __cold __attribute__((__cold__)) + + +#if __GNUC_MINOR__ >= 5 +/* + * Mark a position in code as unreachable. This can be used to + * suppress control flow warnings after asm blocks that transfer + * control elsewhere. + * + * Early snapshots of gcc 4.5 don't support this and we can't detect + * this in the preprocessor, but we can live with this because they're + * unreleased. Really, we need to have autoconf for the kernel. + */ +#define unreachable() __builtin_unreachable() +#endif + +#endif + +#if __GNUC_MINOR__ > 0 +#define __compiletime_object_size(obj) __builtin_object_size(obj, 0) +#endif +#if __GNUC_MINOR__ >= 4 +#define __compiletime_warning(message) __attribute__((warning(message))) +#define __compiletime_error(message) __attribute__((error(message))) +#endif diff --git a/include/linux/compiler.h b/include/linux/compiler.h new file mode 100644 index 0000000..5be3dab --- /dev/null +++ b/include/linux/compiler.h @@ -0,0 +1,303 @@ +#ifndef __LINUX_COMPILER_H +#define __LINUX_COMPILER_H + +#ifndef __ASSEMBLY__ + +#ifdef __CHECKER__ +# define __user __attribute__((noderef, address_space(1))) +# define __kernel /* default address space */ +# define __safe __attribute__((safe)) +# define __force __attribute__((force)) +# define __nocast __attribute__((nocast)) +# define __iomem __attribute__((noderef, address_space(2))) +# define __acquires(x) __attribute__((context(x,0,1))) +# define __releases(x) __attribute__((context(x,1,0))) +# define __acquire(x) __context__(x,1) +# define __release(x) __context__(x,-1) +# define __cond_lock(x,c) ((c) ? ({ __acquire(x); 1; }) : 0) +extern void __chk_user_ptr(const volatile void __user *); +extern void __chk_io_ptr(const volatile void __iomem *); +#else +# define __user +# define __kernel +# define __safe +# define __force +# define __nocast +# define __iomem +# define __chk_user_ptr(x) (void)0 +# define __chk_io_ptr(x) (void)0 +# define __builtin_warning(x, y...) (1) +# define __acquires(x) +# define __releases(x) +# define __acquire(x) (void)0 +# define __release(x) (void)0 +# define __cond_lock(x,c) (c) +#endif + +#ifdef __KERNEL__ + +#ifdef __GNUC__ +#include <linux/compiler-gcc.h> +#endif + +#define notrace __attribute__((no_instrument_function)) + +/* Intel compiler defines __GNUC__. So we will overwrite implementations + * coming from above header files here + */ +#ifdef __INTEL_COMPILER +# include <linux/compiler-intel.h> +#endif + +/* + * Generic compiler-dependent macros required for kernel + * build go below this comment. Actual compiler/compiler version + * specific implementations come from the above header files + */ + +struct ftrace_branch_data { + const char *func; + const char *file; + unsigned line; + union { + struct { + unsigned long correct; + unsigned long incorrect; + }; + struct { + unsigned long miss; + unsigned long hit; + }; + unsigned long miss_hit[2]; + }; +}; + +/* + * Note: DISABLE_BRANCH_PROFILING can be used by special lowlevel code + * to disable branch tracing on a per file basis. + */ +#if defined(CONFIG_TRACE_BRANCH_PROFILING) \ + && !defined(DISABLE_BRANCH_PROFILING) && !defined(__CHECKER__) +void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect); + +#define likely_notrace(x) __builtin_expect(!!(x), 1) +#define unlikely_notrace(x) __builtin_expect(!!(x), 0) + +#define __branch_check__(x, expect) ({ \ + int ______r; \ + static struct ftrace_branch_data \ + __attribute__((__aligned__(4))) \ + __attribute__((section("_ftrace_annotated_branch"))) \ + ______f = { \ + .func = __func__, \ + .file = __FILE__, \ + .line = __LINE__, \ + }; \ + ______r = likely_notrace(x); \ + ftrace_likely_update(&______f, ______r, expect); \ + ______r; \ + }) + +/* + * Using __builtin_constant_p(x) to ignore cases where the return + * value is always the same. This idea is taken from a similar patch + * written by Daniel Walker. + */ +# ifndef likely +# define likely(x) (__builtin_constant_p(x) ? !!(x) : __branch_check__(x, 1)) +# endif +# ifndef unlikely +# define unlikely(x) (__builtin_constant_p(x) ? !!(x) : __branch_check__(x, 0)) +# endif + +#ifdef CONFIG_PROFILE_ALL_BRANCHES +/* + * "Define 'is'", Bill Clinton + * "Define 'if'", Steven Rostedt + */ +#define if(cond, ...) __trace_if( (cond , ## __VA_ARGS__) ) +#define __trace_if(cond) \ + if (__builtin_constant_p((cond)) ? !!(cond) : \ + ({ \ + int ______r; \ + static struct ftrace_branch_data \ + __attribute__((__aligned__(4))) \ + __attribute__((section("_ftrace_branch"))) \ + ______f = { \ + .func = __func__, \ + .file = __FILE__, \ + .line = __LINE__, \ + }; \ + ______r = !!(cond); \ + ______f.miss_hit[______r]++; \ + ______r; \ + })) +#endif /* CONFIG_PROFILE_ALL_BRANCHES */ + +#else +# define likely(x) __builtin_expect(!!(x), 1) +# define unlikely(x) __builtin_expect(!!(x), 0) +#endif + +/* Optimization barrier */ +#ifndef barrier +# define barrier() __memory_barrier() +#endif + +/* Unreachable code */ +#ifndef unreachable +# define unreachable() do { } while (1) +#endif + +#ifndef RELOC_HIDE +# define RELOC_HIDE(ptr, off) \ + ({ unsigned long __ptr; \ + __ptr = (unsigned long) (ptr); \ + (typeof(ptr)) (__ptr + (off)); }) +#endif + +#endif /* __KERNEL__ */ + +#endif /* __ASSEMBLY__ */ + +#ifdef __KERNEL__ +/* + * Allow us to mark functions as 'deprecated' and have gcc emit a nice + * warning for each use, in hopes of speeding the functions removal. + * Usage is: + * int __deprecated foo(void) + */ +#ifndef __deprecated +# define __deprecated /* unimplemented */ +#endif + +#ifdef MODULE +#define __deprecated_for_modules __deprecated +#else +#define __deprecated_for_modules +#endif + +#ifndef __must_check +#define __must_check +#endif + +#ifndef CONFIG_ENABLE_MUST_CHECK +#undef __must_check +#define __must_check +#endif +#ifndef CONFIG_ENABLE_WARN_DEPRECATED +#undef __deprecated +#undef __deprecated_for_modules +#define __deprecated +#define __deprecated_for_modules +#endif + +/* + * Allow us to avoid 'defined but not used' warnings on functions and data, + * as well as force them to be emitted to the assembly file. + * + * As of gcc 3.4, static functions that are not marked with attribute((used)) + * may be elided from the assembly file. As of gcc 3.4, static data not so + * marked will not be elided, but this may change in a future gcc version. + * + * NOTE: Because distributions shipped with a backported unit-at-a-time + * compiler in gcc 3.3, we must define __used to be __attribute__((used)) + * for gcc >=3.3 instead of 3.4. + * + * In prior versions of gcc, such functions and data would be emitted, but + * would be warned about except with attribute((unused)). + * + * Mark functions that are referenced only in inline assembly as __used so + * the code is emitted even though it appears to be unreferenced. + */ +#ifndef __used +# define __used /* unimplemented */ +#endif + +#ifndef __maybe_unused +# define __maybe_unused /* unimplemented */ +#endif + +#ifndef __always_unused +# define __always_unused /* unimplemented */ +#endif + +#ifndef noinline +#define noinline +#endif + +/* + * Rather then using noinline to prevent stack consumption, use + * noinline_for_stack instead. For documentaiton reasons. + */ +#define noinline_for_stack noinline + +#ifndef __always_inline +#define __always_inline inline +#endif + +#endif /* __KERNEL__ */ + +/* + * From the GCC manual: + * + * Many functions do not examine any values except their arguments, + * and have no effects except the return value. Basically this is + * just slightly more strict class than the `pure' attribute above, + * since function is not allowed to read global memory. + * + * Note that a function that has pointer arguments and examines the + * data pointed to must _not_ be declared `const'. Likewise, a + * function that calls a non-`const' function usually must not be + * `const'. It does not make sense for a `const' function to return + * `void'. + */ +#ifndef __attribute_const__ +# define __attribute_const__ /* unimplemented */ +#endif + +/* + * Tell gcc if a function is cold. The compiler will assume any path + * directly leading to the call is unlikely. + */ + +#ifndef __cold +#define __cold +#endif + +/* Simple shorthand for a section definition */ +#ifndef __section +# define __section(S) __attribute__ ((__section__(#S))) +#endif + +/* Are two types/vars the same type (ignoring qualifiers)? */ +#ifndef __same_type +# define __same_type(a, b) __builtin_types_compatible_p(typeof(a), typeof(b)) +#endif + +/* Compile time object size, -1 for unknown */ +#ifndef __compiletime_object_size +# define __compiletime_object_size(obj) -1 +#endif +#ifndef __compiletime_warning +# define __compiletime_warning(message) +#endif +#ifndef __compiletime_error +# define __compiletime_error(message) +#endif + +/* + * Prevent the compiler from merging or refetching accesses. The compiler + * is also forbidden from reordering successive instances of ACCESS_ONCE(), + * but only when the compiler is aware of some particular ordering. One way + * to make the compiler aware of ordering is to put the two invocations of + * ACCESS_ONCE() in different C statements. + * + * This macro does absolutely -nothing- to prevent the CPU from reordering, + * merging, or refetching absolutely anything at any time. Its main intended + * use is to mediate communication between process-level code and irq/NMI + * handlers, all running on the same CPU. + */ +#define ACCESS_ONCE(x) (*(volatile typeof(x) *)&(x)) + +#endif /* __LINUX_COMPILER_H */ diff --git a/include/linux/edd.h b/include/linux/edd.h new file mode 100644 index 0000000..4cbd0fe --- /dev/null +++ b/include/linux/edd.h @@ -0,0 +1,194 @@ +/* + * linux/include/linux/edd.h + * Copyright (C) 2002, 2003, 2004 Dell Inc. + * by Matt Domsch Matt_Domsch@dell.com + * + * structures and definitions for the int 13h, ax={41,48}h + * BIOS Enhanced Disk Drive Services + * This is based on the T13 group document D1572 Revision 0 (August 14 2002) + * available at http://www.t13.org/docs2002/d1572r0.pdf. It is + * very similar to D1484 Revision 3 http://www.t13.org/docs2002/d1484r3.pdf + * + * In a nutshell, arch/{i386,x86_64}/boot/setup.S populates a scratch + * table in the boot_params that contains a list of BIOS-enumerated + * boot devices. + * In arch/{i386,x86_64}/kernel/setup.c, this information is + * transferred into the edd structure, and in drivers/firmware/edd.c, that + * information is used to identify BIOS boot disk. The code in setup.S + * is very sensitive to the size of these structures. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License v2.0 as published by + * the Free Software Foundation + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + */ +#ifndef _LINUX_EDD_H +#define _LINUX_EDD_H + +#include <linux/types.h> + +#define EDDNR 0x1e9 /* addr of number of edd_info structs at EDDBUF + in boot_params - treat this as 1 byte */ +#define EDDBUF 0xd00 /* addr of edd_info structs in boot_params */ +#define EDDMAXNR 6 /* number of edd_info structs starting at EDDBUF */ +#define EDDEXTSIZE 8 /* change these if you muck with the structures */ +#define EDDPARMSIZE 74 +#define CHECKEXTENSIONSPRESENT 0x41 +#define GETDEVICEPARAMETERS 0x48 +#define LEGACYGETDEVICEPARAMETERS 0x08 +#define EDDMAGIC1 0x55AA +#define EDDMAGIC2 0xAA55 + + +#define READ_SECTORS 0x02 /* int13 AH=0x02 is READ_SECTORS command */ +#define EDD_MBR_SIG_OFFSET 0x1B8 /* offset of signature in the MBR */ +#define EDD_MBR_SIG_BUF 0x290 /* addr in boot params */ +#define EDD_MBR_SIG_MAX 16 /* max number of signatures to store */ +#define EDD_MBR_SIG_NR_BUF 0x1ea /* addr of number of MBR signtaures at EDD_MBR_SIG_BUF + in boot_params - treat this as 1 byte */ + +#ifndef __ASSEMBLY__ + +#define EDD_EXT_FIXED_DISK_ACCESS (1 << 0) +#define EDD_EXT_DEVICE_LOCKING_AND_EJECTING (1 << 1) +#define EDD_EXT_ENHANCED_DISK_DRIVE_SUPPORT (1 << 2) +#define EDD_EXT_64BIT_EXTENSIONS (1 << 3) + +#define EDD_INFO_DMA_BOUNDARY_ERROR_TRANSPARENT (1 << 0) +#define EDD_INFO_GEOMETRY_VALID (1 << 1) +#define EDD_INFO_REMOVABLE (1 << 2) +#define EDD_INFO_WRITE_VERIFY (1 << 3) +#define EDD_INFO_MEDIA_CHANGE_NOTIFICATION (1 << 4) +#define EDD_INFO_LOCKABLE (1 << 5) +#define EDD_INFO_NO_MEDIA_PRESENT (1 << 6) +#define EDD_INFO_USE_INT13_FN50 (1 << 7) + +struct edd_device_params { + __u16 length; + __u16 info_flags; + __u32 num_default_cylinders; + __u32 num_default_heads; + __u32 sectors_per_track; + __u64 number_of_sectors; + __u16 bytes_per_sector; + __u32 dpte_ptr; /* 0xFFFFFFFF for our purposes */ + __u16 key; /* = 0xBEDD */ + __u8 device_path_info_length; /* = 44 */ + __u8 reserved2; + __u16 reserved3; + __u8 host_bus_type[4]; + __u8 interface_type[8]; + union { + struct { + __u16 base_address; + __u16 reserved1; + __u32 reserved2; + } __attribute__ ((packed)) isa; + struct { + __u8 bus; + __u8 slot; + __u8 function; + __u8 channel; + __u32 reserved; + } __attribute__ ((packed)) pci; + /* pcix is same as pci */ + struct { + __u64 reserved; + } __attribute__ ((packed)) ibnd; + struct { + __u64 reserved; + } __attribute__ ((packed)) xprs; + struct { + __u64 reserved; + } __attribute__ ((packed)) htpt; + struct { + __u64 reserved; + } __attribute__ ((packed)) unknown; + } interface_path; + union { + struct { + __u8 device; + __u8 reserved1; + __u16 reserved2; + __u32 reserved3; + __u64 reserved4; + } __attribute__ ((packed)) ata; + struct { + __u8 device; + __u8 lun; + __u8 reserved1; + __u8 reserved2; + __u32 reserved3; + __u64 reserved4; + } __attribute__ ((packed)) atapi; + struct { + __u16 id; + __u64 lun; + __u16 reserved1; + __u32 reserved2; + } __attribute__ ((packed)) scsi; + struct { + __u64 serial_number; + __u64 reserved; + } __attribute__ ((packed)) usb; + struct { + __u64 eui; + __u64 reserved; + } __attribute__ ((packed)) i1394; + struct { + __u64 wwid; + __u64 lun; + } __attribute__ ((packed)) fibre; + struct { + __u64 identity_tag; + __u64 reserved; + } __attribute__ ((packed)) i2o; + struct { + __u32 array_number; + __u32 reserved1; + __u64 reserved2; + } __attribute__ ((packed)) raid; + struct { + __u8 device; + __u8 reserved1; + __u16 reserved2; + __u32 reserved3; + __u64 reserved4; + } __attribute__ ((packed)) sata; + struct { + __u64 reserved1; + __u64 reserved2; + } __attribute__ ((packed)) unknown; + } device_path; + __u8 reserved4; + __u8 checksum; +} __attribute__ ((packed)); + +struct edd_info { + __u8 device; + __u8 version; + __u16 interface_support; + __u16 legacy_max_cylinder; + __u8 legacy_max_head; + __u8 legacy_sectors_per_track; + struct edd_device_params params; +} __attribute__ ((packed)); + +struct edd { + unsigned int mbr_signature[EDD_MBR_SIG_MAX]; + struct edd_info edd_info[EDDMAXNR]; + unsigned char mbr_signature_nr; + unsigned char edd_info_nr; +}; + +#ifdef __KERNEL__ +extern struct edd edd; +#endif /* __KERNEL__ */ +#endif /*!__ASSEMBLY__ */ + +#endif /* _LINUX_EDD_H */ diff --git a/include/linux/ioctl.h b/include/linux/ioctl.h new file mode 100644 index 0000000..aa91eb3 --- /dev/null +++ b/include/linux/ioctl.h @@ -0,0 +1,7 @@ +#ifndef _LINUX_IOCTL_H +#define _LINUX_IOCTL_H + +#include <asm/ioctl.h> + +#endif /* _LINUX_IOCTL_H */ + diff --git a/include/linux/ioport.h b/include/linux/ioport.h new file mode 100644 index 0000000..7129504 --- /dev/null +++ b/include/linux/ioport.h @@ -0,0 +1,192 @@ +/* + * ioport.h Definitions of routines for detecting, reserving and + * allocating system resources. + * + * Authors: Linus Torvalds + */ + +#ifndef _LINUX_IOPORT_H +#define _LINUX_IOPORT_H + +#ifndef __ASSEMBLY__ +#include <linux/compiler.h> +#include <linux/types.h> +/* + * Resources are tree-like, allowing + * nesting etc.. + */ +struct resource { + resource_size_t start; + resource_size_t end; + const char *name; + unsigned long flags; + struct resource *parent, *sibling, *child; +}; + +struct resource_list { + struct resource_list *next; + struct resource *res; + struct pci_dev *dev; +}; + +/* + * IO resources have these defined flags. + */ +#define IORESOURCE_BITS 0x000000ff /* Bus-specific bits */ + +#define IORESOURCE_TYPE_BITS 0x00000f00 /* Resource type */ +#define IORESOURCE_IO 0x00000100 +#define IORESOURCE_MEM 0x00000200 +#define IORESOURCE_IRQ 0x00000400 +#define IORESOURCE_DMA 0x00000800 + +#define IORESOURCE_PREFETCH 0x00001000 /* No side effects */ +#define IORESOURCE_READONLY 0x00002000 +#define IORESOURCE_CACHEABLE 0x00004000 +#define IORESOURCE_RANGELENGTH 0x00008000 +#define IORESOURCE_SHADOWABLE 0x00010000 + +#define IORESOURCE_SIZEALIGN 0x00020000 /* size indicates alignment */ +#define IORESOURCE_STARTALIGN 0x00040000 /* start field is alignment */ + +#define IORESOURCE_MEM_64 0x00100000 + +#define IORESOURCE_EXCLUSIVE 0x08000000 /* Userland may not map this resource */ +#define IORESOURCE_DISABLED 0x10000000 +#define IORESOURCE_UNSET 0x20000000 +#define IORESOURCE_AUTO 0x40000000 +#define IORESOURCE_BUSY 0x80000000 /* Driver has marked this resource busy */ + +/* PnP IRQ specific bits (IORESOURCE_BITS) */ +#define IORESOURCE_IRQ_HIGHEDGE (1<<0) +#define IORESOURCE_IRQ_LOWEDGE (1<<1) +#define IORESOURCE_IRQ_HIGHLEVEL (1<<2) +#define IORESOURCE_IRQ_LOWLEVEL (1<<3) +#define IORESOURCE_IRQ_SHAREABLE (1<<4) +#define IORESOURCE_IRQ_OPTIONAL (1<<5) + +/* PnP DMA specific bits (IORESOURCE_BITS) */ +#define IORESOURCE_DMA_TYPE_MASK (3<<0) +#define IORESOURCE_DMA_8BIT (0<<0) +#define IORESOURCE_DMA_8AND16BIT (1<<0) +#define IORESOURCE_DMA_16BIT (2<<0) + +#define IORESOURCE_DMA_MASTER (1<<2) +#define IORESOURCE_DMA_BYTE (1<<3) +#define IORESOURCE_DMA_WORD (1<<4) + +#define IORESOURCE_DMA_SPEED_MASK (3<<6) +#define IORESOURCE_DMA_COMPATIBLE (0<<6) +#define IORESOURCE_DMA_TYPEA (1<<6) +#define IORESOURCE_DMA_TYPEB (2<<6) +#define IORESOURCE_DMA_TYPEF (3<<6) + +/* PnP memory I/O specific bits (IORESOURCE_BITS) */ +#define IORESOURCE_MEM_WRITEABLE (1<<0) /* dup: IORESOURCE_READONLY */ +#define IORESOURCE_MEM_CACHEABLE (1<<1) /* dup: IORESOURCE_CACHEABLE */ +#define IORESOURCE_MEM_RANGELENGTH (1<<2) /* dup: IORESOURCE_RANGELENGTH */ +#define IORESOURCE_MEM_TYPE_MASK (3<<3) +#define IORESOURCE_MEM_8BIT (0<<3) +#define IORESOURCE_MEM_16BIT (1<<3) +#define IORESOURCE_MEM_8AND16BIT (2<<3) +#define IORESOURCE_MEM_32BIT (3<<3) +#define IORESOURCE_MEM_SHADOWABLE (1<<5) /* dup: IORESOURCE_SHADOWABLE */ +#define IORESOURCE_MEM_EXPANSIONROM (1<<6) + +/* PnP I/O specific bits (IORESOURCE_BITS) */ +#define IORESOURCE_IO_16BIT_ADDR (1<<0) +#define IORESOURCE_IO_FIXED (1<<1) + +/* PCI ROM control bits (IORESOURCE_BITS) */ +#define IORESOURCE_ROM_ENABLE (1<<0) /* ROM is enabled, same as PCI_ROM_ADDRESS_ENABLE */ +#define IORESOURCE_ROM_SHADOW (1<<1) /* ROM is copy at C000:0 */ +#define IORESOURCE_ROM_COPY (1<<2) /* ROM is alloc'd copy, resource field overlaid */ +#define IORESOURCE_ROM_BIOS_COPY (1<<3) /* ROM is BIOS copy, resource field overlaid */ + +/* PCI control bits. Shares IORESOURCE_BITS with above PCI ROM. */ +#define IORESOURCE_PCI_FIXED (1<<4) /* Do not move resource */ + +/* PC/ISA/whatever - the normal PC address spaces: IO and memory */ +extern struct resource ioport_resource; +extern struct resource iomem_resource; + +extern int request_resource(struct resource *root, struct resource *new); +extern int release_resource(struct resource *new); +extern void reserve_region_with_split(struct resource *root, + resource_size_t start, resource_size_t end, + const char *name); +extern int insert_resource(struct resource *parent, struct resource *new); +extern void insert_resource_expand_to_fit(struct resource *root, struct resource *new); +extern int allocate_resource(struct resource *root, struct resource *new, + resource_size_t size, resource_size_t min, + resource_size_t max, resource_size_t align, + void (*alignf)(void *, struct resource *, + resource_size_t, resource_size_t), + void *alignf_data); +int adjust_resource(struct resource *res, resource_size_t start, + resource_size_t size); +resource_size_t resource_alignment(struct resource *res); +static inline resource_size_t resource_size(const struct resource *res) +{ + return res->end - res->start + 1; +} +static inline unsigned long resource_type(const struct resource *res) +{ + return res->flags & IORESOURCE_TYPE_BITS; +} + +/* Convenience shorthand with allocation */ +#define request_region(start,n,name) __request_region(&ioport_resource, (start), (n), (name), 0) +#define __request_mem_region(start,n,name, excl) __request_region(&iomem_resource, (start), (n), (name), excl) +#define request_mem_region(start,n,name) __request_region(&iomem_resource, (start), (n), (name), 0) +#define request_mem_region_exclusive(start,n,name) \ + __request_region(&iomem_resource, (start), (n), (name), IORESOURCE_EXCLUSIVE) +#define rename_region(region, newname) do { (region)->name = (newname); } while (0) + +extern struct resource * __request_region(struct resource *, + resource_size_t start, + resource_size_t n, + const char *name, int flags); + +/* Compatibility cruft */ +#define release_region(start,n) __release_region(&ioport_resource, (start), (n)) +#define check_mem_region(start,n) __check_region(&iomem_resource, (start), (n)) +#define release_mem_region(start,n) __release_region(&iomem_resource, (start), (n)) + +extern int __check_region(struct resource *, resource_size_t, resource_size_t); +extern void __release_region(struct resource *, resource_size_t, + resource_size_t); + +static inline int __deprecated check_region(resource_size_t s, + resource_size_t n) +{ + return __check_region(&ioport_resource, s, n); +} + +/* Wrappers for managed devices */ +struct device; +#define devm_request_region(dev,start,n,name) \ + __devm_request_region(dev, &ioport_resource, (start), (n), (name)) +#define devm_request_mem_region(dev,start,n,name) \ + __devm_request_region(dev, &iomem_resource, (start), (n), (name)) + +extern struct resource * __devm_request_region(struct device *dev, + struct resource *parent, resource_size_t start, + resource_size_t n, const char *name); + +#define devm_release_region(dev, start, n) \ + __devm_release_region(dev, &ioport_resource, (start), (n)) +#define devm_release_mem_region(dev, start, n) \ + __devm_release_region(dev, &iomem_resource, (start), (n)) + +extern void __devm_release_region(struct device *dev, struct resource *parent, + resource_size_t start, resource_size_t n); +extern int iomem_map_sanity_check(resource_size_t addr, unsigned long size); +extern int iomem_is_exclusive(u64 addr); + +extern int +walk_system_ram_range(unsigned long start_pfn, unsigned long nr_pages, + void *arg, int (*func)(unsigned long, unsigned long, void *)); + +#endif /* __ASSEMBLY__ */ +#endif /* _LINUX_IOPORT_H */ diff --git a/include/linux/screen_info.h b/include/linux/screen_info.h new file mode 100644 index 0000000..899fbb4 --- /dev/null +++ b/include/linux/screen_info.h @@ -0,0 +1,84 @@ +#ifndef _SCREEN_INFO_H +#define _SCREEN_INFO_H + +#include <linux/types.h> + +/* + * These are set up by the setup-routine at boot-time: + */ + +struct screen_info { + __u8 orig_x; /* 0x00 */ + __u8 orig_y; /* 0x01 */ + __u16 ext_mem_k; /* 0x02 */ + __u16 orig_video_page; /* 0x04 */ + __u8 orig_video_mode; /* 0x06 */ + __u8 orig_video_cols; /* 0x07 */ + __u8 flags; /* 0x08 */ + __u8 unused2; /* 0x09 */ + __u16 orig_video_ega_bx;/* 0x0a */ + __u16 unused3; /* 0x0c */ + __u8 orig_video_lines; /* 0x0e */ + __u8 orig_video_isVGA; /* 0x0f */ + __u16 orig_video_points;/* 0x10 */ + + /* VESA graphic mode -- linear frame buffer */ + __u16 lfb_width; /* 0x12 */ + __u16 lfb_height; /* 0x14 */ + __u16 lfb_depth; /* 0x16 */ + __u32 lfb_base; /* 0x18 */ + __u32 lfb_size; /* 0x1c */ + __u16 cl_magic, cl_offset; /* 0x20 */ + __u16 lfb_linelength; /* 0x24 */ + __u8 red_size; /* 0x26 */ + __u8 red_pos; /* 0x27 */ + __u8 green_size; /* 0x28 */ + __u8 green_pos; /* 0x29 */ + __u8 blue_size; /* 0x2a */ + __u8 blue_pos; /* 0x2b */ + __u8 rsvd_size; /* 0x2c */ + __u8 rsvd_pos; /* 0x2d */ + __u16 vesapm_seg; /* 0x2e */ + __u16 vesapm_off; /* 0x30 */ + __u16 pages; /* 0x32 */ + __u16 vesa_attributes; /* 0x34 */ + __u32 capabilities; /* 0x36 */ + __u8 _reserved[6]; /* 0x3a */ +} __attribute__((packed)); + +#define VIDEO_TYPE_MDA 0x10 /* Monochrome Text Display */ +#define VIDEO_TYPE_CGA 0x11 /* CGA Display */ +#define VIDEO_TYPE_EGAM 0x20 /* EGA/VGA in Monochrome Mode */ +#define VIDEO_TYPE_EGAC 0x21 /* EGA in Color Mode */ +#define VIDEO_TYPE_VGAC 0x22 /* VGA+ in Color Mode */ +#define VIDEO_TYPE_VLFB 0x23 /* VESA VGA in graphic mode */ + +#define VIDEO_TYPE_PICA_S3 0x30 /* ACER PICA-61 local S3 video */ +#define VIDEO_TYPE_MIPS_G364 0x31 /* MIPS Magnum 4000 G364 video */ +#define VIDEO_TYPE_SGI 0x33 /* Various SGI graphics hardware */ + +#define VIDEO_TYPE_TGAC 0x40 /* DEC TGA */ + +#define VIDEO_TYPE_SUN 0x50 /* Sun frame buffer. */ +#define VIDEO_TYPE_SUNPCI 0x51 /* Sun PCI based frame buffer. */ + +#define VIDEO_TYPE_PMAC 0x60 /* PowerMacintosh frame buffer. */ + +#define VIDEO_TYPE_EFI 0x70 /* EFI graphic mode */ + +#define VIDEO_FLAGS_NOCURSOR (1 << 0) /* The video mode has no cursor set */ + +#ifdef __KERNEL__ +extern struct screen_info screen_info; + +#define ORIG_X (screen_info.orig_x) +#define ORIG_Y (screen_info.orig_y) +#define ORIG_VIDEO_MODE (screen_info.orig_video_mode) +#define ORIG_VIDEO_COLS (screen_info.orig_video_cols) +#define ORIG_VIDEO_EGA_BX (screen_info.orig_video_ega_bx) +#define ORIG_VIDEO_LINES (screen_info.orig_video_lines) +#define ORIG_VIDEO_ISVGA (screen_info.orig_video_isVGA) +#define ORIG_VIDEO_POINTS (screen_info.orig_video_points) +#endif /* __KERNEL__ */ + +#endif /* _SCREEN_INFO_H */ diff --git a/lib_i386/zimage.c b/lib_i386/zimage.c index c3b4e59..b39615a 100644 --- a/lib_i386/zimage.c +++ b/lib_i386/zimage.c @@ -34,6 +34,8 @@ #include <asm/zimage.h> #include <asm/realmode.h> #include <asm/byteorder.h> +#include <asm/bootparam.h> +#include <asm/ic/sc520.h>
/* * Memory lay-out: @@ -90,48 +92,56 @@ void *load_zimage(char *image, unsigned long kernel_size, int big_image; void *load_address;
+ struct setup_header *hdr = (struct setup_header *)(image + SETUP_SECTS_OFF);
setup_base = (void*)DEFAULT_SETUP_BASE; /* base address for real-mode segment */
- if (KERNEL_MAGIC != *(u16*)(image + BOOT_FLAG_OFF)) { - printf("Error: Invalid kernel magic (found 0x%04x, expected 0xaa55)\n", - *(u16*)(image + BOOT_FLAG_OFF)); + if (KERNEL_MAGIC != hdr->boot_flag) { + printf("Error: Invalid Boot Flag (found 0x%04x, expected 0x%04x)\n", + hdr->boot_flag, KERNEL_MAGIC); return 0; + } else { + printf("Valid Boot Flag\n"); }
- /* determine boot protocol version */ - if (KERNEL_V2_MAGIC == *(u32*)(image+HEADER_OFF)) { - bootproto = *(u16*)(image+VERSION_OFF); + if (KERNEL_V2_MAGIC == hdr->header) { + printf("Magic signature found\n"); + + bootproto = hdr->version; } else { /* Very old kernel */ + printf("Magic signature not found\n"); bootproto = 0x0100; }
/* determine size of setup */ - if (0 == *(u8*)(image + SETUP_SECTS_OFF)) { + if (0 == hdr->setup_sects) { + printf("Setup Sectors = 0 (defaulting to 4)\n"); setup_size = 5 * 512; } else { - setup_size = (*(u8*)(image + SETUP_SECTS_OFF) + 1) * 512; + setup_size = (hdr->setup_sects + 1) * 512; }
+ printf("Setup Size = 0x%8.8lx\n", (ulong)setup_size); + if (setup_size > SETUP_MAX_SIZE) { printf("Error: Setup is too large (%d bytes)\n", setup_size); }
/* Determine image type */ - big_image = (bootproto >= 0x0200) && (*(u8*)(image + LOADFLAGS_OFF) & BIG_KERNEL_FLAG); + big_image = (bootproto >= 0x0200) && (hdr->loadflags & BIG_KERNEL_FLAG);
- /* Derermine load address */ - load_address = (void*)(big_image ? BZIMAGE_LOAD_ADDR:ZIMAGE_LOAD_ADDR); + /* Determine load address */ + load_address = (void*)(big_image ? BZIMAGE_LOAD_ADDR : ZIMAGE_LOAD_ADDR);
/* load setup */ + printf("Moving Real-Mode Code to 0x%8.8lx (%d bytes)\n", (ulong)setup_base, setup_size); memmove(setup_base, image, setup_size);
printf("Using boot protocol version %x.%02x\n", (bootproto & 0xff00) >> 8, bootproto & 0xff);
- if (bootproto == 0x0100) {
*(u16*)(setup_base + CMD_LINE_MAGIC_OFF) = COMMAND_LINE_MAGIC; @@ -154,48 +164,58 @@ void *load_zimage(char *image, unsigned long kernel_size, memset((void*)0x90000 + setup_size, 0, SETUP_MAX_SIZE-setup_size); }
+ /* We are now setting up the real-mode version of the header */ + hdr = (struct setup_header *)(setup_base + SETUP_SECTS_OFF); + if (bootproto >= 0x0200) { - *(u8*)(setup_base + TYPE_OF_LOADER_OFF) = 0xff; - printf("Linux kernel version %s\n", - (char*)(setup_base + SETUP_START_OFFSET + - *(u16*)(setup_base + START_SYS_OFF + 2))); + hdr->type_of_loader = 8; + + if (hdr->setup_sects >= 15) + printf("Linux kernel version %s\n", (char *) + (setup_base + (hdr->kernel_version + 0x200))); + else + printf("Setup Sectors < 15 - Cannot print kernel version.\n");
if (initrd_addr) { printf("Initial RAM disk at linear address 0x%08lx, size %ld bytes\n", initrd_addr, initrd_size);
- *(u32*)(setup_base + RAMDISK_IMAGE_OFF) = initrd_addr; - *(u32*)(setup_base + RAMDISK_SIZE_OFF)=initrd_size; + hdr->ramdisk_image = initrd_addr; + hdr->ramdisk_size = initrd_size; } }
if (bootproto >= 0x0201) { - *(u16*)(setup_base + HEAP_END_PTR_OFF) = HEAP_END_OFFSET; - - /* CAN_USE_HEAP */ - *(u8*)(setup_base + LOADFLAGS_OFF) = - *(u8*)(setup_base + LOADFLAGS_OFF) | HEAP_FLAG; + hdr->heap_end_ptr = HEAP_END_OFFSET; + hdr->loadflags |= HEAP_FLAG; }
if (bootproto >= 0x0202) { - *(u32*)(setup_base + CMD_LINE_PTR_OFF) = (u32)setup_base + COMMAND_LINE_OFFSET; + hdr->cmd_line_ptr = (u32)setup_base + COMMAND_LINE_OFFSET; } else if (bootproto >= 0x0200) { + *(u16*)(setup_base + CMD_LINE_MAGIC_OFF) = COMMAND_LINE_MAGIC; *(u16*)(setup_base + CMD_LINE_OFFSET_OFF) = COMMAND_LINE_OFFSET; - *(u16*)(setup_base + SETUP_MOVE_SIZE_OFF) = 0x9100; + + hdr->setup_move_size = 0x9100; }
+ if (bootproto >= 0x0204) + kernel_size = hdr->syssize * 16; + else + kernel_size -= setup_size; +
if (big_image) { - if ((kernel_size - setup_size) > BZIMAGE_MAX_SIZE) { + if ((kernel_size) > BZIMAGE_MAX_SIZE) { printf("Error: bzImage kernel too big! (size: %ld, max: %d)\n", - kernel_size - setup_size, BZIMAGE_MAX_SIZE); + kernel_size, BZIMAGE_MAX_SIZE); return 0; }
- } else if ((kernel_size - setup_size) > ZIMAGE_MAX_SIZE) { + } else if ((kernel_size) > ZIMAGE_MAX_SIZE) { printf("Error: zImage kernel too big! (size: %ld, max: %d)\n", - kernel_size - setup_size, ZIMAGE_MAX_SIZE); + kernel_size, ZIMAGE_MAX_SIZE); return 0; }
@@ -203,10 +223,10 @@ void *load_zimage(char *image, unsigned long kernel_size, build_command_line(setup_base + COMMAND_LINE_OFFSET, auto_boot);
printf("Loading %czImage at address 0x%08x (%ld bytes)\n", big_image ? 'b' : ' ', - (u32)load_address, kernel_size - setup_size); + (u32)load_address, kernel_size);
- memmove(load_address, image + setup_size, kernel_size - setup_size); + memmove(load_address, image + setup_size, kernel_size);
/* ready for booting */ return setup_base; @@ -218,8 +238,51 @@ void boot_zimage(void *setup_base)
memset(®s, 0, sizeof(struct pt_regs)); regs.xds = (u32)setup_base >> 4; - regs.xss = 0x9000; + regs.xes = regs.xds; + regs.xss = regs.xds; regs.esp = 0x9000; regs.eflags = 0; enter_realmode(((u32)setup_base+SETUP_START_OFFSET)>>4, 0, ®s, ®s); } + +int do_zboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + void *base_ptr; + void *bzImage_addr; + ulong bzImage_size = 0; + + disable_interrupts(); + + /* Setup board for maximum PC/AT Compatibility */ + setup_pcat_compatibility(); + + /* argv[1] holds the address of the bzImage */ + bzImage_addr = (void *)simple_strtoul(argv[1], NULL, 16); + + if (argc == 3) + bzImage_size = simple_strtoul(argv[2], NULL, 16); + + /* Lets look for*/ + base_ptr = load_zimage (bzImage_addr, bzImage_size, 0, 0, 0); + + if (NULL == base_ptr) { + printf ("## Kernel loading failed ...\n"); + } else { + printf ("## Transferring control to Linux (at address %08x) ...\n", + (u32)base_ptr); + + /* we assume that the kernel is in place */ + printf("\nStarting kernel ...\n\n"); + + boot_zimage(base_ptr); + /* does not return */ + } + + return -1; +} + +U_BOOT_CMD( + zboot, 3, 0, do_zboot, + "Boot bzImage", + "" +);
If the board has a high precision mico-second timer, it maked sense to use it instead of the on-chip one --- cpu/i386/sc520/sc520_timer.c | 4 ++++ include/asm-i386/ic/sc520.h | 1 + 2 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/cpu/i386/sc520/sc520_timer.c b/cpu/i386/sc520/sc520_timer.c index eca48e0..d5617e9 100644 --- a/cpu/i386/sc520/sc520_timer.c +++ b/cpu/i386/sc520/sc520_timer.c @@ -69,7 +69,11 @@ int timer_init(void) return 0; }
+/* Allow boards to override udelay implementation */ void __udelay(unsigned long usec) + __attribute__((weak, alias("sc520_udelay"))); + +void sc520_udelay(unsigned long usec) { int m = 0; long u; diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 57c9904..20384a4 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -28,6 +28,7 @@
void init_sc520(void); unsigned long init_sc520_dram(void); +void sc520_udelay(unsigned long usec);
/* Memory mapped configuration registers */ typedef struct sc520_mmcr {
Onboard AMD Flash chip does not support buffered writes --- include/configs/eNET.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 971840f..58f63f8 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -197,7 +197,7 @@ CONFIG_SYS_FLASH_BASE_1, \ CONFIG_SYS_FLASH_BASE_2} #define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#undef CONFIG_SYS_FLASH_USE_BUFFER_WRITE #define CONFIG_SYS_MAX_FLASH_SECT 128 /* max number of sectors on one chip */ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT #define CONFIG_SYS_FLASH_LEGACY_512Kx8
The clock interupt has always been 1kHz as per timer_init() in /cpu/i386/sc520/sc520_timer.c --- include/configs/eNET.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 58f63f8..19a81b8 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -139,7 +139,7 @@
#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
-#define CONFIG_SYS_HZ 1024 /* incrementer freq: 1kHz */ +#define CONFIG_SYS_HZ 1000 /* incrementer freq: 1kHz */
/*----------------------------------------------------------------------- * SDRAM Configuration
--- I simply do not know why PCI_BASE_ADDRESS_1 has to be changed to PCI_BASE_ADDRESS_0 - Please comment
board/eNET/eNET.c | 12 ++++++++++++ drivers/net/rtl8139.c | 2 +- include/asm-i386/ic/sc520.h | 6 +++--- include/configs/eNET.h | 9 ++++++++- 4 files changed, 24 insertions(+), 5 deletions(-)
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index 52ea140..9d782f3 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -24,6 +24,8 @@ #include <common.h> #include <asm/io.h> #include <asm/ic/sc520.h> +#include <net.h> +#include <netdev.h>
#ifdef CONFIG_HW_WATCHDOG #include <watchdog.h> @@ -173,3 +175,13 @@ ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t * info) } else return 0; } + +int board_eth_init(bd_t *bis) +{ + int adapters; + adapters = pci_eth_init(bis); + + if (adapters > 0) + eth_init(bis); + + return adapters; diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index db8a727..a3df564 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -214,7 +214,7 @@ int rtl8139_initialize(bd_t *bis) if ((devno = pci_find_devices(supported, idx++)) < 0) break;
- pci_read_config_dword(devno, PCI_BASE_ADDRESS_1, &iobase); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_0, &iobase); iobase &= ~0xf;
debug ("rtl8139: REALTEK RTL8139 @0x%x\n", iobase); diff --git a/include/asm-i386/ic/sc520.h b/include/asm-i386/ic/sc520.h index 20384a4..d19cac6 100644 --- a/include/asm-i386/ic/sc520.h +++ b/include/asm-i386/ic/sc520.h @@ -307,14 +307,14 @@ extern volatile sc520_mmcr_t *sc520_mmcr;
/* PCI I/O space from 0x1000 to 0xdfff * (make 0xe000-0xfdff available for stuff like PCCard boot) */ -#define SC520_PCI_IO_PHYS 0x00001000 -#define SC520_PCI_IO_BUS 0x00001000 +#define SC520_PCI_IO_PHYS 0x00002000 +#define SC520_PCI_IO_BUS 0x00002000 #define SC520_PCI_IO_SIZE 0x0000d000
/* system memory from 0x00000000 to 0x0fffffff */ #define SC520_PCI_MEMORY_PHYS 0x00000000 #define SC520_PCI_MEMORY_BUS 0x00000000 -#define SC520_PCI_MEMORY_SIZE 0x10000000 +#define SC520_PCI_MEMORY_SIZE 0x08000000
/* PCI bus memory from 0x10000000 to 0x26ffffff * (make 0x27000000 - 0x27ffffff available for stuff like PCCard boot) */ diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 19a81b8..4380bb1 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -104,9 +104,10 @@ #define CONFIG_CMD_LOADS /* loads */ #define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ #define CONFIG_CMD_MISC /* Misc functions like sleep etc*/ -#undef CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ #undef CONFIG_CMD_NFS /* NFS support */ #define CONFIG_CMD_PCI /* PCI support */ +#define CONFIG_CMD_PING /* ICMP echo support */ #define CONFIG_CMD_RUN /* run command in env variable */ #define CONFIG_CMD_SAVEENV /* saveenv */ #define CONFIG_CMD_SETGETDCR /* DCR support on 4xx */ @@ -225,6 +226,12 @@ #define CONFIG_SYS_THIRD_PCI_IRQ 11 #define CONFIG_SYS_FORTH_PCI_IRQ 15
+ /* + * Network device (TRL8100B) support + */ +#define CONFIG_NET_MULTI +#define CONFIG_RTL8139 + /*----------------------------------------------------------------------- * Hardware watchdog configuration */
HI Graeme,
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index 52ea140..9d782f3 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -24,6 +24,8 @@ #include<common.h> #include<asm/io.h> #include<asm/ic/sc520.h> +#include<net.h> +#include<netdev.h>
#ifdef CONFIG_HW_WATCHDOG #include<watchdog.h> @@ -173,3 +175,13 @@ ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t * info) } else return 0; }
- int adapters;
- adapters = pci_eth_init(bis);
- if (adapters> 0)
eth_init(bis);
I'm not sure why you're calling eth_init() here. Are you sure that's what you want to do? Keep in mind that board_eth_init() gets called by eth_initialize() in the common net code.
- return adapters;
diff --git a/drivers/net/rtl8139.c b/drivers/net/rtl8139.c index db8a727..a3df564 100644 --- a/drivers/net/rtl8139.c +++ b/drivers/net/rtl8139.c @@ -214,7 +214,7 @@ int rtl8139_initialize(bd_t *bis) if ((devno = pci_find_devices(supported, idx++))< 0) break;
pci_read_config_dword(devno, PCI_BASE_ADDRESS_1,&iobase);
pci_read_config_dword(devno, PCI_BASE_ADDRESS_0,&iobase);
Are you fixing a bug here? This seems like a change that would have fairly wide-ranging implications beyond your board. <snip>
regards, Ben
Hi Ben,
Thanks for having a look at this
On Mon, Apr 5, 2010 at 3:32 PM, Ben Warren biggerbadderben@gmail.com wrote:
HI Graeme,
<snip>
int adapters;
if (adapters> 0)
eth_init(bis);
I'll have a look at this and respin this patch
return adapters;
<snip>
If I use PCI_BASE_ADDRESS_1 I simply cannot get the Ethernet adapters to work (I get complete rubbish when accessing the registers). It took me a long time to figure this out and in the end I simply ran out of logical adjustments and started hacking around and this worked.
Maybe there is some special initialisation of the PCI host in the SC520 that would make this work. I really don't know the inner workings of talking to PCI devices and am taking a lot of what I am doing here on blind faith. If it gives you any more of an idea as to why this change is needed, I have to use PIO instead of MMIO for the Linux driver
Regards,
Graeme
The eNET uses the sc520 software timers rather than the PC/AT clones
Set all interrupts and timers up to be PC/AT compatible --- board/eNET/eNET.c | 38 ++++++++++++++++++++++++++++++++++++++ 1 files changed, 38 insertions(+), 0 deletions(-)
diff --git a/board/eNET/eNET.c b/board/eNET/eNET.c index 9d782f3..ac3f958 100644 --- a/board/eNET/eNET.c +++ b/board/eNET/eNET.c @@ -185,3 +185,41 @@ int board_eth_init(bd_t *bis) eth_init(bis);
return adapters; + +void setup_pcat_compatibility() +{ + /* disable global interrupt mode */ + writeb(0x40, &sc520_mmcr->picicr); + + /* set all irqs to edge */ + writeb(0x00, &sc520_mmcr->pic_mode[0]); + writeb(0x00, &sc520_mmcr->pic_mode[1]); + writeb(0x00, &sc520_mmcr->pic_mode[2]); + + /* + * active low polarity on PIC interrupt pins, + * active high polarity on all other irq pins + */ + writew(0x0000,&sc520_mmcr->intpinpol); + + /* Set PIT 0 -> IRQ0, RTC -> IRQ8, FP error -> IRQ13 */ + writeb(SC520_IRQ0, &sc520_mmcr->pit_int_map[0]); + writeb(SC520_IRQ8, &sc520_mmcr->rtcmap); + writeb(SC520_IRQ13, &sc520_mmcr->ferrmap); + + /* Disable all other interrupt sources */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[0]); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[1]); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->gp_tmr_int_map[2]); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pit_int_map[1]); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pit_int_map[2]); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[0]); /* disable PCI INT A */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[1]); /* disable PCI INT B */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[2]); /* disable PCI INT C */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->pci_int_map[3]); /* disable PCI INT D */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->dmabcintmap); /* disable DMA INT */ + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->ssimap); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->wdtmap); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->wpvmap); + writeb(SC520_IRQ_DISABLED, &sc520_mmcr->icemap); +}
diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 4380bb1..1713cd1 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -159,7 +159,7 @@ * CPU Features */ #define CONFIG_SYS_SC520_HIGH_SPEED 0 /* 100 or 133MHz */ -#undef CONFIG_SYS_SC520_RESET /* use SC520 MMCR's to reset cpu */ +#define CONFIG_SYS_SC520_RESET /* use SC520 MMCR's to reset cpu */ #define CONFIG_SYS_SC520_TIMER /* use SC520 swtimers */ #undef CONFIG_SYS_GENERIC_TIMER /* use the i8254 PIT timers */ #undef CONFIG_SYS_TSC_TIMER /* use the Pentium TSC timers */
< snip>
Once this patchset is applied I believe the x86 port of U-Boot will be ready for more mainstream use
Wolfgang - If there is any other renewed interest in the x86 port, I would be more than happy to be an official custodian
Hi Graeme, Is there a quick summary about what is supported, how its used, etc? Eg could x86 U-Boot replace the BIOS on on chipset X, similar to coreboot? Or is it a 2nd stage bootloader like GRUB? Or a bootloader that is run from GRUB? How hard would it be to port to other x86 platform?
It seems like cool stuff, I'm just trying to wrap my head around the high-level concept of U-Boot on x86 and where/why it'd be used instead of the "standard" alternatives.
Thanks, Peter
Peter Tyser wrote:
< snip>
The x86 U-Boot port, like all other U-Boot ports, is a primary boot loader for embedded systems. As such, it is designed to bring a board up from power-on/cold reset to a state where Linux (or other OS) can execute (e.g load FPGAs, configure hardware address and I/O structures etc). The closest 'in-the-wild' comparative software would be RedBoot.
The current implementation is designed around the AMD SC520 ELAN CPU, but porting to other x86 CPUs and boards should be fairly simple. Porting is made easier if the target is PC/AT centric. That said, the modular design should allow for very easy diversion from PC/AT.
It does not (and will not) replace the BIOS of a regular PC (Coreboot) nor will it be a second stage bootloader (GRUB). However, at a pinch, I imagine you could use it to boot a VIA mini-ITX board for example.
x86 is a poor second cousin to PPC and ARM in the embedded world. The reasons for this are many and varied, but generally speaking ARM and PPC are better suited to the embedded world due to lower power consumption and integrated peripherals. x86 has its advantages (no need for cross compiling, easier to simulate and a PC without using QEMU etc).
x86 U-Boot does do a few things though that I think are very special: - It fully relocates itself to the highest available RAM (including Read-Only data and special data structures like the GDT and IDT which are sometimes overlooked) - It can be fail-safe boot-strapped from RAM (i.e. boot an old version from power-up, tftp a new version, jump to the new version)
In the near future, I intend to make it 100% relocatable (i.e. does not need to be loaded at TEXT_BASE) and maybe even add the ability to specify the relocation address.
Thanks, Peter
Your welcome :) Graeme
I did a few months ago for MPC83xx and sent it to the list. There was some discussion but in the end it wasn't applied because it was too invasive. PPC is especially bad as it needs to relocate string literals too.
Search for LINK_OFF if you want to see what I did
Jocke
Yes, I saw a bit of that thread and you patches an I would agree that they were too invasive. x86 is not that great for relocation either (all calls are absolute as well as references to .text). Have a look at board_init_f() in lib_i386\board.c - it has a very basic parsing of the ELF relocation information.
I tried to champion this as a cross-platform method of achieving full relocation and the killing off of all those ugly reloc_off hacks all over the place. Unfortunately, I think the code size and time penalty may have been too great in the end.
To implement full relocation, I simply need to add an additional parameter to this function which provides the 'link versus load' offset which will get applied to the 'load versus run' offset calculation
Graeme Russ graeme.russ@gmail.com wrote on 2010/03/27 12:54:03:
Are we talking about the same thing? when you say "does not need to be loaded at TEXT_BASE" you need something like my LINK_OFF patch, otherwise I don't see how you can boot out of flash otherwise.
Jocke
I realise now that we are not talking about the same thing. The x86 port always relocates into (and runs from) RAM. Only a very small stub is run from flash (SDRAM setup and sizing, copy to RAM, process relocation entries etc). This stub can be made fully relocatable while running from Flash (with a few tricks)
By adjusting all position dependent code after copying into RAM, LINK_OFF is no longer needed
Graeme
Graeme Russ graeme.russ@gmail.com wrote on 2010/03/28 09:38:47:
Have you tried that yet? This is exactly what LINK_OFF is for. Turns out that there is more code than you think that is executed before relocation into RAM. Perhaps your stub is very small and doesn't need the serial port or access to EEPROM via I2C. That won't work in the long run though.
You don't need LINK_OFF for this, PPC already have this feature since it can relocate into any RAM address.
participants (6)
Ben Warren
Graeme Russ
Joakim Tjernlund
Mike Frysinger
Peter Tyser
Vipin Kumar
