[PATCH 1/5] patman: Split out arg parsing into its own file
Move this code into a separate cmdline module, as is done with the other tools.
Use the same HAS_TESTS check as buildman
tools/patman/__main__.py | 116 +----------------------------- tools/patman/cmdline.py | 147 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 150 insertions(+), 113 deletions(-) create mode 100644 tools/patman/cmdline.py
diff --git a/tools/patman/__main__.py b/tools/patman/__main__.py index 197ac1aad103..0e559b5810be 100755 --- a/tools/patman/__main__.py +++ b/tools/patman/__main__.py @@ -6,7 +6,6 @@
"""See README for more information"""
-from argparse import ArgumentParser try: import importlib.resources except ImportError: @@ -23,128 +22,19 @@ if __name__ == "__main__": sys.path.append(os.path.join(our_path, '..'))
# Our modules +from patman import cmdline from patman import control from patman import func_test -from patman import gitutil -from patman import project -from patman import settings from u_boot_pylib import terminal from u_boot_pylib import test_util from u_boot_pylib import tools
-epilog = '''Create patches from commits in a branch, check them and email them -as specified by tags you place in the commits. Use -n to do a dry run first.''' - -parser = ArgumentParser(epilog=epilog) -parser.add_argument('-b', '--branch', type=str, - help="Branch to process (by default, the current branch)") -parser.add_argument('-c', '--count', dest='count', type=int, - default=-1, help='Automatically create patches from top n commits') -parser.add_argument('-e', '--end', type=int, default=0, - help='Commits to skip at end of patch list') -parser.add_argument('-D', '--debug', action='store_true', - help='Enabling debugging (provides a full traceback on error)') -parser.add_argument('-p', '--project', default=project.detect_project(), - help="Project name; affects default option values and " - "aliases [default: %(default)s]") -parser.add_argument('-P', '--patchwork-url', - default='https://patchwork.ozlabs.org', - help='URL of patchwork server [default: %(default)s]') -parser.add_argument('-s', '--start', dest='start', type=int, - default=0, help='Commit to start creating patches from (0 = HEAD)') -parser.add_argument('-v', '--verbose', action='store_true', dest='verbose', - default=False, help='Verbose output of errors and warnings') -parser.add_argument('-H', '--full-help', action='store_true', dest='full_help', - default=False, help='Display the README file') - -subparsers = parser.add_subparsers(dest='cmd') -send = subparsers.add_parser( - 'send', help='Format, check and email patches (default command)') -send.add_argument('-i', '--ignore-errors', action='store_true', - dest='ignore_errors', default=False, - help='Send patches email even if patch errors are found') -send.add_argument('-l', '--limit-cc', dest='limit', type=int, default=None, - help='Limit the cc list to LIMIT entries [default: %(default)s]') -send.add_argument('-m', '--no-maintainers', action='store_false', - dest='add_maintainers', default=True, - help="Don't cc the file maintainers automatically") -send.add_argument( - '--get-maintainer-script', dest='get_maintainer_script', type=str, - action='store', - default=os.path.join(gitutil.get_top_level(), 'scripts', - 'get_maintainer.pl') + ' --norolestats', - help='File name of the get_maintainer.pl (or compatible) script.') -send.add_argument('-n', '--dry-run', action='store_true', dest='dry_run', - default=False, help="Do a dry run (create but don't email patches)") -send.add_argument('-r', '--in-reply-to', type=str, action='store', - help="Message ID that this series is in reply to") -send.add_argument('-t', '--ignore-bad-tags', action='store_true', - default=False, - help='Ignore bad tags / aliases (default=warn)') -send.add_argument('-T', '--thread', action='store_true', dest='thread', - default=False, help='Create patches as a single thread') -send.add_argument('--cc-cmd', dest='cc_cmd', type=str, action='store', - default=None, help='Output cc list for patch file (used by git)') -send.add_argument('--no-binary', action='store_true', dest='ignore_binary', - default=False, - help="Do not output contents of changes in binary files") -send.add_argument('--no-check', action='store_false', dest='check_patch', - default=True, - help="Don't check for patch compliance") -send.add_argument('--tree', dest='check_patch_use_tree', default=False, - action='store_true', - help=("Set `tree` to True. If `tree` is False then we'll " - "pass '--no-tree' to checkpatch (default: tree=%(default)s)")) -send.add_argument('--no-tree', dest='check_patch_use_tree', - action='store_false', help="Set `tree` to False") -send.add_argument('--no-tags', action='store_false', dest='process_tags', - default=True, help="Don't process subject tags as aliases") -send.add_argument('--no-signoff', action='store_false', dest='add_signoff', - default=True, help="Don't add Signed-off-by to patches") -send.add_argument('--smtp-server', type=str, - help="Specify the SMTP server to 'git send-email'") -send.add_argument('--keep-change-id', action='store_true', - help='Preserve Change-Id tags in patches to send.') - -send.add_argument('patchfiles', nargs='*') - -# Only add the 'test' action if the test data files are available. -if os.path.exists(func_test.TEST_DATA_DIR): - test_parser = subparsers.add_parser('test', help='Run tests') - test_parser.add_argument('testname', type=str, default=None, nargs='?', - help="Specify the test to run") - -status = subparsers.add_parser('status', - help='Check status of patches in patchwork') -status.add_argument('-C', '--show-comments', action='store_true', - help='Show comments from each patch') -status.add_argument('-d', '--dest-branch', type=str, - help='Name of branch to create with collected responses') -status.add_argument('-f', '--force', action='store_true', - help='Force overwriting an existing branch') - -# Parse options twice: first to get the project and second to handle -# defaults properly (which depends on project) -# Use parse_known_args() in case 'cmd' is omitted -argv = sys.argv[1:] -args, rest = parser.parse_known_args(argv) -if hasattr(args, 'project'): - settings.Setup(parser, args.project) - args, rest = parser.parse_known_args(argv) - -# If we have a command, it is safe to parse all arguments -if args.cmd: - args = parser.parse_args(argv) -else: - # No command, so insert it after the known arguments and before the ones - # that presumably relate to the 'send' subcommand - nargs = len(rest) - argv = argv[:-nargs] + ['send'] + rest - args = parser.parse_args(argv)
if __name__ != "__main__": pass
+args = cmdline.parse_args() + if not args.debug: sys.tracebacklimit = 0
diff --git a/tools/patman/cmdline.py b/tools/patman/cmdline.py new file mode 100644 index 000000000000..d6496c0cb780 --- /dev/null +++ b/tools/patman/cmdline.py @@ -0,0 +1,147 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2023 Google LLC +# + +"""Handles parsing of buildman arguments + +This creates the argument parser and uses it to parse the arguments passed in +""" + +import argparse +import os +import pathlib +import sys + +from patman import gitutil +from patman import project +from patman import settings + +PATMAN_DIR = pathlib.Path(__file__).parent +HAS_TESTS = os.path.exists(PATMAN_DIR / "func_test.py") + +def parse_args(): + """Parse command line arguments from sys.argv[] + + Returns: + tuple containing: + options: command line options + args: command lin arguments + """ + epilog = '''Create patches from commits in a branch, check them and email + them as specified by tags you place in the commits. Use -n to do a dry + run first.''' + + parser = argparse.ArgumentParser(epilog=epilog) + parser.add_argument('-b', '--branch', type=str, + help="Branch to process (by default, the current branch)") + parser.add_argument('-c', '--count', dest='count', type=int, + default=-1, help='Automatically create patches from top n commits') + parser.add_argument('-e', '--end', type=int, default=0, + help='Commits to skip at end of patch list') + parser.add_argument('-D', '--debug', action='store_true', + help='Enabling debugging (provides a full traceback on error)') + parser.add_argument('-p', '--project', default=project.detect_project(), + help="Project name; affects default option values and " + "aliases [default: %(default)s]") + parser.add_argument('-P', '--patchwork-url', + default='https://patchwork.ozlabs.org', + help='URL of patchwork server [default: %(default)s]') + parser.add_argument('-s', '--start', dest='start', type=int, + default=0, help='Commit to start creating patches from (0 = HEAD)') + parser.add_argument( + '-v', '--verbose', action='store_true', dest='verbose', default=False, + help='Verbose output of errors and warnings') + parser.add_argument( + '-H', '--full-help', action='store_true', dest='full_help', + default=False, help='Display the README file') + + subparsers = parser.add_subparsers(dest='cmd') + send = subparsers.add_parser( + 'send', help='Format, check and email patches (default command)') + send.add_argument('-i', '--ignore-errors', action='store_true', + dest='ignore_errors', default=False, + help='Send patches email even if patch errors are found') + send.add_argument('-l', '--limit-cc', dest='limit', type=int, default=None, + help='Limit the cc list to LIMIT entries [default: %(default)s]') + send.add_argument('-m', '--no-maintainers', action='store_false', + dest='add_maintainers', default=True, + help="Don't cc the file maintainers automatically") + send.add_argument( + '--get-maintainer-script', dest='get_maintainer_script', type=str, + action='store', + default=os.path.join(gitutil.get_top_level(), 'scripts', + 'get_maintainer.pl') + ' --norolestats', + help='File name of the get_maintainer.pl (or compatible) script.') + send.add_argument('-n', '--dry-run', action='store_true', dest='dry_run', + default=False, help="Do a dry run (create but don't email patches)") + send.add_argument('-r', '--in-reply-to', type=str, action='store', + help="Message ID that this series is in reply to") + send.add_argument('-t', '--ignore-bad-tags', action='store_true', + default=False, + help='Ignore bad tags / aliases (default=warn)') + send.add_argument('-T', '--thread', action='store_true', dest='thread', + default=False, help='Create patches as a single thread') + send.add_argument('--cc-cmd', dest='cc_cmd', type=str, action='store', + default=None, help='Output cc list for patch file (used by git)') + send.add_argument('--no-binary', action='store_true', dest='ignore_binary', + default=False, + help="Do not output contents of changes in binary files") + send.add_argument('--no-check', action='store_false', dest='check_patch', + default=True, + help="Don't check for patch compliance") + send.add_argument( + '--tree', dest='check_patch_use_tree', default=False, + action='store_true', + help=("Set `tree` to True. If `tree` is False then we'll pass " + "'--no-tree' to checkpatch (default: tree=%(default)s)")) + send.add_argument('--no-tree', dest='check_patch_use_tree', + action='store_false', help="Set `tree` to False") + send.add_argument( + '--no-tags', action='store_false', dest='process_tags', default=True, + help="Don't process subject tags as aliases") + send.add_argument('--no-signoff', action='store_false', dest='add_signoff', + default=True, help="Don't add Signed-off-by to patches") + send.add_argument('--smtp-server', type=str, + help="Specify the SMTP server to 'git send-email'") + send.add_argument('--keep-change-id', action='store_true', + help='Preserve Change-Id tags in patches to send.') + + send.add_argument('patchfiles', nargs='*') + + # Only add the 'test' action if the test data files are available. + if HAS_TESTS: + test_parser = subparsers.add_parser('test', help='Run tests') + test_parser.add_argument('testname', type=str, default=None, nargs='?', + help="Specify the test to run") + + status = subparsers.add_parser('status', + help='Check status of patches in patchwork') + status.add_argument('-C', '--show-comments', action='store_true', + help='Show comments from each patch') + status.add_argument( + '-d', '--dest-branch', type=str, + help='Name of branch to create with collected responses') + status.add_argument('-f', '--force', action='store_true', + help='Force overwriting an existing branch') + + # Parse options twice: first to get the project and second to handle + # defaults properly (which depends on project) + # Use parse_known_args() in case 'cmd' is omitted + argv = sys.argv[1:] + args, rest = parser.parse_known_args(argv) + if hasattr(args, 'project'): + settings.Setup(parser, args.project) + args, rest = parser.parse_known_args(argv) + + # If we have a command, it is safe to parse all arguments + if args.cmd: + args = parser.parse_args(argv) + else: + # No command, so insert it after the known arguments and before the ones + # that presumably relate to the 'send' subcommand + nargs = len(rest) + argv = argv[:-nargs] + ['send'] + rest + args = parser.parse_args(argv) + + return args
Add a new run_patman() function to hold the main logic.
tools/patman/__main__.py | 127 +++++++++++++++++++++------------------ 1 file changed, 67 insertions(+), 60 deletions(-)
diff --git a/tools/patman/__main__.py b/tools/patman/__main__.py index 0e559b5810be..87850295e704 100755 --- a/tools/patman/__main__.py +++ b/tools/patman/__main__.py @@ -30,63 +30,70 @@ from u_boot_pylib import test_util from u_boot_pylib import tools
-if __name__ != "__main__": - pass - -args = cmdline.parse_args() - -if not args.debug: - sys.tracebacklimit = 0 - -# Run our meagre tests -if args.cmd == 'test': - from patman import func_test - from patman import test_checkpatch - - result = test_util.run_test_suites( - 'patman', False, False, False, None, None, None, - [test_checkpatch.TestPatch, func_test.TestFunctional, - 'gitutil', 'settings']) - - sys.exit(0 if result.wasSuccessful() else 1) - -# Process commits, produce patches files, check them, email them -elif args.cmd == 'send': - # Called from git with a patch filename as argument - # Printout a list of additional CC recipients for this patch - if args.cc_cmd: - fd = open(args.cc_cmd, 'r') - re_line = re.compile('(\S*) (.*)') - for line in fd.readlines(): - match = re_line.match(line) - if match and match.group(1) == args.patchfiles[0]: - for cc in match.group(2).split('\0'): - cc = cc.strip() - if cc: - print(cc) - fd.close() - - elif args.full_help: - with importlib.resources.path('patman', 'README.rst') as readme: - tools.print_full_help(str(readme)) - else: - # If we are not processing tags, no need to warning about bad ones - if not args.process_tags: - args.ignore_bad_tags = True - control.send(args) - -# Check status of patches in patchwork -elif args.cmd == 'status': - ret_code = 0 - try: - control.patchwork_status(args.branch, args.count, args.start, args.end, - args.dest_branch, args.force, - args.show_comments, args.patchwork_url) - except Exception as e: - terminal.tprint('patman: %s: %s' % (type(e).__name__, e), - colour=terminal.Color.RED) - if args.debug: - print() - traceback.print_exc() - ret_code = 1 - sys.exit(ret_code) +def run_patman(): + """Run patamn + + This is the main program. It collects arguments and runs either the tests or + the control module. + """ + args = cmdline.parse_args() + + if not args.debug: + sys.tracebacklimit = 0 + + # Run our meagre tests + if args.cmd == 'test': + from patman import func_test + from patman import test_checkpatch + + result = test_util.run_test_suites( + 'patman', False, False, False, None, None, None, + [test_checkpatch.TestPatch, func_test.TestFunctional, + 'gitutil', 'settings']) + + sys.exit(0 if result.wasSuccessful() else 1) + + # Process commits, produce patches files, check them, email them + elif args.cmd == 'send': + # Called from git with a patch filename as argument + # Printout a list of additional CC recipients for this patch + if args.cc_cmd: + fd = open(args.cc_cmd, 'r') + re_line = re.compile('(\S*) (.*)') + for line in fd.readlines(): + match = re_line.match(line) + if match and match.group(1) == args.patchfiles[0]: + for cc in match.group(2).split('\0'): + cc = cc.strip() + if cc: + print(cc) + fd.close() + + elif args.full_help: + with importlib.resources.path('patman', 'README.rst') as readme: + tools.print_full_help(str(readme)) + else: + # If we are not processing tags, no need to warning about bad ones + if not args.process_tags: + args.ignore_bad_tags = True + control.send(args) + + # Check status of patches in patchwork + elif args.cmd == 'status': + ret_code = 0 + try: + control.patchwork_status(args.branch, args.count, args.start, args.end, + args.dest_branch, args.force, + args.show_comments, args.patchwork_url) + except Exception as e: + terminal.tprint('patman: %s: %s' % (type(e).__name__, e), + colour=terminal.Color.RED) + if args.debug: + print() + traceback.print_exc() + ret_code = 1 + sys.exit(ret_code) + + +if __name__ == "__main__": + sys.exit(run_patman())
Applied to u-boot-dm, thanks!
Tidy up the code a little to reduce the number of pylint warnings.
tools/patman/__main__.py | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/tools/patman/__main__.py b/tools/patman/__main__.py index 87850295e704..3ca858cd3157 100755 --- a/tools/patman/__main__.py +++ b/tools/patman/__main__.py @@ -16,10 +16,10 @@ import re import sys import traceback
-if __name__ == "__main__": - # Allow 'from patman import xxx to work' - our_path = os.path.dirname(os.path.realpath(__file__)) - sys.path.append(os.path.join(our_path, '..')) +# Allow 'from patman import xxx to work' +# pylint: disable=C0413 +our_path = os.path.dirname(os.path.realpath(__file__)) +sys.path.append(os.path.join(our_path, '..'))
# Our modules from patman import cmdline @@ -43,6 +43,7 @@ def run_patman():
# Run our meagre tests if args.cmd == 'test': + # pylint: disable=C0415 from patman import func_test from patman import test_checkpatch
@@ -58,16 +59,15 @@ def run_patman(): # Called from git with a patch filename as argument # Printout a list of additional CC recipients for this patch if args.cc_cmd: - fd = open(args.cc_cmd, 'r') - re_line = re.compile('(\S*) (.*)') - for line in fd.readlines(): - match = re_line.match(line) - if match and match.group(1) == args.patchfiles[0]: - for cc in match.group(2).split('\0'): - cc = cc.strip() - if cc: - print(cc) - fd.close() + re_line = re.compile(r'(\S*) (.*)') + with open(args.cc_cmd, 'r', encoding='utf-8') as inf: + for line in inf.readlines(): + match = re_line.match(line) + if match and match.group(1) == args.patchfiles[0]: + for cca in match.group(2).split('\0'): + cca = cca.strip() + if cca: + print(cca)
elif args.full_help: with importlib.resources.path('patman', 'README.rst') as readme: @@ -85,8 +85,8 @@ def run_patman(): control.patchwork_status(args.branch, args.count, args.start, args.end, args.dest_branch, args.force, args.show_comments, args.patchwork_url) - except Exception as e: - terminal.tprint('patman: %s: %s' % (type(e).__name__, e), + except Exception as exc: + terminal.tprint(f'patman: {type(exc).__name__}: {exc}', colour=terminal.Color.RED) if args.debug: print()
Import this only when it is needed, since it is not present when installed via 'pip install'.
Signed-off-by: Simon Glass sjg@chromium.org Fixes: https://source.denx.de/u-boot/u-boot/-/issues/26 ---
tools/patman/__main__.py | 1 - 1 file changed, 1 deletion(-)
diff --git a/tools/patman/__main__.py b/tools/patman/__main__.py index 3ca858cd3157..d53f686a2d45 100755 --- a/tools/patman/__main__.py +++ b/tools/patman/__main__.py @@ -24,7 +24,6 @@ sys.path.append(os.path.join(our_path, '..')) # Our modules from patman import cmdline from patman import control -from patman import func_test from u_boot_pylib import terminal from u_boot_pylib import test_util from u_boot_pylib import tools
The importlib_resources import is not actually used. Fix this so that patman can run on Python 3.6 to some extent, once 'pip3 install importlib-resources' has been run.
tools/patman/__main__.py | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/tools/patman/__main__.py b/tools/patman/__main__.py index d53f686a2d45..f645b38b6470 100755 --- a/tools/patman/__main__.py +++ b/tools/patman/__main__.py @@ -7,10 +7,10 @@ """See README for more information"""
try: - import importlib.resources + from importlib import resources except ImportError: # for Python 3.6 - import importlib_resources + import importlib_resources as resources import os import re import sys @@ -69,7 +69,7 @@ def run_patman(): print(cca)
elif args.full_help: - with importlib.resources.path('patman', 'README.rst') as readme: + with resources.path('patman', 'README.rst') as readme: tools.print_full_help(str(readme)) else: # If we are not processing tags, no need to warning about bad ones
