[PATCH] doc: fix references to distro documentation
Commit 37c5195dfcd157 ("doc: Move distro boot doc to rST") renamed doc/README.distro to doc/develop/distro.rst.
Signed-off-by: Dario Binacchi dario.binacchi@amarulasolutions.com ---
doc/README.gpt | 2 +- doc/README.uniphier | 2 +- doc/board/emulation/qemu-x86.rst | 2 +- doc/board/st/stm32mp1.rst | 2 +- doc/board/tbs/tbs2910.rst | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/doc/README.gpt b/doc/README.gpt index 91e397d06f88..394cea0aa875 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -177,7 +177,7 @@ To restore GUID partition table one needs to: "name=u-boot,size=60MiB;name=boot,size=60Mib,bootable;name=rootfs,size=0" It can be used to locate bootable disks with command "part list <interface> <dev> -bootable <varname>", - please check out doc/README.distro for use. + please check out doc/develop/distro.rst for use.
2. Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT'
diff --git a/doc/README.uniphier b/doc/README.uniphier index badfacd66aa5..af746f6c316e 100644 --- a/doc/README.uniphier +++ b/doc/README.uniphier @@ -336,7 +336,7 @@ Deployment for Distro Boot --------------------------
UniPhier SoC family boot the kernel in a generic manner as described in -doc/README.distro . +doc/develop/distro.rst.
To boot the kernel, you need to deploy necesssary components to a file system on one of your block devices (eMMC, NAND, USB drive, etc.). diff --git a/doc/board/emulation/qemu-x86.rst b/doc/board/emulation/qemu-x86.rst index db842f2ece6e..e605ae3ab32e 100644 --- a/doc/board/emulation/qemu-x86.rst +++ b/doc/board/emulation/qemu-x86.rst @@ -57,7 +57,7 @@ to instantiate. Note, the maximum supported CPU number in QEMU is 255. U-Boot uses 'distro_bootcmd' by default when booting on x86 QEMU. This tries to load a boot script, kernel, and ramdisk from several different interfaces. For the default boot order, see 'qemu-x86.h'. For more information, see -'README.distro'. Most Linux distros can be booted by writing a uboot script. +'distro.rst'. Most Linux distros can be booted by writing a uboot script. For example, Debian (stretch) can be booted by creating a script file named 'boot.txt' with the contents::
diff --git a/doc/board/st/stm32mp1.rst b/doc/board/st/stm32mp1.rst index 3759df353ee5..0dcc6b783b89 100644 --- a/doc/board/st/stm32mp1.rst +++ b/doc/board/st/stm32mp1.rst @@ -478,7 +478,7 @@ or: +-------+--------+---------+------------------------+------------------------+
And the 4th partition (Rootfs) is marked bootable with a file extlinux.conf -following the Generic Distribution feature (doc/README.distro for use). +following the Generic Distribution feature (doc/develop/distro.rst for use).
The size of fip or ssbl partition must be enough for the associated binary file, 4MB and 2MB are default values. diff --git a/doc/board/tbs/tbs2910.rst b/doc/board/tbs/tbs2910.rst index e97f2b6e6135..4760922a93e6 100644 --- a/doc/board/tbs/tbs2910.rst +++ b/doc/board/tbs/tbs2910.rst @@ -181,7 +181,7 @@ If that fails it will then try to boot from several interfaces using 'distro_bootcmd': It will first try to boot from the microSD slot, then the SD slot, then the internal eMMC, then the SATA interface and finally the USB interface. For more information on how to configure your distribution to boot, -see 'README.distro'. +see 'distro.rst'.
Links: ------
Hi Dario
- please check out doc/develop/distro.rst for use.
- Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT'
Links:
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hi Dario,
Please change 'distro.rst' to 'doc/develop/distro.rst' here. Yes, the 'doc' was missing before, but with the additional 'develop' directory it becomes even more difficult to find.
Thanks, Soeren
Links:
Dario Binacchi
Patrice CHOTARD
Soeren Moch
