[U-Boot-Users] [PATCH] MPC8360EMDS lowboot option
Hi Dave Liu,
The following patch adds a configuration to do "low boot" (HRCW.BMS = 0) as well as "high boot" (HRCW.BMS = 1).
Many people, myself included :o) prefer to boot out of low memory. It has an added benefit that, if you screw up the image of of u-boot in low memory, you can switch SW9.3 FCFG and boot using the BCSR, which "high boots" (assuming you smart enough to keep a valid u-boot image at 0xFFF00000).
The patch is against the top of the denx.de repository (thanks, Wolfgang, for pulling the fsl patches).
gvb
Add a configuration option to "low boot" (boot memory space 0x00000000) as well as the default "high boot" (0xFFF00000).
Signed-off-by: Jerry Van Baren vanbaren@cideas.com --- Makefile | 18 +++++++++++++----- board/mpc8360emds/config.mk | 7 ++++++- include/configs/MPC8360EMDS.h | 14 ++++++++++++-- 3 files changed, 31 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index d2534ab..684b862 100644 --- a/Makefile +++ b/Makefile @@ -1595,27 +1595,35 @@ MPC8349EMDS_config: unconfig @$(MKCONFIG) $(@:_config=) ppc mpc83xx mpc8349emds
MPC8360EMDS_config \ +MPC8360EMDS_lowboot_config \ MPC8360EMDS_HOST_33_config \ +MPC8360EMDS_HOST_33_lowboot_config \ MPC8360EMDS_HOST_66_config \ +MPC8360EMDS_HOST_66_lowboot_config \ +MPC8360EMDS_SLAVE_lowboot_config \ MPC8360EMDS_SLAVE_config: unconfig @echo "" >include/config.h ; \ if [ "$(findstring _HOST_,$@)" ] ; then \ - echo -n "... PCI HOST " ; \ + echo -n "...PCI HOST" ; \ echo "#define CONFIG_PCI" >>include/config.h ; \ fi ; \ if [ "$(findstring _SLAVE_,$@)" ] ; then \ - echo "...PCI SLAVE 66M" ; \ + echo "...PCI SLAVE 66M..." ; \ echo "#define CONFIG_PCI" >>include/config.h ; \ echo "#define CONFIG_PCISLAVE" >>include/config.h ; \ fi ; \ if [ "$(findstring _33_,$@)" ] ; then \ - echo -n "...33M ..." ; \ + echo -n " 33M..." ; \ echo "#define PCI_33M" >>include/config.h ; \ fi ; \ if [ "$(findstring _66_,$@)" ] ; then \ - echo -n "...66M..." ; \ + echo -n " 66M..." ; \ echo "#define PCI_66M" >>include/config.h ; \ - fi ; + fi ; \ + if [ "$(findstring lowboot_,$@)" ] ; then \ + echo -n " (lowboot) " ; \ + echo "TEXT_BASE = 0xFE000000" >$(obj)board/mpc8360emds/config.tmp ; \ + fi @$(MKCONFIG) -a MPC8360EMDS ppc mpc83xx mpc8360emds
MPC8349ITX_config: unconfig diff --git a/board/mpc8360emds/config.mk b/board/mpc8360emds/config.mk index 9ace886..dd560cc 100644 --- a/board/mpc8360emds/config.mk +++ b/board/mpc8360emds/config.mk @@ -25,4 +25,9 @@ # MPC8360EMDS #
-TEXT_BASE = 0xFE000000 +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +## Default: boot high +TEXT_BASE = 0xFFF00000 +endif diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 8ad6551..c4fff07 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -47,6 +47,16 @@ #endif
/* + * Figure out if we are booting low or high. Flash and I2C can boot either + * low or high, the BCSR is hardwired to boot high. + */ +#if (TEXT_BASE != 0xFFF00000) /* Boot low (flash HRCW) */ +# define BOOT_MEMORY_SPACE HRCWH_FROM_0X00000100 +#else +# define BOOT_MEMORY_SPACE HRCWH_FROM_0XFFF00100 +#endif + +/* * Hardware Reset Configuration Word */ #define CFG_HRCW_LOW (\ @@ -65,7 +75,7 @@ HRCWH_PCI1_ARBITER_DISABLE |\ HRCWH_PCICKDRV_DISABLE |\ HRCWH_CORE_ENABLE |\ - HRCWH_FROM_0XFFF00100 |\ + BOOT_MEMORY_SPACE |\ HRCWH_BOOTSEQ_DISABLE |\ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT) @@ -75,7 +85,7 @@ HRCWH_PCI1_ARBITER_ENABLE |\ HRCWH_PCICKDRV_ENABLE |\ HRCWH_CORE_ENABLE |\ - HRCWH_FROM_0X00000100 |\ + BOOT_MEMORY_SPACE |\ HRCWH_BOOTSEQ_DISABLE |\ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT)
On Thu, 2006-11-30 at 22:45 -0500, Jerry Van Baren wrote:
Hi Dave Liu,
The 8360EMDS u-boot is booting at low memory in default now. You can change it for high memory.
Thanks Wolfgang and Stefan for pulling them.
Hi Dave Liu,
Yes, if the board is not configured as a PCI slave. I forgot to ask, is that a hardware restriction or is it OK to "boot low" as a PCI slave (mostly curious)?
In defense of the patch, it is nice to be able to easily configure u-boot to boot high or low. The Makefile configuration trick is really handy and is how several boards handle it.
Thanks, gvb
On Nov 30, 2006, at 10:26 PM, Jerry Van Baren wrote:
Hi Dave Liu,
You can boot low as a PCI slave, no HW restriction.
- k
Dave Liu
Jerry Van Baren
Kumar Gala
