[U-Boot] [PATCH] ppc4xx: Merge Neo board port: CFG_ -> CONFIG_SYS_
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/neo.h | 86 ++++++++++++++++++++++++------------------------ 1 files changed, 43 insertions(+), 43 deletions(-)
diff --git a/include/configs/neo.h b/include/configs/neo.h index a150cdd..f275c7b 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -83,34 +83,34 @@ #define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */
/* SDRAM timings used in datasheet */ -#define CFG_SDRAM_CL 3 /* CAS latency */ -#define CFG_SDRAM_tRP 20 /* PRECHARGE command period */ -#define CFG_SDRAM_tRC 66 /* ACTIVE-to-ACTIVE command period */ -#define CFG_SDRAM_tRCD 20 /* ACTIVE-to-READ delay */ -#define CFG_SDRAM_tRFC 66 /* Auto refresh period */ +#define CONFIG_SYS_SDRAM_CL 3 /* CAS latency */ +#define CONFIG_SYS_SDRAM_tRP 20 /* PRECHARGE command period */ +#define CONFIG_SYS_SDRAM_tRC 66 /* ACTIVE-to-ACTIVE command period */ +#define CONFIG_SYS_SDRAM_tRCD 20 /* ACTIVE-to-READ delay */ +#define CONFIG_SYS_SDRAM_tRFC 66 /* Auto refresh period */
/* - * If CFG_EXT_SERIAL_CLOCK, then the UART divisor is 1. - * If CFG_405_UART_ERRATA_59, then UART divisor is 31. - * Otherwise, UART divisor is determined by CPU Clock and CFG_BASE_BAUD value. + * If CONFIG_SYS_EXT_SERIAL_CLOCK, then the UART divisor is 1. + * If CONFIG_SYS_405_UART_ERRATA_59, then UART divisor is 31. + * Otherwise, UART divisor is determined by CPU Clock and CONFIG_SYS_BASE_BAUD value. * The Linux BASE_BAUD define should match this configuration. * baseBaud = cpuClock/(uartDivisor*16) - * If CFG_405_UART_ERRATA_59 and 200MHz CPU clock, + * If CONFIG_SYS_405_UART_ERRATA_59 and 200MHz CPU clock, * set Linux BASE_BAUD to 403200. */ #undef CONFIG_SERIAL_SOFTWARE_FIFO -#undef CFG_EXT_SERIAL_CLOCK /* external serial clock */ -#undef CFG_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ -#define CFG_BASE_BAUD 691200 +#undef CONFIG_SYS_EXT_SERIAL_CLOCK /* external serial clock */ +#undef CONFIG_SYS_405_UART_ERRATA_59 /* 405GP/CR Rev. D silicon */ +#define CONFIG_SYS_BASE_BAUD 691200
/* * I2C stuff */ -#define CFG_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SPEED 100000 /* I2C speed and slave address */
/* RTC */ #define CONFIG_RTC_DS1337 -#define CFG_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68
/* Temp sensor/hwmon/dtt */ #define CONFIG_DTT_LM63 1 /* National LM63 */ @@ -122,27 +122,27 @@ /* * FLASH organization */ -#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CONFIG_SYS_FLASH_CFI /* The flash is CFI compatible */ #define CONFIG_FLASH_CFI_DRIVER /* Use common CFI driver */
-#define CFG_FLASH_BASE 0xFC000000 -#define CFG_FLASH_BANKS_LIST { CFG_FLASH_BASE } +#define CONFIG_SYS_FLASH_BASE 0xFC000000 +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE }
-#define CFG_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CFG_MAX_FLASH_SECT 512 /* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max number of sectors on one chip */
-#define CFG_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CFG_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
-#define CFG_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ -#define CFG_FLASH_PROTECTION 1 /* use hardware flash protection */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* use buffered writes (20x faster) */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* use hardware flash protection */
-#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ -#define CFG_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CONFIG_SYS_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */
#ifdef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ -#define CONFIG_ENV_ADDR ((-CFG_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_ADDR ((-CONFIG_SYS_MONITOR_LEN)-CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */
/* Address and size of Redundant Environment Sector */ @@ -153,7 +153,7 @@ /* * PPC405 GPIO Configuration */ -#define CFG_4xx_GPIO_TABLE { /* GPIO Alternate1 */ \ +#define CONFIG_SYS_4xx_GPIO_TABLE { /* GPIO Alternate1 */ \ { \ /* GPIO Core 0 */ \ { GPIO_BASE, GPIO_OUT, GPIO_ALT1, GPIO_OUT_NO_CHG }, /* GPIO0 PerBLast */ \ @@ -195,37 +195,37 @@ * Definitions for initial stack pointer and data area (in data cache) */ /* use on chip memory (OCM) for temperary stack until sdram is tested */ -#define CFG_TEMP_STACK_OCM 1 +#define CONFIG_SYS_TEMP_STACK_OCM 1
/* On Chip Memory location */ -#define CFG_OCM_DATA_ADDR 0xF8000000 -#define CFG_OCM_DATA_SIZE 0x1000 -#define CFG_INIT_RAM_ADDR CFG_OCM_DATA_ADDR /* inside of SDRAM */ -#define CFG_INIT_RAM_END CFG_OCM_DATA_SIZE /* End of used area in RAM */ +#define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 +#define CONFIG_SYS_OCM_DATA_SIZE 0x1000 +#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* inside of SDRAM */ +#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area in RAM */
-#define CFG_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) -#define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* * External Bus Controller (EBC) Setup */
/* Memory Bank 0 (NOR-FLASH) initialization */ -#define CFG_EBC_PB0AP 0x92015480 -#define CFG_EBC_PB0CR 0xFC0DA000 /* BAS=0xFC0,BS=64MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB0AP 0x92015480 +#define CONFIG_SYS_EBC_PB0CR 0xFC0DA000 /* BAS=0xFC0,BS=64MB,BU=R/W,BW=16bit */
/* Memory Bank 1 (NVRAM) initialization */ -#define CFG_EBC_PB1AP 0x92015480 -#define CFG_EBC_PB1CR 0xFB85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=8bit */ +#define CONFIG_SYS_EBC_PB1AP 0x92015480 +#define CONFIG_SYS_EBC_PB1CR 0xFB85A000 /* BAS=0xFF8,BS=4MB,BU=R/W,BW=8bit */
/* Memory Bank 2 (FPGA) initialization */ #define CONFIG_FPGA_BASE 0x7f100000 -#define CFG_EBC_PB2AP 0x92015480 -#define CFG_EBC_PB2CR 0x7f11a000 /* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB2AP 0x92015480 +#define CONFIG_SYS_EBC_PB2CR 0x7f11a000 /* BAS=0x7f1,BS=1MB,BU=R/W,BW=16bit */
/* Memory Bank 3 (Latches) initialization */ -#define CFG_EBC_PB3AP 0x92015480 -#define CFG_EBC_PB3CR 0x7f21a000 /* BAS=0x7f2,BS=1MB,BU=R/W,BW=16bit */ +#define CONFIG_SYS_EBC_PB3AP 0x92015480 +#define CONFIG_SYS_EBC_PB3CR 0x7f21a000 /* BAS=0x7f2,BS=1MB,BU=R/W,BW=16bit */
#endif /* __CONFIG_H */
Dear Stefan Roese,
Oops? We don't have any such file in the tree.
Stefan Roese
