[U-Boot] [PATCH] USB storage cleanup patch
Cleanup usb storage
Signed-off-by: Michael Trimarchi trimarchimichael@yahoo.it
--- diff --git a/common/usb_storage.c b/common/usb_storage.c index 94f659f..973d82f 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -63,9 +63,9 @@ #undef BBB_XPORT_TRACE
#ifdef USB_STOR_DEBUG -#define USB_STOR_PRINTF(fmt,args...) printf (fmt ,##args) +#define USB_STOR_PRINTF(fmt, args...) printf(fmt , ##args) #else -#define USB_STOR_PRINTF(fmt,args...) +#define USB_STOR_PRINTF(fmt, args...) #endif
#include <scsi.h> @@ -110,7 +110,7 @@ typedef struct { __u8 CBWCDB[CBWCDBLENGTH]; } umass_bbb_cbw_t; #define UMASS_BBB_CBW_SIZE 31 -static __u32 CBWTag = 0; +static __u32 CBWTag;
/* Command Status Wrapper */ typedef struct { @@ -126,34 +126,35 @@ typedef struct { #define UMASS_BBB_CSW_SIZE 13
#define USB_MAX_STOR_DEV 5 -static int usb_max_devs = 0; /* number of highest available usb device */ +static int usb_max_devs; /* number of highest available usb device */
static block_dev_desc_t usb_dev_desc[USB_MAX_STOR_DEV];
struct us_data; -typedef int (*trans_cmnd)(ccb*, struct us_data*); -typedef int (*trans_reset)(struct us_data*); +typedef int (*trans_cmnd)(ccb *cb, struct us_data *data); +typedef int (*trans_reset)(struct us_data *data);
struct us_data { - struct usb_device *pusb_dev; /* this usb_device */ - unsigned int flags; /* from filter initially */ - unsigned char ifnum; /* interface number */ - unsigned char ep_in; /* in endpoint */ - unsigned char ep_out; /* out ....... */ - unsigned char ep_int; /* interrupt . */ - unsigned char subclass; /* as in overview */ - unsigned char protocol; /* .............. */ - unsigned char attention_done; /* force attn on first cmd */ - unsigned short ip_data; /* interrupt data */ - int action; /* what to do */ - int ip_wanted; /* needed */ - int *irq_handle; /* for USB int requests */ - unsigned int irqpipe; /* pipe for release_irq */ - unsigned char irqmaxp; /* max packed for irq Pipe */ - unsigned char irqinterval; /* Intervall for IRQ Pipe */ - ccb *srb; /* current srb */ - trans_reset transport_reset; /* reset routine */ - trans_cmnd transport; /* transport routine */ + struct usb_device *pusb_dev; /* this usb_device */ + + unsigned int flags; /* from filter initially */ + unsigned char ifnum; /* interface number */ + unsigned char ep_in; /* in endpoint */ + unsigned char ep_out; /* out ....... */ + unsigned char ep_int; /* interrupt . */ + unsigned char subclass; /* as in overview */ + unsigned char protocol; /* .............. */ + unsigned char attention_done; /* force attn on first cmd */ + unsigned short ip_data; /* interrupt data */ + int action; /* what to do */ + int ip_wanted; /* needed */ + int *irq_handle; /* for USB int requests */ + unsigned int irqpipe; /* pipe for release_irq */ + unsigned char irqmaxp; /* max packed for irq Pipe */ + unsigned char irqinterval; /* Intervall for IRQ Pipe */ + ccb *srb; /* current srb */ + trans_reset transport_reset; /* reset routine */ + trans_cmnd transport; /* transport routine */ };
static struct us_data usb_stor[USB_MAX_STOR_DEV]; @@ -163,10 +164,12 @@ static struct us_data usb_stor[USB_MAX_STOR_DEV]; #define USB_STOR_TRANSPORT_FAILED -1 #define USB_STOR_TRANSPORT_ERROR -2
- -int usb_stor_get_info(struct usb_device *dev, struct us_data *us, block_dev_desc_t *dev_desc); -int usb_storage_probe(struct usb_device *dev, unsigned int ifnum,struct us_data *ss); -unsigned long usb_stor_read(int device, unsigned long blknr, unsigned long blkcnt, void *buffer); +int usb_stor_get_info(struct usb_device *dev, struct us_data *us, + block_dev_desc_t *dev_desc); +int usb_storage_probe(struct usb_device *dev, unsigned int ifnum, + struct us_data *ss); +unsigned long usb_stor_read(int device, unsigned long blknr, + unsigned long blkcnt, void *buffer); struct usb_device * usb_get_dev_index(int index); void uhci_show_temp_int_td(void);
@@ -181,7 +184,7 @@ void usb_show_progress(void) printf("."); }
-/********************************************************************************* +/******************************************************************************* * show info on storage devices; 'usb start/init' must be invoked earlier * as we only retrieve structures populated during devices initialization */ @@ -191,7 +194,7 @@ int usb_stor_info(void)
if (usb_max_devs > 0) { for (i = 0; i < usb_max_devs; i++) { - printf (" Device %d: ", i); + printf(" Device %d: ", i); dev_print(&usb_dev_desc[i]); } return 0; @@ -201,7 +204,7 @@ int usb_stor_info(void) return 1; }
-/********************************************************************************* +/******************************************************************************* * scan the usb and reports device info * to the user if mode = 1 * returns current device or -1 if no @@ -214,67 +217,69 @@ int usb_stor_scan(int mode) /* GJ */ memset(usb_stor_buf, 0, sizeof(usb_stor_buf));
- if(mode==1) { + if (mode == 1) printf(" scanning bus for storage devices... "); - } + usb_disable_asynch(1); /* asynch transfer not allowed */
- for(i=0;i<USB_MAX_STOR_DEV;i++) { - memset(&usb_dev_desc[i],0,sizeof(block_dev_desc_t)); - usb_dev_desc[i].target=0xff; - usb_dev_desc[i].if_type=IF_TYPE_USB; - usb_dev_desc[i].dev=i; - usb_dev_desc[i].part_type=PART_TYPE_UNKNOWN; - usb_dev_desc[i].block_read=usb_stor_read; + for (i = 0; i < USB_MAX_STOR_DEV; i++) { + memset(&usb_dev_desc[i], 0, sizeof(block_dev_desc_t)); + usb_dev_desc[i].target = 0xff; + usb_dev_desc[i].if_type = IF_TYPE_USB; + usb_dev_desc[i].dev = i; + usb_dev_desc[i].part_type = PART_TYPE_UNKNOWN; + usb_dev_desc[i].block_read = usb_stor_read; }
- usb_max_devs=0; - for(i=0;i<USB_MAX_DEVICE;i++) { - dev=usb_get_dev_index(i); /* get device */ - USB_STOR_PRINTF("i=%d\n",i); - if(dev==NULL) { + usb_max_devs = 0; + for (i = 0; i < USB_MAX_DEVICE; i++) { + dev = usb_get_dev_index(i); /* get device */ + USB_STOR_PRINTF("i=%d\n", i); + if (dev == NULL) break; /* no more devices avaiable */ - } - if(usb_storage_probe(dev,0,&usb_stor[usb_max_devs])) { /* ok, it is a storage devices */ - /* get info and fill it in */ - if(usb_stor_get_info(dev, &usb_stor[usb_max_devs], &usb_dev_desc[usb_max_devs])) + + if (usb_storage_probe(dev, 0, &usb_stor[usb_max_devs])) { + /* ok, it is a storage devices + * get info and fill it in + */ + if (usb_stor_get_info(dev, &usb_stor[usb_max_devs], + &usb_dev_desc[usb_max_devs])) usb_max_devs++; - } /* if storage device */ - if(usb_max_devs==USB_MAX_STOR_DEV) { - printf("max USB Storage Device reached: %d stopping\n",usb_max_devs); + } + /* if storage device */ + if (usb_max_devs == USB_MAX_STOR_DEV) { + printf("max USB Storage Device reached: %d stopping\n", + usb_max_devs); break; } } /* for */
usb_disable_asynch(0); /* asynch transfer allowed */ printf("%d Storage Device(s) found\n", usb_max_devs); - if(usb_max_devs>0) + if (usb_max_devs > 0) return 0; - else - return-1; + return -1; }
static int usb_stor_irq(struct usb_device *dev) { struct us_data *us; - us=(struct us_data *)dev->privptr; + us = (struct us_data *)dev->privptr;
- if(us->ip_wanted) { - us->ip_wanted=0; - } + if (us->ip_wanted) + us->ip_wanted = 0; return 0; }
-static void usb_show_srb(ccb * pccb) +static void usb_show_srb(ccb *pccb) { int i; - printf("SRB: len %d datalen 0x%lX\n ",pccb->cmdlen,pccb->datalen); - for(i=0;i<12;i++) { - printf("%02X ",pccb->cmd[i]); - } + printf("SRB: len %d datalen 0x%lX\n ", pccb->cmdlen, pccb->datalen); + for (i = 0; i < 12; i++) + printf("%02X ", pccb->cmd[i]); printf("\n"); }
@@ -322,11 +327,14 @@ static int us_one_transfer(struct us_data *us, int pipe, char *buf, int length) USB_STOR_PRINTF("Bulk xfer 0x%x(%d) try #%d\n", (unsigned int)buf, this_xfer, 11 - maxtry); result = usb_bulk_msg(us->pusb_dev, pipe, buf, - this_xfer, &partial, USB_CNTL_TIMEOUT*5); + this_xfer, &partial, + USB_CNTL_TIMEOUT * 5); USB_STOR_PRINTF("bulk_msg returned %d xferred %d/%d\n", result, partial, this_xfer); - if(us->pusb_dev->status!=0) { - /* if we stall, we need to clear it before we go on */ + if (us->pusb_dev->status != 0) { + /* if we stall, we need to clear it before + * we go on + */ #ifdef USB_STOR_DEBUG display_int_status(us->pusb_dev->status); #endif @@ -334,9 +342,9 @@ static int us_one_transfer(struct us_data *us, int pipe, char *buf, int length) USB_STOR_PRINTF("stalled ->clearing endpoint halt for pipe 0x%x\n", pipe); stat = us->pusb_dev->status; usb_clear_halt(us->pusb_dev, pipe); - us->pusb_dev->status=stat; - if(this_xfer == partial) { - USB_STOR_PRINTF("bulk transferred with error %X, but data ok\n",us->pusb_dev->status); + us->pusb_dev->status = stat; + if (this_xfer == partial) { + USB_STOR_PRINTF("bulk transferred with error %X, but data ok\n", us->pusb_dev->status); return 0; } else @@ -346,12 +354,15 @@ static int us_one_transfer(struct us_data *us, int pipe, char *buf, int length) USB_STOR_PRINTF("Device NAKed bulk_msg\n"); return result; } - if(this_xfer == partial) { - USB_STOR_PRINTF("bulk transferred with error %d, but data ok\n",us->pusb_dev->status); + USB_STOR_PRINTF("bulk transferred with error"); + if (this_xfer == partial) { + USB_STOR_PRINTF(" %d, but data ok\n", + us->pusb_dev->status); return 0; } /* if our try counter reaches 0, bail out */ - USB_STOR_PRINTF("bulk transferred with error %d, data %d\n",us->pusb_dev->status,partial); + USB_STOR_PRINTF(" %d, data %d\n", + us->pusb_dev->status, partial); if (!maxtry--) return result; } @@ -359,7 +370,7 @@ static int us_one_transfer(struct us_data *us, int pipe, char *buf, int length) this_xfer -= partial; buf += partial; /* continue until this transfer is done */ - } while ( this_xfer ); + } while (this_xfer); }
/* if we get here, we're done and successful */ @@ -386,29 +397,33 @@ static int usb_stor_BBB_reset(struct us_data *us) * This comment stolen from FreeBSD's /sys/dev/usb/umass.c. */ USB_STOR_PRINTF("BBB_reset\n"); - result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev,0), - US_BBB_RESET, USB_TYPE_CLASS | USB_RECIP_INTERFACE, - 0, us->ifnum, 0, 0, USB_CNTL_TIMEOUT*5); + result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev, 0), + US_BBB_RESET, + USB_TYPE_CLASS | USB_RECIP_INTERFACE, + 0, us->ifnum, 0, 0, USB_CNTL_TIMEOUT * 5);
- if((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) - { + if ((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) { USB_STOR_PRINTF("RESET:stall\n"); return -1; }
/* long wait for reset */ wait_ms(150); - USB_STOR_PRINTF("BBB_reset result %d: status %X reset\n",result,us->pusb_dev->status); + USB_STOR_PRINTF("BBB_reset result %d: status %X reset\n", result, + us->pusb_dev->status); pipe = usb_rcvbulkpipe(us->pusb_dev, us->ep_in); result = usb_clear_halt(us->pusb_dev, pipe); /* long wait for reset */ wait_ms(150); - USB_STOR_PRINTF("BBB_reset result %d: status %X clearing IN endpoint\n",result,us->pusb_dev->status); + USB_STOR_PRINTF("BBB_reset result %d: status %X clearing IN endpoint\n", + result, us->pusb_dev->status); /* long wait for reset */ pipe = usb_sndbulkpipe(us->pusb_dev, us->ep_out); result = usb_clear_halt(us->pusb_dev, pipe); wait_ms(150); - USB_STOR_PRINTF("BBB_reset result %d: status %X clearing OUT endpoint\n",result,us->pusb_dev->status); + USB_STOR_PRINTF("BBB_reset result %d: status %X" + " clearing OUT endpoint\n", result, + us->pusb_dev->status); USB_STOR_PRINTF("BBB_reset done\n"); return 0; } @@ -423,16 +438,20 @@ static int usb_stor_CB_reset(struct us_data *us) int result;
USB_STOR_PRINTF("CB_reset\n"); - memset(cmd, 0xFF, sizeof(cmd)); + memset(cmd, 0xff, sizeof(cmd)); cmd[0] = SCSI_SEND_DIAG; cmd[1] = 4; - result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev,0), - US_CBI_ADSC, USB_TYPE_CLASS | USB_RECIP_INTERFACE, - 0, us->ifnum, cmd, sizeof(cmd), USB_CNTL_TIMEOUT*5); + result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev, 0), + US_CBI_ADSC, + USB_TYPE_CLASS | USB_RECIP_INTERFACE, + 0, us->ifnum, cmd, sizeof(cmd), + USB_CNTL_TIMEOUT * 5);
/* long wait for reset */ wait_ms(1500); - USB_STOR_PRINTF("CB_reset result %d: status %X clearing endpoint halt\n",result,us->pusb_dev->status); + USB_STOR_PRINTF("CB_reset result %d: status %X" + " clearing endpoint halt\n", result, + us->pusb_dev->status); usb_clear_halt(us->pusb_dev, usb_rcvbulkpipe(us->pusb_dev, us->ep_in)); usb_clear_halt(us->pusb_dev, usb_rcvbulkpipe(us->pusb_dev, us->ep_out));
@@ -455,9 +474,11 @@ int usb_stor_BBB_comdat(ccb *srb, struct us_data *us) dir_in = US_DIRECTION(srb->cmd[0]);
#ifdef BBB_COMDAT_TRACE - printf("dir %d lun %d cmdlen %d cmd %p datalen %d pdata %p\n", dir_in, srb->lun, srb->cmdlen, srb->cmd, srb->datalen, srb->pdata); + printf("dir %d lun %d cmdlen %d cmd %p datalen %d pdata %p\n", + dir_in, srb->lun, srb->cmdlen, srb->cmd, srb->datalen, + srb->pdata); if (srb->cmdlen) { - for(result = 0;result < srb->cmdlen;result++) + for (result = 0; result < srb->cmdlen; result++) printf("cmd[%d] %#x ", result, srb->cmd[result]); printf("\n"); } @@ -474,13 +495,14 @@ int usb_stor_BBB_comdat(ccb *srb, struct us_data *us) cbw.dCBWSignature = cpu_to_le32(CBWSIGNATURE); cbw.dCBWTag = cpu_to_le32(CBWTag++); cbw.dCBWDataTransferLength = cpu_to_le32(srb->datalen); - cbw.bCBWFlags = (dir_in? CBWFLAGS_IN : CBWFLAGS_OUT); + cbw.bCBWFlags = (dir_in ? CBWFLAGS_IN : CBWFLAGS_OUT); cbw.bCBWLUN = srb->lun; cbw.bCDBLength = srb->cmdlen; /* copy the command data into the CBW command data buffer */ /* DST SRC LEN!!! */ memcpy(cbw.CBWCDB, srb->cmd, srb->cmdlen); - result = usb_bulk_msg(us->pusb_dev, pipe, &cbw, UMASS_BBB_CBW_SIZE, &actlen, USB_CNTL_TIMEOUT*5); + result = usb_bulk_msg(us->pusb_dev, pipe, &cbw, UMASS_BBB_CBW_SIZE, + &actlen, USB_CNTL_TIMEOUT * 5); if (result < 0) USB_STOR_PRINTF("usb_stor_BBB_comdat:usb_bulk_msg error\n"); return result; @@ -492,46 +514,61 @@ int usb_stor_BBB_comdat(ccb *srb, struct us_data *us) int usb_stor_CB_comdat(ccb *srb, struct us_data *us) { int result = 0; - int dir_in,retry; + int dir_in, retry; unsigned int pipe; unsigned long status;
- retry=5; - dir_in=US_DIRECTION(srb->cmd[0]); + retry = 5; + dir_in = US_DIRECTION(srb->cmd[0]);
- if(dir_in) - pipe=usb_rcvbulkpipe(us->pusb_dev, us->ep_in); - else - pipe=usb_sndbulkpipe(us->pusb_dev, us->ep_out); - while(retry--) { - USB_STOR_PRINTF("CBI gets a command: Try %d\n",5-retry); + if (dir_in) + pipe = usb_rcvbulkpipe(us->pusb_dev, us->ep_in); + else + pipe = usb_sndbulkpipe(us->pusb_dev, us->ep_out); + + while (retry--) { + USB_STOR_PRINTF("CBI gets a command: Try %d\n", 5 - retry); #ifdef USB_STOR_DEBUG usb_show_srb(srb); #endif /* let's send the command via the control pipe */ - result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev,0), - US_CBI_ADSC, USB_TYPE_CLASS | USB_RECIP_INTERFACE, + result = usb_control_msg(us->pusb_dev, + usb_sndctrlpipe(us->pusb_dev , 0), + US_CBI_ADSC, + USB_TYPE_CLASS | USB_RECIP_INTERFACE, 0, us->ifnum, - srb->cmd, srb->cmdlen, USB_CNTL_TIMEOUT*5); - USB_STOR_PRINTF("CB_transport: control msg returned %d, status %X\n",result,us->pusb_dev->status); + srb->cmd, srb->cmdlen, + USB_CNTL_TIMEOUT * 5); + USB_STOR_PRINTF("CB_transport: control msg returned %d," + " status %X\n", result, us->pusb_dev->status); /* check the return code for the command */ if (result < 0) { - if(us->pusb_dev->status & USB_ST_STALLED) { - status=us->pusb_dev->status; - USB_STOR_PRINTF(" stall during command found, clear pipe\n"); - usb_clear_halt(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev,0)); - us->pusb_dev->status=status; + if (us->pusb_dev->status & USB_ST_STALLED) { + status = us->pusb_dev->status; + USB_STOR_PRINTF(" stall during command found," + " clear pipe\n"); + usb_clear_halt(us->pusb_dev, + usb_sndctrlpipe(us->pusb_dev, 0)); + us->pusb_dev->status = status; } - USB_STOR_PRINTF(" error during command %02X Stat = %X\n",srb->cmd[0],us->pusb_dev->status); + USB_STOR_PRINTF(" error during command %02X" + " Stat = %X\n", srb->cmd[0], + us->pusb_dev->status); return result; } /* transfer the data payload for this command, if one exists*/
- USB_STOR_PRINTF("CB_transport: control msg returned %d, direction is %s to go 0x%lx\n",result,dir_in ? "IN" : "OUT",srb->datalen); + USB_STOR_PRINTF("CB_transport: control msg returned %d," + " direction is %s to go 0x%lx\n", result, + dir_in ? "IN" : "OUT", srb->datalen); if (srb->datalen) { - result = us_one_transfer(us, pipe, (char *)srb->pdata,srb->datalen); - USB_STOR_PRINTF("CBI attempted to transfer data, result is %d status %lX, len %d\n", result,us->pusb_dev->status,us->pusb_dev->act_len); - if(!(us->pusb_dev->status & USB_ST_NAK_REC)) + result = us_one_transfer(us, pipe, (char *)srb->pdata, + srb->datalen); + USB_STOR_PRINTF("CBI attempted to transfer data," + " result is %d status %lX, len %d\n", + result, us->pusb_dev->status, + us->pusb_dev->act_len); + if (!(us->pusb_dev->status & USB_ST_NAK_REC)) break; } /* if (srb->datalen) */ else @@ -543,21 +580,21 @@ int usb_stor_CB_comdat(ccb *srb, struct us_data *us) }
-int usb_stor_CBI_get_status (ccb * srb, struct us_data *us) +int usb_stor_CBI_get_status(ccb *srb, struct us_data *us) { int timeout;
us->ip_wanted = 1; - submit_int_msg (us->pusb_dev, us->irqpipe, + submit_int_msg(us->pusb_dev, us->irqpipe, (void *) &us->ip_data, us->irqmaxp, us->irqinterval); timeout = 1000; while (timeout--) { if ((volatile int *) us->ip_wanted == 0) break; - wait_ms (10); + wait_ms(10); } if (us->ip_wanted) { - printf (" Did not get interrupt on CBI\n"); + printf(" Did not get interrupt on CBI\n"); us->ip_wanted = 0; return USB_STOR_TRANSPORT_ERROR; } @@ -596,9 +633,9 @@ int usb_stor_BBB_clear_endpt_stall(struct us_data *us, __u8 endpt) int result;
/* ENDPOINT_HALT = 0, so set value to 0 */ - result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev,0), + result = usb_control_msg(us->pusb_dev, usb_sndctrlpipe(us->pusb_dev, 0), USB_REQ_CLEAR_FEATURE, USB_RECIP_ENDPOINT, - 0, endpt, 0, 0, USB_CNTL_TIMEOUT*5); + 0, endpt, 0, 0, USB_CNTL_TIMEOUT * 5); return result; }
@@ -638,12 +675,14 @@ int usb_stor_BBB_transport(ccb *srb, struct us_data *us) pipe = pipein; else pipe = pipeout; - result = usb_bulk_msg(us->pusb_dev, pipe, srb->pdata, srb->datalen, &data_actlen, USB_CNTL_TIMEOUT*5); + result = usb_bulk_msg(us->pusb_dev, pipe, srb->pdata, srb->datalen, + &data_actlen, USB_CNTL_TIMEOUT * 5); /* special handling of STALL in DATA phase */ - if((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) { + if ((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) { USB_STOR_PRINTF("DATA:stall\n"); /* clear the STALL on the endpoint */ - result = usb_stor_BBB_clear_endpt_stall(us, dir_in? us->ep_in : us->ep_out); + result = usb_stor_BBB_clear_endpt_stall(us, + dir_in ? us->ep_in : us->ep_out); if (result >= 0) /* continue on to STATUS phase */ goto st; @@ -660,15 +699,16 @@ int usb_stor_BBB_transport(ccb *srb, struct us_data *us) printf("\n"); #endif /* STATUS phase + error handling */ - st: +st: retry = 0; - again: +again: USB_STOR_PRINTF("STATUS phase\n"); result = usb_bulk_msg(us->pusb_dev, pipein, &csw, UMASS_BBB_CSW_SIZE, &actlen, USB_CNTL_TIMEOUT*5);
/* special handling of STALL in STATUS phase */ - if((result < 0) && (retry < 1) && (us->pusb_dev->status & USB_ST_STALLED)) { + if ((result < 0) && (retry < 1) && + (us->pusb_dev->status & USB_ST_STALLED)) { USB_STOR_PRINTF("STATUS:stall\n"); /* clear the STALL on the endpoint */ result = usb_stor_BBB_clear_endpt_stall(us, us->ep_in); @@ -722,32 +762,33 @@ int usb_stor_BBB_transport(ccb *srb, struct us_data *us)
int usb_stor_CB_transport(ccb *srb, struct us_data *us) { - int result,status; + int result, status; ccb *psrb; ccb reqsrb; - int retry,notready; + int retry, notready;
psrb = &reqsrb; - status=USB_STOR_TRANSPORT_GOOD; - retry=0; - notready=0; + status = USB_STOR_TRANSPORT_GOOD; + retry = 0; + notready = 0; /* issue the command */ do_retry: - result=usb_stor_CB_comdat(srb,us); - USB_STOR_PRINTF("command / Data returned %d, status %X\n",result,us->pusb_dev->status); + result = usb_stor_CB_comdat(srb, us); + USB_STOR_PRINTF("command / Data returned %d, status %X\n", + result, us->pusb_dev->status); /* if this is an CBI Protocol, get IRQ */ - if(us->protocol==US_PR_CBI) { - status=usb_stor_CBI_get_status(srb,us); + if (us->protocol == US_PR_CBI) { + status = usb_stor_CBI_get_status(srb, us); /* if the status is error, report it */ - if(status==USB_STOR_TRANSPORT_ERROR) { + if (status == USB_STOR_TRANSPORT_ERROR) { USB_STOR_PRINTF(" USB CBI Command Error\n"); return status; } - srb->sense_buf[12]=(unsigned char)(us->ip_data>>8); - srb->sense_buf[13]=(unsigned char)(us->ip_data&0xff); - if(!us->ip_data) { - /* if the status is good, report it */ - if(status==USB_STOR_TRANSPORT_GOOD) { + srb->sense_buf[12] = (unsigned char)(us->ip_data >> 8); + srb->sense_buf[13] = (unsigned char)(us->ip_data & 0xff); + if (!us->ip_data) { + /* if the status is good, report it */ + if (status == USB_STOR_TRANSPORT_GOOD) { USB_STOR_PRINTF(" USB CBI Command Good\n"); return status; } @@ -755,51 +796,62 @@ do_retry: } /* do we have to issue an auto request? */ /* HERE we have to check the result */ - if((result<0) && !(us->pusb_dev->status & USB_ST_STALLED)) { - USB_STOR_PRINTF("ERROR %X\n",us->pusb_dev->status); + if ((result < 0) && !(us->pusb_dev->status & USB_ST_STALLED)) { + USB_STOR_PRINTF("ERROR %X\n", us->pusb_dev->status); us->transport_reset(us); return USB_STOR_TRANSPORT_ERROR; } - if((us->protocol==US_PR_CBI) && - ((srb->cmd[0]==SCSI_REQ_SENSE) || - (srb->cmd[0]==SCSI_INQUIRY))) { /* do not issue an autorequest after request sense */ + if ((us->protocol == US_PR_CBI) && + ((srb->cmd[0] == SCSI_REQ_SENSE) || + (srb->cmd[0] == SCSI_INQUIRY))) { + /* do not issue an autorequest after request sense */ USB_STOR_PRINTF("No auto request and good\n"); return USB_STOR_TRANSPORT_GOOD; } /* issue an request_sense */ - memset(&psrb->cmd[0],0,12); - psrb->cmd[0]=SCSI_REQ_SENSE; - psrb->cmd[1]=srb->lun<<5; - psrb->cmd[4]=18; - psrb->datalen=18; + memset(&psrb->cmd[0], 0, 12); + psrb->cmd[0] = SCSI_REQ_SENSE; + psrb->cmd[1] = srb->lun << 5; + psrb->cmd[4] = 18; + psrb->datalen = 18; psrb->pdata = &srb->sense_buf[0]; - psrb->cmdlen=12; + psrb->cmdlen = 12; /* issue the command */ - result=usb_stor_CB_comdat(psrb,us); - USB_STOR_PRINTF("auto request returned %d\n",result); + result = usb_stor_CB_comdat(psrb, us); + USB_STOR_PRINTF("auto request returned %d\n", result); /* if this is an CBI Protocol, get IRQ */ - if(us->protocol==US_PR_CBI) { - status=usb_stor_CBI_get_status(psrb,us); - } - if((result<0)&&!(us->pusb_dev->status & USB_ST_STALLED)) { - USB_STOR_PRINTF(" AUTO REQUEST ERROR %d\n",us->pusb_dev->status); + if (us->protocol == US_PR_CBI) + status = usb_stor_CBI_get_status(psrb, us); + + if ((result < 0) && !(us->pusb_dev->status & USB_ST_STALLED)) { + USB_STOR_PRINTF(" AUTO REQUEST ERROR %d\n", + us->pusb_dev->status); return USB_STOR_TRANSPORT_ERROR; } - USB_STOR_PRINTF("autorequest returned 0x%02X 0x%02X 0x%02X 0x%02X\n",srb->sense_buf[0],srb->sense_buf[2],srb->sense_buf[12],srb->sense_buf[13]); + USB_STOR_PRINTF("autorequest returned 0x%02X 0x%02X 0x%02X 0x%02X\n", + srb->sense_buf[0], srb->sense_buf[2], + srb->sense_buf[12], srb->sense_buf[13]); /* Check the auto request result */ - if((srb->sense_buf[2]==0) && - (srb->sense_buf[12]==0) && - (srb->sense_buf[13]==0)) /* ok, no sense */ + if ((srb->sense_buf[2] == 0) && + (srb->sense_buf[12] == 0) && + (srb->sense_buf[13] == 0)) { + /* ok, no sense */ return USB_STOR_TRANSPORT_GOOD; + } + /* Check the auto request result */ - switch(srb->sense_buf[2]) { - case 0x01: /* Recovered Error */ + switch (srb->sense_buf[2]) { + case 0x01: + /* Recovered Error */ return USB_STOR_TRANSPORT_GOOD; break; - case 0x02: /* Not Ready */ - if(notready++ > USB_TRANSPORT_NOT_READY_RETRY) { - printf("cmd 0x%02X returned 0x%02X 0x%02X 0x%02X 0x%02X (NOT READY)\n", - srb->cmd[0],srb->sense_buf[0],srb->sense_buf[2],srb->sense_buf[12],srb->sense_buf[13]); + case 0x02: + /* Not Ready */ + if (notready++ > USB_TRANSPORT_NOT_READY_RETRY) { + printf("cmd 0x%02X returned 0x%02X 0x%02X 0x%02X" + " 0x%02X (NOT READY)\n", srb->cmd[0], + srb->sense_buf[0], srb->sense_buf[2], + srb->sense_buf[12], srb->sense_buf[13]); return USB_STOR_TRANSPORT_FAILED; } else { wait_ms(100); @@ -807,113 +859,116 @@ do_retry: } break; default: - if(retry++ > USB_TRANSPORT_UNKNOWN_RETRY) { - printf("cmd 0x%02X returned 0x%02X 0x%02X 0x%02X 0x%02X\n", - srb->cmd[0],srb->sense_buf[0],srb->sense_buf[2],srb->sense_buf[12],srb->sense_buf[13]); + if (retry++ > USB_TRANSPORT_UNKNOWN_RETRY) { + printf("cmd 0x%02X returned 0x%02X 0x%02X 0x%02X" + " 0x%02X\n", srb->cmd[0], srb->sense_buf[0], + srb->sense_buf[2], srb->sense_buf[12], + srb->sense_buf[13]); return USB_STOR_TRANSPORT_FAILED; - } else { + } else goto do_retry; - } break; } return USB_STOR_TRANSPORT_FAILED; }
-static int usb_inquiry(ccb *srb,struct us_data *ss) +static int usb_inquiry(ccb *srb, struct us_data *ss) { - int retry,i; - retry=5; + int retry, i; + retry = 5; do { - memset(&srb->cmd[0],0,12); - srb->cmd[0]=SCSI_INQUIRY; - srb->cmd[1]=srb->lun<<5; - srb->cmd[4]=36; - srb->datalen=36; - srb->cmdlen=12; - i=ss->transport(srb,ss); - USB_STOR_PRINTF("inquiry returns %d\n",i); - if(i==0) + memset(&srb->cmd[0], 0, 12); + srb->cmd[0] = SCSI_INQUIRY; + srb->cmd[1] = srb->lun<<5; + srb->cmd[4] = 36; + srb->datalen = 36; + srb->cmdlen = 12; + i = ss->transport(srb, ss); + USB_STOR_PRINTF("inquiry returns %d\n", i); + if (i == 0) break; - } while(retry--); + } while (retry--);
- if(!retry) { + if (!retry) { printf("error in inquiry\n"); return -1; } return 0; }
-static int usb_request_sense(ccb *srb,struct us_data *ss) +static int usb_request_sense(ccb *srb, struct us_data *ss) { char *ptr;
- ptr=(char *)srb->pdata; - memset(&srb->cmd[0],0,12); - srb->cmd[0]=SCSI_REQ_SENSE; - srb->cmd[1]=srb->lun<<5; - srb->cmd[4]=18; - srb->datalen=18; + ptr = (char *)srb->pdata; + memset(&srb->cmd[0], 0, 12); + srb->cmd[0] = SCSI_REQ_SENSE; + srb->cmd[1] = srb->lun << 5; + srb->cmd[4] = 18; + srb->datalen = 18; srb->pdata = &srb->sense_buf[0]; - srb->cmdlen=12; - ss->transport(srb,ss); - USB_STOR_PRINTF("Request Sense returned %02X %02X %02X\n",srb->sense_buf[2],srb->sense_buf[12],srb->sense_buf[13]); - srb->pdata=(uchar *)ptr; + srb->cmdlen = 12; + ss->transport(srb, ss); + USB_STOR_PRINTF("Request Sense returned %02X %02X %02X\n", + srb->sense_buf[2], srb->sense_buf[12], + srb->sense_buf[13]); + srb->pdata = (uchar *)ptr; return 0; }
-static int usb_test_unit_ready(ccb *srb,struct us_data *ss) +static int usb_test_unit_ready(ccb *srb, struct us_data *ss) { int retries = 10;
do { - memset(&srb->cmd[0],0,12); - srb->cmd[0]=SCSI_TST_U_RDY; - srb->cmd[1]=srb->lun<<5; - srb->datalen=0; - srb->cmdlen=12; - if(ss->transport(srb,ss)==USB_STOR_TRANSPORT_GOOD) { + memset(&srb->cmd[0], 0, 12); + srb->cmd[0] = SCSI_TST_U_RDY; + srb->cmd[1] = srb->lun << 5; + srb->datalen = 0; + srb->cmdlen = 12; + if (ss->transport(srb, ss) == USB_STOR_TRANSPORT_GOOD) return 0; - } - usb_request_sense (srb, ss); - wait_ms (100); - } while(retries--); + usb_request_sense(srb, ss); + wait_ms(100); + } while (retries--);
return -1; }
-static int usb_read_capacity(ccb *srb,struct us_data *ss) +static int usb_read_capacity(ccb *srb, struct us_data *ss) { int retry; - retry = 3; /* retries */ + /* XXX retries */ + retry = 3; do { - memset(&srb->cmd[0],0,12); - srb->cmd[0]=SCSI_RD_CAPAC; - srb->cmd[1]=srb->lun<<5; - srb->datalen=8; - srb->cmdlen=12; - if(ss->transport(srb,ss)==USB_STOR_TRANSPORT_GOOD) { + memset(&srb->cmd[0], 0, 12); + srb->cmd[0] = SCSI_RD_CAPAC; + srb->cmd[1] = srb->lun << 5; + srb->datalen = 8; + srb->cmdlen = 12; + if (ss->transport(srb, ss) == USB_STOR_TRANSPORT_GOOD) return 0; - } - } while(retry--); + } while (retry--);
return -1; }
-static int usb_read_10(ccb *srb,struct us_data *ss, unsigned long start, unsigned short blocks) +static int usb_read_10(ccb *srb, struct us_data *ss, unsigned long start, + unsigned short blocks) { - memset(&srb->cmd[0],0,12); - srb->cmd[0]=SCSI_READ10; - srb->cmd[1]=srb->lun<<5; - srb->cmd[2]=((unsigned char) (start>>24))&0xff; - srb->cmd[3]=((unsigned char) (start>>16))&0xff; - srb->cmd[4]=((unsigned char) (start>>8))&0xff; - srb->cmd[5]=((unsigned char) (start))&0xff; - srb->cmd[7]=((unsigned char) (blocks>>8))&0xff; - srb->cmd[8]=(unsigned char) blocks & 0xff; - srb->cmdlen=12; - USB_STOR_PRINTF("read10: start %lx blocks %x\n",start,blocks); - return ss->transport(srb,ss); + memset(&srb->cmd[0], 0, 12); + srb->cmd[0] = SCSI_READ10; + srb->cmd[1] = srb->lun << 5; + srb->cmd[2] = ((unsigned char) (start >> 24)) & 0xff; + srb->cmd[3] = ((unsigned char) (start >> 16)) & 0xff; + srb->cmd[4] = ((unsigned char) (start >> 8)) & 0xff; + srb->cmd[5] = ((unsigned char) (start)) & 0xff; + srb->cmd[7] = ((unsigned char) (blocks >> 8)) & 0xff; + srb->cmd[8] = (unsigned char) blocks & 0xff; + srb->cmdlen = 12; + USB_STOR_PRINTF("read10: start %lx blocks %x\n", start, blocks); + return ss->transport(srb, ss); }
@@ -933,85 +988,94 @@ static void usb_bin_fixup(struct usb_device_descriptor descriptor, const unsigned char max_vendor_len = 40; const unsigned char max_product_len = 20; if (descriptor.idVendor == 0x0424 && descriptor.idProduct == 0x223a) { - strncpy ((char *)vendor, "SMSC", max_vendor_len); - strncpy ((char *)product, "Flash Media Cntrller", max_product_len); + strncpy((char *)vendor, "SMSC", max_vendor_len); + strncpy((char *)product, "Flash Media Cntrller", + max_product_len); } } #endif /* CONFIG_USB_BIN_FIXUP */
#define USB_MAX_READ_BLK 20
-unsigned long usb_stor_read(int device, unsigned long blknr, unsigned long blkcnt, void *buffer) +unsigned long usb_stor_read(int device, unsigned long blknr, + unsigned long blkcnt, void *buffer) { - unsigned long start,blks, buf_addr; + unsigned long start, blks, buf_addr; unsigned short smallblks; struct usb_device *dev; - int retry,i; + int retry, i; ccb *srb = &usb_ccb;
if (blkcnt == 0) return 0;
device &= 0xff; - /* Setup device - */ - USB_STOR_PRINTF("\nusb_read: dev %d \n",device); - dev=NULL; - for(i=0;i<USB_MAX_DEVICE;i++) { - dev=usb_get_dev_index(i); - if(dev==NULL) { + /* Setup device */ + USB_STOR_PRINTF("\nusb_read: dev %d \n", device); + dev = NULL; + for (i = 0; i < USB_MAX_DEVICE; i++) { + dev = usb_get_dev_index(i); + if (dev == NULL) return 0; - } - if(dev->devnum==usb_dev_desc[device].target) + if (dev->devnum == usb_dev_desc[device].target) break; }
usb_disable_asynch(1); /* asynch transfer not allowed */ - srb->lun=usb_dev_desc[device].lun; - buf_addr=(unsigned long)buffer; - start=blknr; - blks=blkcnt; - if(usb_test_unit_ready(srb,(struct us_data *)dev->privptr)) { - printf("Device NOT ready\n Request Sense returned %02X %02X %02X\n", - srb->sense_buf[2],srb->sense_buf[12],srb->sense_buf[13]); + srb->lun = usb_dev_desc[device].lun; + buf_addr = (unsigned long)buffer; + start = blknr; + blks = blkcnt; + if (usb_test_unit_ready(srb, (struct us_data *)dev->privptr)) { + printf("Device NOT ready\n Request Sense returned %02X %02X" + " %02X\n", srb->sense_buf[2], srb->sense_buf[12], + srb->sense_buf[13]); return 0; } - USB_STOR_PRINTF("\nusb_read: dev %d startblk %lx, blccnt %lx buffer %lx\n",device,start,blks, buf_addr); + + USB_STOR_PRINTF("\nusb_read: dev %d startblk %lx, blccnt %lx" + " buffer %lx\n", device, start, blks, buf_addr); + do { - retry=2; - srb->pdata=(unsigned char *)buf_addr; - if(blks>USB_MAX_READ_BLK) { - smallblks=USB_MAX_READ_BLK; - } else { - smallblks=(unsigned short) blks; - } + /* XXX need some comment here */ + retry = 2; + srb->pdata = (unsigned char *)buf_addr; + if (blks > USB_MAX_READ_BLK) + smallblks = USB_MAX_READ_BLK; + else + smallblks = (unsigned short) blks; retry_it: - if(smallblks==USB_MAX_READ_BLK) + if (smallblks == USB_MAX_READ_BLK) usb_show_progress(); - srb->datalen=usb_dev_desc[device].blksz * smallblks; - srb->pdata=(unsigned char *)buf_addr; - if(usb_read_10(srb,(struct us_data *)dev->privptr, start, smallblks)) { + srb->datalen = usb_dev_desc[device].blksz * smallblks; + srb->pdata = (unsigned char *)buf_addr; + if (usb_read_10(srb, (struct us_data *)dev->privptr, start, + smallblks)) { USB_STOR_PRINTF("Read ERROR\n"); - usb_request_sense(srb,(struct us_data *)dev->privptr); - if(retry--) + usb_request_sense(srb, (struct us_data *)dev->privptr); + if (retry--) goto retry_it; - blkcnt-=blks; + blkcnt -= blks; break; } - start+=smallblks; - blks-=smallblks; - buf_addr+=srb->datalen; - } while(blks!=0); - USB_STOR_PRINTF("usb_read: end startblk %lx, blccnt %x buffer %lx\n",start,smallblks,buf_addr); + start += smallblks; + blks -= smallblks; + buf_addr += srb->datalen; + } while (blks != 0); + + USB_STOR_PRINTF("usb_read: end startblk %lx, blccnt %x buffer %lx\n", + start, smallblks, buf_addr); + usb_disable_asynch(0); /* asynch transfer allowed */ - if(blkcnt>=USB_MAX_READ_BLK) + if (blkcnt >= USB_MAX_READ_BLK) printf("\n"); - return(blkcnt); + return blkcnt; }
/* Probe to see if a new device is actually a Storage device */ -int usb_storage_probe(struct usb_device *dev, unsigned int ifnum,struct us_data *ss) +int usb_storage_probe(struct usb_device *dev, unsigned int ifnum, + struct us_data *ss) { struct usb_interface_descriptor *iface; int i; @@ -1025,8 +1089,11 @@ int usb_storage_probe(struct usb_device *dev, unsigned int ifnum,struct us_data
#if 0 /* this is the place to patch some storage devices */ - USB_STOR_PRINTF("iVendor %X iProduct %X\n",dev->descriptor.idVendor,dev->descriptor.idProduct); - if ((dev->descriptor.idVendor) == 0x066b && (dev->descriptor.idProduct) == 0x0103) { + USB_STOR_PRINTF("iVendor %X iProduct %X\n", dev->descriptor.idVendor, + dev->descriptor.idProduct); + + if ((dev->descriptor.idVendor) == 0x066b && + (dev->descriptor.idProduct) == 0x0103) { USB_STOR_PRINTF("patched for E-USB\n"); protocol = US_PR_CB; subclass = US_SC_UFI; /* an assumption */ @@ -1095,19 +1162,20 @@ int usb_storage_probe(struct usb_device *dev, unsigned int ifnum,struct us_data */ for (i = 0; i < iface->bNumEndpoints; i++) { /* is it an BULK endpoint? */ - if ((iface->ep_desc[i].bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) - == USB_ENDPOINT_XFER_BULK) { + if ((iface->ep_desc[i].bmAttributes & + USB_ENDPOINT_XFERTYPE_MASK) == USB_ENDPOINT_XFER_BULK) { if (iface->ep_desc[i].bEndpointAddress & USB_DIR_IN) ss->ep_in = iface->ep_desc[i].bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; else - ss->ep_out = iface->ep_desc[i].bEndpointAddress & + ss->ep_out = + iface->ep_desc[i].bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; }
/* is it an interrupt endpoint? */ - if ((iface->ep_desc[i].bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) - == USB_ENDPOINT_XFER_INT) { + if ((iface->ep_desc[i].bmAttributes & + USB_ENDPOINT_XFERTYPE_MASK) == USB_ENDPOINT_XFER_INT) { ss->ep_int = iface->ep_desc[i].bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; ss->irqinterval = iface->ep_desc[i].bInterval; @@ -1130,26 +1198,28 @@ int usb_storage_probe(struct usb_device *dev, unsigned int ifnum,struct us_data */ if (ss->subclass != US_SC_UFI && ss->subclass != US_SC_SCSI && ss->subclass != US_SC_8070) { - printf("Sorry, protocol %d not yet supported.\n",ss->subclass); + printf("Sorry, protocol %d not yet supported.\n", ss->subclass); return 0; } - if(ss->ep_int) { /* we had found an interrupt endpoint, prepare irq pipe */ - /* set up the IRQ pipe and handler */ - + if (ss->ep_int) { + /* we had found an interrupt endpoint, prepare irq pipe + * set up the IRQ pipe and handler + */ ss->irqinterval = (ss->irqinterval > 0) ? ss->irqinterval : 255; ss->irqpipe = usb_rcvintpipe(ss->pusb_dev, ss->ep_int); ss->irqmaxp = usb_maxpacket(dev, ss->irqpipe); - dev->irq_handle=usb_stor_irq; + dev->irq_handle = usb_stor_irq; } - dev->privptr=(void *)ss; + dev->privptr = (void *)ss; return 1; }
-int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t *dev_desc) +int usb_stor_get_info(struct usb_device *dev, struct us_data *ss, + block_dev_desc_t *dev_desc) { - unsigned char perq,modi; + unsigned char perq, modi; unsigned long cap[2]; - unsigned long *capacity,*blksz; + unsigned long *capacity, *blksz; ccb *pccb = &usb_ccb;
/* for some reasons a couple of devices would not survive this reset */ @@ -1157,7 +1227,6 @@ int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t /* Sony USM256E */ (dev->descriptor.idVendor == 0x054c && dev->descriptor.idProduct == 0x019e) - || /* USB007 Mini-USB2 Flash Drive */ (dev->descriptor.idVendor == 0x066f && @@ -1175,17 +1244,20 @@ int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t
dev_desc->target = dev->devnum; pccb->lun = dev_desc->lun; - USB_STOR_PRINTF(" address %d\n",dev_desc->target); + USB_STOR_PRINTF(" address %d\n", dev_desc->target);
- if(usb_inquiry(pccb,ss)) + if (usb_inquiry(pccb, ss)) return -1;
perq = usb_stor_buf[0]; modi = usb_stor_buf[1]; - if((perq & 0x1f) == 0x1f) { - return 0; /* skip unknown devices */ + + if ((perq & 0x1f) == 0x1f) { + /* skip unknown devices */ + return 0; } - if((modi&0x80) == 0x80) {/* drive is removable */ + if ((modi&0x80) == 0x80) { + /* drive is removable */ dev_desc->removable = 1; } memcpy(&dev_desc->vendor[0], &usb_stor_buf[8], 8); @@ -1195,29 +1267,34 @@ int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t dev_desc->product[16] = 0; dev_desc->revision[4] = 0; #ifdef CONFIG_USB_BIN_FIXUP - usb_bin_fixup(dev->descriptor, (uchar *)dev_desc->vendor, (uchar *)dev_desc->product); + usb_bin_fixup(dev->descriptor, (uchar *)dev_desc->vendor, + (uchar *)dev_desc->product); #endif /* CONFIG_USB_BIN_FIXUP */ - USB_STOR_PRINTF("ISO Vers %X, Response Data %X\n",usb_stor_buf[2],usb_stor_buf[3]); - if(usb_test_unit_ready(pccb,ss)) { - printf("Device NOT ready\n Request Sense returned %02X %02X %02X\n",pccb->sense_buf[2],pccb->sense_buf[12],pccb->sense_buf[13]); - if(dev_desc->removable == 1) { + USB_STOR_PRINTF("ISO Vers %X, Response Data %X\n", usb_stor_buf[2], + usb_stor_buf[3]); + if (usb_test_unit_ready(pccb, ss)) { + printf("Device NOT ready\n" + " Request Sense returned %02X %02X %02X\n", + pccb->sense_buf[2], pccb->sense_buf[12], + pccb->sense_buf[13]); + if (dev_desc->removable == 1) { dev_desc->type = perq; return 1; } - else - return 0; + return 0; } pccb->pdata = (unsigned char *)&cap[0]; - memset(pccb->pdata,0,8); - if(usb_read_capacity(pccb,ss) != 0) { + memset(pccb->pdata, 0, 8); + if (usb_read_capacity(pccb, ss) != 0) { printf("READ_CAP ERROR\n"); cap[0] = 2880; cap[1] = 0x200; } - USB_STOR_PRINTF("Read Capacity returns: 0x%lx, 0x%lx\n",cap[0],cap[1]); + USB_STOR_PRINTF("Read Capacity returns: 0x%lx, 0x%lx\n", cap[0], + cap[1]); #if 0 - if(cap[0]>(0x200000 * 10)) /* greater than 10 GByte */ - cap[0]>>=16; + if (cap[0] > (0x200000 * 10)) /* greater than 10 GByte */ + cap[0] >>= 16; #endif cap[0] = cpu_to_be32(cap[0]); cap[1] = cpu_to_be32(cap[1]); @@ -1226,15 +1303,16 @@ int usb_stor_get_info(struct usb_device *dev,struct us_data *ss,block_dev_desc_t cap[0] += 1; capacity = &cap[0]; blksz = &cap[1]; - USB_STOR_PRINTF("Capacity = 0x%lx, blocksz = 0x%lx\n",*capacity,*blksz); + USB_STOR_PRINTF("Capacity = 0x%lx, blocksz = 0x%lx\n", + *capacity, *blksz); dev_desc->lba = *capacity; dev_desc->blksz = *blksz; dev_desc->type = perq; - USB_STOR_PRINTF(" address %d\n",dev_desc->target); - USB_STOR_PRINTF("partype: %d\n",dev_desc->part_type); + USB_STOR_PRINTF(" address %d\n", dev_desc->target); + USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type);
init_part(dev_desc);
- USB_STOR_PRINTF("partype: %d\n",dev_desc->part_type); + USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type); return 1; }
Hello Michael,
2008/12/10 Michael Trimarchi trimarchi@gandalf.sssup.it:
Cleanup usb storage
oops... I overlooked this one... Applied to U-boot-usb tree.
Thanks!
Remy
struct us_data {
- show info on storage devices; 'usb start/init' must be invoked earlier
- as we only retrieve structures populated during devices initialization
- scan the usb and reports device info
- to the user if mode = 1
- returns current device or -1 if no
if(mode==1) {
usb_max_devs=0;
if(dev==NULL) {
usb_max_devs = 0;
usb_max_devs); break; } } /* for */ usb_disable_asynch(0); /* asynch transfer allowed */ printf("%d Storage Device(s) found\n", usb_max_devs);
if(usb_max_devs>0)
else
return-1;
return -1;
if(us->ip_wanted) {
us->ip_wanted=0;
if (us->ip_wanted)
for(i=0;i<12;i++) {
* we go on
} while (this_xfer); } /* if we get here, we're done and successful */
US_BBB_RESET,
if ((result < 0) && (us->pusb_dev->status & USB_ST_STALLED)) { USB_STOR_PRINTF("RESET:stall\n"); return -1; } /* long wait for reset */ wait_ms(150);
US_CBI_ADSC,
USB_CNTL_TIMEOUT * 5); /* long wait for reset */ wait_ms(1500);
int dir_in,retry;
retry=5;
retry = 5;
if(dir_in)
else
while(retry--) {
if (dir_in)
else
while (retry--) {
US_CBI_ADSC,
" clear pipe\n");
srb->datalen);
us->ip_wanted = 1;
wait_ms (10);
- st:
+st: retry = 0;
- again:
int result,status;
int retry,notready;
int retry, notready; psrb = &reqsrb;
retry=0;
notready=0;
retry = 0;
do_retry:
if(!us->ip_data) {
if (!us->ip_data) {
psrb->cmd[4]=18;
psrb->datalen=18;
psrb->cmd[4] = 18;
psrb->cmdlen=12;
case 0x01:
case 0x02:
/* Not Ready */
} else {
int retry,i;
retry=5;
int retry, i;
retry = 5; do {
srb->cmd[4]=36;
srb->datalen=36;
srb->cmdlen=12;
if(i==0)
srb->cmd[4] = 36;
srb->datalen = 36;
srb->cmdlen = 12;
if (i == 0) break;
} while(retry--);
} while (retry--);
if(!retry) {
srb->cmd[4]=18;
srb->datalen=18;
srb->cmd[4] = 18;
srb->cmdlen=12;
srb->cmdlen = 12;
do {
srb->datalen=0;
srb->cmdlen=12;
srb->datalen = 0;
srb->cmdlen = 12;
wait_ms (100);
} while(retries--);
wait_ms(100);
} while (retries--); return -1;
/* XXX retries */
retry = 3; do {
srb->datalen=8;
srb->cmdlen=12;
srb->datalen = 8;
srb->cmdlen = 12;
} while(retry--);
} while (retry--); return -1;
srb->cmdlen=12;
srb->cmdlen = 12;
max_product_len); }
int retry,i;
int retry, i; ccb *srb = &usb_ccb; if (blkcnt == 0) return 0; device &= 0xff;
/* Setup device
dev=NULL;
if(dev==NULL) {
/* Setup device */
dev = NULL;
if (dev->devnum == usb_dev_desc[device].target) break; } usb_disable_asynch(1); /* asynch transfer not allowed */
start=blknr;
blks=blkcnt;
start = blknr;
blks = blkcnt;
do {
retry=2;
} else {
retry = 2;
else
retry_it:
if(retry--)
blkcnt-=blks;
start+=smallblks;
blks-=smallblks;
} while(blks!=0);
start += smallblks;
blks -= smallblks;
return(blkcnt);
return blkcnt;
struct us_data *ss)
ss->ep_out =
iface->ep_desc[i].bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; } /* is it an interrupt endpoint? */
if (ss->ep_int) {
unsigned long *capacity, *blksz; ccb *pccb = &usb_ccb; /* for some reasons a couple of devices would not survive this reset */
if (usb_inquiry(pccb, ss)) return -1; perq = usb_stor_buf[0]; modi = usb_stor_buf[1];
return 0; }
usb_stor_buf[3]);
else
cap[1]);
#if 0
cap[0]>>=16;
cap[0] >>= 16;
USB_STOR_PRINTF("partype: %d\n", dev_desc->part_type); init_part(dev_desc);
Michael Trimarchi
Remy Bohmer
