[U-Boot] [PATCH 0/2] Update configs for the firefly-rk3288
This set of patches enables SPL_BACK_TO_BROM feature that has been tested on this board. That is preferable if all rk3288-based boards use the same configuration and boot in the same way. Then, it enables ethernet address randomization.
Romain Perier (2): Enable ROCKCHIP_SPL_BACK_TO_BROM for firefly-rk3288 board rockchip: Enable ETH address randomization for the firefly-rk3288
configs/firefly-rk3288_defconfig | 3 +++ include/configs/firefly-rk3288.h | 9 +++++++++ 2 files changed, 12 insertions(+)
Like the rock2, this board has been tested with back to brom feature. This commits adjusts environment offset regarding if back_to_brom is enabled or not and uses this feature by default.
Signed-off-by: Romain Perier romain.perier@collabora.com --- configs/firefly-rk3288_defconfig | 2 ++ include/configs/firefly-rk3288.h | 9 +++++++++ 2 files changed, 11 insertions(+)
diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 3ed17b4..3aa8bcf 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -2,6 +2,8 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y +# CONFIG_SPL_MMC_SUPPORT is not set +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index 14fdead..b9c2290 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -16,11 +16,20 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 + +#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else /* SPL @ 32k for ~36k * ENV @ 96k * u-boot @ 128K */ #define CONFIG_ENV_OFFSET (96 * 1024) +#endif
#define CONFIG_SYS_WHITE_ON_BLACK
On 17 January 2017 at 02:32, Romain Perier romain.perier@collabora.com wrote:
We need at least one board that does not use this option. Also, doesn't this mean that we need to change how the image is written to the board?
Should we use binman to create a suitable image?
Why do you want at least one board without this option ? for testing that it's still working without back_to_brom ? That's weird because all rk3288-based board has the same limitations regarding the SPL, no ?
Regards, Romain
Hi Romain,
On 21 January 2017 at 00:51, Romain Perier romain.perier@collabora.com wrote:
Yes, but remember this is a non-standard booting mechanism, and one that I hope we can move away from in future. Also firefly does not *need* this mechanism. If we don't have one board that uses the standard mechanism then it might stop working.
This commit enables ethernet MAC address randomization on the firefly-rk3288. It removes the error at startup 'ethernet@ff290000 address not set'.
Signed-off-by: Romain Perier romain.perier@collabora.com --- configs/firefly-rk3288_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 3aa8bcf..3fe7add 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_OF_PLATDATA=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y
Applied to u-boot-rockchip, thanks!
Romain Perier
