[U-Boot] [PATCH v2 0/3] fastboot: Fix getvar "has-slot" and cleanup
This patch series fixes "has-slot" fastboot variable and provides associated refactoring, so that related code is not cluttered.
Igor Opaniuk (1): fastboot: Check if partition really exist in getvar_has_slot()
Sam Protsenko (2): fastboot: Use const qualifier for char *part_name fastboot: getvar: Refactor fastboot_*_get_part_info() usage
drivers/fastboot/fb_getvar.c | 78 +++++++++++++++++++++++++++--------- drivers/fastboot/fb_mmc.c | 3 +- drivers/fastboot/fb_nand.c | 4 +- include/fb_mmc.h | 3 +- include/fb_nand.h | 4 +- 5 files changed, 66 insertions(+), 26 deletions(-)
In fastboot_*_get_part_info() functions we can use stronger typing by expecting const strings.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/fastboot/fb_mmc.c | 3 ++- drivers/fastboot/fb_nand.c | 4 ++-- include/fb_mmc.h | 3 ++- include/fb_nand.h | 4 ++-- 4 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/fastboot/fb_mmc.c b/drivers/fastboot/fb_mmc.c index 90ca81da9b..0a335db3a6 100644 --- a/drivers/fastboot/fb_mmc.c +++ b/drivers/fastboot/fb_mmc.c @@ -298,7 +298,8 @@ static int fb_mmc_update_zimage(struct blk_desc *dev_desc, * @part_info: Pointer to returned disk_partition_t * @response: Pointer to fastboot response buffer */ -int fastboot_mmc_get_part_info(char *part_name, struct blk_desc **dev_desc, +int fastboot_mmc_get_part_info(const char *part_name, + struct blk_desc **dev_desc, disk_partition_t *part_info, char *response) { int r; diff --git a/drivers/fastboot/fb_nand.c b/drivers/fastboot/fb_nand.c index 526bc12307..6756ea769f 100644 --- a/drivers/fastboot/fb_nand.c +++ b/drivers/fastboot/fb_nand.c @@ -152,8 +152,8 @@ static lbaint_t fb_nand_sparse_reserve(struct sparse_storage *info, * @part_info: Pointer to returned part_info pointer * @response: Pointer to fastboot response buffer */ -int fastboot_nand_get_part_info(char *part_name, struct part_info **part_info, - char *response) +int fastboot_nand_get_part_info(const char *part_name, + struct part_info **part_info, char *response) { struct mtd_info *mtd = NULL;
diff --git a/include/fb_mmc.h b/include/fb_mmc.h index fd5db9eac8..95db001bee 100644 --- a/include/fb_mmc.h +++ b/include/fb_mmc.h @@ -14,7 +14,8 @@ * @part_info: Pointer to returned disk_partition_t * @response: Pointer to fastboot response buffer */ -int fastboot_mmc_get_part_info(char *part_name, struct blk_desc **dev_desc, +int fastboot_mmc_get_part_info(const char *part_name, + struct blk_desc **dev_desc, disk_partition_t *part_info, char *response);
/** diff --git a/include/fb_nand.h b/include/fb_nand.h index 08ab0e28a6..6d7999f262 100644 --- a/include/fb_nand.h +++ b/include/fb_nand.h @@ -16,8 +16,8 @@ * @part_info: Pointer to returned part_info pointer * @response: Pointer to fastboot response buffer */ -int fastboot_nand_get_part_info(char *part_name, struct part_info **part_info, - char *response); +int fastboot_nand_get_part_info(const char *part_name, + struct part_info **part_info, char *response);
/** * fastboot_nand_flash_write() - Write image to NAND for fastboot
On Thu, 13 Jun 2019 00:14:09 +0300 Sam Protsenko semen.protsenko@linaro.org wrote:
- @part_info: Pointer to returned disk_partition_t
- @response: Pointer to fastboot response buffer
- @part_info: Pointer to returned part_info pointer
char *response)
*response); /** diff --git a/include/fb_nand.h b/include/fb_nand.h index 08ab0e28a6..6d7999f262 100644 --- a/include/fb_nand.h +++ b/include/fb_nand.h @@ -16,8 +16,8 @@
char *response);
*response); /**
- fastboot_nand_flash_write() - Write image to NAND for fastboot
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On Thu, Jun 13, 2019 at 12:14 AM Sam Protsenko semen.protsenko@linaro.org wrote:
char *response)
char *response);
-- 2.20.1
Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Extract fastboot_*_get_part_info() usage for MMC and NAND into getvar_get_part_info() function, as it will be needed further in other functions. This way we can avoid code duplication and mess with preprocessor directives across all points of usage.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/fastboot/fb_getvar.c | 52 +++++++++++++++++++++++++----------- 1 file changed, 36 insertions(+), 16 deletions(-)
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index 4268628f5e..b23880089e 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -81,6 +81,41 @@ static const struct { } };
+#if CONFIG_IS_ENABLED(FASTBOOT_FLASH) +/** + * Universal function to get partition number and size. + * + * @param[in] part_name Info for which partition name to look for + * @param[in,out] response Pointer to fastboot response buffer + * @param[out] size If not NULL, will contain partition size (in blocks) + * @return Partition number or negative value on error + */ +static int getvar_get_part_info(const char *part_name, char *response, + size_t *size) +{ + int r; +# if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) + struct blk_desc *dev_desc; + disk_partition_t part_info; + + r = fastboot_mmc_get_part_info(part_name, &dev_desc, &part_info, + response); + if (r >= 0 && size) + *size = part_info.size; +# elif CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) + struct part_info *part_info; + + r = fastboot_nand_get_part_info(part_name, &part_info, response); + if (r >= 0 && size) + *size = part_info->size; +# else + r = -ENODEV; +# endif + + return r; +} +#endif + static void getvar_version(char *var_parameter, char *response) { fastboot_okay(FASTBOOT_VERSION, response); @@ -176,22 +211,7 @@ static void getvar_partition_size(char *part_name, char *response) int r; size_t size;
-#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_MMC) - struct blk_desc *dev_desc; - disk_partition_t part_info; - - r = fastboot_mmc_get_part_info(part_name, &dev_desc, &part_info, - response); - if (r >= 0) - size = part_info.size; -#endif -#if CONFIG_IS_ENABLED(FASTBOOT_FLASH_NAND) - struct part_info *part_info; - - r = fastboot_nand_get_part_info(part_name, &part_info, response); - if (r >= 0) - size = part_info->size; -#endif + r = getvar_get_part_info(part_name, response, &size); if (r >= 0) fastboot_response("OKAY", response, "0x%016zx", size); }
On Thu, 13 Jun 2019 00:14:10 +0300 Sam Protsenko semen.protsenko@linaro.org wrote:
- Universal function to get partition number and size.
- @param[in] part_name Info for which partition name to look for
- @param[in,out] response Pointer to fastboot response buffer
- @param[out] size If not NULL, will contain partition size (in
blocks)
- @return Partition number or negative value on error
size_t *size)
- int r;
&part_info,
response);
- if (r >= 0 && size)
response);
+# else
- r = -ENODEV;
+# endif
- return r;
+} +#endif
&part_info,
response);
- if (r >= 0)
response);
- if (r >= 0)
-#endif
- r = getvar_get_part_info(part_name, response, &size); if (r >= 0) fastboot_response("OKAY", response, "0x%016zx",
size); }
Lukasz Majewski
Hi Sam,
- @param[out] size If not NULL, will contain partition size (in blocks)
size_t *size)
int r;
response);
if (r >= 0 && size)
if (r >= 0 && size)
+# else
r = -ENODEV;
+# endif
return r;
+} +#endif
response);
if (r >= 0)
if (r >= 0)
-#endif
2.20.1
Currently getvar_has_slot() invocation for "boot" and "system" partitions always returns affirmative response regardless the fact of existence of these partitions, which leads to impossibility to flash them on old non-A/B AOSP setups, where _a/_b suffixes aren't used:
$ fastboot flash boot boot.img Sending 'boot__a' (11301 KB) OKAY [ 0.451s] Writing 'boot__a' FAILED (remote: 'cannot find partition') fastboot: error: Command failed
Although partition layout is: -> part list mmc 0 Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name Attributes Type GUID Partition GUID 1 0x00000800 0x000107ff "boot" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: ea2e2470-db4a-d646-b828-10167f736d63 2 0x00010800 0x000127ff "environment" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 10a819d2-6004-3d48-bd87-114e2a796db9 3 0x00012800 0x0001a7ff "recovery" attrs: 0x0000000000000000 type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7 guid: 9ea116e4-8a34-0c48-8cf5-2fe9480f56cd 4 0x0001a800 0x0031a7ff "system" attrs: 0x0000000000000000 ......
This patch adds checks of existence for requested partitions on eMMC/NAND.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/fastboot/fb_getvar.c | 26 ++++++++++++++++++++++---- 1 file changed, 22 insertions(+), 4 deletions(-)
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index b23880089e..563bda0088 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -179,11 +179,29 @@ static void getvar_slot_suffixes(char *var_parameter, char *response)
static void getvar_has_slot(char *part_name, char *response) { - if (part_name && (!strcmp(part_name, "boot") || - !strcmp(part_name, "system"))) + char part_name_wslot[PART_NAME_LEN]; + size_t len; + int r; + + if (!part_name) + goto no; + + /* Append "_a" prefix to part_name */ + len = strlcpy(part_name_wslot, part_name, PART_NAME_LEN - 3); + if (len > PART_NAME_LEN - 3) { + fastboot_fail("too long partition name", response); + return; + } + strcat(part_name_wslot, "_a"); + + /* Check if this partition exists */ + r = getvar_get_part_info(part_name_wslot, response, NULL); + if (r >= 0) { fastboot_okay("yes", response); - else - fastboot_okay("no", response); + return; + } +no: + fastboot_okay("no", response); }
Hi Tom,
We have broken fastboot right now... Can we please apply this series, so that it appears in v2019.07?
Thanks!
size_t len;
int r;
if (!part_name)
goto no;
return;
else
return;
+no:
2.20.1
Hi Sam,
Hi Tom,
I'm running Travis-CI on this series, and send PR to Marek when it finish.
Thanks for fixing fastboot.
Thanks!
size_t len;
int r;
if (!part_name)
goto no;
3);
return;
else
return;
+no:
2.20.1
Lukasz Majewski
On Thu, 13 Jun 2019 07:47:19 +0200 Lukasz Majewski lukma@denx.de wrote:
Hi Sam,
Hi Tom,
Unfortunately, there are several build breaks: https://travis-ci.org/lmajewski/u-boot-dfu/jobs/545073270
Please fix them before sending v3.
Thanks in advance,
Thanks!
size_t len;
int r;
if (!part_name)
goto no;
3);
response);
return;
else
return;
+no:
2.20.1
Lukasz Majewski
Lukasz Majewski
Lukasz, Eugeniu,
Just sent v3 where build is fixed. Please review and merge, if applicable.
Thanks!
Hi Sam,
Hi Tom,
Thanks in advance,
Thanks!
size_t len;
int r;
if (!part_name)
goto no;
3);
response);
return;
else
return;
+no:
2.20.1
Lukasz Majewski
Lukasz Majewski
On Thu, 13 Jun 2019 00:14:11 +0300 Sam Protsenko semen.protsenko@linaro.org wrote:
diff --git a/drivers/fastboot/fb_getvar.c b/drivers/fastboot/fb_getvar.c index b23880089e..563bda0088 100644 --- a/drivers/fastboot/fb_getvar.c +++ b/drivers/fastboot/fb_getvar.c @@ -179,11 +179,29 @@ static void getvar_slot_suffixes(char *var_parameter, char *response) static void getvar_has_slot(char *part_name, char *response) {
- char part_name_wslot[PART_NAME_LEN];
- size_t len;
- int r;
- if (!part_name)
goto no;
- /* Append "_a" prefix to part_name */
- len = strlcpy(part_name_wslot, part_name, PART_NAME_LEN - 3);
- if (len > PART_NAME_LEN - 3) {
return;
- strcat(part_name_wslot, "_a");
- /* Check if this partition exists */
- r = getvar_get_part_info(part_name_wslot, response, NULL);
- if (r >= 0) { fastboot_okay("yes", response);
- else
return;
+no:
Lukasz Majewski
Hi Sam, hi Igor,
With the https://patchwork.ozlabs.org/cover/1114844/ ("[U-Boot,v2,0/3] fastboot: Fix getvar "has-slot" and cleanup") series applied on top of v2019.07-rc4-136-gc2ea87883ef3, I get below build failure on sandbox:
drivers/fastboot/fb_getvar.c: In function ‘getvar_has_slot’: drivers/fastboot/fb_getvar.c:198:6: warning: implicit declaration of function ‘getvar_get_part_info’; did you mean ‘getvar_serialno’? [-Wimplicit-function-declaration] r = getvar_get_part_info(part_name_wslot, response, NULL); ^~~~~~~~~~~~~~~~~~~~ getvar_serialno [..] LD u-boot drivers/built-in.o: In function `getvar_has_slot': /home/erosca/R/u-boot-master/drivers/fastboot/fb_getvar.c:198: undefined reference to `getvar_get_part_info' collect2: error: ld returned 1 exit status Makefile:1570: recipe for target 'u-boot' failed make[1]: *** [u-boot] Error 1 Makefile:498: recipe for target '__build_one_by_one' failed make: *** [__build_one_by_one] Error 2
Eugeniu Rosca
Igor Opaniuk
Lukasz Majewski
Sam Protsenko
