[U-Boot] [PATCH 1/2] mtd/nand:Fix wrong address read in is_blank()
IFC NAND Machine calculates ECC on 512byte sector. Same is taken care in fsl_ifc_run_command() while ECC status verification. Here buffer number is calculated assuming 512byte sector and same is passed to is_blank. However in is_blank() buffer address is calculated using mdt->writesize which is wrong. It should be calculated on basis of ecc sector size.
Also, in fsl_ifc_run_command() bufferpage is calculated on the basis of ecc sector size instead of hard coded value.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git (branch master)
Top commit: commit bfcc40bb09b05c90cc3b1496abb270eb8aa72134 Merge: cba9a89 1895420 Author: Wolfgang Denk wd@denx.de Date: Fri Dec 23 20:53:58 2011 +0100
Merge branch 'next' of ../next
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c
drivers/mtd/nand/fsl_ifc_nand.c | 6 ++++-- 1 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index b3f3c3c..3a28ab8 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -196,7 +196,9 @@ static int is_blank(struct mtd_info *mtd, struct fsl_ifc_ctrl *ctrl, { struct nand_chip *chip = mtd->priv; struct fsl_ifc_mtd *priv = chip->priv; - u8 __iomem *addr = priv->vbase + bufnum * (mtd->writesize * 2); + int bufperpage = mtd->writesize / chip->ecc.size; + u8 __iomem *addr = priv->vbase + bufnum / bufperpage + * (mtd->writesize * 2); u32 __iomem *main = (u32 *)addr; u8 __iomem *oob = addr + mtd->writesize; int i; @@ -279,7 +281,7 @@ static int fsl_ifc_run_command(struct mtd_info *mtd) printf("%s: Write Protect Error\n", __func__);
if (ctrl->eccread) { - int bufperpage = mtd->writesize / 512; + int bufperpage = mtd->writesize / chip->ecc.size; int bufnum = (ctrl->page & priv->bufnum_mask) * bufperpage; int bufnum_end = bufnum + bufperpage - 1;
You just sent two patches based on the same commit, but those are clearly dependent. This is weird. So next time:
1) Submit this with git-send-email as a series 2) iomem looks linuxish, so instead of specifying u-boot commit, specify Linux commit/tree etc. from where this is pulled so when someone synces next time, he'll know where he is in linux. 3) Cc Scott Wood
M
Merge branch 'next' of ../next * 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot
- int bufperpage = mtd->writesize / chip->ecc.size;
- u8 __iomem *addr = priv->vbase + bufnum / bufperpage
u32 __iomem *main = (u32 *)addr; u8 __iomem *oob = addr + mtd->writesize; int i;* (mtd->writesize * 2);
int bufnum = (ctrl->page & priv->bufnum_mask) * bufperpage; int bufnum_end = bufnum + bufperpage - 1;int bufperpage = mtd->writesize / chip->ecc.size;
is_blank.
sector size.
- Submit this with git-send-email as a series
I will take care this point in future
- iomem looks linuxish, so instead of specifying u-boot commit, specify
This patch is independent of Linux tree. I will float similar patch to Linux tree.
- Cc Scott Wood
--Prabhakar
zboot
vboot
coreboot
protocol
Import
Initial
*mtd)
is_blank.
sector size.
- Cc Scott Wood
--Prabhakar
Awesome, good going, thanks!
M
Same changes requested as in http://patchwork.ozlabs.org/patch/133500/
Also, please mention IFC in the subject.
-Scott
Kushwaha Prabhakar-B32579
Prabhakar Kushwaha
Scott Wood
