[U-Boot] [PATCH 1/2] sf: add support for GD25Q256
Add support for GD25Q256, a 32MiB SPI Nor flash from Gigadevice.
Signed-off-by: Andy Yan andy.yan@rock-chips.com ---
drivers/mtd/spi/sf_internal.h | 1 + drivers/mtd/spi/spi_flash.c | 7 ++++--- drivers/mtd/spi/spi_flash_ids.c | 1 + 3 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 839cdbe..357b3bc 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -37,6 +37,7 @@ enum spi_nor_option_flags { #define SPI_FLASH_CFI_MFR_SST 0xbf #define SPI_FLASH_CFI_MFR_WINBOND 0xef #define SPI_FLASH_CFI_MFR_ATMEL 0x1f +#define SPI_FLASH_CIF_MFR_GIGADEVICE 0xc8
/* Erase commands */ #define CMD_ERASE_4K 0x20 diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 0034a28..cf23077 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -74,7 +74,7 @@ static int write_sr(struct spi_flash *flash, u8 ws) return 0; }
-#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) || defined(CONFIG_SPI_FLASH_GIGADEVICE) static int read_cr(struct spi_flash *flash, u8 *rc) { int ret; @@ -807,7 +807,7 @@ int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) #endif
-#ifdef CONFIG_SPI_FLASH_MACRONIX +#if defined(CONFIG_SPI_FLASH_MACRONIX) || defined(CONFIG_SPI_FLASH_GIGADEVICE) static int macronix_quad_enable(struct spi_flash *flash) { u8 qeb_status; @@ -892,8 +892,9 @@ static int set_quad_mode(struct spi_flash *flash, const struct spi_flash_info *info) { switch (JEDEC_MFR(info)) { -#ifdef CONFIG_SPI_FLASH_MACRONIX +#if defined(CONFIG_SPI_FLASH_MACRONIX) || defined(CONFIG_SPI_FLASH_GIGADEVICE) case SPI_FLASH_CFI_MFR_MACRONIX: + case SPI_FLASH_CIF_MFR_GIGADEVICE: return macronix_quad_enable(flash); #endif #if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c index edca94e..46d5e67 100644 --- a/drivers/mtd/spi/spi_flash_ids.c +++ b/drivers/mtd/spi/spi_flash_ids.c @@ -65,6 +65,7 @@ const struct spi_flash_info spi_flash_ids[] = { #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ {"gd25q64b", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, {"gd25lq32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, + {"GD25Q256", INFO(0xc84019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K)}, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ {"is25lp032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) },
So GB and Macronix has same procedure bit for Quadenable? in that case why you need read_cr bcz it is part of spansion.
thanks!
Hi Jagan:
2017-08-07 16:44 GMT+08:00 Jagan Teki jagannadh.teki@gmail.com:
WINBOND)
size_t len)
#endif
GIGADEVICE)
Sorr, I forgot remove it. It has been removed in V2.
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Andy Yan
Andy Yan
Jagan Teki
