[U-Boot] [PATCH] cmd: bmp: manage centered display
Allow to display BMP at the middle of the screen.
'm' means "middle" as it is done for the splashscreen variable: splashpos=m,m
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com --- Example for command
load mmc 0:4 ${splashimage} splash.bmp bmp display ${splashimage} m m
or function can be used directly
bmp_display(0xC0000000, BMP_ALIGN_CENTER, BMP_ALIGN_CENTER)
cmd/bmp.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/cmd/bmp.c b/cmd/bmp.c index 02bdf48..1ace8a8 100644 --- a/cmd/bmp.c +++ b/cmd/bmp.c @@ -108,6 +108,7 @@ static int do_bmp_info(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[ return (bmp_info(addr)); }
+#define BMP_ALIGN_CENTER 0x7FFF static int do_bmp_display(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) { ulong addr; @@ -124,8 +125,14 @@ static int do_bmp_display(cmd_tbl_t * cmdtp, int flag, int argc, char * const ar break; case 4: addr = simple_strtoul(argv[1], NULL, 16); - x = simple_strtoul(argv[2], NULL, 10); - y = simple_strtoul(argv[3], NULL, 10); + if (!strcmp(argv[2], "m")) + x = BMP_ALIGN_CENTER; + else + x = simple_strtoul(argv[2], NULL, 10); + if (!strcmp(argv[3], "m")) + y = BMP_ALIGN_CENTER; + else + y = simple_strtoul(argv[3], NULL, 10); break; default: return CMD_RET_USAGE; @@ -249,9 +256,11 @@ int bmp_display(ulong addr, int x, int y) if (!ret) { bool align = false;
-# ifdef CONFIG_SPLASH_SCREEN_ALIGN - align = true; -# endif /* CONFIG_SPLASH_SCREEN_ALIGN */ + if (CONFIG_IS_ENABLED(SPLASH_SCREEN_ALIGN) || + x == BMP_ALIGN_CENTER || + y == BMP_ALIGN_CENTER) + align = true; + ret = video_bmp_display(dev, addr, x, y, align); } #elif defined(CONFIG_LCD)
Hi Patrick,
On Wed, 14 Nov 2018 10:18:22 +0100 Patrick Delaunay patrick.delaunay@st.com wrote: ...
this already exists when including splash.h, I dropped it in v2.
-- Anatolij
Hi Anatolij,
From: Anatolij Gustschin agust@denx.de Sent: samedi 1 décembre 2018 15:06
Hi Patrick,
Ok, I don't see that splash.h is included in cmd/bmp.c.
In fact I hesitate to move this define in commun bmp include (in include/lcd.h with bmp_display prototype for exmaple) to avoid a other double definition:
common/lcd.c:392 #define BMP_ALIGN_CENTER 0x7FFF drivers/video/video_bmp.c:143:#define BMP_ALIGN_CENTER 0x7fff include/splash.h:78:#define BMP_ALIGN_CENTER 0x7FFF
-- Anatolij
Hi Patrick,
On Mon, 3 Dec 2018 08:45:57 +0000 Patrick DELAUNAY patrick.delaunay@st.com wrote: ...
In mainline U-Boot it is included, please see [1].
I've sent a patch cleaning up multiple defines, please see [2].
[1] http://git.denx.de/?p=u-boot.git;a=blob;f=cmd/bmp.c;h=02bdf48b4d422ced97dea7... [2] http://patchwork.ozlabs.org/patch/1006354
-- Anatolij
Anatolij Gustschin
Patrick DELAUNAY
Patrick Delaunay
