[PATCH v5 0/5] roc-rk3399-pc: Custom SPL
This series supports custom initialization code required for roc-rk3399-pc board on SPL stage.
Now this series is well mature code handling to add custom spl_board_init code parts.
roc-rk3399-pc would require custom leds initialization based on user intervention of the power key. This code handles the user intervention via SPI environment variable. If someone or production systems wants this feature then 'pwr_key' has to be set otherwise it is normal like other rk3399 boards in Mainline.
Changes for v5: - drop banner changes - add code changes in roc-pc-rk3399.c Changes for v4: - enable SPL_BOARD_INIT in all platforms Changes for v3: - support leds on SPL - support env 'pwr_key'
Jagan Teki (5): roc-rk3399-pc: Move leds setup in SPL rockchip: Don't clear the reset status reg rockchip: Separate the reset cause from display cpuinfo rockchip: spl: Move board_early_init_f after cpu timer roc-rk3399-pc: Set LED only during POR and pwr_key=y
arch/arm/include/asm/arch-rockchip/cru.h | 3 +- arch/arm/mach-rockchip/Makefile | 5 +- arch/arm/mach-rockchip/cpu-info.c | 26 ++++---- arch/arm/mach-rockchip/spl.c | 5 +- arch/arm/mach-rockchip/tpl.c | 7 --- board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 67 ++++++++++++++++----- configs/roc-pc-mezzanine-rk3399_defconfig | 5 +- configs/roc-pc-rk3399_defconfig | 5 +- 8 files changed, 80 insertions(+), 43 deletions(-)
roc-rk3399-pc has some specific requirements to support LEDS, environment. board detection and etc prior to U-Boot proper.
So as of now SPL would be a better stage for these custom board requirements to support unlike TPL. Adding few of these custom requirements like LEDS in TPL would require extra code pulling and also the size of TPL can grow.
So, this patch moves the leds code from TPL into SPL after relocation.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5 - drop tpl.c file - update the code in board file
arch/arm/mach-rockchip/tpl.c | 7 ---- board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 36 +++++++++++---------- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- 4 files changed, 21 insertions(+), 26 deletions(-)
diff --git a/arch/arm/mach-rockchip/tpl.c b/arch/arm/mach-rockchip/tpl.c index 88f80b05a9..cc908e1b0e 100644 --- a/arch/arm/mach-rockchip/tpl.c +++ b/arch/arm/mach-rockchip/tpl.c @@ -43,18 +43,11 @@ __weak void rockchip_stimer_init(void) TIMER_CONTROL_REG); }
-__weak int board_early_init_f(void) -{ - return 0; -} - void board_init_f(ulong dummy) { struct udevice *dev; int ret;
- board_early_init_f(); - #if defined(CONFIG_DEBUG_UART) && defined(CONFIG_TPL_SERIAL_SUPPORT) /* * Debug UART can be used from here if required: diff --git a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c index 7c3a803654..4db3dd739c 100644 --- a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c +++ b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c @@ -6,14 +6,24 @@ #include <common.h> #include <dm.h> #include <log.h> -#include <asm/arch-rockchip/periph.h> -#include <power/regulator.h> #include <spl_gpio.h> -#include <asm/io.h> +#include <power/regulator.h> + #include <asm/arch-rockchip/gpio.h>
-#ifndef CONFIG_SPL_BUILD -int board_early_init_f(void) +#define GPIO0_BASE 0xff720000 + +static int led_setup(void) +{ + struct rockchip_gpio_regs * const gpio0 = (void *)GPIO0_BASE; + + /* Turn on red LED, indicating full power mode */ + spl_gpio_output(gpio0, GPIO(BANK_B, 5), 1); + + return 0; +} + +static int roc_pc_early_init_f(void) { struct udevice *regulator; int ret; @@ -30,19 +40,11 @@ int board_early_init_f(void) out: return 0; } -#endif - -#if defined(CONFIG_TPL_BUILD) - -#define GPIO0_BASE 0xff720000
int board_early_init_f(void) { - struct rockchip_gpio_regs * const gpio0 = (void *)GPIO0_BASE; - - /* Turn on red LED, indicating full power mode */ - spl_gpio_output(gpio0, GPIO(BANK_B, 5), 1); - - return 0; + if (IS_ENABLED(CONFIG_SPL_BUILD)) + return led_setup(); + else + return roc_pc_early_init_f(); } -#endif diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index c87a8568fc..15d511741f 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 @@ -21,7 +22,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_TPL=y -CONFIG_TPL_GPIO_SUPPORT=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 601f5c6ae1..2a6d0d22c8 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_SPL_GPIO_SUPPORT=y CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 @@ -21,7 +22,6 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 CONFIG_SPL_SPI_LOAD=y CONFIG_TPL=y -CONFIG_TPL_GPIO_SUPPORT=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y
Reviewed-by: Kever Yangkever.yang@rock-chips.com
Thanks, - Kever
Changes for v5
drop tpl.c file
- Debug UART can be used from here if required:
- #include <asm/arch-rockchip/gpio.h>
- if (IS_ENABLED(CONFIG_SPL_BUILD))
return led_setup();
- else
}return roc_pc_early_init_f();
reset reason can be used several stages of U-Boot bootloader like SPL, U-Boot proper based on the requirements.
Clearing the status register end of get_reset_cause will end up showing the wrong reset cause when it read the second time. For example, if board resets, SPL reads the reset status as RST whereas U-Boot proper reads the status as POR.
However, based on the latest testing clearing reset status won't be required for determine the last reset cause or following resets.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - new patch
arch/arm/include/asm/arch-rockchip/cru.h | 1 - arch/arm/mach-rockchip/cpu-info.c | 6 ------ 2 files changed, 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru.h b/arch/arm/include/asm/arch-rockchip/cru.h index 5eb17f9d55..d2057cb738 100644 --- a/arch/arm/include/asm/arch-rockchip/cru.h +++ b/arch/arm/include/asm/arch-rockchip/cru.h @@ -26,7 +26,6 @@ enum { SND_GLB_TSADC_RST_ST = BIT(3), FST_GLB_WDT_RST_ST = BIT(4), SND_GLB_WDT_RST_ST = BIT(5), - GLB_RST_ST_MASK = GENMASK(5, 0), };
#define MHz 1000000 diff --git a/arch/arm/mach-rockchip/cpu-info.c b/arch/arm/mach-rockchip/cpu-info.c index 21ca9dedce..bb5a198039 100644 --- a/arch/arm/mach-rockchip/cpu-info.c +++ b/arch/arm/mach-rockchip/cpu-info.c @@ -47,12 +47,6 @@ static char *get_reset_cause(void) */ env_set("reset_reason", cause);
- /* - * Clear glb_rst_st, so we can determine the last reset cause - * for following resets. - */ - rk_clrreg(&cru->glb_rst_st, GLB_RST_ST_MASK); - return cause; }
Thanks, - Kever
Changes for v5:
new patch
#define MHz 1000000
- return cause; }
reset cause is a generic functionality based on the soc cru registers in rockchip. This can be used for printing the cause of reset in cpuinfo or some other place where reset cause is needed.
Other than cpuinfo, reset cause can also be using during bootcount for checking the specific reset cause and glow the led based on the reset cause.
So, let's separate the reset cause code from cpuinfo, and add a check to build it for rk3399, rk3288 since these two soc are supporting reset cause as of now.
Tested-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - update Makefile
arch/arm/include/asm/arch-rockchip/cru.h | 2 ++ arch/arm/mach-rockchip/Makefile | 5 ++++- arch/arm/mach-rockchip/cpu-info.c | 20 ++++++++++++-------- 3 files changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru.h b/arch/arm/include/asm/arch-rockchip/cru.h index d2057cb738..13ea4aba8e 100644 --- a/arch/arm/include/asm/arch-rockchip/cru.h +++ b/arch/arm/include/asm/arch-rockchip/cru.h @@ -30,4 +30,6 @@ enum {
#define MHz 1000000
+char *get_reset_cause(void); + #endif /* _ROCKCHIP_CLOCK_H */ diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 5b38526fe0..121f23a563 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -22,11 +22,14 @@ ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) # we can have the preprocessor correctly recognise both 0x0 and 0 # meaning "turn it off". obj-y += boot_mode.o -obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o obj-$(CONFIG_MISC_INIT_R) += misc.o endif
+ifeq ($(CONFIG_TPL_BUILD),) +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu-info.o +endif + obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram.o
obj-$(CONFIG_ROCKCHIP_PX30) += px30/ diff --git a/arch/arm/mach-rockchip/cpu-info.c b/arch/arm/mach-rockchip/cpu-info.c index bb5a198039..d0f030109f 100644 --- a/arch/arm/mach-rockchip/cpu-info.c +++ b/arch/arm/mach-rockchip/cpu-info.c @@ -13,7 +13,7 @@ #include <asm/arch-rockchip/hardware.h> #include <linux/err.h>
-static char *get_reset_cause(void) +char *get_reset_cause(void) { struct rockchip_cru *cru = rockchip_get_cru(); char *cause = NULL; @@ -41,21 +41,25 @@ static char *get_reset_cause(void) cause = "unknown reset"; }
- /** - * reset_reason env is used by rk3288, due to special use case - * to figure it the boot behavior. so keep this as it is. - */ - env_set("reset_reason", cause); - return cause; }
+#if CONFIG_IS_ENABLED(DISPLAY_CPUINFO) int print_cpuinfo(void) { + char *cause = get_reset_cause(); + printf("SoC: Rockchip %s\n", CONFIG_SYS_SOC); - printf("Reset cause: %s\n", get_reset_cause()); + printf("Reset cause: %s\n", cause); + + /** + * reset_reason env is used by rk3288, due to special use case + * to figure it the boot behavior. so keep this as it is. + */ + env_set("reset_reason", cause);
/* TODO print operating temparature and clock */
return 0; } +#endif
Thanks, - Kever
Changes for v5:
update Makefile
#define MHz 1000000
- #endif /* _ROCKCHIP_CLOCK_H */
- return cause; }
- char *cause = get_reset_cause();
- printf("SoC: Rockchip %s\n", CONFIG_SYS_SOC);
return 0; }
Custom board_early_init_f not only deal with simple gpio configuration but also have a possibility to access clocks to process any clock related operations like checking reset cause state and etc.
So, call it once the rockchip timer initialization done instead of calling first place of board_init_f which doesn't have any rockchip init code before.
This specific concern was tested with checking reset reason via board_early_init_f, which indeed require a clk probe.
arch/arm/mach-rockchip/spl.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/spl.c b/arch/arm/mach-rockchip/spl.c index cddf4fd3d5..082828de66 100644 --- a/arch/arm/mach-rockchip/spl.c +++ b/arch/arm/mach-rockchip/spl.c @@ -122,8 +122,6 @@ void board_init_f(ulong dummy) debug("\nspl:debug uart enabled in %s\n", __func__); #endif
- board_early_init_f(); - ret = spl_early_init(); if (ret) { printf("spl_early_init() failed: %d\n", ret); @@ -137,6 +135,9 @@ void board_init_f(ulong dummy) /* Init ARM arch timer in arch/arm/cpu/armv7/arch_timer.c */ timer_init(); #endif + + board_early_init_f(); + #if !defined(CONFIG_TPL) || defined(CONFIG_SPL_RAM) debug("\nspl:init dram\n"); ret = dram_init();
Hi Jagan,
board_early_init_f() is suppose to run at very beginning before the spl framework is init, so I don't agree this move. I think the led setup code definitely should go to spl_board_init().
As I said before, the setup_led should be the common feature, so I think you can have a copy of setup_led() in rk3399.c as a weak common function, and if roc-rk3399-pc is really special, then you can have its own implementation.
Note that the spl_board_init in SPL is already very early stage in system init, should be enough for your case, you can do a test for the led_setup() in board_early_init_f() after this patch and in spl_board_init(), they should be very close.
Thanks, - Kever
Changes for v5:
new patch
- #if !defined(CONFIG_TPL) || defined(CONFIG_SPL_RAM) debug("\nspl:init dram\n"); ret = dram_init();
ROC-RK3399-PC has specific set of configurations for on-board led setup.
Due to easiness for user to know the state of the board roc-rk339-pc board code will setup the low power led on/off, and waiting for user to press power key and then glow full power led.
All this needs to happen only during power-on-reset not for soft reset or WDT.
Also, it is not a proper usage to ask the user to press the Power key if the board connected remotely, so add the environment variable 'pwr_key' to check as well.
So, user need to press Power key only - during POR - pwr_key=y
Tested-by: Suniel Mahesh sunil@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v5: - add changes on board file
board/firefly/roc-pc-rk3399/roc-pc-rk3399.c | 35 ++++++++++++++++++++- configs/roc-pc-mezzanine-rk3399_defconfig | 3 ++ configs/roc-pc-rk3399_defconfig | 3 ++ 3 files changed, 40 insertions(+), 1 deletion(-)
diff --git a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c index 4db3dd739c..ff2dc028a1 100644 --- a/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c +++ b/board/firefly/roc-pc-rk3399/roc-pc-rk3399.c @@ -5,19 +5,52 @@
#include <common.h> #include <dm.h> +#include <env.h> #include <log.h> #include <spl_gpio.h> +#include <asm/io.h> #include <power/regulator.h>
+#include <asm/arch-rockchip/cru.h> #include <asm/arch-rockchip/gpio.h> +#include <asm/arch-rockchip/grf_rk3399.h>
+#define PMUGRF_BASE 0xff320000 #define GPIO0_BASE 0xff720000
+/** + * LED setup for roc-rk3399-pc + * + * 1. Set the low power leds (only during POR, pwr_key env is 'y') + * glow yellow LED, termed as low power + * poll for on board power key press + * once powe key pressed, turn off yellow + * 2. Turn on red LED, indicating full power mode + */ static int led_setup(void) { struct rockchip_gpio_regs * const gpio0 = (void *)GPIO0_BASE; + struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; + bool press_pwr_key = false; + + if (IS_ENABLED(CONFIG_SPL_ENV_SUPPORT)) { + env_init(); + env_load(); + if (env_get_yesno("pwr_key") == 1) + press_pwr_key = true; + } + + if (press_pwr_key && !strcmp(get_reset_cause(), "POR")) { + spl_gpio_output(gpio0, GPIO(BANK_A, 2), 1); + + spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_A, 5), + GPIO_PULL_NORMAL); + while (readl(&gpio0->ext_port) & 0x20) + ; + + spl_gpio_output(gpio0, GPIO(BANK_A, 2), 0); + }
- /* Turn on red LED, indicating full power mode */ spl_gpio_output(gpio0, GPIO(BANK_B, 5), 1);
return 0; diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 15d511741f..14cda5850e 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 @@ -20,6 +21,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_TPL=y CONFIG_CMD_BOOTZ=y @@ -34,6 +36,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc-mezzanine" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 2a6d0d22c8..85f5c8f86b 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_SPL_DM_SPI=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 @@ -20,6 +21,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_SPI_LOAD=y CONFIG_TPL=y CONFIG_CMD_BOOTZ=y @@ -33,6 +35,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MISC=y
Jagan Teki
Kever Yang
